- Dec 8, 2020
- 5
- 0
- Phila, PA, USA
- C?ID=427374
I came across the trailer maneuver assist on a forum for the Q8. I tried to follow to see if I can get it activated on the SQ7. Here was what I changed:
(forgive me for my amature approach here - I'm just getting back into this after getting rid of my last Audi in 2015 (back when this was still call VAG-com))
44 - coding - Byte 01 - Bit 2 - Trailer maneuver assist
46 - coding - Byte 04 - Bit 7 - Trailer monitoring
09 - coding - Byte 28 - Bit 7 - ARA installed
A5 - coding - Byte 15 - Bit 4 - FW_ARA_BCM, installed
A5 - coding - Byte 54 - Bit 6 - TMA_Trailer_maneuver_assist, installed
A5 - coding - Byte 54 - Bit 7 - TMA_Trailer_assist_image_processing, installed
5F - adaptations - ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant - not activated to activated
5F - adaptations - ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high - not activated to activated
5F - adaptations - ENG122227-ENG122315-Car_Function_List_BAP_Gen2-Trailer_assistant_0x36 - not activated to activated
5F - adaptations - ENG122227-ENG122315-Car_Function_List_BAP_Gen2-Trailer_assistant_msg_bus_0x36 - Klemme15 (but this was not an option on the SQ7 so I tried Terminal 15)
While the icon appeared on the MMI after the reboot, I was never able to activate it with a trailer attached. I decided return everything back to stock configuration, but now I have an engine fault (23755) with MIL on. While I would like to have the trailer assist I am now more concerned with the fault code. I have checked everything over multiple times to confirm that it is back to stock so I am now stuck with what my issue is. It seems the engine is looking to communicate with the Body Control Module (BCM) in central elect which I deactivated (A5 and 09) because from what I can tell was the way it was originally. As you can see based on the other fault codes (13, 17, A5) something is definitely not coded correctly.
This first scan is the current status with the MIL:
This scan is the original scan before making any changes:
Wednesday,23,December,2020,12:16:47:63796
VCDS Version: 20.12.0.1 (x64) HEX-NET2 CB: 0.4529.4
Chassis Type: F7-AU73 (4K0)
Scan: 01 02 03 06 09 13 15 16 17 19 36 3C 42 44 46 47 50 52 5F 69
6D 74 75 81 82 A5 A9 BA BB BC CA CB CF D6 D7 DB DC DE
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (------DCUE) Labels: None
Part No SW: 4M0 906 014 HW: 0P2 907 309 A
Component: V8 4.0l TFS H31 0004
Revision: 72H31000
Coding: 2A2A0012257E090E342C0000000000000000000000000000
Shop #: WSC 31414 033 00001
ASAM Dataset: EV_ECM40TFS0114M0906014 002004
ROD: EV_ECM40TFS0114M0906014.rod
VCID: 659CDBBB059E5563E04-8030
23755 - Body Control Module (Central Electric)
U0140 00 [175] - No Communications
Mileage: 10678 km
Date: 2020.12.22
Time: 17:55:54
Engine RPM: 0.00 /min
Coolant temperature: 49 °C
Intake air temperature: 28 °C
Voltage terminal 30: 11.380 V
selected gear-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 32
Readiness: 1000 0100
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 4M8 927 158 L HW: 0D6 927 156 J
Component: 0D6 40FSINAR H05 0002
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002016
ROD: EV_TCMALX52011_AU49.rod
VCID: 45DC3B3BA55E7563004-8010
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 4M6 907 379 AF HW: 4M6 907 379
Component: ESP9 Premium H06 0857
Coding: 2CAA629C30A20B9E93A15C93187D56E2E53A8934460CD0C93A186A47A75C91
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 0154EF2BF1F699437CC-8054
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M6 959 760 B HW: 4M6 959 760 B
Component: MEM-BFS 009 0044
Serial number: 00000406751369
Coding: 001410000000B0810060010101010000810000070700878700000000000000
Shop #: WSC 31414 043 00001
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
VCID: 3D2C53DBCD8E3DA3584-8068
Valve block 1 in front seat passenger side:
Subsystem 1 - Part No SW: 4N0 907 182 HW: 4N0 907 182
