- Jul 3, 2023
- 79
- 9
- Chisago City, MN, USA
- C?ID=54688
I'm trying to calibrate the steering angle sensor, when I log in to abs/measuring blocks/005, this is what I get:
The car is a 2001 Allroad with a bhw tdi swap. I replaced the steering rack during the swap. When I try to calibrate, turning the wheel nothing changes, stays at zero. Here is a full scan:
And here is a scan before the swap
Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: Release 23.3.1
Dealer/Shop Name:
Workshop Code: 000 00000
Diagnostic Trouble Code Report
Thursday,07,December,2023,10:09:57:28633
VIN: License Plate: ALLROAD
Mileage: Repair Order: 12 7 2023
Control Module Part Number: 4Z7 907 389
Component and/or Version: ABS/ESP allrad D57
Software Coding: 06355
Work Shop Code: WSC 00000
VCID: 0913732C33569BDB9C-513C
18263 - Powertrain Data Bus
P1855 - 35-00 - Software Version Monitoring
01310 - Level Control System Control Module (J197)
49-00 - No Communications
37-00 - Faulty
35-00 - -
VCDS Version: Release 23.3.1(x64) Data version: 20230421 DS346.2
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Wednesday,29,November,2023,11:37:04:28633
VIN: WAUZZZ4B73N041436 License Plate:
Mileage: Repair Order: 2001 Allroad 11/29/2023
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
75 76 77
VIN: WAUZZZ4B73N041436 ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-016-BHW.lbl
Part No SW: 038 906 016 R HW: 028 101 198 2
Component: R4 2,0L EDC G000SG 6416
Revision: 12345678 Serial number: XXXXXXXXXXXXXX
Coding: 0150032
Shop #: WSC 66565 257 00032
VCID: 234F0184E1BA218BF6-513C
VINID: A28A28A28A28A28A28A28A28A0617BF560
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
RPM: 2541 /min
Torque: 192.0 Nm
Speed: 59.0 km/h
Load: 51.8 %
Voltage: 13.68 V
Bin. Bits: 00101000
(no units): 2246.4
(no units): 1123.2
Readiness: 1 1 1 1 X -------------------------------------------------------------------------------
Self-Diagnosis Log
Wednesday,29,November,2023,11:37:05:28633
Page 2
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389
Component: ABS/ESP allrad D57
Coding: 00000
VCID: 0913732C33569BDB9C-5120
66-10 - Not Matched - Intermittent
35-00 - -
------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
VCID: 2D5BE7BCE77EE7FB50-4B00
07-00 - Signal too Low
06-00 - Signal too High
------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 L
Component: A6-Klimavollautomat D64
Coding: 00160
Shop #: WSC 02325
VCID: 234F0184B1BA218BF6-259E
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
00792 - A/C Pressure Switch (F129)
31-10 - Open or Short to Ground - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 3
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4Z7 959 655 C
Component: Airbag Front+Kopf 1002
Coding: 00307
Shop #: WSC 02325
VCID: 4FA79D348DB2F5EB02-5120
01213 - Belt Tensioner Igniter; Rear Middle (N198)
36-10 - Open Circuit - Intermittent ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 D
Component: Lenkradelektronik D03
Coding: 00102
Shop #: WSC 65535
VCID: 2D5BE7BCE77EE7FB50-4FC6
No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 933 G
Component: KOMBI+WEGFAHRS. VDO D12
Coding: 04240
Shop #: WSC 00001
VCID: 27571594C582CDABAA-513C
WAUZZZ4B73N041436 AUZ7Z0B2214229
7 Faults Found:
01176 - Key
65-10 - Unauthorized - Intermittent
01177 - Engine Control Unit
01304 - Radio
01324 - Control Module for All Wheel Drive (J492)
01327 - Control Module for Parking Aid (J446)
30-00 - Open or Short to Plus
Self-Diagnosis Log
Page 4
