Special editions | E0A | Without special action equipment |
Lockable wheel bolts | 1PC | Wheel bolts with anti-theft protection
(unlockable) |
Vehicle class differentiation
units/platform components | 0CM | Vehicle class differentiation -1JM- |
Emission standard | 0GL | Emission standard TLEV |
Trailer hitch | 1D0 | without trailer towing |
airbag | 4UB | Airbag for NAR |
Automatic transmission indicator light | 9FA | Without automatic transmission
indicator light |
Aktivkohlebehälter / Ottopartikelfilter | 1E4 | Activated carbon canister (ORVR)
and siphoning device for fueling |
Aerials | 8L3 | roof antenna |
Exterior mirror setting | 6XN | Exterior mirrors, power-adjustable/
separately heated |
Left exterior mirror | 5SH | Left exterior mirror, flat (US) |
Right exterior mirror | 5RR | Right exterior mirror, convex (US) |
Drive type | 1X0 | Front-wheel drive |
Equipment levels | A8W | Luxury equipment |
Brake type in rear | 1KX | Disc brakes in rear (Geomet D) |
batteries | J1L | Battery 280 A (60 Ah) |
Brake type, front | 1ZD | Disc brakes in front (Geomet D) |
Components with special surface | 6FF | Exterior mirror housing and various attachments
colour coded to vehicle |
Controls (steering wheel/steering column) | 4LA | Without control element |
Beverage holders | 4M6 | Beverage holders |
Special color trim | 0UA | Without special color trim |
Component part sets with
country-specific design requirements | B0D | Assembly kit, USA corresponding vehicle
version (not California), various parts |
floor covering | 3MH | Dilours floor covering without scuff
guard |
vehicle tools and jack | 1S7 | Tool kit and aluminum jack |
brake pressure regulator | 1H0 | without brake pressure regulator |
Brake systems | 1AJ | Anti-slip regulation (ABS/ASR/EDL) with
electronic differential lock (EDL) |
brake wear indicator | 9U1 | brake wear indicator |
Heated washer nozzles | 9T1 | Heated washer nozzles in front |
CD changer/CD player | 7A1 | CD changer preparation |
Chrome package | QJ0 | Without aluminum/chrome work package |
Cd enhancing underbody panel | 2D1 | Complete cd enhancing underbody panel |
Roof rails/roof load rack | 3S0 | Without roof rails/roof load rack |
Roof insert/convertible top | 3FE | Tilting and sliding glass sunroof with
sunbshade |
Suspension system in rear | 1JY | Rear shock absorption, basic version 2
(NAR, South America, Mexico) |
Suspension system in front | 1GJ | Front shock absorption, Basic 2 (Audi) |
Insert for the filling up of unleaded
fuel/fuel type | 2G7 | Filler neck module 1 with insert |
Installation differentiation for components | 0EJ | Installation differentiation for
transmission MQ 250
-- vehicle components -- |
Theft protection system | 7AG | Electronic immobilizer
with anti-theft alarm system (for USA) |
Inserts | 5MA | Decorative inserts |
Interference suppression | 8E2 | Local interference suppression for FM/AM
radio reception |
Manufacturing sequence differentiation | 0FL | Mexico manufacturing sequence |
Vehicle type | AZ0 | Vehicle with production equipment |
chassis/running gear | 2E0 | Base chassis |
window regulator | 4R4 | Power windows with comfort operation and
circuit breaker |
fire extinguisher | 6A0 | without fire extinguisher |
Headlight activation | 8K4 | Separate daytime running lights
NAR |
Fresh air intake for passenger
compartment (with particulate filter) | 2V5 | Fresh air intake with activated charcoal filter |
Antifreeze | 1C2 | Antifreeze up to -35 degree celsius
tolerance up to -40 degree C |
Vehicle specifications | F0A | No special purpose vehicle, standard
equipment |
throttle control | 0L2 | accelerator pedal with electronic modul |
Alternators | 8GD | Alternator 90 A |
Transmission types/gearshift mechanisms | 0G4 | Cable gearshift |
Transmission shafts | 1WB | Transmission shafts 100 mm in diameter |
Weight category front axle | U33 | Suspension range 132 |
Base engine | T8C | 4-cyl. petrol engine 1.8 l assembly 06A.C |
Luggage netting/pocket on backrest(s) | 4U5 | Luggage pockets on backrest |
Luggage compartment cover | 3U0 | Without luggage compartment cover |
Tie down straps/net/pocket | 6M3 | Luggage net |
cruise control system | 8T2 | Electronic cruise control system (CCS)
