Tuesday,05,December,2023,12:00:48:26125
VCDS Version: 23.11.0.0 (x64) HEX-NET CB: 0.4643.4
VIN: WAUZZZF44LA044994 License Plate:
Chassis Type: F4-AU49 (80B)
Scan: 01 02 03 08 09 13 15 16 17 18 19 3C 42 44 46 52 5F 69 6C 6D
75 81 82 8B A5 AC BB BC CF D6 D7 DE
VIN: WAUZZZF44LA044994 Mileage: 119668km-74358miles
81-Gear Shift -- Status: Malfunction 0010
Address 01: Engine (J623-DETA) Labels: None
Part No SW: 04L 906 027 BB HW: 04L 907 309 L
Component: R4 2.0l TDI H37 7155
Revision: B1H37--- CVN: 802D0CB99066EFDD6C5AF8886C5AF888
Coding: 0A25403A2374050834280000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TDI01104L906027BB 005001
ROD: EV_ECM20TDI01104L906026PP.rod
VCID: 6C94087487EDFAF10F-8038
VINID: 9D196AAAA58411C44010424910C91719A5
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 EB HW: 0HK 927 156 B
Component: 0CK 20TDI RdW H01 0003
Revision: --H01--- Serial number: 0000001347 CVN: 86DDF04D
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU49.rod
VCID: 05425DD084472BB9F0-8050
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041190343002028
22348 - Selector Lever
P0919 00 [00100110] - Malfunction
Mileage: 119668 km
Date: 2023.12.05
Time: 11:53:02
Engine RPM: 0 /min
Driving position: P
ATF temperature: 1 °C
Voltage terminal 30: 11.6 V
Engine torque: -100 Nm
selected gear: 1
Ctrl. mod.: operating condition: regular operation
Auxiliary pump for transmission: requesting function: Preloading
Auxiliary hydraulic pump for transmission oil: current: 0 A
Oil pressure reservoir: pressure: 15.9 bar
Pressure of clutch 1: actual value: 0.0 bar
Pressure of clutch 2: actual value: 0.0 bar
Clutch status: Neutral
Occurrence_counter_over_length_of_life: 3
Gear_shift_module_reset_state-Reset_status: Wait for end of Initialization
Gear_shift_module_switch_off_counter_over_length_of_life: 0
Gear_shift_module_reset_counter_since_erasing_DTC_memory: 0
Gear_shift_module_switch_off_counter_since_erasing_DTC_memory: 0
22351 - Selector Lever
P085D 00 [00100111] - Malfunction
Mileage: 119668 km
Date: 2023.12.05
Time: 11:51:55
Engine RPM: 0 /min
Driving position: P
selected gear: 1
Oil pressure reservoir: pressure: 16.6 bar
Occurrence_counter_over_length_of_life: 2
Gear_shift_module_P_taste_state: 3
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PRE-V1.clb
Part No SW: 8W0 907 379 AM HW: 8W0 907 379 N
Component: ESP9 Premium H17 0837
Dataset Number: 8W0909504S 0010 CVN: 3AC213DA
Coding: 0CAA489910A60A9A51A7489A008152A2E5B59A301208508A12004A45A7AD59
Shop #: WSC 06334 790 00001
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 106C7C84CB057E1153-8044
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0251
Dataset Number: 8W0909862D 0024
Coding: 241840195544410D02000100080000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44C480D4CFFDD2B1A7-8010
Subsystem 1 - Part No SW: 4M1 820 021 C HW: 4M1 820 021 C
Component: J126 FLuftV H09 0004
Serial number: 00000000000004537275
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 C HW: 4H0 907 658 C
Component: G935 MuFu H04 0010
Serial number: 9E410E8A00PAG0MUFU04
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W1 907 063 G HW: 8W1 907 063 G
Component: BCM1 MLBevo H10 0690
Dataset Number: 8W1909514A 0012
Coding: 07001140C13900DD0505578898BF80E9110B3108000000980101080020001C810A45023B0257050000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 016011
ROD: EV_BCM1BOSCHAU651_016_VW53.rod
VCID: 40CC8CC4DBE5CE9183-8014
Subsystem 1 - Part No SW: 8W1 955 119 A HW: 566 955 119
