B9 A4 / allroad Matrix LED Retrofit
meijerbrantm
C?ID=95679
Been working on a Matrix LED retrofit. I'm at a pretty decent point, the hardest part was getting the modules flashed but VCP was finally able to do that eventually.
I think I'm pretty much to the point of getting the Matrix LED's calibrated so that the high beams will begin to work. Here's my auto scan of the vehicle.
Thursday,07,June,2018,16:35:27:30225
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(Parallels)
VCDS Version 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
VIN: WA19NAF4XHA148620   License Plate:
Mileage: 33786km-20993mi   Repair Order:
Chassis Type: F4-AU49 (8W8)
Scan: 01 02 03 08 09 13 15 16 17 19 22 29 36 39 3C 42 44 46 47 52
          5F 6C 6D 74 81 82 8B A5 BB BC CA CF D6 D7
VIN: WA19NAF4XHA148620   Mileage: 33786km-20993miles
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CYMC)       Labels: None
   Part No SW: 8W0 906 259 J    HW: 06L 907 425 C
   Component: 2.0l R4 TFSI  H15 0002
   Revision: --H15---
   Coding: 326500322366010E34280000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
   ROD: EV_ECM20TFS020_AU49.rod
   VCID: 48DCAACFF3C5EA04AF-801D
Readiness: 1010 0101
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 155 J    HW: 0CJ 927 156
   Component: 0CJ 20TFSINAR H03 0002
   Revision: --H03---    Serial number: 0000001745
   ASAM Dataset: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_AU48.rod
   VCID: 302CE22F6B5542C497-8065
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071170049002168
Address 03: ABS Brakes (J104)       Labels:. 8W0-907-379-PRE-V1.clb
   Part No SW: 8W0 907 379 H    HW: 8W0 907 379 D
   Component: ESP9 Premium  H09 0719
   Coding: 18AA409928A62A9E91A44893207D52A2E6259A180214548912044A4567A459
   Shop #: WSC 06334 790 00001
   ASAM Dataset: EV_ESP9BOSCHCMP 001001
   ROD: EV_ESP9BOSCHCMP_001.rod
   VCID: 4AD890C7EDC91814B9-801F
200960 - Databus
          U1123 00 [047] - Received Error Message
          [Signal_LWR_Hoehenwert_VL_error_(255)]
                    Mileage: 33754 km
                    Date: 2018.06.07
                    Time: 11:53:50
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 H    HW: 8W0 820 043 H
   Component: Klima Zone 3  H32 0090
   Coding: 240809085548010D10020100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 383CDA0F83259A84DF-806D
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J216 FLuftV  H08 0003
   Serial number: 00000000000001381981
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 9379C59880PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158 A    HW: 8W0 919 158 A
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07500B63C13900CD051751195CAF98B9110B3D080000000000000000200016810A45022B025709
   Shop #: WSC 12345 123 61029
   VCID: 024878E79579005431-8057
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 170201  043 0813
   Serial number: 89435300301703200408
   Coding: 5BC7F7
   Serial number: 20296446X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
   Component: E1 - LDS  H06 0008
   Serial number: 04 07 2016  00695960
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0050
   Serial number: 0000009600335Z32Z002
   Coding: 350000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20170221114259 00510
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE103011711520689
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 8W0 947 135 CS    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00288587
   Subsystem 8 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2616000199313006
   Seat Backrest Fan 1 Front Left:
   Subsystem 9 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V512 LLR1SLvL  H03 0012
   Serial number: L14DG36200481
   Seat Cushion Fan 1 Front Left:
   Subsystem 10 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V514 LLR1SKvL  H03 0012
   Serial number: L14DG36200261
   Seat Backrest Fan 1 Front Right:
   Subsystem 11 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V516 LLR1SLvR  H03 0012
   Serial number: L14DG36201118
   Seat Cushion Fan 1 Front Right:
   Subsystem 12 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V518 LLR1SKvR  H03 0012
   Serial number: L14DG36200312
66707 - Image processing control module
          U1079 00 [009] - No communication
