Sticky MQB Light Configuration Case Study
Sticky
   #41
@marttimat:
Here's an interesting thing for you to try : I'm not sure what web browser you use, but whatever it is -invoke the find facility and search for the term "Brake" within the Leuchte-sets in your admap.
I can see in your admap that you have implemented the changes that you describe in post #39 (the "adjustments"). However, the ONLY instance of the Leuchte-command "Brake" (Lamp) in the entire 665 x Leuchte channels is ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 - which is the high-level Brake light. This means that none of the Leuchte-sets in the tail lights is currently programmed to operate as a Brake-light - which is most interesting!!
Now, I've never seen an instance of an active physical car that has Leuchte-sets with no Brake light function (albeit I've generated this bizzar outcome on my MQB test bench). Intuitively, I would have expected that the Brake lights would not work at all (not even with a Brake pedal push). But, I am aware from my test bench scenarios, that the brake lights are intimately tied to the ECU and they operate when aspects of the hex01 module are missing. My hypothesis (guess really) is that this "special" brake relationship is an inherent safety feature of MQB platform vehicles - which (if correct) helps to explain why your brake lights work on pedal push - because they shouldn't work from a Leuchte-command perspective!!
So, why has this happened and what to do? Well... more than happy to be corrected if anyone has an alternate view, but I suspect that the instructions in your post #39 do not apply to the factory settings in your BCM.
As a way forward, it might be useful to post-up yet anther item of information; the history records that contain the "old" values of the channels that you changed as per the instructions in post #39. You will find these records in the file called AdpLog.CSV which lives in the directory C:\Ross-Tech\Debug. Perhaps place a copy of this file on a third party hosting site and include a link here.
marttimat
CT | USA
C?ID=305745
@marttimat:
You are indeed correct Don and I am slowly starting to understand the Leuchte functions that you all have described in this thread (referring to wire / connector pins vs general function outputs). Below is my original map for reference and you will see for NAR, turn signal and brake being activated together (as designed). It is beginning to look more and more like additional wiring would be needed to get 09 to automatically activate the brake lights as designed for RoW tail lights. From what I can put together, I would need to run 2 new wires from 09 to each light respectively and change the adaptations for rear turn signal and brake lights respectively. Unless there is another channel not being used in NAR 09 that can be tricked into out putting the brake signal based on the wiring existing (doubtful)?
;SW:5Q0-937-085-BF   HW:5Q0-937-085-BF ---  Cent. Elect.
;Component:BCM MQBAB MNA H34 0236     Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB    17001
;Monday    8
;VCDS Version: Release 17.1.3  Data version: 20170320 DS267.7
;VCID: 7EB019BAE11537B19B-802A
IDE00001-ENG99061-Production mode-Access control    not active
IDE00001-ENG115730-Production mode-Aussenbeleuchtung    not active
IDE00001-ENG112304-Production mode-Heckwischer    not active
IDE00001-ENG98647-Production mode-Interior lighting    not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung    not active
IDE00001-ENG115731-Production mode-Virtuel_pedal    not active
IDE00002-Transport mode    active
IDE00820-Activating and deactivating all development messages    not active
IDE01550-Service position    133.296571 °
IDE02152-Characteristics in production mode    2000 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking    Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln    not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global    active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn    not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln    active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn    normal
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung    active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte    not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen    not active
IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl    not active
IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl    not active
IDE02269-ENG11176-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit    300 ms
IDE02269-ENG11175-Acknowledgement signals-ZV-Blinken_Dunkelzeit    300 ms
IDE02269-ENG11174-Acknowledgement signals-ZV-Blinken_Hellzeit    300 ms
IDE02332-Deactivate production mode    0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen    not active
IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen    not active
IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1    8 s (second)
IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2    16 s (second)
IDE02711-ENG112304-Rear Window Wiper-Heckwischer    logikgesteuert
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf    not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck    active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1    3 s (second)
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2    1 s (second)
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik    5 s (second)
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall    5 s (second)
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW    not active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck    not active
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset    -0.3 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit    50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt    OFF
IDE03638-ENG116675-static AFS light-Lower speed threshold    0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur    100.0 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur    95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel    90 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur    80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel    30 °
IDE03638-ENG116676-static AFS light-Upper speed threshold    32.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift    OFF
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht    15 min
IDE03787-Activate left/right hand drive switch-over    not active
IDE04927-IDE01446-Window heater-Running time of heated front window    600 s (second)
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung    35.0 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung    35.0 °C
IDE04927-ENG11179-Window heater-Frontscheibenheizung _maximale_Dauer    0 s (second)
IDE04927-ENG10963-Window heater-Frontscheibenheizung_LED_direkt    not installed
IDE04927-ENG10946-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus    not installed
IDE04927-ENG126845-Window heater-FSH Automatik    not active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert    600 s (second)
IDE04927-ENG10883-Window heater-heizbare Heckscheibe    installed
IDE04927-ENG10949-Window heater-Heizbare_Frontscheibe    not installed
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH    not active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH    active
IDE04927-ENG10890-Window heater-Waschduesenheizung    installed
IDE04927-ENG10945-Window heater-window heating front activation time    240 s (second)
IDE04928-MAS01577-Anti-theft device-Parking heater    not installed
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn    not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal    frequency modulated
IDE04928-ENG10888-Anti-theft device-Diebstahlwarnanlage    active
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung    driver door contact thatcham
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus    not active
IDE04928-ENG10935-Anti-theft device-DWA_Einfachhorn_oder_Sounder    Sounder_verbaut
IDE04928-ENG10889-Anti-theft device-Heckscheibenbruchsensor    not installed
IDE04928-ENG10934-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet    No
IDE04928-ENG11177-Anti-theft device-OBD Alarm    activ
IDE04928-ENG10937-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)    Yes
IDE04928-ENG10938-Anti-theft device-Sensor_fuer_Innenraumueberwachung    No
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl    1 Alarm
IDE04928-ENG10936-Anti-theft device-tilt_sensor    No
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel    not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm    keine verzoegerung
IDE05144-Read parameter address    00 00 00
IDE05145-Light configuration    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 61 49 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 62 4A 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 1A 0B 00 7F 1E 00 7F 00 00 00 00 00 00 06 40 00 1B 0C 00 7F 1E 00 7F 00 00 00 00 00 00 06 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 06 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 04 45 00 1E 46 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 5D 28 1E 7F 00 00 00 00 00 00 00 00 00 06 40 00 5E 28 1E 7F 00 00 00 00 00 00 00 00 00
IDE06089-ENG10904-Seat heater level current consumption allocation-Sitzheitzung_CAN    Heizmatten am BCM
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss    1 s (second)
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss    0.00 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle    28.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle    27.50 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle    28.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle    27.50 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle    41.00 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle    40.50 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle    41.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle    40.50 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle    63.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle    62.50 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle    63.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle    62.50 °C
IDE06089-ENG10905-Seat heater level current consumption allocation-Sitzheizungsfreigabe    not installed
IDE06425-Roller test bench mode: functional    not active
IDE06507-MAS13125-Button in center console-Funktion Taster 1    Start-stop
IDE06507-MAS13129-Button in center console-Funktion Taster 2    not coded/not installed
IDE06507-MAS13132-Button in center console-Funktion Taster 3    Driving program
IDE06507-MAS13135-Button in center console-Funktion Taster 4    not coded/not installed
IDE06507-ENG09171-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED    LED not installed
IDE07007-ENG11181-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich    active
IDE07007-ENG11180-A/C heater function via remote control-Abbruch_Hupen_RSt    not active
IDE07007-ENG11183-A/C heater function via remote control-Aktivierung_Drehzahlanzeige    active
IDE07007-ENG11182-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik    active
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt    active
IDE07007-ENG115720-A/C heater function via remote control-Remotestart    not installed
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung    active
IDE07356-Position during interval mode    21.692286 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs    abschalten nach der Nachlaufzeit
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit    30 min
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein    not active
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen    active
IDE08786-ENG10884-Assistance light functions-Humidity sensor    installed
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit    normal
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe    active
IDE08786-ENG11156-Assistance light functions-Maskierung_Regenfunktion    not active
IDE08786-ENG10913-Assistance light functions-Regen_Lichtsensor    LIN_REGEN_LICHT_SENSOR
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor    not installed
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit    0.00 s (second)
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1    0
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2    0
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3    0
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig    not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig    not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach    0%
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe    0
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum    0%
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole    0%
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer    0%
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn    0%
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen    active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen    active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen    active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen    active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen    active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen    active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen    active
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen    not active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen    active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen    active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen    not active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen    active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen    active
IDE09731-ENG11161-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen    active
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten    not active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig    not active
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM    active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig    not active
IDE09731-ENG10959-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht    not installed
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig    not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren    not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig    not active
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel    not installed
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel    not installed
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig    not active
IDE09731-ENG11112-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G    not installed
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel    not active
IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI    not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel    not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel    not installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher    installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen    active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus    not active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung    installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung    not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil    not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI    not installed
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting    installed
IDE09732-ENG02313-Interior light: light configuration-Frei_Farbwahl_ueber_HMI    not active
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar    not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung    not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung    not installed
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne    30%
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz    25%
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne    30%
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz    25%
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne    58%
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz    53%
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne    58%
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz    53%
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne    85%
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz    80%
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne    85%
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz    80%
IDE09761-ENG10952-Seat fan charac. curve-Sitzlueftung    not installed
IDE09761-ENG11111-Seat fan charac. curve-Sitzlueftung_reduzierbar    not installed
IDE09761-ENG10953-Seat fan charac. curve-Sitzpneumatik    not installed
IDE10298-Alternating park position 1    18.692289 °
IDE10299-Alternating park position 2    21.692286 °
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit    1
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach    1
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum    1
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel    1
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher    1
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko    1
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd    1
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer    1
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI    0
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2    0
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3    0
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4    0
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI    0
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2    0
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3    0
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4    0
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab    1
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf    1
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI    0
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay    0
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit    100%
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach    100%
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum    100%
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht    100%
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel    100%
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher    100%
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko    100%
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd    100%
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren    100%
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit    100%
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach    100%
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum    100%
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht    100%
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel    100%
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher    100%
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko    100%
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd    100%
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren    100%
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit    100%
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach    100%
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum    100%
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht    100%
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel    100%
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher    100%
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko    100%
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd    100%
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren    100%
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit    100%
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach    100%
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum    100%
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht    100%
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel    100%
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher    100%
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko    100%
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd    100%
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren    100%
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit    100%