Component: N477 VB1 BFSv H04 0011
Serial number: SJ8001230220402581A4
Coding: BF2F00
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 4N0 907 063 KE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0691
Coding: 07000360C0291CDD070E57889CFF9C38130B37510406009B01050A001B33160108630A020010000000000303004308185802000044010104000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 016011
ROD: EV_BCM1BOSCHAU651_016.rod
VCID: 7BA89DC3931AF393260-802E
Subsystem 1 - Part No SW: 4M8 955 119 HW: 4N1 955 119
Component: J400FRWISCH 052 0997
Serial number: 904753F0301915902781
Coding: 7DC727
Serial number: 24424825X81A955555A0
Coding: 02005E
Subsystem 3 - Part No SW: 4K1 941 501 C HW: 4K1 941 501 C
Component: E1 - LTM H09 0086
Serial number: 14S04.03.2000690141
Subsystem 4 - Part No SW: 4N0 907 410 C HW: 4M0 907 410 A
Component: USHL5 GX1 H12 0300
Serial number: 0000009600373Z001Y02
Coding: 250000
Subsystem 5 - Part No SW: 4KE 857 511 B HW: 4KE 857 511
Component: Y7_Innenspieg H05 0003
Serial number: GX1NR113121923310951
Coding: 030000
Interior Light Module:
Subsystem 6 - Part No SW: 4M0 947 135 EC HW: 4M0 947 135 EC
Component: Dachmodul H42 0416
Serial number: Q00858923
Coding: 0D0305
Subsystem 7 - Part No SW: 80A 907 705 A HW: 80A 907 705
Component: J866-EVLS-SG H07 0200
Serial number: WA140175000077997502
Coding: 0A0100
Subsystem 8 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V512 LLR1SLvL H01 0012
Serial number: Q98BK05784608
Subsystem 9 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V514 LLR1SKvL H01 0012
Serial number: Q98BK05067154
Subsystem 10 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V516 LLR1SLvR H01 0012
Serial number: Q98BK05885387
Subsystem 11 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V518 LLR1SKvR H01 0012
Serial number: Q98BK05752029
67730 - Databus
[Missing message zFAS]
Reset counter: 128
Mileage: 10678 km
Date: 2020.12.22
Time: 17:45:13
average_Voltage_terminals: 11.50 V
Outside air temperature sensor-Outside air temperature on CAN: 11.00 °C
interior_temperature: 12.50 °C
Vehicle speed: 0.00 km/h
System run time-Engine running time: 65535 s
System run time-Terminal 15 on: 0 s
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4M0 907 561 M HW: 4K0 907 561
Component: LRR4R H04 0332
Coding: B6659F5C78082C00010320A10000003E4A1246484401009E05
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_AU73.rod
VCID: 3A2658C7DCA00A9B7D6-806E
2342 - Databus
[FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
Reset counter: 128
Mileage: 10678 km
Date: 2020.12.22
Time: 17:45:01
Control Module temperature: 30 °C
Voltage terminal 15: 11.4 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
Steering_angle-Data: 10.000 °
Yaw_rate-Data: 0.000 rad/s
adjustment_calculation: On
Misalignment angle: horiz: 0.031 °
Misalignment angle: horiz: fast algorithm: 0.106 °
Congestion pilot: status: OFF
Outside temperature: 11.00 °C
Sensor blindness: radar: no blindness detected
Address 15: Airbags (J234) Labels:* None
Part No SW: 4KE 959 655 A HW: 4KE 959 655 A
Component: AirbagVW32 H43 3122
Serial number: 003XQM00RAXP
Coding: AECCFCC000800000A0F0003FF20D410000C5
Shop #: WSC 31414 030 00001
ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
ROD: EV_AirbaVW31SMEAU65x.rod
VCID: 4CCA0E1F8634842BDFA-8018
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2050
Serial number: 4M0857705AD056U00816
Coding: 880020
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2050
Serial number: 4M0857706AD056U01397
Coding: 880020
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H12 0022
Serial number: IBH0000D19000CV3910$
Coding: 303235
Subsystem 4 - Part No SW: ----------- HW: 480 002 702 20
Serial number: 35700000000ED19C264X
Subsystem 5 - Part No SW: ----------- HW: 480 002 702 20
Serial number: 3580000000076435A64I
Subsystem 6 - Part No SW: ----------- HW: 480 032 402 20
Component: SideSensor_Dr 002 0149
Serial number: 351002C04C9D19E0DCD.
