2013 a6 - esc fault
BIFFRIPJOCK
Canada
C?ID=532545
hello all
2013 a6 quatro prestige
120,xxx kms
a week ago or so i got a message on the dash, I i checked all lights, all signals they were fine, i thought it was weird. it then reappeared a second time a few days later
RIGHT TURN SIGNAL/BRAKE LIGHT/REAR LIGHT - all signals and lights still intact and warning has not returned
then i got this for the esc about 2 days after that second brake light warning
STABILATION CONTROL (ESC) FAULT - CONSULT OWNERS MANUAL.
i checked all fuses in the trunk and the side panels they are good. the battery is new one year old.
i tried holding the esc control button down for 6-10 seocnds, in park, nuetral, gear etc. the esc warning squiggly burn out on teh dash stays lit, the esc control button does not illuminate.
using VCDS i have the follwoing report. any input greatly appreciated
thanks
Saturday,06,April,2024,13:06:11:25342
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240322 DS351.0
VIN: WAUFGCFC8DN105626 License Plate:
Mileage: 122431km-76075mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 3C 42 44 46 52 53 55
56 5F 62 72 8F 90
VIN: WAUFGCFC8DN105626 Mileage: 122431km-76075miles
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CTUA) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 D HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0006
Revision: --H07--- CVN: 4C7FB7FB
Coding: 0A2A0032052601060000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551D 001007
ROD: EV_ECM30TFS0214G0907551D.rod
VCID: 2A0D0E227C7906BA517-807E
VINID: 9D19565D359321478100518218E63938B4
6201 - Function Restriction due to Faults in Other Modules
U1113 00 [01101000] - -
Fault Frequency: 23
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:07
Engine RPM: 1744.00 /min
Normed load value: 32.9 %
Vehicle speed: 58 km/h
Coolant temperature: 97 C
Intake air temperature: 42 C
Voltage terminal 30: 14.319 V
Engine speed: actual: 2336 /min
MAF_ENVD: 315.92940 mg/stroke
Coolant temperature (unfiltered): 80.25 C
Engine: operating status: PL
Engine load: 39.453125 %
Vehicle speed: actual: 29 km/h
6134 - Function Restriction due to Faults in Other Modules
U1113 00 [01101101] - -
Fault Frequency: 20
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:07
Engine RPM: 1745.00 /min
Normed load value: 33.3 %
Engine speed: actual: 2304 /min
MAF_ENVD: 321.37646 mg/stroke
Engine load: 40.234375 %
20136 - PCV Valve Malfunction
P052E 00 [01101101] - -
Fault Frequency: 28
Mileage: 113166 km
Date: 2023.09.14
Time: 11:47:44
Engine RPM: 705.00 /min
Normed load value: 17.6 %
Intake air temperature: 27 C
Voltage terminal 30: 14.726 V
Engine speed: actual: 672 /min
MAF_ENVD: 163.41176 mg/stroke
Coolant temperature (unfiltered): 99.00 C
Engine: operating status: IS
Engine load: 17.968750 %
Vehicle speed: actual: 0 km/h
Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1006
Revision: --H16--- CVN: 06AF4385
Coding: 000002
VCID: 2D07053E4D971182B45-8078
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 44A78F0122E5F1805B00
ASAM Dataset: EV_ESPPremiAU57X 004028
VCID: 36352A52B8C1525AC5F-8062
0156 - Function Restriction due to Faults in Other Modules
U1113 00 [00001000] - -
[NET_SAS_SteeringAngleFaultValue]
Fault Frequency: 24
Reset counter: 100
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:08
VzRef: 3A
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 02
F-Type: 3A
Uz: BA
0167 - Function Restriction due to Implausible Message(s)
U1112 00 [00001000] - -
[NET_SAS_SubInfoInitializationFailure]
Fault Frequency: 24
Reset counter: 100
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:08
VzRef: 3A
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 02
F-Type: 37
Uz: BA
Part No SW: 4H0 907 064 CC HW: 4H0 907 064 CC
Component: BCM2 2.0 H33 0433
Coding: 09A83046000000000000
VCID: 6C81C83AB68DD88AE3B-8038
Serial number: 2312000280499006
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AC HW: 4G0 820 043 AC
Component: KLIMA 2 ZONEN H11 0076
Serial number: 23011300110707
Coding: 6681201849
ASAM Dataset: EV_AirCondiBasisUDS 002040
ROD: EV_AirCondiBasisUDS_002.rod
VCID: 6099AC0A4AC58CEA4F3-8034
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001501714
Coding: 0600A096473C9FE08100088780003908CF9CD308A609022180 0004406000
VCID: 6FBBDF36879B2392C69-803A
Component: WWS57X 130107 H36 0080
Serial number: 130121163520
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 20911102
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 23 01 2013 00001162
Component: USHL4.2 H30 0030
Serial number: 0000002274555R4KTP02
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA120043000011409134
Coding: 020300
Subsystem 6 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 85480C86000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061302900750
Coding: 88C305
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71BFD94E912F3562D0D-8024
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8002P7HW Dataset Number: 4G0909602E 0007
Coding: 30323437313130303035554A304C34473053
VCID: 33331346ABB34772E21-8066
Serial number: 3575HRB40531PU942GPR
Serial number: 3585HRB400E4UPA0I8P%
Serial number: 3515JRB401050D62696.
