I need to make some changes (blink with indicator or turn on with DRL) with the rear lamp of Skoda Slavia sedan.
Can anyone please help me to identify the channels for the rear lamps.
However, I managed to find one as Leuchte23SL HLC7 and Leuchte24SL HRA69, Please help to find others
Auto Scan and AdpMap (09) files attached.
Sunday,11,February,2024,12:53:17:24446
VCDS Version: 23.11.0.0 HEX-V2 CB: 0.4643.4
VIN: MEXBPEPB9NG000000 License Plate:
Chassis Type: PB-SK27 (2Q0)
Scan: 01 03 05 08 09 15 17 19 2B 44 47 5F
VIN: MEXBPEPB9NG000000 Mileage: 19941km-12390miles
Address 01: Engine (J623-DTBA) Labels: None
Part No SW: 04C 906 025 DK HW: 04C 907 309 CF
Component: R3 1.0l TFS H80 2834
Revision: DYH80000 CVN: 8461162F
Coding: 01190012232409001000
Shop #: WSC 46447 005 1048576
ASAM Dataset: EV_ECM10TFS01104C906025DK 003005
ROD: EV_ECM10TFS01104C906025DK.rod
VCID: 6C81D4FD360E008AE3B-8038
VINID: 755A1281581225E5C000900618CC9D1267
18841 - Switch for Start-Stop Operation
P168E 00 [00100000] - Stuck Closed
[Button for start-stop operationElectrical malfunction]
34785 - EVAP Emission Control Sys
P0441 00 [01100000] - Incorrect Flow
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5QP 614 517 HW: 2Q0 614 517 L
Component: ESC_base H13 0201
Serial number: 36903379220321
Coding: 39128B4F3B419CB6D1FCDC1C52E062A649D4CD06224A26242C541254454A4665922BB36044526424342A482AA231D6431F8C6BC2F84CE47032270E
Shop #: WSC 00793 648 00200
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
ROD: EV_Brake1BOSCHESPMQBA0_005_SK27.rod
VCID: 0E45BE7560D2929AADF-805A
1272 - Tire Pressure Warning
C102D 00 [10001001] - -
Reset counter: 35
Mileage: 10318 km
Date: 2023.06.07
Time: 21:31:06
Part No SW: 3Q0 959 435 Q HW: 3Q0 959 435 Q
Component: VWKESSYMQB 037 1400
Revision: 00037000 Serial number: 0590706264 Dataset Number: V03935342GU 0001
Coding: 032C0C0623
ASAM Dataset: EV_KessyHellaMQBAB 004055
ROD: EV_KessyHellaMQBAB.rod
VCID: 48C9486D42360CAAA73-801C
1074183 - Terminal 50
B11A4 11 [00001000] - Short to Ground
Reset counter: 49
Mileage: 19918 km
Date: 2024.02.11
Time: 11:27:01
Terminal_15_Kessy_specified_value: OFF
Terminal_15_Kessy_actual_value: OFF
Terminal_15_central electric_actual_value: Timeout
Terminal_15red_Kessy_specified_value: OFF
Terminal_15red_Kessy_actual_value: OFF
Terminal_S_Kessy_specified_value: OFF
Terminal_S_Kessy_actual_value: OFF
Terminal_S_central electric_actual_value: Timeout
Terminal_50_Kessy_specified_value: On
Terminal_50_Kessy_actual_value: On
ZAT_pressed: On
Park selector lever position: Not engaged and not locked
Request active: Condition met
Enabling Steering Column Lock: Condition not met
Enabling immobilizer: Condition not met
Control Module Voltage: 12.183 V
Vehicle speed: 0.0 km/h
Engine RPM: 0.0 /min
Status of vehicle locking: Vehicle unlocked
Coding information: coded
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID-sensor 1 authentication: status: No response
ID-sensor 2 authentication: status: No response
ID-sensor 3 authentication: status: No response
ID-sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 6JM 907 057 A HW: 6JM 907 057 A
Component: Climatronic 035 0208
Coding: 211100000400003101000400024011050101350000000000000000000000
ASAM Dataset: EV_ACClimaBHBMQBA0Touch 001008
ROD: EV_ACClimaBHBMQBA0Touch.rod
VCID: 4ACD72655C3AFEBAB17-801E
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
B10F0 00 [00001000] - -
Fault Frequency: 12
Reset counter: 46
Mileage: 19349 km
Date: 2024.01.29
Time: 13:59:06
Voltage terminal 30: 12.8 V
Compressor shut-off condition: Shut-off of engine control module via CAN (T > 15 sec.)
Part No SW: 2Q0 937 089 D HW: 2Q0 937 089 C
Component: BCM A0 Std H12 0954
Serial number: 014160422A0659 Dataset Number: V03935375QW 0001
ASAM Dataset: EV_BCMA0 207001
ROD: EV_BCMA0_207_SK26.rod
VCID: 3B2327A103E057323A1-806E
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: SBY22M02D08H21M08S11
Coding: 00184D
Driver door control module:
Subsystem 2 - Part No SW: 5QR 959 801 C HW: 5QR 959 801 A
Component: FHSG_DRV 003 0012
Serial number: AP0883RHNA1822048518
Coding: 2D2203
Part No SW: 2Q0 959 655 AP HW: 2Q0 959 655 AP
Component: VW22Airbag 020 0511
Revision: -------- Dataset Number: V03935365GB 0001
Coding: 88CCC000000000007C000000000800000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 0B43B76113C0A7B24A1-805E
Subsystem 1 - Part No SW: ----------- HW: 442 060 610 21
Serial number: 3577Y55B905DFAD231AT
Subsystem 2 - Part No SW: ----------- HW: 442 060 610 21
Serial number: 3587Y559D05C32825254
Subsystem 3 - Part No SW: ----------- HW: 442 0B0 202 22
Serial number: 35177129908C8321C2AG
Subsystem 4 - Part No SW: ----------- HW: 442 0B0 511 21
Serial number: 3527782A307EF5C4E1B1
Subsystem 5 - Part No SW: ----------- HW: 442 130 202 22
Component: FrontSensor_D 290 118A
Serial number: 355AG93A2C76E938A59H
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 6JM 920 310 HW: 6JM 920 310
Component: KOMBI 030 3092
Coding: 252408102180000C020828001000000000000500
ASAM Dataset: EV_DashBoardJCIMQBAB 010005
ROD: EV_DashBoardJCIMQBAB_010_VW27.rod
VCID: 7CA1E4BD466E900A73B-8028
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [00001000] - -
[BAP_Audio_0x31 keine Kommunikation]
Reset counter: 7
Mileage: 19298 km
Date: 2024.01.29
Time: 08:22:46
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 2Q0 909 901 E HW: 2Q0 937 089 C
Component: GW MQB A0 H12 0954
Serial number: 014160422A0659 Dataset Number: V03935375KZ 0001
Coding: 030100042F00570000000000000F00010001070000000000000000000000
GVL: 01403C0000000600400000000080480000000000000000000000000000000000
ASAM Dataset: EV_GatewA0 013026
ROD: EV_GatewA0_VW27.rod
VCID: 34310C9D2EBE984AFBB-8060
Generator:
Component: 4-00-12-00-04
Subsystem 2 - Part No SW: 5E3 919 719 H HW: 5E3 919 719 H Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H02 0110
Serial number: PR6-0440061056220743
Coding: 240000
Subsystem 3 - Part No SW: 2Q0 915 181 B HW: 2Q0 915 181 B
Component: J367-BDMBOSCH H03 2012
Serial number: 1023D218
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H10 0021
Serial number: 22000043905002
Coding: 0000000000000000
ROD: EV_ELVMarqMQBA0_VW53.rod
VCID: 313F0589D1ACAD6290D-8064
Address 44: Steering Assist (J500) Labels: None
Part No SW: 5QR 909 144 C HW: 5QR 909 144 A
Component: EPS_ECU 430 4250
Serial number: 000013.10.21000 Dataset Number: V03935361EU 0001
Coding: 00000000000000000101020101000100000001010101
ASAM Dataset: EV_SteerAssisNSKGEN3MQB 004008
ROD: EV_SteerAssisNSKGEN3MQB.rod
VCID: 56F596159882AA5A25F-8002
Part No SW: 5Q6 035 456 HW: 5Q6 035 456
Component: KonzernAmp 8K H01 2427
Revision: -------- Serial number: A1117A00259658 Dataset Number: V03935361ER 0001
Coding: 0302000000AAAA00000000000000
ASAM Dataset: EV_AMPCAN8C1PASE 001015
ROD: EV_AMPCAN8C1PASE_SK27.rod
VCID: 73B3CF816B30DF72221-8026
Part No SW: 6JM 035 180 HW: 6JM 035 180
Component: MU-R--R2 H04 0576
Serial number: SKZ7Z2A4305266 Dataset Number: V03935369AH 0001
Coding: 32711608000000000000000000000000000000000000000000
ASAM Dataset: EV_MUREGIO 001010
ROD: EV_MUREGIO.rod
VCID: 7EA5EEB55072821A5DF-802A
End----------(Elapsed Time: 00:48, VBatt start/end: 12.3V/12.2V)-----------
;SW:2Q0-937-089-D HW:2Q0-937-089-C --- Cent. Elect.
