Reductant/adblue tank issues: 2015 Passat B8
jez
Alberta, Canada
C?ID=205893 (NRRT)
Hi,
I have a Ross-Tech Hex-Can connector to read electronic codes and prime my TDI fuel pump.
My current car is a 2015 Passat TDI, type-B8 (different from the 2014 Passat)
It recently got cold here in Canada.
During this time my dashboard screen indicated to refill the Adblue tank.
I purchased more fluid and refilled the tank. The fluid was cold (-25 Celsius). There was about 50 km left on the countdown. None of this was ideal.
My car does not recognize the tank level changed, so I need to reset the level sensor. Hopefully now there is no mechanical problem.
--- How likely is it that fluid froze and damaged the plastic SCR tank, or could a low fluid level burn out the injector/pump or tank heater?
--- I am seeking procedures to follow for checking/reseting the SCR system, using VCDS.
Please provide advice. I can post my scans if required.
Thanks,
Jeremy
jez
Alberta, Canada
C?ID=205893 (NRRT)
I filled out my verification info online last week
I don't see it. You joined the forum last week, and you provided a serial number, but that interface has never been registered with us.
jez
Alberta, Canada
C?ID=205893 (NRRT)
Hi. Thanks for helping. I will check into why my Hex-can cable (which I ordered directly from Ross-Tech) is "not registered".
I used it to do an initial scan. Then I screwed up by deleting the codes. I then did another scan. Here they both are (I removed the unnecessary sections).
FIRST SCAN Saturday,02,March,2024,21:20:53:48870
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
VCDS Version: 23.11.0.0
Data version: 20240205 DS351.0
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 016 C HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9467
Revision: 8AH20--- CVN: 121EE41138D3FF82B866C2AD
Coding: 01190012832410081000
Shop #: WSC 91599 999 00000
ASAM Dataset: EV_ECM20TDI01104L997016C 004002
ROD: EV_ECM20TDI01104L997016C.rod
VCID: 33651F329A8B8E090E-8066
VINID: 0669D39874430164C01022020454401E67
12 Faults Found:
25730 - Control Module for Reductant Quality
U02A2 00 [01100000] - No Communications
17158 - Implausible Data Received from ESP Control Module
U0416 00 [00100000] - -
22589 - Reductant Tank Temperature Sensor
P205B 00 [01100000] - Implausible Signal
22585 - Reductant Level Sensor
P203B 00 [01100000] - Implausible Signal
7917 - Glow Plug Control Module
P064C 00 [00100000] - -
7924 - Glow Plug Control Module
9645 - Reductant
P20E8 00 [11101101] - Pressure too Low
Fault Frequency: 8
Mileage: 156907 km
Date: 2024.01.20
Time: 14:51:57
Engine RPM: 1497.00 /min
Normed load value: 85.1 %
Vehicle speed: 57 km/h
Coolant temperature: 78 °C
Intake air temperature: 54 °C
Ambient air pressure: 920 mbar
Voltage terminal 30: 14.000 V
Outside temperature sensor 1: B1: raw value: -11.5 °C
Reducing agent pump module relative press.: calculated: 5609 hPa
Reducing agent fill level sensor: act. value: 0.0 mm
Sensor for reducing agent tank temperature: temperature: -9.6 °C
Reducing agent system pressurization release conditions-Bits 0-7: 0
Reducing agent system pressurization release conditions-Bits 0-7: 255
Reducing agent system: current status: COSCR_PURGE
Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE: 8
21467 - Mass Airflow Sensor 1
P00BC 00 [01100000] - Airflow too Low
22566 - Reductant Injection System
P249C 00 [01100101] - Excessive Time to Enter Closed Loop
Mileage: 157981 km
Date: 2024.02.27
Time: 20:17:17
Engine RPM: 2098.50 /min
Normed load value: 57.3 %
Vehicle speed: 55 km/h
Coolant temperature: 86 °C
Intake air temperature: 51 °C
Ambient air pressure: 930 mbar
Voltage terminal 30: 14.500 V
Outside temperature sensor 1: B1: raw value: -19.5 °C
Reducing agent pump module relative press.: calculated: 1032 hPa
Sensor for reducing agent tank temperature: temperature: -6.7 °C
