NZ - Touran wants an R32 engine
   #201
golfi_vend
Tartu, Estonia
C?ID=195131
I see You don't have 7n0907530Bx gw yet which will hopefully fix the canbus faults.
Why no basic settings on ABS?
Do you have info about fuel levwl sensor calibration? White VDO NEC cluster eeprom seems alot easier to calibrate than older red Micronas.
   #202
NZDubNurd
New Zealand
C?ID=230482
I thought about 2x 1.6 badges at one point :thumbs:
I have a 7N0 gateway... but it's on the floor :-) I have no radio yet - the RCD330+ is still coming.
I did the ABS later, and the battery is out of it again now - I have to buy it one - I had stolen the battery from the Bluran, but I needed that for work today.
I have a fault with the fuel sender - Not sure if I damaged a wire yet - still to investigate. I had planned to adapt the reserve level yesterday... but then saw the fault and thought I'd rather drive it :-) I hope it isn't the sender, because I have to partially unmount the tank to get it out :cry:
   #203
NZDubNurd
New Zealand
C?ID=230482
Mwahahaha!
   #204
NZDubNurd
New Zealand
C?ID=230482
I fixed the fuel level sender.....
... turns out some dumbass fitted the wrong sender - it was the 2 wire one, not the 3 - I've got 4 in total, and picked the wrong one :facepalm: Of course I put 20L of fuel in BEFORE I decided to do it :D
I got a battery for it today... but I think I used the bolts for my septic aeration pump... better find some more tomorrow!
   #206
golfi_vend
Tartu, Estonia
C?ID=195131
My original second fuel sender had 3 pins, though 3rd not connected. Had to connect it for white cluster.
So I'm guessing You're using somesort of aftermarket sensor?
   #208
NZDubNurd
New Zealand
C?ID=230482
I got the pump out through the top, changed the sender module over to a 3 wire sender, and soldered the wire to the connection on the top. It's a factory sender - they all are, but from all sorted of different models.
The pump just fits out through the slightly modified original access hole.
The 3 pins produce opposing resistances to the centre, I guess it has to see both? The Ausi A3 sender is the 2 wire one, but the Golf cluster wanted 3 wire signals. Not sure when it changed ovet, year wise. Touran had a 3 wire sender originally too. All red clusters.
   #209
NZDubNurd
New Zealand
C?ID=230482
Argh...
The gateway I got was wrong, so the right one is being sent to me. Of course I tried the wrong one to see what it was, but it was a 6 byte? one!
Anyway - I thought I'd clear the ESP "system function test activated" code... but I couldn't! The stupid gateway had made the ABS flag an "incorrect module installed" code... which I didn't clear because I didn't know they were there!
But I also had:
Autoscan:
Wednesday,21,February,2018,20:46:29:42165
VCDS Version: 18.2.0.3 (x64)
Workshop Code: 123 12345 045678
VIN: WVWZZZ1KZ6W124470   License Plate: POST SYSTEM TEST ATTEMPT
Mileage: 123140km-76515mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ6W124470   Mileage: 123140km-76515miles
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 CD    HW:
   Component: MOTRONIC ME7.1.1    7802
   Revision: --H07---    Serial number: VWZ7Z0E3138758
   Coding: 0000172
   Shop #: WSC 12345 123 45678
   VCID: 4FAD5C06DE79993CD1-801A
Readiness: 0010 1001
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
   Component: ESP 4MOTION MK60    0102
   Revision: 00H13001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 72EBF5F26D0B94D41E-8026
02085 - Incorrect Control Module Installed
            000 -  -  - Intermittent
01487 - System Function Test
            000 -  -
   Part No: 1K0 907 044 BD
   Component: ClimatronicPQ35 090 0808
   VCID: 6ADBED9245DB5C14A6-803E
            000 -  -
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000005382893
   Coding: 008D0F210004100000120C000000000000097B075C
   Shop #: WSC 01324 785 00200
   VCID: 2A5B2D92855B9C1466-807E
   Subsystem 1 - Part No: 1T0 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW358  012  0401
   Coding: 00063445
   Shop #: WSC 01324
   Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
   Component: 02 AIRBAG VW62 0506 1500
   Revision: 09025000    Serial number: 0038BD0H4NRK
   Coding: 0012338
   VCID: 35610EEE5CE5C3ECFB-8060
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000042
   VCID: 76E3C9E2016388F432-8022
   Part No: 1K6 920 862 F
   Component: KOMBIINSTRUMENT VDD 4316
   Coding: 0001103
   VCID: 336530F65291DDDCD5-8066
   Revision:   H10       Serial number: 2800106127113D
   Coding: BD3F0340078003
   Shop #: WSC 12345 678 910111
                    Fault Frequency: 97
                    Reset counter: 127
                    Mileage: 123123 km
                    Time: 00:00:02
01304 - Radio
                    Fault Frequency: 89
                    Reset counter: 127
                    Mileage: 123123 km
                    Time: 00:00:05
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554
   Component: HALDEX 4Motion      0101
   Coding: 0000001
   Component: IMMO            VDD 4316
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2302
   Coding: 0000692
   VCID: 366309E241E3C8F4F2-8062
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.0   D06 1701
   VCID: 346733EA579FDAE4CC-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 00C802087F2D8405485FC61010CC
   VCID: 79F9C2DE307DE78C5F-802C
   Subsystem 5 - Part No: 1K0 947 291 F
   Component: Innenraumueberw.009 4809
   Coding: 00000000
   Subsystem 7 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
01134 - Alarm Horn (H12)
   Part No: 1T0 959 702 B
   Coding: 0000692
   VCID: 377D04E646E931FCE9-8062
Address 56: Radio
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2428
   Coding: 0000144
   VCID: 326B35F2AD8BD4D4DE-8066
01036 - Electric Window Thermal Protection Active; Rear Left
   Part No: 1K0 959 704 E
   Coding: 0000144
End-------------------------(Elapsed Time: 01:51)--------------------------
So, I cleared them all out, and tried again:
Autoscan BEFORE second attempt:
Wednesday,21,February,2018,20:51:49:42165
VIN: WVWZZZ1KZ6W124470   License Plate: READY FOR SYSTEM TEST
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 62 72
   Coding: 0000172
Readiness: 0110 1101
   Revision: 00H13001
   Coding: 0004738
            000 -  -
            000 -  -
   Coding: 00063445
   Shop #: WSC 01324
   Coding: 0012338
   Coding: 0000042
   Coding: 0001103
   Coding: BD3F0300078003
   Coding: 0000001
   Coding: 0000692
   Coding: 00000000
   Coding: 0000692
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 01:41)--------------------------
Which then resulted in these codes:
Control Module Part Number: 1K0 907 379 AB    HW: 1K0 907 379 AB
  Component and/or Version: ESP 4MOTION MK60    0102
           Software Coding: 0004738
            Work Shop Code: WSC 01279 785 00200
            000 -  -
So I have the original "01486 - System Function Test Activated" - makes sense.
