How to reset SRI (Service Reminder Indicator) Crafter/LT3
moonwalk
Stockholm Sweden
C?ID=207107
Hi
I Recently bought a VCDS Interface for my Crafter (LT3) 2010. It connects and i can access all modules. Everything seems to work nicely!
I have now done a service and needs to reset the SRI. I followed the guidline in http://www.ross-tech.com/vcds/tour/LT3.html where the SRI reset procedure for Crafter is described. I just cant finns the Channel "Service intervall extension.." or alike. Seems like my version (12.12.2) doesn´t include the right channel?
Anyone have any tips on this?
My autoscan as per below,
 VCDS version: AER 12.12.2
Dataversion: 20140418
Moonwalk
Sunday,18,Maj,2014,12:06:53:23306
Chassityp: 2E (2E - VW Crafter (LT3 / 2006 >))
Skanna: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3  B0 B1 B2 B3 B4 B5 B6 C1
VIN: WV1ZZZ2EZA6024726
01: Motor (CEC)       Labels: missing
   Artikelnr SW: 076 906 022 P    HW: 076 906 022 G
   Component: R5 2,5L EDC A020SG  7730
   Revision: 24H33---    Serienummer: VWXDZ0J1007072
   Kodning: 0003072
   Verkstad #: WSC 40206 222 99507
   VCID: 2077DCBBF098E91EBB7-FFFF
Readiness: 0 1 0 0 0
Adress 91: LT3 Motor        Labels: missing
   Kodning: 0003072
   VCID: 2077DCBBF398E91EBB7-8075
Adress 93: LT3 Startspärr        Labels: AER\2E0-905-865-93.clb
   Artikelnr SW: 2E0 905 865 AD    HW: 906 545 580 8
   Component: IMMO          0805  0815
   Revision: 00805000    Serienummer: VWXDZ0J1007072
   Verkstad #: WSC 00000 000 00000
   VCID: 6DE9F58F74CAF476401-8038
Ingen felkod funnen.
Adress 94: LT3 Airbag        Labels: missing
   Artikelnr HW: 9064461442
   Verkstad #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3332.rod (*)
   VCID: 5599BD6F345A5CB6981-8000
Adress 95: LT3 ESP        Labels: missing
   Artikelnr SW: 9069022800    HW: 0004460153
   ASAM Dataset: 3 4101
   ROD: CRFT_ESP_3_4101.rod (*)
   VCID: 043FB02B8F40153EBFF-8051
1 fel funnet:
5731 - ACM: Utvecklingsmonitor E
            Fellampa(MIL) tänd - Test färdigt - Aktiv/Lagrad
Adress 96: LT3 Instrument        Labels: missing
   Artikelnr SW: 9069024700    HW: 9069011800
   ASAM Dataset: 32 786
   ROD: CRFT_KOMBI_32_786.rod (*)
   VCID: 0539AD2F847A2C36A81-8050
Adress 99: LT3 Tändningslås        Labels: missing
   Artikelnr HW: 9065455808
   ASAM Dataset: 67 257
   ROD: CRFT_EZS_67_257.rod (*)
Adress 9A: LT3 Centrallås        Labels: AER\2E0-905-865-9A.clb
   Component: HF-FFB        0805  0815
   Revision: 00805000    Serienummer: 12345678901234
Adress 9B: LT3 Förardörr        Labels: missing
   Artikelnr HW: 9068205626
   ASAM Dataset: 33 260
   ROD: CRFT_FTUHR_33_260.rod
Adress 9C: LT3 Klimatanl.        Labels: missing
   Artikelnr SW: 2514450200    HW: 9068300885
   ASAM Dataset: 21 2
   ROD: CRFT_KLIMA_21_2.rod (*)
   VCID: F7C557E74E96CEA62AD-80A2
Adress 9E: LT3 Exvärm (Elek)        Labels: missing
   Artikelnr HW: 9064460029
   Verkstad #: WSC 131071 1023 2097151
   ASAM Dataset: 84 769
   ROD: CRFT_PTC_84_769.rod (*)
Adress 9F: LT3 Statvärm (vatten)        Labels: missing
   Artikelnr HW: 9064460629
   ASAM Dataset: 98 257
   ROD: CRFT_STH_98_257.rod (*)
Adress B1: LT3 Övre konsol        Labels: missing
   Artikelnr HW: 9065453607
   ASAM Dataset: 67 3
   ROD: CRFT1_OBF_67_3.rod (*)
Adress B3: LT3 Dragkroksenhet        Labels: missing
   Artikelnr HW: 1695455632
   ASAM Dataset: 21 4
   ROD: CRFT_TRL_21_4.rod (*)
Adress B4: LT3 Elcentral        Labels: missing
