Octavia MKiii 2017 Starter system faulty workshop error
tomer
Israel
C?ID=324798
Hi, new here
I've had the car (Octavia RS 220 TSI DSG6 2017) for about 4 months and recently I'm getting "Starter system faulty workshop!" error after I turn off the switch . If I turn off the engine and switch quickly at once, it doesn't appear.
So far I've been to the importer's service 3 times and they've yet to figure out the problem, although they're working according to Skoda's instructions (so they say) .
I don't have any ignition issue with the car what so ever. Here's a scan i took today:
Friday,02,February,2018,15:20:47:12953
VCDS Version: 18.1.0.2  HEX-V2 CB: 0.4411.4
VIN: TMBAE7NE4H01XXXXX   License Plate:
Mileage: 3445km-2140mi   Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A9
VIN: TMBAE7NE4H01XXXXX   Mileage: 3445km-2140miles
5F-Information Electr. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 C    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 0C1D00124424010B0000
   Shop #: WSC 19383 002 1048576
   ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
   ROD: EV_ECM20TFS0205G0906259C.rod
   VCID: 2E05F397B0946CE7CA9-807A
Readiness: 1000 0001
   Part No SW: 0D9 300 042 S    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5010
   Revision: 06454104    Serial number: TFK01610120525
   Shop #: WSC 73430 031 00063
   ROD: EV_TCMDQ250021.rod
   VCID: 290F008B897A0BDF1FB-807C
          P1734 00 [002] - -
Address 03: ABS Brakes (J104)       Labels:| 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0398
   Revision: 00000000    Serial number: 63006000001556
   Coding: 1A076B91542119704078060241CB2958D62A98026082947600410070C00903
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
   ROD: EV_Brake1UDSContiMK100ESP_035_SK37.rod
   VCID: 75B71CFB15421F3F4B3-8020
   Part No SW: 5E0 907 044 AB    HW: 5E0 907 044 AB
   Component: Climatronic   H04 1601
   Revision: 00001K07
   Coding: 01010004000110011005000000101002
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 65974CBBA5E2EFBFFB3-8030
   Air quality sensor:
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
   Serial number: 01061629000275
   Coding: 0C101A42C24722FB47E04000000C07280000000000000000000000000000
   Shop #: WSC 73430 790 00000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0451713F4E9836B74CD-8050
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 161004  041 0570
   Serial number:         161018094438
   Coding: 065DDD
   Component: RLHS  042 0105
   Serial number: S3Y16M10D31H09M51S07
   Coding: 00885D
   Sun Roof:
   Subsystem 3 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.403  H03 0004
   Serial number: 0000FST0018NRYL00000
   Coding: 981803
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39261629502863
   Coding: 0001050011
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   ROD: EV_EPHVA14AU3700000_002_VW27.rod
   VCID: 3C21C9DF76E88E7774D-8068
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPMWG67-
   Coding: 98CCC000000000005C5400CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F7B4E1317DE45EFE1F-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 710 16
   Serial number: 3576U000000241E8BD1J
   Subsystem 2 - Part No SW: -----------    HW: 454 000 310 16
   Serial number: 3586U000000235244E11
   Subsystem 3 - Part No SW: -----------    HW: 454 800 610 16
   Serial number: 3516REB80310D0000006
   Subsystem 4 - Part No SW: -----------    HW: 454 801 310 16
   Serial number: 3526RF8242F0C000000F
   Subsystem 5 - Part No SW: -----------    HW: 454 800 810 16
   Serial number: 3556V422EF90C000000M
10492928 - Supply Voltage
          B201C 00 [008] - Implausible Signal
          [Powersupply implausible signal]
                    Reset counter: 26
                    Mileage: 3445 km
                    Date: 2018.02.02
                    Time: 15:17:18
   Part No SW: 5Q0 953 521 T    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20161026500471
   Coding: 1410
   Shop #: WSC 73430 031 00000
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 43D3B2230B16F18F357-8016
   Part No SW: 5E0 920 746 C    HW: 5E0 920 746 C
   Component: KOMBI         205 8311
   Coding: 07A5010829800008010A2A001000000000000000
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005454104
   Coding: 030100047F085900EB00026A1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013_SK37.rod
   VCID: 7CA109DF36684E7734D-8028
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000A0320111016
   Serial number: 75410803001610260561
131699 - Control unit for information electronics 1
          U1054 00 [009] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuerger\E4t f\FCr Informationselektronik 1]
                    Reset counter: 238
                    Mileage: 3429 km
                    Date: 2018.01.30
                    Time: 15:28:43
                    Terminal 15: On
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert \FCberschritten]
                    Reset counter: 26
                    Mileage: 3436 km
                    Date: 2018.01.30
                    Time: 22:28:17
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
   Component: TSG FS        010 0032
   Serial number: 0000223728077
   Coding: 001D0120D000040000001100
   VCID: 47CBA6333F2EDDAFE9F-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000011987022
   Coding: 010200
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCFC77CDCB047661-806E
   Component: TSG BFS       010 0032
   Serial number: 0000225193883
   VCID: 46D5AB373824C4A7129-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000012042926
   Coding: 190200
   Coding: 03DA00003F000000
   Shop #: WSC 73430 790 00063
   VCID: 40D9BD2F1A00EA97285-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 161008200130
   VCID: 698F408B49FACBDFDFB-803C
End----(Elapsed Time: 01:31, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
I think the "10763 - Starter Enable from Selector Lever Sensor System" error has something to do with this issue, as I'm not getting it every scan.
