https://www.law.cornell.edu/cfr/text/49/173.185
49 CFR 173.185 - Lithium cells and batteries.
§ 173.185 Lithium cells and batteries.
As used in this section, lithium cell(s) or battery(ies) includes both lithium metal and lithium ion chemistries. Equipment means the device or apparatus for which the lithium cells or batteries will provide electrical power for its operation. Consignment means one or more packages of hazardous materials accepted by an operatorfrom one shipper at one time and at one address, receipted for in one lot and moving to one consignee at one destination address.
(a)Classification.
(1) Each lithium cell or battery must be of the type proven to meet the criteria in part III, sub-section 38.3 of the UN Manual of Tests and Criteria (IBR; see § 171.7 of this subchapter). Lithium cells and batteries are subject to these tests regardless of whether the cells used to construct the battery are of atested type.
(i) Cells and batteries manufactured according to a type meeting the requirements of sub-section 38.3 of the UN Manual of Tests and Criteria, Revision 3, Amendment 1 or any subsequent revision and amendment applicable at the date of the type testing may continue to be transported, unless otherwise provided in this subchapter.
(ii) Cell and battery types only meeting the requirements of the UN Manual of Tests and Criteria, Revision 3, are no longer valid. However, cells and batteries manufactured in conformity with such types before July 2003 may continue to be transported if all other applicable requirements are fulfilled.
(2) Each person who manufactures lithium cells or batteries must create a record of satisfactory completion of the testing required by this paragraph prior to offering the lithium cell or battery for transport and must:
(i) Maintain this record for as long as that design is offered for transportation and for one year thereafter; and
(ii) Make this record available to an authorized representative of the Federal, state or local government upon request.
(3) Except for cells or batteries meeting the requirements of paragraph (c) of this section, each lithium cell or battery must:
(i) Incorporate a safety venting device or be designed to preclude a violent rupture under conditions normally incident to transport;
(ii) Be equipped with means of preventing external short circuits; and
(iii) Be equipped with an means of preventing dangerous reverse current flow (e.g., diodes or fuses) if a battery contains cells, or a series of cells that are connected in parallel.
(b)Packaging.
(1) Each package offered for transportation containing lithium cells or batteries, including lithium cells or batteries packed with, or contained in, equipment, must meet all applicable requirements of subpart B of this part.
(2) Lithium cells or batteries, including lithium cells or batteries packed with, or contained in, equipment, must be packaged in a manner to prevent:
(i) Short circuits;
(ii) Movement within the outer package; and
(iii) Accidental activation of the equipment.
(3) For packages containing lithium cells or batteries offered for transportation:
(i) The lithium cells or batteries must be placed in non-metallic inner packagings that completely enclose the cells or batteries, and separate the cells or batteries from contact with equipment, other devices, or conductive materials (e.g., metal) in the packaging.
(ii) The inner packagings containing lithium cells or batteries must be placed in one of the followingpackagings meeting the requirements of part 178, subparts L and M, of this subchapter at the Packing Group II level:
(A) Metal (4A, 4B, 4N), wooden (4C1, 4C2, 4D, 4F), fiberboard (4G), or solid plastic (4H1, 4H2) box;
(B) Metal (1A2, 1B2, 1N2), plywood (1D), fiber (1G), or plastic (1H2) drum;
(C) Metal (3A2, 3B2) or plastic (3H2) jerrican.
(iii) When packed with equipment, lithium cells or batteries must:
(A) Be placed in inner packagings that completely enclose the cell or battery, then placed in an outer packaging. The completed package for the cells or batteries must meet the Packing Group II performance requirements as specified in paragraph (b)(3)(ii) of this section; or
(B) Be placed in inner packagings that completely enclose the cell or battery, then placed with equipment in a package that meets the Packing Group II performance requirements as specified inparagraph (b)(3)(ii) of this section.
(4) When lithium cells or batteries are contained in equipment:
(i) The outer packaging, when used, must be constructed of suitable material of adequate strength and design in relation to the capacity and intended use of the packaging, unless the lithium cells or batteries are afforded equivalent protection by the equipment in which they are contained;
(ii) Equipment must be secured against movement within the outer packaging and be packed so as to prevent accidental operation during transport; and
(iii) Any spare lithium cells or batteries packed with the equipment must be packaged in accordance with paragraph (b)(3) of this section.