   Artikelnr SW: 9064420700    HW: 9065453801
   ASAM Dataset: 33 772
   ROD: CRFT_EZE_33_772.rod (*)
Adress B6: LT3 Ratt        Labels: missing
   Artikelnr SW: 9065402545    HW: 9065402545
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 0827A41BB368315ED37-805D
End   --------------------------------------------------------------------
I have no idea what it would be called in the Swedish version you are using, but in the standard English version, which you can download here (and it's no problem to have both Swedish and English versions installed on the same computer), the very first Adaptation channel in the list for that cluster should be called:
"Service interval extension -Reset"
moonwalk
Stockholm Sweden
C?ID=207107
I´ve come a bit closer to resetting the SRI using the standard English version:) I can access the channel ("Service interval extension -Reset konstante"). My question now is what "new value" to store???
The reported stored value is "0" (dec). I tried to store "0" (dec) as new value, corresponding to "00 00 00 00" Hex but got an Error stating "Request out of range", se log below. I also run a new autoscan using the English version.
Sunday,25,May,2014,11:03:23:23306
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
Dealer/Shop Name: Moonwalk
VIN: WV1ZZZ2EZA6024726   License Plate: GCU210
Mileage: 106783   Repair Order:
UDS Adaptation Channel: Service interval extension -Reset-Konstante
Stored value 0
Address 96:9069011800 recoded (ADP-Service interval extension -Reset-Konstante) from 0  to
VCDS Version: Release 12.12.2 (x64)
Moonwalk
Sunday,25,May,2014,11:10:00:23306
Chassis Type: 2E (2E - VW Crafter (LT3 / 2006 >))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
Address 01: Engine (CEC)       Labels: None
   Part No SW: 076 906 022 P    HW: 076 906 022 G
   Revision: 24H33---    Serial number: VWXDZ0J1007072
   Coding: 0003072
   Shop #: WSC 40206 222 99507
Address 91: LT3 Engine        Labels: None
   Coding: 0003072
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
   Revision: 00805000    Serial number: VWXDZ0J1007072
Address 94: LT3 Airbag        Labels: None
   Part No HW: 9064461442
   Shop #: WSC 00117 555 00000
Address 95: LT3 ESP        Labels: None
   Part No SW: 9069022800    HW: 0004460153
5731 - ACM: Development monitor E
            MIL ON - Test Complete - Active/Stored
Address 96: LT3 Instruments        Labels: None
   Part No SW: 9069024700    HW: 9069011800
Address 99: LT3 Ign. Switch        Labels: None
   Part No HW: 9065455808
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Revision: 00805000    Serial number: 12345678901234
Address 9B: LT3 Driver Door        Labels: None
   Part No HW: 9068205626
Address 9C: LT3 HVAC        Labels: None
   Part No SW: 2514450200    HW: 9068300885
   ASAM Dataset: 21 2
Address 9E: LT3 Aux.heat (elec)        Labels: None
   Part No HW: 9064460029
Address 9F: LT3 Stat.heat (water)        Labels: None
   Part No HW: 9064460629
Address B1: LT3 Upper Console        Labels: None
   Part No HW: 9065453607
   ASAM Dataset: 67 3
Address B3: LT3 Trailer Module        Labels: None
   Part No HW: 1695455632
   ASAM Dataset: 21 4
Address B4: LT3 Central Elec.        Labels: None
   Part No SW: 9064420700    HW: 9065453801
Address B6: LT3 Steering Wheel        Labels: None
   Part No SW: 9065402545    HW: 9065402545
Have you tried typing in '00 00 00 00' (without the quotes)?