;Component:BCM A0 Std H12 0954, Coding:
;EV_BCMA0,207001,EV_BCMA0_207_SK26.rod
;Sunday,11,February,2024,12:57:10:24446
;VCDS Version: Release 23.11.0 Data version: 20231027 DS351.0
;VCID: 3B2327A103E057323A1-806E
IDE00001-ENG130235-Production mode-Entry_control,not_active ,3
IDE00001-ENG115730-Production mode-Exterior lighting,not_active ,3
IDE00001-ENG112304-Production mode-Heckwischer,not_active ,3
IDE00001-ENG98647-Production mode-Interior lights,not_active ,3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not_active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not_active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not_active ,3
IDE00002-Transport mode,active ,4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,5
IDE02269-ENG149191-Acknowledgement signals-Akustische_Rueckmeldung_entriegeln,not active ,5
IDE02269-ENG149190-Acknowledgement signals-Akustische_Rueckmeldung_global,not active ,5
IDE02269-ENG149195-Acknowledgement signals-Akustische_Rueckmeldung_Signalhorn,not active ,5
IDE02269-ENG149192-Acknowledgement signals-Akustische_Rueckmeldung_verriegeln,not active ,5
IDE02269-ENG149194-Acknowledgement signals-Dauer_der_Akustischen_Rueckmeldung_vom_Einfachhorn,normal ,5
IDE02269-ENG149193-Acknowledgement signals-Menuesteuerung_akustische_Rueckmeldung,not active ,5
IDE02269-ENG149189-Acknowledgement signals-Optische_Rueckmeldung_3.Bremsleuchte,not active ,5
IDE02269-ENG149188-Acknowledgement signals-Optische_Rueckmeldung_Komfortschliessen,not active ,5
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,5
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,5
IDE02488-Anti-theft system interior monitoring,No Response From Subnet Component,3
IDE02711-ENG149246-Rear wiper-Automatisches_Heckwischen,not active ,8
IDE02711-ENG112304-Rear wiper-Heckwischer,Keine_Spannungsanforderung ,8
IDE02711-ENG149248-Rear wiper-Heckwischer_Weiterlauf,not active ,8
IDE02711-ENG115850-Rear wiper-Komfortwischen_Heck,not active ,8
IDE02711-ENG149251-Rear wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_1,0 s,8
IDE02711-ENG149252-Rear wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_2,0 s,8
IDE02711-ENG149250-Rear wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Automatik,0 s,8
IDE02711-ENG149249-Rear wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Intervall,0 s,8
IDE02711-ENG149245-Rear wiper-Menuesteuerung_Komfortwischen_HW,not active ,8
IDE02711-ENG148996-Rear wiper-rear_window_wiper,not installed ,8
IDE02711-ENG149247-Rear wiper-Traenenwischen_Heck,not active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE02957-ENG154500-Ambient lighting-Ambience_borders_front,installed ,8
IDE02957-ENG133384-Ambient lighting-Ambient_Farbliste_HMI,not active ,8
IDE02957-ENG154513-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,8
IDE02957-ENG154514-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,8
IDE02957-ENG149168-Ambient lighting-Ambientelicht_mit_raste_heckdeckel,not enabled ,8
IDE02957-ENG126836-Ambient lighting-Ambientemenue mit alle Zonen,not active ,8
IDE02957-ENG126835-Ambient lighting-Ambientemenue mit globalem aus,not active ,8
IDE02957-ENG154907-Ambient lighting-Applikationsleisten_Tuer,not installed ,8
IDE02957-ENG154995-Ambient lighting-Cupholderbeleuchtung,not installed ,8
IDE02957-ENG125648-Ambient lighting-Dachbeleuchtung,not installed ,8
IDE02957-ENG125029-Ambient lighting-Defaultwert Ambienteprofil Farbe,NOT-DEFINED ,8
IDE02957-ENG149163-Ambient lighting-Defaultwert_Ambienteprofil_Fussraum,0 %,8
IDE02957-ENG149164-Ambient lighting-Defaultwert_Ambienteprofil_Tuer,30 %,8
IDE02957-ENG149165-Ambient lighting-Defaultwert_Ambienteprofil_Vorn,30 %,8
IDE02957-ENG125651-Ambient lighting-Farbwahl ueber Fahrprofil,not installed ,8
IDE02957-ENG125650-Ambient lighting-Farbwahl ueber HMI,not installed ,8
IDE02957-ENG114629-Ambient lighting-Footwell lighting,not installed ,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
IDE02957-ENG155264-Ambient lighting-Lautsprecherbeleuchtung,not installed ,8
IDE02957-ENG125647-Ambient lighting-Mittelkonsolenbeleuchtung,not installed ,8
IDE02957-ENG125649-Ambient lighting-Panoramaschiebedachbeleuchtung,not installed ,8
IDE02957-ENG149167-Ambient lighting-Tuerinnengriff_mit_Tuertafel,not installed ,8
IDE02957-ENG149166-Ambient lighting-Tuerinnengriffbeleuchtung_mit_I-Tafel,not installed ,8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,0.0 °,16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,40.0 %/s,16
IDE03638-ENG149111-Stationary cornering lamp-bei_Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.0 °C,16
IDE03638-ENG149114-Stationary cornering lamp-Obere_Geschwindigkeitsschwelle,40.0 km/h,16
IDE03638-ENG149117-Stationary cornering lamp-obere_Grenztemperatur,95.0 °C,16
IDE03638-ENG149116-Stationary cornering lamp-Oberer_Lenkradwinkel,90 °,16
IDE03638-ENG149113-Stationary cornering lamp-Untere_Geschwindigkeitsschwelle,0.0 km/h,16
IDE03638-ENG149118-Stationary cornering lamp-untere_Grenztemperatur,80.0 °C,16
IDE03638-ENG149115-Stationary cornering lamp-Unterer_Lenkradwinkel,30 °,16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE_R119 ,16
IDE03638-ENG149112-Stationary cornering lamp-Zeitwert_Einschaltzeit_Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,9
IDE04927-MAS01535-Window heater-Rear window defogger,installed ,9
IDE04927-MAS01564-Window heater-Front windshield heater,not installed ,9
IDE04927-ENG142182-Window heater-Abschalttemperatur_fuer_Frontscheibenheizung,35.0 °C,9
IDE04927-ENG142181-Window heater-Abschalttemperatur_fuer_Heckscheibenheizung,35.0 °C,9
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,0 s,9
IDE04927-ENG142180-Window heater-Heckscheibenheizung_Zeitwert,600 s,9
IDE04927-ENG142179-Window heater-Temperaturabhaengige_Einschaltzeit_FSH,not active ,9
IDE04927-ENG142178-Window heater-Temperaturabhaengige_Einschaltzeit_HSH,not active ,9
IDE05145-Light configuration,0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 08 09 1C 06 00 9C 00 00 00 04 4C 00 4C 14 00 64 08 0A 1C 07 00 9C 00 00 00 01 44 00 4B 14 00 7F 08 0A 7F 00 00 00 00 00 00 01 3A 00 49 14 00 7F 08 09 7F 00 00 00 00 00 00 05 36 00 1A 0B 1E 7F 0D 0F 7F 00 00 00 00 00 00 05 40 00 1B 0C 1E 7F 0E 0F 7F 00 00 00 00 00 00 20 37 00 1C 0D 0F 7F 00 00 00 00 00 00 00 00 00 20 41 00 1D 0E 0F 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,208
IDE05548-ENG149125-Additional interior light-Signal_mapping_ambient_lighting_doors_lin,0 ,38
IDE05548-ENG149126-Additional interior light-Signal_mapping_door_handle_lighting_lin,0 ,38
IDE05548-ENG149127-Additional interior light-Signal_mapping_puddle_light_lin,puddle light ,38
IDE05822-Anti-theft alarm system vehicle inclination sensor,No Response From Subnet Component,38
IDE05823-DWA Interior monitoring parameter set,No Response From Subnet Component,38
IDE06089-ENG149261-Seat heater level current consumption allocation-Art_der_Sitzheizungsregelung,Time-controlled ,36
IDE06089-ENG155386-Seat heater level current consumption allocation-Not_networked_seat_heater_rearseats,connected ,36
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,not installed ,36
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,36
IDE06089-ENG149262-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 1,0 %,36
IDE06089-ENG149263-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 2,20 %,36
IDE06089-ENG149264-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 3,0 %,36
IDE06089-ENG149265-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 4,80 %,36
IDE06089-ENG149266-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 5,0 %,36
IDE06089-ENG149267-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 6,100 %,36
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.05 ,36
IDE06089-ENG149271-Seat heater level current consumption allocation-Sitzheizung Stufe 0 Ansteuerzeit,2 min,36
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,24.00 °C,36
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C,36
IDE06089-ENG149269-Seat heater level current consumption allocation-Sitzheizung Stufe 4 Ansteuerzeit,10 min,36
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,32.00 °C,36
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,30.00 °C,36
IDE06089-ENG149268-Seat heater level current consumption allocation-Sitzheizung Stufe 6 Ansteuerzeit,15 min,36
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,40.00 °C,36
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,38.00 °C,36
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,36
IDE06089-ENG155904-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase LO,Sollspannungsanforderung 13.5 ,36
IDE06096-ENG149157-Interior lights-Innenlicht_bei_offenem_Heckdeckel_einschalten,active ,8
IDE06096-ENG98648-Interior lights-Interior lighting,Keine_Spannungsanforderung ,8
IDE08786-MAS10528-Assistance light functions-Rain light sensor,Rain light sensor ,9
IDE08786-MAS10545-Assistance light functions-Humidity sensor,not installed ,9
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,not active ,9
IDE08786-ENG149124-Assistance light functions-AFL_Zeitverzoegerung,0 ms,9
IDE08786-ENG149123-Assistance light functions-Assistenzfahrlicht_bei_Regen,active ,9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,not installed ,9
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,82 °,7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,85 °,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,0_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,83 °,7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,86 °,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,0_Ohm ,7
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs,Time ,6
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit,30 min,6
IDE11421-ENG179280-Leaving concept-VLK_Deaktivierung_der_Diagnose,not active ,6
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000 ,3
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000100 ,3
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000110 ,3
IDE11944-MAS10510-Keyless access and start authorization-Kessy,installed ,5
IDE11944-ENG174170-Keyless access and start authorization-central_locking_system_selective_sigle_door_kessy_NAR,not active ,5
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,active ,5
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,active ,5
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,5
IDE11944-ENG149273-Keyless access and start authorization-Kessy_Komfort_oeffnen,not active ,5
IDE11944-ENG149274-Keyless access and start authorization-Kessy_Komfort_schliessen,active ,5
IDE11944-ENG149275-Keyless access and start authorization-Oeffnung_Heckdeckel_bei_Wiederentriegelung,not active ,5
IDE11944-ENG149000-Keyless access and start authorization-Steering_wheel_locking_system,installed ,5
MAS01490-IDE08581-Energy management-Recuperation,active ,5
MAS01490-MAS12921-Energy management-Predictive energy management,not active ,5
MAS01490-ENG149047-Energy management-Eingriff_durch_Energiemanagement,active ,5
MAS01490-ENG98636-Energy management-Hybrid,No ,5
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain,active ,24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,NOT-DEFINED ,24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4300 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
MAS16372-Security version number,1 ,2
ENG153709-ENG155626-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG_DTC,First_dtc ,9
ENG148492-MAS01577-Anti-theft protection-Parking heater,not installed ,5
ENG148492-ENG149232-Anti-theft protection-Akustischer_Alarm_Signalhorn,active ,5
ENG148492-ENG115864-Anti-theft protection-Alarmsignal,frequency_modulated ,5
ENG148492-ENG148991-Anti-theft protection-anti_theft_alarm_system,active ,5
ENG148492-ENG148992-Anti-theft protection-anti_theft_alarm_with_simple_horn,not installed ,5
ENG148492-ENG148993-Anti-theft protection-anti_theft_alarm_without_Thatcham,No ,5
