Hi im new here and got a problem with park-assist
Wader
C?ID=235771
Hi all
First i will present my self my name is Lars and im from Denmark.
A couple of month ago i brought my dream car, a brand new golf.
And a ovner of a vcd-usb that im trying to learn how to use.
My car is a Golf 7 1.4 tsi, dsg7, 5 doors, 140hk, Highline
Discover media navigation
Reverse cam.
Adaptiv speedpilot, sleep reg., front assist
park sensorer front and back
I have brought a VW Golf 7 5G0 - Park Assist - PLA - UPGRADE SET at carsystems.pl, but I can´t get it to Work. It must be something i do wrong whit the coding. but i don´t know what.
I hope somebody can help me here, because there are nobody in littel Denmark.
The code guide from carsystems :
19 CAN Gateway - Installation List - 10 Park/Steer Assist
5F Infotainment - Adaptation - set all to active
Vehicle function list BAP-parking_assist_0x0A
Vehicle menu operation-menu_display_pdc
Vehicle menu operation-menu_display_pdc_over_threshold_high
And now my log says after :
Control unit  17: Instrument (J285)	Forklaringsfil: NEZ\5G0-920-XXX-17.clb
   Styreenhedsnr: SW: 5G1 920 750	HW: 5G1 920 750
   Komponent  : KOMBI	304 4270
   Kodning	: 07A419082780000800886A011400000000000000
   Forhandler    : WSC 01357 011 00200
   ASAM datasæt: EV_DashBoardVDDMQBAB 009037
   VCID: 64C79ACF6F380C01EB2-8031
2 fejlkoder fundet:
13636608 - control unit not coded right
	  U1014 00 [009] - -
	  Bekræftet - Testet siden sletning af hukommelse
Fryseramme:
	    Fejl status  : 00000001
	    Fejlprioritet: 2
	    Fejlhyppighed: 2
	    Nulstiltæller: 175
	    Kørestrækning: 2891 km
	    Dato: 2015.02.13
	    Tid: 16:05:57
15361024 - Komponent protection
	  U1101 00 [008] - Aktiv
	  Periodisk - Bekræftet - Testet siden sletning af hukommelse
Fryseramme:
	    Fejlprioritet: 4
	    Fejlhyppighed: 1
	    Nulstiltæller: 215
	    Dato: 2015.02.13
	    Tid: 16:17:
Tank you i advance
Lars
Mari
C?ID=150535
Allways make a scan before you change coding (and post the scan here!)
I noticed "Komponent protection"... seems you have added/swapped a part of the car that has component-protection. This part will not work untill the dealer has removed the component protection of this part!
As fas as I know this is not possible with VCDS!
Nicoleise
C?ID=208110
Hi all
2 fejlkoder fundet:
	  U1014 00 [009] - -
Fryseramme:
	    Fejlprioritet: 2
	    Fejlhyppighed: 2
	    Nulstiltæller: 175
	    Dato: 2015.02.13
	    Tid: 16:05:57
Fryseramme:
	    Fejlprioritet: 4
	    Fejlhyppighed: 1
	    Nulstiltæller: 215
	    Dato: 2015.02.13
	    Tid: 16:17:
Tank you i advance
Lars
Hej Lars!
I'm not sure about no one being able to help you in Denmark. :)
Please see below though. I will translate the information from your scan, so that more people may be able to assist, and also comment further on (atleast what I know) your errors. If you need anything translated to Danish, feel free to send me a PM - I'll write in English since this is an English forum, so it'd be rude to reply in Danish.
Many regards,
Nicolai
The component protection is listed under Adr. 17 Instrument Cluster, which it would not make sense to exchange for the retrofit in question. I'm unsure, but I think the protection is activated due to incorrect coding as a result of changing something else in the car.