Component: J400FRWISCH 051 0822
Serial number: 887353F0401934201898
Coding: 7DC727
Subsystem 2 - Part No SW: 81D 955 555 HW: 81D 955 555
Serial number: 90085511X81D95555500
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AH HW: 4M0 941 531 AH
Component: E1 - LDS H06 0008
Serial number: 26 08 2019 02097591
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE101101924110516
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 AE HW: 4K0 947 135 AE
Component: Dachmodul H42 0416
Serial number: B01536508
Coding: 0D0104
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 8W0 907 561 F HW: 8W0 907 561
Component: LRR4 H10 0440
Dataset Number: 8W0909863P 0001
Coding: 3577FFFA58FFEC0A959B81A0
ASAM Dataset: EV_ACCBOSCHAU49X 003022
ROD: EV_ACCBOSCHAU49X_003_AU49.rod
VCID: 41CA89C0D0EFC7998C-8014
2082 - Databus
[FAULT_EPB_SWITCH_FAIL]
Reset counter: 0
Mileage: 119668 km
Date: 2023.12.05
Time: 11:11:34
Control Module temperature: 4 °C
Voltage terminal 15: 10.9 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_StandBy
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0109
Serial number: 003UP00Z1DG. Dataset Number: 8W0909602BA 0012
Coding: AACCF0C00C800000985400F3D04C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006.rod
VCID: 4CD4A8F4E7AD1AF16F-8018
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2040
Serial number: 8W0857705L0006U00436
Coding: 88001B
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2040
Serial number: 8W0857706N0006U01599
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 442 061 412 19
Serial number: 3577Y00A7325C5D0B331
Subsystem 4 - Part No SW: ----------- HW: 442 061 412 19
Serial number: 3587Y009D325C5D2B227
Subsystem 5 - Part No SW: ----------- HW: 442 0B0 312 19
Serial number: 35177009F34C9851B0FT
Subsystem 6 - Part No SW: ----------- HW: 442 0B0 312 19
Serial number: 3527700BB345FBB5617S
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 911 19
Component: FrontSensor_D 1C5 014A
Serial number: 3557500A134C4801037Z
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 911 19
Component: FrontSensor_P 1C5 014A
Serial number: 3567500A334C4805C236
Subsystem 9 - Part No SW: ----------- HW: 442 0C0 801 20
Component: PedP_Sensor_C 1C5 014A
Serial number: 23075009B3507725809/
Subsystem 10 - Part No SW: ----------- HW: 442 551 212 19
Component: PedPSensor_D2 38B 0887
Serial number: I0MEB00C132C43B454DA
Subsystem 11 - Part No SW: ----------- HW: 442 551 212 19
Component: PedPSensor_P2 38B 0887
Serial number: I0NEB00B532C43B473AC
Part No SW: 4N0 907 129 AJ HW: 4N0 907 129 AJ
Component: Lenks.Modul H03 0005
VCID: 79BA2120F8BF5F5984-802C
Address 17: Instruments () Labels:* None-SRI2
Part No SW: 8W5 920 790 J HW: 8W5 920 790 J
Component: FBenRDW------ H08 0067
Dataset Number: 8W1909525B 0010
Coding: 85A42BC06E8800080080E3601000680008000000
ASAM Dataset: EV_DashBoardAU65X 002018
ROD: EV_DashBoardAU65X_002_AU49.rod
VCID: 49DA91E0E8DF0FD954-801C
Address 18: Aux. Heat (J364) Labels:* None
Part No SW: 4M0 265 105 E HW: 4M0 265 105 E
Component: HSG H12 0110
Dataset Number: 8W0909858G 0021
Coding: 0D0B01
ASAM Dataset: EV_AuxilParkHeateEBEAU736 001019
ROD: EV_AuxilParkHeateEBEAU736_AU49.rod
VCID: 291A3160489F2FD9B4-807C
Part No SW: 80B 907 468 E HW: 80B 907 468 B
Component: Gateway H05 0456
Serial number: 1CF02105559401 Dataset Number: 8W0909515N 0013
Coding: 03010001000006404107000000590012DC180007100000000100008F00000000
GVL: 01503C0808040000C0CCC8008006C800000C0000000000000000000000006500
