2017 VW UP steering angle won't adjust
smartvox
The Netherlands
C?ID=4921
Lately I obtained a 2017 (Facelift model) VW UP! 55kW 3-doors.
After a crash were both front airbags deployed I managed to reset the #44 steering controlller back to Factory settings. So power steering works again.
"You never know what your missing untill it's gone "
Also new airbags are in, everything reset - no errors there.
I include my Autoscan:
 Tuesday,06,March,2018,16:22:09:56769
VCDS Version: 18.2.0.3 (x64)
Dealer/Shop Name: rob
Workshop Code: 444 54321 054321
VIN: WVWZZZAAZHD062110   License Plate:
Chassis Type: AA-VW12 (1S0)
Scan: 01 03 09 15 17 19 25 44 5F 61 AD
VIN: WVWZZZAAZHD062110   Mileage: 5540km-3442miles
AD-Brake Sensors -- Status: Malfunction 0010
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 020 ED    HW: 04C 907 309 P
   Component: R3 1.0l MPI   H24 3166
   Revision: UNH24---
   Coding: 00110014022401000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM10MPI01104C906020ED 002002
   ROD: EV_ECM10MPI_VW12.rod
   VCID: 61C9D86F70946B4C77-8034
18872 - A/C Refrigerant Pressure Sensor (G65)
          P0530 00 [047] - Electrical Malfunction
                    Mileage: 5472 km
                    Date: 2018.03.01
                    Time: 11:44:26
                    Coolant temperature: 9 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 12.038 V
                    Outside air temperature: 12 °C
                    Absolute intake pressure: 100 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 14.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Overrun cut-off-Bits 0-7: 0
Address 03: ABS Brakes (J104)       Labels:. 1S0-614-517.clb
   Part No SW: 1S0 614 517 L    HW: 1S0 614 517 L
   Component: EBC 460 ESP   H16 0023
   Serial number: A01EK1H
   Coding: 12BF247129B302F348FB24F694A940505FB100
   ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
   ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
   VCID: 387F550B838E4A84E0-806C
0349 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 105
                    Mileage: 5472 km
                    Date: 2018.03.02
                    Time: 10:14:47
                    DTC: 00 01 5D
Address 09: Cent. Elect. (J519)       Labels:. 1S0-937-08x-09.clb
   Part No SW: 1S0 937 090 F    HW: 1S0 937 090
   Component: BCM PQ25 1MX4 H81 0744
   Revision: BW081001    Serial number: 0978 033170741
   Coding: 62B8290000010000010007D02CEB8E8079C0704C60432D602101000B0900
   VCID: 36635B33819ABCF4F2-8062
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 020217 04  42  0106
   Coding: 0228DD
   Part No SW: 1S0 959 655 C    HW: 1S0 959 655 C
   Component: VW10Airbag02W H03 0007
   Revision: --------    Serial number: 003UB000MG62
   Coding: 000000000000000000000000000000003257
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   VCID: 3E734313A1AA74B42A-806A
   Serial number: 3575HRB401A57GCO5PMY
   Serial number: 3585HRB400G57HGCI1DD
   Serial number: 3557BRB40514B2169GBA
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1S0 920 870     HW: 1S0 920 870
   Component: KOMBI         H05 0010
   Revision: X0005001    Serial number: 00000000000000
   Coding: 114A010000
   ASAM Dataset: EV_KombiUDSMM9RM10 A05808
   ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
   VCID: 6ED3B353B14AC434FA-803A
   Part No SW: 1S0 909 901     HW: 1S0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: BW081001
   Coding: 001001
   VCID: 70EFAD2BA37ED2C4E8-8024
   Part No SW: 5K0 953 234     HW: 1S0 920 870
   Component: IMMO          H05 0010
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_VW12.rod
   VCID: 6ADBBF438DA22814A6-803E
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AM    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  313 3142
   Serial number: CH2C0396
   Coding: 000700
   Shop #: WSC 54321 444 54321
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 020BF7E395D2D0540E-8056
1094656 - Steering angle sensor
                    Reset counter: 106
                    Mileage: 5547 km
                    Date: 2018.03.06
                    Time: 15:40:09
1073664 - Steering End Stops Not Learned
          C10AC F0 [137] - Unknown Error Elaboration
                    Reset counter: 106
                    Mileage: 5547 km
                    Date: 2018.03.06
                    Time: 15:40:09
1073920 - Steering End Stops Not Learned
                    Reset counter: 106
                    Mileage: 5547 km
                    Date: 2018.03.06
                    Time: 15:40:09
   Part No SW: 1S0 035 871     HW: 1S0 035 871
   Component: MU-E--EU      068 7288
   Serial number: 18011700020208
   Coding: 022100002800000041110001000002001F0002C40001010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   VCID: 6CD7B95B87563624D4-8038
   Part No SW: 1S0 907 534     HW: 1S0 937 090
   Component: Batt.regelung H81 0744
   Coding: 032B7864
   Subsystem 1 - Part No SW: 1S0 915 181 C    HW: 1S0 915 181 C
   Component: J367-BDM  H08 0270
   Serial number: 54026256325861108825
Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
   Part No SW: 1S0 907 201 A    HW: 1S0 907 201 A
   Component: CV-SENSOR     H08 0460
   ASAM Dataset: EV_CVSen 001001
   ROD: EV_CVSen.rod
   VCID: 285F854B532EDA0470-807C
4113 - Databus
                    Fault Frequency: 27
                    Reset counter: 106
                    Mileage: 5472 km
                    Date: 2018.03.01
                    Time: 13:27:00
End-------------------------(Elapsed Time: 02:05)--------------------------
I had to recode #44 again (from 0003000 to 000700) but that was no problem since a had a backup ;-)
But now I am stuck and could not find my situation here in this forum explained.
