09G to 02Q transmission swap (2006 3C Passat)
Yo2095
California
C?ID=282415
I have a 2006 Passat (its been my project car for a few years now) I have always wanted to swap the 09g to a manual 02Q transmission, but I have heard there is a ton of programing that needs to be done (which is what has stopped me from attempting it). Has anyone done it? What I have read around says I need to reprogram the ABS, ECU, and Cluster. Should I just forget about it? or anyone has some programing advice they could give me.
Thanks a lot!
iichel
Netherlands, eastern part
C?ID=284912
let's start in good fashion with an autoscan? see below.
maybe it's an idea to sell the car and buy one with a DSG?
I think he wants a proper, 3-pedal manual, not a DSG. ;)
2006 Passats were offered with a manual in the US, so it should be doable. Trouble with them was that you could only get a manual in the lowest, base trim of the car. If you wanted any options at all (stuff like a nicer interior, sunroof, Navi, or xenons) you to take the slushbox auto. Note: I'm assuming this is a 2.0T car. The 3.6 VR6 was never available with a manual, and those were the only two engines offered here.
But I do agree, a complete Auto-Scan of the car in its current (stock?) state would tell us much.
iichel
C?ID=284912
Ah yes. Now I understand. We have the same here in Europe. You want a polo highline TDI? Excellent, have a standard dsg. Funny thing is, in the Netherlands the dsg will add the two grams of co2 to jump straight into the next tax disc.
NZDubNurd
New Zealand
C?ID=230482
I think he wants a proper manual, not a Automatic. ;)
Fixed :thumbs:
OP:
Anything is doable... with enough time and money :D
Chances are you'll need a replacement manual ECU for the engine you have... otherwise a good "tuner" may be able to sort it out - though by the time you've paid for that and got it all correct, you may be getting close to the price of a brand new ECU from VW to suit your engine.
Bear in mind I've only ever scanned 1 Passat of that vintage, and touched 2 :-), but I can say, that a manual conversion in a 2006 mk5 Golf is fairly easy as far as conversions go. Replace ECU with manual version, code a couple of places, remove the trans wiring and earth a wire to tell it it's allowed to start (as per factory wiring diagrams), install clutch switch, fit manual trans/pedal/shifter etc.
Are you allowed to fit an ECU from a Euro car there? I'm guessing the emissions etc are different, because of things like the evap leak pump etc, that a lot of other places don't have.
Google is your friend, but filter everything you read and confirm - lots of people think they know what they are talking about and have no idea (Not on here though - people have been VERY helpful on here for my project car).
No, that's definitely not legal. Now there are plenty of places in the USA where you could get away with that, but given that the OP is located in California, no way. They will interrogate the ECU with each emissions inspection and there's a generic OBD-II PID that specifies which set of emissions standards the ECU complies with.
PS: I'm confident someone like Jack or Marin could put manual trans software in the ECU if that's required.
