2008 Audi A6 -- No crank, no start
pogophil
C?ID=301989
My 2008 Audi A6 isn't responding to the key when I try to start the car. I turn the key, and the dash stays off, but the MMI turns on. It may be the ignition module reset or replacement is needed, but looking for others' opinions.
I scanned the car, and deleted the codes, twice -- first without override, and second with the hazards/highbeam/brake override, but no luck. Car still not cranking, dash doesn't turn on, but MMI does.
Here are the two scans. Can someone assist? Thanks in advance.
SCAN 1:
Sunday,15,April,2018,12:59:48:01374
VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 42 46 47 4F 52 53
          55 56 61 62 65 72 77
   Mileage: 196000km-121788miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500898293
   Coding: 0000003
   Shop #: WSC 02323 758 00200
   VCID: 6390A6DFB755EDFF0FA-8036
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H45 0080
00288 - Steering Column Lock Actuator (N360)
            014 - Defective
                    Fault Status: 01111110
                    Mileage: 196002 km
                    Date: 2018.04.13
                    Time: 14:12:52
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 732 C    HW: 4E0 035 729
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 303IY077557466
   Coding: 0000003
   Shop #: WSC 02335 758 00200
   VCID: 2310E6DFF7D5ADFF4FA-8076
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000000881406
   Subsystem 3 - Serial number: 0102.10.070000000100010508ÿ
   Subsystem 4 - Serial number: 010508ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000053    Serial number: 00000030291060
   Coding: 0524326
   Shop #: WSC 02325 758 00200
   VCID: 1C62DD23CAAB92078E0-8048
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0012123
   VCID: 313C1C97BD290F6FCD6-8064
   Subsystem 1 - Component: Fehler Lin-Slave 01
   Subsystem 2 - Component: Fehler Lin-Slave 02
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H46 0350
   Revision: 00046006    Serial number: AUZ5ZBG3485349
   VCID: 186AC1333E93FE27AA8-804C
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7G0169202
   Coding: 0000100
   VCID: 2F381AEFAB1D199FDB2-807A
            000 -  -
                    Reset counter: 7
                    Mileage: 195462 km
                    Date: 2018.03.09
                    Time: 20:14:34
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 C    HW: 4F0 920 951 A
   Component: KOMBIINSTR. M73 H16 0240
   Revision: 00200000    Serial number: 64858GT97
   Coding: 2065288
   Shop #: WSC 40674 067 57207
   VCID: 201AE9D3E6C3B6E7528-8074
                    Reset counter: 65
                    Mileage: 195802 km
                    Date: 2018.04.04
                    Time: 09:37:44
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B079268404
   Coding: E5D59E77301A0600
   VCID: 2D0400E7A1116B8FE9E-8078
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082946
   VCID: 619CACD7AD49FFEF1D6-8034
Address 46: Central Conv.
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H10 0240
   Revision: PROD_01     Serial number: 00000000051573
   Coding: 0000016
   Shop #: WSC 02324 758 00200
   VCID: 2514F8C7F9E153CF21E-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000076127
   Coding: 0002014
   VCID: 5EE6972B9C37C017204-800A
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 394J4077817856
   Coding: 0000002
   VCID: 2E0607EBAC171097D04-807A
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000147098
   Shop #: WSC 00000 512 00290
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  0709271154
   Coding: 344630393135313035442056413030373039323731313534
Address 62: Door, Rear Left
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000700056800
   Coding: 0062221
   VCID: 221EE3DBE8CFA4F744C-8076
02214 - Tire Pressure Warning
            000 -  -  - Intermittent
                    Reset counter: 61
                    Mileage: 195760 km
                    Date: 2018.03.24
                    Time: 22:33:02
                    (no units): 47.0
                    Temperature: 0.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 72: Door, Rear Right
   Part No SW: 4F0 910 336 E    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005009903
   Coding: 0010900
End----(Elapsed Time: 01:29, VBatt start/end: 12.1V/12.1V. VIgn 0.0V)------
SCAN 2:
Sunday,15,April,2018,13:02:23:01374
Chassis Type: 4L0
Address 01: Engine
   Coding: 0000003
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0040
            014 - Defective
                    Mileage: 196002 km
                    Date: 2018.04.13
                    Time: 14:12:52
   Coding: 0000003
   Coding: 0524326
   Coding: 0012123
   Coding: 0000100
            000 -  -
                    Reset counter: 7
                    Mileage: 195462 km
                    Date: 2018.03.09
                    Time: 20:14:34
Address 15: Airbags
   Coding: 2065288
                    Reset counter: 65
                    Mileage: 195802 km
                    Date: 2018.04.04
                    Time: 09:37:44
   Coding: 0082946
   Coding: 0000016
   Coding: 0002014
   Coding: 0000002
   Coding: 0062221
                    Reset counter: 61
                    Mileage: 195760 km
                    Date: 2018.03.24
                    Time: 22:33:02
                    (no units): 47.0
                    Temperature: 0.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0010900
End----(Elapsed Time: 01:29, VBatt start/end: 11.5V/11.8V. VIgn 0.0V)------
Lots of stuff is not powered on, including the "Vign" pin (pin 1) on your OBD-II socket.
Not sure whether the "00288 - Steering Column Lock Actuator (N360)" fault is the cause, or a symptom.
Time to break out the wiring diagrams and see where all that the stuff that's not powering up gets power from.
Gone But Not Forgotten
Check Kessy for water damage/ingress and blocking power up & COM with ESCL too......
pogophil
C?ID=301989
For anyone with this issue in the future:
Go to 05-Acc/Start Auth
Read Codes
Erase Codes
Once I did this my car clicked to life, and I was able to start it no problem. I was able to turn it off and on again. Good luck!
Read Codes
Erase Codes
This will most likely happen again!
Inspect Kessy for water and rectify before you can't just clear codes..........
A NostraJackASS Quatrain........... :rolleyes:
pogophil
C?ID=301989
It did happen again - ugh! A bit different this time, as the dash is on now (previously it stayed off even with the key in).
Here is the new scan -- note the engine codes for starter control and starter relay. A quick search found others posting about the problem, but no solutions listed, unfortunately....
Wednesday,18,April,2018,17:50:19:01374
VIN: WAUDH74F78N060872 License Plate:
Chassis Type: 4F (4L0)
VIN: WAUDH74F78N060872 Mileage: 196060km-121826miles
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 H HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0040
Revision: --H21--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 08253 444 83875
012371 - Starter Control; Returned Message
P3053 - 006 - 50 Short to Ground
Fault Status: 11000001
Mileage: 196061 km
Date: 2018.04.18
Time: 15:30:31
Mass Air / Rev.: 0.0 mg/str
Temperature: 84.0°C
Engine Off
Voltage: 12.34 V
012424 - Starter Relay
P3088 - 006 - Electrical Malfunction
Mileage: 196061 km
Date: 2018.04.18
Time: 15:30:31
Temperature: 84.0°C
Engine Off
Voltage: 12.04 V
Part No SW: 4F5 910 156 HW: 09L 927 156 C
Component: AG6 09L 3.2 FSI USA 0010
Revision: --H04--- Serial number: 4376994
Coding: 0000002
VCID: 6594B8C7B96193CFE1E-8030
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Coding: 0020895
VCID: 6696BFCB446798D7E84-8032
Coding: 0000003
Coding: 0000003
Coding: 0524326
Coding: 0012123
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 02335
Coding: 0000100
Mileage: 196002 km
Date: 2018.04.15
Time: 17:13:19
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 6N AIRBAG AUDI8RH30 0300
Revision: 15H30000 Serial number: 00359D0G7KC%
Coding: 0013902
VCID: 2A0E0BFB90FF7CB70CC-807E
Subsystem 1 - Part No: 4F0 910 339 B
Component: BF-Gewichtsens. H03 0060
Subsystem 2 - Serial number: 6332CSME28236807/
Subsystem 3 - Serial number: 6342CSME28231053T
Subsystem 4 - Serial number: 6352QSME3C294459P
Subsystem 5 - Serial number: 6362QSME3C511F4BU
Subsystem 6 - Serial number: 63734SME3D12417F4
Subsystem 7 - Serial number: 63834SME380F531B5
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90055072630100
Coding: 0002041
VCID: 2708F2CF83ED41DF132-8072
Component: E0221 H02 0030
Coding: 2065288
Coding: 0082946
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: V
Coding: 0035563
Shop #: WSC 02327 758 00200
VCID: 2C020DE39A0B6287FE0-8078
Fault Status: 01101100
Reset counter: 43
Mileage: 196002 km
Date: 2018.04.15
Time: 17:13:08
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H26 0210
Revision: 02100026 Serial number: 01068674880000
Coding: 4618269
01506 - Bulb for Rear Fog; Right (L47)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 62
Mileage: 191413 km
Date: 2007.05.16
Time: 12:02:01
Coding: 0000016
Coding: 0002014
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: CI
Coding: 0035563
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0005022
Shop #: WSC 02145 758 00200
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H01 0010
Coding: 0000003
VCID: 3FD84AAF7B7DE91F4B2-806A
Coding: 0000002
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0035370
