That means you erased the codes before you took it in.... because the scan you showed had a confirmed code and MIL in it.
Yes, I erased the original fault codes from
Jan 23, which was as shown below, thinking that it was caused by (related to) the low voltage situation, tied to the weak battery which I replaced as the first course of action:
Tuesday,23,January,2024,14:36:33:41104
VCDS Version Release 23.11.0 (x64) Running on Windows 10 x64(Parallels)
Address 01: Engine Labels: 059-907-401-V2.clb
Control Module Part Number: 8K5 907 401 AC HW: 4G0 907 401 E
Component and/or Version: 3.0TDI FSA H14 0008
Software Coding: 2A2A4012053603050000
Work Shop Code: WSC 11886 002 1048576
ASAM Dataset: EV_ECM30TDI0118K5907401AC 002008 (AU48)
ROD: EV_ECM30TDI0118K5907401AC_002.rod
VCID: 71E96F35A0098A193C-8025
31982 - EGR Valve (N18)
P0403 00 [01100101] - Malfunction
Mileage: 155984 km
Date: 2024.01.23
Time: 14:22:55
Engine RPM: 1820.50 /min
Normed load value: 54.5 %
Vehicle speed: 34 km/h
Coolant temperature: 14 °C
Intake air temperature: 10 °C
Ambient air pressure: 810 mbar
Voltage terminal 30: 13.560 V
Air mass: actual value (mg/stroke): 496.6 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 27.19 %
EGR Solen.val.: actual value: 100.00 %
EGR valve: offset closed: 0.10 %
High press EGR actuator: actual unconditioned volt val: 796.6 mV
EGR valve: offset open: -0.10 %
37931 - EGR Valve (N18)
Mileage: 155984 km
Date: 2024.01.23
Time: 14:23:01
Engine RPM: 1888.50 /min
Normed load value: 56.5 %
Vehicle speed: 41 km/h
Coolant temperature: 15 °C
Voltage terminal 30: 13.800 V
Air mass: actual value (mg/stroke): 455.0 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 100.00 %
Readiness: 0 0 0 1 1
The Q5 had some other curious codes in the system back then which were tripped by the bad battery situation. All codes were cleared and none came back after the battery issue got addressed with a battery replacement and a proper battery coding.
My wife drove the vehicle for a month and then the fault came back on Feb 29 as shown below, and I have not cleared this one, I delivered the car to the dealer this way.
Address 01: Engine (J623-CPNB) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 401 AC HW: 4G0 907 401 E
Component: 3.0TDI FSA H14 0008
Revision: 58H14--- CVN: E29A4E35C19C777138D3FF8238D3FF820E1FC39E
Shop #: WSC 11886 002 1048576
VINID: 9D10539915A02174400C624800B38EEB44
P0403 00 [11101101] - Malfunction
Mileage: 158005 km
Date: 2024.02.29
Time: 13:39:02
Engine RPM: 762.50 /min
Normed load value: 43.5 %
Vehicle speed: 4 km/h
Coolant temperature: 53 °C
Intake air temperature: 20 °C
Ambient air pressure: 820 mbar
Voltage terminal 30: 13.100 V
Air mass: actual value (mg/stroke): 624.4 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 96.88 %
EGR Solen.val.: actual value: 99.87 %
EGR valve: offset closed: 0.82 %
High press EGR actuator: actual unconditioned volt val: 776.8 mV
EGR valve: offset open: -0.82 %
Readiness: 1 1 0 1 0
One would hope that if the dealer's procedure is to trigger/observe the code twice, I should be able to provide documentation from documenting that it has happened for the second time already and have them start the repairs, no? (I did save the report from Jan 23rd).
The other thing is, can these codes be thrown by otherwise good valve/motor controller which would operate properly if the system was cleaned up from the carbon buildup? The local shops seem to clean the system from carbon as part of the advised remedy. Not sure why audi dealer choses not to and tries talking us into driving this unreliable vehicle…
Am I mistaken here or should I be able to talk them into cleaning up the carbon buildup based on the history of the faults?