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach    100%
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum    100%
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht    100%
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel    100%
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher    100%
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko    100%
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd    100%
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren    100%
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit    100%
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach    100%
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum    100%
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht    100%
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel    100%
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher    100%
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko    100%
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd    100%
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren    100%
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit    100%
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach    100%
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum    100%
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht    100%
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel    100%
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher    100%
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko    100%
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd    100%
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren    100%
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit    100%
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach    100%
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum    100%
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht    100%
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel    100%
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher    100%
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko    100%
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd    100%
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren    100%
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit    126%
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach    126%
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum    126%
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht    0%
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel    126%
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher    126%
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko    126%
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd    126%
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren    126%
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit    100%
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach    100%
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum    100%
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht    100%
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel    100%
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher    100%
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko    100%
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd    100%
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren    100%
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit    100%
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach    100%
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum    100%
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht    100%
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel    100%
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher    100%
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko    100%
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd    100%
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren    100%
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit    100%
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach    100%
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum    100%
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht    100%
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel    100%
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher    100%
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko    100%
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd    100%
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren    100%
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit    100%
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach    100%
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum    100%
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht    100%
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel    100%
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher    100%
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko    100%
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd    100%
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren    100%
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit    100%
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach    100%
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum    100%
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht    100%
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel    100%
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher    100%
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko    100%
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd    100%
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren    100%
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit    100%
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach    100%
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum    100%
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht    100%
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel    100%
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher    100%
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko    100%
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd    100%
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren    100%
IDE11477-ENG06093-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte    200 ms
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit    0.0 s (second)
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach    0.0 s (second)
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum    0.0 s (second)
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht    0.0 s (second)
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko    0.0 s (second)
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren    0.0 s (second)
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit    0.0 s (second)
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach    0.0 s (second)
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum    0.0 s (second)
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht    0.0 s (second)
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko    0.0 s (second)
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren    0.0 s (second)
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit    0.0 s (second)
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach    0.0 s (second)
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum    0.0 s (second)
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht    0.0 s (second)
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko    0.0 s (second)
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren    0.0 s (second)
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit    0.0 s (second)
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach    0.0 s (second)
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum    0.0 s (second)
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht    0.0 s (second)
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko    0.0 s (second)
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren    0.0 s (second)
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit    0.0 s (second)
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach    0.0 s (second)
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum    0.0 s (second)
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht    0.0 s (second)
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko    0.0 s (second)
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren    0.0 s (second)
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit    0.0 s (second)
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach    0.0 s (second)
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum    0.0 s (second)
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht    0.0 s (second)
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko    0.0 s (second)
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren    0.0 s (second)
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit    0.0 s (second)
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach    0.0 s (second)
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum    0.0 s (second)
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht    0.0 s (second)
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko    0.0 s (second)
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren    0.0 s (second)
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen    0
IDE11714-ENG126827-Ambientelicht Farbliste-Blauwert Farbe 1    225
IDE11714-ENG02360-Ambientelicht Farbliste-Blauwert Farbe 10    225
IDE11714-ENG126830-Ambientelicht Farbliste-Blauwert Farbe 2    225
IDE11714-ENG126833-Ambientelicht Farbliste-Blauwert Farbe 3    225
IDE11714-ENG02342-Ambientelicht Farbliste-Blauwert Farbe 4    225
IDE11714-ENG02345-Ambientelicht Farbliste-Blauwert Farbe 5    225
IDE11714-ENG02348-Ambientelicht Farbliste-Blauwert Farbe 6    225
IDE11714-ENG02351-Ambientelicht Farbliste-Blauwert Farbe 7    225
IDE11714-ENG02354-Ambientelicht Farbliste-Blauwert Farbe 8    225
IDE11714-ENG02357-Ambientelicht Farbliste-Blauwert Farbe 9    225
IDE11714-ENG126826-Ambientelicht Farbliste-Gruenwert Farbe 1    225
IDE11714-ENG02359-Ambientelicht Farbliste-Gruenwert Farbe 10    225
IDE11714-ENG126829-Ambientelicht Farbliste-Gruenwert Farbe 2    225
IDE11714-ENG126832-Ambientelicht Farbliste-Gruenwert Farbe 3    225
IDE11714-ENG02341-Ambientelicht Farbliste-Gruenwert Farbe 4    225
IDE11714-ENG02344-Ambientelicht Farbliste-Gruenwert Farbe 5    225
IDE11714-ENG02347-Ambientelicht Farbliste-Gruenwert Farbe 6    225
IDE11714-ENG02350-Ambientelicht Farbliste-Gruenwert Farbe 7    225
IDE11714-ENG02353-Ambientelicht Farbliste-Gruenwert Farbe 8    225
IDE11714-ENG02356-Ambientelicht Farbliste-Gruenwert Farbe 9    225
IDE11714-ENG126825-Ambientelicht Farbliste-Rotwert Farbe 1    225
IDE11714-ENG02358-Ambientelicht Farbliste-Rotwert Farbe 10    225
IDE11714-ENG126828-Ambientelicht Farbliste-Rotwert Farbe 2    225
IDE11714-ENG126831-Ambientelicht Farbliste-Rotwert Farbe 3    225
IDE11714-ENG02340-Ambientelicht Farbliste-Rotwert Farbe 4    225
IDE11714-ENG02343-Ambientelicht Farbliste-Rotwert Farbe 5    225
IDE11714-ENG02346-Ambientelicht Farbliste-Rotwert Farbe 6    225
IDE11714-ENG02349-Ambientelicht Farbliste-Rotwert Farbe 7    225
IDE11714-ENG02352-Ambientelicht Farbliste-Rotwert Farbe 8    225
IDE11714-ENG02355-Ambientelicht Farbliste-Rotwert Farbe 9    225
IDE11944-ENG10942-Schlüssellose Zugang- und Startberechtigung-Elektische_Lenkradverriegelung    installed
IDE11944-ENG10876-Schlüssellose Zugang- und Startberechtigung-Kessy    installed
IDE11944-ENG116653-Schlüssellose Zugang- und Startberechtigung-Kessy Komfort oeffnen    not active
IDE11944-ENG116654-Schlüssellose Zugang- und Startberechtigung-Kessy Komfort schliessen    active
IDE11944-ENG116655-Schlüssellose Zugang- und Startberechtigung-Kessy Komfortbedienung Reichweitenbegrenzung    active
IDE11944-ENG116626-Schlüssellose Zugang- und Startberechtigung-Oeffnung Heckdeckel bei Wiederentriegelung    active
MAS01490-ENG10955-Energy management-Energiemanagement Abschaltung    active
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation    Energy management active
MAS01490-ENG11184-Energy management-Hochvoltfahrzeug    not installed
MAS01490-ENG10878-Energy management-Hybridfahrzeug    No
MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement    not active
MAS01490-ENG10906-Energy management-Recuperation    active
MAS01490-ENG10965-Energy management-Zweitbatterie    not installed
MAS05055-lower turn position    27.692280 °
MAS05056-upper turn position    166.296538 °
MAS08228-ENG02362-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze    1200 lx
MAS08228-ENG02363-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze    2200 lx
MAS08228-ENG02372-Light sensor-ECE_Lichteinschaltschwelle    1000 lx
MAS08228-ENG02361-Light sensor-Einschaltgrenze_CHO_LHO    600 lx
MAS08228-ENG02365-Light sensor-Helligkeitsgrenze_Licht__einschalten    1200 lx
MAS08228-ENG02366-Light sensor-Helligkeitsgrenze_Licht_ausschalten    2200 lx
MAS08228-ENG02373-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red    00 50
MAS08228-ENG02364-Light sensor-Helligkeitsgrenze_sehr_hell    2000 lx
MAS08228-ENG11158-Light sensor-HMI_Exterior_light_on_highway    not active
MAS08228-ENG11159-Light sensor-HMI_Exterior_light_on_rain    not active
MAS08228-ENG11160-Light sensor-HMI_exterior_light_sensitivity    frueh
MAS08228-ENG11157-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF    not active
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe    not active
MAS08228-ENG02370-Light sensor-Maximale_Ausgangsspannung    4500 mV
MAS08228-ENG02368-Light sensor-Maximale_Beleuchtungsstaerke    6000 lx
MAS08228-ENG02369-Light sensor-Minimale_Ausgangsspannung    2000 mV
MAS08228-ENG02367-Light sensor-Minimale_Beleuchtungsstaerke    0 lx
MAS08228-ENG02371-Light sensor-Tunnel_einschalt_verzoegerung    2
ENG10611-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren    not active
ENG10611-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT    not active
ENG10611-ENG10903-Allwetterlicht_Spoiler-tt_spoiler    not installed
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1    0
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10    0
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11    0
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12    0
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13    0
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14    0
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15    0
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2    0
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3    0
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4    0
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5    0
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6    0
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7    0
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8    0
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9    0
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1    NOT-DEFINED
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10    NOT-DEFINED
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11    NOT-DEFINED
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12    NOT-DEFINED
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13    NOT-DEFINED
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14    NOT-DEFINED
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15    NOT-DEFINED
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2    NOT-DEFINED
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3    NOT-DEFINED
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4    NOT-DEFINED
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5    NOT-DEFINED
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6    NOT-DEFINED
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7    NOT-DEFINED
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8    NOT-DEFINED
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9    NOT-DEFINED
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1    not installed
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10    not installed
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11    not installed
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12    not installed
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13    not installed
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14    not installed
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15    not installed
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2    not installed
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3    not installed
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4    not installed
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5    not installed
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6    not installed
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7    not installed
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8    not installed
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9    not installed
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12    0
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1    0
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10    0
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11    0
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13    0
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14    0
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15    0
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16    0
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17    0
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18    0
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19    0
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2    0
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20    0
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3    0
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4    0
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5    0
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6    0
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7    0
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8    0
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9    0
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1    0
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10    0
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11    0
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12    0
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13    0
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14    0
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15    0
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16    0
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17    0
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18    0
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19    0
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2    0
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20    0
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3    0
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4    0
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5    0
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6    0
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7    0
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9    0
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8    0
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1    not installed
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10    not installed
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11    not installed
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12    not installed
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13    not installed
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14    not installed
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15    not installed
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16    not installed
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17    not installed
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18    not installed