Yo2095
California
C?ID=282415
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 17.8.0(x64) Data version: 20170721 DS276.2
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Tuesday,13,February,2018,12:21:57:10169
VIN: WVWEK73C56P155772 License Plate: 217
Mileage: 225600km-140181mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
 72
VIN: WVWEK73C56P155772 Mileage: 225600km-140181miles
52-Door Elect, Pass. -- Status: Malfunction 1010
Self-Diagnosis Log
Page 2
Address 01: Engine Labels:. 06F-907-115-AXX.clb
 Part No SW: 3C0 907 115 F HW: 3C0 907 115 F
 Component: 2.0l R4/4V TFSI 0030
 Revision: --H14--- Serial number: VWZCZ000000000
 Coding: 0404010A19070160
 Shop #: WSC 22228 444 85679
 VCID: 234593A5E2F2415EB7-8076
000010 - Camshaft Positioner (Bank 1 Intake)
 P000A - 008 - Slow Response - Intermittent
 Mileage: 225479 km
 Date: 2018.02.01
 Time: 11:26:42
 RPM: 2183 /min
 Load: 31.0 %
 Speed: 81.0 km/h
 Temperature: 48.0°C
 Temperature: 15.0°C
 Absolute Pres.: 950.0 mbar
 Voltage: 14.351 V
Self-Diagnosis Log
Tuesday,13,February,2018,12:21:58:10169
Page 3
 Part No SW: 09G 927 750 HJ HW: 09G 927 750 CJ
 Component: AQ 250 6F 1068
 Revision: 00H38000 Serial number:
 Coding: 0000072
 VCID: 000FFC295324BA468A-8054
 Fault Frequency: 33
 Reset counter: 0
 Mileage: 66351 km
 Date: 2008.08.09
 Time: 16:25:32
Self-Diagnosis Log
Page 4
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
 Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
 Component: ESP 440 C2 H015 0003
 Revision: H015 Serial number: 0658614583
 Coding: 0013755
 Shop #: WSC 00028 028 00001
 VCID: 306F6CE9A304EAC63A-8064
 Fault Status: 00101110
 Reset counter: 113
 Mileage: 225241 km
 Date: 2017.12.11
 Time: 00:00:01
 Fault Status: 00101101
 Reset counter: 122
 Mileage: 225418 km
 Date: 2017.12.27
 Time: 16:23:17
------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-820-047.lbl
 Part No: 1K0 820 047 EC
 Component: Climatic PQ35 090 0505
 VCID: 69D9C18D405E5B0E3D-803C
No fault code found. -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 5
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
 Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
 Component: Bordnetz-SG H46 1501
 Revision: 00H46000 Serial number: 00000002315018
 Coding: 14848F0340041A00400A00000F00000000285D435C0000
 VCID: 377D57F5466A3DFE7B-8062
 Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
 Component: Wischer VW461 012 0503
 Coding: 00063445
 Shop #: WSC 00028
 Reset counter: 97
 Mileage: 224667 km
 Date: 2017.11.22
 Time: 22:49:00
 Voltage: 12.50 V
Self-Diagnosis Log
Page 6
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
 Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
 Component: SDAR SIRIUS H03 0060
 Revision: 00000000 Serial number: AUZ4Z7E2018189
 VCID: 2A5B7E8185D89016F4-807E
 Reset counter: 73
 Mileage: 225241 km
 Date: 2017.12.11
 Time: 00:13:19
Self-Diagnosis Log
Page 7
Address 15: Airbags Labels: 3C0-909-605.lbl
 Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
 Component: 0N AIRBAG VW8R 029 2521
 Revision: 10029000 Serial number: 003A3P0BQB14
 Coding: 0012366
 VCID: 2E537291B930FC3628-807A
 Subsystem 1 - Part No: 3C0 959 339 A
 Component: BF-Gewichtsens. 006 0002
 Subsystem 2 - Serial number: 00000000032ZU5
 Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63*
 Subsystem 4 - Serial number: 000000ÿ†6332MSME0D5078318ÿ†63 * *
 Subsystem 5 - Serial number: 078318ÿ†6342MSME0D5B594CVÿ†63 * *
 Subsystem 6 - Serial number: B594CVÿ†6351HTS61IKEK5K2Nÿ†63 * *
 Subsystem 7 - Serial number: EK5K2Nÿ†6361HTS61IKE8543/ÿ†63 * *
 Subsystem 8 - Serial number: E8543/ÿ†63727TS6I2IU56533ÿ†63 * *
 Subsystem 9 - Serial number: U56533ÿ†63827TS6I2IQIBQ2 ÿ *
 Subsystem 10 - Serial number: QIBQ2 ÿ
No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
 Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
 Component: J0527 0015
 Revision: 00005000 Serial number: 3C5953507P
 Coding: 0002111
