Hello, ive had this issue before but i cant remember how i resolved it or even if i did
But i am trying to code a new battery in 19 and set the Amp capacity from 75 to 95
Everytime i do i get the following error
WSC 00001 imported 001 equipment 00001 was rejected by the control module, the command will probably fail please change your values
I have tried the default values, 12345, 123, 00000,000 etc and everything i can find from suggestions on the forum.
And i am totally at a lost cause now really
I also cant change any value either its not just specifically that one, but trying to update the serial number so the car knows a new battery has been installed
Any suggestions :/
24.5 vcds latest version installed
Autoscan below
Any suggestions :/
Autoscan below
Wednesday,01,May,2024,18:44:41:17950
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUZZZF55HA013527 License Plate:
Chassis Type: F5-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 65 6D 81
A5 AC BB BC D6 D7
VIN: WAUZZZF55HA013527 Mileage: 97821km-60783miles
Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 AG HW: 04L 907 309 L
Component: R4 2.0l TDI H34 1969
Revision: B1H34--- CVN: 121537D000000000B866C2AD
Coding: 0A254032232605083408
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM20TDI01104L906026AG 001006
ROD: EV_ECM20TDI01104L906026AG_001.rod
VCID: 6FBBC19977196D92BE9-803A
VINID: 9D196AAAA5851584400431421CEF334016
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W0 927 155 K HW: 0CJ 927 156
Component: 0CL 20TDIRdWH03 0004
Revision: --H03--- Serial number: 0000000593 CVN: A800CDE9
ASAM Dataset: EV_TCMDL382021 002024
ROD: EV_TCMDL382021_AU49.rod
VCID: 47CB49393F2995D2D69-8012
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071160335000307
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 G HW: 8W0 907 379 J
Component: ESP9 Plus H06 0719
Dataset Number: 8W2909504B 0003 CVN: B085950A
Coding: 0CAA489A28A30A9911A3489300841292E6A59230121450881200484967A549
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 49CF4F01293D63A2C0D-801C
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 G HW: 8W0 820 043 G
Component: Klima Zone 3 H32 0082
Coding: 141800295544440D02000100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 372B39F94FC9E552A69-8062
Subsystem 1 - Part No SW: 4M2 820 021 HW: 4M2 820 021
Component: J216 FLuftV H05 0003
Serial number: 00000000000001206140
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: 3918026880PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: Klima Heck H40 0073
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0266
Dataset Number: 8W2909514C 0028
Coding: 07501143E17900CD054587141BAC80B9110B3108000000000000000020001A810A450123025601
VCID: 025D982D548B70FA417-8056
Subsystem 1 - Part No SW: 8W6 955 119 A HW: 8W6 955 119 A
Component: 494 RL 161121 036 0471
Serial number: 00000001611170424011
Coding: 5FC7F7
Serial number: 20189511X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 06 07 2016 00595411
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE110101612010435
Coding: 230000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B10453945
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2616000152319006
65685 - Heated Seat Backrest; Front Right
B14E3 15 [00001000] - Open or Short to Plus
Fault Frequency: 18
Reset counter: 167
Mileage: 96953 km
Date: 2024.03.29
Time: 11:39:09
average_Voltage_terminals: 14.80 V
Outside air temperature sensor-Outside air temperature on CAN: 10.50 °C
interior_temperature: 19.50 °C
Vehicle speed: 35.65 km/h
65687 - Heated Seat Cushion; Front Right
B14E4 15 [00001000] - Open or Short to Plus
Fault Frequency: 18
Reset counter: 167
Mileage: 96953 km
Date: 2024.03.29
Time: 11:39:09
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0103
Serial number: 003UP0015XKV Dataset Number: 8W2909602AC 0003
Coding: AACCF0C00C800000585400F3D0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005013
ROD: EV_AirbaAU10BPAAU736_005.rod
VCID: 4CC17615264F768AFBB-8018
Subsystem 1 - Part No SW: ----------- HW: 442 062 911 16
Serial number: 3577Y00A5209FF917303
Subsystem 2 - Part No SW: ----------- HW: 442 062 911 16
Serial number: 3587Y00B9209FF9542EN
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 511 16
Serial number: 3517700AB2220D0251F0
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 511 16
Serial number: 3527700AB2220D0192E4
Subsystem 5 - Part No SW: ----------- HW: 442 0C0 501 17
Component: FrontSensor_D 1C5 014A
Serial number: 3557500A92135011323M
Subsystem 6 - Part No SW: ----------- HW: 442 0C0 501 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500A92135012321M
Subsystem 7 - Part No SW: ----------- HW: 442 0C0 501 17
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500BB2216102F0F/
Subsystem 8 - Part No SW: ----------- HW: 442 432 411 16
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00C12093B7173A8
Subsystem 9 - Part No SW: ----------- HW: 442 432 411 16
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00BD1FD7533055O
Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76B5F4FD08435C5A7DF-8022
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 C HW: 8W5 920 790 C
Component: FBenRDW H17 0309
Coding: 24AF49D8688406000100E9641000401000000000
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736_AU49.rod (VIN: N/A)
VCID: 42DD582D140BB0FA017-8016
16777024 - No Communication with Diagnostic Gateway
U0146 00 [00001000] - -
[BCME_0x23 communication error bap_error_timeout heartbeat]
Reset counter: 166
Mileage: 97483 km
Date: 2024.04.06
Time: 22:56:27
Part No SW: 8W5 907 468 D HW: 8W5 907 468 C
Component: Gateway H30 0308