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19    not installed
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2    not installed
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20    not installed
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3    not installed
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4    not installed
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5    not installed
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6    not installed
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7    not installed
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9    not installed
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8    not installed
ENG10577-ENG122212-Außenlicht_Blinker-ABBA_Blinken    active
ENG10577-ENG02307-Außenlicht_Blinker-Abbruch Komfortblinken    active
ENG10577-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger    separte
ENG10577-ENG121966-Außenlicht_Blinker-Crash flashing    not active
ENG10577-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken    active
ENG10577-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung    active
ENG10577-ENG11122-Außenlicht_Blinker-dynamisch_blinken_10    not active
ENG10577-ENG11123-Außenlicht_Blinker-Dynamische_Blink_Delay    50 ms
ENG10577-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken    not active
ENG10577-ENG115774-Außenlicht_Blinker-Komfortblinken    active
ENG10577-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen    3
ENG10577-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken    not active
ENG10577-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2    not active
ENG10577-ENG121967-Außenlicht_Blinker-Panic flashing    active
ENG10577-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links    active
ENG10577-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts    active
ENG10577-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken    active
ENG10577-ENG121968-Außenlicht_Blinker-Taxi alarm flashing    active
ENG10577-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken    active
ENG10577-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken    active
ENG10577-ENG10957-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz    not active
ENG10577-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS    active
ENG10577-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN    active
ENG10577-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf    active
ENG10577-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu    active
ENG10575-ENG10914-Außenlicht_Front-Abblendlicht_Leuchtentyp    H7
ENG10575-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze    350 km/h
ENG10575-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze    350 km/h
ENG10575-ENG115833-Außenlicht_Front-Fahrlicht bei Tag    Daytime running lights
ENG10575-ENG11121-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL    4 km/h
ENG10575-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich    not active
ENG10575-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht    active
ENG10575-ENG11119-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument    active
ENG10575-ENG11118-Außenlicht_Front-Signaturlicht_verbaut    not installed
ENG10575-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht    not active
ENG10575-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich    active
ENG10575-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten    not active
ENG10575-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO    not active
ENG10575-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht    not active
ENG10575-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte    not active
ENG10575-ENG11120-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit    active
ENG10575-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge    active
ENG10575-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren    in Betrieb lassen
ENG10576-ENG10915-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht    No
ENG10576-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit    60 km/h
ENG10576-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA    not active
ENG10576-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion    active
ENG10576-ENG10932-Aussenlicht_Heck-Umgreifende_Heckklappe    not installed
ENG10584-ENG10948-Außenlicht_uebergreifend-All-weather lights    installed
ENG10584-ENG02309-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung    abschaltbar über Energiemanagement
ENG10584-ENG02308-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung    abschaltbar über Energiemanagement
ENG10584-ENG11116-Außenlicht_uebergreifend-bewusstes Standlicht    Aktive Begrenzung
ENG10584-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten    Low beam
ENG10584-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus    automatic
ENG10584-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis    Driver door
ENG10584-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach    not active
ENG10584-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig    Hinweis_in_LDS-Stellung_Null_und_SL
ENG10584-ENG02310-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer    Faktor fuer x1 Stunden
ENG10584-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung    6400 lx
ENG10584-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung    12 lx
ENG10584-ENG11117-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige    No
ENG10584-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht    separate
ENG10584-ENG11113-Außenlicht_uebergreifend-LCM_blinker    falsch
ENG10584-ENG10920-Außenlicht_uebergreifend-LDS_mit_AFL    Yes
ENG10584-ENG10919-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht    Yes
ENG10584-ENG10918-Außenlicht_uebergreifend-LDS_mit_Nebellicht    Yes
ENG10584-ENG10921-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung    Yes
ENG10584-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus    Enabled
ENG10584-ENG10917-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)    LIN
ENG10584-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten    klemmenabhaengig
ENG10584-ENG10962-Außenlicht_uebergreifend-Light_Control_Module    installed
ENG10584-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO    Menuesteuerung aktivieren
ENG10584-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome    20 s
ENG10584-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP    60 s
ENG10584-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung    active
ENG10584-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP    active
ENG10584-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert    not active
ENG10584-ENG126816-Außenlicht_uebergreifend-Standlicht aus    active
ENG10584-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht    active
ENG10584-ENG02311-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit    8 s (second)
ENG10584-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte    not active
ENG126647-ENG98399-debug_light_function-Activation    0
ENG126647-ENG101417-debug_light_function-Adresse    0
ENG126647-ENG126820-debug_light_function-Bitmask    0
ENG126647-ENG126821-debug_light_function-Divisor    0
ENG126647-ENG98827-debug_light_function-Offset    0
ENG126647-ENG126822-debug_light_function-Polaritaet    0
ENG10603-ENG115658-Dimmunt_KL_58xs_PWM-x0    0.00%
ENG10603-ENG101574-Dimmunt_KL_58xs_PWM-X1    50.00%
ENG10603-ENG99557-Dimmunt_KL_58xs_PWM-X2    100.00%
ENG10603-ENG115659-Dimmunt_KL_58xs_PWM-y0    0.00%
ENG10603-ENG99777-Dimmunt_KL_58xs_PWM-Y1    50.00%
ENG10603-ENG100480-Dimmunt_KL_58xs_PWM-Y2    100.00%
ENG122934-erase_error_table    55 00 00
ENG122933-error_mask    0 bit
ENG10578-MAS13782-Fernlicht_assistent-Assistenzfahrlicht: Empfindlichkeit per BAP einstellbar    present
ENG10578-ENG10901-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung    AFS: FLA: Fernlicht ueber AFS
ENG10578-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset    active
ENG10578-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent    present
ENG10578-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung    present
ENG10613-Front_wash_function    10
ENG10610-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA    active
ENG10610-ENG11178-Front_wiper-Anfahrzeit_servicestellung    500 ms
ENG10610-ENG115836-Front_wiper-Frontwischer Notlaufprogramm    active
ENG10610-ENG116614-Front_wiper-Frontwischer Referenzlauf    not active
ENG10610-ENG02322-Front_wiper-Frontwischer_Abtauposition    not active
ENG10610-ENG10894-Front_wiper-Frontwischertyp    LIN
ENG10610-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung    active
ENG10610-ENG116615-Front_wiper-Menuesteuerung Frontwischer    not active
ENG10610-ENG115771-Front_wiper-Regensensor aktivieren    Deactivating
ENG10610-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz    active
ENG10610-ENG116618-Front_wiper-Traenenwischen Front Status    active
ENG10610-ENG115770-Front_wiper-Variable Regensensoraktivierung    not active
ENG10610-ENG126844-Front_wiper-Washer_Tipwiping_Variant    not active
ENG10610-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube    not active
ENG10610-ENG116612-Front_wiper-Wischer stop bei KL15 aus    not active
ENG10610-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube    active
ENG99457-ENG117394-Head area heater-blower_speed    0
ENG99457-ENG98971-Head area heater-Temperature    -3
ENG10573-MAS00211-HW_Verbau-Insufficient brake fluid    installed
ENG10573-MAS00212-HW_Verbau-Insufficient washer fluid    installed
ENG10573-MAS00213-HW_Verbau-Insufficient coolant    installed
ENG10573-MAS00214-HW_Verbau-Brake pad wear    installed
ENG10573-ENG10954-HW_Verbau-Druckklappe    not installed
ENG10573-ENG10891-HW_Verbau-Elektrische Laderaumabdeckung aktiv    not active
ENG10573-ENG10940-HW_Verbau-Elektrische_Laderaumabdeckung    not installed
ENG10573-ENG10880-HW_Verbau-Exterior temp. sensor    installed
ENG10573-ENG10933-HW_Verbau-Kontaktschalter_fuer_Motorhaube    installed
ENG10573-ENG11114-HW_Verbau-Ladesteckerverriegelung    not installed
ENG10573-ENG10964-HW_Verbau-PTC Zuheizer    not installed
ENG10573-ENG115809-HW_Verbau-Signalhorn ohne KL15    not active
ENG10573-ENG10931-HW_Verbau-Status_Tankdeckelverriegelung    not active
ENG10588-ENG115658-Kennlinie_sLWR_Soll-x0    95.00%
ENG10588-ENG101574-Kennlinie_sLWR_Soll-X1    94.90%
ENG10588-ENG99557-Kennlinie_sLWR_Soll-X2    94.40%
ENG10588-ENG102140-Kennlinie_sLWR_Soll-X3    93.90%
ENG10588-ENG102936-Kennlinie_sLWR_Soll-X4    93.40%
ENG10588-ENG103548-Kennlinie_sLWR_Soll-X5    92.90%
ENG10588-ENG113992-Kennlinie_sLWR_Soll-X6    92.40%
ENG10588-ENG115661-Kennlinie_sLWR_Soll-x7    91.9
ENG10588-ENG115662-Kennlinie_sLWR_Soll-x8    91.40%
ENG10588-ENG115663-Kennlinie_sLWR_Soll-x9    90.90%
ENG10588-ENG115659-Kennlinie_sLWR_Soll-y0    100.00%
ENG10588-ENG99777-Kennlinie_sLWR_Soll-Y1    89.50%
ENG10588-ENG100480-Kennlinie_sLWR_Soll-Y2    83.00%
ENG10588-ENG100773-Kennlinie_sLWR_Soll-Y3    75.50%
ENG10588-ENG100631-Kennlinie_sLWR_Soll-Y4    68.00%
ENG10588-ENG102174-Kennlinie_sLWR_Soll-Y5    61.00%
ENG10588-ENG113993-Kennlinie_sLWR_Soll-Y6    56.50%
ENG10588-ENG115665-Kennlinie_sLWR_Soll-y7    47.00%
ENG10588-ENG115666-Kennlinie_sLWR_Soll-y8    40.00%
ENG10588-ENG115667-Kennlinie_sLWR_Soll-y9    33.00%
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0    maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0    maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0    maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0    0
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0    0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0    0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0    0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0    0
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0    0
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0    not active
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0    Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0    not active
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0    not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0    not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0    not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0    not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0    not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0    not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0    not active
ENG10585-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15    maximize
ENG10585-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15    maximize
ENG10585-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15    maximize
ENG10585-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15    100
ENG10585-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15    0
ENG10585-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15    0
ENG10585-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15    0
ENG10585-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15    63
ENG10585-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15    0
ENG10585-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15    41 - LED Kleinleistung
ENG10585-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15    Always
ENG10585-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15    not active
ENG10585-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15    not active
ENG10585-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15    not active
ENG10585-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15    not active
ENG10585-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15    not active
ENG10585-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15    not active
ENG10585-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15    not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10    maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10    maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10    maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10    127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10    0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10    0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10    0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10    1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10    45
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10    4 - LED Tagfahrlichtmodul Signal
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10    Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10    Versorgungsbedarf der LCM Module
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10    not active
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10    not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10    not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10    not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10    not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10    not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10    not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11    maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11    maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11    maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11    0
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11    0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11    0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11    0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11    0
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11    0
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11    not active
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11    Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11    not active
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11    not active
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11    not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11    not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11    not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11    not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11    not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11    not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12    maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12    maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12    maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12    127
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12    0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12    0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12    0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12    5D
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12    36
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12    6 - LED Lichtmodul
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12    Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12    Klemme 15 mit Nachlauf bis Fahrzeugstillstand
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12    Coming Home oder Leaving Home aktiv
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12    not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12    not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12    not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12    not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12    not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12    not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13    maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13    maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13    maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13    127
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13    0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13    0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13    0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13    5E
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13    40
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13    6 - LED Lichtmodul
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13    Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13    Klemme 15 mit Nachlauf bis Fahrzeugstillstand
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13    Coming Home oder Leaving Home aktiv
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13    not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13    not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13    not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13    not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13    not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13    not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16    maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16    maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16    maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16    0
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16    0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16    0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16    0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16    0
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16    0
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16    not active
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16    Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16    not active
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16    not active
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16    not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16    not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16    not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16    not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16    not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16    not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17    maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17    maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17    maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17    0
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17    0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17    0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17    0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17    0