If I understand correctly, the kit in question is the following:
Scope of delivery :
1x Wirings
1x Control unit 5Q0919298B
1x Button
4x Sensors 1T0919297A
4x Holders
Electric diagram
We dont provide coding manual for this product !
http://www.carsystems.pl/vw-golf-7-park-assist-pla-1t0919297a-upgrade,id667.html
The fault codes in the scan (if the scan is written correctly of course) are stored not in the CAN gateway (19) or the Park Assist (10), but the instrument cluster. The fault codes state, that the instrument cluster has not been coded correctly, and that (perhaps for that reason) component protection is activated. In the scope of delivery is no new instrument cluster, and there is no reason why it should be there either.
I don't see why you should need to code your instrument cluster to achieve this retrofit - I didn't need to atleast. But the incorrect coding can arise from you changing other things in the car as well, meaning that modules the instrument cluster expects to "hear from", no longer "talks".
The coding manual you followed states:
-> 19 CAN Gateway - Installation List - 10 Park/Steer Assist
-> 5F Infotainment - Adaptation - set all to active
-> Vehicle function list BAP-parking_assist_0x0A
-> Vehicle menu operation-menu_display_pdc
-> Vehicle menu operation-menu_display_pdc_over_threshold_high
You also mention, that your car already had parking sensors front and rear (if I understand correctly) before the upgrade. If you followed the guide to the letter, then a potential error could be, if you disabled the Control Module for the Park Assist, since it was already present in your car. CarSystems.pl should know this, since they sell an "upgrade" kit that expects you to have PDC front and rear, but the manual you inserted doesn't seem to show that they do.
Therefore, I think we should make sure, that you didn't accidentially disable the module in the CAN Gateway Installation List, and that this is causing all the problems;
  1. Open VCDS, connect your cable to your car, ignition on
  2. Press Control Modules
  3. Press 19 - CAN Gateway
  4. Press Installation List
  5. Locate "10 - Park/Steer Assist" and make sure the box is ticked/enabled
  6. Press Save Config
  7. Wait 10 seconds
  8. Press Fault Codes, and ensure that there are no communication errors
  9. Press Go Back
  10. Press Close Controller - Go Back
  11. Go back to the main menu of VCDS
  12. Go forward again into the Control Modules menu, to find module 10 - Park/Steer Assist now under Installed tab
  13. Enter this module
  14. Press Coding
  15. Press Long Coding Helper
  16. Review the Coding to make sure it's correct - especially that your vehicle model is correct
  17. Also; check that option to display reverse camera is enabled, but do not enable options for "Rear View Camera (Low) Installed" since yours must be a high model
  18. Press Exit
  19. Press Do It!
  20. Wait 10 seconds
  21. View Fault Codes
  22. Press Go Back
  23. Press Close Controller - Go back
  24. Press 17 - Instrument Cluster
  25. Press Fault Codes
  26. Press Clear Codes
  27. Press Go Back
  28. Wait 10 seconds
  29. Press Fault Codes again, and see if component protection and incorrect coding is solved
  30. If not; Go back, Close Controller - Go back, Go back and then AutoScan, Start, and upon completion save the entire scan and upload it here in your reply.
Furthermore, while it isn't mentioned in the guide, and I'm not entirely sure about a Golf 7, you often need to enter 44 - Steering Assist, Adaptation and select Documented Channels, PLA Installation, and in your case select to adapt the channel to PLA 2.0 Installed.
The reason I ask you to do all this is, that the first step in the guide should be unnessacary for anyone buying that kit, and I'm not able to properly assess your skills with VCDS through a simple forum post. If this is all basics to you, then please excuse me and post a full autoscan with your reply, so we may be able to find a more advanced solution. I stress that I'm not trying to talk down to you, but basics first. :) Another thing that puzzles me about the guide is the phrase "Set all to active" - that also raises an alarm in my head.
If the component protection of your instrument cluster persists, you may have to go to a dealership to have it cleared/removed, as it requires online connection to Volkswagens diagnostic systems. It could be though, that it will simply resolve itself after the other errors have been fixed, so I would wait with spending those dollars.
You can also clarify to us if you did or did not recode your instrument cluster? And maybe describe in steps what you did, if the above solution doesn't work.