ASAM Dataset: EV_Gatew31xAU65x 003190
ROD: EV_Gatew31xAU65x_AU49.rod
VCID: 312AD900604F57197C-8064
Subsystem 1 - Part No SW: 82A 951 523 F HW: 82A 951 523 F
Component: E221__MFL H03 0010
Serial number: 03S03001088114320008
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 7797383305
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 F HW: 4M0 907 566
Component: MRR1Rear H22 0440
Revision: -------- Dataset Number: 8W0909535D 0002
Coding: 1EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
VCID: 383CE424833586513B-806C
Part No SW: 4M0 959 793 M HW: 4M0 959 793 J
Component: TSG FS 010 0384
Serial number: 0000400755316 Dataset Number: 8W0909872H 0034
Coding: 001D0B215000008000011030
ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
VCID: 48DC94E4F3D5F6D14B-801C
Part No SW: 8W0 909 144 J HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0411
Dataset Number: 8W0909852R 0043
Coding: 0D008380008080
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
Part No SW: 8W1 907 064 AN HW: 8W1 907 064 N
Component: BCM2 MLBevo 044 0542
Dataset Number: 8W0909501P 0010
Coding: 01342100002000E06309A0000C00C80211034000804F06502F0400000504803F001F0601001F11
ASAM Dataset: EV_BCM2HellaAU736 017017
ROD: EV_BCM2HellaAU736_017_AU49.rod
VCID: 095A51E0A85F4FD994-805C
left tail lamp 1:
Subsystem 1 - Part No SW: 8W9 945 423 HW: 8W9 945 423
Component: T1 LH ECE H10 0510
Serial number: HAX00206F4CW000020AE
Subsystem 2 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 14285199
left tail lamp 2:
Subsystem 3 - Part No SW: 8W9 945 429 HW: 8W9 945 429
Component: T2 LH ECE H10 0510
Serial number: HAX00007TRBV000020AY
Right rear tail lamp 1:
Subsystem 4 - Part No SW: 8W9 945 424 HW: 8W9 945 424
Component: T1 RH ECE H10 0510
Serial number: HAX00204CKBV000020AF
Right rear tail lamp 2:
Subsystem 5 - Part No SW: 8W9 945 430 HW: 8W9 945 430
Component: T2 RH ECE H10 0510
Serial number: HAX000096GBV000020AX
Part No SW: 4M0 959 792 M HW: 4M0 959 792 J
Component: TSG BFS 010 0384
Serial number: 0000400662529 Dataset Number: 8W0909873H 0034
Coding: 001D0B215C00008000011030
VCID: 47DE97D8FECBF9A942-8012
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8W2 035 043 A HW: 8W2 035 043
Component: MU-TH-ND-EU 041 3248
Serial number: GRO-63307.01.20 Dataset Number: 8W1909545B 0025
Coding: 14920000804020000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001008
ROD: EV_MUTI_VW53.rod
Multimedia System 1:
Subsystem 1 - Part No SW: 8W1 919 620 A HW: 8W1 919 620
Component: CenterDisplay H42 0160
Serial number: AUZ8Z9K2H0091F
Subsystem 2 - Part No: V03 959 820 KB
Component: MIB3_EU_ 0960
Compact disc data bank:
Component: Gracenote2 1005
Volume Control 1:
Subsystem 4 - Part No SW: 8W1 919 616 D HW: 8W1 919 616 D
Component: LSR-B9PA H20 0103
Serial number: ALJAL211111900050053
Media socket:
Subsystem 5 - Part No: 8W0 035 708 A
009 0007
6662 - Volume Control
U11B9 00 [00001000] - No Communications
Reset counter: 0
Mileage: 119668 km
Date: 2023.12.05
Time: 11:11:37
Voltage terminal 30: 11.4 V
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 8W1 907 383 A HW: 8W1 907 383
Component: Anhaenger H07 0040
Serial number: 000000000005349 Dataset Number: 8Y0909527A 0005
Coding: 0100000202001100
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 3FCE8F38A61BB169FA-806A
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H18 0250
Dataset Number: 8W0909460D 0012
Coding: 0294020103002005400040
ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
VCID: 3326D3089A5365090E-8066
Part No SW: 4M0 959 107 D HW: 4M0 959 107 A
Component: HDSG-Modul H13 0171
Revision: -------- Serial number: A2-C737-6252-4 Dataset Number: 8W0909541F 0019
Coding: 05F0
VCID: 3424D0149F5D623117-8060
Part No SW: 4KE 035 282 C HW: 4KE 035 282 C
Component: CB_H_ECE 036 0179
Serial number: A970L0KB047282
Coding: 01E0E0F8C04080F6E0
ASAM Dataset: EV_ConBoxHighAU49X 001004
ROD: EV_ConBoxHighAU49X_AU49.rod
VCID: 3B36FB28B203AD49D6-806E
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 N HW: 8W1 713 041 K
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 19120957347889
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 3E30F23CA111B861F1-806A
27686 - Unlock Button
P17EC 00 [10001001] - Electrical Malfunction
Reset counter: 215
Mileage: 119668 km
Date: 2023.12.05
Time: 11:53:03
Selec. range display: spec. val.: Init
Selector lever position: Basic setting X
Standard_FreezeFrame_Extended_Temperature_CAN: 76
Standard_FreezeFrame_Extended_Temperature_Celsius: 9.0 °C
System run time: 127 s
28449 - Switch for Parking Lock
P18CA 00 [10001001] - Electrical Malfunction
Reset counter: 215
Mileage: 119668 km
Date: 2023.12.05
Time: 11:53:03
30120 - Indicator Lamp for Parking Lock
P10EA 00 [00001001] - Electrical Malfunction
Reset counter: 215
Mileage: 119668 km
Date: 2023.12.05
Time: 11:53:02
System run time: 126 s
Address 82: Head Up Display (J898) Labels:| 4M0-919-617-V1.clb
Part No SW: 8W5 919 617 F HW: 8W5 919 617 F
Component: HeadUpDisplay H22 1906
Coding: 4F01E0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736_AU49.rod
VCID: 4BD6ABE8E2A31DC966-801E
Address 8B: Adaptive Cruise 2 (J850) Labels: None
Part No SW: 8W0 907 541 F HW: 8W0 907 541
Dataset Number: 8W0909885H 0002
ASAM Dataset: EV_ACC2BOSCHAU49X 003022
ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 F HW: 8W0 907 217 F
Component: BVS H21 0062
Dataset Number: 8W0909466G 0047
Coding: 0404090200000401022023A7A50000FCB0F0C020E280
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002028
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 D HW: 4M0 907 355 B
Component: SCR-Stg-G3H05 0006
Dataset Number: 8W0909571D 0007
ASAM Dataset: EV_RDCMINERGAU736 005012
ROD: EV_RDCMINERGAU736_AU49.rod
VCID: 3228D60C65496C0105-8066
Part No SW: 4M0 959 795 M HW: 4M0 959 795 J
Component: TSG HFS 010 0384
Serial number: 0000401112998 Dataset Number: 8W0909897H 0034
Coding: 000D09210000008000001020
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 4AD8AEECEDD904C15D-801E
Component: TSG HBFS 010 0384
Serial number: 0000401110783 Dataset Number: 8W0909896H 0034
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 F HW: 4M0 907 590
Revision: --------
Coding: 1EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
VCID: 3522ED1094277B3920-8060
Part No SW: 4K0 941 591 BD HW: 4K0 941 591 B
Component: LMS_MLBevo H11 0040
Dataset Number: 8W0909471F 0013
ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
ROD: EV_LMSLeftHELLAAU58X_AU37.rod
VCID: 72A8160CA5C92C01C5-8026
Dataset Number: 8W0909472F 0013
ASAM Dataset: EV_LMSRightHELLAAU58X 001015
ROD: EV_LMSRightHELLAAU58X_AU37.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
Part No SW: 4K0 035 502 B HW: 4K0 035 502 B
Component: WLC Front H14 0061
Dataset Number: 4N0909485A 0007
Coding: 800000
ROD: EV_Charg1MobilDevicAU651_004_AU37.rod
VCID: 200C2C443BA5EE91E3-8074
End----------(Elapsed Time: 02:09, VBatt start/end: 14.4V/15.0V)-----------