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17    0
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17    not active
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17    Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17    not active
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17    not active
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17    not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17    not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17    not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17    not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17    not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17    not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    minimize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    minimize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    127
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    127
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    3F
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    8
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    38 - LED Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    Brake light
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    Nebelschlusslicht wenn kein Anhaenger gesteckt
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    Blinken links aktiv (beide Phasen)
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    Blinken links Hellphase
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    Blinken links Dunkelphase
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    minimize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    minimize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    127
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    127
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    40
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    38 - LED Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    Brake light
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    Nebelschlusslicht wenn kein Anhaenger gesteckt
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    Blinken rechts aktiv (beide Phasen)
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    Blinken rechts Hellphase
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    Blinken rechts Dunkelphase
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1    maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1    maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1    maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1    100
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1    0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1    0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1    0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1    4
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1    0
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1    46 - LED Kleinleistung
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1    Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1    Ambientelicht 2
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1    not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1    not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1    not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1    not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1    not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1    not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1    not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    minimize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    0
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    127
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    127
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    3D
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    13
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    35 - kombinierte LED Blink-Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    not active
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    Brake light
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    Blinken links Hellphase
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    Blinken links Dunkelphase
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    minimize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    0
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    127
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    127
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    3E
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    23
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    35 - kombinierte LED Blink-Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    not active
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    Brake light
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    Blinken rechts Hellphase
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    Blinken rechts Dunkelphase
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22    maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22    maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22    maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22    127
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22    0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22    0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22    0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22    2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22    29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22    42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22    Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22    Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22    not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22    not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22    not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22    not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22    not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22    not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22    not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    127
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    127
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    37 - allgemeine LED bis 12W
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    Coming Home oder Leaving Home aktiv
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    127
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    127
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    37 - allgemeine LED bis 12W
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    Coming Home oder Leaving Home aktiv
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    Parking light right
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25    maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25    maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25    maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25    127
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25    127
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25    0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25    0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25    30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25    28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25    43 - allgemeine LED
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25    Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25    Coming Home oder Leaving Home aktiv
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25    beidseitiges Dauerparklicht
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25    not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25    not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25    not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25    not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25    not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26    minimize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26    maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26    maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26    100
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26    0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26    0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26    0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26    2E
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26    0C
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26    37 - allgemeine LED bis 12W
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26    Always
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26    Nebelschlusslicht wenn kein Anhaenger gesteckt
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26    not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26    Left high beam
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26    not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26    not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26    not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26    not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26    not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27    minimize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27    maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27    maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27    100
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27    0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27    0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27    0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27    2F
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27    1C
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27    37 - allgemeine LED bis 12W
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27    Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27    Nebelschlusslicht wenn kein Anhaenger gesteckt
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27    not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27    Right high beam
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27    not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27    not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27    not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27    not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27    not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    127
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    37 - allgemeine LED bis 12W
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    Always
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29    maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29    maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29    maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29    127
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29    0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29    0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29    0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29    32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29    1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29    37 - allgemeine LED bis 12W
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29    Always
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29    Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29    not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29    not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29    not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29    not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29    not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29    not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29    not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2    maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2    maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2    maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2    127
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2    0
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2    0
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2    0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2    61
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2    0
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2    36 - LED Kleinleistung
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2    Always
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2    not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2    not active
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2    not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2    not active
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2    not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2    not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2    not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30    maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30    maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30    maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30    100
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30    0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30    0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30    0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30    2
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30    0
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30    46 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30    Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30    Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30    not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30    not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30    not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30    not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30    not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30    not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30    not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31    maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31    maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31    maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31    100
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31    0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31    0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31    0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31    3
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31    0
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31    not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31    Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31    Ambientelicht 1
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31    not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31    not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31    not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31    not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31    not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31    not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31    not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32    maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32    maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32    maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32    100
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32    0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32    0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32    0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32    4
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32    0
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32    not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32    Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32    Ambientelicht 2
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32    not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32    not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32    not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32    not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32    not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32    not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32    not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33    maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33    maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33    maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33    100
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33    0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33    0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33    0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33    5
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33    0
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33    not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33    Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33    Ambientelicht 3
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33    not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33    not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33    not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33    not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33    not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33    not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33    not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34    maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34    maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34    maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34    100
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34    0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34    0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34    0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34    6
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34    0
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34    not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34    Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34    Ambientelicht 4
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34    not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34    not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34    not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34    not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34    not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34    not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34    not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3    maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3    maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3    maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3    127
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3    0
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3    0
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3    0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3    62
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3    0
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3    36 - LED Kleinleistung
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3    Always
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3    not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3    not active
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3    not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3    not active
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3    not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3    not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3    not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4    maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4    maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4    maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4    0
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4    0
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4    0