moonwalk
Stockholm Sweden
C?ID=207107
Yes, I´ve tried 00 00 00 00 - Same result
Wait, I'm looking back at one of your previous posts and you already have a Stored Value of 0 in there..?
Stored value 0
Is the service reminder in this vehicle actually on? If so, please make an Adaptation Channel Map so we can see all the channels.
[Applications]
[Controller Channel Map]
- Controller Address = 96
- Login or security access code: leave blank
- Function: Adaptation
- Output: CSV file.
[Go]
moonwalk
Stockholm Sweden
C?ID=207107
Yep, the service reminder is on, at least the LCD tells me the car is overdue for service. I tried to write in a new date and distance since last serice (adpations) but that didn´t help
Here is the Channel Map
SW:9069011800   HW:9069011800 ---  LT3 Instruments
	Component:, Coding:
	32,786,CRFT_KOMBI_32_786.rod (*)
	Sunday,25,May,2014,20:38:11:23306
	VCDS Version: Release 12.12.2 (x64)  Data version: 20140212
(1)-Write service data-Day,25
(2)-Write service data-Month,5
(3)-Write service data-Year,14
(1)-Write time-Hour,20
(2)-Write time-Minute,38
(3)-Write time-Second,11
Write SVD2 Offset Write-Item Value,Write only channel
Write Timer Konstante Write-Item Value,Write only channel
Service interval extension -Reset-Konstante,0
Write service interval extension adaptation channel 38-Min. oil detection,On
Write service interval extension adaptation channel 40-Kilometers since last service,2200 km
Write service interval extension adaptation channel 41-Days since last service,27 Days
Write service interval extension adaptation channel 42-Driven distance (min) in km,20000 km
Write service interval extension adaptation channel 43-Driven distance (max) in km,40000 km
Write service interval extension adaptation channel 44-Time (max) in days,744 Days
Write service interval extension adaptation channel 45-Oil quality,2
Write service interval extension adaptation channel 47-Soot entry,2.71400
Write service interval extension adaptation channel 48-Thermal load,0.24600
Write service interval extension adaptation channel 49-Time (min) in days,372 Days
Write service interval extension adaptation channel 64-dwM2Min in15Ml Minus1905,825 ml
Write service interval extension adaptation channel 65-dwM2Max in15Ml Minus1905 1,1110 ml
Write service interval extension adaptation channel 66-dwOutM2 in15Ml Minus1905 1,-1905 ml
Write service interval extension adaptation channel 68-S Diff SUM in15Ml Minus1905 1,1.40201e+008 ml
Write service interval extension adaptation channel 69-Z_Diff_SUM_1,48179
Thomas
Sweden
C?ID=153019 (NRRT)
Reset service interval
	Component:, Coding:
Hi I have exactly the same problem, with my Crafter 2010. Have you find any solution to the problem yet?
moonwalk
Stockholm Sweden
C?ID=207107
Hi
Sort of nice to hear Iḿ not the only one having trouble resetting the SRI. To answer Thomas: No, I still haven't found a way to reset my SRI. I called VW to have them just reset but they are not interested in doing it without having performed the service. I can buy in to that but it leaves me with the SRi still reminding me every time i turn on the car. I have also tested later updates of VCDS without success. I have tried the manual reset procedure that can be found on the net - still no progress.