I cannot calibrate the steering angle. When steering is straight, it shows valueas around 400 (!)degrees. I read the Steering Angle Senor: Raw Value
As if I am one turn off. But I never did any mechanical work on the steering system, car drives normally.
I think 400 is too much to calibrate.( I know that on a Audi A3 8P I was able to calibrate only if raw data was between -5 and + 5 degrees)
What am I missing here? What should / can I do to start the calibrating process?
(as this is my first post ever ... I hope to get better at this. Any input welcome)
DrPeter
16.4905° S, 151.7375° W
- The post looks good, short simple, with an Auto-Scan in the 'Code' format and it is to the point.
- I have never worked on an 'UP', however if you are looking at the G85 actual value and it is 'around 400 degrees', like other VAG vehicles that does not appear to be correct if the steering wheel and wheels are straight ahead. You typically will not be able to perform the basic settings until the G85 is as close to [0.00] as you can get it.
Questions:
- Does the value you are looking at move with the movement of the steering wheel, can you get it to read [0.00]?
- If so, what are the positions of the wheels and steering wheel?
- Also check the end-stop values, when the steering wheel is all the way to the right and the left, what are the readings?
Thanks,
drpeter
smartvox
The Netherlands
C?ID=4921
Hi drpeter
Thanks for your prompt reply
Believe it or not, the car is beeing driven so I do not have access all days (needless to says it drives lousy ... with a lot of errors).
I took the steering wheel off. Found out that the steering angle signal comes from the steering rack. There is no sensor in the slipring.
I can get raw data to read 0.0 deg.--> Steering wheel is almost 1 turn to the right, so are the wheels.
I set it to 4.9 deg and tried to calibrate from there. But I cannot, although all prerequisites are met (I think)
So for the end stops: left reads -535.9 where right reads -123.7
The sigs flips around -700. So -701 will be +700 and from tehre it goes to 0.
I tried to (again) go back to Factory default but now with my wheels a kinda straight. It says it buys it but I see long coding did not change (as it did before when performing Reset).
Maybe my login is false (used the popup value)?
Or do I need to reset the steering angle in the ABS module? Tried this -but no luck.
Also I could change the steering wheel sensor from extern to intern in #44. Then it reads 0.00 deg on Steering Angle (NOT the Raw Data) even if I turn the steering wheel. So I guess I am looking at a non-existing sensor in the slipring in that case.
Any next steps you can suggest?
Thanks,
Rob
Mechanical setting incorrect still for baseline point of rack or SAS G85 is bad.
Cant find? trace using WD with tone generator..........
smartvox
The Netherlands
C?ID=4921
If baseline point is mechanically wrong ... but steering is straight at 400 deg. ... does this mean I have to adjust the steering rods coming from the rack? So basically shift the rack (inside) by making one outgoing rod shorter and the other longer? Or is there a way of mechanically adjusting the sensor in the rack. Which would make more sense.
I was hoping the sensor would ask for a new calibration point if I would take the battery off for a week or so :-)
APV_Com
SouthWest UK
C?ID=414488
Was a solution found for this in the end please? I'm having the same issue. the measurement "Steering angle senseor: raw value" IDE09230 is showing 0 degrees when the wheel is about 1.5 turns to the left. when the wheels are dead straight, it shows about -370 degrees , then full lock right is 571 degrees and full lock left is 162 degrees.