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4    0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4    0
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4    0
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4    not active
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4    Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4    not active
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4    not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4    not active
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4    not active
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4    not active
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4    not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4    not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4    not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5    maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5    maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5    maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5    0
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5    0
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5    0
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5    0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5    0
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5    0
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5    not active
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5    Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5    not active
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5    not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5    not active
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5    not active
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5    not active
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5    not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5    not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5    not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6    maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6    maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6    maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6    127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6    127
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6    0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6    0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6    1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6    36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6    6 - LED Lichtmodul
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6    Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6    Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6    not active
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6    Coming Home oder Leaving Home aktiv
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6    not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6    not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6    not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6    not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6    not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7    maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7    maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7    maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7    127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7    127
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7    0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7    0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7    1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7    40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7    6 - LED Lichtmodul
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7    Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7    Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7    not active
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7    Coming Home oder Leaving Home aktiv
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7    not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7    not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7    not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7    not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7    not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8    maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8    maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8    maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8    127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8    127
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8    0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8    0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8    4B
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8    44
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8    6 - LED Lichtmodul
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8    Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8    Versorgungsbedarf der LCM Module
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8    not active
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8    Parking light right
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8    not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8    not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8    not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8    not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9    maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9    maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9    maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9    127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9    127
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9    0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9    0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9    49
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9    3A
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9    6 - LED Lichtmodul
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9    Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9    Versorgungsbedarf der LCM Module
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9    not active
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9    Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9    not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9    not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9    not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9    not active
ENG10589-Leuchtenkonfiguration_Aussenlich_Heck    26 08 00 3F 18 00 7F 1A 06 80 02 00 7F 03 00 80 26 18 00 40 18 00 7F 1A 07 80 04 00 7F 05 00 80 23 13 00 3D 00 00 00 18 00 7F 02 00 7F 03 00 80 23 23 00 3E 00 00 00 18 00 7F 04 00 7F 05 00 80 2A 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 25 0A 00 29 08 1E 7F 09 00 7F 00 00 00 00 00 00 25 1A 00 2A 08 1E 7F 0A 00 7F 00 00 00 00 00 00 2B 28 00 30 08 1E 7F 3A 00 7F 00 00 00 00 00 00 25 0C 00 2E 1A 00 64 0D 00 80 00 00 00 00 00 00 25 1C 00 2F 1A 00 64 0E 00 80 00 00 00 00 00 00 25 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 25 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00
ENG10590-Leuchtenkonfiguration_Sonstiges    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 64 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 64 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 64 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00
ENG10586-ENG11125-Leuchtweitenregulierung-1_Sensor_LWR    1-Sensor_LWR
ENG10586-ENG11147-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges    2650 mm
ENG10586-ENG11146-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4    4.50 mm/%
ENG10586-ENG11145-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn    3.30 mm/%
ENG10586-ENG11129-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe    active
ENG10586-ENG11139-Leuchtweitenregulierung-Ansteuerung_obere_grenze    84.00%
ENG10586-ENG11138-Leuchtweitenregulierung-Ansteuerung_untere_grenze    20.00%
ENG10586-ENG11137-Leuchtweitenregulierung-diagnose_soll_toleranz    15%
ENG10586-ENG11131-Leuchtweitenregulierung-Entprellung_Fehlerlampe    10.0 s (second)
ENG10586-ENG11142-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1    4.10 mm/%
ENG10586-ENG11144-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2    4.70 mm/%
ENG10586-ENG11141-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1    3.30 mm/%
ENG10586-ENG11143-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2    3.30 mm/%
ENG10586-ENG11126-Leuchtweitenregulierung-Fahrwerk_Variante    2: Variante 3 (Mehrlenkerhinterachse 4-Motion
ENG10586-ENG11132-Leuchtweitenregulierung-Fail_Safe_sLWR    70.00%
ENG10586-ENG11151-Leuchtweitenregulierung-fFiltEinf    0.10 Hz
ENG10586-ENG11140-Leuchtweitenregulierung-Lineare_Abbildung    1
ENG10586-ENG11130-Leuchtweitenregulierung-Logik_PWM_Signal    Negative
ENG10586-ENG11148-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand    550 mm
ENG10586-ENG11149-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe    680 mm
ENG10586-ENG11154-Leuchtweitenregulierung-lwr_pwm_obere_schwelle    95.00%
ENG10586-ENG11153-Leuchtweitenregulierung-lwr_pwm_untere_schwelle    5.00%
ENG10586-ENG11155-Leuchtweitenregulierung-max_v_slwr    5 km/h
ENG10586-ENG11150-Leuchtweitenregulierung-pa_fDynFiltStatLwr    100 Hz
ENG10586-ENG11152-Leuchtweitenregulierung-pa_fFiltSwNeigung    10.00 Hz
ENG10586-ENG11128-Leuchtweitenregulierung-Quelle_Hoehenwerte    CAN_Daempferregelung
ENG10586-ENG10970-Leuchtweitenregulierung-sensor_headlight_range_control_installed    not installed
ENG10586-ENG11127-Leuchtweitenregulierung-sLWR_bei_Abblendlicht    not active
ENG10586-ENG11136-Leuchtweitenregulierung-sLWR_Hysterese    60.00%
ENG10586-ENG11135-Leuchtweitenregulierung-sLWR_SW_Grad    5.0 %/s
ENG10586-ENG11134-Leuchtweitenregulierung-sLWR_Touristenlicht    20.00%
ENG10586-ENG11124-Leuchtweitenregulierung-sLWR_verbaut    not installed
ENG10586-ENG11133-Leuchtweitenregulierung-Zyklus_sLWR    0.00 s (second)
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1    not active
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2    not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3    not active
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4    not active
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5    not active
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6    not active
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ    not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0    0.00%
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1    5.00%
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2    50.00%
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3    75.00%
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4    110
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5    126.5
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0    0.00%
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1    6.00%
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2    16.00%
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3    30.00%
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4    60.00%
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5    100.00%
ENG10587-ENG115658-lwr_ofs_RSw_Ah1S-x0    0.00%
ENG10587-ENG101574-lwr_ofs_RSw_Ah1S-X1    -0.30%
ENG10587-ENG99557-lwr_ofs_RSw_Ah1S-X2    -0.80%
ENG10587-ENG102140-lwr_ofs_RSw_Ah1S-X3    -1.80%
ENG10587-ENG102936-lwr_ofs_RSw_Ah1S-X4    -2.10%
ENG10587-ENG115659-lwr_ofs_RSw_Ah1S-y0    0.3
ENG10587-ENG99777-lwr_ofs_RSw_Ah1S-Y1    0
ENG10587-ENG100480-lwr_ofs_RSw_Ah1S-Y2    0.62
ENG10587-ENG100773-lwr_ofs_RSw_Ah1S-Y3    0.8
ENG10587-ENG100631-lwr_ofs_RSw_Ah1S-Y4    -0.7
ENG122979-ENG10882-Networking-A/C electronics    installed
ENG122979-ENG10896-Networking-Anhaengeranschlussgeraet    not installed
ENG122979-ENG10902-Networking-Bremsen_Steuergeraet    installed
ENG122979-ENG10881-Networking-Getriebesteuergeraet    installed
ENG122979-ENG99457-Networking-Head area heater    not installed
ENG122979-ENG10968-Networking-Kunden_spezifisches_Funktions_SG    not installed
ENG122979-ENG10897-Networking-UGDO    not installed
ENG124714-ENG10972-OCU-DWA_push    not active
ENG124714-ENG11188-OCU-Honk DWA_Ausgabe_Fanfare    not active
ENG124714-ENG124714-OCU-    not installed
ENG124714-ENG11189-OCU-Remote HuF Abbruch    0 km/h
ENG124714-ENG11190-OCU-Remote HuF Hupfrequenz    0
ENG124714-ENG02319-OCU-Remote Lock Unlock Timer s1    0 s (second)
ENG124714-ENG02320-OCU-Remote Lock Unlock Timer s3    0.0 ms
ENG124714-ENG125657-OCU-Remote_Unlock_Lock    not_active
ENG98831-ENG126849-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar    not active
ENG98831-ENG02329-Personalisierung-Anzahl_Benutzerkonten    0
ENG98831-ENG02330-Personalisierung-Automatische_ Schluesselzuordnung    not active
ENG98831-ENG126850-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar    not active
ENG98831-ENG126848-Personalisierung-Personalisierung_aktiv    not active
ENG98831-ENG10922-Personalisierung-Personalisierung_Profilfunkion    profiles_inactive
ENG98831-ENG126851-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar    not active
ENG98831-ENG10958-Personalisierung-Profil_Variante    Schluessel
ENG98831-ENG02332-Personalisierung-PSO_FSG_Setup2_Bit_1    not active
ENG98831-ENG02333-Personalisierung-PSO_FSG_Setup2_Bit_2    not active
ENG98831-ENG02334-Personalisierung-PSO_FSG_Setup2_Bit_3    not active
ENG98831-ENG02335-Personalisierung-PSO_FSG_Setup2_Bit_4    not active
ENG10574-MAS01065-Querschnitts_funktionen-Brand    Audi
ENG10574-ENG10908-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll    active
ENG10574-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung    not active
ENG10574-ENG10895-Querschnitts_funktionen-Codierungsabsicherung    not active
ENG10574-ENG10956-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21    active
ENG10574-ENG11115-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus    Pin 31
ENG10574-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben    active
ENG10574-ENG10892-Querschnitts_funktionen-Lenkungsanordnung    Left
ENG10574-ENG10943-Querschnitts_funktionen-Personalisierungsuebernahme    installed
ENG10574-ENG10911-Querschnitts_funktionen-Schnittstelle_TrackingSystem    not active
ENG10574-ENG10893-Querschnitts_funktionen-Verkehrsseite    Right
ENG122927-RLS_close_glazing    2.0 s (second)
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off    120 s (second)
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on    10 s (second)
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off    65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on    140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle    6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high    12
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low    6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht    30 s (second)
ENG122929-RLS_LIN_Communication    4 s (second)
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn    100 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day    200 lx
ENG122930-RLS_tunel_gateway_recognize    5 s (second)
ENG122935-RLS_Washer_Front    15 s (second)
ENG122926-RLS_wiper_position_parking    15 s (second)
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung    8
ENG115729-ENG10877-Scheinwerferreinigung-Headlamp washer system    installed
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel    active
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit    1000 ms
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit    1200 ms
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit    1000 ms
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit    1000 ms
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit    1200 ms
ENG10612-SFT09729-Slave_systems_identification-Control Unit For Wiper Motor    Not available
ENG10612-SFT09730-Slave_systems_identification-Rain Light Recognition Sensor    Not available
ENG10612-SFT09731-Slave_systems_identification-Light switch    Not available
ENG10612-SFT09732-Slave_systems_identification-Garage door opener control module    Not available
ENG10612-SFT09733-Slave_systems_identification-Garage Door Opener Operating Unit    Not available
ENG10612-SFT09750-Slave_systems_identification-Sensor For Anti Theft Alarm System    Not available
ENG10612-SFT09752-Slave_systems_identification-Alarm horn    Not available
ENG10612-SFT09760-Slave_systems_identification-Sun Roof    Not available
ENG10612-SFT09766-Slave_systems_identification-Ceiling Light Module    Not available
ENG10612-SFT09784-Slave_systems_identification-Roof Blind    Not available
ENG10612-SFT09803-Slave_systems_identification-Relative Air Humidity Interior Sender    Not available
ENG10612-SFT09822-Slave_systems_identification-Neck Heating Left    Not available
ENG10612-SFT09823-Slave_systems_identification-Neck Heating Right    Not available
ENG10612-SFT09921-Slave_systems_identification-Seat Backrest Fan 1 Front Left    Not available
ENG10612-SFT09923-Slave_systems_identification-Seat Cushion Fan 1 Front Left    Not available
ENG10612-SFT09925-Slave_systems_identification-Seat Backrest Fan 1 Front Right    Not available
ENG10612-SFT09927-Slave_systems_identification-Seat Cushion Fan 1 Front Right    Not available
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker    SMLS
ENG116588-ENG116588-Sonderfunktionen-    not enabled
ENG116588-ENG10907-Sonderfunktionen-Sonderfunktionen 1    not installed
ENG10563-ENG116658-Spiegelverstellung-Funk Spiegelanklappen    not active
ENG10563-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus    by look command via remote control key
ENG10563-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen    active
ENG10563-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung    active
ENG10563-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung    not active
ENG10563-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel    not active
ENG10563-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung    active
ENG10563-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt    active
ENG10563-ENG02339-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung    not active
ENG10563-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron    not active
ENG10606-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0    0.0 lx
ENG10606-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1    8.0 lx
ENG10606-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2    50.0 lx
ENG10606-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3    80.0 lx
ENG10606-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4    100.0 lx
ENG10606-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0    6
ENG10606-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1    6
ENG10606-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2    20
ENG10606-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3    50
ENG10606-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4    100
ENG10607-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0    0.0 lx
ENG10607-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1    8.0 lx
ENG10607-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2    50.0 lx
ENG10607-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3    80.0 lx
ENG10607-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4    100.0 lx
ENG10607-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0    6
ENG10607-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1    6
ENG10607-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2    20
ENG10607-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3    50
ENG10607-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4    100
ENG10594-ENG115658-Suchbeleuchtung_Abdimmen-x0    0 ms
ENG10594-ENG101574-Suchbeleuchtung_Abdimmen-X1    200 ms
ENG10594-ENG115664-Suchbeleuchtung_Abdimmen-x10    2000 ms
ENG10594-ENG99557-Suchbeleuchtung_Abdimmen-X2    400 ms
ENG10594-ENG102140-Suchbeleuchtung_Abdimmen-X3    600 ms
ENG10594-ENG102936-Suchbeleuchtung_Abdimmen-X4    800 ms
ENG10594-ENG103548-Suchbeleuchtung_Abdimmen-X5    1000 ms
ENG10594-ENG113992-Suchbeleuchtung_Abdimmen-X6    1200 ms
ENG10594-ENG115661-Suchbeleuchtung_Abdimmen-x7    1400 ms
ENG10594-ENG115662-Suchbeleuchtung_Abdimmen-x8    1600 ms