I hope my reply helps you - best of luck,
Nicolai
DV52
C?ID=194404
Nicholeise: Wow - that's a very impressive post ^^^^^! I've just had a look at the wiring diagram for park assist on a mk7 and you are entirely correct. The park assist control module (J791) is largely self contained. The only interface that J791 has with other control modules is a couple of wires into Data bus diagnostic interface (J533), and a single wire from the BCM that supplies power to the switch module on the centre console-EX30 (J791 receives signals from this switch module). I couldn't find any direct connections to the control module for the instrument cluster albeit there may be an indirect route via J533 (since the instrument cluster is also wired to J533). Interesting to see this how this problem unfolds!
Nicoleise
C?ID=208110
[...]The park assist control module (J791) is largely self contained. The only interface that J791 has with other control modules is a couple of wires into Data bus diagnostic interface (J533), and a single wire from the BCM that supplies power to the switch module on the centre console-EX30 (J791 receives signals from this switch module). I couldn't find any direct connections to the control module for the instrument cluster albeit there may be an indirect route via J533 (since the instrument cluster is also wired to J533).[...]
Hi DV52,
I'm not sure I would call the module self contained, since the two wires to J533 (CAN Gateway) that you're refering to, are CAN bus wires connected to the CAN Drive Bus (the bus between steering-, braking- and engine components). This is how the control module achieves the whole "automatic parking" - by transmitting over the CAN bus to the Steering Assist module, which then actuates the turning of the steering wheel, and of course using information from the ABS controller to determine speed, distance and soforth. It also "talks" to the instrument cluster (17) via CAN bus, as it displays directions in the MFA.
The control module itself consists of three plugs; a harness for the front sensors (up to six sensors) and a harness for the rear sensors (also up to six sensors). The last plug is for the "system harness" which has the CAN connections, as well as power for the control module, signal wires from the switch(es) and outputs to the in-switch indication lights. It communicates as follows;
- Each parking sensor shares a common plus and ground, and returns an individual signal wire, that carries a PWM signal to the control unit.
- The switch(es) are hardwired directly to the module - the switch gets it's ground and cabin dimmed instrumentation light supply plus from the CCM along with a ground connection, the rest goes to the control module.
- All other communication (Instrument Cluster, Radio/Nav (for optical parking system), ABS and steering assist) is carried out over the CAN Gateway (19/J533)
When coding the device, you tell it which vehicle it is installed into, and that determines things like if it recieves one switch wire (e.g. Passat 3C) or two switch wires (e.g. Golf), what the vehicle lenght is, which messages to expect from ABS controller, how sharp the vehicle can (and need to) turn, in order to enter a parking space.
There are three versions; PLA (Park Lenkrad Assistant - Park Steering Assistent) 1.0, which is only capable of reverse parallel parking in one movement, the driver has to finish the parking, and it requires a rather long bay. 1.5, which is still only capable of reverse parallel parking, but can do so in several movements and thus making it possible to enter much shorter parking spaces - my Passat for instance, can easily park in a bay just 0,8 meters longer than the car. Both of these versions utilize 6 sensors front, 4 sensors rear - the two "extra" sensors front are mounted perpendicular to the direction of travel (makes sense?) and are used like normal parking sensors, but also to scan to the side. When you activate the function, the sensor at the side you are indicating to (turn signal) scans the distance - long distance = parking space, short distance = car/obstacle. Combining this with the ABS information allows the car to calculate the lenght of the bay, and determine if it can fit. When you engage reverse, the car will also know how long it has travelled since the bay ended, and thus knows when to steer into the parking space. PLA2.0 (as in this thread) contains six sensors front and rear, and is able to do everything PLA1.5 can, but with the addition of being able to park in "normal" perpendicular parking bays like you'd find at a mall. It uses the rear two side-sensors to center itself between the other vehicles - and this is the reason PLA1.5 can't park like that; it would only know if it parked correctly or if it hit something, when it was done parking and the front sensors would be inside the bay.