and I have the "01487 - System Function Test" because I couldn't complete the test.
But the G200 and G202 - are they because the paddock I'm doing it in isn't flat and has a few sharp humps and hollows? I had to start the test a few times, becasue I have to miss the trees etc too.
It's the wedding venue next door... but I can't rough it up too much, because the owners (and very good friends of mine) are getting married there this weekend!
To start the test, I applied firm brake pressure. The ABS light was on, and the traction control light comes on with the brake pressure. Then on the failed attempts, the traction light would turn off, and the ABS light remained on. After a couple of tries, both lights were on to show the test started, but the ABS light turned off at the end, and left the traction light on - I think that was the run that triggered the G200 and G202 codes?
Does anyone think I just need to find a flatter spot, or have I really got an issue? My wheelbase is 100mm longer than the golf the drivetrain is from, but I wouldn't think it was enough to throw off it's plausability calculations???
Thanks! :thumbs:
Allan.
NZDubNurd
New Zealand
C?ID=230482
P.S. The R32ran is currently showing an average speed of 14km/h and 19.4L/100kms! (8.7MPH and a bit over 12 US MPG, or 14.5 UK MPG) I hope the whole lot of them improve when I start driving "normally"
NZDubNurd
New Zealand
C?ID=230482
P.P.S. My steering rack is the Touran one, not a 4motion one - does that make any difference? Is 44 Steering assist, I can only set the DSR (driver steering recommendation) to 0 which is "ON - MK60-AT" or 1 which is "OFF - MK70 ASR", if I choose 2 which 's "ON - MK60 AWD" the save button is greyed out, and the stored value stays at the previous value.
related???
   #212
NZDubNurd
New Zealand
C?ID=230482
right.
Longitudinal acceleration sensor - G251: Should I be expecting a +ve value when accelerating, and -ve when braking?
What about transverse acceration? Should positive be left or right?
I have flipped the G419, because some genius at VW decided the sensor should be basically the same shape, but mounted up the other way for 4 motion cars!
NOW... I currently have +ve for acceleration, and -ve for right turn. I suspect I should be aiming for -ve for left turns though?
anyone know for sure?
   #213
Closest thing we could have available to check check would be 1K0-907-379-Q, but that's ESP FRONT MK60...
NZDubNurd
New Zealand
C?ID=230482
Thanks Uwe, I'm going to check what my other Touran reads, but it's ESP FRONT MK60-AT. I'd ASSUME they use the same direction values..... but VW aren't like that!
I've been searching like crazy to find an image of an installed G419 in a MK5 R32, but no luck so far. Diagrams appear to have it mounted the same way I have it mounted now, which is the same as the 8J TT, for which the manual shows the direction, but other models sometimes have them other way - just as the Q7 and A4 - obviously different platforms though!
I thought I had an image of it installed in the A3 donor, but I don't...
Thanks Uwe!
   #215
   #216
NZDubNurd
New Zealand
C?ID=230482
Exactly! Thanks ;-)
Yesterday I drove (illegally!) to a large carpark to attempt the System Function test. the whole way there, the traction control would cut power on corners!
On the way home, having failed to perform the test, the traction control light came on solid, and it stopped cutting power on corners! I then had the G251 Lateral Acceleration sensor - implausible signal.
I turned the sensor, to get positve readings on acceleration, and it doesn't cut the power after clearing the codes. I haven't returned to the carpark yet either!
My 2WD Touran has a negative value on left turns, so perhaps that is correct!
I have a friend nearby with an R32 Golf, but it's a 2009, so I suspect it maybe MK60EC1??? without the external sensor :-( I'll check though.
I believe all 4motion PQ35s have the G251, and a few 2WD's do, that have hill start assist or some other unusual features.
I just need to get the orientation correct, before I go driving over the countryside in a car that hasn't been road legal for a year :thumbs:
Especially, because the carpark I used is around the Community Police Constables building :-)
   #217
golfi_vend
Tartu, Estonia
C?ID=195131
If You'd write me directly with channels and values You need i can check my MK5 4motion, with exact same p/n ABS.
I kinda get confused around this thread. :)
Results can be posted later...