ENG10594-ENG115663-Suchbeleuchtung_Abdimmen-x9    1800 ms
ENG10594-ENG115659-Suchbeleuchtung_Abdimmen-y0    100.00%
ENG10594-ENG99777-Suchbeleuchtung_Abdimmen-Y1    100.00%
ENG10594-ENG115668-Suchbeleuchtung_Abdimmen-y10    0.00%
ENG10594-ENG100480-Suchbeleuchtung_Abdimmen-Y2    95.00%
ENG10594-ENG100773-Suchbeleuchtung_Abdimmen-Y3    80.00%
ENG10594-ENG100631-Suchbeleuchtung_Abdimmen-Y4    40.00%
ENG10594-ENG102174-Suchbeleuchtung_Abdimmen-Y5    20.00%
ENG10594-ENG113993-Suchbeleuchtung_Abdimmen-Y6    10.00%
ENG10594-ENG115665-Suchbeleuchtung_Abdimmen-y7    5.00%
ENG10594-ENG115666-Suchbeleuchtung_Abdimmen-y8    3.00%
ENG10594-ENG115667-Suchbeleuchtung_Abdimmen-y9    1.00%
ENG10591-ENG11168-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM    0.00 s (second)
ENG10591-ENG11164-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM    0.00 s (second)
ENG10591-ENG11166-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM    0.00 s (second)
ENG10591-ENG11167-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM    0.00 s (second)
ENG10591-ENG11165-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM    0.00 s (second)
ENG10591-ENG10916-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung    Potentiometer
ENG10591-ENG11170-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen    0.0 s (second)
ENG10591-ENG11169-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen    0.0 s (second)
ENG10591-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe    not active
ENG10591-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten    active
ENG10591-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung    active
ENG10591-ENG11171-Suchbeleuchtung_allgemein-pa_Hysterese_RLS    5
ENG10591-ENG11163-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM    0.00 s (second)
ENG10591-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert    50%
ENG10591-ENG11162-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl    Fotosensor_Kombi
ENG10591-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung    Always active
ENG10591-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor    0.248
ENG10591-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert    1.00%
ENG10595-ENG115658-Suchbeleuchtung_Fotosensor-x0    0
ENG10595-ENG101574-Suchbeleuchtung_Fotosensor-X1    50
ENG10595-ENG115664-Suchbeleuchtung_Fotosensor-x10    0
ENG10595-ENG99557-Suchbeleuchtung_Fotosensor-X2    100
ENG10595-ENG102140-Suchbeleuchtung_Fotosensor-X3    200
ENG10595-ENG102936-Suchbeleuchtung_Fotosensor-X4    253
ENG10595-ENG103548-Suchbeleuchtung_Fotosensor-X5    0
ENG10595-ENG113992-Suchbeleuchtung_Fotosensor-X6    0
ENG10595-ENG115661-Suchbeleuchtung_Fotosensor-x7    0
ENG10595-ENG115662-Suchbeleuchtung_Fotosensor-x8    0
ENG10595-ENG115663-Suchbeleuchtung_Fotosensor-x9    0
ENG10595-ENG115659-Suchbeleuchtung_Fotosensor-y0    0 lx
ENG10595-ENG99777-Suchbeleuchtung_Fotosensor-Y1    50 lx
ENG10595-ENG115668-Suchbeleuchtung_Fotosensor-y10    0 lx
ENG10595-ENG100480-Suchbeleuchtung_Fotosensor-Y2    100 lx
ENG10595-ENG100773-Suchbeleuchtung_Fotosensor-Y3    200
ENG10595-ENG100631-Suchbeleuchtung_Fotosensor-Y4    500
ENG10595-ENG102174-Suchbeleuchtung_Fotosensor-Y5    0
ENG10595-ENG113993-Suchbeleuchtung_Fotosensor-Y6    0 lx
ENG10595-ENG115665-Suchbeleuchtung_Fotosensor-y7    0 lx
ENG10595-ENG115666-Suchbeleuchtung_Fotosensor-y8    0 lx
ENG10595-ENG115667-Suchbeleuchtung_Fotosensor-y9    0 lx
ENG10593-ENG115658-Suchbeleuchtung_Hochdimmen-x0    0 ms
ENG10593-ENG101574-Suchbeleuchtung_Hochdimmen-X1    200 ms
ENG10593-ENG115664-Suchbeleuchtung_Hochdimmen-x10    2000 ms
ENG10593-ENG99557-Suchbeleuchtung_Hochdimmen-X2    400 ms
ENG10593-ENG102140-Suchbeleuchtung_Hochdimmen-X3    600 ms
ENG10593-ENG102936-Suchbeleuchtung_Hochdimmen-X4    800 ms
ENG10593-ENG103548-Suchbeleuchtung_Hochdimmen-X5    1000 ms
ENG10593-ENG113992-Suchbeleuchtung_Hochdimmen-X6    1200 ms
ENG10593-ENG115661-Suchbeleuchtung_Hochdimmen-x7    1400 ms
ENG10593-ENG115662-Suchbeleuchtung_Hochdimmen-x8    1600 ms
ENG10593-ENG115663-Suchbeleuchtung_Hochdimmen-x9    1800 ms
ENG10593-ENG115659-Suchbeleuchtung_Hochdimmen-y0    0.00%
ENG10593-ENG99777-Suchbeleuchtung_Hochdimmen-Y1    1.00%
ENG10593-ENG115668-Suchbeleuchtung_Hochdimmen-y10    100.00%
ENG10593-ENG100480-Suchbeleuchtung_Hochdimmen-Y2    3.00%
ENG10593-ENG100773-Suchbeleuchtung_Hochdimmen-Y3    5.00%
ENG10593-ENG100631-Suchbeleuchtung_Hochdimmen-Y4    11.00%
ENG10593-ENG102174-Suchbeleuchtung_Hochdimmen-Y5    22.00%
ENG10593-ENG113993-Suchbeleuchtung_Hochdimmen-Y6    40.00%
ENG10593-ENG115665-Suchbeleuchtung_Hochdimmen-y7    80.00%
ENG10593-ENG115666-Suchbeleuchtung_Hochdimmen-y8    95.00%
ENG10593-ENG115667-Suchbeleuchtung_Hochdimmen-y9    100.00%
ENG10597-ENG115658-Suchbeleuchtung_KL 58xs max-x0    0 lx
ENG10597-ENG101574-Suchbeleuchtung_KL 58xs max-X1    8 lx
ENG10597-ENG99557-Suchbeleuchtung_KL 58xs max-X2    50 lx
ENG10597-ENG102140-Suchbeleuchtung_KL 58xs max-X3    500 lx
ENG10597-ENG115659-Suchbeleuchtung_KL 58xs max-y0    100
ENG10597-ENG99777-Suchbeleuchtung_KL 58xs max-Y1    100
ENG10597-ENG100480-Suchbeleuchtung_KL 58xs max-Y2    100
ENG10597-ENG100773-Suchbeleuchtung_KL 58xs max-Y3    100
ENG10596-ENG115658-Suchbeleuchtung_KL 58xs min-x0    0 lx
ENG10596-ENG101574-Suchbeleuchtung_KL 58xs min-X1    8 lx
ENG10596-ENG99557-Suchbeleuchtung_KL 58xs min-X2    50 lx
ENG10596-ENG102140-Suchbeleuchtung_KL 58xs min-X3    500 lx
ENG10596-ENG115659-Suchbeleuchtung_KL 58xs min-y0    6
ENG10596-ENG99777-Suchbeleuchtung_KL 58xs min-Y1    6
ENG10596-ENG100480-Suchbeleuchtung_KL 58xs min-Y2    100
ENG10596-ENG100773-Suchbeleuchtung_KL 58xs min-Y3    100
ENG10602-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0    0.00%
ENG10602-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1    6.00%
ENG10602-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2    16.00%
ENG10602-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3    30.00%
ENG10602-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4    60.00%
ENG10602-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5    100.00%
ENG10602-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0    10
ENG10602-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1    10
ENG10602-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2    100
ENG10602-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3    150
ENG10602-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4    220
ENG10602-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5    253
ENG10601-ENG115658-Suchbeleuchtung_KL_58xd_max-x0    0 lx
ENG10601-ENG101574-Suchbeleuchtung_KL_58xd_max-X1    8 lx
ENG10601-ENG99557-Suchbeleuchtung_KL_58xd_max-X2    200 lx
ENG10601-ENG102140-Suchbeleuchtung_KL_58xd_max-X3    300 lx
ENG10601-ENG102936-Suchbeleuchtung_KL_58xd_max-X4    500 lx
ENG10601-ENG115659-Suchbeleuchtung_KL_58xd_max-y0    16
ENG10601-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1    16
ENG10601-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2    100
ENG10601-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3    100
ENG10601-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4    100
ENG10600-ENG115658-Suchbeleuchtung_KL_58xd_min-x0    0 lx
ENG10600-ENG101574-Suchbeleuchtung_KL_58xd_min-X1    8 lx
ENG10600-ENG99557-Suchbeleuchtung_KL_58xd_min-X2    220 lx
ENG10600-ENG102140-Suchbeleuchtung_KL_58xd_min-X3    300 lx
ENG10600-ENG102936-Suchbeleuchtung_KL_58xd_min-X4    500 lx
ENG10600-ENG115659-Suchbeleuchtung_KL_58xd_min-y0    6
ENG10600-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1    6
ENG10600-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2    100
ENG10600-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3    100
ENG10600-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4    100
ENG10605-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0    0
ENG10605-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1    10
ENG10605-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2    100
ENG10605-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3    150
ENG10605-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4    220
ENG10605-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5    253
ENG10605-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0    6.00%
ENG10605-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1    6.00%
ENG10605-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2    16.00%
ENG10605-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3    30.00%
ENG10605-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4    60.00%
ENG10605-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5    100.00%
ENG10598-ENG115658-Suchbeleuchtung_KL_58xt min-x0    0 lx
ENG10598-ENG101574-Suchbeleuchtung_KL_58xt min-X1    8 lx
ENG10598-ENG99557-Suchbeleuchtung_KL_58xt min-X2    50 lx
ENG10598-ENG102140-Suchbeleuchtung_KL_58xt min-X3    500 lx
ENG10598-ENG115659-Suchbeleuchtung_KL_58xt min-y0    6
ENG10598-ENG99777-Suchbeleuchtung_KL_58xt min-Y1    6
ENG10598-ENG100480-Suchbeleuchtung_KL_58xt min-Y2    100
ENG10598-ENG100773-Suchbeleuchtung_KL_58xt min-Y3    100
ENG10599-ENG115658-Suchbeleuchtung_KL_58xt_max-x0    0 lx
ENG10599-ENG101574-Suchbeleuchtung_KL_58xt_max-X1    8 lx
ENG10599-ENG99557-Suchbeleuchtung_KL_58xt_max-X2    50 lx
ENG10599-ENG102140-Suchbeleuchtung_KL_58xt_max-X3    500 lx
ENG10599-ENG115659-Suchbeleuchtung_KL_58xt_max-y0    100
ENG10599-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1    100
ENG10599-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2    100
ENG10599-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3    100
ENG10604-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0    0.00%
ENG10604-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1    50.00%
ENG10604-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2    100.00%
ENG10604-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0    0.00%
ENG10604-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1    50.00%
ENG10604-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2    100.00%
ENG10608-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0    0 lx
ENG10608-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1    200 lx
ENG10608-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2    400 lx
ENG10608-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3    600 lx
ENG10608-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4    800 lx
ENG10608-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5    1020 lx
ENG10608-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0    0
ENG10608-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1    84
ENG10608-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2    166
ENG10608-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3    250
ENG10608-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4    370
ENG10608-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5    500
ENG10592-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0    0 ms
ENG10592-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1    2000 ms
ENG10592-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2    3000 ms
ENG10592-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3    4000 ms
ENG10592-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4    5100 ms
ENG10592-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0    1.00%
ENG10592-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1    5
ENG10592-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2    15
ENG10592-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3    40
ENG10592-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4    100
ENG10560-ENG116647-Sunroof-SAD Komfort oeffnen    active
ENG10560-ENG116646-Sunroof-SAD Komfort schliessen    active
ENG10560-ENG116645-Sunroof-SAD Richtung Komfortoeffnen    tilting
ENG10560-ENG10898-Sunroof-Schiebedachmodul_MD_1    installed
ENG10560-ENG10899-Sunroof-Schiebedachmodul_MD_3    not installed
ENG10560-ENG10900-Sunroof-Schiebedachmodul_MD_Rollo    not installed
ENG10560-ENG10950-Sunroof-Verortung Schiebedachmodule    LIN
ENG10562-ENG10941-Verdecksteuergeraet-Cabrio_Verdeck    not_installed
ENG10562-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck    not active
ENG10562-ENG128459-Verdecksteuergeraet-easycloselight_aktiv    not active
ENG10562-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb    active
ENG10562-ENG11187-Verdecksteuergeraet-Kick_and_close    not installed
ENG10562-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global    active
ENG10562-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen    active
ENG10562-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen    active
ENG10562-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf    active
ENG10562-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen    not active
ENG10562-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung    Always
ENG10562-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden    nur wenn freigegeben
ENG10562-ENG10939-Verdecksteuergeraet-trunk_lid_conrol_unit    not installed
ENG10562-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach    not active
ENG10562-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung    not active
ENG10562-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy    not active
ENG10562-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder    active
ENG10562-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung    not active
ENG10562-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy    active
ENG10562-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder    active
ENG10562-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal    not active
ENG10562-ENG11186-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba    not active
ENG10562-ENG11185-Verdecksteuergeraet-Virtuelles_Pedal_Verbau    not installed
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1    00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2    00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3    00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4    00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1    00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2    00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3    00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4    00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5    00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6    00 00
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute    42
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute    62
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute    30
ENG10579-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB    not active
ENG10579-ENG02315-ZV allgemein-Deaktivierung_Laderaumschliessung_extern    not active
ENG10579-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster    active
ENG10579-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein    active
ENG10579-ENG115754-ZV allgemein-Funk bei Klemme 15 ein    not active
ENG10579-ENG10909-ZV allgemein-Lock_Unlock_Taster_direkt    not installed
ENG10579-ENG10947-ZV allgemein-Lock_Unlock_Toggle_Taster    not installed
ENG10579-ENG02316-ZV allgemein-LS_Taster_Togglefunktion    not active
ENG10579-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung    active
ENG10579-ENG115755-ZV allgemein-Notschließfunktion    not active
ENG10579-ENG02317-ZV allgemein-Nutzfahrzeug_Schliessung    not active
ENG10579-ENG10885-ZV allgemein-Radio freq.    315MHz
ENG10579-ENG10886-ZV allgemein-Tankschloss    Bidirectional
ENG10579-ENG02318-ZV allgemein-Wiederverriegelung_Laderaum    Freigabe_Softtouch
ENG10579-ENG116623-ZV allgemein-ZV Tuerentriegelung    Einzeltuerentriegelung
ENG10579-ENG10924-ZV allgemein-ZV_ohne_Safe_Funktion    installed
ENG10582-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck    active
ENG10582-ENG116621-ZV Autolock-automatisches Entriegeln    active
ENG10582-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit    active
ENG10582-ENG116706-ZV Autolock-Autounlock NAR    active
ENG10582-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung    not active
ENG10582-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock    adjustable
ENG10583-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren    active
ENG10583-ENG116661-ZV Crash-SAD PreCrash Konturschliessen    active
ENG10583-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash    active
ENG10581-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels    active
ENG10581-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang    not active
ENG10581-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster    not active
ENG10581-ENG10944-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster    via_CAN
ENG10581-ENG02314-ZV Heck-Heckfreigabe_Ohne_Verzoegerung    not active
ENG10581-ENG11173-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen    not active
ENG10581-ENG10926-ZV Heck-Heckschloss_mit_Vorraste    No
ENG10581-ENG10923-ZV Heck-Heckschloss_Steuerung    Pulse control
ENG10581-ENG06090-ZV Heck-Mindestbetaetigung_HDF_Innentaster    0.0 s (second)
ENG10581-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt    active
ENG10581-ENG10910-ZV Heck-Tausch_Tank_Hecktreiberausgang    No
ENG10581-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel    active
ENG10581-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen    not active
ENG10581-ENG10925-ZV Heck-ZV_Heck_Schlosstyp    1 or 2 notch rear actuator
ENG10609-IDE02021-ZV Komfort-Comfort closing    active
ENG10609-IDE02022-ZV Komfort-Comfort opening    not active
ENG10609-ENG10912-ZV Komfort-elektrischer_Fensterheber_hinten    Yes
ENG10609-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen    not active
ENG10609-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen    not active
ENG10609-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit    600 s (second)
ENG10609-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus    active
ENG10609-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen    active
ENG10609-ENG116652-ZV Komfort-Funk Komfort oeffnen    active
ENG10609-ENG116651-ZV Komfort-Funk Komfort schliessen    not active
ENG10609-ENG115670-ZV Komfort-Komfortbedienung global    active
ENG10609-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer    not active
ENG10609-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar    adjustable
ENG10609-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen    not active
ENG10609-ENG125656-ZV Komfort-Regenschliessen_art    once
ENG10609-ENG125655-ZV Komfort-Regenschliessen_ein_aus    not active
ENG10609-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen    active
ENG10609-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen    active
ENG10580-ENG10927-ZV Türkonfiguration-Fond_Schloss    Tuersteuergeraet im Fond verbaut oder keine Fondtuer
ENG10580-ENG10971-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal    nicht invertiert
ENG10580-ENG10967-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite    not installed
ENG10580-ENG10966-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite    not installed
ENG10580-ENG10929-ZV Türkonfiguration-Schiebetuer_links    No
ENG10580-ENG10930-ZV Türkonfiguration-Schiebetuer_rechts    No
ENG10580-ENG10969-ZV Türkonfiguration-Schiebetueren_Crafter    not installed
ENG10580-ENG11172-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM    Driver side
ENG10580-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe    not active
ENG10580-ENG10928-ZV Türkonfiguration-Schlosstyp_NAR    Yes
ENG10580-ENG10887-ZV Türkonfiguration-Viertuerer    Yes
   #43
@marttimat: hmm........... that's odd!! Your original admap has exactly the correct settings for the changes in your post #39??:confused:
Before you abandon the cross wiring harness option - riddle me this, please:
  1. Where did you get the post #39 instructions?
  2. Where did you buy the cross wiring harness?
  3. Do you have the manufacturer's coding instructions for the cross wiring harness?
  4. As currently programmed (I assume using the post #39 settings) and with the cross wiring harness fitted, do the tails work correctly - other than the brake function?
marttimat
CT | USA
C?ID=305745
Hey Don, whoops - sorry I copied the wrong excel file. Below you will find a cleaned up comparison of the channel values as changed. As you called out earlier, the dynamic turn signal channels used in RoW vehicles goes unchanged with this retrofit.
