Sunday,24,December,2023,16:49:35:34784
VCDS Version: 23.11.0.0 (x64) HEX-NET CB: 0.4643.4
VIN: WAUZZZFY9J2169774 License Plate:
Chassis Type: FY-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 22 29 2B 39 42 44 46 52 5F 6D 81
A5 AC BB BC D6 D7
VIN: WAUZZZFY9J2169774 Mileage: 78409km-48721miles
Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 CE HW: 04L 907 309 L
Component: R4 2.0l TDI H35 6648
Revision: B1H35--- CVN: FACB31A871719EC2B866C2AD
Coding: 2A654032252605083408
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM20TDI01104L906026CE 005007
ROD: EV_ECM20TDI01104L906026CE_005.rod
VCID: 6FAEFBD1B61AECE92A-803A
VINID: 9D196AAAA5A925A0811891C710441078F9
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 80A 927 155 BA HW: 0CJ 927 156
Component: 0CJ 20TDI RdW H05 0001
Revision: --H05--- Serial number: 0000000938 CVN: BF920B2E
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU49.rod
VCID: 699A95C988FE02D974-803C
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180030001687
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 80A 907 379 B HW: 80A 907 379
Component: ESP9 Plus H11 0766
Dataset Number: 80B909504S 0002 CVN: C2A13B20
Coding: 48AA48BE28A80A9F91A5589820815292E4A5D212121450891A044A4927A54B
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 2E1026D57190A5E161-807A
419584 - TPMS Warning; Rear Left Tire
C1059 00 [00101000] - Flat
Mileage: 78319 km
Date: 2023.12.23
Time: 10:58:07
80 00 00 25 89 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 27
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 80A 820 043 K HW: 80A 820 043 K
Component: Klima Zone 3 H60 0262
Coding: 641800295544440D02000100080000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: 2502D9F92466E6B990-8070
Subsystem 1 - Part No SW: 4M2 820 021 B HW: 4M2 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002057320
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 9F72131900PAG0MUFU02
Subsystem 3 - Part No SW: 80A 919 158 HW: 80A 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Dataset Number: 80B909517F 0029
Coding: 07501143E11800CD054587149FAE80F9110B3108000000000000000020001A810A450122025601
VCID: 0248A2659588F181D5-8056
Subsystem 1 - Part No SW: 80C 955 119 HW: 80C 955 119
Component: 426 RL 180227 040 0570
Serial number: 00000001802262203732
Coding: 5FC7F7
Serial number: 21128627X81A955555A0
Coding: 02006E
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 10 04 2018 81000160
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE122031823810163
Coding: 230000
Interior Light Module:
Subsystem 5 - Part No SW: 80A 947 135 G HW: 80A 947 135
Component: Dachmodul Q5 H31 0310
Serial number: Q00034454
Coding: 0D0104
Subsystem 6 - Part No SW: 8W0 925 301 BD HW: 8W0 925 301 BD
Component: SL-B9/Q5NF H17 0010
Serial number: 2818000051585007
66332 - Reading Lamp; 3rd Row Left
B14F7 01 [00001000] - Electrical Failure
Reset counter: 112
Mileage: 78252 km
Date: 2023.12.23
Time: 09:24:54
average_Voltage_terminals: 12.10 V
Outside air temperature sensor-Outside air temperature on CAN: 9.50 C
interior_temperature: 9.00 C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 75 status: Not available
Terminal activation-Terminal 15 status signal: OFF
Terminal activation-Terminal 15 via CAN: Not available
66333 - Reading Lamp; 3rd Row Right
B14F8 01 [00001000] - Electrical Failure
Reset counter: 110
Mileage: 78353 km
Date: 2023.12.23
Time: 19:24:02
Outside air temperature sensor-Outside air temperature on CAN: 11.50 C
interior_temperature: 14.00 C
Terminal activation-Terminal 75 status: OFF
Terminal activation-Terminal 15 via CAN: OFF
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 80A 959 655 N HW: 80A 959 655 N
Component: AirbagVW30 031 0513
Serial number: 003WBM04APR5 Dataset Number: 80A909602G 0014
Coding: AACCF0C00C800000585400FFF08C40000065
ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
ROD: EV_AirbaVW31SMEAU65x_001_AU49.rod
VCID: 3E301695A1F05561F1-806A
Subsystem 1 - Part No SW: ----------- HW: 480 000 402 18
Serial number: 35700000000BBCC41B2-
Subsystem 2 - Part No SW: ----------- HW: 480 000 402 18
Serial number: 35800000000645346B2E
Subsystem 3 - Part No SW: ----------- HW: 480 032 701 18
Component: SideSensor_Dr 002 0149
Serial number: 351001C08788B4D02BCK
Subsystem 4 - Part No SW: ----------- HW: 480 032 701 18
Component: SideSensor_Pr 002 0149
Serial number: 352001C08C5B71F0197D
Subsystem 5 - Part No SW: ----------- HW: 480 030 402 18
Component: FrontSensor_D 002 0149
Serial number: 355001C08C5E7950F8D-
Subsystem 6 - Part No SW: ----------- HW: 480 030 402 18
Component: FrontSensor_P 002 0149
Serial number: 356001C08C5E7030CE4K
Subsystem 7 - Part No SW: ----------- HW: 480 031 403 18
Component: PedP_Sensor_C 002 0149
Serial number: 230001C0C33E6070FEFL
Subsystem 8 - Part No SW: ----------- HW: 480 001 602 18
Serial number: I0M0000000020C8155A/
Subsystem 9 - Part No SW: ----------- HW: 480 001 602 18
Serial number: I0N00000000FFB8155AP
Central crash sensor X/Y:
Subsystem 10 - Part No SW: ----------- HW: 480 020 302 18
Component: CentrSensorXY 000 0108
Serial number: I0O00019F2920092B37Q
Part No SW: 80A 907 129 BE HW: 80A 907 129 BE
Component: Lenks.Modul H02 0003
VCID: 6C94ECDD870C17F10F-8038
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H18 0373
Coding: 25A48DD4A88006000123E9601000000000000000
VCID: 43C66761CA1238899E-8016
Part No SW: 8W5 907 468 F HW: 8W5 907 468 E
Component: Gateway H43 0123
Revision: 7A000002 Serial number: 0287A505218308 Dataset Number: 80B909515F 0045
Coding: 03010001000086404107000000590032483A0007100000000175078E10000000
GVL: 01D03C0008040200408C08000000C80000080000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003111
VCID: 4CD44C5DE74CF7F16F-8018
Subsystem 1 - Part No SW: 80A 951 523 D HW: 80A 951 523 D
Component: J453 MFL H06 0004
Serial number: 20180329221423 01405
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 8281535700
Address 22: AWD (J492) Labels:* Redir Fail!
