Hi! also a question regarding DIS in an old C5
qew
New Member
Sweden
HC554395 (2nd hand?)
First post and also my first vagcom project.
Hopefully this works out and I can re-register my second hand cable. :thumbs:
Is it possible to enable DIS on an A6 C5?
My car came with CC installed but not DIS.
I'm guessing it is factory installed in all cars but just not enabled so you switch the wiper stalk and enable it via VCDS, or is it more complicated than that?
Anyone have any info on this?
Thanks in advance!
Not sure what you're asking?
CC = cruise control
DIS = Driver Information System - the LCD display in the instruments
qew
New Member
Sweden
All right, let me rephrase that.
Is it possible to use VCDS to enable the DIS, aka trip computer on a C5?
I know you can swap the turn signal stalk and enable CC using VCDS, can the same be done for the wiper stalk and the trip comp, as in being able to flip through mpg, average speed and so on.
qew
New Member
Sweden
Really, no one?
I guess that it's not possible then?
I'll start looking into doing a cluster swap in that case.
Zenerdiode
Newcastle, England
C?ID=24330
Don’t forget you can still do an Auto-Scan without registering your cable. If we see how your car is equipped, we may be able to help you.
qew
New Member
Sweden
Yeah sure, I was just hoping to find someone who had actually attempted it and could tell me if it was possible or not.
Either way, it looks like I'm outta luck since I have the European split display and from what I understand that one doesn't have the capability to show any information besides outside temp.
Gonna swap to another cluster, with the full size display, from the same model and year and see what options open up.
As said above we need to see a full Auto-Scan to be able to tell you yes or no. You just might not need another cluster...
qew
New Member
Sweden
Maybe I should have cleared some codes first, not sure how long ago some of theses were logged?
Monday,19,March,2018,13:46:32:31346
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ4B73N055630   License Plate:
Mileage: 181080km-112517mi   Repair Order: 991
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
VIN: WAUZZZ4B73N055630   Mileage: 181080km-112517miles
Address 01: Engine        Labels: 078-907-552-AMM.lbl
   Part No: 3B0 907 552 BJ
   Component: 2.4L V6/5V      G   0001
   Coding: 11752
   Shop #: WSC 02325
   VCID: 6DD53F2C27EB8C2CC3-5120
   WAUZZZ4B73N055630     AUZ5Z0B9248112
   Part No: 4B0 927 156 DQ
   Component: AG5 01V 2.4l5V  RdW 1818
   Coding: 00001
   VCID: 79FD1B7C63A3208C5F-5102
17086 - Transm. Control Module Electrical Malf. (SAE) or Control Module Defective (VAG)
            P0702 - 35-10 -  - Intermittent
   Part No: 4B0 614 517 H
   Component: ABS/ESP allrad      1728
   Coding: 06497
   Shop #: WSC 02325
   VCID: 26470000C29D7F7442-5102
Address 08: Auto HVAC        Labels: 4B0-820-043-MY1.lbl
   Part No: 4B0 820 043 AH
   Component: A6-Klimavollautomat D65
   Coding: 00060
   Shop #: WSC 02325
   VCID: 60CB5618E039D14478-2578
01582 - Signal for Coolant Temperature
            30-00 - Open or Short to Plus
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4B0 959 655 P
   Component: Airbag 8.4EP        2002
   Coding: 0001706
   Shop #: WSC 02325 785 00200
   VCID: 3D75CF6C670BDCAC33-5120
00532 - Supply Voltage B+
   Part No: 4B0 920 901
   Component: KOMBI+WEGFAHRS. M73 D04
   Coding: 00162
   VCID: 5BB161F4C95FF29C2D-4AE6
Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
   Part No: 4B0 962 258 L
   Component: Zentralverriegelung D37
   Coding: 06721
   Shop #: WSC 02325
   VCID: 326FEC50FE5513D4DE-4ECA
01366 - Opened Due to Crash Signal
            35-00 -  -
   Part No SW: 4B0 035 192 P    HW: 4B0 035 192 P
   Component: RNS-E HIGH EU   H47 0650
   Revision:      03S    Serial number: AUZBZ7D0013309
   Coding: 0519351
   Shop #: WSC 00720 210 60988
   VCID: 2A5FF43086855B1466-513C
9 Faults Found:
                    Reset counter: 211
                    Time Indication: 15
                    Voltage: 12.10 V
                    Reset counter: 211
                    Time Indication: 15
                    Voltage: 10.50 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
                    Fault Status: 00101011
                    Reset counter: 211
                    Time Indication: 15
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
02261 - Data Medium
                    Fault Status: 00101110
                    Fault Frequency: 22
                    Reset counter: 211
                    Time Indication: 15
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
00856 - Radio Antenna
                    Reset counter: 211
                    Time Indication: 15
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
                    Reset counter: 211
                    Time Indication: 15
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
00857 - CD Changer Unit (R41)
                    Fault Status: 01110100
                    Reset counter: 171
                    Time Indication: 15
                    Reset counter: 211
                    Time Indication: 15
02005 - Coding Pin
                    Reset counter: 171
                    Time Indication: 15
   Part No: 4Z7 907 357
   Coding: 00050
   Shop #: WSC 02325
   VCID: 04037A8814616D643C-4B00
   Coding: 0519351
9 Faults Found:
                    Reset counter: 211
                    Time Indication: 15
                    Voltage: 12.10 V
                    Reset counter: 211
                    Time Indication: 15
                    Voltage: 10.50 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
                    Reset counter: 211
                    Time Indication: 15
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
02261 - Data Medium
                    Fault Frequency: 22
                    Reset counter: 211
                    Time Indication: 15
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
                    Reset counter: 211
                    Time Indication: 15
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
                    Reset counter: 211
                    Time Indication: 15
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
                    Reset counter: 171
                    Time Indication: 15
                    Reset counter: 211
                    Time Indication: 15
02005 - Coding Pin
                    Reset counter: 171
                    Time Indication: 15
End-------------------------(Elapsed Time: 05:19)--------------------------
iichel
Netherlands, eastern part
C?ID=284912
Hard to say. Usually it stores a time/date (not always reliable) and a mileage. But in your case neither seems to have happened. Since the codes you now see are read after clearing, you can assume they're current
Zenerdiode
Newcastle, England
C?ID=24330
The Instrument Cluster looks to be 'lowline' - and needs to be a 'highline' to support DIS. It also houses the Immobiliser; so you need to factor that in to any replacement.
DGMotors
C?ID=57532
qew
New Member
Sweden
Great write up!
I do have the midline at the moment (I think) so I'm probably looking at doing the exact same thing.
This is the one:
Actually I sent a question to my local Audi shop since I'm worried I'll mess up the immobilizer somehow, once they get back to me with an outrageous price that is sure to change though...
Any tips on what cluster I should look for, as in what part numbers? Seeing as the highline was available for my model year could I just get one of those and plug and play it? Or will there be modifications to the wiring either way?
qew
New Member
Sweden
For what it's worth, maybe someone else is looking for information regarding this.
It is NOT possible to enable the on board computer if you have the mid-line display, had to swap in a cluster with full display to make this work.