ENG148492-ENG148990-Anti-theft protection-deactivation_button_anti_theft_alarm_sensor,not installed ,5
ENG148492-ENG154590-Anti-theft protection-Deaktivierung_DWA_ueber_MMI,not active ,5
ENG148492-ENG123016-Anti-theft protection-Diebstahlschutz_mit_Anhaenger,not active ,5
ENG148492-ENG149229-Anti-theft protection-DWA_Alarmverzoegerung,immidiat_driver_door_contact_thatcham ,5
ENG148492-ENG149230-Anti-theft protection-DWA_Camper_Modus,not active ,5
ENG148492-ENG148994-Anti-theft protection-interior_monitoring_sensor,No ,5
ENG148492-ENG149231-Anti-theft protection-Sirenen_Alarmzahl,10_Alarme ,5
ENG148492-ENG142008-Anti-theft protection-tilt_sensor,No ,5
ENG148492-ENG149228-Anti-theft protection-Verzoegerung_Panikalarm,keine_verzoegerung ,5
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,5
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken,active ,5
ENG141649-ENG130187-Außenlicht_Blinker-Blinkkontrolleuchte_fuer_Anhaenger,separte ,5
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing,not active ,5
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,5
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,5
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay,0 ms,5
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken,not active ,5
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken,active ,5
ENG141649-ENG115854-Außenlicht_Blinker-Komfortblinken_Blinkzyklen,3 ,5
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken,not active ,5
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2,not active ,5
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,5
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,5
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,5
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,not active ,5
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,5
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,5
ENG141649-ENG286352-Außenlicht_Blinker-Telematikblinken_OCU_Blinken,not active ,5
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,5
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,5
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,5
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,5
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,5
ENG141647-MAS10529-Außenlicht_Front-Low beam: bulb type,H7 ,9
ENG141647-ENG149099-Außenlicht_Front-Allwetterlicht_Ausschaltgrenze,350 km/h,9
ENG141647-ENG149098-Außenlicht_Front-Allwetterlicht_Einschaltgrenze,350 km/h,9
ENG141647-ENG149106-Außenlicht_Front-Fahrlicht_bei_Tag,Daytime running lamps ,9
ENG141647-ENG149097-Außenlicht_Front-Lichthupe_bei_Zuendung_aus_moeglich,active ,9
ENG141647-ENG126567-Außenlicht_Front-max_scheinwerfer_2limitieren,in_Betrieb_lassen ,9
ENG141647-ENG149100-Außenlicht_Front-Scheinwerferferreinigungsansteuerung_und_Abblendlichtanzeige_bei_Dauerfahrlicht,not active ,9
ENG141647-ENG149103-Außenlicht_Front-Standlicht_aktiviert_zusaetzlich_Tagfahrlicht,active ,9
ENG141647-ENG149101-Außenlicht_Front-Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich,not active ,9
ENG141647-ENG149104-Außenlicht_Front-Tagfahrlicht_Dauerfahrlicht_bei_Handbremse_abschalten,not active ,9
ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO,not active ,9
ENG141647-ENG149105-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht_aktiviert_zusaetzlich_Standlicht,not active ,9
ENG141647-ENG149102-Außenlicht_Front-Werkseinstellung_fuer_Tagfahrlicht_Freischaltung_BAP_/_Bedienfolge,active ,9
ENG141648-MAS10533-Aussenlicht_Heck-Brake light is turn signal,No ,5
ENG141648-ENG179109-Aussenlicht_Heck-Bremslicht_mit_Schlusslichtfunktion,active ,5
ENG141648-ENG149110-Aussenlicht_Heck-Nebelschlusslicht_Warngeschwindigkeit,255 km/h,5
ENG141648-ENG115847-Aussenlicht_Heck-Notbremsanzeige_NBA,active ,5
ENG141648-ENG155652-Aussenlicht_Heck-Schlusslicht_mit_Brems_und_Blinklichtfunktion,not active ,5
ENG141648-ENG149109-Aussenlicht_Heck-Schlusslicht_mit_Bremslichtfunktion,not active ,5
ENG141656-MAS10538-Außenlicht_uebergreifend-Light rotary sw. connection,Discrete signal current ,16
ENG141656-MAS10541-Außenlicht_uebergreifend-Light rotary switch with fog light,Yes ,16
ENG141656-MAS10542-Außenlicht_uebergreifend-Light rotary switch with fog tail light,No ,16
ENG141656-MAS10543-Außenlicht_uebergreifend-Light rotary sw. with AFL,Yes ,16
ENG141656-MAS10544-Außenlicht_uebergreifend-Light rotary switch with park. light pos.,Yes ,16
ENG141656-ENG248495-Außenlicht_uebergreifend-ABL_off_ECE48_Rev6,No ,16
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,Energy management ,16
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,Energy management ,16
ENG141656-ENG126566-Außenlicht_uebergreifend-beidseitiges_dauerparklicht,active ,16
ENG141656-ENG281103-Außenlicht_uebergreifend-CHo_Nachlauf,0 ms,16
ENG141656-ENG149092-Außenlicht_uebergreifend-Coming_home_Leuchten,Low beam ,16
ENG141656-ENG149089-Außenlicht_uebergreifend-Coming_Home_Verbaustatus,automatic ,16
ENG141656-ENG149093-Außenlicht_uebergreifend-Coming-home_Einschaltereignis,Driver_door ,16
ENG141656-ENG248654-Außenlicht_uebergreifend-ECE48_Rev6_aktiv,not active ,16
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,16
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,in 0 and SL position ,16
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,16
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Keine_Spannungsanforderung ,16
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Keine_Spannungsanforderung ,16
ENG141656-ENG149096-Außenlicht_uebergreifend-Helligkeitsschwelle_Forward-Messung,100 ,16
ENG141656-ENG149094-Außenlicht_uebergreifend-Helligkeitsschwelle_Infrarot-Messung,72 ,16
ENG141656-ENG155156-Außenlicht_uebergreifend-keine_LCM_blinker,false ,16
ENG141656-ENG149086-Außenlicht_uebergreifend-Kontrollleuchte_fuer_Begrenzungslicht,integriert_in_Suchbeleuchtung ,16
ENG141656-ENG149095-Außenlicht_uebergreifend-Leaving-Home_Verbausstatus,Enabled ,16
ENG141656-ENG126569-Außenlicht_uebergreifend-lho_aktiviert,active ,16
ENG141656-ENG126570-Außenlicht_uebergreifend-lho_zeit,10 seconds ,16
ENG141656-ENG149005-Außenlicht_uebergreifend-Lichtdrehschalter_mit_Nebellicht_bei_Assistenzfahrlicht,Yes ,16
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten,klemmenabhaengig ,16
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,16
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Keine_Spannungsanforderung ,16
ENG141656-ENG149088-Außenlicht_uebergreifend-Menueeinstellung_CHO_LHO,Menuesteuerung_Zeit_aktivieren ,16
ENG141656-ENG149091-Außenlicht_uebergreifend-Menueeinstellung_Cominghome,10 seconds ,16
ENG141656-ENG149090-Außenlicht_uebergreifend-Menuesteuerung_Coming_Home_Werkseinstellung,active ,16
ENG141656-ENG149087-Außenlicht_uebergreifend-Parklicht_ueber_LSS_aktiviert,One-sided ,16
ENG141656-ENG126565-Außenlicht_uebergreifend-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,16
ENG141656-ENG137035-Außenlicht_uebergreifend-Standlicht-Verfuegbarkeit,24 s,16
ENG141656-ENG248823-Außenlicht_uebergreifend-TFL_off_ECE48_Rev6,No ,16
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Keine_Spannungsanforderung ,16
ENG148494-MAS10534-Background lighting-Input medium: search illumination,HMI ,21
ENG148494-ENG142240-Background lighting-Daempfung Abdimmen KL 58xd PWM,0.00 s,21
ENG148494-ENG154582-Background lighting-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
ENG148494-ENG154583-Background lighting-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
ENG148494-ENG154584-Background lighting-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
ENG148494-ENG154585-Background lighting-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
ENG148494-ENG179120-Background lighting-Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
ENG148494-ENG142242-Background lighting-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG148494-ENG142241-Background lighting-Helligkeit_RLS_Daempfung_Aufdimmen,0.0 s,21
ENG148494-ENG149159-Background lighting-KL58_Einschalten_mit_Rampe,not active ,21
ENG148494-ENG149160-Background lighting-KL58_Verriegelungsausschalten,active ,21
ENG148494-ENG149161-Background lighting-Lichtsensor_wirkt_auf_Suchbeleuchtung,active ,21
ENG148494-ENG149162-Background lighting-Suchbeleuchtung_Festwert,60 %,21
ENG148494-ENG142234-Background lighting-Umgebungs_helligkeit_auswahl,Fotosensor_Kombi ,21
ENG148494-ENG130188-Background lighting-Warnblinktastersuchbeleuchtung_Aktivierung,always_active ,21
ENG148494-ENG130190-Background lighting-Warnblinktastersuchbeleuchtung_Faktor,0.072 ,21
ENG148494-ENG130189-Background lighting-Warnblinktastersuchbeleuchtung_Grundwert,1.0 %,21
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,No Response From Subnet Component,21
ENG248426-ENG252093-Elektronische_Rückwandklappe-eRWK_Abbruchblinken_Heck,not active ,9
ENG248426-ENG248659-Elektronische_Rückwandklappe-eRWK_Abstand_Umfeld_frei,120 cm,9
ENG248426-ENG248660-Elektronische_Rückwandklappe-eRWK_Abstand_Umfeld_Nahbereich,20 cm,9
ENG248426-ENG248661-Elektronische_Rückwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite,not active ,9
ENG248426-ENG248662-Elektronische_Rückwandklappe-eRWK_Heck_sperren_bei_Hindernis,not active ,9
ENG248426-ENG248663-Elektronische_Rückwandklappe-eRWK_Oeffnungsblinken_Heck,not active ,9
ENG248426-ENG248664-Elektronische_Rückwandklappe-eRWK_ohne_FFB_HDF,not active ,9
ENG248426-ENG252079-Elektronische_Rückwandklappe-eRWK_Pruefung_Umfelderkennung,1.6 s,9
ENG248426-ENG252068-Elektronische_Rückwandklappe-eRWK_Start_Umfelderkennung,2.0 s,9
ENG148609-ENG148997-Fahrerinformation-Cockpit_button_1,installed ,5
ENG148609-ENG148998-Fahrerinformation-Cockpit_button_2,not installed ,5
ENG148609-ENG148999-Fahrerinformation-Cockpit_button_3,not installed ,5
ENG148609-ENG149003-Fahrerinformation-Cockpit_button_4,not installed ,5
ENG141650-MAS10514-Fernlicht_assistent-Expanded high beam control,Halogen ,6
ENG141650-ENG149120-Fernlicht_assistent-Fernlichtassistent_Reset,not active ,6
ENG141650-ENG149122-Fernlicht_assistent-Fernlichtassistent_Zeitverzoegerungswert,800 ms,6
ENG141650-ENG149119-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent,not installed ,6
ENG141650-ENG149121-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent_Werkseinstellung,not installed ,6
ENG248411-ENG248631-Front doors-cockpittaster2_funktion,not active ,1
ENG248411-ENG252063-Front doors-Deaktivierung_LS_mit_ext_Ver_Entriegelung,not active ,1
ENG248411-ENG248723-Front doors-Laderaumschließung Taster togglen,not active ,1
ENG248411-ENG248768-Front doors-NFZ_Schliessung,not active ,1
ENG248411-ENG248784-Front doors-pa_Schlosstyp_vorne,Einmotorenschloss ,1
ENG248411-ENG133390-Front doors-Wiederverriegelung_Laderaum,not installed ,1
ENG248444-ENG248688-Global-Freischaltung_der_Kisi_Auswurffunktion,No ,1
ENG248444-ENG248689-Global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,No ,1
ENG248444-ENG248691-Global-Funktion_SAFE,No ,1
ENG248444-ENG248774-Global-pa_eKiSi,No ,1
ENG248444-ENG248776-Global-pa_FFb_Sbt_Tausch_Seite,No ,1
ENG248444-ENG248809-Global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt_aktiv,No ,1
ENG248444-ENG248810-Global-Schiebetuertaste_Armaturentafel_bei_extern_verriegelt_aktiv,No ,1
ENG248445-ENG248698-Heckklappe: Türen-HD_Innentaster_im_Heck,not installed ,1
ENG248445-ENG248782-Heckklappe: Türen-pa_Schlosstyp_Heck,Federsteller ,1
ENG248445-ENG248787-Heckklappe: Türen-pa_Typ_Heck,Klappe ,1
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,not installed ,8
ENG141645-MAS06495-HW_Verbau-Engine hood contact switch,installed ,8
ENG141645-MAS10521-HW_Verbau-Exterior temp. sensor,installed ,8
ENG141645-ENG126574-HW_Verbau-auspraegung_Bremsfluessigkeitsschalter,Open ,8
ENG141645-ENG115848-HW_Verbau-Signalhorn_ohne_KL15,active ,8
ENG141645-ENG149002-HW_Verbau-Signalhorn_ueber_LIN,Signalhorn hartverdrahtet (kein MFL) ,8
ENG141645-ENG142011-HW_Verbau-trunk_lid_conrol_unit,not installed ,8
ENG148603-ENG115658-Innen_beleuchtung_KL58_xd_max-x0,0 lx,10