Revision: 5A010004 Serial number: 0485A270617105 Dataset Number: 8W2909515B 0027
Coding: 0301000100008640410700000059001248100007000000000175078E10000000
GVL: 01583C0008040200408C08000000C80000080000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 002040
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: 4ACD700D2C3B68BAC97-801E
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20161209090156 20345
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 2075272204
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B
Component: LCM_MLBevoH05 0024
Dataset Number: 8W2909519A 0002
VCID: 77ABF9F90F492552669-8022
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 16000317597008
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 323D08EDA4AB007A917-8066
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Dataset Number: 8W2909520A 0002
Part No SW: 8W0 959 593 E HW: 8W0 959 593
Component: TSG FS 005 0057
Serial number: 0000230276534 Dataset Number: 8W2909872A 0017
Coding: 001FCA625001000000001482
B1487 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 146
Mileage: 97821 km
Date: 2024.05.01
Time: 00:00:06
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Dataset Number: 8W2909852N 0025
Coding: 09008380008000
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
VCID: 41DF5721110DABE218D-8014
Part No SW: 8W0 907 064 CB HW: 8W0 907 064 B
Component: BCM2 MLBevo 018 0342
Dataset Number: 8W2909501B 0025
Coding: 013500006F9100406309A0000600080233020010004306502F04000000040030001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU49.rod
VCID: 7EA5ECDD2073141A25F-802A
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY163232D8E
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000067894280
Part No SW: 8W0 959 592 E HW: 8W0 959 592
Component: TSG BFS 005 0057
Serial number: 0000232772172 Dataset Number: 8W2909873A 0017
Coding: 001FCA225C01000000001480
VCID: 4BC37509234171B2F21-801E
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 035 C HW: 8W5 035 035
Component: MU-P-LND-EU 033 1329
Serial number: A829B0HB012473 Dataset Number: 8W0909545L 0035
Coding: 01945301FF0A000013111101000A00102F000DE7017001009E
Subsystem 1 - Part No SW: V03 959 802 TQ HW: -----------
Component: ECE 2023 --- 0310
Subsystem 2 - Part No SW: 8W0 919 614 N HW: 8W0 919 614 N
Component: ControlUnit_B H22 0134
Serial number: APVAK105121600040158
Compact disc data bank:
Component: Gracenote2 --- 1015
6660 - No Communications with Display Unit 1 for Multimedia
U10E2 00 [00001001] - -
[Display 1: no signal/communication]
Reset counter: 108
Mileage: 96631 km
Date: 2024.03.23
Time: 12:35:13
Voltage terminal 30: 12.0 V
Address 65: Tire Pressure (J502) Labels: 4M0-907-273.clb
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H06 0010
Serial number: 30000000256810 Dataset Number: xiaozhihui 0004
ROD: EV_RDKHUFAU736_AU37.rod
VCID: 2F3B0199B7992D92FE9-807A
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31128897600000 Dataset Number: 8W2909541B 0004
Coding: 0610
ROD: EV_DeckLidCONTIAU736_VW41.rod
VCID: 48C94A0532379AAADF3-801C
0018 - Motor 1 for rear lid
B11D9 13 [00001000] - Open Circuit
Reset counter: 168
Mileage: 97545 km
Date: 2024.04.09
Time: 09:05:58
Motors for tailgate: activation-Motor 1 for tailgate: status: Malfunction
Motors for tailgate: activation-Motor 2 for tailgate: status: OFF
Motors for tailgate: activation-Closing Assist Motor: OFF
Motors for tailgate: activation-Luggage compartment cover motor: OFF
0023 - Hall Sensors in Motor 1 for Rear Lid
B1211 15 [00001000] - Open or Short to Plus
Mileage: 97545 km
Date: 2024.04.09
Time: 09:05:58
Status of hall sensor in motor for tailgate-Motor 1 for tailgate: Hall sensor voltage supply: Open circuit
Status of hall sensor in motor for tailgate-Motor 2 for tailgate: Hall sensor voltage supply: On
Status of hall sensor in motor for tailgate-Motor 1: Sensor 1: 00000001
Status of hall sensor in motor for tailgate-Motor 1: Sensor 2: 00000001
Status of hall sensor in motor for tailgate-Motor 2: Sensor 1: 00000001
Status of hall sensor in motor for tailgate-Motor 2: Sensor 2: 00000000
Status of hall sensor in motor for tailgate-Motor for luggage comp. cover: sensor 1: 00000000
Status of hall sensor in motor for tailgate-Motor for luggage compartment cover: Hall sensor voltage supply: OFF
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W2 713 041 J HW: 8W2 713 041 J
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20161123001249
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 3B2325C973E1C132421-806E
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 HW: 8W6 907 217
Component: BVS H14 0042
Dataset Number: 8W2909466B 0020
Coding: 0404090300000403024023A0AF0100FC90F0C020C020
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
VCID: 7F5B11D927791D122E9-802A
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 H HW: 4M0 907 355 B
Component: SCR-Stg-G3H05 0010
Dataset Number: 8W2909571H 0002
ASAM Dataset: EV_RDCMINERGAU736 005014
ROD: EV_RDCMINERGAU736.rod
VCID: 363534FD48C31C5ABDF-8062
Part No SW: 8W0 959 595 E HW: 8W0 959 595
Component: TSG HFS 005 0057
Serial number: 0000232513146 Dataset Number: 8W2909897A 0014
Coding: 000FC8220001000000001080
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 4EC57C1DD053449A95F-801A
Component: TSG HBFS 005 0057
Serial number: 0000232513088 Dataset Number: 8W2909896A 0014
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
Dataset Number: 8W2909471A 0008
VCID: 176BD9792F09C552869-8042
Component: LED1R H09 0008
Dataset Number: 8W2909472A 0008
End----------(Elapsed Time: 02:02, VBatt start/end: 12.5V/12.5V)-----------
