- Jul 10, 2023
- 5
- 0
- Deptford, NJ, USA
- C?ID=495576
Group,
Looking for some help or insight into a new issue. Two days ago, while driving, my '12 A7 the car would flash an "ACC cruise control / ABS standby" error on the dash while simultaneously taking the car out of gear (no gear indicator on console or on dash cluster); and as such the car wouldn't move. I scanned the car and it returned error code P0705 Transmission Range Sensor. I took the car to an independent shop and they informed me today that although the sensor is testing as failed Audi won't sell them a new part.
My question to the group is:
1) Can I potentially swap a Transmission Range Sensor from an identical year A7 onto my car? And if so will any coding or adaptations be needed? Since this wouldn't be a "fresh part" I'm assuming I wouldn't have much if anything to code in this case, however, if so does anyone have any insight.
2) This sensor also connects to the cars mechatronics unit. The shop didn't give me any indication that this unit is bad, only that the sensor is. Is it required to replace the entire unit as well as the sensor or will a sensor swap work?
Right now this failure happened 400 miles from home. My first priority is getting the car back home and from there if I need to do any further or more permanent fixes that's fine but what I'm looking for right now is to get this car home.
Any insight into this issue or fixes would be greatly appreciated.
Thank you.
Thank you.
Saturday,08,July,2023,17:42:44:32313
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: WAUSGAFC0CN002623 License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 28 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 6C 6D 72 82 84 85 8B 8E 8F 90
VIN: WAUSGAFC0CN002623 Mileage: 200229km-124416miles
Address 01: Engine (J623-CGXB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSI H05 0005
Revision: --H05--- CVN: 0CD0E245
Coding: 1A2A0034056600060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 002006
ROD: EV_ECM30TFS0214G0907551A_002.rod
VCID: 270BF31FEF6AF7A3C6B-8072
VINID: 9D19635D15930137800021820CFA1E706D
Readiness: 0010 1101
Part No SW: 4G0 927 158 E HW: 0BK 927 156 R
Component: 0BK 30TFSIUSA H08 0002
Revision: --H08--- CVN: 9A2A7163
Coding: 001102
ASAM Dataset: EV_TCMAL551211 001014
ROD: EV_TCMAL551211_001.rod
VCID: 30391843DAA4B01B171-8064
14517 - Transmission Range Sensor (F125)
P0705 00 [036] - Circuit Malfunction
Mileage: 200229 km
Date: 2023.07.08
Time: 17:37:48
Voltage terminal 30: 13.391 V
Voltage terminal 15: 14.0 V
Terminal 15 status: Terminal 15 on
Driving position: s
Driving mode sensor-Hall sensor A: not active
Driving mode sensor-Hall sensor B: not active
Driving mode sensor-Hall sensor C: not active
Driving mode sensor-Hall sensor D: not active
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 B HW: 4G0 907 379 B
Component: ESP PREMIUM H09 0190
Coding: 44A70F0222E5F0404B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod
0486 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Ldm_ApbFailureState]
Reset counter: 196
Mileage: 200214 km
Date: 2023.07.08
Time: 16:40:07
VzRef: 69
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 02
F-Type: 06
Uz: B2
0712 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[SCL_GE_Waehlhebel_Error]
Reset counter: 196
Mileage: 200214 km
Date: 2023.07.08
Time: 16:40:07
VzRef: 69
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 00
F-Type: CA
Uz: B3
Part No SW: 4H0 907 064 AR HW: 4H0 907 064 AR
Component: BCM2 2.0 H24 0217
Coding: 0D8A2000000000000000
VCID: 79AFE56749DEB153E0F-802C
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000016900013
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H11 0056
Serial number: 23021100040545
Coding: 6603207A1C
ASAM Dataset: EV_AirCondiComfoUDS 002029
VCID: 2809F023E274F8DBCF1-807C
Part No SW: 4H0 907 063 G HW: 4H0 907 063
Component: BCM1 2.0 H12 0092
Revision: 11012002 Serial number: 00000000786005
Coding: 0D072091073E9FE081000884A0003820CF9CD308A2090125800308453B00
VCID: 2C010C33F60CD4FB2B9-8078
Component: WWS57X 110218 H32 0051
Serial number: 110221160422
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11290290
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 H HW: 4G0 941 531 H
Component: E1 - LDS H07 0044
Serial number: 23 02 2011 00000335
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0C0V06
Subsystem 5 - Part No SW: 8K0 959 772 C HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 1002330070
Coding: 853000
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0001
Serial number: 00000000001101210718
