Connecting without a PC
Alpinab7
C?ID=20495
Can I do any of the following without connecting to a PC?
-Update ASAM data
-Connect the HEX-NET to infrastructure
-Check for updates
It looks like I should be able to do some of this stuff without connecting to a PC but i'm not sure and i'm not techie when it comes to this sort of stuff. Am I doing something wrong? It would seem that if I am connected to the HEX-NET I could not be connected to the internet where the updates would need to come from unless it was already able to connect to the infrastructure. I don't have a PC and don't really want to get one.
Shaun
If the HEX-NET is in AP mode this is true, the interface is broadcasting it's own local network disconnected from the internet. However, if you have it connected to your home/shop wifi then it has internet access through that wifi, and if you have it connected through a wifi hotspot on your phone, then it can get internet access from your phone's data plan.
Alpinab7
C?ID=20495
But is there a way to connect the HEX-NET to my home network without connecting to a PC? That's the first step to get the other two done but it seems to require a PC, correct?
Shaun
It is easier to set up with a PC, but generally not required. With the interface in AP mode, you can connect to its network with your phone, in VCDS-mobile go to [Options] -> [Network options] -> [Advanced profile config] and type in the info for your home network. Then use the red button on the interface to toggle it out of AP mode to your home network which you just entered, if everything goes correctly the middle LED should now be green. Then you need to switch your phone back to your home network to access the interface.
Alpinab7
C?ID=20495
That makes more sense. I'll have to play with those settings.
Alpinab7
C?ID=20495
OK. So I got connected to the infrastructure network on my 2.4 network. The issue now is that I am getting garlbled codes that i can't read. I was hoping this would be pretty plug and play. Any thoughts on the following:
Self Test Results:
APP Id (1) CodeBlock V0.4643 API V5
FW version: 1.71
Dataset: 30000060
K1: OK
K2: OK
CAN: OK
VCDS-Cloud: OK
Config: OK
Ports 11011: OK 11012: Failed 11013:
Failed
Auto Scan Codes come up like this:
VCDS Mobile 0.4643.0.5
VCDS Mobile: 0.4643
Data Version: 30000060
VIN: WAUD2AFD1DN029864
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 1B 20 22 28 34 36 3B
     3C 42 46 47 52 53 56 5F 62 6C 6D 6F 72 7F 81 84 85 88 89 8B
     8E 8F 90 A9 BA
1B-Active Steering -- Status: Malfunction 0010
7F-Inform. Electr. II -- Status: OK 0000
8F-Pretension. Front Left -- Status: OK 0000
90-Pretension. Front Right -- Status: OK 0000
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine  (------CGTA)    Labels: 4H-01.lbl
    Part No SW: 4H0 907 557 E    HW: 4H0 906 014
    Component: 4.0l V8TFSI / H62 0004
    Revision: NCH62---
    Coding: 022A00326546000E1000
    Shop #: WSC 21156 003 1048576
    ASAM Dataset: EV_ECM40TFS0114H0907557E 001003
    ROD: EV_ECM40TFS0114H0907557E.rod
    VCID: 3227B9CB9E17E91E557B3B78-8067
¶©À”L{‘þ6´+œ#K,›/®„¿uö´²ójI¸ëm÷è–_O…`É
ÈÓ²ÙÜö
D² ƒá¤wl׃œƒ‚;yº)†ÞÞ¦¶[
ÕÕ*ŠÖOjO•Ãã¨@œ’Û\E-ÉТn    à ©ä>óŸ€
m>|1íT‚{•úm»¨U;ŽäZ×v]£ÛpRVF¢Ò5Wz³Å³‹Q
Alpinab7
C?ID=20495
Not sure if I should have "Replied" to you to notify so i'm doing it here.
Shaun
I have switched your interface to the beta updates channel, where there is a newer dataset available. Please check for updates again to download that update, and then try the scan again.
Alpinab7
C?ID=20495
I did the update 4 times. It says "Update completed successfully. You may now resume using the interface". But I now get a bunch of garbled text on the Main Screen, scanning in AP mode still says "ROD- unkown faultcode", and if I check for updates it still says:
A dataset update is available. This update may take several minutes to perform. Please be patient. Once started, you will be unable to use the interface until the update is complete. Do not press the back button or remove the interface from power until the update has finished. If you do not wish to download this update now, you will be reminded about it again at a latter time.
To download this update manually, go to "Options" - "Check for Updates"
Current version: 20000063
New version: 00000064
Description:
Shaun
You had several Dataset Updates to perform, and without a PC these need to be done incrementally, please continue with the updates until it says you are up to date.
