VCDS - NEW CAR Seat Leon 1.4 ST FR 2018 (facelifted)
JazzDK
Copenhagen
C?ID=285115
Hi Guys,
I have some problems coding my new car.
Lights in: 09 - Cent -Elect: (similar problems in "17 - instruments")
Coding -07
Long coding is not possible and not visible, also in other channels I have been in.
Adaption -10
Changes is possible, and the car do accept some of the coding, but not all are visible.
If this car is so new, what do you guys need from me to be able to update VCDS at some point.
I have had a previous model, not facelifted, witch worked fine. It is the same car model visual out site with some small changes.
Wednesday,04,July,2018,17:09:15:33767
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4427.4
VIN: VSSZZZ5FZJR169093   License Plate:
Mileage: 223km-138mi   Repair Order:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 02 03 08 09 13 15 16 17 19 42 44 4B 52 5F D6 D7
VIN: VSSZZZ5FZJR169093   Mileage: 223km-138miles
Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HF    HW: 04E 907 309 BJ
   Component: R4 1.4l TFS   H24 3744
   Revision: R6H24---
   Coding: 01250012236419082000
   Shop #: WSC 00049 770 00174
   ASAM Dataset: EV_ECM14TFS01104E906027HF 001007
   ROD: EV_ECM14TFS01104E906027HF.rod
   VCID: 6FAE05ADB61EEB3CCE-803A
   CAN Converter 01:
   Part No SW: 0CW 300 041 Q    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1602
   Revision: 00005008    Serial number: CU501805147800
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_AU27.rod
   VCID: 43C6991DCA163F5C7A-8016
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 61428000002426
   Coding: 19EE6A92242621758777060960C62498562484E1600624731822F074C202430B00000012121212B835351919323200
   Shop #: WSC 00049 770 00224
   ROD: EV_Brake1UDSContiMK100IPB_037_VW27.rod
   VCID: 0346591D8A96FF5C3A-8056
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 43
                    Mileage: 41 km
                    Date: 2018.07.04
                    Time: 08:08:24
   Part No SW: 5F0 907 044 AL    HW: 5F0 907 044 AL
   Component: Climatronic   H05 1801
   Revision: 00001K09
   Coding: 02000004200114011005000000101020
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 70AC06D1AB20F4C4D7-8024
   Air quality sensor:
          B10CD 00 [008] -  -
                    Reset counter: 43
                    Mileage: 41 km
                    Date: 2018.07.04
                    Time: 10:07:23
                    Voltage terminal 30: 10.9 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up light: OFF
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001814500428
   ROD: EV_BCMCONTI.rod
   VCID: 095A4B35A8BAA50C70-805C
   Subsystem 1 - Part No SW: 5F1 955 119 A    HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 180426  041 0574
   Serial number:         180508111609
   Coding: 0BC5FD
   Serial number: 21426500X81A955555A0
   Coding: 00005D
5642 - Bulb for Rear Left Turn Signal
          B11E9 15 [008] - Open or Short to Plus
                    Reset counter: 43
                    Mileage: 39 km
                    Date: 2018.07.03
                    Time: 12:36:51
10506 - Bulb for Left Tail Light
          B12BE 15 [008] - Open or Short to Plus
                    Reset counter: 42
                    Mileage: 39 km
                    Date: 2018.07.03
                    Time: 12:34:46
10762 - Bulb for Right Tail Light
          B12BF 15 [008] - Open or Short to Plus
                    Reset counter: 42
                    Mileage: 39 km
                    Date: 2018.07.03
                    Time: 12:34:46
12298 - License Plate Light
          B12CA 15 [008] - Open or Short to Plus
                    Reset counter: 42
                    Mileage: 39 km
                    Date: 2018.07.03
                    Time: 12:36:54
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Coding: 3500678159FF8728949C814580400600000000000000000000
   VCID: 3C34E2E1B7E840A43B-8068
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4PAAQ6H4
   Coding: 98CCC000000000005C5400CC000800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0542470584A2C16C14-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 000 905 18
   Serial number: 357000000001E3E00138
   Subsystem 2 - Part No SW: -----------    HW: 454 001 005 18
   Serial number: 3580000000017BFC113O
   Subsystem 3 - Part No SW: -----------    HW: 454 801 405 18
   Serial number: 351000660B8140000002
   Subsystem 4 - Part No SW: -----------    HW: 454 801 505 18
   Serial number: 352007570B814000000A
   Subsystem 5 - Part No SW: -----------    HW: 454 801 505 18
   Serial number: 3550079DAA114000000P
   Part No SW: 5Q0 953 507 HB    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 19051804220036
   Coding: 6410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 7DB22FE5EC7289AC4C-8028
   Part No SW: 5F0 920 790     HW: 5F0 920 790
   Component: KOMBI         512 0630
   Coding: 04A452082F800008018862011000000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001029
   ROD: EV_DashBoardVDDMQBA0_SE27.rod
   VCID: 6680608999E42A74BD-8032
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0008018640
   Coding: 030100F42F085738EB0002581C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_SE27.rod
   VCID: 383CFEF183D06C84DF-806C
   Subsystem 2 - Part No SW: 5F0 959 537 D    HW: 5F0 959 537 D
   Serial number: 000000000H0681040518
   Coding: 012000
   Serial number: 7588600000180518237A
   Serial number: 0000321602965
   Coding: 00140320DC00040000001000
   VCID: 47DE8D0DFE2E137CA6-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000021382320
   Coding: 310000
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73A609DDDA36CFDC2A-8026
   Serial number: 13051810802521
   Coding: 000000070100094200000900000000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X.rod
   VCID: 72A80CD9A52CC6D421-8026
   Serial number: 0000319373883
   Coding: 00140320DE00040000001000
   VCID: 46C08009F9240A745D-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000021390986
   Coding: 290000
   Part No SW: 5QA 035 874     HW: 5QA 035 874
   Component: MU-S-ND-ER    H41 0472
   Serial number: SEZAZ2U0379484
   Coding: 04738201FF0A00001111000100080A002F0101E401200400C6
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_MUStd6C3TSAT 001015
   ROD: EV_MUStd6C3TSAT_SK25.rod
   VCID: 02485C19958CF65431-8056
   Subsystem 1 - Part No SW: 5F0 919 606     HW: 5F0 919 606
   Component: ABTm-2_8-CR  H41 1042
   Serial number: SEZ8Z9V6C02VZ3
   Subsystem 2 - Part No SW: 6P0 919 866 AB    HW: -----------
   Component: ECE1 2018  --- 0915
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 7EB028E9E17492B455-802A
   ROD: EV_LED_PLUS_R_KEBODAVW416.rod
End----------(Elapsed Time: 01:48, VBatt start/end: 12.7V/12.7V)-----------
You BCM at address 09 is the newer MQB style with a coding string of all zeros, meaning that all the things that were previously in coding have been moved to Adaptation channels. Some channels may require a security access code. Feel free to post a map of the channels.
Is there something specific you wish to change?
JazzDK
Copenhagen
C?ID=285115
Thanks Uwe for replying, we can't keep meeting like this ;)
I guess you also need a loong security code instead of the 5 digit one.
Fog light together with highbeam
1.	Select 09 – Cent. Elect.
2.	Select 16 – Security Access
3.	Enter Unlock Code 31347 -
4.	Select 10 - Adaptation
Leuchte12NL LB45-Lichtfunktion C 12 - Stored value "Lichthupe generell" (Active)
Leuchte13NL RB5-Lichtfunktion C 13 - Stored value "Lichthupe generell" (Active)
I can code this, but it is not visual working
ESC menu - ESC Normal/ ESC sport/ ESC off
SEAT LEON 5F - ESP Off (3 Modes) FR, CUPRA
STG 03,
LongCoding,
Byte 29, change the last to hex-values to 06 = 00000110 [org=0000010]
before 00000011 (03)  Den er jeg ikke sikker på, men er det var 00000010 TJEK DET LIGE
after 00000110 (06 ESC Normal/ ESC sport/ ESC off) THIS I WHAT I NEED TO BE DONE
or 00000101 (05 ASR Off+ESC OFF)
or 00001001 (09 ASR + ESC Sport)
03 abs -
02 only ASR -
09 ASR + ESC Sport -
05 ASR OFF + ESC OFF -
06 ESC Sport + ESC OFF
ESC SPORT - You can then press the BRAKE and SPEED pedals at the same time with ABS funktional.