ENG148603-ENG101574-Innen_beleuchtung_KL58_xd_max-X1,8 lx,10
ENG148603-ENG99557-Innen_beleuchtung_KL58_xd_max-X2,200 lx,10
ENG148603-ENG102140-Innen_beleuchtung_KL58_xd_max-X3,300 lx,10
ENG148603-ENG102936-Innen_beleuchtung_KL58_xd_max-X4,500 lx,10
ENG148603-ENG115659-Innen_beleuchtung_KL58_xd_max-y0,16.0 ,10
ENG148603-ENG99777-Innen_beleuchtung_KL58_xd_max-Y1,16.0 ,10
ENG148603-ENG100480-Innen_beleuchtung_KL58_xd_max-Y2,100.0 ,10
ENG148603-ENG100773-Innen_beleuchtung_KL58_xd_max-Y3,100.0 ,10
ENG148603-ENG100631-Innen_beleuchtung_KL58_xd_max-Y4,100.0 ,10
ENG148602-ENG115658-Innen_beleuchtung_KL58_xd_min-x0,0 lx,10
ENG148602-ENG101574-Innen_beleuchtung_KL58_xd_min-X1,8 lx,10
ENG148602-ENG99557-Innen_beleuchtung_KL58_xd_min-X2,220 lx,10
ENG148602-ENG102140-Innen_beleuchtung_KL58_xd_min-X3,300 lx,10
ENG148602-ENG102936-Innen_beleuchtung_KL58_xd_min-X4,500 lx,10
ENG148602-ENG115659-Innen_beleuchtung_KL58_xd_min-y0,6.0 ,10
ENG148602-ENG99777-Innen_beleuchtung_KL58_xd_min-Y1,6.0 ,10
ENG148602-ENG100480-Innen_beleuchtung_KL58_xd_min-Y2,100.0 ,10
ENG148602-ENG100773-Innen_beleuchtung_KL58_xd_min-Y3,100.0 ,10
ENG148602-ENG100631-Innen_beleuchtung_KL58_xd_min-Y4,100.0 ,10
ENG148607-ENG115658-Innen_beleuchtung_KL58_xd_PWM-x0,0 ,12
ENG148607-ENG101574-Innen_beleuchtung_KL58_xd_PWM-X1,10 ,12
ENG148607-ENG99557-Innen_beleuchtung_KL58_xd_PWM-X2,50 ,12
ENG148607-ENG102140-Innen_beleuchtung_KL58_xd_PWM-X3,100 ,12
ENG148607-ENG102936-Innen_beleuchtung_KL58_xd_PWM-X4,220 ,12
ENG148607-ENG103548-Innen_beleuchtung_KL58_xd_PWM-X5,253 ,12
ENG148607-ENG115659-Innen_beleuchtung_KL58_xd_PWM-y0,2.0 %,12
ENG148607-ENG99777-Innen_beleuchtung_KL58_xd_PWM-Y1,2.0 %,12
ENG148607-ENG100480-Innen_beleuchtung_KL58_xd_PWM-Y2,6.0 %,12
ENG148607-ENG100773-Innen_beleuchtung_KL58_xd_PWM-Y3,10.0 %,12
ENG148607-ENG100631-Innen_beleuchtung_KL58_xd_PWM-Y4,80.0 %,12
ENG148607-ENG102174-Innen_beleuchtung_KL58_xd_PWM-Y5,100.0 %,12
ENG148599-ENG115658-Innen_beleuchtung_KL58_xs_max-x0,0 lx,8
ENG148599-ENG101574-Innen_beleuchtung_KL58_xs_max-X1,8 lx,8
ENG148599-ENG99557-Innen_beleuchtung_KL58_xs_max-X2,50 lx,8
ENG148599-ENG102140-Innen_beleuchtung_KL58_xs_max-X3,500 lx,8
ENG148599-ENG115659-Innen_beleuchtung_KL58_xs_max-y0,100.0 ,8
ENG148599-ENG99777-Innen_beleuchtung_KL58_xs_max-Y1,100.0 ,8
ENG148599-ENG100480-Innen_beleuchtung_KL58_xs_max-Y2,100.0 ,8
ENG148599-ENG100773-Innen_beleuchtung_KL58_xs_max-Y3,100.0 ,8
ENG148605-ENG115658-Innen_beleuchtung_KL58_xs_PWM-x0,0.0 %,6
ENG148605-ENG101574-Innen_beleuchtung_KL58_xs_PWM-X1,50.0 %,6
ENG148605-ENG99557-Innen_beleuchtung_KL58_xs_PWM-X2,100.0 %,6
ENG148605-ENG115659-Innen_beleuchtung_KL58_xs_PWM-y0,0.0 %,6
ENG148605-ENG99777-Innen_beleuchtung_KL58_xs_PWM-Y1,50.0 %,6
ENG148605-ENG100480-Innen_beleuchtung_KL58_xs_PWM-Y2,100.0 %,6
ENG148601-ENG115658-Innen_beleuchtung_KL58_xt_max-x0,0 lx,8
ENG148601-ENG101574-Innen_beleuchtung_KL58_xt_max-X1,8 lx,8
ENG148601-ENG99557-Innen_beleuchtung_KL58_xt_max-X2,50 lx,8
ENG148601-ENG102140-Innen_beleuchtung_KL58_xt_max-X3,500 lx,8
ENG148601-ENG115659-Innen_beleuchtung_KL58_xt_max-y0,100.0 ,8
ENG148601-ENG99777-Innen_beleuchtung_KL58_xt_max-Y1,100.0 ,8
ENG148601-ENG100480-Innen_beleuchtung_KL58_xt_max-Y2,100.0 ,8
ENG148601-ENG100773-Innen_beleuchtung_KL58_xt_max-Y3,100.0 ,8
ENG148600-ENG115658-Innen_beleuchtung_KL58_xt_min-x0,0 lx,8
ENG148600-ENG101574-Innen_beleuchtung_KL58_xt_min-X1,8 lx,8
ENG148600-ENG99557-Innen_beleuchtung_KL58_xt_min-X2,50 lx,8
ENG148600-ENG102140-Innen_beleuchtung_KL58_xt_min-X3,500 lx,8
ENG148600-ENG115659-Innen_beleuchtung_KL58_xt_min-y0,6.0 ,8
ENG148600-ENG99777-Innen_beleuchtung_KL58_xt_min-Y1,6.0 ,8
ENG148600-ENG100480-Innen_beleuchtung_KL58_xt_min-Y2,100.0 ,8
ENG148600-ENG100773-Innen_beleuchtung_KL58_xt_min-Y3,100.0 ,8
ENG148606-ENG115658-Innen_beleuchtung_KL58_xt_PWM-x0,0.0 %,6
ENG148606-ENG101574-Innen_beleuchtung_KL58_xt_PWM-X1,50.0 %,6
ENG148606-ENG99557-Innen_beleuchtung_KL58_xt_PWM-X2,100.0 %,6
ENG148606-ENG115659-Innen_beleuchtung_KL58_xt_PWM-y0,0.0 %,6
ENG148606-ENG99777-Innen_beleuchtung_KL58_xt_PWM-Y1,50.0 %,6
ENG148606-ENG100480-Innen_beleuchtung_KL58_xt_PWM-Y2,100.0 %,6
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,510 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG148597-ENG115658-Innenbeleuchtung_Abdimmen-x0,0 ms,22
ENG148597-ENG101574-Innenbeleuchtung_Abdimmen-X1,100 ms,22
ENG148597-ENG115664-Innenbeleuchtung_Abdimmen-x10,1000 ms,22
ENG148597-ENG99557-Innenbeleuchtung_Abdimmen-X2,200 ms,22
ENG148597-ENG102140-Innenbeleuchtung_Abdimmen-X3,300 ms,22
ENG148597-ENG102936-Innenbeleuchtung_Abdimmen-X4,400 ms,22
ENG148597-ENG103548-Innenbeleuchtung_Abdimmen-X5,500 ms,22
ENG148597-ENG113992-Innenbeleuchtung_Abdimmen-X6,600 ms,22
ENG148597-ENG115661-Innenbeleuchtung_Abdimmen-x7,700 ms,22
ENG148597-ENG115662-Innenbeleuchtung_Abdimmen-x8,800 ms,22
ENG148597-ENG115663-Innenbeleuchtung_Abdimmen-x9,900 ms,22
ENG148597-ENG115659-Innenbeleuchtung_Abdimmen-y0,100.0 %,22
ENG148597-ENG99777-Innenbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG148597-ENG115668-Innenbeleuchtung_Abdimmen-y10,0.0 %,22
ENG148597-ENG100480-Innenbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG148597-ENG100773-Innenbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG148597-ENG100631-Innenbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG148597-ENG102174-Innenbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG148597-ENG113993-Innenbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG148597-ENG115665-Innenbeleuchtung_Abdimmen-y7,5.0 %,22
ENG148597-ENG115666-Innenbeleuchtung_Abdimmen-y8,3.0 %,22
ENG148597-ENG115667-Innenbeleuchtung_Abdimmen-y9,1.0 %,22
ENG148598-ENG115658-Innenbeleuchtung_Fotosensor-x0,0 ,22
ENG148598-ENG101574-Innenbeleuchtung_Fotosensor-X1,50 ,22
ENG148598-ENG99557-Innenbeleuchtung_Fotosensor-X2,100 ,22
ENG148598-ENG102140-Innenbeleuchtung_Fotosensor-X3,200 ,22
ENG148598-ENG102936-Innenbeleuchtung_Fotosensor-X4,253 ,22
ENG148598-ENG115659-Innenbeleuchtung_Fotosensor-y0,0 lx,22
ENG148598-ENG99777-Innenbeleuchtung_Fotosensor-Y1,50 lx,22
ENG148598-ENG100480-Innenbeleuchtung_Fotosensor-Y2,100 lx,22
ENG148598-ENG100773-Innenbeleuchtung_Fotosensor-Y3,200 ,22
ENG148598-ENG100631-Innenbeleuchtung_Fotosensor-Y4,500 ,22
ENG148596-ENG115658-Innenbeleuchtung_Hochdimmen-x0,0 ms,22
ENG148596-ENG101574-Innenbeleuchtung_Hochdimmen-X1,100 ms,22
ENG148596-ENG115664-Innenbeleuchtung_Hochdimmen-x10,1000 ms,22
ENG148596-ENG99557-Innenbeleuchtung_Hochdimmen-X2,200 ms,22
ENG148596-ENG102140-Innenbeleuchtung_Hochdimmen-X3,300 ms,22
ENG148596-ENG102936-Innenbeleuchtung_Hochdimmen-X4,400 ms,22
ENG148596-ENG103548-Innenbeleuchtung_Hochdimmen-X5,500 ms,22
ENG148596-ENG113992-Innenbeleuchtung_Hochdimmen-X6,600 ms,22
ENG148596-ENG115661-Innenbeleuchtung_Hochdimmen-x7,700 ms,22
ENG148596-ENG115662-Innenbeleuchtung_Hochdimmen-x8,800 ms,22
ENG148596-ENG115663-Innenbeleuchtung_Hochdimmen-x9,900 ms,22
ENG148596-ENG115659-Innenbeleuchtung_Hochdimmen-y0,0.0 %,22
ENG148596-ENG99777-Innenbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG148596-ENG115668-Innenbeleuchtung_Hochdimmen-y10,100.0 %,22
ENG148596-ENG100480-Innenbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG148596-ENG100773-Innenbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG148596-ENG100631-Innenbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG148596-ENG102174-Innenbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG148596-ENG113993-Innenbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG148596-ENG115665-Innenbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG148596-ENG115666-Innenbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG148596-ENG115667-Innenbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG148604-ENG115658-Innenbeleuchtung_KL58xd_log_Bus-x0,0.0 %,12
ENG148604-ENG101574-Innenbeleuchtung_KL58xd_log_Bus-X1,6.0 %,12
ENG148604-ENG99557-Innenbeleuchtung_KL58xd_log_Bus-X2,16.0 %,12
ENG148604-ENG102140-Innenbeleuchtung_KL58xd_log_Bus-X3,30.0 %,12
ENG148604-ENG102936-Innenbeleuchtung_KL58xd_log_Bus-X4,60.0 %,12
ENG148604-ENG103548-Innenbeleuchtung_KL58xd_log_Bus-X5,100.0 %,12
ENG148604-ENG115659-Innenbeleuchtung_KL58xd_log_Bus-y0,10 ,12
ENG148604-ENG99777-Innenbeleuchtung_KL58xd_log_Bus-Y1,10 ,12
ENG148604-ENG100480-Innenbeleuchtung_KL58xd_log_Bus-Y2,100 ,12
ENG148604-ENG100773-Innenbeleuchtung_KL58xd_log_Bus-Y3,150 ,12
ENG148604-ENG100631-Innenbeleuchtung_KL58xd_log_Bus-Y4,220 ,12
ENG148604-ENG102174-Innenbeleuchtung_KL58xd_log_Bus-Y5,253 ,12
ENG148595-ENG149169-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x0,0 ms,10
ENG148595-ENG149170-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x1,2000 ms,10
ENG148595-ENG149171-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x2,3000 ms,10
ENG148595-ENG149172-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x3,4000 ms,10
ENG148595-ENG149173-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x4,5100 ms,10
ENG148595-ENG149174-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y0,1.0 %,10
ENG148595-ENG149175-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y1,5.0 ,10
ENG148595-ENG149176-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y2,15.0 ,10
ENG148595-ENG149177-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y3,40.0 ,10
ENG148595-ENG149178-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y4,100.0 ,10
ENG248447-ENG248714-Inszenierung CHoLHo-Inszenierung CHo/LHo Aktivieren,not active ,36
ENG248447-ENG115658-Inszenierung CHoLHo-x0,0 ms,36
ENG248447-ENG101574-Inszenierung CHoLHo-X1,200 ms,36
ENG248447-ENG115664-Inszenierung CHoLHo-x10,2000 ms,36
ENG248447-ENG248838-Inszenierung CHoLHo-x11,200 ms,36
ENG248447-ENG248839-Inszenierung CHoLHo-x12,400 ms,36
ENG248447-ENG248840-Inszenierung CHoLHo-x13,600 ms,36
ENG248447-ENG248841-Inszenierung CHoLHo-x14,800 ms,36
ENG248447-ENG248842-Inszenierung CHoLHo-x15,1000 ms,36
ENG248447-ENG99557-Inszenierung CHoLHo-X2,400 ms,36
ENG248447-ENG102140-Inszenierung CHoLHo-X3,600 ms,36
ENG248447-ENG102936-Inszenierung CHoLHo-X4,800 ms,36
ENG248447-ENG103548-Inszenierung CHoLHo-X5,1000 ms,36
ENG248447-ENG113992-Inszenierung CHoLHo-X6,1200 ms,36
ENG248447-ENG115661-Inszenierung CHoLHo-x7,1400 ms,36
ENG248447-ENG115662-Inszenierung CHoLHo-x8,1600 ms,36
ENG248447-ENG115663-Inszenierung CHoLHo-x9,1800 ms,36
ENG248447-ENG115659-Inszenierung CHoLHo-y0,0.0 %,36
ENG248447-ENG99777-Inszenierung CHoLHo-Y1,3.0 %,36
ENG248447-ENG115668-Inszenierung CHoLHo-y10,100.0 %,36
ENG248447-ENG136987-Inszenierung CHoLHo-Y11,3.0 %,36
ENG248447-ENG136988-Inszenierung CHoLHo-Y12,7.0 %,36
ENG248447-ENG136989-Inszenierung CHoLHo-Y13,12.0 %,36
ENG248447-ENG136990-Inszenierung CHoLHo-Y14,17.0 %,36
ENG248447-ENG136991-Inszenierung CHoLHo-Y15,24.0 %,36
ENG248447-ENG100480-Inszenierung CHoLHo-Y2,7.0 %,36
ENG248447-ENG100773-Inszenierung CHoLHo-Y3,12.0 %,36
ENG248447-ENG100631-Inszenierung CHoLHo-Y4,17.0 %,36
ENG248447-ENG102174-Inszenierung CHoLHo-Y5,24.0 %,36
ENG248447-ENG113993-Inszenierung CHoLHo-Y6,33.0 %,36
ENG248447-ENG115665-Inszenierung CHoLHo-y7,44.0 %,36
ENG248447-ENG115666-Inszenierung CHoLHo-y8,59.0 %,36
ENG248447-ENG115667-Inszenierung CHoLHo-y9,78.0 %,36
ENG148608-ENG148900-Lenkradhebel-Art des Lenkstockschalters,LSS ohne Elektronik ,5
ENG148608-ENG149233-Lenkradhebel-Aussenspiegelheizung_aktivierungssignal,Hardwaresignal ,5
ENG148608-ENG155105-Lenkradhebel-FAS-Taster,not installed ,5
ENG148608-ENG149006-Lenkradhebel-Fernlichtstellung,FL tastend ,5
ENG148608-ENG148901-Lenkradhebel-GRA-Bedienung,LSS-Bedienung ,5
ENG148608-ENG149001-Lenkradhebel-heated_mirror,not installed ,5
ENG148608-ENG149004-Lenkradhebel-speed_limiter,not installed ,5
ENG148608-ENG179276-Lenkradhebel-Umschaltung GRA zu SL,Direct ,5
ENG148608-ENG154803-Lenkradhebel-Verbauort_Lenkstockschalter,CAN ,5
ENG148608-ENG149234-Lenkradhebel-Versorgung_Lenkstockschalters_KL30,installed ,5