(5) Lithium batteries that weigh 12 kg (26.5 pounds) or more and have a strong, impact-resistant outer casing and assemblies of such batteries, may be packed in strong outer packagings; in protective enclosures (for example, in fully enclosed or wooden slatted crates); or on pallets or other handling devices, instead of packages meeting the UN performance packaging requirements in paragraphs (b)(3)(ii) and (b)(3)(iii) of this section. Batteries or battery assemblies must be secured to prevent inadvertentmovement, and the terminals may not support the weight of other superimposed elements. Batteries or battery assemblies packaged in accordance with this paragraph are not permitted for transportation bypassenger-carrying aircraft, and may be transported by cargo aircraft only if approved by the Associate Administrator.
(6) Except for transportation by aircraft, the following rigid large packagings are authorized for a single battery, including for a battery contained in equipment, meeting provisions in paragraphs (b)(1) and (2) of this section and the requirements of part 178, subparts P and Q, of this subchapter at the Packing Group II level:
(i) Metal (50A, 50B, 50N);
(ii) Rigid plastic (50H);
(iii) Wooden (50C, 50D, 50F);
(iv) Rigid fiberboard (50G).
(c)Exceptions for smaller cells or batteries. Other than as specifically stated below, a packagecontaining lithium cells or batteries, or lithium cells or batteries packed with, or contained in, equipment, that meets the conditions of this paragraph is excepted from the requirements in subparts C through H ofpart 172 of this subchapter and the UN performance packaging requirements in paragraphs (b)(3)(ii) and (iii) of this section under the following conditions and limitations.
(1)Size limits.
(i) The Watt-hour (Wh) rating may not exceed 20 Wh for a lithium ion cell or 100 Wh for a lithium ion battery. After December 31, 2015, each lithium ion battery subject to this provision must be marked with the Watt-hour rating on the outside case.
(ii) The lithium content may not exceed 1 g for a lithium metal cell or 2 g for a lithium metal battery.
(iii) Except when lithium metal cells or batteries are packed with or contained in equipment in quantities not exceeding 5 kg net weight, the outer package that contains lithium metal cells or batteries must be marked: “PRIMARY LITHIUM BATTERIES - FORBIDDEN FOR TRANSPORT ABOARD PASSENGERAIRCRAFT” or “LITHIUM METAL BATTERIES - FORBIDDEN FOR TRANSPORT ABOARD PASSENGERAIRCRAFT”, or labeled with a “CARGO AIRCRAFT ONLY” label specified in § 172.448 of this subchapter.
(iv) For transportation by highway or rail only, the lithium content of the cell and battery may be increased to 5 g for a lithium metal cell or 25 g for a lithium metal battery and 60 Wh for a lithium ion cell or 300 Wh for a lithium ion battery provided the outer package is marked: “LITHIUM BATTERIES - FORBIDDEN FOR TRANSPORT ABOARD AIRCRAFT AND VESSEL.”
(v) The marking specified in paragraphs (c)(1)(iii) and (iv) of this section must have a background of contrasting color, and the letters in the marking must be:
(A) At least 6 mm (0.25 inch) in height on packages having a gross weight of 30 kg (66 pounds) or less, except that smaller font may be used as necessary when package dimensions so require.
(B) At least 12 mm (0.5 inch) in height on packages having a gross weight of more than 30 kg (66 pounds).
(vi) Except when lithium cells or batteries are packed with, or contained in, equipment, each packagemust not exceed 30 kg (66 pounds) gross weight.
(2)Packaging. Each package must be rigid unless the cell or battery is contained in equipment and is afforded equivalent protection by the equipment in which it is contained. Except when lithium cells or batteries are contained in equipment, each package of lithium cells or batteries, or the completed packagewhen packed with equipment must be capable of withstanding a 1.2 meter drop test, in any orientation, without damage to the cells or batteries contained in the package, without shifting of the contents that would allow battery-to-battery (or cell-to-cell) contact, and without release of the contents of the package.
(3)Hazard communication. Each package must display the lithium battery mark except when a packagecontains button cell batteries installed in equipment (including circuit boards), or no more than four lithium cells or two lithium batteries contained in equipment, where there are not more than two packages in the consignment.