The harness can be purchased here. It came with the coding instructions which I have since reached out to let them know the issue coding out the brake light function.
As of now, the 3rd brake light stays on when the brake lights are requested on (Auto Hold, Hill Assist and ACC) while the outer lamps turn off when the brake pedal is released. There is a slight delay of the 3rd brake light turning off when the brake pedal is released when the vehicle is not in Auto Hold. I believe this is due to the wiring and coding nature of the kit. All other lighting circuits work without issue other than when the brake lights are requested on vs stepping on the brake pedal. Not bad considering the complexity of a retrofit like this. Really makes you wish they could have kept the lighting as intended in all markets!
I am thinking if there is the option of tapping into the 3rd brake light or running 2 wires and not need the piggy back harness. Feel free to let me know your thoughts. Thanks again.
Below is before and after:
Original adaption channels:
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    minimize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    minimize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    127
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    127
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    3F
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    8
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    38 - LED Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    Brake light
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    Nebelschlusslicht wenn kein Anhaenger gesteckt
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    Blinken links aktiv (beide Phasen)
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    Blinken links Hellphase
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    Blinken links Dunkelphase
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    minimize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    minimize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    127
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    127
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    40
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    38 - LED Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    Brake light
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    Nebelschlusslicht wenn kein Anhaenger gesteckt
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    Blinken rechts aktiv (beide Phasen)
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    Blinken rechts Hellphase
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    Blinken rechts Dunkelphase
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    minimize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    0
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    127
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    127
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    3D
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    13
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    35 - kombinierte LED Blink-Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    not active
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    Brake light
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    Blinken links Hellphase
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    Blinken links Dunkelphase
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    minimize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    0
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    127
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    127
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    3E
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    23
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    35 - kombinierte LED Blink-Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    not active
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    Brake light
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    Blinken rechts Hellphase
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    Blinken rechts Dunkelphase
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    127
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    127
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    37 - allgemeine LED bis 12W
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    Coming Home oder Leaving Home aktiv
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    127
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    127
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    37 - allgemeine LED bis 12W
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    Coming Home oder Leaving Home aktiv
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    Parking light right
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    127
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    37 - allgemeine LED bis 12W
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    Always
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active
Coding changes with harness:
Leutche 18 Lichtfunktion A18 - "Bremslicht" change to "Not Active"
Leutche 18 Lichtfunktion C18 - "Nebelschlusslicht Wenn Kein anhaenger Gesteckt" change to "Not Active"
Leutche 19 Lichtfunktion A19 - "Bremslicht" change to "Not Active"
Leutche 19 Lichtfunktion C19 - "Nebelschlusslicht Wenn Kein anhaenger Gesteckt" change to "Not Active"
Leutche 20 Lastttp 20 - "35 Kombinierte LED Blink - Brem" change to "Not Active"
Leutche 20 Lichtfunktion C20 - "Bremslicht" change to "Not Active"
Leutche 20 Lichtfunktion E20 - "Blinken Links Hellphase" change to "Not Active"
Leutche 20 Lichtfunktion G20 - "Blinken Links Dunkelphase" change to "Not Active"
Leutche 21 Lastttp 21 - "35 Kombinierte LED Blink - Brem" change to "Not Active"
Leutche 21 Lichtfunktion C21 - "Bremslicht" change to "Not Active"
Leutche 20 Lichtfunktion E21 - "Blinken Recht Hellphase" change to "Not Active"
Leutche 20 Lichtfunktion G21 - "Blinken Recht Dunkelphase" change to "Not Active"
Leutche 23 Lichtfunktion A23 - "Standlicht allgemein (Schlu sslicht Positionslicht; B)" change to "Blinken Links Hellphase"
Leutche 23 Lichtfunktion B23 - "Coming Home oder leaving home" change to "Not Active"
Leutche 23 Lichtfunktion C23 - "Parklicht (beidseitiges Parklicht...)" change to "Not Active"
Leutche 24 Lichtfunktion A24 - "Standlicht allgemein (Schlu sslicht Positionslicht; B)" change to "Blinken Recht Hellphase"
Leutche 24 Lichtfunktion B24 - "Coming Home oder leaving home" change to "Not Active"
Leutche 23 Lichtfunktion C24 - "Parklicht (beidseitiges Parklicht...)" change to "Not Active"
Leutche 28 Lichtfunktion A28 - "Rueckfahrlicht" change to "Standlicht allgemein (Schlu sslicht Positionslicht; B)"
Leutche 28 Dimmwert AB28 - "127" change to "35"
Current adaptation channels:
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    minimize     16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize     16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    minimize     16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    127    16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0    16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    127    16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0    16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    3F     16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    8    16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    38 - LED Blinkleuchten     16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always     16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    not active     16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active     16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    not active     16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    Blinken links aktiv (beide Phasen)     16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    Blinken links Hellphase     16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active     16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    Blinken links Dunkelphase     16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active     16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    minimize     16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize     16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    minimize     16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    127    16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0    16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    127    16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0    16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    40    16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    18    16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    38 - LED Blinkleuchten     16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always     16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    not active     16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active     16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    not active     16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    Blinken rechts aktiv (beide Phasen)     16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    Blinken rechts Hellphase     16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active     16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    Blinken rechts Dunkelphase     16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active     16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    maximize     16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize     16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    minimize     16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    0    16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    127    16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    127    16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0    16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    3D     16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    13    16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    not active     16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always     16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    not active     16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    not active     16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    not active     16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    not active     16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    not active     16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active     16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    not active     16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active     16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    maximize     16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize     16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    minimize     16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    0    16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    127    16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    127    16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0    16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    3E     16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    23    16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    not active     16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always     16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    not active     16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    not active     16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    not active     16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    not active     16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    not active     16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active     16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    not active     16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active     16
NG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize     16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize     16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize     16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    127    16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    127    16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0    16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0    16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    29    16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A     16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    37 - allgemeine LED bis 12W     16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    Always     16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Blinken links Hellphase     16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    not active     16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    not active     16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active     16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active     16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active     16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active     16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active     16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize     16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize     16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize     16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    127    16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    127    16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0    16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0    16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2A     16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    1A     16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    37 - allgemeine LED bis 12W     16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    Always     16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Blinken rechts Hellphase     16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    not active     16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    not active     16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active     16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active     16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active     16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active     16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active     16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize     16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize     16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize     16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    35    16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0    16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0    16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0    16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31    16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0B     16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    37 - allgemeine LED bis 12W     16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    Always     16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active     16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active     16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active     16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active     16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active     16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active     16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active     16
   #45
@marttimat : So, the astonishing thing is that (with the cross wiring harness installed and the suggested changes made), you end up with:
This is a direct copy from your Current adaptation channels listing - but it means that the 2 x Leuchte-sets above are disabled!!
In an exercise where there are effectively too many lamps and not enough wires to operate the tail-light fittings, every available pin on the BCM counts. Disabling the 2 x Leuchte-sets above, disables 2 x pins on the BCM which have wires that terminate on the tail-light connections - completely antithetical to the objective of the exercise!!! Really odd!!
As a totally left-field suggestion based on nothing more than the observation that 2 x disabled Leucthe-sets is wrong - why not try this:
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 and ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 > 34 LED Bremsleuchten
and ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 > Bremslicht/Brake lamp
and ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 > 100
Probably won't work, but it's an easy try
   #46
marttimat
CT | USA
C?ID=305745
Hey Don,
I found it odd myself as both brake light adaptations were coded off. My guess tells me it is due to how they made their cross wiring harness and having it convert NAR wiring to RoW lamps. As you know, 1 pin is absent on NAR so I wonder if they are changing the brake circuits to turn signals since they know the brake pedal switch will still manually turn on the brake lamps? Just a thought. I sent them a video of the car being held automatically and the outer brake lights turning off when I release the brake pedal. Curious to see what they say.
As for the fields above, I will give it a try and see what happens. I will try doing 1 side and see how the other side compares. I appreciate all the support and theory on my configuration!
   #47
marttimat
CT | USA
C?ID=305745
Well Don you have out done yourself again. I owe you a beer for all your knowledgeable support! Through sheer experiment, the adaptation value changes above fixed the issue with my Auto Hold and brake lights not turning on (outside lamps) when control module activated. I am going to inform the vendor to make sure to add these steps to their instructions so any others are not out there with non functioning brake lights. This exercise has really opened my understanding to the Leuchte channels in 09 all together. That being said, it makes me question the other steps provided. Can you make any sense in changing the following values?
I assume this is strictly due to the harness making using of 1 circuit for both reverse lights and the harness using this circuit for parking light?
   #48
@marttimat: well done you (take $20 from petty-cash and go directly to the top of the class)!! It was only through your insightful provision of the correct information that we were able to overcome the ignominy of wrong manufacturer's instructions!! What a dynamic-duo we make? :D
As for your specific question, yes you are correct - regardless of the type of tail light fitting (i.e. LED, or incandescent), Leuchte28RFL LC11 is normally assigned to the left side reversing light. And, Leuchte29RFL RA64 is it's counterpart on the right side of the car. "RFL" in the Leuchte-set names is short for RueckFahrLicht, which means "Reversing Light" (I think)
My guess too is that your particular harness connects together both the left and right side reversing lamps on the tailgate and the BCM controls both these lights via Leuchte 29. This leaves Leuchte 28 spare for the harness to re-allocate to another purpose.
The altered Leuchte-command for Lichtfunktion A28 gives a clue as to what the re-purposed Leuchte 28 does. The new value for this channel is "Standlicht allgemein........." which translates to "Parking Light in general........"
So, the harness has re-assigned BCM pin #11, Socket C:
  • from its normal role as the reverse light on the left-side of the car
  • to the new role as Parking Lights on both sides of the car (I think yanks call these "Position lights").
  • Because I suspect that the Leuchte-command "Standlicht allgemein........." remains as factory coded in another pair of Leuchte-sets related to the tail lights, the the repurposed Leutche 28 probably controls Parking Lights only on the tail-gate fittings - but this is a guess.
Finally, the altered value of Leutche 28 Dimmwert AB28 from "127" change to "35" is necessary because when tail lights are used as Parking Lights, they always illuminate at a dimmed level so that these lamps are not confused for Stop lights.
QED
marttimat
CT | USA
C?ID=305745
Follow up to all of this would be, is a harness even needed for the inner lamps? If memory serves me right, there are the same amount of wires in the connector for NAR as I saw for RoW. Is there a combined NAR circuit that I am missing that is a separate circuit on RoW?
Thanks again Don!
   #50
marttimat
CT | USA
C?ID=305745
QED
After seeing some adaptation channel inaccuracies with the instructions (with your help nonetheless Don), I cannot help wonder if other values should be adjusted for the best long term outcome / reliability? Most notably, if the parking light circuits are repurposed for turn signal use, should the Lattyp channel be changed to reflect this (from 37 - allgemeine LED bis 12W to 38 - LED Blinkleuchten)? Would the additional channel functions also have to change (in 23 and 24 C, D E and G)?
Also, on the other side, should Leutche 28 be adjusted to mirror the parking light channels vs the Reverse light (coming home, parking light in A and B for 28 channel) I also find it odd that Dimmwert was lowered to 35 as no other lamp has that value set. The parking lights have 127 listed for their 2 Dimmwert AB and CD channels. I wonder if I adjust it, I will see any impacts.