Due to some differences in the ABS telegrams, the PLA1.5 and 2.0 are not nessacarely compatible into the same vehicle, as there are requirements to the ABS controller. As such, for instance a Passat 3C can go no higher than PLA1.5 without replacing the ABS controller, but of course in this case, it's a brand new car, so it has an ABS controller than supports PLA2.0, which is also confirmed by the number of sensors in the kit. :)
It's a brilliant piece of kit here in Europe, where I live, and has already impressed me alot. It's a bit spooky to see the car just starting to steer on its own, but hey. With the PLA 1.5 and the rear view camera installed, a car like the Passat feels very parkable despite being almost 5 meters long. I wouldn't even begin to try and market this in the US though, atleast in my three vacations there I've never seen anything even resembling a small parking space, but on the other hand I'm sure it might as well come standard in the UK, since there isn't really much generousity about neither road width nor parking bay sizes there. :)
I hope the reply enlightened you a bit on the functionality of the device. :)
Many regards,
Nicolai
DV52
C?ID=194404
Many regards,
Nicolai
Nicolai: My enlightenment is almost spiritual- LOL !! Seriously, many thanks for the explanation.
I wouldn't even begin to try and market this in the US though, at least in my three vacations there I've never seen anything even resembling a small parking space
That's because so many Americans need space to park their Ferd Fteenthousand. :D
Wader
C?ID=235771
Hello everyone
I've been on vacation and had no opportunity to respond .
But where I am now, the car can do everything , both in display and try to park .
But it just can not hit the free parking area .
I can not figure out what is wrong . I would be happy if there are some that have any ideas for what might be wrong.
I have attached the latest log.
sincerely,
Lars
Torsdag,26,Februar,2015,00:52:58:25523
VCDS -- Windows baseret VAG/VAS emulator
VCDS version: NEZ 14.10.0.1
Dataversion: 20141124
Firma: +45 24272469
Stelnummer: WVWZZZAUZFW077610   Indreg.nr.:
Kørestrækning: 3365km   Reparationsordre:
Modeltype: AU (5Q0)
Søgt på: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
Stelnummer: WVWZZZAUZFW077610   Kørestrækning: 3365km
01-Motor -- Status: Ok 0000
02-Automatik -- Status: Ok 0000
03-ABS bremser -- Status: Ok 0000
08-Klimaanlæg -- Status: Ok 0000
09-Centralelektrik -- Status: Ok 0000
10-Park.assist. -- Status: Ok 0000
13-Afstandsreg. I -- Status: Ok 0000
15-Airbags -- Status: Ok 0000
16-Ratelektronik -- Status: Ok 0000
17-Instrument -- Status: Ok 0000
19-CAN Gateway -- Status: Ok 0000
42-Dørelektr. V for -- Status: Ok 0000
44-Servostyring -- Status: Ok 0000
52-Dørelektr. H for -- Status: Ok 0000
5F-Informationselek. -- Status: Ok 0000
Styreenhed  01: Motor (J623-CHPA)     Forklaringsfil: NEZ\04E-907-309-V1.clb
   Styreenhedsnr: SW: 04E 906 016 G    HW: 04E 907 309 A
   Komponent	: 1,4l R4 TSI   H09 7615
   Revision: WAH09---
   Kodning	: 01250032246405082000
   ASAM datasæt: EV_ECM14TFS01104E906016G 002010
   ROD: EV_ECM14TFS01104E906016G.rod
   VCID: 2643C0C75984BE11356-8073
Ingen fejlkoder fundet.