I would love to write some good news about this, maybe that the car runs nicely and i continue to service the car myself (successfully). VCDS works fine for what it can, except for this particular little feature - resetting the SRI on my 2010 Crafter
/Arne
We have something in the works that MAY solve this problem. PM me if you're interested in testing it.
moonwalk
Stockholm Sweden
C?ID=207107
I´m all in for testing what may solve this problem:) I have sent a PM
/Arne
grikinis
New Member
Lithuania
C?ID=228596 (NRRT)
Hi, had the same problem today (Request out of range), any updates?
Are you using the latest beta, 15.6.1 as of this moment?
Yupster
C?ID=218817
Hi
Any update to this??
I'm trying to reset the service indicator on a 2016 Crafter with a 2E chassis no and the channel list is completely different!
Which channel is it I need to reset??
Thanks
Dave
;SW:9069014901 HW:9069014901 --- LT3 Instruments
;Component: Coding:
;32 1056 CRFT_KOMBI_32_1056.rod
;Wednesday 17 May 2017 12:52:09:04619
;VCDS Version: Release 17.1.3 Data version: 20170320 DS267.7
;VCID: 071D8196BE3F3F79A8-8052
LR029456-Write SVD2 Offset Write Write only channel
LR029467-SVD 2 Offset write Write only channel
LR029500-LR029501-Write date-Date - Year 17
LR029500-LR029503-Write date-Date - Month 5
LR029500-LR029510-Write date-Date - Day 17
LR029522-LR029524-Write time-Time -Minute 53
LR029522-LR029527-Write time-Time -Second 55
LR029522-LR029532-Write time-Time -Hour 12
LR303066-WIV Reset (VW) Write 0
LR303076-AnpKanal_WIV_Kanal_Write_AKD69 Write 0
LR303086-AnpKanal_WIV_Kanal_Write_AKD68 Write -1905 ml
LR303096-AnpKanal_WIV_Kanal_Write_AKD66 Write -1905 ml
LR303106-AnpKanal_WIV_Kanal_Write_AKD65 Write -1905 ml
LR303116-AnpKanal_WIV_Kanal_Write_AKD64 Write 2.51656e+008 ml
LR303126-AnpKanal_WIV_Kanal_Write_AKD49 Write 372 Days
LR303136-AnpKanal_WIV_Kanal_Write_AKD48 Write 0
LR303146-AnpKanal_WIV_Kanal_Write_AKD47 Write 0
LR303156-AnpKanal_WIV_Kanal_Write_AKD45 Write 2
LR303168-AnpKanal_WIV_Kanal_Write_AKD44 Write 744 Days
LR303178-AnpKanal_WIV_Kanal_Write_AKD43 Write 40000 km
LR303188-AnpKanal_WIV_Kanal_Write_AKD42 Write 20000 km
LR303198-AnpKanal_WIV_Kanal_Write_AKD41 Write 1 Days
LR303208-AnpKanal_WIV_Kanal_Write_AKD40 Write 0 km
LR303218-AnpKanal_WIV_Kanal_Write_AKD38 Write On
Elapsed Time: 00:06
campcreekrv
Unverified
Australia
LP/IP
Same Problem and a Solution.
My vehicle is a VW Crafter 50 van, 2011 2E build. Service Reminder was on.
I have searched the net for weeks trying to come across a solution to this as my local dealer also will not reset the service without great a good deal of money exchanging hands. The issue some people don't understand is that the dashboard method for resetting will simply not work on many vehicles, I won't go into the reason for this.
I am still using VCDS Release 17.8.0 and initially found a major issue with Windows 10 Pro wiping out my drivers (fixed now)
I won't post my Map as it is identical to the previous Map posted.
Here is how it has worked for me;
1) Clear any DTC's
2) Click on LR135057-WIV Reset (VW) Write (This is your SERVICE RESET)
3) Enter "0" as "new value" (stored value is also "0")
4) Workshop code entered in this screen only is 12345 / 123 / 12345
5) Hit "Do It!"
6) Without leaving the previous screen, switch IGNITION to off then back to on position. (At this stage the service reminder is gone!)
