hello friends
I'm trying to figure out that the autohold works on my golf 7 2014 - to raise the handbrake when I open the door and if I'm not tied in -
I also have another golf 7 which is 2015 and it raises the handbrake when I open the door and if I have not buckled
;SW:5Q0-907-379-CK HW:5Q0-907-379-G --- ABS Brakes --- SA: 24990
;Component:ESC H31 0472, Coding:01FA62A124250972037E060941C42580462490C06082A4F30040F07AD009
;EV_Brake1UDSContiMK100IPB,033001,EV_Brake1UDSContiMK100IPB_033_VW37.rod
;Monday,22,April,2024,16:06:51:15841
;VCDS Version: Release 23.11.0 Data version: 20240322 DS351.0
;VCID: 8740714E8FAE6A22EE9-80D2
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE03493-Driver's door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Weak ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-IDE05287-Electromechanical parking brake-Automatic application,activated ,2
IDE04645-MAS05667-Electromechanical parking brake-Driver presence recognition via brake pedal,not activated ,2
IDE04765-Counter steer support,Strong ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire Pressure Monitoring System (TPMS),2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake Boost,4 ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05337-Starting vibration reduction,Strong ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,2 ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Always active ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,not activated ,1
MAS07300-Monitoring infotainment control unit,Security access required,1
MAS08145-Hill-start assistant: increase threshold,3 %,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,2
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,2
ENG118148-Developer_Function_1,0 ,1
ENG122612-Developer_Function_100,Security access required,1
ENG122613-Developer_Function_101,Security access required,1
ENG122614-Developer_Function_102,Security access required,1
ENG122615-Developer_Function_103,Security access required,1
ENG122616-Developer_Function_104,Security access required,1
ENG122617-Developer_Function_105,Security access required,1
ENG122618-Developer_Function_108,Security access required,1
ENG125054-Developer_Function_110,3 ,1
ENG118149-Developer_Function_2,Security access required,1
ENG118200-Developer_Function_3,Security access required,1
ENG118201-Developer_Function_4,Security access required,1
ENG118202-fill_and_bleed_information,Security access required,1
Elapsed Time: 00:14
;SW:3Q0-907-379-AF HW:3Q0-907-379-F --- ABS Brakes --- SA: 24990
;Component:ESC H42 0625, Coding:01FA62A12426096F077C060041C72580462490E06082A4F31440F07AC002
;EV_Brake1UDSContiMK100IPB,034036,EV_Brake1UDSContiMK100IPB_034.rod
;Monday,22,April,2024,16:30:15:15841
;VCID: FEAE14AAD0742BEADDF-80AA
IDE01763-Dimming,not activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE04456-Brake disk drying,Medium ,1
IDE05337-Starting vibration reduction-,Strong ,1
IDE05337-MAS02653-Starting vibration reduction-Limited torque,Deactivated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,Security access required,3
ENG130301-Developer_Function_121,not activated ,1
ENG127702-Developer_Function_5,Security access required,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,50 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,220 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,6 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,8 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,80 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,10 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,100 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,253 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,6 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,12 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,50 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,220 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,6 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,8 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,80 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,10 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,100 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,253 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,6 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,12 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
ENG118202-fill_and_bleed_information,Security access required,12
Elapsed Time: 00:16
