Hi
Could anybody help with new coding for 13 auto dist reg as I have fitted a trailer module to the vehicle.
I have tried checking the boxes on vcds coding but will not let me change it and no information on what they actually change.
Every other module has changed fine just this one !!!!
Workshop Code: 790 33361 000070
VIN: WAUZZZ8R9HA064786 License Plate:
Mileage: 102370km-63609mi Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 22 36 3C 42 44 46 47 52
53 56 5F 62 69 6C 6D 72 A9 AC C0
VIN: WAUZZZ8R9HA064786 Mileage: 102370km-63609miles
Address 01: Engine (J623-DEHA) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 589 C HW: 4G0 907 589 B
Component: 3.0BTD EDC17 H23 0008
Revision: 54H23---
Coding: 2A2A4032257603030000
Shop #: WSC 33361 790 00070
ASAM Dataset: EV_ECM30BTD0118K5907589C 001010
ROD: EV_ECM30BTD0118K5907589C.rod
VCID: 41897984D00445838C-8014
4330 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Fault Frequency: 15
Mileage: 102370 km
Date: 2021.03.27
Time: 13:49:21
Engine RPM: 697.00 /min
Normed load value: 26.7 %
Coolant temperature: 60 °C
Intake air temperature: 22 °C
Voltage terminal 30: 14.280 V
ACC specified acceleration: 0.007 m/s²
ACC control module: received status-Bits 0-7: 7
Active brake system error status-Bits 0-7: 1
Status of ACC/CCS acceleration interface-Bits 0-7: 4
Acceleration: 0.000 m/s²
Engine status: COENG_RUNNING
Part No SW: 8R0 927 158 BC HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H22 1006
Revision: --H22---
VCID: 7F0D3F7CE670F373BA-802A
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 BF HW: 8R0 907 379 BF
Component: ESP8 quattro H09 0020
Coding: 38DDCE01
VCID: 0501AD948CACA9A3F0-8050
Address 05: Acc/Start Auth. Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 KH HW: 8K0 907 064 KH
Component: BCM2 2.0 H15 BCM2 2.0 H15 07110711
Coding: 05B54040000000000000
Shop #: WSC 06335 000 00000
VCID: 000FBC80938E8C8BC3-8054
Subsystem 1 - Part No: 8K0 905 852 E
Component: J764 ELV MLB
No Faults Found
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K2 820 043 AQ HW: 8K2 820 043 AQ
Revision: D1000000 Serial number: 01260920160122
Coding: 3625028080
VCID: 78FFD460CB5EC44BFB-802C
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00001483113502
Coding: 260000108074AFE2218140C300001D0D0F9DE70827090201000008004400010200020034000000
VCID: 7AFBCE68F552D65B8D-802E
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 160920 H13 0050
Serial number: 90243015160913093431
Coding: 01DD13
Component: G397_RLFS H06 0004
Serial number: 62298957
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000002409160227
Subsystem 4 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 6 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: FFD88E4800PAG0MUFU03
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 A HW: 8R0 907 561 A
Component: ACC3 H11 0110
Coding: 008172
VCID: 377D175C86C00B3332-8062
Reset counter: 77
Mileage: 102370 km
Date: 2021.03.27
Time: 15:39:18
Temperature: 28.0°C
Voltage: 13.44 V
Hex Value: 0x005C
Lateral Accel.: 0.00 m/s^2
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H49 0610
Serial number: 003JPDD3E7DO
Coding: 30473531313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 489F64A0F33E74CB4B-801C
Serial number: 6334MSME5A6A4870N
Serial number: 6344MSME5A6A2574N
Serial number: 6352QSME3B751472H
Serial number: 6362QSME3B592348N
Serial number: 63732SME446E08585
Serial number: 63832SME516E494CC
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 90372PIS000BW
Coding: 00003F
VCID: 44877090C71650ABA7-8010
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 951 HW: 8R0 920 951
Component: KOMBIINSTR. H35 0567
Revision: 00300000 Serial number: 03I487N9H
Coding: 23A722008F012600010000
VCID: 74E7E050D736A02BD7-8020
00003 - Control Module
Fault Status: 01100101
Reset counter: 77
Mileage: 102370 km
Date: 2021.03.27
Time: 14:30:36
Part No SW: 8R0 907 468 AF HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0071
Revision: 1Z140033 Serial number: 3341Z1692307AC
Coding: 80CD07FF00
VCID: 0305B38C82989793DE-8056
Subsystem 1 - Part No SW: 80A 915 181 A HW: 80A 915 181 A
Component: J367-BDMHella H06 9070
Serial number: 9006971504
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Serial number: 16270001354021200410
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02022064747464545425363E00
VCID: 7CF7C870FF66E86B9F-8028
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H17 0100
Serial number: 002109160001019
VCID: 2F6D2F3C7690C3F36A-807A
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000219417666
Coding: 01781B00000000000000
VCID: 428B7688DD025E9B95-8016
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H07 0071
Serial number: 0417825601
Coding: 010312
Shop #: WSC 06334 000 00000
VCID: 3F8D7F7CA6F03373FA-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H07 0071
Serial number: 0417728931
Coding: 010312
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H03 0511
Revision: Serial number: 0000220071480
Coding: 011D12215E01440004
VCID: 4FAD4FBC1E50A3F30A-801A
Part No SW: 8R0 909 144 Q HW: 8R0 909 144 L
Component: RCevo H54 0702
Revision: 00000002 Serial number: 0000283859
Coding: 100000010001
ASAM Dataset: EV_RCEPSAU48X 104002
ROD: EV_RCEPSAU48X_104.rod
VCID: 46836A98F92A62BBB9-8012
Component: BCM2 2.0 H15 0711
Revision: 00002001 Serial number: 0417994786
Coding: 013B0E22A0B930958720053680040047
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H04 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H04 0090
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813063327410
VCID: 2D513534749CB1E358-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H03 0511
Revision: Serial number: 0000219883262
VCID: 4E9352B8195AAAFB01-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H03 0005
Revision: -------- Serial number: 00000001841895
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A7B0E68BDD2165BCD-806E
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109IU0G5000815
Coding: 010103010000000001
Part No SW: 8R2 035 670 M HW: 8R2 035 670 J
Component: H-BNT-EU H51 1036
Revision: -------- Serial number: 517IU0G2505013
Coding: 1A0101060205A9EF75808B5E00000403040000000000000000
VCID: 3E730278A9FA3A7BF1-806A
Subsystem 1 - Part No: 8R0 060 884 DP
Component: EUR 2016/2017 2302
Component: DU7 High H42 0104
Serial number: A130IR0G3633241
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000002608056
Component: CD-Database 6890
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H02 0510
Revision: Serial number: 0000219721622
Coding: 010C12204001240004
VCID: 46836A98F12A62BBB9-8012
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Towbar module H09 0100
Revision: 3A001001 Serial number: ÀÁ006789,,+''.
Coding: 0100000100000000
VCID: 36631A5881CAF23B29-8062
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H11--- Serial number: 525PA8-JB8A5AN
Coding: 1030010
VCID: 3467205057B6E02B17-8060
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D710574A4FC2163E8-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H02 0510
Revision: Serial number: 0000219713803
Part No SW: 8R0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0007
Serial number: 160820202622
VCID: 79F9D164F854DD4384-802C
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 162560623
ROD: EV_RDCMA00100.rod
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 8R0 907 160 A HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H10 0008
Serial number: 160902200646
ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS.rod
VCID: 326B264865A2EE1B05-8066
End-------------------------(Elapsed Time: 05:15)--------------------------