Serial number: 3525JRB400E50D627P6P
Serial number: 3554VRB400E4UPLCL125
Serial number: 3564VRB400E4UPLCEH2F
1050117 - Databus
[CAN: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 100
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:07
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MAO001KO
Coding: 000434
VCID: 3829246AB255A42AD73-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 11 10 2012 11235152
Fault Frequency: 24
Reset counter: 100
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:07
(no units): 36.0
Text: 24A142027B001D0001
Bin. Bits: 01000010 00000010
Oil Pr. 1 OK
Part No SW: 4G8 920 932 B HW: 4G8 920 932 B
Component: TBenRdw H79 0515
Revision: 28460208 Serial number: 658210113596044
Coding: 0BAF09040B410008020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
VCID: 2E05023240916A9A8DF-807A
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000805361 Dataset Number: 4G0909515C 0064
Coding: 00CD073000
GVL: FDA1E80CDE60600D0000
ASAM Dataset: EV_GatewPkoUDS 001018
Serial number: 9168329101
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 1210170000000000002E
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000049712745
Coding: 0058130000006001000001010101102030303232203232
VCID: 77ABE756FFCB6B521E9-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H02 0056
Revision: -------- Serial number: EJ1BPA82029KC4 Dataset Number: 4G0909573C 0006
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 010 287-03
Coding: 0000001
VCID: 30391C4A56257C6A9F3-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0050
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F25.01.1300H03000AMS16116
Subsystem 4 - Serial number: S16116
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F17005E00628002000012
VCID: 47CB5796CFABDBD2AE9-8012
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0004155433 Dataset Number: 4G0909852H 0026
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D164254A94E7AE97-8066
4215044 - Function Restriction due to Faults in Other Modules
[Fehlerwert "Lenkradwinkel"]
Fault Frequency: 15
Reset counter: 100
Mileage: 121994 km
Date: 2024.03.26
Time: 21:21:50
Write only channel
Revision: 00002001 Serial number: 0188134438
Coding: 0106023A00FA408480B0080402050E07000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000126234
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO1979319D
Coding: 101F00
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 181
Mileage: 112568 km
Date: 2023.08.30
Time: 16:36:39
02615 - Fuel Tank Cap; Lock
Fault Frequency: 8
Reset counter: 184
Mileage: 112568 km
Date: 2023.08.31
Time: 16:13:32
02902 - Lamp for Brake / Blink / Parking 2; Right (M73)
Fault Status: 00101100
Fault Frequency: 9
Reset counter: 88
Mileage: 121473 km
Date: 2024.03.19
Time: 14:23:24
Component: TSG BF H03 0507
Coding: 011F17005E00628002000002
VCID: 46D55A92C8A1C2DA55F-8012
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000577556 Dataset Number: 4G0909522C 0005
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B030B2673831FB2AA1-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 130130-0002-210
Coding: 1221A6101002A300
ROD: EV_HeadlRegulBasic_AU21.rod
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156A%0D7685392
Coding: 020007020100000001
VCID: 221DE60204C9DEFA197-8076
Part No SW: 4G0 035 664 D HW: 4G0 035 664 B
Component: H-BN-NA H50 0622
Revision: -------- Serial number: 193AU0D7505019
Coding: 050200000003E0ED55128B0E00000003F00001020000000000
VCID: 270BF7166FEB3BD24E9-8072
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDCD000EA8G
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349MAU000GR
Component: CD-Database 4949
Component: TSG HL H03 0507
Coding: 010F17004000628002000002
VCID: 49CF51AED9BF2DA2B8D-801C
Component: TSG HR H03 0507
Component: RGS-VL H13 0080
Dataset Number: 4G0909614C 0001
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F194E51AF756290D-8064
12584197 - Function Restriction due to Faults in Other Modules
[Function limitation due to received error]
Reset counter: 100
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:07
Component: RGS-VR H13 0080
Dataset Number: 4G0909615C 0001
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Reset counter: 100
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:07
End----(Elapsed Time: 02:16, VBatt start/end: 11.9V/12.0V. VIgn 11.9V)----
Based on the fault code, that looks like an intermittently dodgy connection somewhere.
I'm not quite sure what to make of the faults in the ABS. One of them references the steering angle sensor. So does the fault in 44-Steering Assist. My guess is your steering angle sensor is starting to go, but that's just a guess.
BIFFRIPJOCK
Canada
C?ID=532545
hi, thx Uwe, i have discovered the vcds coding here on the site for the steering angle calibration. should i try that as a start? the car scanned clean and perfect just in late september. so i was surprised at all the codes hoping an item or two would resolve them if they are interlocked . i have researched about speed sensors and thier wires possibly a culprit, poor tail light connections or water as well. the brakes are easy 50- 60 % left the car is not aggressively raced or driven. i will recheck grounds and the battery connections
BIFFRIPJOCK
Canada
C?ID=532545
I performed the channel 16 steering calibration. No changes same codes. Does anyone have any other ideas.
Cheers
You might want to look at live readings from the steering angle sensor in the ABS and check if they're plausible.
BIFFRIPJOCK
Canada
C?ID=532545
Thanks today i did that with the wheel sensors they returned good. I did get a fault left front abs. But not sure i did it correctly. I will live test steering tommorow. And report back.