7) Close down and exit VCDS
8) Pull up a chair with a cold drink in hand and celebrate!
It is now 4 days since I have completed the reset procedure, some people have reported a return of the service reminder after resetting but I have had no problem with this.
Good luck, I hope this works for everyone else with this problem.
grant@gendan
Hi all,
I have a question on a 2017 LT3. The controller map, part numbers etc are identical to those posted above by Yupster.
We have tried writing '0' to 'LR303066-WIV Reset (VW) Write' - which already had a stored value of '0' but this has not reset the values on the dashboard.
The dashboard is saying it is an Inspection due. Please can anyone help?
Thanks,
Dana
Western PA, USA
Hi Grant,
I took a look at that map and it looks like the service was reset properly. I realize that doesn't explain why the Inspection light is still on but I added additional SRI related text to the last column of the map:
;Component: Coding:
;321056CRFT_KOMBI_32_1056.rod
;Thursday5July201815:37:02:14247
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
LR029456-Write SVD2 Offset WriteWrite only channel
LR029467-SVD 2 Offset writeWrite only channel
LR029500-LR029501-Write date-Date - Year18
LR029500-LR029503-Write date-Date - Month7
LR029500-LR029510-Write date-Date - Day5
LR029522-LR029524-Write time-Time -Minute38
LR029522-LR029527-Write time-Time -Second28
LR029522-LR029532-Write time-Time -Hour15
LR303066-WIV Reset (VW) Write0WIV Reset (VW) Write - Konstante
LR303076-AnpKanal_WIV_Kanal_Write_AKD69 Write0Z Diff SUM
LR303086-AnpKanal_WIV_Kanal_Write_AKD68 Write-1905 mlS Diff SUM in 15Ml Minus1905
LR303096-AnpKanal_WIV_Kanal_Write_AKD66 Write-1905 mldw Out M2 in 15Ml Minus1905
LR303106-AnpKanal_WIV_Kanal_Write_AKD65 Write-1905 mldwM2 Max in 15Ml Minus 1905
LR303116-AnpKanal_WIV_Kanal_Write_AKD64 Write2.51656e+008 mldwM2 Min in 15Ml Minus 1905
LR303126-AnpKanal_WIV_Kanal_Write_AKD49 Write372 DaysTime min in Days
LR303136-AnpKanal_WIV_Kanal_Write_AKD48 Write0FV Sum Cons Wear Equiv
LR303146-AnpKanal_WIV_Kanal_Write_AKD47 Write0FR Sum Soot Equiv
LR303156-AnpKanal_WIV_Kanal_Write_AKD45 Write2Flexible Maintainace Interval
LR303168-AnpKanal_WIV_Kanal_Write_AKD44 Write744 DaysTime max in Days
LR303178-AnpKanal_WIV_Kanal_Write_AKD43 Write40000 kmW max in km
LR303188-AnpKanal_WIV_Kanal_Write_AKD42 Write20000 kmW min in km
LR303198-AnpKanal_WIV_Kanal_Write_AKD41 Write0 DaysDays Since Last Service
LR303208-AnpKanal_WIV_Kanal_Write_AKD40 Write0 kmKm Since Last Service
LR303218-AnpKanal_WIV_Kanal_Write_AKD38 WriteOnf Oil Min Recognition Is Off
Elapsed Time: 00:04
<tbody> </tbody>
I cannot add clarity to the channels with names like Diff SUM but someone else may. I believe:
  • WIV Reset (VW) Write - Konstante = ESI: Resetting ESI / normal oil change status. 0 should be reset
  • Days Since Last Service and zero is good (reset).
  • Km Since Last Service and zero is good (reset).
I'll check the German file to see if it adds any clarity to some of those channels but I honestly don't see why the service still shows INSP needed.
You may want to see if the channels report the same with our Beta (make sure the customer know how to switch his HN to the Beta channel) in addition to using the Soft Reset tickbox per the pic half way down on this page.
