- May 16, 2014
- 5,469
- 5,936
- Melbourne, Australia
- C?ID=194404
I do need it! I'm merely interested in a permanent terminal 15 solution so other modules can power up and talk to VCDS.
Eric: Here you go_
I'm not sure if you "Yanks" get taught these diagrams the same as us Southerners, but I hope the table is self explanatory
I've shown the way the Key-switch connector locks into the body of the steering module in the lower LHS to indicate the relative position of pin#1
Lastly, I suspect that you probably know having hooked-up the steering module to your test-bench, but the PC board into which the key-switch connector fits is double-sided. So the Pins make contact on both sides of the board as shown in the lower LHS picture