                    Reset counter: 145
                    Mileage: 33754 km
                    Date: 2018.06.07
                    Time: 11:53:54
                    average_Voltage_terminals: 14.30 V
                    Outside air temperature sensor-Outside air temperature on CAN: 28.00 °C
                    interior_temperature: 33.50 °C
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: On
                    Terminal control-Terminal 15 status signal: On
                    Terminal control-Terminal 15 via CAN: On
                    Terminal control-Term 75: qualification: OFF
66881 - Databus
          [Left LED headlamp power output module: incorrect data record]
                    Reset counter: 184
                    Mileage: 33754 km
                    Date: 2018.06.07
                    Time: 11:53:51
66882 - Databus
          [Right LED headlamp power output module: incorrect data record]
                    Reset counter: 184
                    Mileage: 33754 km
                    Date: 2018.06.07
                    Time: 11:53:51
67735 - Databus
          [MxB not available]
                    Reset counter: 144
                    Mileage: 33754 km
                    Date: 2018.06.07
                    Time: 11:53:51
131955 - Unknown Error Code
          U134F 00 [009] - -
          [EFP control module: implausible message in signal FA_height-value_FL_00]
                    Reset counter: 144
                    Mileage: 33754 km
                    Date: 2018.06.07
                    Time: 11:53:51
131956 - Unknown Error Code
          U134F 00 [009] - -
          [EFP control module: implausible message in signal FA_height-value_RL_00]
                    Reset counter: 144
                    Mileage: 33754 km
                    Date: 2018.06.07
                    Time: 11:53:51
   Part No SW: 8W0 907 561 B    HW: 8W0 907 561
   Component: LRR4          H10 0220
   Coding: B4779FF258FFEC09949880A1
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 3D32CB1BAC07BFAC0C-8069
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 144
                    Mileage: 33757 km
                    Date: 2018.06.07
                    Time: 12:15:17
                    Control Module temperature: 59 °C
                    Voltage terminal 15: 13.0 V
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 G    HW: 8W0 959 655 G
   Component: Airbag10.44   H05 0104
   Serial number: 003UQ000JGX+
   Coding: BFCCF0C000800000A0000033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005015
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 4DD29BDB1CA70F2C9C-8019
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 8W0857705C0062R01681
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 8W0857706D0067R00315
   Coding: 80000D
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J170006UDPJ0.
   Subsystem 4 - Part No SW: -----------    HW: 442 060 303 17
   Serial number: 3577Y00C1209FF449389
   Subsystem 5 - Part No SW: -----------    HW: 442 060 303 17
   Serial number: 3587Y00B31FD7524C39D
   Subsystem 6 - Part No SW: -----------    HW: 442 0B1 502 17
   Serial number: 3517700222A53DB9A82E
   Subsystem 7 - Part No SW: -----------    HW: 442 0B1 502 17
   Serial number: 3527700142A53DB8F8CU
   Subsystem 8 - Part No SW: -----------    HW: 442 0C0 903 17
   Serial number: 3557500C121E5F93515C
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C0 903 17
   Serial number: 3567500C921E5F95142J
   Part No SW: 4M0 907 129 GS    HW: 4M0 907 129 GS
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 075E69F3BE5B257C66-8053
   Part No SW: 8W5 920 890 C    HW: 8W5 920 890 C
   Component: FBenUSA       H17 0309
   Coding: 08CF99C3FC89CF0502A769601804400008000000
   ASAM Dataset: EV_DashBoardAU736 001022
   VCID: 43C6BDE3CAE3C95C7A-8017
16777046 - Charger for HV Battery
          U1139 00 [009] - No Communications
          [BAP_BatteryControl_0x25 communication error bap_error_timeout heartbeat]
                    Fault Frequency: 47
                    Reset counter: 145
                    Mileage: 33754 km
                    Date: 2018.06.07
                    Time: 11:53:49
   Part No SW: 8W8 907 468 D    HW: 8W8 907 468 D
   Component: Gateway       H30 0308
   Revision: 5D010003    Serial number: 0385D281717309