I've followed the processes I've found for the general g85 steering calibration, but the security code 19259 isn't accepted. When using the hover over suggested security code I get "Aborted due to malfunction" when running 04-Basic settings -> Steering angle sensor MAS00815.
I have tried the suggested process from https://diagnostics.vis4vag.com/en/...tting-of-steering-wheel-turn-angle-sensor-g85 however this process suggests Security Code 19249, which also isn't accepted
Here is the scan results I get:
Wednesday,17,August,2022,09:20:24:06514
VCDS Version: 22.3.1.4 (x64)  HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
VIN: WVWZZZAAZJD904051   License Plate:
Chassis Type: AA-VW12 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 23 25 44 51 5F 61 75 8C AD BD C0
          C6
VIN: WVWZZZAAZJD904051   Mileage: 7530km-4678miles
8C-HV Battery -- Status: OK 0000
AD-Brake Sensors -- Status: OK 0000
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
Address 01: Engine (J623-EABA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 B    HW: 0EA 907 309 B
   Component: E-Vehicle     H24 8242
   Revision: WLH24---    CVN: 7E71C7BB
   Coding: 000D0012002400000000
   ASAM Dataset: EV_VCU00XXX0110EA906016B 001019
   ROD: EV_VCU00XXX0110EA906016B_VW12.rod
   VCID: 2E050AE0C096D25B6D3-807A
   VINID: 9E69EAAAA451A9A50900400504CECE95AD
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 12E 614 517 E    HW: 12E 614 517 E
   Component: EBC 460 ESP   H17 0012
   Serial number: A01MKQ7
   Coding: 44BF247199AD00F522FA24FA99AA00815FB800
   ASAM Dataset: EV_Brake1ESPTRWPQ12E 006016
   ROD: EV_Brake1ESPTRWPQ12E_006_VW12.rod
   VCID: 2517F5CC956091039C9-8070
0360 - Steering angle sensor
   Part No SW: 12E 907 044 C    HW: 12E 907 044 C
   Component: Climatronic   H05 0109
   Revision: V0000000
   VCID: 2313EBD49BD46F33F2D-8076
   Subsystem 1 - Part No SW: 12E 963 231 H    HW: 12E 963 231 H
   Component: J848 HV-PTC  H09 0211
   Serial number: LR181563013302000027
   Subsystem 2 - Part No SW: 5QE 816 803 D    HW: 5QE 816 803 D
   Component: J842 eKK  H02 0008
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 16
                    Mileage: 7532 km
                    Date: 2022.08.17
                    Time: 03:27:25
04070 - Function Limitation for Blower Regulator 1
                    Reset counter: 16
                    Mileage: 7532 km
                    Date: 2022.08.17
                    Time: 18:52:42
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 152180662
   Coding: 64B82B000001000021000FD42CEB0EF07180726C604325602101000B0910
   VCID: 2B0303F4F304A7734AD-807E
   Subsystem 1 - Part No: 5K7 955 547
   Component: RLHS 240418 0  50  0107
   Coding: 0228DD
04194 - Vehicle Status with Under-Voltage
                    Reset counter: 16
                    Mileage: 7532 km
                    Date: 2022.08.17
                    Time: 03:27:22
Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
   Part No SW: 1S0 919 475 B    HW: 1Q0 919 475
   Component: PARKHILFE 3K  H03 0013
   Revision: --------    Serial number: 32931815701247
   Coding: 308106
   ASAM Dataset: EV_EPHVA14VW1200000 001009
   ROD: EV_EPHVA14VW1200000.rod
   VCID: 392F29BC09D805E3C81-806C
   Part No SW: 12E 959 655 B    HW: 12E 959 655 B
   Component: VW10Airbag365 H04 0218
   Revision: --------    Serial number: 003UA0006DM+
   Coding: 000000000000000000000000000000003635
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 313F119CD1A8CDA3701-8064
   Serial number: 3497ARB4B92B0ECA172P
   Serial number: 3507ARB4C92A2D0C1F1F
   Serial number: 3557BRB4C12B0511650V
   Part No SW: 12E 920 960 F    HW: 12E 920 960 F
   Component: KOMBI         H33 0203
   Revision: X0033002    Serial number: 00000000000000
   Coding: 410A010000
   VCID: 2809FCF8E2728C6BA7F-807C
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 002301
   VCID: 6889BCF822724C6B67F-803C
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 12E 909 059 A    HW: 12E 909 059
   Component: EBKV          H12 0123
   Serial number:   085460013134
   Coding: 00700134010101
   ASAM Dataset: EV_BrakeBoostEBKVBosch 004025
   ROD: EV_BrakeBoostEBKVBosch_VW12.rod