Styreenhed  02: Automatik (J743)     Forklaringsfil: NEZ\0CW-927-769.clb
   Styreenhedsnr: SW: 0CW 300 047 T    HW: 0AM 927 769 K
   Komponent	: GSG DQ200-MQB H43 5201
   Revision: 00043014    Serienummer: CU501407127334
   Kodning	: 0014
   ASAM datasæt: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_SE26.rod
   VCID: 4C97526FE7A8A441C32-8019
Styreenhed  03: ABS bremser (J104)     Forklaringsfil: NEZ\5Q0-907-379.clb
   Styreenhedsnr: SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Komponent	: ESC           H31 0571
   Revision: 00000000    Serienummer: 62064000000319
   Kodning	: 01FA6AA124271173037D060141C32980562488C0608294F3F822507AC202
   ASAM datasæt: EV_Brake1UDSContiMK100IPB 033001
   ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
   VCID: 46836047F9C45E11156-8013
Styreenhed  08: Klimaanlæg (J255)     Forklaringsfil: NEZ\5G0-907-044.clb
   Styreenhedsnr: SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Komponent	: Climatronic   H03 0907
   Revision: 00001K08
   Kodning	: 00020004200100011005000000101000
   ASAM datasæt: EV_ACClimaBHBVW37X 003018
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 73E5E993DAD69BB9628-8026
Styreenhed  09: Centralelektrik (J519)     Forklaringsfil: NEZ\5Q0-937-08X-HV1.clb
   Styreenhedsnr: SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Komponent	: BCM MQBAB H   H18 0134
   Serienummer: 01011421104567
   Kodning	: 00001846C24102FB4BE44000001C07081000000000000000000000000000
   ASAM datasæt: EV_BCMCONTI 013000
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 000FB65F9B60B0216FA-8055
   Undersystem 1 - Styreenhedsnr: SW: 5G1 955 119 A    HW: 5G1 955 119 A
   Komponent	: WWS    140718  043 0551
   Serienummer:         140724001440
   Kodning	: 0E4DDD
   Undersystem 2 - Styreenhedsnr: SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Forklaringsfil: NEZ\5Q0-955-547.CLB
   Komponent	: RLHS  037 0059
   Serienummer: S5Y14M08D05H06M24S19
   Kodning	: 00A8DD
Styreenhed  10: Park.assist. (J791)     Forklaringsfil: NEZ\5Q0-919-298.clb
   Styreenhedsnr: SW: 5Q0 919 298     HW: 5Q0 919 298
   Komponent	: PARKHILFE PLA H09 0008
   Revision: --------    Serienummer: --------------
   Kodning	: 0031161851
   Forhandler	: WSC 00028 028 00025
   ASAM datasæt: EV_EPHVA2CAU3700000 003006
   ROD: EV_EPHVA2CAU3700000_AU37.rod
   VCID: 7CF7C2AFF788D4C1332-8029
Styreenhed  13: Afstandsreg. I (J428)     Forklaringsfil: NEZ\5Q0-907-572.clb
   Styreenhedsnr: SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Komponent	: ACC Bosch MQB H05 0304
   Serienummer: 31071476510648
   Kodning	: 001C1100FE0739
   ASAM datasæt: EV_ACCMRRBoschVW372 001015
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 387F1EBF833038E197A-806D
Styreenhed  15: Airbags (J234)     Forklaringsfil: NEZ\5Q0-959-655.clb
   Styreenhedsnr: SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Komponent	: AirbagVW20    014 0386
   Serienummer: 003MLR07K6CW
   Kodning	: 98CCC000000000005C0000CF004800000065
   ASAM datasæt: EV_AirbaVW20SMEVW37X 002130
   VCID: 7F0D35A3E69ECFD9160-802A
   Selestrammer i venstre side:
   Undersystem 1 - Styreenhedsnr: SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Komponent	: BeltPretRevFL  H35 0341
   Serienummer: 34169667B04081450908
   Kodning	: 333135
   Selestrammer i højre side:
   Undersystem 2 - Styreenhedsnr: SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Komponent	: BeltPretRevFR  H35 0341
   Serienummer: 34169668B05081440628
   Kodning	: 333135
   Crashsensor til sideairbag i førerside:
   Undersystem 3 - Styreenhedsnr: SW: -----------    HW: 480 003 007 14
   Komponent	: SideSensor_Df  001 0887
   Serienummer: 35767000000604E8901R
   Kodning	: 2D2D2D
   Crashsensor til sideairbag i passagerside:
   Undersystem 4 - Styreenhedsnr: SW: -----------    HW: 480 000 308 14
   Komponent	: SideSensor_Pf  001 0887
   Serienummer: 3586700000080D64901R
   Kodning	: 2D2D2D
   Crashsensor til sideairbag bagi i førerside:
   Undersystem 5 - Styreenhedsnr: SW: -----------    HW: 480 402 807 14
   Komponent	: SideSensor_Dr  001 6149
   Serienummer: 3516502B51656B92E017
   Kodning	: 2D2D2D
   Crashsensor til sideairbag bagi i passagerside:
   Undersystem 6 - Styreenhedsnr: SW: -----------    HW: 480 402 807 14
   Komponent	: SideSensor_Pr  001 6149
   Serienummer: 3526502B11656901E31
   Kodning	: 2D2D2D
   Crashsensor til frontairbag i førerside:
   Undersystem 7 - Styreenhedsnr: SW: -----------    HW: 480 400 508 14
   Komponent	: FrontSensor_D  001 6149
   Serienummer: 3556502BD16DB800D2EW
   Kodning	: 2D2D2D
Styreenhed  16: Ratelektronik (J527)     Forklaringsfil: NEZ\5Q0-953-549.clb
   Styreenhedsnr: SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Komponent	: Lenks. Modul  002 0110
   Revision: --------    Serienummer: 03081404400482
   Kodning	: 0C10
   ASAM datasæt: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 7BF5C1B3F286D3F93A8-802E
Styreenhed  17: Instrument (J285)     Forklaringsfil: NEZ\5G0-920-XXX-17.clb
   Kodning	: 07A419082790000800886A011400000000000000
Styreenhed  19: CAN Gateway (J533)     Forklaringsfil: NEZ\5Q0-907-530-V1.clb
   Styreenhedsnr: SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Komponent	: GW MQB High   128 1188
   Revision: --------    Serienummer: 0002316760
   Kodning	: 030100342B085700EF00025C1C0F00010001050000000000000000000000
   ASAM datasæt: EV_GatewLear 011016
   ROD: EV_GatewLear.rod
   VCID: 428B7C57D5EC623139E-8017
   Generator:
   Styreenhed til multifunktionsenhed:
   Undersystem 2 - Styreenhedsnr: SW: 5G0 959 442 K    HW: 5G0 959 442 K
   Komponent	: E221__MFL-DC1  H16 0038
   Serienummer: 27140001860060054306
   Kodning	: 2CFFFF
   Styreenhed til batteriovervågning:
   Undersystem 3 - Styreenhedsnr: SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Komponent	: J367-BDMHella  H03 8043
   Serienummer: 2547304003
Styreenhed  42: Dørelektr. V for (J386)     Forklaringsfil: NEZ\5QX-959-X93-42.clb
   Styreenhedsnr: SW: 5Q0 959 593 B    HW: 5Q0 959 593 B
   Komponent	: TSG FS        020 0025
   Serienummer: 18071401101731
   Kodning	: 003B0320D000048000001000
   ASAM datasæt: EV_DCUDriveSideEWMAXKLO 006003
   VCID: 408F765FDBE070212FA-8015
   Undersystem 1 - Styreenhedsnr: SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Komponent	: FOND_FHSG_DRV  005 0005
   Serienummer: 00000000000003428349
   Kodning	: 010000
Styreenhed  44: Servostyring (J500)     Forklaringsfil: NEZ\5Q0-909-144.clb
   Styreenhedsnr: SW: 5Q0 909 144 P    HW: 5Q0 909 144 P
   Komponent	: EPS_MQB_ZFLS  123 1043
   Kodning	: 0303
   ASAM datasæt: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB_SE37.rod
   VCID: 4189735BD0EA7929204-8014
Styreenhed  52: Dørelektr. H for (J387)     Forklaringsfil: NEZ\5QX-959-X92-52.clb
   Styreenhedsnr: SW: 5Q0 959 592 B    HW: 5Q0 959 592 B
   Komponent	: TSG BFS       020 0025
   Serienummer: 22071406070031
   Kodning	: 003B0120DE00048000801000
   ASAM datasæt: EV_DCUPasseSideEWMAXKLO 006003
   VCID: 3F8D75A3A61E0FD9560-806A