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,20 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,52 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken_links_Hellphase ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not_activ ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not_activ ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not_activ ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not_activ ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not_activ ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not_activ ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not_activ ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,Blinkleuchten ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,0 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,0 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblink_taster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not_activ ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not_activ ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not_activ ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not_activ ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not_activ ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not_activ ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not_activ ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,100 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,34 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,56 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,Nebel_licht_links ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,not_activ ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not_activ ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not_activ ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not_activ ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not_activ ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not_activ ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not_activ ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,allgemeineScheinwerfer ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,100 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,35 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,66 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,Nebellichtrechts ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,not_activ ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not_activ ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not_activ ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not_activ ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not_activ ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not_activ ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not_activ ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,allgemeineScheinwerfer ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,0 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,0 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,Safe_LED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not_activ ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not_activ ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not_activ ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not_activ ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not_activ ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not_activ ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not_activ ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,23 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,57 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken_links_Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not_activ ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not_activ ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not_activ ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not_activ ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not_activ ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not_activ ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not_activ ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED_Blinkleuchten ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,25 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,67 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken_rechts_Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not_activ ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not_activ ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not_activ ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not_activ ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not_activ ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not_activ ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not_activ ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED_Blinkleuchten ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,22 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,8 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken_links_Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not_activ ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not_activ ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not_activ ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not_activ ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not_activ ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not_activ ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not_activ ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100 ,16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0 ,16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize ,16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize ,16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize ,16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0 ,16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0 ,16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,24 ,16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,24 ,16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always ,16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken_rechts_Hellphase ,16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not_activ ,16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not_activ ,16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not_activ ,16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not_activ ,16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not_activ ,16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not_activ ,16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not_activ ,16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,21 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,62 ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken_rechts_Hellphase ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not_activ ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not_activ ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not_activ ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not_activ ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not_activ ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not_activ ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not_activ ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,Blinkleuchten ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,7 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,100 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,57 ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,9 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Position lamps ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,Parklichtlinks ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,Brake lamp ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not_activ ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not_activ ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not_activ ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not_activ ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not_activ ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,NOT-DEFINED ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,7 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,100 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,58 ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,25 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Position lamps ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,Parklichtrechts ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,Brake lamp ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not_activ ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not_activ ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not_activ ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not_activ ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not_activ ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,NOT-DEFINED ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,44 ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,41 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake lamp ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not_activ ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not_activ ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not_activ ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not_activ ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not_activ ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not_activ ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not_activ ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LED dritte Bremsleuchte ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,127 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,41 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,10 ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Position lamps ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parklichtlinks ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not_activ ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not_activ ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not_activ ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not_activ ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not_activ ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not_activ ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeine_LED_12W ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,127 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,42 ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,26 ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Position lamps ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parklichtrechts ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not_activ ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not_activ ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not_activ ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not_activ ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not_activ ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not_activ ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeine_LED_12W ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,48 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,40 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Position lamps ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not_activ ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not_activ ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not_activ ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not_activ ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not_activ ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not_activ ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not_activ ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,allgemeine_LED_6W ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,0 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,0 ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0 ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,not_activ ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not_activ ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not_activ ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not_activ ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not_activ ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not_activ ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not_activ ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not_activ ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,not_active ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,8 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,0 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Dimmung_Klemme_58_xs ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not_activ ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not_activ ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not_activ ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not_activ ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not_activ ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not_activ ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not_activ ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,52 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,43 ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,only_if_closed ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not_activ ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not_activ ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not_activ ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not_activ ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not_activ ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not_activ ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not_activ ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,2*21W_Nebelschluss_Rueckfahrleuchte_mit_Teilausfallerkennung ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,1 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,0 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme_30_G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not_activ ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not_activ ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not_activ ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not_activ ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not_activ ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not_activ ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not_activ ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeine_Gluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,28 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,minimize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,28 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,74 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,72 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Daytime running lamps ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,not_activ ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,Position lamps ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,Parklichtlinks ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,Blinkenlinksaktiv ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not_activ ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not_activ ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not_activ ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,LEDTagfahrlichtmodulSignal ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,7 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,0 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior lighting ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not_activ ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not_activ ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not_activ ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not_activ ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not_activ ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not_activ ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not_activ ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeine_Gluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,0 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,0 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not_activ ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not_activ ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not_activ ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not_activ ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not_activ ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not_activ ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not_activ ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not_activ ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not_active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,100 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,4 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,0 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,Ambientelicht_1 ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not_activ ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not_activ ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not_activ ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not_activ ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not_activ ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not_activ ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not_activ ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,0 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,0 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not_activ ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not_activ ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not_activ ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not_activ ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not_activ ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not_activ ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not_activ ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not_activ ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not_active ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,0 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,0 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not_activ ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not_activ ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not_activ ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not_activ ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not_activ ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not_activ ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not_activ ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not_activ ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not_active ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,28 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,minimize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,28 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,76 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,76 ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Daytime running lamps ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,not_activ ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,Position lamps ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,Parklichtrechts ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,Blinkenrechtsaktiv ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not_activ ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not_activ ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not_activ ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,LEDTagfahrlichtmodulSignal ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,127 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,127 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,75 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,68 ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lamps ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not_activ ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,Position lamps ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,Parklichtrechts ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not_activ ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not_activ ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not_activ ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not_activ ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,LEDTagfahrlichtmodulVersorgung ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,127 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,127 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,73 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,58 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lamps ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not_activ ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,Position lamps ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,Parklichtlinks ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not_activ ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not_activ ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not_activ ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not_activ ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,LEDTagfahrlichtmodulVersorgung ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,127 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,127 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,26 ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,54 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlichtlinks ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,coming_home_leaving_home ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,Fernlichtlinks ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,Headlamp flasher ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not_activ ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not_activ ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not_activ ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not_activ ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,LED_Abblendlicht ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,127 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,127 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,27 ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,64 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlichtrechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,coming_home_leaving_home ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,Fernlichtrechts ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,Headlamp flasher ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not_activ ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not_activ ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not_activ ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not_activ ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,LED_Abblendlicht ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,127 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,28 ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,55 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Fernlichtlinks ,16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not_activ ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not_activ ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not_activ ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not_activ ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not_activ ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not_activ ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeine_LED_12W ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,127 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,29 ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,65 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Fernlichtrechts ,16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not_activ ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not_activ ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not_activ ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not_activ ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not_activ ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not_activ ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeine_LED_12W ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,0 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,0 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,Lock_Unlock_LED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not_activ ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not_activ ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not_activ ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not_activ ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not_activ ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not_activ ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not_activ ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG148593-Leuchtenkonfiguration (Aussenlicht Heck),0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 33 09 00 39 08 09 07 18 00 64 00 00 00 00 00 00 33 19 00 3A 08 0A 07 18 00 64 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 20 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 2D 28 00 30 08 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1A 2B 00 34 19 00 E4 00 00 00 00 00 00 00 00 00 ,160
ENG148594-Leuchtenkonfiguration (Sonstiges),24 00 00 00 3E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 3F 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 40 00 64 00 00 00 00 00 00 00 00 00 21 39 00 17 02 00 64 00 00 00 00 00 00 00 00 00 21 43 00 19 04 00 64 00 00 00 00 00 00 00 00 00 24 00 00 08 26 00 64 00 00 00 00 00 00 00 00 00 08 00 00 01 25 00 64 00 00 00 00 00 00 00 00 00 08 00 00 07 29 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 24 00 00 04 2D 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,192
ENG126648-MAS02526-LIN-Mirrormode-Activation,not active ,1
ENG126648-ENG149044-LIN-Mirrormode-LIN4,not active ,1
ENG126648-ENG149045-LIN-Mirrormode-LIN5,not active ,1
ENG148592-ENG115658-LuB_Lichtrouter_Kennlinie_1-x0,0.0 %,12
ENG148592-ENG101574-LuB_Lichtrouter_Kennlinie_1-X1,5.0 %,12
ENG148592-ENG99557-LuB_Lichtrouter_Kennlinie_1-X2,50.0 %,12
ENG148592-ENG102140-LuB_Lichtrouter_Kennlinie_1-X3,75.0 %,12
ENG148592-ENG102936-LuB_Lichtrouter_Kennlinie_1-X4,110.0 %,12
ENG148592-ENG103548-LuB_Lichtrouter_Kennlinie_1-X5,126.5 %,12
ENG148592-ENG115659-LuB_Lichtrouter_Kennlinie_1-y0,0.0 %,12
ENG148592-ENG99777-LuB_Lichtrouter_Kennlinie_1-Y1,6.0 %,12
ENG148592-ENG100480-LuB_Lichtrouter_Kennlinie_1-Y2,16.0 %,12
ENG148592-ENG100773-LuB_Lichtrouter_Kennlinie_1-Y3,30.0 %,12
ENG148592-ENG100631-LuB_Lichtrouter_Kennlinie_1-Y4,60.0 %,12
ENG148592-ENG102174-LuB_Lichtrouter_Kennlinie_1-Y5,100.0 %,12
ENG122979-MAS00075-Networking-ABS Control Module,installed ,8
ENG122979-MAS00798-Networking-Transmission Control Module (TCM),not installed ,8
ENG122979-MAS01374-Networking-Trailer,not installed ,8
ENG122979-MAS03175-Networking-Extended data bus,not installed ,8
ENG122979-MAS09880-Networking-Interval potentiometer,installed ,8
ENG122979-MAS09882-Networking-MFA button on BCM,not installed ,8
ENG122979-MAS10518-Networking-A/C electronics,installed ,8
ENG122979-MAS10570-Networking-Window lift type,MQB_window_regulator ,8
ENG122979-ENG149007-Networking-Door LIN,installed ,8
ENG122979-ENG252084-Networking-KL30_weckfaehig,wakable ,8
ENG122979-ENG149008-Networking-Roof LIN,installed ,8
ENG122979-ENG149009-Networking-Sounder LIN,not installed ,8
ENG122979-ENG149010-Networking-Wiper LIN,not installed ,8
ENG124714-ENG179221-OCU-Remote Lock Unlock Timer s0,15 s,8
ENG124714-ENG179222-OCU-Remote Lock Unlock Timer s2,0 s,8
ENG124714-ENG179223-OCU-Remote Lock Unlock Timer s4,15 s,8
ENG124714-ENG154722-OCU-RHF_Panikalarm,not active ,8
ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1,Conditions not correct or request sequence error,8
ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2,Conditions not correct or request sequence error,8
ENG148615-ENG148862-Patch_code_passenger-Parameter_1,Conditions not correct or request sequence error,8
ENG148615-ENG148865-Patch_code_passenger-Parameter_2,Conditions not correct or request sequence error,8
ENG117308-ENG148862-Patch_Code_Passenger_Side_Rear-Parameter_1,Conditions not correct or request sequence error,8
ENG117308-ENG148865-Patch_Code_Passenger_Side_Rear-Parameter_2,Conditions not correct or request sequence error,8
ENG141646-MAS00481-Querschnitts_funktionen-BAP,active ,5
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Skoda ,5
ENG141646-MAS04194-Querschnitts_funktionen-Driver side,Right ,5
ENG141646-MAS10509-Querschnitts_funktionen-Traffic,Left ,5
ENG141646-MAS10511-Querschnitts_funktionen-Personalization transfer,installed ,5
ENG141646-MAS10527-Querschnitts_funktionen-Tracking System,not active ,5
ENG141646-ENG252090-Querschnitts_funktionen-anhaengerrangierassistent,not active ,5
ENG141646-ENG149084-Querschnitts_funktionen-CAN_Wecken_bei_Softtouchbetaetigung,active ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Keine_Spannungsanforderung ,5
ENG141646-ENG149085-Querschnitts_funktionen-Klemmenfehler_auf_CAN_ausgeben,active ,5
ENG141646-ENG126575-Querschnitts_funktionen-mute_mode_aktiv,not active ,5
ENG141646-ENG148952-Querschnitts_funktionen-P_locked,not installed ,5
ENG141646-ENG125011-Querschnitts_funktionen-pa_Funktion_2aus3,installed ,5
ENG117299-Reversing_Threshold_Driver_Side_Rear,Conditions not correct or request sequence error,1
ENG117298-Reversing_Threshold_Passenger_Side_Front,Conditions not correct or request sequence error,1
ENG117300-Reversing_Threshold_Passenger_Side_Rear,Conditions not correct or request sequence error,1
ENG179054-ENG179160-RLFS_ZF_TRW-p_n_1st_wipe_threshold,100 %,12
ENG179054-ENG179161-RLFS_ZF_TRW-p_n_highspeed_wipe_threshold,100 %,12
ENG179054-ENG179162-RLFS_ZF_TRW-p_n_interval_wipe_threshold,100 %,12
ENG179054-ENG179163-RLFS_ZF_TRW-p_n_LIN_Filter,3 ,12
ENG179054-ENG179164-RLFS_ZF_TRW-p_n_permanent_wipe_threshold,100 %,12
ENG179054-ENG179165-RLFS_ZF_TRW-p_n_RsEmergencyReducePercent,10 %,12
ENG179054-ENG179166-RLFS_ZF_TRW-p_t_ParkPosition_SpeedReset,1300 ms,12
ENG179054-ENG179167-RLFS_ZF_TRW-p_t_ParkPosition_WipeTimeout,1000 ms,12
ENG179054-ENG263513-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Cycle,2.0 s,12
ENG179054-ENG263511-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Delay,4.0 s,12
ENG179054-ENG179170-RLFS_ZF_TRW-p_t_tunnel_wipe_delay,6 s,12
ENG179054-ENG179171-RLFS_ZF_TRW-p_t_tunnel_wipe_window,15 s,12
ENG179054-ENG179172-RLFS_ZF_TRW-pa_lx_tunnel_light_on,1100 ,12
ENG179054-ENG179173-RLFS_ZF_TRW-pa_n_wisch_max_2,2 ,12
ENG179054-ENG179174-RLFS_ZF_TRW-pa_t_tunnel_delay_decrement,30 s,12
ENG179054-ENG179175-RLFS_ZF_TRW-pa_t_tunnel_delay_max,120 s,12
ENG179054-ENG179176-RLFS_ZF_TRW-Pa_t_tunnel_delay_on,1800 ms,12
ENG179054-ENG179177-RLFS_ZF_TRW-pa_t_tunnel_delay_step,5 s,12
ENG179054-ENG179178-RLFS_ZF_TRW-pa_v_RsActivationSpeed,5 km/h,12
ENG179054-ENG179179-RLFS_ZF_TRW-pa_v_wisch_max_1,20 km/h,12
ENG179054-ENG179180-RLFS_ZF_TRW-pa_v_wisch_max_2,4 km/h,12
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-IDE05534-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG149254-Scheinwerferreinigung-Adaptives_Nachwischen_bei_SRA,not active ,10
ENG115729-ENG149255-Scheinwerferreinigung-Anzahl_Betaetigungen_Frontwaschanlage_pro_SRA_Aktivierung,10 ,10
ENG115729-ENG149253-Scheinwerferreinigung-SRA_bei_Waschwassermangel,not active ,10
ENG115729-ENG149258-Scheinwerferreinigung-SRA_Einweichpausenzeit,0 ms,10
ENG115729-ENG149259-Scheinwerferreinigung-SRA_Nachwaschzeit,0 ms,10
ENG115729-ENG149260-Scheinwerferreinigung-SRA_Pausenzeit,0 ms,10
ENG115729-ENG149256-Scheinwerferreinigung-SRA_Verzoegerungszeit,0 ms,10
ENG115729-ENG149257-Scheinwerferreinigung-SRA_Waschzeit,0 ms,10
ENG115729-ENG148897-Scheinwerferreinigung-windshield_washer_system,not installed ,10
ENG116588-MAS10520-Sonderfunktionen-Special function 1,not installed ,4
ENG116588-ENG273845-Sonderfunktionen-Blinkerueberwachung_MFG,not installed ,4
ENG116588-ENG130186-Sonderfunktionen-Signalprioritaet_fuer_Blinker,SMLS ,4
ENG116588-ENG126568-Sonderfunktionen-Sonderfunktionen_2,not enabled ,4
ENG141635-ENG149220-Spiegelverstellung-Funk_Spiegelanklappen,active ,5
ENG141635-ENG149221-Spiegelverstellung-Funk_Spiegelanklappung_Modus,by_look_command_via_remote_control_key ,5
ENG141635-ENG149219-Spiegelverstellung-Menue__Spiegel_absenkung,not active ,5
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,active ,5
ENG141635-ENG149043-Spiegelverstellung-only_ECU_FHSG_Driver_side,installed ,5
ENG141635-ENG149223-Spiegelverstellung-Profilfunktion_fuer_Anklappung_der_Aussenspiegel,not active ,5
ENG141635-ENG155908-Spiegelverstellung-Spiegel_ausklappen_ueber_FFB_auf,active ,5
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,not active ,5
ENG141635-ENG149224-Spiegelverstellung-Spiegelanklappung_geschwindigkeitsabhaengig,active ,5
ENG141635-ENG149041-Spiegelverstellung-window_regulator_node_adress,getauscht ,5
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 lx,10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 lx,10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 lx,10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 lx,10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 lx,10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 ,10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 ,10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 ,10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 ,10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 ,10
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 lx,10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 lx,10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 lx,10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 lx,10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 lx,10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 ,10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 ,10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 ,10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 ,10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 ,10
ENG141632-MAS10512-Sunroof-Sunroof module MD1,not installed ,4
ENG141632-MAS10513-Sunroof-Sunroof module MD shade,not installed ,4
ENG141632-ENG149217-Sunroof-SAD_Komfort_oeffnen,not active ,4
ENG141632-ENG149216-Sunroof-SAD_Komfort_schliessen,not active ,4
ENG141632-ENG149215-Sunroof-SAD_Richtung_Komfortoeffnen,Open ,4
ENG248473-ENG261749-Türen HBFS-pa_NFZ_Funktion_HBFS_1,not active ,2
ENG248473-ENG248779-Türen HBFS-pa_Schiebetür_HBFS,No ,2
ENG248473-ENG248781-Türen HBFS-pa_schlosstyp_HBFS,No ,2
ENG248473-ENG248785-Türen HBFS-pa_tuerkontaktmodul_hbfs,ohne TKM ,2
ENG248474-ENG261743-Türen HFS-pa_NFZ_Funktion_HFS_1,not active ,2
ENG248474-ENG248780-Türen HFS-pa_Schiebetür_HFS,No ,2
ENG248474-ENG248783-Türen HFS-pa_schlosstyp_HFS,No ,2
ENG248474-ENG248786-Türen HFS-pa_tuerkontaktmodul_hfs,ohne TKM ,2
ENG148611-MAS10548-Verbau Personalisierung-Profile function,no key profile ,8
ENG148611-ENG252096-Verbau Personalisierung-Aktiver_Teilnehmer_Doorlocking_aktiviert,not active ,8
ENG148611-ENG252051-Verbau Personalisierung-Aktiver_Teilnehmer_ExteriorLight_aktiviert,not active ,8
ENG148611-ENG252071-Verbau Personalisierung-Aktiver_Teilnehmer_InteriorLight_aktiviert,not active ,8
ENG148611-ENG252085-Verbau Personalisierung-Aktiver_Teilnehmer_Mirror_aktiviert,not active ,8
ENG148611-ENG252072-Verbau Personalisierung-Aktiver_Teilnehmer_WiperComfort_aktiviert,not active ,8
ENG148611-ENG126849-Verbau Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,8
ENG148611-ENG133401-Verbau Personalisierung-Anzahl_Benutzerkonten,1 ,8
ENG148611-ENG133402-Verbau Personalisierung-Automatische_ Schluesselzuordnung,not active ,8
ENG148611-ENG126850-Verbau Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,8
ENG148611-ENG246970-Verbau Personalisierung-IAA -Nutzer_management,not installed ,8
ENG148611-ENG246991-Verbau Personalisierung-pa_Two_Keys,not active ,8
ENG148611-ENG126848-Verbau Personalisierung-Personalisierung_aktiv,not active ,8
ENG148611-ENG126851-Verbau Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,8
ENG148611-ENG142030-Verbau Personalisierung-Profil_Variante,Schluessel ,8
ENG148611-ENG133403-Verbau Personalisierung-PSO_FSG_Setup2_Bit_0,not active ,8
ENG148611-ENG133404-Verbau Personalisierung-PSO_FSG_Setup2_Bit_1,not active ,8
ENG148611-ENG133405-Verbau Personalisierung-PSO_FSG_Setup2_Bit_2,not active ,8
ENG148611-ENG133406-Verbau Personalisierung-PSO_FSG_Setup2_Bit_3,not active ,8
ENG148611-ENG133407-Verbau Personalisierung-PSO_FSG_Setup2_Bit_4,not active ,8
ENG148611-ENG133408-Verbau Personalisierung-PSO_FSG_Setup2_Bit_5,not active ,8
ENG148611-ENG133409-Verbau Personalisierung-PSO_FSG_Setup2_Bit_6,not active ,8
ENG148611-ENG133410-Verbau Personalisierung-PSO_FSG_Setup2_Bit_7,not active ,8
ENG148610-ENG148877-Vernetzungs-_Diagnosefunktionen-can_msg_1,00 00 ,20
ENG148610-ENG148878-Vernetzungs-_Diagnosefunktionen-can_msg_2,00 00 ,20
ENG148610-ENG148879-Vernetzungs-_Diagnosefunktionen-can_msg_3,00 00 ,20
ENG148610-ENG148880-Vernetzungs-_Diagnosefunktionen-can_msg_4,00 00 ,20
ENG148610-ENG148881-Vernetzungs-_Diagnosefunktionen-lin_msg_1,00 00 ,20
ENG148610-ENG148882-Vernetzungs-_Diagnosefunktionen-lin_msg_2,00 00 ,20
ENG148610-ENG148883-Vernetzungs-_Diagnosefunktionen-lin_msg_3,00 00 ,20
ENG148610-ENG148884-Vernetzungs-_Diagnosefunktionen-lin_msg_4,00 00 ,20
ENG148610-ENG148885-Vernetzungs-_Diagnosefunktionen-lin_msg_5,00 00 ,20
ENG148610-ENG148886-Vernetzungs-_Diagnosefunktionen-lin_msg_6,00 00 ,20
ENG148612-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_1,14 04 07 0A 0B 05 DC 09 C4 04 6E 6E 14 04 0C 32 32 1E 03 3C 28 05 3C C8 50 DC 14 42 68 03 E8 03 64 05 01 18 1E 0A 32 1E 00 64 32 64 02 58 00 83 14 02 5A 0A 01 A4 01 54 1B 0A 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 56 37 2E 30 0C ,128
ENG148612-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_2,FE 11 ,128
ENG148613-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_1,DC 05 DC 05 DC 05 DC 05 DC 05 DC 05 DC 05 DC 05 DC 05 DC 05 DC 05 DC 05 C4 09 D0 07 E8 03 E8 03 E8 03 E8 03 C4 09 D0 07 E8 03 E8 03 E8 03 E8 03 04 2C 01 08 07 03 08 07 03 C8 00 F4 01 DC 05 19 08 82 1E 1E 37 00 82 37 0F FA 00 A0 0F A0 0F A0 0F F4 01 B8 0B D0 07 F4 01 E8 03 F4 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 56 37 2E 30 0C ,128
ENG148613-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_2,D3 11 ,128
ENG130135-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 56 37 2E 30 0C ,128
ENG130135-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_2,F0 3E ,128
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,Conditions not correct or request sequence error,128
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,Conditions not correct or request sequence error,128
ENG117303-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_1,Conditions not correct or request sequence error,128
ENG117303-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_2,Conditions not correct or request sequence error,128
ENG130138-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_1,Conditions not correct or request sequence error,128
ENG130138-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_2,Conditions not correct or request sequence error,128
ENG130139-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_1,Conditions not correct or request sequence error,128
ENG130139-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_2,Conditions not correct or request sequence error,128
ENG130140-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_1,Conditions not correct or request sequence error,128
ENG130140-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_2,Conditions not correct or request sequence error,128
ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1,Conditions not correct or request sequence error,128
ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2,Conditions not correct or request sequence error,128
ENG117307-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_1,Conditions not correct or request sequence error,128
ENG117307-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_2,Conditions not correct or request sequence error,128
ENG130142-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_3-Parameter_1,Conditions not correct or request sequence error,128
ENG130142-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_3-Parameter_2,Conditions not correct or request sequence error,128
ENG124895-Window_Regulator_VW_Settings_Driver_Side,0A 0A 00 0A 00 0A 32 19 0F 01 A3 14 00 14 32 0A 32 32 03 FF 01 04 01 18 00 C8 01 18 01 02 0A 01 00 00 00 00 00 00 00 00 00 00 00 37 0F 0F 14 14 C8 C6 0B 05 02 1E B4 AA 02 64 4B B4 55 AA 0A 02 64 64 05 00 0F 0A 1E 0F 01 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 41 B4 06 0A 00 52 1B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 56 37 2E 30 0C 7B 0F ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,Conditions not correct or request sequence error,128
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,Conditions not correct or request sequence error,128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,Conditions not correct or request sequence error,128
ENG148493-ENG115721-Windshield wiper-Frontwischer,Keine_Spannungsanforderung ,6
ENG148493-ENG133394-Windshield wiper-Frontwischer_Abtauposition,keine_Abtaupostition ,6
ENG148493-ENG149235-Windshield wiper-Frontwischer_Referenzlauf,active ,6
ENG148493-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active ,6
ENG148493-ENG149241-Windshield wiper-Geschwindigkeitsabhaengige_Wischstufenrueckschaltung,active ,6
ENG148493-ENG149239-Windshield wiper-Menuesteuerung_Frontwischer,not active ,6
ENG148493-ENG154706-Windshield wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG148493-ENG149042-Windshield wiper-rain_sensor_function,installed ,6
ENG148493-ENG149238-Windshield wiper-Regensensor_aktivieren,active ,6
ENG148493-ENG149242-Windshield wiper-Traenenwischen_Front_Status,not active ,6
ENG148493-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,active ,6
ENG148493-ENG148995-Windshield wiper-windshield_wiper_typ,Direct ,6
ENG148493-ENG149237-Windshield wiper-Wischer_abparken_bei_Oeffnen_der_Motorhaube,not active ,6
ENG148493-ENG149236-Windshield wiper-Wischer_stop_bei_KL15_aus,not active ,6
ENG148493-ENG149244-Windshield wiper-Wischer_stop_bei_Motorstart,nur_Erststart ,6
ENG148493-ENG149243-Windshield wiper-Wischer_Stopp_bei_Oeffnen_der_Motorhaube,active ,6
ENG141651-MAS10522-ZV allgemein-Lock/unlock: direct button,Toggle-Taster ,5
ENG141651-MAS10546-ZV allgemein-Radio freq.,434.42MHz ,5
ENG141651-MAS10554-ZV allgemein-Central locking without SAFE function,installed ,5
ENG141651-ENG179102-ZV allgemein-Abgesichertes Safen,not active ,5
ENG141651-ENG252045-ZV allgemein-Anti_theft_alarm_diagnostic_connection_monitoring,not active ,5
ENG141651-ENG248507-ZV allgemein-Auswertung_Batt_TranspID_Telegramm,not active ,5
ENG141651-ENG179106-ZV allgemein-Autolock_nur_bei_Motorlauf,not active ,5
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,5
ENG141651-ENG252065-ZV allgemein-FFB_Sbt_Entriegelt,No ,5
ENG141651-ENG149179-ZV allgemein-Funk_bei_Klemme_15_ein,not active ,5
ENG141651-ENG179144-ZV allgemein-Kessy Wiederentriegelung mit Außenhaut,not active ,5
ENG141651-ENG149181-ZV allgemein-Menuesteuerung_Tuerentriegelung,active ,5
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,5
ENG141651-ENG179092-ZV allgemein-Schlossansteuerung,all_doors_connected_directly ,5
ENG141651-ENG149384-ZV allgemein-seitenselektive_Oeffnung,Yes ,5
ENG141651-ENG149180-ZV allgemein-ZV_Tuerentriegelung,Globale_Entriegelung ,5
ENG141654-ENG149213-ZV Autolock-Autolock_Autounlock_wirkt_auf_Heck,active ,5
ENG141654-ENG149211-ZV Autolock-automatisches_Entriegeln,active ,5
ENG141654-ENG149210-ZV Autolock-Automatisches_Verriegeln_bei_Geschwindigkeit,active ,5
ENG141654-ENG149212-ZV Autolock-Autounlock_NAR,not active ,5
ENG141654-ENG149214-ZV Autolock-Menuesteuerung_ZV_Autolock-Unlock,adjustable ,5
ENG141655-ENG149225-ZV Crash-Heckdeckel-Bedienstellen_nachCrash_temporaer_sperren,not active ,4
ENG141655-ENG149227-ZV Crash-SAD_PreCrash_Konturschliessen,not active ,4
ENG141655-ENG149226-ZV Crash-ZV-Entriegelung_nach_Seitencrash,active ,4
ENG141653-MAS07515-ZV Heck-Trunk lid remote unlocking: int. button,not installed ,5
ENG141653-MAS10551-ZV Heck-Rear lid lock control,Pulse control ,5
ENG141653-MAS10555-ZV Heck-Central locking: rear lock type,1 or 2 notch rear actuator ,5
ENG141653-MAS10561-ZV Heck-Rear lock with safety catch,No ,5
ENG141653-ENG149183-ZV Heck-Direkter_Auswurf_des_Heckdeckels,active ,5
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,5
ENG141653-ENG149185-ZV Heck-Freigabenachlauf_Heck_nach_Einzeloeffnung_ueber_HDF-Funktaster,not active ,5
ENG141653-ENG149187-ZV Heck-Hecksteuerung_ohne_ZV,not active ,5
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,5
ENG141653-ENG261746-ZV Heck-Rear_lock_control_min_aktiv,not active ,5
ENG141653-ENG126630-ZV Heck-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,5
ENG141653-ENG155905-ZV Heck-Softtouch_Auswertung,digitale_Logik ,5
ENG141653-ENG252095-ZV Heck-Zentralverrieglung_ohne_Heckdeckel,not active ,5
ENG141653-ENG149182-ZV Heck-ZV_entriegelt_auch_Heckdeckel,active ,5
ENG141653-ENG149184-ZV Heck-ZV_Heck_nur_direkt_auswerfen,not active ,5
ENG148616-IDE02021-ZV Komfort (Fensterheber)-Comfort closing,not active ,7
ENG148616-IDE02022-ZV Komfort (Fensterheber)-Comfort opening,not active ,7
ENG148616-MAS10525-ZV Komfort (Fensterheber)-Electrical window lift: front,active ,7
ENG148616-MAS10526-ZV Komfort (Fensterheber)-Electrical window left: rear,Yes ,7
ENG148616-ENG154964-ZV Komfort (Fensterheber)-BAP_Komfortschließen,not active ,7
ENG148616-ENG248524-ZV Komfort (Fensterheber)-Busruhe_bei_Fensterheberfreigabenachlauf,active ,7
ENG148616-ENG149202-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_oeffnen,not active ,7
ENG148616-ENG149206-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_schliessen,not active ,7
ENG148616-ENG149203-ZV Komfort (Fensterheber)-FH_SAD_Kl15Aus_Freigabezeit,600 s,7
ENG148616-ENG149196-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Kl_15_aus,active ,7
ENG148616-ENG149197-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Tueroeffnen,active ,7
ENG148616-ENG149201-ZV Komfort (Fensterheber)-Funk_Komfort_oeffnen,not active ,7
ENG148616-ENG149205-ZV Komfort (Fensterheber)-Funk_Komfort_schliessen,not active ,7
ENG148616-ENG155240-ZV Komfort (Fensterheber)-Kindersicherung_Beifahrerfenster,not active ,7
ENG148616-ENG149198-ZV Komfort (Fensterheber)-Komfortbedienung_global,not active ,7
ENG148616-ENG149199-ZV Komfort (Fensterheber)-Komfortoeffnen_nur_FH_Fahrertuer,not active ,7
ENG148616-ENG155244-ZV Komfort (Fensterheber)-Komfortschliessen_Brasilien,not active ,7
ENG148616-ENG149209-ZV Komfort (Fensterheber)-Manuelle_ZV_Variantenprogrammierung,not active ,7
ENG148616-ENG149207-ZV Komfort (Fensterheber)-Menuesteuerung_Komfortbedienung_einstellbar,not active ,7
ENG148616-ENG149200-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_oeffnen,not active ,7
ENG148616-ENG149204-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_schliessen,not active ,7
ENG141652-MAS01914-ZV Türkonfiguration-Type of lock,1 Motor locks without Safe (NAR locks) ,5
ENG141652-MAS06443-ZV Türkonfiguration-Lock cylinder passenger door,not installed ,5
ENG141652-MAS10567-ZV Türkonfiguration-Four-door,Yes ,5
ENG141652-ENG273805-ZV Türkonfiguration-schliesszylinderlogik_lbs,active ,5
Elapsed Time: 01:24