   VCID: 290FF9FCF978B563B81-807C
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 12E 614 307 B    HW: 12E 614 307 A
   Component: V545BrakeAssi  H04 0115
   Serial number: 05802861030518115828
   Part No SW: 5K0 953 234     HW: 12E 920 960 F
   Component: IMMO          H33 0203
   VCID: 6A8DC6F03CFE7E7B71B-803E
   Part No SW: 6R2 909 144 AN    HW: 6R2 909 144 E
   Component: EPS_TRW_ALow  323 3150
   Serial number: CI671028
   Coding: 000300
   VCID: 045188483E9A880BEB7-8050
                    Reset counter: 16
                    Mileage: 7532 km
                    Date: 2022.08.17
                    Time: 03:27:23
          [DEM_LEFT_ENDSTOP_NOT_KNOWN]
                    Reset counter: 16
                    Mileage: 7532 km
                    Date: 2022.08.17
                    Time: 03:27:23
          [DEM_RIGHT_ENDSTOP_NOT_KNOWN]
                    Reset counter: 16
                    Mileage: 7532 km
                    Date: 2022.08.17
                    Time: 03:27:23
   Part No SW: 12E 907 080 K    HW: 12E 907 080 K
   Component: VW120E2313010 H08 2141
   Revision: 00H08000    CVN: 56B4A5C0
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM070501112E907080K 001026
   ROD: EV_DMCM070501112E907080H.rod
   VCID: 2B0303F4F384A7734AD-807E
   Part No SW: 1S0 035 869 B    HW: 1S0 035 869 B
   Component: MU-E-D-EU     068 7338
   Serial number: 05061800021690
   Coding: 02210000BE00000041111101018000001F0003D60001010001
   VCID: 3537258C25C0E1832C9-8060
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 1682081C
   Subsystem 1 - Part No SW: 6Z3 915 181 A    HW: 6Z3 915 181 A
   Serial number: 65135J16515871974048
Address 75: Telematics (J949)       Labels:. 12E-035-284.clb
   Part No SW: 12E 035 284 B    HW: 12E 035 284 B
   Component: OCULowEMobil  029 0183
   Serial number: 000003560590501
   Coding: 02217001101612F000F800000000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002_VW12.rod
   VCID: 2019E4D88A42742BEFF-8074
Address 8C: HV Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 12E 915 227 Q    HW: 12E 915 227 Q
   Component: K8C           H14 0816
   Serial number: 288 VWACIF6004 CVN: B88D4EFA
   ASAM Dataset: EV_BECM102202112E915227Q 008010
   ROD: EV_BECM102202112E915227G.rod
   VCID: 33331B942BB4FFB302D-8066
   ROD: EV_CVSen_VW12.rod
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022-V2.clb
   Part No SW: 12E 915 022 Q    HW: 12E 915 022 C
   Component: LMSG          H08 0086
   Serial number: 00920082130002
   Coding: CA0D03040000
   ASAM Dataset: EV_HVChargManagVW 006008
   ROD: EV_HVChargManagVW_006_VW12.rod
   VCID: 2C0100E8F68AA04B437-8078
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 12E 035 335 B    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H07 0006
   Serial number: 180310200990
   VCID: 1D67DD2CBD3059C3C49-8048
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 12E 915 682 S    HW: 12E 915 682 S
   Component: OBC KOSTAL    H41 0039
   Revision: --------    Serial number: 2106180FI00015
   ASAM Dataset: EV_OBCSinglPhaseKLOVW120 004001
   ROD: EV_OBCSinglPhaseKLOVW120_004.rod
   VCID: 3A2D36B00CDE0EFBC1B-806E
End----------(Elapsed Time: 01:11, VBatt start/end: 12.5V/12.5V)-----------
Any help would be appreciated!
iichel
Netherlands, eastern part
C?ID=284912
I believe the basic setting of the G85 is done in the ABS controller and not in the power steering module.
Hi, @APV_Com, was your vehicle also in "a crash" as described by the OP ? I'm speculating, but in his case the steering is most likely so far off because the rack jumped some teeth internally when the tire/wheel (s) were impacted. Or, the structure the steering rack is mounted to is misaligned.
In your case, presuming the vehicle wasn't involved in a collision, and your mileage is so low, is there any repairs you attempted to do ? Did you do something to cause this fault code? Any history to this concern here?
APV_Com
SouthWest UK
C?ID=414488
Yes it was in a crash same as the op, does that mean a new tracks is need?or can this be adjusted, it's mounted correctly as far as I can tell and the power steering works at speed, but just doesn't work at low speed/stationary
