2008 Jetta multiple codes
Check your grounds..........OP!
https://s7.postimg.cc/54r9yog97/F319.png
https://s7.postimg.cc/5hio4uyix/F319.png?dl=1
   #23
AA7QQ
C?ID=337402
I am just going to print up the pertinent wiring, trans, engine & other schematics for my application. I am also printing each manual/guide/training course/or bit of information that I got on erWin.
In a bit of time, I should be rather versed in my platform & somewhat of a helper on the forums.
It's what I love to do, learn new things & then help others like you are all doing for me.
I messed with the older forms of diagnostics/CAN (9141 & others) with my 24 valve Dodge. Got pretty good at it. Built & sold a few minor electronic upgrades for them, too.
It's just been quite a while & I am quite rusty.
Thanks,
Ed
   #24
Thanks,
Ed
Well I welcome such a person with these goals to collective.
   #25
AA7QQ
C?ID=337402
I checked, cleaned, silicone greased all grounds underhood, right & left footwells, steering column. I will get the A pillar ground. Is there any way to find the ground & power connections that are listed as "In main wiring harness"? Or have I just not found that?
With the newer schematics, I will look deeper on Saturday.
Thank you,
Ed
   #26
Thank you,
Ed
Yup....
5VYE0_AS01
   #27
AA7QQ
C?ID=337402
Resistance is, well.... Resistance....
I got this car as a challenge. $70 for the tow home. It'll be my new daily commuter. Much better than the F-550. The truck is for remote antenna work (I'm a ham). Also, both will have full amateur radio systems. I will definitely report back, as to how much RF the car can take, per frequency. I will also be able to sniff out noise makers in the system, that many never knew existed.
Thank you,
Ed
Oh, I am still active on Cummins forums, even though I did a full runaway explosion 2 years ago...
I started to cry, then realized that it was like a glorious Viking funeral. 623,000 miles on that beast. As Warf would say, "It died well". (Met him one day, 2 years ago (Michael Dorn). Cool & humble kinda guy.
   #28
AA7QQ
C?ID=337402
Dang, I never thought about that. I have an excellent Greenlee wire tracing system (Yes, down to 1 wire in a bundle).
THanks,
Ed
AA7QQ
C?ID=337402
Well, I am finally home with the column & shifter. No work tonight, but a bit of studying.
The column is complete, less airbag. I am almost contemplating swapping the whole thing, as (As far as I know) the steering wheel bolt removal tool is not in any of my tool boxes, unless a normal Torx will work?
Shifter looks relatively simple, actually. It seems that there will be a magnet, or ferrous metal, in the white part of the shifter. It's on the backside of the PCB (Printed Circuit Board). On the other side, I am guessing some form of hall effect units that indicate the gear selection, as they correspond to positions well. THen off to the chip.
Ya know, I will install the replacement, but will also try to diagnose the real issue with the shifter system.
Yes, yes, I surely will take many photos to document it all, pass or fail.
Good evening, I am off to do a Scotch rocks & study...
Ed
   #31
AA7QQ
C?ID=337402
WOO HOO !!!
Saturday,19,May,2018,16:29:28:30861
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: 3VWRJ71K48M115204   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRJ71K48M115204   Mileage: 163230km-101426miles
   Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0H02470RP
   Coding: 0403010A1C070160
   Shop #: WSC 00066 000 00000
   VCID: 3635DAA14440F5679BB-8062
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 008 -  - Intermittent
                    Mileage: 163239 km
                    Time: 00:52:31
                    RPM: 1179 /min
                    Load: 36.1 %
                    Temperature: 25.0°C
                    Temperature: 31.0°C
                    Absolute Pres.: 920.0 mbar
                    Voltage: 13.716 V
Readiness: 0110 0101
   Part No SW: 02E 300 050 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1409
   Revision: 05308020    Serial number: 00001107060644
   Shop #: WSC 04940 001 00001
   VCID: 196F311DD59E3A1F969-804C
   Revision: 00H11001
   Coding: 0021122
   VCID: 73B323B517B2A04F7C5-8026
   Part No SW: 1K0 820 047 HJ    HW: 1K0 820 047 HJ
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000000837571
   Coding: 14058E234004150007140000001400000008730B5C000100000000000000
   VCID: 6FBB2FC57B9A84AF98D-803A
   Component: Wischer 030108 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7G0228397
   VCID: 2E05F2C1BC10CDA7D3B-807A
            000 -  -  - Intermittent
                    Reset counter: 218
                    Mileage: 163239 km
                    Time: 00:00:39
01304 - Radio
                    Fault Frequency: 62
                    Reset counter: 178
                    Mileage: 163239 km
                    Time: 00:21:31
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M042FFZ
   Coding: 0013889
   VCID: 6C8138C94A8C7FB7BDF-8038
   Subsystem 2 - Serial number: 6332MSME1734660DB