   Coding: 03010001000006402907000000590030DCB20007000000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
   Component: J453 MFL  H06 0002
   Serial number: 20170302233716 02696
   Serial number: 6936703304
Address 22: AWD (J492)       Labels:* None
   Part No SW: 8W9 927 755     HW: 0CJ 927 749
   Component: B9_DL3_H_SD5  H01 0004
   Serial number: 1625815576
   Coding: 11040000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: 0B5655C3A233411C42-805F
   Part No SW: 4M0 907 397 AD    HW: 4M0 907 397 D
   Component: LCM_MLBevoH05 0022
   ASAM Dataset: EV_LCMLeftHELLAAU736 001011
   VCID: 79BA1F0BF8AF438C60-802D
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 00000246014727
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   ROD: EV_SCMDriveSideCONTIAU736.rod
   VCID: 76A01437C9B12CF40D-8023
   ASAM Dataset: EV_LCMRightHELLAAU736 001011
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 3620D43789316CF4CD-8063
   Part No SW: 4M0 959 793 E    HW: 4M0 959 793 C
   Component: TSG FS        009 0057
   Serial number: 0000245151150
   Coding: 005D1B215E001080000100B2
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   VCID: 40CCB2EFDBF5D24467-8015
   Part No SW: 8W0 909 144 G    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0409
   Coding: 0D008380008080
   ASAM Dataset: EV_EPSZFAU49X 003018
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 41CAB7EBD0FFDB4C68-8015
   Part No SW: 8W0 907 064 CC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   018 0344
   Coding: 013400004F9100C0630BA0006E01080233004000014727502F0400000F04803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 7F4EF113E68B6DBC5E-802B
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY170381JFK
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000068897909
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0904
   Serial number: >1056806
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAGJA01C0U1
   Coding: 0194420800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   Part No SW: 4M0 959 792 E    HW: 4M0 959 792 C
   Component: TSG BFS       009 0057
   Serial number: 0000245521922
   Coding: 005D1B215E001080000100B0
   ROD: EV_DCU2PasseSideMAXHCONT.rod
   VCID: 3FCEB113A60BADBC1E-806B
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880     HW: 8W5 035 880
   Component: MU-P-LNS-US   033 0918
   Serial number: A798C0HB017395
   Coding: 019442020000000053220002041A00102F000CE501700904BE
   VCID: 7CB4061FF79D76A47B-8029
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
   Component: DU High AU49x  H32 0160
   Serial number: TPO00109011700820240
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK113021700040027
   Compact Disc Database:
   Component: Gracenote2  --- 3011
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 144
                    Mileage: 33757 km
                    Date: 2018.06.07
                    Time: 15:36:00
                    Voltage terminal 30: 12.4 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H13 0315
   Serial number: C854607JG013564
   Coding: 02940202BA0FA10008404000
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   VCID: 3424EE3F9F4D7EE4F3-8061
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 31242474100000
   Coding: 0570
   ROD: EV_DeckLidCONTIAU736_AU49.rod
   VCID: 3228E827655970D4E1-8067
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 8W0 907 777 H    HW: 8W0 907 777 C
   Component: Fahrwerk-SG   H35 1214
   Serial number: 1003170095
   Coding: 1051506118
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   VCID: 4CD496DFE7BD06248B-8019
   Part No SW: 8W1 713 041 L    HW: 8W1 713 041 J
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170303002311
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 3C34C61FB71DB6A43B-8069
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 8W5 919 617 B    HW: 8W5 919 617 B
   Component: HeadUpDisplay H17 1603
   Coding: 4F01E0
   ASAM Dataset: EV_HudNSEIKAU736 001015
   ROD: EV_HudNSEIKAU736_AU49.rod
   VCID: 47DEA9F3FEDBE57CA6-8013
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 8W0 907 541 B    HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 3B36C503B213B19C32-806F
   Part No SW: 8W0 907 217 B    HW: 8W0 907 217
   Component: BVS           H15 0042