Part No SW: 80A 927 755 HW: 0CJ 927 749 A
Component: Q5_DL3_N_SD4 H01 0004
Serial number: 18019A2917
Coding: 01070000
ASAM Dataset: EV_AWDCQUOD31 001048
ROD: EV_AWDCQUOD31.rod
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 80A 907 397 B HW: 80A 907 397 B
Component: LCM_MLBevo H06 0017
Dataset Number: 80B909519C 0009
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 18000035419008
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 322832A565A8810105-8066
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
Dataset Number: 80B909520C 0009
Part No SW: 8W1 959 593 HW: 8W1 959 593
Component: TSG FS001 0737
Serial number: CLSM1RCU00NRH Dataset Number: 80B909872C 0027
Coding: 001F8A015001040000001002
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
VCID: 085CB04DB3B4DBD18B-805C
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H22 0005
Serial number: 0000487275 Dataset Number: 80B909852K 0001
Coding: 90002001000100
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
VCID: 342434BD9FBC8F3117-8060
Part No SW: 4N0 907 064 AM HW: 4N0 907 064 M
Component: BCM2 MLBevo H14 0128
Dataset Number: 80B909501G 0032
Coding: 013500002FB100406309A0000400980233020010804306502F00000000040030001F0001000000
ASAM Dataset: EV_BCM2CONTIAU651 007005
ROD: EV_BCM2CONTIAU651_007.rod
VCID: 7AB8DA85FD58B9418D-802E
ID - sensor:
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY173332AR9
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099812483
Rear spoiler control module:
Part No SW: 8W1 959 592 HW: 8W1 959 592
Component: TSG BFS001 0737
Serial number: CLSM1RCQ00N54 Dataset Number: 80B909873C 0032
Coding: 001F8A015C01040000001000
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
VCID: 075EB371BEAAD4A982-8052
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 035 B HW: 8W5 035 035
Component: MU-P-LND-EU 034 1177
Serial number: A829C0J9410645 Dataset Number: 80B909545N 0026
Coding: 01240601FF0A000053111101000A00332F0015E701700100DE
VCID: 36200EB589C09D2129-8062
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Multimedia System 1:
Subsystem 2 - Part No SW: 80A 919 605 HW: 80A 919 605
Component: AU426_DU_HIGH H42 0008
Serial number: AUZ8Z9JBL03YTQ
Subsystem 3 - Part No SW: 80A 919 615 HW: 80A 919 615
Component: ControlUnit_P H15 0209
Serial number: 10021800000000000298
Compact disc data bank:
Component: Gracenote2 --- 1016
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: A2-C748-5750-5 Dataset Number: 80B909541C 0009
Coding: 0710
Shop #: WSC 00378 210 00000
VCID: 48DC704DF3341BD14B-801C
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 80C 713 041 S HW: 80C 713 041 S
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 20180320001829
ROD: EV_GSMWaehlZFAU736_AU49.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 80A 907 217 A HW: 80A 907 217 A
Component: BVS H16 0050
Dataset Number: 80B909466D 0023
Coding: 0404020600000401024023A0A50000FE00F0C020C000
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
VCID: 2404C4FD2F5C1FB187-8070
Address AC: Reductant Control (J880) Labels: 80A-907-355.clb
Part No SW: 80A 907 355 F HW: 80A 907 355 D
Component: SCR-Stg-G4H07 0004
Dataset Number: 80B909571J 0001
ASAM Dataset: EV_RDCMHelbaAU426 003011
ROD: EV_RDCMHelbaAU426_003.rod
VCID: 2C142CDD478CD7F14F-8078
Part No SW: 8W1 959 595 HW: 8W1 959 595
Component: TSG HFS001 0737
Serial number: CLSM1RCK00RBM Dataset Number: 80B909897C 0027
Coding: 000F88000001040000001000
ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
VCID: 0A588A45ADB8A9C19D-805E
Component: TSG HBFS001 0737
Serial number: CLSM1RCK00R5F Dataset Number: 80B909896C 0027
ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
Dataset Number: 80B909471B 0004
VCID: 177EE331EE0A442912-8042
Component: LED1R H09 0008
Dataset Number: 80B909472B 0004
End----------(Elapsed Time: 02:01, VBatt start/end:
