We were on the last part of a 200 mile round trip yesterday in our 2016 MK2 VW Tiguan 2.0L TDI 4Motion.
When stopping at some traffic lights an audible warning flashed up, together with messages related to Auto Stop/start, ABS, ESC, TPMS and Park Pilot.
The car pulled away, but was a bit hesistant. We found a place to stop and switched off and restarted. The brake pedal felt a bit wierd, but we were able to complete our journey and I ran a scan today with VCDS.
Any ideas what the problem could be?
Sunday,31,March,2024,09:10:54:03359
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVGZZZ5NZHW337106 License Plate:
Mileage: 76423km-47487mi Repair Order:
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 22 29 36 39 42 44 52 55 5F 6C
A5 BB BC CA D6 D7
VIN: WVGZZZ5NZHW337106 Mileage: 76423km-47487miles
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 JC HW: 04L 907 309 P
Component: R4 2.0l TDI H24 3023
Revision: B4H24--- CVN: DBFBCE1D4C6C0C4B
Coding: 0119001203471D082000
ASAM Dataset: EV_ECM20TDI01104L906026JC 004002
ROD: EV_ECM20TDI01104L906026GQ_004.rod
VCID: 74B02969AE3BFE5A3BB-8020
VINID: 9E65EAAAA15EA989C30C704018E97954A6
17158 - Databus
U1123 00 [00100111] - Received Error Message
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
Engine RPM: 839.50 /min
Normed load value: 15.3 %
Coolant temperature: 90 �C
Intake air temperature: 78 �C
Voltage terminal 30: 12.280 V
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Acceleration: 0.000 m/s�
28991 - No Communications with NOX Sensor 1
U029D 00 [00100000] - -
Mileage: 75854 km
Date: 2024.03.06
Time: 12:31:09
Engine RPM: 0.00 /min
Coolant temperature: 48 �C
Intake air temperature: 39 �C
Voltage terminal 30: 12.000 V
Unlearning counter according OBD: 31
CAN status - brake control module 1-Bits 0-7: 8
selected gear-Bits 0-7: 0
Part No SW: 5Q0 614 517 CA HW: 5Q0 614 517 AC
Component: ESC H25 0408
Revision: 00000000 Serial number: 62126000000014
Coding: 0AEE929A34230B734778670062C94950492CD0E2E646927D34605078C02A02
ROD: EV_Brake1UDSContiMK100IPB_035.rod
VCID: 72BC2F71D42FF06A297-8026
0095 - Rear Right Wheel Speed Sensor
C101D 29 [10001001] - Signal Implausible
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
4202 - Front Left ABS Wheel Speed Sensor
C101A F1 [00001000] - Magnetic Field too Low
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:47
16417 - Display for Tire Pressure Monitoring
C1146 02 [10001001] - Signal Failure
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:56
32994 - Control Module for Electric Parking Brake
C10E2 F0 [00001001] - RPM Sensor Implausble Signal
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 K HW: 5NA 907 044 K
Component: AC Automat H35 4003
Revision: 20K08000 Serial number: 00000B00207067
Coding: 0012012420211001110510000010112A
ASAM Dataset: EV_ACClimaPrehVW37X 002014
VCID: 47CAAEA58F2D25C2AE9-8012
Subsystem 1 - Part No SW: 3G0 907 049 E HW: 3G0 907 049 E
Component: E265KlimaHeck H02 0201
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001623202154 Dataset Number: V03935243DS 0001
ROD: EV_BCMBOSCH_017.rod
VCID: 7F5AF645977DAD02569-802A
Subsystem 1 - Part No SW: 5NC 955 119 HW: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 160708 033 0372
Serial number: 00000001607050306596
Component: RLHS 042 0105
Serial number: S5Y16M08D17H05M33S09
Coding: 00A8DD
Serial number: 000000000ZY161960GTM
Serial number: 00000000000066626277
Part No SW: 3Q0 919 294 A HW: 3Q0 919 294
Component: PDC 8 Kanal H07 0020
Serial number: 002607167478021 Dataset Number: V03935247MH 0001
Coding: 0071551801
ASAM Dataset: EV_EPHBO18VW3260000 007015
ROD: EV_EPHBO18VW3260000.rod
VCID: 372ADE65FFCD5542DE9-8062
13637410 - Databus
[Bremsensteuerger�t - ESP_10.ESP_WegimpulsHR - Fehlerspeicher auslesen]
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
13637423 - Databus
[ESP_19_ESP_HR_Radgeschw_02 Datenbus empfangener Fehlerwert]
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
13637426 - Databus
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
Part No SW: 2Q0 907 572 J HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0156