Subsystem 7 - Part No SW: ----------- HW: 480 032 402 20
Component: SideSensor_Pr 002 0149
Serial number: 352002C04E0081116DF1
Subsystem 8 - Part No SW: ----------- HW: 480 030 602 20
Component: FrontSensor_D 002 014A
Serial number: 355002C00FA8EE312C5P
Subsystem 9 - Part No SW: ----------- HW: 480 030 602 20
Component: FrontSensor_P 002 014A
Serial number: 356002C00FA0A9501989
Part No SW: 4N0 907 129 Q HW: 4N0 907 129 Q
Component: Lenks.Modul H03 0005
VCID: 3FD029D3C7822FB34A8-806A
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4K0 920 890 B HW: 4K0 920 890 B
Component: FBenUSAACC--- H12 0212
Coding: 8BCF80F77C88D7050283E56098806B0008003000
ROD: EV_DashBoardAU65X_001_AU73.rod
VCID: 2D0C639B1DEEAD23E84-8078
16776969 - Databus
[LDW_02 communication error can_error_timeout]
Reset counter: 128
16776971 - Databus
[Motor_04 communication error can_error_timeout]
Reset counter: 128
16777089 - Databus
[ACC_12 communication error can_error_timeout]
Reset counter: 128
Mileage: 10689 km
Date: 2020.12.23
Time: 10:59:50
Part No SW: 4K0 907 468 Q HW: 4K0 907 468 C
Component: Gateway H06 0272
Serial number: 1AF02135612101
Coding: 030100010000064054070000005B0132FC9A00001C0000000975078E10000000
ASAM Dataset: EV_Gatew31xAU65x 003190
ROD: EV_Gatew31xAU65x_AU73.rod
VCID: 42D62027B470425B256-8016
Subsystem 1 - Part No SW: 4M8 951 523 A HW: 4M8 951 523 A
Component: J453 MFL H07 0004
Serial number: 20200209230521 30122
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 3369344105
Component: MEM-FS 009 0044
Serial number: 00000406774094
Coding: 001C1A000000B0810003010101010000810000070700878700000000004000
Valve block 1 in front seat driver side:
Component: N475 VB1 FSv H04 0011
Serial number: SJ800123022040258201
Coding: BF2F00
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 H HW: 4N0 907 566 A
Component: MRR_HR H16 0267
Coding: 1FFC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651.rod
VCID: 3B285DC3D39A3393660-806E
Part No SW: 4M0 959 793 M HW: 4M0 959 793 J
Component: TSG FS 010 0384
Serial number: 0000406563407
Coding: 005D8B015200108000092032
VCID: 48C2320F924C680BFB2-801C
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Coding: B2000101000100
ROD: EV_EPSVWBSAU426_010.rod
VCID: 323670E704D0F2DBB56-8066
Part No SW: 8W1 907 064 AP HW: 8W1 907 064 P
Component: BCM2 MLBevo 044 0542
Coding: 01341E004FB100C0650BA0046C01D80203004000810426502F0400000F04803F001E0181010A11
ASAM Dataset: EV_BCM2HellaAU736 017017
ROD: EV_BCM2HellaAU736_017_AU73.rod
VCID: 0B48CD03C3BAC313160-805E
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY20030272Y
Subsystem 2 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000970311
Subsystem 3 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 14420800
left tail lamp 2:
Subsystem 4 - Part No SW: 4M0 945 429 A HW: 4M0 945 429 A
Component: SHL_li2 H08 0008
Serial number: 429A2001030000018888
Right rear tail lamp 2:
Subsystem 5 - Part No SW: 4M0 945 430 A HW: 4M0 945 430 A
Component: SHL_re2 H08 0008
Serial number: 430A2001220000020259
Part No SW: 4M0 035 223 D HW: 4M0 035 223