 Component: E0221 006 0080
Self-Diagnosis Log
Page 8
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
 Part No SW: 3C0 920 970 R HW: 3C0 920 970 R
 Component: KOMBIINSTRUMENT VD1 4240
 Revision: X0033000 Serial number: 00000000000000
 Coding: 0007205
 Shop #: WSC 22228 444 52549
 VCID: 336563E55212D1DE47-8066
No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
 Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
 Component: Gateway 007 0040
 Revision: 00007000 Serial number: 0700C05C2800D5
 Coding: 3FFD0E04D31002
 VCID: 214999ADF8EE534EA5-8074
 Reset counter: 97
 Mileage: 224667 km
 Date: 2017.11.22
 Time: 22:49:21
------------------------------------------------------------------------------- Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
 Part No SW: 3C0 919 965 HW: 3C0 919 965
 Component: Kompass 005 0002
 Revision: 00005000 Serial number: 1166279TQ5P304
 VCID: 6DD1B59D74B6472E51-8038
Self-Diagnosis Log
Page 9
 Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
 Component: IMMO 041 0364
 Revision: 00041000 Serial number: VWZCZ000000000
 Shop #: WSC 00028 118 51761
 Subsystem 1 - Part No: 3C0 905 861 D
 Component: ELV 024 0370
 3C0905861D ELV 024 0370
No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
 Part No: 1K0 959 701 K
 Component: Tuer-SG 024 2365
 Coding: 0001205
 VCID: 36635AF14160C4F660-8062
No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
 Part No: 1K1 909 144 K
 Component: EPS_ZFLS Kl.5 D06 1701
Self-Diagnosis Log
Page 10
 Component: KSG PQ46 RDK 041 0213
 Coding: 13910F8801862E521804141FF00A0F0E081800
 Reset counter: 97
 Mileage: 224667 km
 Date: 2017.11.22
 Time: 22:49:21
00956 - Key 2
 Fault Status: 00100101
 Reset counter: 99
------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
 Part No: 1K0 959 702 K
 Coding: 0001204
 005 - No or Incorrect Basic Setting / Adaptation - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 11
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
 Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
 Component: EPB VC8HC001 013 0001
 Revision: 013
 Coding: 0000013
No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl
 Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
 Component: Radio PM6 016 0017
 Revision: 00016000 Serial number: VWZ5Z7E2052832
 Coding: 0040400
 VCID: 204F9CA9F3E45A46AA-8074
 Reset counter: 113
 Mileage: 225241 km
 Date: 2017.12.11
 Time: 00:00:02
 Fault Status: 00111011
 Reset counter: 114
 Mileage: 224661 km
 Date: 2017.11.22
 Time: 15:59:49
Self-Diagnosis Log
Page 12
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
 Part No: 1K0 959 703 D
 Component: Tuer-SG 021 2432
 Coding: 0000144
 VCID: 316969EDA80EE3CE35-8064
No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
 Component: RDK 0391
 Coding: 0100101
00667 - Ambient Temperature Signal
 Fault Status: 00111000
 Reset counter: 113
 Mileage: 225241 km
 Date: 2017.12.11
 Time: 00:13:20
------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
 Part No: 1K0 959 704 D
 Coding: 0000144
 VCID: 326B66E1AD08D8D64C-8066
End-------------------------(Elapsed Time: 02:05)--------------------------
Yo2095
California
C?ID=282415
It is a 2.0T with a tiptronic 09G transmission BPY engine. I own a 2009 CC with manual transmission and I absolutely love it over the Passat automatic transmission. I found a possible donor (2010 Jetta) for most of the parts, but I have no clue how to do any of the modules reprogramming.
Thanks for all the responses!
Please don't use the PRINT function in VCDS to post data here. The formatting is less than optimal and it's much harder to read here than the native text that VCDS generates. Please just copy & paste text directly, either using the COPY button on the Auto-Scan screen or by opening one of the text files that VCDS generates (for example in your Scans sub-folder) using Notepad and then copying the text here.
Please see: How to Get Verified.