   Undersystem 1 - Styreenhedsnr: SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Komponent	: FOND_FHSG_PSG  005 0005
   Serienummer: 00000000000003444840
   Kodning	: 190000
Styreenhed  5F: Informationselek. (J794)     Forklaringsfil: Ingen
   Styreenhedsnr: SW: 5G0 035 846 A    HW: 5G0 035 846 A
   Komponent	: MU-S-N-ER     041 0430
   Serienummer: V1F00208143701
   Kodning	: 02730001FF00000011110001000800001F0100940100010045
   ASAM datasæt: EV_MUStd4CPASE 002039
   ROD: EV_MUStd4CPASE_SE37.rod
   VCID: 275DCDC35E8EA7190E0-8072
   Medieplayer 1:
   Undersystem 1 - Styreenhedsnr: SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Komponent	: ABT_Std_Nav  H60 0030
   Serienummer: VWZ8Z9PS402TPD
   Motorelektronik 2:
   Undersystem 2 - Styreenhedsnr: SW: 5G0 919 866 N    HW: -----------
   Komponent	:  ECE 2014/15  --- 0040
   Serienummer: --------------------
4 fejlkoder fundet:
0513 - Diskanthøjttaler
          B1068 13 [009] - Bagi i højre side
             Fryseramme:
                    Fejlprioritet: 6
                    Fejlhyppighed: 1
                    Nulstiltæller: 197
                    Kørestrækning: 3365 km
                    Dato: 2015.02.26
                    Tid: 00:53:01
0518 - Diskanthøjttaler
          B1064 13 [009] - Foran i højre side
             Fryseramme:
                    Fejlprioritet: 6
                    Fejlhyppighed: 1
                    Nulstiltæller: 197
                    Dato: 2015.02.26
                    Tid: 00:53:01
0523 - Diskanthøjttaler
          B1061 13 [009] - Foran i venstre side
             Fryseramme:
                    Fejlprioritet: 6
                    Fejlhyppighed: 1
                    Nulstiltæller: 197
                    Dato: 2015.02.26
                    Tid: 00:53:01
0528 - Diskanthøjttaler
          B1066 13 [009] - Bagi i venstre side
             Fryseramme:
                    Fejlprioritet: 6
                    Fejlhyppighed: 1
                    Nulstiltæller: 197
                    Dato: 2015.02.26
                    Tid: 00:53:01
Slutning----------------------(Forløbet tid: 03:56)------------------------
lala30
Croatia
C?ID=71949
hello
you need to change rear ABS sensors
then you need to coding addrese 01,03,09,10,17,19,44 and 5F
NEtech
C?ID=56995
For this model ABS sensors should be okay.
All ECU's are coded.
There was a problem with cable connections.
It is working now.
lala30
Croatia
C?ID=71949
i need help
i retrofit on Audi A3 8v PLA 2.0
and change rear ABS sensor!
now i need good coding for this new ABS sensor and for PLA.
rest I good coding
adresse 17,19,44 and 5F
i think is coding for new ABS sensor is byte 26 value 50( bit 4&6 mark) but I am not sure can any confirmed?
coding for PLA i think byte 24 but i don't know which is value correct
my ABS coding before install PLA 2.0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 62474000001935
Coding: 13F162A224260A6D0180060641CA25C8462450806082A4F2004100788608
Shop #: WSC 06385 790 00016
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 45818F94C4966E091CD-8010
chris2011
Austria
C?ID=79962
I have the same problem like Wader cant code parkassist ecu. All codings invalid i also enter login code.
Golf 7 2015
martinlop
Argentina
C?ID=303160
i need help
rest I good coding
Hi my Friend from Croatia! (Once upon a while met a lovely girl from there - nice memories!)...
Anyway back to businesss... take a look at http://forums.ross-tech.com/showthr...st-(J791)-gt-Coding-Rejected-Error-31-Request
Apparently this user did it ;)