Address 35: Centr. Locks Labels:. 4B0-962-258.clb
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02325
VCID: 3065FEC8F04C8A137B-4EE6
01560 - Passenger Door
59-00 - Can't Unlock
01561 - Rear left door
01562 - Rear right door
------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
VCID: 2C5DEAB8DC64EEF347-4B00
06-10 - Signal too High - Intermittent ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02325
VCID: 26491890C288D4A391-513C
Self-Diagnosis Log
Page 5
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 195 A
Component: Radio D00
Coding: 00114
Shop #: WSC 02325
VCID: 1E3930709AD80C63D9-4B32
00-00 - -
End-------------------------(Elapsed Time: 05:15)--------------------------
VCDS Version: Release 19.6.2(x64) Data version: 20200210 DS308.0
Dealer/Shop Name:
Self-Diagnosis Log
Monday,30,March,2020,18:38:32:28633
VIN: WAUYP64B51N083892 License Plate:
75 76 77
VIN: WAUYP64B51N083892 ------------------------------------------------------------------------------- Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551
Component: 2.7l V6/5VT G 0002
Coding: 06712
Shop #: WSC 02325
VCID: 55AB6F5CAF6E8FE7A6-513C
WAUYP64B51N083892 AUZ7Z0Y1640797
13 Faults Found:
17840 - Secondary Air Injection Solenoid Valve (N112)
P1432 - 35-00 - Open Circuit
17530 - Oxygen (Lambda) Sensor Heating; B2 S2
P1122 - 35-00 - Open Circuit
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 35-00 - Open Circuit
17528 - Oxygen (Lambda) Sensor Heating; B2 S1
P1120 - 35-00 - Open Circuit
17548 - Oxygen (Lambda) Sensor; B2 S2
P1140 - 35-00 - Internal Resistance too High
16518 - Oxygen (Lambda) Sensor B1 S1
P0134 - 35-00 - No Activity
17956 - Boost Pressure Regulation Valve (N75)
P1548 - 35-10 - Open Circuit - Intermittent
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-10 - - Intermittent
17965 - Charge Pressure Control
P1557 - 35-10 - Positive Deviation - Intermittent
16538 - Oxygen (Lambda) Sensor B2 S1
P0154 - 35-00 - No Activity
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
18058 - Powertrain Data Bus
P1650 - 35-10 - Missing Message from Instrument Cluster - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
Readiness: 0010 1101
Self-Diagnosis Log
Monday,30,March,2020,18:38:33:28633
Page 2
Coding: 06395
Shop #: WSC 02325
VCID: 0913732C33569B07F2-5120
27-10 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None
Coding: 00003
VCID: 2D5BE7BCE77EE7273E-4B00
Coding: 00160
Shop #: WSC 02325
VCID: 234F0184B1BA215798-259E
41-10 - Blocked or No Voltage - Intermittent
31-00 - Open or Short to Ground
01582 - Signal for Coolant Temperature
30-10 - Open or Short to Plus - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 3
Coding: 00307
Shop #: WSC 02325
VCID: 4FA79D348DB2F5376C-5120
No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4B0-907-487.lbl
Coding: 00102
Shop #: WSC 65535
VCID: 2D5BE7BCE77EE7273E-4FC6
Part No: 4Z7 920 980 BX
Component: C5-KOMBIINSTR. VDO D13
Coding: 02264
Shop #: WSC 00001
VCID: 1B3F396489CA199750-5120
01176 - Key
------------------------------------------------------------------------------- Address 35: Centr. Locks Labels:. 4B0-962-258.clb
Coding: 15885
Shop #: WSC 02325
VCID: 3065FEC8F04C8ACF15-4ECA
Self-Diagnosis Log
Page 4
Coding: 00001
VCID: 2C5DEAB8DC64EE2F29-4B00
Coding: 00102
Shop #: WSC 02325
VCID: 26491890C288D47FFF-513C
No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Coding: 00114
Shop #: WSC 02325
VCID: 1E3930709AD80CBFB7-4B32
End---------------------(Elapsed Time: 05:09, udsna)-----------------------