My gut says the ECU 3C0-907-115-F is specific to the auto trans application. If I'm right about that, then it would need MT software flashed into it, which is something that can't be done using VCDS.
cazamoyr
C?ID=182839
2010 Passat transmission swap (DSG to Manual)
Hi Yo2095
I'm working on a transmission swap for my 2010 (3C) Passat. I'm already done with most of it and everything works fine :D. The only think I'm missing is the ABS coding as it has to be re-code it for the manual transmission. Could you please post the ABS coding for you 2009 CC manual tranny. I think I might be able to use your code as the ABS unit for Passat and CC should be same.
Thanks!
Hi Yo2095
Please post an Auto-Scan so people can see exactly what ABS module you have and what its existing coding is.
cazamoyr
C?ID=182839
Auto-scan:
Thursday,06,December,2018,09:37:02:16534
VCDS Version: 18.9.0.2 (x64)
VIN: WVWJK7AN6AE112453   License Plate: PASSAT
Mileage: 236370km-146873mi   Repair Order:
Chassis Type: AN-VW46 (3C0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 53 56 62 65 72
          77
VIN: WVWJK7AN6AE112453   Mileage: 236370km-146873miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 DA    HW: 06J 906 026 DA
   Component: MED17.5 TFSI 2,0    6987
   Revision: AAH15---    Serial number: VWZCZ000000000
   Coding: 0404010A18070160
   Shop #: WSC 05314 123 12345
   VCID: 6CD7FF894FCB612A19-8038
Readiness: 1110 0101
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --025---    Serial number: 00000705132477
   Coding: 0000000
   Shop #: WSC 05311 000 00000
   VCID: 62CB91B1BD0F275AA3-8036
            000 -  -
                    Reset counter: 138
                    Mileage: 236379 km
                    Date: 2013.04.28
                    Time: 14:21:45
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 149
                    Hex Value: 0x0000
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 05311 115 00000
   ROD: EV_ClimaBasis_VW46.rod
   VCID: 75E1DAEDD481A0E2F6-8020
   Revision: 00H54000    Serial number: 00000003639490
   Coding: 15848F0340041A00470000000F00000080285D435C000120000000000000
   Shop #: WSC 05124 123 12345
   VCID: 336524F55275FED218-8066
   Subsystem 1 - Part No: 3C1 955 419 B  Labels: 1KX-955-119.CLB
   Component: Wischer 140110 006  0208
   Coding: 00046997
   Shop #: WSC 05124
   Part No SW: 5N0 959 655 H    HW: 5N0 959 655 H
   Component: J234__01T VW10 HI   1916
   Revision: 20013000    Serial number: 003E1P2X8EBP
   Coding: 0012628
   VCID: 428B71311DCF475A83-8016
   Subsystem 1 - Part No: 000 000 000 00
   Component: BF-Gewichtsens. 000 0000
   Subsystem 2 - Serial number: 00000000000000
   Subsystem 3 - Serial number: 0000.00.000000000000000000ˇÜ63
   Subsystem 4 - Serial number: 000000ˇÜ6332MTS612523509 ˇÜ63
   Subsystem 5 - Serial number: 23509 ˇÜ6342MTS649710270 ˇÜ63
   Subsystem 6 - Serial number: 10270 ˇÜ6351HTS6OIV286KJ ˇÜ63
   Subsystem 7 - Serial number: 286KJ ˇÜ6361HTS6JV2986KR ˇÜ63
   Subsystem 8 - Serial number: 986KR ˇÜ63727TS6K56886KR ˇÜ63
   Subsystem 9 - Serial number: 886KR ˇÜ63827TS6KGT986KR ˇ
   Subsystem 10 - Serial number: 986KR ˇ
02511 - Control Module for Seat Occupied Recognition (J706)
                    Fault Status: 11100100
                    Reset counter: 178
                    Mileage: 236379 km
                    Date: 2013.04.28
                    Time: 14:11:31
00592 - Seat Belt Switch; Passenger (E25)
                    Fault Status: 11101010
                    Mileage: 236379 km
                    Date: 2013.04.28
                    Time: 14:11:23
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
                    Fault Status: 11101001
                    Mileage: 236379 km
                    Date: 2013.04.28