Reducing agent system pressurization release conditions-Bits 0-7: 251
Reducing agent system: current status: COSCR_AFTERRUN
Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE: 6
17262 - Terminal 30
U140A 00 [00100000] - Open Circuit
4629 - ECM Power Relay Load Circuit
P068A 00 [00100000] - Opens Too Early
28922 - Reductant
Mileage: 156868 km
Date: 2024.01.17
Time: 15:22:53
Engine RPM: 1341.00 /min
Normed load value: 78.8 %
Vehicle speed: 51 km/h
Intake air temperature: 49 °C
Voltage terminal 30: 14.320 V
Outside temperature sensor 1: B1: raw value: -18.0 °C
Reducing agent pump module relative press.: calculated: 3432 hPa
Reducing agent fill level sensor: act. value: 31.3 mm
Sensor for reducing agent tank temperature: temperature: -9.0 °C
Reducing agent system: current status: COSCR_PRESSURECTL
Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE: 4
Readiness: 1 2 0 0 0
CODES GOT CLEARED
SUBSEQUENT SCAN
Saturday,09,March,2024,07:08:22:48870
9645 - Reductant
P20E8 00 [01100101] - Pressure too Low
Mileage: 158020 km
Date: 2024.03.04
Time: 20:30:29
Engine RPM: 2650.50 /min
Normed load value: 29.8 %
Vehicle speed: 23 km/h
Coolant temperature: 55 °C
Voltage terminal 30: 13.760 V
Reducing agent pump module relative press.: calculated: 5487 hPa
Sensor for reducing agent tank temperature: temperature: -10.0 °C
Westbury, UK
There are NO unnecessary sections when posting an Auto-Scan, context is important.
  • Agree
Clearly the OP doesn't want to follow any instructions at all.... this should go smoothly.
  • Agree
jez
Alberta, Canada
C?ID=205893 (NRRT)
I removed irrelevant sections such as about the radio, and a side-marker light-bulb that burnt out...
My post was editted to show the issues that showed up.
jez
Alberta, Canada
C?ID=205893 (NRRT)
What instructions? Where? I have been unable to find a clear procedure relevant to the 2015 CVCA Passat TDI.
I believe the 2014 and earlier TDI's use different procedures, and much more information is available.
This is all a headache for me, learning about the SCR system PLUS the Ross-Tech VCDS software.
In hindsight I recognize mistakes I made.
Anyways I am looking for help and useful information here (not sarcasm).
MrMeeseeks
LP/SN
Start here: https://forums.ross-tech.com/index.php?threads/101/
Having a full unedited autoscan tells the forum what the car is equipped with. In some instances, an engine ECU fault flagged, could actually be a fault flagged in a different module, or a communication issue. This is why a full autoscan is important in diagnosing a fault first time, and correctly.
I see....
Now I feel bad that unlike the rest of us who want to fix things ourselves, you weren't born with this natural knowledge
I guess you'll have to stick to reading user manuals, forums and service manuals to get up to speed.
PS Get verified
PPS Post an auto-scan
:D
Westbury, UK
NO section is irrelevant, often modules throw up sympathy faults, so knowing ALL the details of a vehicle matters.
  • Agree
jez
Alberta, Canada
C?ID=205893 (NRRT)
My car is a 2015 PASSAT TdI (CVCA engine build).
Please advise how long should SCR metering/adaptation tests should take? I cancelled mine after waiting almost ten minutes.
Also with the car ignition kept on, without engine running, how long do the glow-plug circuits stay heating? I intend to run an extended test with a battery charger plugged in, but I am waiting for snow to melt outside.
Are there adaptation code(s) to modify, before running the SCR metering quantity test? This forum mentions this, plus a VW technical bulletin for installing new SCR pumps, specifying setting a value of "2", instead of "4"?
Thanks! I am learning also kinds of SCR Vag-Com sorcery lately. I will post lengthy auto-scans soon.
My recollection is it can be longer than that. This was from a VAG training video that I doubt is public, from many years ago.