   Coding: 0404090200000202022023A6AD0000FCB0F0C023E280
   ROD: EV_BVSMLBevKOSTAAU736.rod
1122640 - Databus
          [TIMEOUT_SARA_08]
                    Reset counter: 145
                    Mileage: 33757 km
                    Date: 2018.06.07
                    Time: 12:23:26
                    Control Module temperature: 69 °C
                    Voltage terminal 15: 13.20 V
13679104 - Databus Front Lights
          U1504 00 [009] - No Communications
          [AFS_CAN_no_communication]
                    Reset counter: 144
                    Mileage: 33757 km
                    Date: 2018.06.07
                    Time: 12:23:26
1123669 - Left Matrix High Beam
          C1175 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 144
                    Mileage: 33757 km
                    Date: 2018.06.07
                    Time: 12:23:25
                    Control Module temperature: 68 °C
1123670 - Right Matrix High Beam
          C1176 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 144
                    Mileage: 33757 km
                    Date: 2018.06.07
                    Time: 12:23:25
0660 - No Basic Setting
          B2010 00 [009] -  -
          [Initial_calibration_missing]
                    Reset counter: 144
                    Mileage: 33757 km
                    Date: 2018.06.07
                    Time: 12:23:25
                    Voltage terminal 15: 13.10 V
   Part No SW: 4M0 959 795 E    HW: 4M0 959 795 C
   Component: TSG HFS       009 0057
   Serial number: 0000246569818
   Coding: 000D1B2000001080400000A0
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 42C8B8E7D5F9C05471-8017
   Component: TSG HBFS      009 0057
   Serial number: 0000245539627
   ROD: EV_DCU2RearPasseMAXHCONT.rod
   Part No SW: 4M0 907 594     HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 208000049202
   VCID: 73A62D23DAC339DC2A-8027
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   VCID: 3326ED239A4379DCEA-8067
   Part No SW: 7PP 941 571 BB    HW: 7PP 941 571 B
   Component: LED1L         H09 0003
   VCID: 166034B7E9F18CF4ED-8043
0019 - Headlamp Type
          C119F 00 [008] - Implausible
                    Reset counter: 184
                    Mileage: 33754 km
                    Date: 2018.06.07
                    Time: 11:53:49
0304 - Databus
          [can message MXB_Soll_Fktx missing]
                    Reset counter: 144
                    Mileage: 33754 km
                    Date: 2018.06.07
                    Time: 11:53:49
   Component: LED1R         H09 0003
                    Reset counter: 184
                    Mileage: 33754 km
                    Date: 2018.06.07
                    Time: 11:53:49
0304 - Databus
                    Reset counter: 144
                    Mileage: 33754 km
                    Date: 2018.06.07
                    Time: 11:53:49
End----------(Elapsed Time: 02:25, VBatt start/end: 12.3V/12.3V)-----------
Anyone know the possibility of how to put in calibration parameters? I was trying the basic headlamp settings in the in Central Electronics but that just says "not running" and I never receive any form of prompts. Looking at Elsa, it seems like that should be kind of the direction you need to go.
There was also these in A5, but any thing i clicked here related to Matrix says "Error: Service not supported in active session"
Then I also clicked start calibration mode and now my lane assist and stuff is all faulting. I saw another thread on here where someone had to go to the dealership to get that reset. Wasn't sure if it was the full calibration or not.
I'm also not sure on the error about the Image processing control module. I read a thread about that and someone said that it eventually just went away, but I'm not seeing that.
Anyways this is where I stand. The low beams, DRLS, and sweeping turns all work correctly. The coding that I have currently is a mix between what my factory coding is and from an actual B9 with Matrix lights.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Welcome to the forum! And thank you for the detailed first post.
I have been farting around with High Beam / Dynamic Light Assist recently on my 2018 Golf R with MLBevo LED AFS, with decidedly mixed success, so I have some limited familiarity with this topic.