   Subsystem 3 - Serial number: 6342MSME17344530%
   Subsystem 4 - Serial number: 6351HSME12464B667
   Subsystem 5 - Serial number: 6361HSME12455F3FI
   Subsystem 6 - Serial number: 63727SME1210466CZ
   Subsystem 7 - Serial number: 63827SME12121A67Y
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Component: J0527           051 0100
   Coding: 0010021
   VCID: 77AB17A503CACC6F40D-8022
   Part No SW: 1K0 920 954 P    HW: 1K0 920 954 P
   Component: KOMBIINSTRUMENT 3HL 1212
   Revision: V0002000    Serial number: VWX7Z0H02470RP
   Coding: 0023203
   VCID: 392FD19D755E1A1F769-806C
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 261107F1000475
   Coding: ED807F070003021002
   VCID: 3039ECB9A624DB57C17-8064
01304 - Radio
                    Reset counter: 178
                    Mileage: 163239 km
                    Time: 00:28:41
   Component: IMMO            3HL 1212
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000522379211
   Coding: 0001205
   VCID: 3B23CB957F62280F645-806E
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 3537DDAD5946FE7F921-8060
02546 - Steering Limit Stop
                    Mileage: 163230 km
                    Temperature: 40.0°C
                    Voltage: 13.10 V
                    Voltage: 12.90 V
   Component:    KSG PQ35 RDK 052 0221
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 04517069421C97F755F-8050
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000036279208
   Coding: 0001204
   VCID: 3C21C8897A6C2F376DF-8068
                    Fault Status: 01100101
                    Reset counter: 178
                    Mileage: 163239 km
Address 56: Radio
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000002607637
   Coding: 0001168
   VCID: 3E25C2816C703D2743B-806A
   Component:    RDK              0450
   Coding: 0100101
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000002609753
   Coding: 0001168
   VCID: 3FDBBF856B7A342F48D-806A
End----------(Elapsed Time: 01:20, VBatt start/end: 13.2V/13.2V)-----------
Sure wasn't fun, but, it drives.
I still have to do some initializations & adaptions, along with the radio issue.
I'll finish up tomorrow.
Thank you all for the help. I doubt that I could have gotten to this point without,
Ed
Yay!
So what or where was the issue or actual break?
Water ingress with corrosion?
   #33
AA7QQ
C?ID=337402
This was a car that sat for 5 months. PO got it jumped, drove to work, never could get it out of Park.
Main issue was the shifter, as just plugging it into the harness & clearing the codes put it right.
Radio now does not function at all & no comms. No biggie.If it did finally die (Was working), I'll just pull it & install my ham radio head units with a plate to seal it off. Oh, I have full access to a machine shop at work.
Now, as for the steering angle sensor, it was fine. Just a bad Column controller.I originally thought it might be part of the problem & it was. I still have to do adaptations on the sensor, along with windows & other stuff.
So, for a grand total of about $600 including the VCDS, I have an 08 Jetta. Scrapping the ol' LeSabre, which will cover it all.
In a few weeks, I will do my best to diagnose the shifter. I still have several projects ahead of it. I will start a new thread on it.
THank you all for the great help.
Ed
AA7QQ
   #34
AA7QQ
C?ID=337402
So, as an update, I have everything functioning & cleared, except for all of the codes pertaining to the "Tuner" (Head unit).
In:
                    Reset counter: 218
                    Mileage: 163239 km
                    Time: 00:00:39
01304 - Radio
                    Fault Frequency: 62
                    Reset counter: 178
                    Mileage: 163239 km
                    Time: 00:21:31
01304 - Radio
                    Reset counter: 178
                    Mileage: 163239 km
                    Time: 00:28:41
Address 56: Radio
Radio may be fried. Not sure. Just wondering of there might be a setting to enable it? I cannot even communicate with it.
I have the premium sound system. Not sure if it has the CD changer, but obviously, it has sattelite radio (Won't be used).
Now, I am still learning. I have the radio adaptation & coding all printed out. Just need to turn the bugger on.
I do recall trying to turn the CD changer on & that might be when I messed up.
Thank you,
Ed Grafton
02635 - Tuner Not Enabled/Activated -- this just means that Sirius/XM tuner doesn't have an active subscription.
Radio: Is it getting power? A lot of them have a dedicated fuse on the back of the radio itself....
AA7QQ
C?ID=337402
Well, I guess leaving the center console & a bunch of dash panels off helps...
When I started, the radio functioned. It was giving 16.1V or above & 7.01V below voltage, with no comms.
I'll pull it over the weekend & see what I find.
THank you again,
Ed
   #37
AA7QQ
C?ID=337402
Twas the dang fuse on the back. No more codes, all functions, as I want them & a very happy customer.
The rest of the weekend goes towards building a software defined ham radio.
THank you,
Ed