Dataset Number: V03935241MW 0001
Coding: 2A0140C158FF8728749C8065104085
ASAM Dataset: EV_ACCMRRCONTIVW376 001011
ROD: EV_ACCMRRCONTIVW376_001.rod
VCID: 3B22C255C3E571223A1-806E
11 Faults Found:
1127 - Databus
[FAULT_TIMEOUT_PSD_04]
Reset counter: 89
Mileage: 75545 km
Date: 2024.03.02
Time: 14:00:31
Voltage terminal 15: 12.3 V
Control Module temperature: 40 �C
Longitudinal_acceleration_vehicle_reference: 0.53 m/s�
1218 - Databus
[FAULT_TIMEOUT_PSD_05]
Reset counter: 89
Mileage: 75545 km
Date: 2024.03.02
Time: 14:00:31
1219 - Databus
[FAULT_TIMEOUT_PSD_06]
Reset counter: 89
Mileage: 75545 km
Date: 2024.03.02
Time: 14:00:31
0803 - Databus
[FAULT_BV1_FEHLER]
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
Voltage terminal 15: 12.1 V
Control Module temperature: 36 �C
Longitudinal_acceleration_vehicle_reference: 0.06 m/s�
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
0809 - Databus
[FAULT_ESP_HR_RADGESCHWINDIGKEIT_LOWVOLT_OR_ERROR]
Reset counter: 104
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
0815 - Databus
[FAULT_ESP_WEGIMPULS_HL_ERROR]
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
2102 - Databus
[FAULT_ESP_CONTROL_FAIL]
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
0862 - Databus
[FAULT_DIRECTION_OF_TRAVEL_INVALID_SIGNAL]
Fault Frequency: 12
Reset counter: 104
Mileage: 76377 km
Date: 2024.03.30
Time: 13:43:00
Velocity_vehicle_reference: 2.89 m/s
Longitudinal_acceleration_vehicle_reference: 1.44 m/s�
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
Voltage terminal 15: 12.2 V
0863 - Databus
[FAULT_ESP_QBIT_WEGIMPULS]
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0315
Serial number: 003TDR21RP42 Dataset Number: V03935239XG 0001
Coding: 98CCC0C00C0000005C5400CF008800000065
VCID: 107845F9BAE3A27ABF3-8044
Left seat belt tensioner:
Serial number: 5NC857705C0225Q00552
Coding: 80000D
Right seat belt tensioner:
Serial number: 5NC857706C0228Q00087
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 000 508 16
Serial number: 3570000000010A0D3D1D
Subsystem 4 - Part No SW: ----------- HW: 480 001 708 16
Serial number: 3580000000041C449B1J
Subsystem 5 - Part No SW: ----------- HW: 480 402 208 16
Serial number: 35100019920F2B2467F6
Subsystem 6 - Part No SW: ----------- HW: 480 402 208 16
Serial number: 35200019920F2B22E663
Subsystem 7 - Part No SW: ----------- HW: 480 402 208 16
Serial number: 3550001A320F2B23C0F3
Subsystem 8 - Part No SW: ----------- HW: 480 402 208 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001C121DBA0174E3
Subsystem 9 - Part No SW: ----------- HW: 480 402 208 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001A920F2B2602D0
Subsystem 10 - Part No SW: ----------- HW: 480 402 208 16
Component: PedP_Sensor_C 000 6149
Serial number: 2300001A920F2B2373D/
Subsystem 11 - Part No SW: ----------- HW: 480 000 908 16
Serial number: I0M00000000B57354D13
Subsystem 12 - Part No SW: ----------- HW: 480 000 908 16
Serial number: I0N00000000D57354D16
Part No SW: 5Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160722500627
Coding: 0C00
ROD: EV_SMLSVALEOMQB.rod
VCID: 41DEB0BDA1091BF260D-8014
Part No SW: 5NA 920 791 A HW: 5NA 920 791 A
Component: KOMBI 405 2153
Coding: 27A400006F84260001886B031401000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009052
U1110 00 [00001000] - -
[BAP_TEL_0x28 keine Kommunikation]
Fault Frequency: 11
Reset counter: 104
Mileage: 75205 km
Date: 2024.02.08
Time: 11:45:51
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005212445 Dataset Number: V03935239XY 0001
Coding: 030500041F087300FB07225E0A0F00010001050000000000000000000000
GVL: 01D43C0000000000409C90000002480010000000000000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 7CA00149866BB61A73B-8028
Generator:
Subsystem 2 - Part No SW: 5TA 959 442 B HW: 5TA 959 442 B Labels: 3C8-959-537.CLB
Serial number: 2181604401300585AT2B
Coding: 2C0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Component: J367-BDMHella H11 9070
Serial number: 6803305405
Serial number: HA1-00011.07.16 Dataset Number: v1260x015G0 0000