Coding: 0062221
Reset counter: 61
Mileage: 195760 km
Date: 2018.03.24
Time: 22:33:02
(no units): 47.0
Temperature: 0.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0035370
Coding: 0010900
End----(Elapsed Time: 02:01, VBatt start/end: 11.9V/11.8V. VIgn 11.7V)-----
pogophil
C?ID=301989
                    Mileage: 196061 km
                    Date: 2018.04.18
                    Time: 15:30:31
                    Temperature: 84.0°C
                        Engine Off
                    Voltage: 12.34 V
                    Mileage: 196061 km
                    Date: 2018.04.18
                    Time: 15:30:31
                    Temperature: 84.0°C
                        Engine Off
                    Voltage: 12.04 V
   Coding: 0000002
   Coding: 0020895
   Coding: 0000003
   Coding: 0000003
   Coding: 0524326
   Coding: 0012123
   Coding: 00064784
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Coding: 0000100
            000 -  -
                    Mileage: 196002 km
                    Date: 2018.04.15
                    Time: 17:13:19
   Coding: 0013902
   Coding: 0002041
   Coding: 2065288
   Coding: 0082946
   Coding: 0035563
                    Reset counter: 43
                    Mileage: 196002 km
                    Date: 2018.04.15
                    Time: 17:13:08
   Coding: 4618269
                    Reset counter: 62
                    Mileage: 191413 km
                    Date: 2007.05.16
                    Time: 12:02:01
   Coding: 0000016
   Coding: 0002014
   Coding: 0035563
   Revision: --H04---
   Coding: 0005022
   Coding: 0000003
   Coding: 0000002
   Coding: 0035370
   Coding: 0062221
                    Reset counter: 61
                    Mileage: 195760 km
                    Date: 2018.03.24
                    Time: 22:33:02
                    (no units): 47.0
                    Temperature: 0.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0035370
   Coding: 0010900
Fix water leak and take Kessy apart to clean.......... :rolleyes:
Last warning.......
Only you can change the outcome of futures past....... :popcorn:
Dam ball........ all I can get is snow & since the Wizard ran it with an undercharge.
http://forums.ross-tech.com/showthr...crank-no-start&p=126615&viewfull=1#post126615
pogophil
C?ID=301989
Thanks Jack -- I had to Google what Kessy was, so I could start to understand your post.
Help me understand -- where is the Kessy? Where should I inspect for water leaks into Kessy?
pogophil
C?ID=301989
Also, if it's water, should it dry out after a while in the garage? If so, I should be able to start it after dry.
Get the RTFB and read it.
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
Inside it would be a good start and where it is coming from....... :rolleyes:
Take it apart & dry it out, before you are not lucky..........
Than bag it with something & so water cant get in it!
Do something the OEM seems to fail to use .........It's called common sense!
pogophil
C?ID=301989
Ok.... piecing together some info:
Location of keyless entry antenna: https://www.audiworld.com/forums/q5...n-129/keyless-entry-antenna-location-2897015/
Keyless entry antenna part for sale: https://www.wolfautoparts.com/2005-...a6-c6-kessy-keyless-entry-antenna-171249.html
Based on this info, it looks like the part in question is just forward of the shifter?
If so, I can take apart the center console to inspect for water entry and damage.
If not, a bit of additional guidance would be greatly appreciated. (Thanks in advance.)
pogophil
C?ID=301989
Needed a new ECU, one of the pins was shorted out. $2k cost to fix.
Pin was shorted why.........water damage?
Pictures of old module?
pogophil
C?ID=301989
Didn't get the old part, although in retrospect I probably should have requested it.
Why do you ask?