(i) The mark must indicate the UN number, `UN3090' for lithium metal cells or batteries or `UN 3480' for lithium ion cells or batteries. Where the lithium cells or batteries are contained in, or packed with, equipment, the UN number `UN3091' or `UN 3481' as appropriate must be indicated. Where a packagecontains lithium cells or batteries assigned to different UN numbers, all applicable UN numbers must be indicated on one or more marks. The package must be of such size that there is adequate space to affix the mark on one side without the mark being folded.
(A) The mark must be in the form of a rectangle with hatched edging. The mark must be not less than 120 mm (4.7 inches) wide by 110 mm (4.3 inches) high and the minimum width of the hatching must be 5 mm (0.2 inches) except markings of 105 mm (4.1 inches) wide by 74 mm (2.9 inches) high may be used on a package containing lithium batteries when the package is too small for the larger mark;
(B) The symbols and letters must be black on white or suitable contrasting background and the hatching must be red;
(C) The “*” must be replaced by the appropriate UN number(s) and the “**” must be replaced by a telephone number for additional information; and
(D) Where dimensions are not specified, all features shall be in approximate proportion to those shown.
(ii) For transportation by highway, rail or vessel, the provisions in 49 CFR 173.185(c)(3) (revised as of October 1, 2016) for marking packages, including the exceptions from marking, may continue to be used until December 31, 2018. For transportation by aircraft, the provisions for the lithium battery handlingmarking in 49 CFR 173.185(c)(3)(ii) (revised as of October 1, 2016) may continue to be used until December 31, 2018.
(4)Air transportation.
(i) For transportation by aircraft, lithium cells and batteries may not exceed the limits in the following table. The limits on the maximum number of batteries and maximum net quantity of batteries in the following table may not be combined in the same package:
Contents | Lithium metal cells and/or batteries with a lithium
content not more than 0.3 g | Lithium metal cells with a lithium content more than 0.3 g but not more than 1g | Lithium metal batteries with a lithium content more than 0.3 g but not more than 2 g | Lithium ion cells and/or batteries with a Watt-hour rating not more than 2.7 Wh | Lithium ion cells with a Watt-hour rating more than 2.7 Wh but not more than 20 Wh | Lithium ion batteries with a Watt-hour rating more than 2.7 Wh but not more than 100 Wh |
Maximum number of cells/batteries per package | No Limit | 8 cells | 2 batteries | No Limit | 8 cells | 2 batteries. |
Maximum net quantity (mass) per package | 2.5 kg | n/a | n/a | 2.5 kg | n/a | n/a. |
(ii) When packages required to bear the lithium battery mark in paragraph (c)(3)(i) are placed in anoverpack, the lithium battery mark must either be clearly visible through the overpack, or the handling mark must also be affixed on the outside of the overpack, and the overpack must be marked with the word “OVERPACK.”
(iii) Each shipment with packages required to bear the handling marking must include an indication on the air waybill of compliance with this paragraph (c)(4) (or the applicable ICAO Packing Instruction), when an air waybill is used.
(iv) For lithium batteries packed with, or contained in, equipment, the number of batteries in eachpackage is limited to the minimum number required to power the piece of equipment, plus two spares, and the total net quantity (mass) of the lithium cells or batteries in the completed package must not exceed 5 kg.
(v) Each person who prepares a package for transport containing lithium cells or batteries, including cells or batteries packed with, or contained in, equipment in accordance with the conditions and limitations in this paragraph, must receive adequate instruction on these conditions and limitations, commensurate with their responsibilities.
(vi) A package that exceeds the number or quantity (mass) limits in the table shown in (c)(4) is subject to all applicable requirements of this subchapter, except that a package containing no more than 2.5 kg lithium metal cells or batteries or 10 kg lithium ion cells or batteries is not subject to the UN performance packaging requirements in paragraphs (b)(3)(ii) of this section when the package displays both the lithium battery handling marking and the Class 9 label. This paragraph does not apply to batteries or cells packed with or contained in equipment.
(d)Lithium cells or batteries shipped for disposal or recycling. A lithium cell or battery, including a lithium cell or battery contained in equipment, that is transported by motor vehicle to a permitted storage facility or disposal site, or for purposes of recycling, is excepted from the testing and record keeping requirements of paragraph (a) and the specification packaging requirements of paragraph (b)(3) of this section, when packed in a strong outer packaging conforming to the requirements of §§ 173.24 and 173.24a. A lithium cell or battery that meets the size, packaging, and hazard communication conditions in paragraph (c)(1)-(3) of this section is excepted from subparts C through H of part 172 of this subchapter.