Coding: 0101
VCID: 4ACC97919C3FD8AAB17-801E
16656 - Databus
[Bremsensteuerger�t - no speed signal]
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH07 0014
VCID: 45D6A4ADB52137D25C5-8010
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0020
Serial number: Y0006PHB14851
Coding: 0014000000000500018281818181000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
VCID: 3C20C149C6EB761A33B-8068
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Component: TSG FS 020 0041
Serial number: 030416ED314107 Dataset Number: V03935236MK 0001
Coding: 003F0220D201048000001000
VCID: 43D2BAB5BB1509E2721-8016
Component: EPS_MQB_ZFLS 128 1072
Dataset Number: V03935244JH 0001
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
19716 - Databus
[ESP_10 Botschaft - SNA-Check]
Reset counter: 104
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
Motor status: 02
System status: Driving mode
Supply voltage: 12.25 V
Temperature: 61.0 �C
KFC: 4D
KFA: 00 04
Freeze frame conditions: 21
uAdSensI_U1V2Filtered_gdu16: 1.21 V
uioUdNotFilt_xdu16: 12.44 V
uAdSensI_SwitchedKl30_xdu16: 12.44 V
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
20228 - Databus
[ESP_19 Botschaft - SNA-Check]
Reset counter: 104
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
Motor status: 02
KFC: 4F
KFA: 00 04
Component: TSG BFS 020 0041
Serial number: 090716EG905536 Dataset Number: V03935238QV 0001
Coding: 003F0020DE01048000001000
VCID: 42DCBFB1A40F00EA797-8016
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0051
Revision: -------- Serial number: -------------- Dataset Number: V03935231LM 0001
Coding: 08AE00104B200201
ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
13705987 - Databus
U1123 00 [10001001] - Received Error Message
[Fehlerwert im Signal ESP_HR_Radgeschw]
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0751
Serial number: Dataset Number: V03935247LK 0001
Coding: 02730601FF00000051110101008808001F0100E6012000008F
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 313EE07D11A98B7290D-8064
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL036AK
Subsystem 2 - Part No SW: 5NA 919 866 AG HW: -----------
Component: ECE AS 2020 --- 1310
Component: RVC Compact H18 0231
Coding: 0123060102002017000040
VCID: 392ED85DC9D9433228D-806C
13705990 - Databus
[Errorvalue-monitoring ESP_10.ESP_Wegimpuls_HR]
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:48
passive
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H06 0220
Serial number: 19081611P11296 Dataset Number: V03935242TC 0001
Coding: 0003070600000401000213448050A10094000E200040
VCID: 3A2CC751CCDF482A217-806E
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 64
Mileage: 76377 km
Date: 2024.03.30
Time: 13:42:46
Control Module temperature: 44 �C
Outside temperature: 14.5 �C
Vehicle speed: 0.00 km/h
System run time: 6854.4 s
mid: 02 E0
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 0
Software_Info_3: 2
Software_Info_2: 2
Software_Info_1: 0
1122664 - Databus
[TIMEOUT_PSD_04]
Reset counter: 89
Mileage: 75545 km
Date: 2024.03.02
Time: 14:00:31
Control Module temperature: 21 �C
Outside temperature: 3.0 �C
System run time: 308.1 s
mid: 01 F8
Engine_Running_Info: 0
Software_Info_4: 0
Software_Info_3: 2
Software_Info_2: 2
Software_Info_1: 0
Component: TSG HFS 020 0041
Serial number: 280716EGS12886 Dataset Number: V03935244TR 0001
Coding: 002A00200100048000001000
Component: TSG HBFS 020 0041
Serial number: 290716EGS18653 Dataset Number: V03935245EM 0001
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 013 0005
Dataset Number: V03935237GM 0001
Coding: 308040732602
ROD: EV_SunRoofCONTIAU736_006.rod
VCID: 3D26CC4DDDF17F12045-8068
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 167433E198074C4AE5F-8042
0774 - Light Bulb for Low Beam
C1198 29 [00001000] - Signal Implausible
Reset counter: 104
Mileage: 75171 km
Date: 2024.01.28
Time: 13:30:24
Component: LED1R H09 0003
Reset counter: 104
Mileage: 75171 km
Date: 2024.01.28
Time: 13:30:24
End----(Elapsed Time: 02:10, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