What exactly did you replace and/or reflash?
These LED control modules are stock, or at least the same part number as as factory, per PL24.
These LED power modules are... a downgrade from factory? Your factory part was 7PP 941 572 AB which GIS shows labeled with "LED LEIMO MAX". Your installed modules are 7PP 941 571 BB which GIS shows labeled with "LED LEIMO MIN + LIN".
I think your BCM is stock, I can't quite line up the part number with PL24 but it may have been superseded. You have no address 55 headlight range control or 4B multifunction module to take care of the headlight magic, so this has to be coming from the BCM, and I'm not even sure you can have BCM-driven Matrix LEDs.
What exactly did you replace? What retrofit guide are you working from? I haven't worked directly with a true Matrix LED setup before, but this looks very much like the more basic MLBevo LED AFS setup available in NAR.
meijerbrantm
C?ID=95679
Hey thanks for the response. I'm pretty new to this entire retrofit. It's actually only been done by one person at this point that I know of. He had some connections with some people with Audi so I think he was able to get this going more or less. He mentioned that he had the PR updated for his VIN of his vehicle and that allowed him to just use ODIS since that recognized his car having Matrix from the factory. I of course don't have that luxury so we need to just move forward with what I have. If we can make a breakthrough and get this figured out for the entire community that would be awesome.
So excuse me for not being really intelligent on all of the things related to this process, but let me speak with the knowledge I have. My car has OEM LED's with the normal like Auto High Beam headlight assist piece so it was all originally coded for that. With the Matrix LED, the same LED control module is used as mentioned before. The power modules are what are different. So to give some history, I originally had the modules purchased OEM. These modules come unflashed. I was having a hard time getting them flashed, but I'm working with Alex at Europrice on this project and he was actually able to get them flashed. We also got a pair of these power modules from Europe that came, flashed from a Matrix vehicle. If I swap those out with the ones that are currently in the vehicle, I get the same results. So these were flashed with a provided Matrix profile via VCP on my one set, and OEM from the other.
The coding that I've performed came directly from a Matrix equipped vehicle. I only made adjustments so I had a lot of the other items work on the car (my hatch motor, my cameras, parking sensors, etc.). I have all of the same errors that I did with the other setup, just less in regards to the rest of the items that I just mentioned. I'm not thinking it as easy as you may be mentioning. I believe the B9 has all of the equipment available for doing the Matrix setup, but there is something not coded properly, nor calibrated. Maybe my BCM is missing something and maybe I should look into VCP for some more of that information, but honestly I'm in a little over my head when talking about all of these items but I'm enjoying learning what I can.
You're right on the address 55. I'll have to see if I can find a scan of my car prior to putting these in and seeing if that address showed up at all. In the mean time any other random ideas you may have would be great.
spyderboyant
Australia
C?ID=65474
Hi there,
I think you have missed quite a bit of stuff looking at the errors on your BCM1.... For starters, for Matrix lights there is a 2 wire bus directly from the A5 camera to J519 (I think this is what this error is: 66707 - Image processing control module U1079 00 [009] - No communication). Also, you need to check your wiring because with steel springs you need both a FRONT and REAR level sensor (this error: [EFP control module: implausible message in signal FA_height-value_FL_00]_ and once installed, this needs to be coded in BCM2.. Air suspension on the other hand requires four level sensors, one on each wheel axle. With all those errors in your VCDS module dump I reckon the controller will refuse to update it's basic settings.. I have been trying to do this retrofit on a Q7 4M and that hardest thing for me is trying to find a Q7 with steel springs and matrix lights to copy the coding from. Every set of coding I have is for air-suspension with with Matrix lights. The difference between steel springs and air-suspension with the Matrix headlights is that there is an additional module for the air suspension that is responsible also for the level sensors and it sends the height information to J519 (BCM1) which in turn sends the information to the headlight controllers... With steel springs, BCM2 sends the height information to BCM1.