Exterior noise suppression measures | 2B1 | additional noise dampener |
Luggage compartment trim | 5A7 | Comfort luggage compartment lining with
service flap |
Transmission specifications | G0C | 5-speed manual transmission |
Brackets | 3P0 | Without bracket for first aid kit and
warning triangle |
handle for hand brake lever | 6PA | Hand brake lever handle in plastic |
Rear window wiper and washer system | 8M0 | Without rear window wiper and washer
system |
Grab handles at roof frame | 5N6 | Folding grab handles on roof frame
soft fold-away |
Rear axle | 0N1 | Standard rear axle |
Molded headliner | 6NG | Unsplit molded headliner
roof cutout rear (radio antenna) |
Rear seats | 3NF | Rear seat bench/backrest, split folding
locking |
Heating and air-conditioning system | 9AB | Manually controlled air conditioning
system |
Headlamps | 8BL | Halogen headlamps for driving on the
right, US design |
Instrument clusters | U0F | Instrument cluster with tachometer,
clock and mph speedometer |
Breakaway interior rearview mirror | 4L2 | Breakaway interior rearview mirror,
dimming |
Sticker (customized or special edition) | 0KA | Without decals and emblems |
Body style | K8B | Notchback |
Luggage compartment floor covering | 6SC | Luggage compartment floor covering in
needle-punched nonwoven |
Cassette and CD storage unit | 4W0 | without cassette / CD tray |
Electronic map cooling system | QS0 | Without electronic map cooling system |
headrest for seat, rear | 3Q6 | Three rear head restraints |
Head restraints | 5ZH | Head restraints for front seats, tilt-
and height-adjustable with integrated
adjustment mechanism |
Fuel tank treatment | 2LC | Fuel tank with special material
treatment (coextrusion) |
Fuel quantity for initial filling | 1Z0 | Initial standard fuel filling |
Fuel systems | 0F2 | Fuel system for SI engine |
Body measures | 5C1 | Body measures for increased safety
requirements |
Catalytic converter control | 8KA | without catalyst control |
Radiator grille | 6KC | Radiator grille |
Rear license plate bracket | 6P2 | License plate bracket, rear (NAR) |
Front license plate bracket | 6W3 | License plate bracket front (small, NAR) |
Paint preservative/transit coating | 5K5 | Transportation protective film
(instead of paint preservation) |
Paint coating | FB0 | standard paint coating |
Rear cargo area | 3GA | Without luggage compartment floor |
Steering system arrangement | L0L | Left-hand drive |
Reading lamp | 8S2 | One reading light in front, two reading
lights in rear |
steering | 1N9 | steering gear |
Backrest release | 3H0 | Without backrest release for front seats |
Lumbar support | 7P0 | Without lumbar support
in seat backrests |
steering wheels | 1MP | Steering wheel for airbag system |
Speaker installation | 9VG | "Monsoon sound system"
(NAR) |
Steering column systems | 2C5 | Steering column, adjusted axially and vertically |
Headlight range control | 8Q0 | without beam length regulator |
Center armrest | 6E3 | Front center armrest |
Multi-function display/trip computer | 9Q0 | Without multi-function display/
trip computer |
Engine cooling | 8Z6 | Engine cooling, version 2 |
Engine specifications | M98 | 4-cyl. gasoline engine 1.8 L/110 kW 20V
turbo
base engine is T8B/T8C |
engine compartment lighting | 9L0 | without engine compartment lighting |
Left vanity mirror | 4SQ | Left vanity mirror illuminated with
cover and special mirror imprint (NAR) |
Right vanity mirror | 4TQ | Vanity mirror, right, illuminated, with
Navigation device | 7Q0 | without navigation system |
rear fog lamp | 8TA | witout rear fog lamp |
Front fog lamp/additional headlamp | 8WA | Without fog lights |
Rear of platform module base | 4P1 | Rear floor panel module, type 2 |
Platform group class | 7PA | Platform group class 1 |
Hubcaps | 1NL | Trims for alloy wheels |
Wheels | C6V | Alloy wheels 6J x 15
Design: Avus, ET 38 |
Radios | 8YT | Radio "Premium" |
Smoker's/non-smoker's package | 9JA | Non smoker version |
tire | H5B | All-weather tires 195/65 R15 H (NAR) |
Tire suppliers | V0A | Tires without specification of tire
brand |
Spare wheel/breakdown kit | 1G2 | Spare wheel with full tyre, steel |
| PCA | COLD WEATHER PACKAGE (USA/CAN) |
| PEA | LUXURY PACKAGE (15" ALLOY WHEELS) |