Subsystem 7 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0001
Serial number: 00000000001101210153
Subsystem 8 - Part No SW: 4H0 907 705 J HW: 4H0 907 705 C
Component: EVLS-SG H08 0280
Serial number: WA101933000000179722
Coding: 020300
Subsystem 9 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 6138C395000000000001
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0001
Serial number: 00000000001101212035
Subsystem 11 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0001
Serial number: 00000000001101212472
03189 - Bulb for Side Marker Light; Front Right
Fault Status: 01101100
Reset counter: 156
Mileage: 200227 km
Date: 2023.07.08
Time: 17:34:00
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 C HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0490
Revision: 00000006
VCID: 2D070137CD16DDF33C7-8078
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 J HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0032
Revision: 11001001 Serial number: 55931100404635
Coding: 300904
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 392F256709DE7153A0F-806C
Part No SW: 4G0 907 561 HW: 4G0 907 561
Component: ACC3 H15 0160
Coding: 3601010201
ASAM Dataset: EV_AdaptCruisContrAU57X 001003
ROD: EV_AdaptCruisContrAU57X_001.rod
VCID: 678BB31F2FEA37A306B-8032
105984 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_EPB_FAIL]
Reset counter: 196
Mileage: 199207 km
Date: 2023.06.10
Time: 15:08:58
Control Module temperature: 40 °C
Voltage terminal 15: 12.088 V
140288 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_ECD_FAIL]
Reset counter: 196
Mileage: 199207 km
Date: 2023.06.10
Time: 15:08:59
Voltage terminal 15: 12.097 V
103168 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_TMC_FAIL]
Reset counter: 196
Mileage: 200214 km
Date: 2023.07.08
Time: 16:40:07
Voltage terminal 15: 13.895 V
Velocity_vehicle_reference: 30.21 m/s
Longitudinal_acceleration_vehicle_reference: -0.09 m/s²
103936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_GPOS_FAIL]
Fault Frequency: 8
Reset counter: 196
Mileage: 200214 km
Date: 2023.07.08
Time: 16:40:07
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H31 0032
Revision: -------- Serial number: 003D80012CA6
Coding: 303145313131303030324A55304C34473853
VCID: 3333174F2BB28B036A3-8066
Serial number: 6940000Y160001H2JV01
Serial number: 3575HRB405F00Q2IA94$
Serial number: 3585HRB405V09RF2AP8/
Serial number: 3515JRB405P0AMH0J8T
Serial number: 3525JRB404P0BTBG39CO
Serial number: 3554VRB405N0DD241ONQ
Serial number: 3564VRB405J0DD24JHQ.
Component: Lenks.Modul H03 0003
Revision: -------- Serial number: 90372KBM00079
Coding: 00003C
VCID: 372B235F3F4A672356B-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H07 0009
Serial number: 22 01 2011 11099102
Part No SW: 4G8 920 981 M HW: 4G8 920 981 M
Component: TBenUsaAccNv H34 0309
Revision: 19100073 Serial number: 658020211593062
Coding: 0BC601060F03CF05020100
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU57.rod
VCID: 3D2731771DF64D738C7-8068
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000103388
Coding: 00C1033000
GVL: FDEDE84CFEE36C0D40
ROD: EV_GatewUDS_AU57.rod
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650557738
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0056
Serial number: 24021100040304
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
VCID: 2F3B1B3FC79AAFE30EB-807A
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00001002262492
Coding: C0581B008F002001000001010101102030303232203232
VCID: 382920633254685B5F1-806C
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200DY150
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D070137CD96DDF33C7-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 C HW: 4G0 907 566
Component: J769 SWA MasterH01 0020
Revision: 00H01000 Serial number: 6PZ 010 287-01
Coding: 0000007
VCID: 2F3B1B3FCB1AAFE30EB-807A
Subsystem 1 - Part No: 4G0 907 568 C
Component: J770 SWA Slave H01 0020
Subsystem 2 - Serial number: 6PZ 010 287-21
Subsystem 3 - Serial number: 5F03.02.1100H010003CD20269ÿ
Subsystem 4 - Serial number: D20269ÿ
Part No SW: 4G8 959 793 B HW: 4G8 959 793
Component: TSG FA H04 0210
Coding: 011F57225E00628002000003
Shop #: WSC 02312 785 00200
VCID: 3FDB4B7F177A5F639EB-806A
Part No SW: 4G0 909 144 L HW: 4G0 909 144 F
Component: RCEPS H32 0010
Revision: 00001000 Serial number: 0017038517
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D124BD4A8820B615-8066
Revision: 00002001 Serial number: 0143827375
Coding: 0126023A20FAF48580B00A80020100000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000022754
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Serial number: WOO1140392.