                    Time: 14:11:23
01218 - Side Airbag Igniter; Passenger Side (N200)
                    Fault Status: 11100001
                    Mileage: 236379 km
                    Date: 2013.04.28
                    Time: 14:11:23
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Component: LENKS.MODUL   009 0122
   Revision: FF010035    Serial number: 20100208100160
   Coding: 018A270002
   Shop #: WSC 05311 115 12345
   ASAM Dataset: EV_VW360SteerWheelUDS A03002
   VCID: 6BD5FC9582C5661210-803E
   Coding: E20000
   Part No SW: 3C0 920 972 L    HW: 3C0 920 972 L
   Component: KOMBI         H03 0305
   Coding: 260F00
   Shop #: WSC 05314 115 00000
   VCID: 2F6D2885765DDA327C-807A
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
   Component: J533  Gateway   H13 0172
   Revision:   H13       Serial number: 3620P10218073D
   Coding: F9807F07001612001002
   VCID: 2F6D2885BE5DDA327C-807A
   Part No SW: 3C8 919 965     HW: 3C8 919 965
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1614128T1CCS02
   Coding: 0000002
   Shop #: WSC 05314 000 00000
   VCID: 75E1DAED1C81A0E2F6-8020
   Part No SW: 3C0 959 433 AP    HW: 3C0 959 433 AP
   Component:    IMMO         052 0383
   Revision: 00052000    Serial number: VWZCZ000000000
   VCID: 78FFD3D90B93DD8AED-802C
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667824967
   VCID: 2643CDA151A79B7A8F-8072
   Part No SW: 3C0 959 701     HW: 3C0 959 793
   Component: TUER-SG FT    002 0305
   Revision: 13101005    Serial number: 0000439990
   Coding: 0004B5
   ROD: EV_DCU42BroseDriveSide_VW36.rod
   VCID: 65C18AAD6421506246-8030
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 A    HW: 3C0 959 795 A  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0402
   Serial number: 00000001264426
   Coding: 000490
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.148 0703
   Revision: 1AH03726    Serial number: 00093370154002
   Coding: 0000258
   VCID: 3A7B09D1751F0F9ADB-806E
   Component:    KSG PQ46 RDK 052 0412
   Coding: 13910F8001862E521004141FF08A0F0E085801
   Part No SW: 3C0 959 702     HW: 3C0 959 792
   Component: TUER-SG BT    002 0305
   Revision: 15101005    Serial number: 0000416234
   Coding: 0004B4
   ROD: EV_DCU52BrosePasseSide_VW32.rod
   VCID: 66C38DA199275B7A4F-8032
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 A    HW: 3C0 959 794 A  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0402
   Serial number: 00000001281521
   Coding: 000490
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000167979
   Coding: 0000056
   VCID: 2C573F898F4BA12A59-8078
03182 - Clutch Position Sensor (G476)
                    Fault Status: 11111010
                    Reset counter: 138
                    Mileage: 236379 km
                    Date: 2013.04.28
                    Time: 14:11:22
                    Voltage: 11.70 V
                    Count: 57
                    Hex Value: 0x1261
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0035
   Revision: -----20S    Serial number: VWZ4Z7K1111828
   Coding: 0100040004
   VCID: 61C99EBD78093C42BA-8034
                    Reset counter: 138
                    Mileage: 236379 km
                    Date: 2000.15.00
                    Time: 14:11:24
            000 -  -
                    Reset counter: 138
                    Mileage: 236379 km
                    Date: 2000.15.00
                    Time: 14:11:21
   Component:    RDK              0453
   Coding: 0100101
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 E    HW: 1Z0 035 729 E
   Component: FSE_2P8x        H40 0190
   Revision: 00000000    Serial number: 00000005197183
   Coding: 0013077
End-------------------------(Elapsed Time: 02:27)--------------------------