Last question, you recommended a Dimmwert value for the brake lights at 100. Should this not be 127 to mirror the other LED outputs?
I know we are starting to get down to the nitpicky, but I have fallen into the rabbit hole of the light channels. Very interesting stuff. Through research, I have been able to map all output channels of 09 for the rear of the car. Interesting to see sub channel selections like "high beam" (C26) under rear fog light as example. Thanks again for all the insight on this topic Don!
   #51
Sounds like an excellent suggestion - give it a try
hmmm........ yes, I see your point. I don't know what the manufacturer of your new tails had in mind. If it was my car, I would make ALL the Parking Lights on the new tails operate the same. The problem with my suggestion will be that where the "Leuchte-Pair" contains 2 x functions, reducing the Dimmwert value to 35 will also affect the other light-function. This can be easily solved by shifting the "other function" (i.e. like coming home) to an unused "Leuchte-pair" and assign 127 to that Dimmwert channel
I have found that although in general, LED settings are normally accompanied with a dimmwert vale of 127 - this is not always the case!. So, bearing in mind that none of this stuff is in any publicly available literature, it seems from my observations that the max Dimmwert value is dependent on the the value in the Lasttyp channel. For the setting that I have suggested, and at least for earlier BCM s, 100 is the maximum value. But don't assume that simply because 100 < 127, a value of 100 produces less light. Again based on my own experience, my hunch is that those Lasttyp values that allow 127 are using digital control in their power supply and those that allow 100 use analogue control. However, regarless of what control mechanism is employed, both produce maximum illumination in the lamp (the difference is the permissible granularity - albeit I very-much doubt that the human eye can distinguish a difference of "one" in both)
But- why not try 127 in your BCM - what's the worst that can happen? If 127 gives an error, simply change it back to 100 and clear the DTC!
marttimat
CT | USA
C?ID=305745
I had a chuckle with your photo as I just finished the last season of Mandolorian this evening!
I will do some digging and see if there is any impact to those sub channel changes.
Have you noticed any impact when it comes to changing B,C,D,E,G etc channels? I find it interesting they have some functions listed but with no effect after changing "A" channel or "Lattyp" ? My guess here would be that they are just left in there to support large vehicle model availability?
   #53
Bruce
Near Philadelphia, PA, USA
I finished a week ago. I too chuckled @DV52 photo... I also watched The Empire Strikes Back this weekend... Yeah, I'm a trekky and Star Wars fan. But I digress in this thread... apologies. Keep on. May the Force enlighten your endeavors.
hmmm............ normally, and particularly when coded at the factory - the settings in "A, B, C.....G" are 100 % efficient - meaning that there are no superfluous entries and meaning that each entry deserves its place in the Leuchte-set. This assumes of course that the Leuchte-set is activated.
The A, B, C,.....D nomenclature is not just nominal; the value is actually significant in Leuche-programming in that it sets the priority order when multiple light functions operate at the same time. So the Alpha letter determines the outcome in conflict resolution situations using the simple logic algorithm: priority A < B < C...... G
   #55
marttimat
CT | USA
C?ID=305745
Ah, interesting. Well I went ahead and adjusted all the channels to make sure they mirror all channel functions. All seem to be working properly except for:
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 change from "Not Active" to "Blinken links aktiv (beide Phasen)"
When I adjusted this channel the outside left turn signal stopped working so I assume it must be something with my version of 09 or tail lamp lens itself. I went and just set it as "Not Active" and everything is working. Oddly, when changing the right side (ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 from "Not Active" to "Blinken links aktiv (beide Phasen) the right outer turn signal worked without issue... I left this one as "Not Active" as well just to be safe.
Here is my list of changes I made to align the output functions of 09 to the RoW taillamps I have fitted:
Brake light dimming change:
Adjust Leuchte20BR LA71-Dimmwert AB 20 From “100” to “127”
Adjust Leuchte21BR RC8-Dimmwert AB 21 From “100” to “127”
Parking to turn signal (left) channel:
Adjust Leuchte23SL HLC10-Lasttyp 23 From “37 - allgemeine LED bis 12W” to “38 - LED Blinkleuchten”
Adjust Leuchte23SL HLC10-Dimming Direction CD 23 From “maximize”     to “minimize”
Adjust Leuchte23SL HLC10-Dimming Direction GH 23 From “maximize” to “minimize”
Adjust Leuchte23SL HLC10-Dimmwert CD 23 From “127” to “0”
Adjust Leuchte23SL HLC10-Dimmwert EF 23 From “0” to “127”
Adjust Leuchte23SL HLC10-Lichtfunktion E 23 From “not active” to “Blinken links Hellphase”
Adjust Leuchte23SL HLC10-Lichtfunktion G 23 From “not active” to “Blinken links Dunkelphase”
Parking to turn signal (right) channel:
Adjust Leuchte24SL HRA65-Lasttyp 24 From “37 - allgemeine LED bis 12W” to “38 - LED Blinkleuchten”
Adjust Leuchte24SL HRA65-Dimming Direction CD 24 From “maximize”     to “minimize”
Adjust Leuchte24SL HRA65-Dimming Direction GH 24 From “maximize” to “minimize”
Adjust Leuchte24SL HRA65-Dimmwert CD 24 From “127” to “0”
Adjust Leuchte24SL HRA65-Dimmwert EF 24 From “0” to “127”
Adjust Leuchte24SL HRA65-Lichtfunktion E 24 From “not active” to “Blinken rechts Hellphase”
Adjust Leuchte24SL HRA65-Lichtfunktion G 24 From “not active” to “Blinken rechts Dunkelphase”
Left Reverse channel to Parking lights:
Adjust Leuchte28RFL LC11-Lichtfunktion B 28 From “not active” to “Coming Home oder Leaving Home aktiv”
Adjust Leuchte28RFL LC11-Lichtfunktion C 28 From “not active” to “Parklicht links (beidseitiges Parklicht aktiviert li & re)”
I am going to make another post in this thread containing my old Adaptation values and new for any future searcher as I am sure anyone reading up this point could easily get lost with all of our adjustments!
   #56
@marttimat: hmm............ it's all getting a tad murky now because there are so many changes. Trying to follow your alterations is too much for my addled brain - but I very much doubt that:
is Leuchte-kosher (same for Leuchte24SL HRA65)
   #57
marttimat
CT | USA
C?ID=305745
Of course I was bound to slip up somewhere with all those changes! Cue the head spinning!
I think I found why Leuchte23SL HLC10-Lichtfunktion D 23 change from "Not Active" to "Blinken links aktiv (beide Phasen)" had an issue. I changed Leuchte23SL HLC10-Dimmwert GH 23 From “0” to “127” instead of EF 23. I am going to go in and correct and verify. I assume all will be set then!
   #58
marttimat
CT | USA
C?ID=305745
Verified facelift 8V adaptation channel changes for RoW tail lamps
For all those going down the rabbit hole of putting Rest of World tail lamps on their NAR facelift A/S/RS 3 - you will need the following 09 adaptation channel changes:
Left turn signal:
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    Change:    Brake light    Change To:    not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    Change:    Nebelschlusslicht wenn kein Anhaenger gesteckt     Change To:    not active
Right turn signal:
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    Change:    Brake light    Change To:    not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    Change:    Nebelschlusslicht wenn kein Anhaenger gesteckt     Change To:    not active
Left brake light:
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    Change:    0    Change To:    127
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    Change:    35 - kombinierte LED Blink-Bremsleuchten     Change To:    34 - LED Bremsleuchten
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    Change:    not active     Change To:    Brake lamp
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    Change:    Brake light     Change To:    not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    Change:    Blinken links Hellphase     Change To:    not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    Change:    Blinken links Dunkelphase     Change To:    not active
Right brake light:
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    Change:    0    Change To:    127
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    Change:    35 - kombinierte LED Blink-Bremsleuchten     Change To:    34 - LED Bremsleuchten
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    Change:    not active     Change To:    Brake lamp
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    Change:    Brake light     Change To:    not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    Change:    Blinken rechts Hellphase     Change To:    not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    Change:    Blinken rechts Dunkelphase     Change To:    not active
Parking light circuit left:
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    Change:    maximize     Change To:    minimize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    Change:    maximize     Change To:    minimize
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    Change:    127    Change To:    0
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    Change:    0    Change To:    127
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    Change:    37 - allgemeine LED bis 12W     Change To:    38 - LED Blinkleuchten
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Change:    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     Change To:    Blinken links Hellphase
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    Change:    Coming Home oder Leaving Home aktiv     Change To:    not active
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    Change:    Parklicht links (beidseitiges Parklicht aktiviert li & re)     Change To:    not active
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    Change:    not active     Change To:    Blinken links aktiv (beide Phasen)
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    Change:    not active     Change To:    Blinken links Hellphase
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    Change:    not active     Change To:    Blinken links Dunkelphase
Parking light circuit right:
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    Change:    maximize     Change To:    minimize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    Change:    maximize     Change To:    minimize
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    Change:    127    Change To:    0
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    Change:    0    Change To:    127
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    Change:    37 - allgemeine LED bis 12W     Change To:    38 - LED Blinkleuchten
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Change:    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     Change To:    Blinken rechts Hellphase
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    Change:    Coming Home oder Leaving Home aktiv     Change To:    not active
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    Change:    Parking light right     Change To:    not active
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    Change:    not active     Change To:    Blinken rechts aktiv (beide Phasen)
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    Change:    not active     Change To:    Blinken rechts Hellphase
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    Change:    not active     Change To:    Blinken rechts Dunkelphase
Left reverse light:
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    Change:    127    Change To:    35
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Change:    Rueckfahrlicht     Change To:    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    Change:    not active     Change To:    Coming Home oder Leaving Home aktiv
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    Change:    not active     Change To:    Parklicht links (beidseitiges Parklicht aktiviert li & re)
You will of course need tail lamps from RoW market (NAR lamps will not work as they are hardwired internally) as well as this harness to assist in changing the circuits and connector coding's for the lamps.
quailallstar
Florida & the Nation's Capital
C?ID=53119
@DV52 Don,
Have you uncovered if the MK7.5 Golf vehicles equipped with NAR front LED dipped beams allow you to make the DRL and front turn signal LEDs "wink"? I remember you saying a while back that the newer headlights no longer had their own Leuchte channel, so I hopped that with this new research would come some discovery to mod the lights after all.
   #60
@quailallstar: Hi.
Whilst I try to "assimilate" information about MQB vehicles from whatever available source I find, I get my best data from cars that occasionally visit my home - usually accompanied by a distraught owner who has unknowingly used his (yes, normally it's a "he") diagnostic cable for evil!!
As you will appreciate there has been less-than-one NAR model car in my workshop!! ;)
Seriously - there's a very easy way to determine if a NAR vehicle can be modified to suit your wants; If the auto-scan reports Light Control Modules, then alas the BCM is not used to manage the lamps in the headlight fittings - and sadly, no changes can be made
I found a part auto-scan that you posted HERE. If the subject car is this 2019 NAR GTI Rabbit, then notice the modules @ address hex29 and hex39 in the summary list. Your auto-scan is missing the detailed information for these modules, but if you look at your full copy, you should find the term LCM in the descriptor "Component".
To confirm that indeed the BCM does not manage the DRL behavior on your car, check the 4 x associated Leuchte-sets :
  • Leuchte2SL VLB10
  • Leuchte3SL VRB21
  • Leuchte4TFL LB4
  • Leuchte5 TFL RB32
You should find that these Leuchte-sets are disabled in your BCM because the factory values for the channels are "not active".
This thread was a valiant attempt to find an alternative way of programming LCM based headlight lamps - alas it's still a work in progress!!