MAP CHANNELS:
I can post them when I get the car back from the shop
^^^ yes: post-up the BCM admap so that we can see how the 2 x Leuchte-sets for the front fogs are factory configured (and also because I want a copy of an admap for this new-ish BCM for my database -please)
yxcvbnm
Croatia
C?ID=333170
I also have new Leon facelift, let me know if you need anything from it :)
JazzDK
Copenhagen
C?ID=285115
I will as son I get it back from the shop. Right know I'm driving the new "Seat Ateca", I love it, but too expensive :)
What version do you have and what extras is added to your car?
mine is with: Virtuelcockpit, LED headlight, 8" with Navi, Adaptive cruise control, (P sensors and revers cam, will be added later)
^^^ Jazz- I don't understand "too expensive"? The only value that money has is when it's spent - "too expensive" is your bank manager's problem, not yours !!;)
my suggestion -carp diem
JazzDK
Copenhagen
C?ID=285115
LOOL, you have a point there ;) It is still over my budget ;) Cars in Denmark are really expensive!!
ex VW Golf Highline no extras = $46.199 - I could buy a nice big truck in the US for that money
JazzDK
Copenhagen
C?ID=285115
And in Yellow, hehe
Got my car back
03 - ABS Breaks
;SW:5Q0-614-517-CR   HW:5Q0-614-517-AD ---  ABS Brakes
;Component:ESC           H25 0523, Coding:19EE6A92242621758777060960C62498562484E1600624731822F074C202430B00000012121212B835351919323200
;EV_Brake1UDSContiMK100IPB,037009,EV_Brake1UDSContiMK100IPB_037_VW27.rod
;Sunday,22,July,2018,20:22:33:33767
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
;VCID: 0346591D8A96FF5C3A-8056
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03493-Driver door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-Electromechanical parking brake,not activated ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire pressure monitoring display,2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake booster,4 ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,2 ,1
IDE07292-Brake pre-filling,not completed successfully ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
IDE12030-Rough road optimization,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,activated ,1
ENG118148-Developer_Function_1,0 ,1
ENG130301-Developer_Function_121,not activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,100 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,150 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,2 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,2 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,5 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,40 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,82 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,100 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,150 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,2 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,2 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,5 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,40 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,82 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
Elapsed Time: 00:16
09 - Cent-Elect
;SW:5Q0-937-084-CQ   HW:5Q0-937-084-CG ---  Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H   H36 0253, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,018001,EV_BCMCONTI.rod
;Sunday,22,July,2018,20:08:21:33767
;VCID: 095A4B35A8BAA50C70-805C
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active ,3
IDE01550-Service position,162.703135 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,16 s,8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,127.5 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °,16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,not active ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04928-MAS01577-Anti-theft device-Parking heater,not installed ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,not active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),Yes ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 49 00 00 0B 1E 7F 1E 00 7F 00 00 00 00 00 00 05 4D 00 00 0C 1E 7F 1E 00 7F 00 00 00 00 00 00 06 52 00 5D 46 08 7F 09 3A 7F 00 00 00 00 00 00 06 53 00 5E 46 08 7F 0A 3A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 38 00 22 12 16 64 0F 00 64 00 00 00 00 00 00 06 42 00 23 13 17 64 0F 00 64 00 00 00 00 00 00 ,224
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,10 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,1.10 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,21.703275 °,2
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,not active ,6
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,0 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,1 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,5 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,30 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,100 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,100 %,19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Sollspannungsanforderung 13.5 ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
IDE10298-Alternating park position 1,7.703289 °,2
IDE10299-Alternating park position 2,26.703270 °,2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,0.00 ,256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.00 ,256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,0.00 ,256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,0.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,0.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,1.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000001  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00010000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000100  ,256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,0 %,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,0 %,256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,0 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,0 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,0 %,256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,0 %,256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,0 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,0 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,0 %,256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,0 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,0 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,0 %,256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,0 %,256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,0 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,0 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,0 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,0 %,256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,0 %,256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,0 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,0 %,256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,0 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %,256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,0 %,256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,0 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,0 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,100 %,256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,0 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,0 %,256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,0 %,256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,0 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,0 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,0 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,0 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,0 %,256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,0 %,256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,0 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,0 %,256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,0 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,0 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,0 %,256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,0 %,256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,0 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,0 %,256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,0 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,0 %,256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,0 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,0 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,0 %,256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,0 %,256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,0 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,0 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,0 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,0 %,256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,0 %,256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,0 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,0 %,256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,0 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,0 %,256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,0 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,0 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,0 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,0 %,256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,0 %,256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,0 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,0 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %,256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,0 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,0 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,0 %,256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,0 %,256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,0 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,0 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,3200 ms,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,246 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,213 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,251 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,255 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,207 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,34 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,56 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,237 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,218 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,255 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,230 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,255 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,114 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,255 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,36 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,44 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,193 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,255 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,245 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,255 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,246 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,not installed ,3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,254 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,83 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,103 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,48 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,27 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,115 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,255 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,254 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,254 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,220 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,201 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,53 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,254 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,12 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,139 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,169 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,254 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,252 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,254 ,30