Component: MIB2_amp_PD H03 0470
Serial number: 00000000018377
Coding: 0175530A018AF02A5A0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
VCID: 241A86BF4E246C6B37A-8070
Address 50: Seat Adj. 3rd row (J857) Labels:* None
Part No SW: 4M1 959 760 G HW: 4M1 959 760 G
Component: MEM-SR3 008 0016
Serial number: 00000406049075
Coding: FF041020F1000000000F000000000900000021210900000000000000440000
Shop #: WSC 31414 054 00001
ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
Part No SW: 4M0 959 792 M HW: 4M0 959 792 J
Component: TSG BFS 010 0384
Serial number: 0000406208696
Coding: 005D8B015E00108000092030
VCID: 47C031339F526773F28-8012
Part No SW: 4K0 035 084 D HW: 4K0 035 084 A
Component: MU-H-LNS-US 056 2711
Coding: 0137560200000000C1220002061C00302F0001E403F008048E
ROD: EV_MUHigGen2pALPI_AU37.rod
VCID: 270091B33F128773128-8072
Subsystem 1 - Part No: V03 959 807 TD
Component: MIB2P_NA_Q220 0456
Multimedia System 1:
Subsystem 2 - Part No SW: 4M8 919 605 L HW: 4M8 919 605 F
Component: DU AU536 Top H32 0053
Serial number: INX00125111900151175
Compact disc data bank:
Component: Gracenote2 3008
Volume Control 1:
Subsystem 4 - Part No SW: 4N1 919 616 B HW: 4N1 919 616
Component: LSR-D5/C8 H33 0110
Serial number: 00004420000019275045
Multimedia System 5:
Subsystem 5 - Part No SW: 4N0 919 603 L HW: 4N0 919 603 F
Component: DU AU651 Bot H32 0053
Serial number: INX00123111900170960
Media socket:
Subsystem 6 - Part No SW: 4N0 035 726 A HW: 4N0 035 726
Component: MediaConnectL 014 0133
Serial number: 052000081805011
Address 69: Trailer (J345) Labels:* None
Part No SW: 8W0 907 383 A HW: 8W0 907 383
Component: Anhaenger H07 0040
Serial number: 000000000005429
Coding: 0200000200001100
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 3E2E54D7C08826BB41E-806A
Part No SW: 8W8 959 107 D HW: 8W8 959 107
Component: HDSG-Modul H13 0171
Revision: -------- Serial number: A2-C744-8781-2
Coding: 00B0
ROD: EV_DeckLidCONTIAU736_AU73.rod
VCID: 4AC608078C409A1BED6-801E
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 4M8 907 777 CA HW: 4M8 907 777 C
Component: Fahrwerk-SG H52 2135
Serial number: 0503200778
Coding: B8506848F842
ASAM Dataset: EV_ChassContrContiAU651 002016
ROD: EV_ChassContrContiAU651_002.rod
VCID: 0256E027F4F0825B656-8056
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130890804
Coding: 303030
Part No SW: 4K1 035 283 C HW: 4K1 035 283 B
Component: ConBox H09 0233
Serial number: 005CCA12F121353
Coding: 01C020FE4040800000
ROD: EV_ConBoxAU651_002.rod
VCID: 2802928F320C880B1B2-807C
458759 - Control Module Incorrectly Coded
U1014 00 [008] - -
[ECU_coded_wrong]
Reset counter: 128
Mileage: 8753 km
Date: 2020.10.27
Time: 08:17:28
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4N1 713 041 D HW: 4N1 713 041 C
Component: GSM-LL H10 0081
Revision: 0L0D5012 Serial number: 20011757900109
ASAM Dataset: EV_GSMWaehlZFAU736 001018
ROD: EV_GSMWaehlZFAU736.rod
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4M1 919 617 HW: 4M1 919 617
Component: HeadupDisplay H07 3910
Coding: 4F00E2
ASAM Dataset: EV_HeadUpDisplAU65X 001011