With calibration for Matrix, there are two places that need calibrating. One, A5 camera which uses a calibration board. Then J519 needs calibrating for matrix headlights. The information is in the factory repair manual for your car. With Matrix, there is a special tool that is used and the values are entered into ODIS. I don't think VCDS asks for those values but I could be wrong.
So my recommendation is to get rid of those errors on your J519 before trying to update the basic settings and then go to erwin.audi.com and purchase an hour access and download the factory repair manuals for your car and see what they say about calibrating Matrix headlights..
good luck
A
Bogdan.audi
Ukraine
C?ID=90275
Hey. 55 unit in this car is in BCM 1.
spyderboyant all right you wrote.
meijerbrantm
C?ID=95679
Hi there,
good luck
A
So I have been busy with other things these days and this retrofit went by the wayside. I just wanted to say that I appreciate your response and you were pretty spot on a lot of things.
First of all, the camera didn't have my extra two wires I needed. I ran wires and tapped into my BCM, but I don't have the ends yet to add those to the plug, they are arriving Saturday. I tried to just jam the wires in there to see if they would make contact, but I was unable to get a signal still so I'll have to wait, but that definitely was the case there. Just an FYI, the wiring diagram is completely incorrect on coloring for the wires used for this but I just looked at the terminals on the headlights and was able to find the appropriate wires going to the BCM.
Regarding the camera calibration, I figured this out as well. It was saying I had an implausible signal due to disabling the adaptive suspension in the Chassis Control module. I have an AirLift Performance setup on my allroad so I disabled this to not get the error on the screen. Once I added I flipped it back on, the suspension errors came back, but the camera calibrating procedure worked like a charm. The adaptive suspension does have 4 level sensors, which I thought was only a magride or factory air ride thing, but it appears they do it now on the adaptive as well. I'm going to try to do some looking on that A5's coding to see if there is another setting that could possibly still allow me to disable that, while keeping the level sensors functional.
Once this is all said and done, I'll be attempting the basic settings for the headlights hopefully early next week. Currently when I try to do it I get an error saying the camera could not be started which makes sense if I didn't have the CAN signal wired in. The only thing that confuses me is stepping through it in ODIS it does say "Vehicle has no EFP (active level control system)" and later on says "int_efp_auto=-1" which I would think it still has the sensors for it, but maybe the fact that I don't have something that actually adjusts the level of the vehicle (factory air) that it's just letting me know. I did just plug in my stock suspension just to see if it would make that go away, but it still gave me the same results outside of the fact that my suspension errors went away.
Hopefully should have this all working by next week as long as that EFP issue doesn't grow into something bigger. Again thanks for the assistance and heads up! Hopefully you've been able to get your Matrix retrofit on the Q7 going.
spyderboyant
Australia
C?ID=65474
no probs... last thing is you will need to o is update the dataset in your bcm1 module or else it won't be able to communicate with the headlight controllers... 2 methods... buys a sexond hand bcm1 thst came from a car with matrix headlights or get VCP which can "update" datasets... datasets is how cars can share modules between models....(ie q7 4m all a4 8w share same bcm1/j519 but dataset determines what car and features bcm1 supports) the dataset update shows up when you code everything correctly and you get a dataset error in J519... re datasets, different versions exist for q7 4m depending on whether you have, matrix headlights, heated seats, vented seats, ambient lighting etc... so just changing long coding and adaption channels for modules no longer guarantees a retrofit will work!
you will see the dataset and version in vcds "advancedID"... compare to cars with matrix lights and other features and you will see it's different.
good luck
meijerbrantm
C?ID=95679
good luck
Comparing my dataset with a similar car with Matrix, they are the same so I think I should be good to go then.
meijerbrantm
C?ID=95679
Just wanted to give a big shout out to everyone who helped in this thread. Especially spyderboyant. He definitely pinpointed a few things that led me back to my Chassis Control setting I changed, but in regards to the retrofit, all my other coding was correct. They are fully installed and working great! Hopefully now we'll start seeing more Matrix retrofits in the states.
spyderboyant
Australia
C?ID=65474
well done!