| RSM | sound system "Monsoon" package |
Side airbag | 4X1 | Side airbag in front |
Gearshift knob/handle | 6Q4 | Comfort gearshift knob/handle |
Special labels/plates | 0SC | Labels in English |
Tail lamp assemblies | 8SB | Taillight assembly w/ dark colored lens
Locking mechanism for boot lid/cover
rear | 4E2 | Tailgate/trunk lid release
from inside (electrically) |
Materials of low flammability | 4Q1 | Materials of low flammability |
Nameplates for sales name | QD3 | Jetta, lettering for sales name |
Seat belt check | 9P1 | Seat belt reminder, electric contact in
buckle |
Outer rear seat belts | 3ZM | 3-point seat belts, outer rear |
Center rear seat belts | 3C7 | 3-point seat belt for center rear seat |
Gearshift boot/cover | 6R1 | Gearshift boot in leatherette |
seat covers | N0U | Cut pile seat covering |
Seat adjustment | 3L3 | Manual height adjustment for front seats |
seat heater | 4A3 | seat heating for front seats separat controlable |
Side lights | 7R4 | Side marker lamps and turn signal
repeaters (turn signals with white lens) |
Key for locking system | 8QE | Key for locking system with remote control |
Start-stop system/regenerative braking | 7L0 | Without inertia benefit system/
deceleration fuel cut-off/idle stop
valve |
Horns | 8Y1 | Two-tone horn |
Side and rear windows | 4KC | Side and rear windows in heat-insulating
glass |
Protective side molding | 4B2 | Body-colored protective side molding |
Sunroof roller blind for rear/side windows | 3Y0 | without roller blind |
power outlet | 7B2 | 12 volt socket in luggage compartment |
Bumper | 2JC | Comfort bumpers |
Rear stabilizer | 0BC | Rear stabilizer |
Front stabilizer | 0AE | Front stabilizer |
Heavy-duty/sports version | 2UA | Without bad road/sports version |
Headlamp washer system | 8X0 | Without headlamp washer system |
Windshield wiper intermittent control/
light/rain sensor | 8N4 | Windshield wiper intermittent control
with potentiometer (four speeds) |
Nameplate set | 1RT | Nameplate set "1.8T" |
Door storage compartments in front | 3YR | Door pockets with insert mats |
Fuel filler cap/door, locking option | 2W2 | Fuel filler cap, attached (NAR) |
Mass damper for steering wheels | 1Q0 | steering wheel without balance weight |
Door and lid locking system | 4K0 | Central locking w/ radio remote control
and interior controls |
Type approval countries/countries with
special requirements | B34 | Legal requirements USA |
Carrier frequency for remote control | 5D2 | Carrier frequency 315 MHz |
Partition | 3CA | without partition |
Door and side trim panels | 4AR | Door and side trim panel in foam film
and circular-knit |
doors | 0A2 | 4 doors |
TV reception/digital radio reception | QV0 | without TV/digital radio reception |
Speedometer cable and seal | 8CC | Speedometer sensor without seal
(electronic speedometer sensor) |
Front underbody guard | 1SA | Without additional front underbody guard |
Identification plates | 1EB | without identification plate |
Two-way radio installation preparation | 9D0 | without prepared for two way radio system |
Front seats | Q2J | convenience seat |
Rear seat catch | 6QB | Locking rear seat catch |
Preparation for rotating beacon/siren
combination | 9F0 | Without preparation for rotating
beacon/siren combination |
Telephone / telematics | 9W0 | Without car phone preparation/
installation |
Additional warning lights | 9TB | Additional warning lights (door area) |
LongLife Service Regime | QG0 | without service interval extension |
Heat accumulator system/auxiliary heater | 7E0 | W/o heat accumulator/auxiliary heating |
Windshield Glass | 4GC | Windshield in heat-insulating glass with
colourstripe |
Washer fluid level indicator | 8W1 | Washer fluid level indicator |
floor mats | 0TD | Front and rear floor mats |
Additional body panels,
side | 6EA | Without additional side body covers
(stone guard) |
Additional child seat anchors | 3B2 | Child seat anchors acc. to Australian
requirements |
Zündanlaß/Schloß-Sperrsystem/
Elektrische Lenksäulenverriegelung | 0RB | Ignition/starter switch locking system |
Additional tunnel cover | 4J1 | Floor tray, extension center console |
Additional dust seals | 6U0 | Without additional seals outside |