ROD: EV_HeadUpDisplAU65X_AU73.rod
VCID: 73B8B5E3BB4ABBD37E0-8026
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4KE 907 107 AR HW: 4N0 907 107 H
Component: zFAS Var C H09 0295
Coding: 020108000000000000FBD60000F0C70C139F5600000000000000000000969401019BA8000000000000000080000000000000000000000000F980400000000000000098D00080009000800080000000000080400000E0
ASAM Dataset: EV_ZFASAU516 001007
ROD: EV_ZFASAU516_001.rod
VCID: 0F70D913B7A2FF33FA8-805A
4170 - Coding invalid
U10DA 00 [008] - -
[Ungültige Codierung - kein ARA codiert]
Reset counter: 128
Mileage: 10678 km
Date: 2020.12.22
Time: 17:45:02
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 4M0 907 159 B HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0001
Serial number: 190627200894
Address BA: Motor Mounts (J931) Labels: None
Part No SW: 4M0 907 145 E HW: 4M0 907 145 B
Component: AEMevo H10 0132
ASAM Dataset: EV_AEMZFAU736 006014
ROD: EV_AEMZFAU736_006.rod
VCID: 30327AEF0ADCC0CBC32-8064
Part No SW: 4M0 959 795 M HW: 4M0 959 795 J
Component: TSG HFS 010 0384
Serial number: 0000405941556
Coding: 004D8B000000108040082020
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
Component: TSG HBFS 010 0384
Serial number: 0000405941694
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Part No SW: 4K0 907 594 AA HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 228000053602
ROD: EV_SunRoofCONTIAU736_009_AU37.rod
Address CB: Rear Axle Steering (J1019) Labels:* None
Part No SW: 4M0 909 145 AA HW: 4M0 909 145 E
Component: HAL_MLBevoH08 0698
Revision: -------- Serial number: CCC_098_B_1122_
Coding: 42242A00
ASAM Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010.rod
VCID: 6FB0B993D7629F339A8-803A
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H16 0267
Coding: 1FFC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651.rod
Part No SW: 4K0 941 592 AD HW: 4K0 941 592 A
Component: LMS_MLBevo H11 0040
ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
ROD: EV_LMSLeftHELLAAU58X.rod
VCID: 72B6B0E7C450B2DB756-8026
ASAM Dataset: EV_LMSRightHELLAAU58X 001015
Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
Part No SW: 4N0 907 669 H HW: 4N0 907 669 A
Component: MRR_VR H16 0267
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
ROD: EV_FrontCorneRadarS1AU651.rod
Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
Component: MRR_VL H16 0267
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
ROD: EV_FrontCorneRadarS2AU651.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
Part No SW: 4N0 035 502 B HW: 4N0 035 502 B
Component: WLC Front H14 0061
Coding: 800000
ROD: EV_Charg1MobilDevicAU651_004_AU37.rod
VCID: 231885A34B2A6B534E0-8076
End----(Elapsed Time: 02:26, VBatt start/end: 12.0V/12.0V. VIgn 11.8V)-----
Wednesday,09,December,2020,13:03:28:63796
6D 74 75 81 82 A5 A9 BA BC CA CB CF D6 D7 DB DC DE
Revision: 72H31000
Revision: --H05---
Coding: 100000
420352 - TPMS Warning; Front Left Tire
C1054 00 [175] - Pressure too Low
Mileage: 9997 km
Date: 2020.11.26
Time: 11:49:06
81 00 80 41 88 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