Coding: 001F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00000150370
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0027
Serial number: WA100924000000184133
01403 - Glass-Break Sensors; Rear
Reset counter: 156
Mileage: 200215 km
Date: 2023.07.08
Time: 17:04:47
Part No SW: 4G0 035 465 A HW: 4G0 035 465
Component: BO G3 C7 H07 0130
Revision: 05S00000 Serial number: 0011303
VCID: 2313E70F9BD21B839A3-8076
Subsystem 1 - Part No SW: 4G0 035 466 HW: 4G0 035 466
Component: BO C7 SLAVE H51 0100
Serial number: 01901110001571
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
Coding: 011F57225E00628002000002
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000042951
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0D0A2BFC78CACBD95-807E
461056 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FC_SIGNAL_GE_WAEHLHEBEL_ERROR_VALUE]
Reset counter: 196
Mileage: 200229 km
Date: 2023.07.08
Time: 17:37:49
Voltage terminal 30: 14.0 V
Internal Fault ID: 145
Vehicle speed: 82 km/h
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: Dynamic
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0012
Serial number: 110225-0004-019
Coding: 1223A6601002A400
ROD: EV_HeadlRegulBasic_AU21.rod
VCID: 2C010C33F68CD4FB2B9-8078
Component: Radio U SIRIU H51 0133
Revision: AB001007 Serial number: 156BT0B7501483
Coding: 020007010000000001
VCID: 2411E4139EDC1CBBE39-8070
Part No SW: 4G0 035 746 E HW: 4G0 035 746
Component: H-BNT-NA H48 0735
Revision: -------- Serial number: 031BK0B7502553
Coding: 090200040003EDEF75168B2E00000003100001000000000000
VCID: 290FF527F9FEC1D3D0F-807C
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1300CNMV
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 612 L
Component: E380 BDT C7 H08 0204
Serial number: 90349KBM0006B
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F17224000628002000002
VCID: 42DD428B6488328BF15-8016
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H04--- Serial number: 525 PA8J12F08F
Coding: 1020013
VCID: 2517F91799E6E5B3F47-8070
Part No SW: 4G8 959 107 E HW: 4G8 959 107 A
Component: HDSG-Modul H12 0036
Revision: 12012001 Serial number: 044100003
Coding: 0A3205C100
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: 372B235F3FCA672356B-8062
Component: TSG HR H03 0210
Address 82: Head Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G8 919 604 HW: 4G8 919 604
Component: HeadUpDisplay 023 0042
Coding: DA0000
ASAM Dataset: EV_HUDContiC7 001020
ROD: EV_HUDContiC7.rod
VCID: 70B9D8431A24F01B571-8024
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0026
Serial number: 0K84AE40026225
Coding: 1411
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: 313F1D47D1AEB91318F-8064
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H08 0007
Serial number: 00000000001101110919
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 6597B917D5E625B3347-8030
Part No SW: 4G0 907 541 HW: 4G0 907 541
Coding: 3601010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
ROD: EV_AdaptCruisContr2AU57X_001.rod
U1113 00 [008] - -
Reset counter: 196
Mileage: 200229 km
Date: 2023.07.08
Time: 17:37:50
Control Module temperature: 52 °C
Voltage terminal 15: 13.783 V
Velocity_vehicle_reference: 22.91 m/s
Longitudinal_acceleration_vehicle_reference: -0.14 m/s²
U1113 00 [008] - -
Reset counter: 196
Mileage: 200229 km
Date: 2023.07.08
Time: 17:37:49
Voltage terminal 15: 13.806 V
Velocity_vehicle_reference: 23.01 m/s
U1113 00 [008] - -
Reset counter: 196
Mileage: 200229 km
Date: 2023.07.08
Time: 17:37:49
Voltage terminal 15: 13.837 V
Velocity_vehicle_reference: 23.02 m/s
Longitudinal_acceleration_vehicle_reference: 0.12 m/s²
U1113 00 [008] - -
Reset counter: 196
Mileage: 200229 km
Date: 2023.07.08
Time: 17:37:49
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H28 0034
Serial number: 000040181702117
Coding: 038198180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 2517F9179566E5B3F47-8070
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FBBDB3F071AEFE34EB-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 03:04, VBatt start/end: 12.1V/12.1V)-----------
