- Nov 15, 2020
- 49
- 17
- Maryland, USA
- C?ID=417194
Car is a 2014 NMS Passat TDI SEL. I have looked around everywhere and cant find a definitive answer on this. I put LED headlights and foglights in my car and they work great but I kind of figured they would throw bulb warnings, and they do. Only at startup though. After starting, the warning goes away and everything works as it should, all the lights turn on and off like they should, throw no warnings, and the fogs even fade on and off like they should. I read that disabling an option called "Cold monitoring" for the bulbs will get rid of this startup check, but I cant seem to find it anywhere in my CECM. I know I can get a canbus adapter that should fix the issue, but I would like to solve it with coding if possible.
For the time being, I managed to turn off the headlight bulb warning by selecting Byte 14, Bit 4 in the CECM "Xenon Headlights (w/o shutter) installed". I believe this gets rid of the startup check based on the nature of xenon lights, and the LED headlights seem to work just fine with no issues at all with this selected.
I cant find any option like that for the foglights. If anyone knows a way to shut off the warning or trick the car into thinking everything is correct, please let me know. Here is a full auto scan if it is needed.
Tuesday,30,November,2021,17:24:08:05267
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: 1VWCN7A33EC035442 License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 75 77
VIN: 1VWCN7A33EC035442 Mileage: 75740km-47062miles
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H24 9982
Revision: 71H24--- Serial number: CVN: D240C61F38D3FF82
Coding: 001D0012042400008000
Shop #: WSC 09459 444 00000
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B233361B3E4E9E3B23-806E
VINID: 0669D37874430D54C00C51040803B054A7
Readiness: 0 0 0 1 1
Component: GSG DSG AG6 521 9437
Revision: 05652104 Serial number: 00001307220582
Shop #: WSC 09003 957 00200
VCID: 1471B8DDF27AC69B139-8040
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: C54BC0F5492500FFA30F03E8921B0042A71000
VCID: 7DA7FD79EDF027D3CC7-8028
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00086000 Serial number: 0194023358
Coding: 130C1C
VCID: 3431185D9EBA269B739-8060
Part No SW: 561 907 044 AB HW: 561 907 044 AB
Component: Climatronic H03 0505
Revision: 00001K01
Coding: 0038019012
VCID: 57EB8FD12F8C2D83B6B-8002
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0173
Revision: BL122001
Coding: EF200E3FEC2B2AD409880201360091C802F1A00045A015B064806800BC70
Shop #: WSC 04715 001 104857
VCID: 78A9EC6DC2D202FB9F1-802C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 010615 05 54 0403
Coding: 07300A
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM032WD0
Coding: 00004D4A
Shop #: WSC 44082 004 1048576
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 75B7E559D5407F93847-8020
Serial number: 6940000Y130000Y8L900
Coding: 303047
Serial number: 3572MSME24124176ZZZK
Serial number: 3582MSME0046207DZZZQ
Serial number: 3516KSME70073527ZZZK
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME0D532327ZZZP
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME570B3C27ZZZ+
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME370A3C27ZZZ$
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20130807300345
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DA7FD79ED7027D3CC7-8028
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 G HW: 561 920 970 G
Component: KOMBI H04 0811
Coding: 031C00
VCID: 1E65DAF500369CCBB5D-804A
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 13091303000858
Coding: 461000
VCID: 7BA3F361F3E429E3F23-802E
Component: IMMO H04 0811
Coding: 000007
VCID: 6A8DC6258CFEA06B195-803E
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000151648003
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3039144D6AA21ABB171-8064
Address 2E: Media Player 3
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0182
Revision: AA000000 Serial number: 00000073459481
Coding: 00581B0000000000000021010100202020202120202020
VCID: 221DEE0534CEB82B915-8076
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 Q HW: 3C0 035 684 J
Component: RNS-MID H21 5382
Revision: AB001001 Serial number: VWZ6Z7N3145019
Coding: 04090042010000A4000B
VCID: 313F1149612813B318F-8064
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V12 8534
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0007280237
Coding: 0405FD
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C61D0FD162A8EDB5B9-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14202630130913150408
Coding: 800000
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 290 3501
Revision: 00H22000
VCID: 392F2969B558DBF3A0F-806C
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0068833
ROD: EV_AudioVerst10KanalSTT3_VW36.rod
VCID: 2615F2155866440BFDD-8072
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 01030108
VCID: 6FBBD731B79C45434EB-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011314501622
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0007299225
Coding: 0405FC
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D67DDF90D3087D3AC7-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14102631130913172138
Coding: 800000
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0086
Serial number: 000003554140504
Coding: 02140102C2423A007F1606000000
ROD: EV_OCULow_001.rod
VCID: 53F37BC13B7401A34A3-8006
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
[roofline module open load]
Reset counter: 116
Mileage: 75745 km
Date: 2021.11.30
Time: 17:22:15
2103041 - Control Module
Fault Priority: 8
Reset counter: 116
Mileage: 75745 km
Date: 2021.11.30
Time: 17:22:15
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007665082982
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 2E050A3570960C4B05D-807A
End----------(Elapsed Time: 01:21, VBatt start/end: 12.3V/12.3V)-----------