(e)Low production runs and prototypes. Low production runs (i.e., annual production runs consisting of not more than 100 lithium cells or batteries), or prototype lithium cells or batteries, including equipment transported for purposes of testing, are excepted from the testing and record keeping requirements ofparagraph (a) of this section, provided:
(1) Except as provided in paragraph (e)(4) of this section, each cell or battery is individually packed in a non-metallic inner packaging, inside an outer packaging, and is surrounded by cushioning material that is non-combustible and non-conductive or contained in equipment. Equipment must be constructed orpackaged in a manner as to prevent accidental operation during transport;
(2) Appropriate measures shall be taken to minimize the effects of vibration and shocks and preventmovement of the cells or batteries within the package that may lead to damage and a dangerous condition during transport. Cushioning material that is non-combustible and non-conductive may be used to meet this requirement;
(3) The lithium cells or batteries are packed in inner packagings or contained in equipment. The inner packaging or equipment is placed in one of the following outer packagings that meet the requirements of part 178, subparts L and M, of this subchapter at the Packing Group I level. Cells and batteries, including equipment of different sizes, shapes or masses must be placed into an outer packaging of a tested design type listed in this section provided the total gross mass of the package does not exceed the gross mass for which the design type has been tested. A cell or battery with a net mass of more than 30 kg is limited to one cell or battery per outer packaging;
(i) Metal (4A, 4B, 4N), wooden (4C1, 4C2, 4D, 4F), or solid plastic (4H2) box;
(ii) Metal (1A2, 1B2, 1N2), plywood (1D), or plastic (1H2) drum.
(4) Lithium batteries, including lithium batteries contained in equipment, that weigh 12 kg (26.5 pounds) or more and have a strong, impact-resistant outer casing or assemblies of such batteries, may be packed in strong outer packagings, in protective enclosures (for example, in fully enclosed or wooden slatted crates), or on pallets or other handling devices, instead of packages meeting the UN performancepackaging requirements in paragraphs (b)(3)(ii) and (iii) of this section. The battery or battery assembly must be secured to prevent inadvertent movement, and the terminals may not support the weight of other superimposed elements;
(5) Irrespective of the limit specified in column (9B) of the § 172.101 Hazardous Materials Table, the battery or battery assembly prepared for transport in accordance with this paragraph may have a mass exceeding 35 kg gross weight when transported by cargo aircraft;
(6) Batteries or battery assemblies packaged in accordance with this paragraph are not permitted for transportation by passenger-carrying aircraft, and may be transported by cargo aircraft only if approved by the Associate Administrator prior to transportation; and
(7) Shipping papers must include the following notation “Transport in accordance with § 173.185(e).”
(f)Damaged, defective, or recalled cells or batteries. Lithium cells or batteries, that have been damaged or identified by the manufacturer as being defective for safety reasons, that have the potential of producing a dangerous evolution of heat, fire, or short circuit (e.g., those being returned to the manufacturer for safety reasons) may be transported by highway, rail or vessel only, and must be packagedas follows:
(1) Each cell or battery must be placed in individual, non-metallic inner packaging that completely encloses the cell or battery;
(2) The inner packaging must be surrounded by cushioning material that is non-combustible, non-conductive, and absorbent; and
(3) Each inner packaging must be individually placed in one of the following packagings meeting the applicable requirements of part 178, subparts L, M, P and Q of this subchapter at the Packing Group I level:
(ii) Metal (1A2, 1B2, 1N2), plywood (1D), or plastic (1H2) drum; or
(iii) For a single battery or for a single battery contained in equipment, the following rigid large packagings are authorized:
(A) Metal (50A, 50B, 50N);
(B) Rigid plastic (50H);
(C) Plywood (50D); and
(4) The outer package must be marked with an indication that the package contains a “Damaged/defective lithium ion battery” and/or “Damaged/defective lithium metal battery” as appropriate. The marking required by this paragraph (f)(4) must be in characters at least 12 mm (0.47 inches) high.
(g)Approval. A lithium cell or battery that does not conform to the provisions of this subchapter may be transported only under conditions approved by the Associate Administrator.
[ 80 FR 72924, Nov. 23, 2015, as amended at 82 FR 15881, Mar. 30, 2017]
