Robster
Hi All,
New joiner, so please go easy on me if this is an obvious answer.
I’ve replaced the Turbo Actuator on my 2010 Golf mk6 2.0 GTD.
Everything went swimmingly until I went to adjust the actuator rod using VCDS. I needed to go into Engine - Measuring Blocks -120 to set the voltage with a vacuum pump.
Unfortunately, for my car, the whole measuring blocks option is greyed out. I’ve trawled through the gazillions of items in Advanced Measuring Blocks but can’t find the item I’m after.
…is there somewhere else I should be looking?
To be clear, I’m looking for the entity that shows the voltage output of the actuator relative to the vacuum pressure. (I need to set the actuator position when the voltage is at 0.76V)
At the moment I’ve just eyeballed it to get me on the road, but obviously this isn’t ideal - especially as I have a 600 mile journey coming up at the weekend!
Looking forward to this being a simple case of me being dim!
Thanks in advance.
Rob
Thanks in advance.
Rob