MAS05055-lower turn position,21.703275 °,2
MAS05056-upper turn position,162.703135 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,multicolor ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,1 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,2 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,3 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,4 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,04 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,5 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,8 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,9 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,installed ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,60 km/h,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,18 lx,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,true ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,30 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,30 seconds ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
ENG122934-erase_error_table,55 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: Fernlicht ueber AFS ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present ,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,not active ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,0 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,active ,6
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-100.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-100.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-100.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-100.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-100.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-100.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,0.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,0.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,0.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,0.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,0.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,0.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,0.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,0.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,0.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,0.0 %,30
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,06 ,16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,100 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,Lichthupe generell ,16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,100 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,Lichthupe generell ,16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,minimize ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,41 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,08 ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Blinken links Dunkelphase ,16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,minimize ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,42 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,18 ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Blinken rechts Dunkelphase ,16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,minimize ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links Dunkelphase ,16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,minimize ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts Dunkelphase ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light ,16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,00 ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,minimize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,127 ,16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,10 ,16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,10 ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Coming Home oder Leaving Home aktiv ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Daytime running lights ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,Blinken links aktiv (beide Phasen) ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,127 ,16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,20 ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Daytime running lights ,16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,minimize ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,127 ,16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,10 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,35 ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0A ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,Coming Home oder Leaving Home aktiv ,16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,Brake light ,16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,Blinken links aktiv (beide Phasen) ,16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,minimize ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,127 ,16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,10 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,36 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,Parking light right ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Coming Home oder Leaving Home aktiv ,16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,Brake light ,16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,Blinken rechts aktiv (beide Phasen) ,16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,33 ,16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,0C ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,34 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,18 - 2* 5W ,16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,00 ,16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,49 ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Coming Home oder Leaving Home aktiv ,16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,00 ,16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,4D ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Coming Home oder Leaving Home aktiv ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,5D ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,52 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,beidseitiges Dauerparklicht ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,5E ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,53 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Parking light right ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,beidseitiges Dauerparklicht ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,30 08 00 16 02 00 7F 03 00 80 00 00 00 00 00 00 30 18 00 18 04 00 7F 05 00 80 00 00 00 00 00 00 31 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 31 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 31 00 00 2C 18 24 64 00 00 00 00 00 00 00 00 00 2F 10 00 29 08 09 7F 1E 14 7F 06 00 8A 00 00 00 2F 20 00 2A 08 0A 7F 1E 14 7F 00 00 00 00 00 00 2B 28 00 30 08 1E 7F 00 00 00 00 00 00 00 00 00 2F 0A 00 35 08 09 7F 1E 18 7F 06 00 8A 00 00 00 2F 1A 00 36 08 0A 7F 1E 18 7F 07 00 8A 00 00 00 2F 0C 00 33 1A 00 FF 00 00 00 00 00 00 00 00 00 09 1B 00 34 19 00 E4 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,30 08 00 41 02 00 FF 03 00 80 00 00 00 00 00 00 30 18 00 42 04 00 FF 05 00 80 00 00 00 00 00 00 12 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 06 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2650 mm,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,84.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,20.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-127.0 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,4.10 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,4.70 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,4.50 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.30 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.30 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,3.30 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,70.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,10.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,Inverted ,62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Positive ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,10 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,10 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,10 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,10 mm,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,5 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,10.00 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,not active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,15.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,5.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,14.0 %,62
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,20.0 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,30.0 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,40.0 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,50.0 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,100.0 ,12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,10.0 %,12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,20.0 %,12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,40.0 %,12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-3.71 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-2.96 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-2.04 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-1.48 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-0.37 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-0.20 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-0.10 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-0.05 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-0.01 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.00 ,20
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,1 ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,not active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Seat ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,not active ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Keine_Spannungsanforderung ,5
ENG122927-RLS_close_glazing,2.5 s,1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,100 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,200 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,500 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,500 ms,10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,10.0 min,10
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,1.1 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.200 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,0.0 %,21
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,80 lx,22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,150 lx,22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,300 ,22
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,5.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,5.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,15.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,40.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,82.0 %,12
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,Open ,4
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,No ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Pulse control ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
Elapsed Time: 02:11