420096 - TPMS Warning; Rear Left Tire
C1058 00 [175] - Pressure too Low
Mileage: 9997 km
Date: 2020.11.26
Time: 11:49:06
417024 - TPMS Warning; Rear Right Tire
C105A 00 [175] - Pressure too Low
Mileage: 9997 km
Date: 2020.11.26
Time: 11:49:06
419328 - TPMS Warning; Front Right Tire
C1057 00 [040] - Flat
Mileage: 9306 km
Date: 2020.11.01
Time: 19:03:43
80 00 80 1E 89 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 08
Coding: BF2F00
Coding: 7DC727
Coding: 02005E
Coding: 250000
Coding: 030000
Coding: 0D0305
Coding: 0A0100
2342 - Databus
Reset counter: 80
Mileage: 9574 km
Date: 2020.11.11
Time: 17:12:18
Control Module temperature: 31 °C
Voltage terminal 15: 14.0 V
Vehicle speed: 24.10 m/s
Longitudinal acceleration: 0.25 m/s²
Adaptive distance regulation: status: ACC_reversible_error
Steering_angle-Data: 0.300 °
Yaw_rate-Data: -0.020 rad/s
Misalignment angle: horiz: -0.041 °
Misalignment angle: horiz: fast algorithm: 0.031 °
Outside temperature: 19.00 °C
Sensor blindness: radar: Blindness: limited scope via part absorption
1538 - Sensor for Automatic Distance Control
C110B F0 [008] - Limited Visibility
[FAULT_SENSOR_BLIND]
Reset counter: 80
Mileage: 9574 km
Date: 2020.11.11
Time: 17:12:17
Vehicle speed: 23.93 m/s
Longitudinal acceleration: 0.29 m/s²
Yaw_rate-Data: 0.022 rad/s
Misalignment angle: horiz: fast algorithm: 0.023 °
Coding: 880020
Coding: 880020
Coding: 303235
1065477 - Databus
[NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_MOD]
Fault Frequency: 14
Reset counter: 110
Mileage: 8772 km
Date: 2020.10.28
Time: 17:33:58
Coding: 8BCF80F77C88D7050283E16098806B0008003000
16777089 - Databus
Fault Frequency: 30
Reset counter: 110
Mileage: 8753 km
Date: 2020.10.27
Time: 11:50:23
131687 - Control Module for Emergency Call and Communications
U1421 00 [008] - No Communication
[Timeout_Node_0x67_DiagAdress_0075_ConBox]
Reset counter: 79
Mileage: 9627 km
Date: 2020.11.11
Time: 19:21:43
Coding: BF2F00
Coding: 1FFC00
left tail lamp 2:
Volume Control 1:
Media socket:
660234 - Bulb for Left Brake Light on Trailer
C10FA 15 [040] - Open or Short to Plus
Fault Frequency: 82
Reset counter: 24
Mileage: 9633 km
Date: 2020.11.12
Time: 15:59:36
85770 - Tail Lamp on Trailer
C10DB 15 [040] - Open or Short to Plus
Reset counter: 8
Mileage: 9633 km
Date: 2020.11.12
Time: 15:59:38
Coding: 00B0
Coding: 303030
U1014 00 [008] - -
[ECU_coded_wrong]
Reset counter: 111
Mileage: 8753 km
Date: 2020.10.27
Time: 08:17:28
Coding: 4700E0
4107 - Databus
[reversibler_Fehler_im_ACC_System]
Reset counter: 80
Mileage: 9574 km
Date: 2020.11.11
Time: 17:12:18
65540 - Following-Distance Warning (High)
C12DA F0 [008] - Status Feedback for HMI Implausible
Reset counter: 80
Mileage: 9575 km
Date: 2020.11.11
Time: 17:12:23
Profile master status distance warning high-Nominal status: OFF
Profile master status distance warning high-Actual status:: Malfunction
Coding: 42242A00
Coding: 1FFC00
Coding: 003000
Coding: 003000
Coding: 800000
End----------(Elapsed Time: 02:23, VBatt start/end: 15.1V/15.2V)-----------