I've replaced the original stereo system with aftermakret Alpine multimedia so i guess some of the Can bus errors have to do with that ,
no idea where the airbag "Supply Voltage
B201C 00 [008] - Implausible Signal" comes from - should this be a concern?
Any advise or lead would be most appreciated
iichel
Netherlands, eastern part
C?ID=284912
Gear selector switch problems are not uncommon on the Octavia III, that's the first thing I would check.
tomer
Israel
C?ID=324798
I couldn't find anything relevant with the word "lever", "selector" or "shift" under advanced measurements , when searching for "gear" i found:
selected gear
Gear position sensor. raw value
Gear position sensor. current value
Gear position sensor. last valid value
Gear position sensor. gear position valid
none of the measurements in the above made any sense while measuring and changing gears - should i be getting a letter (d,p,r ) ?
How about:
IDE00095-ENG101643 -- Status of selector lever lock - Status Shift Lock
IDE00096-ENG100569 -- Selector lever position - Shift Position
IDE02719-ENG99606 -- Selector lever position made plausible - Shift Position Plausible
These should all turn up with 'selector' in the search/filter box...
tomer
Israel
C?ID=324798
i searched for the word selector and don't recall any of these come up. what am i missing?
I'm not sure what you're missing. Is it possible you made a typo?
In any case, since I've given you the database identifiers, you should be able to find these. :)
tomer
Israel
C?ID=324798
ok got it - i was looking under engine adv. measurements instead of auto trans..
anyways, the values i get match the gear lever position.
any other ideas?
thanks
Sounds like you may have an intermittent fault...
tomer
Israel
C?ID=324798
yes, for sure, if i close the switch quickly, I'm not getting the error message
tomer
Israel
C?ID=324798
Also, in my last visit to the imprter's workshop, they replaced the battery as I complained i was getting "12v battery low" warning messages before starting the car.
I noticed they didn't recode the battery's serial number . all the other details were correct (battery type, manufacturer, capacity). is this critical ?
I think a change to the serial number is what tells the BEM that a new battery has been installed. Post your Battery History Data and let's see what it shows.
tomer
Israel
C?ID=324798
Pasting only the relevant part (i hope that's the right part..)
Record 4/16: Battery change history
2018-01-17-00:08*03*069*BA2*BA21H9VBDN*09989*00105*0000*0000*0000**
       0000000km*02*069*JCB*1111111111*09989*00795*0013*0001*0000**
       0000000km*01*069*JCB*1111111111*10000*00000*0000*0000*0000**
17/1/18 is the date I've been in the garage . the serial number is wrong though, the one on the (new) battery is longer - BA2170930U0DN
Then it seems your BEM knows the battery has been changed. If it was mine, I wouldn't try "correct" the serial number at this point.
tomer
Israel
C?ID=324798
Thanks, i won't touch it.
Any other thought about the "starter system" error message?
I forgot to mention, that as part of the multimedia upgrade, I installed Connects2 Infodapter which allows me to control the car's settings through the Alpine screen and use the wrs button to change driving modes.
I don't think it has anything to do with the error as it started to appear some time after the Infodapter installation.
tomer
Israel
C?ID=324798
Also, I'm trying to figure out this under airbags
 Supply Voltage
From what I understand, 4 fault priority is kind of high. Any thought what could this be?
 Supply Voltage
If you clear it, does it come back?
tomer
Israel
C?ID=324798
yes, just found a scan from November, same error there. I've cleared all the errors several times since
tomer
Israel
C?ID=324798
Manged to solve the problem - it was the VW Infodapter causing this error http://www.connects2.co.uk/Product/ProductItem/CTUSK02
once disconnected, warning message and beeping gone.
Still getting the selector error under gearbox though
          P1734 00 [002] - -
          P1734 00 [002] - -
From the multiple posts about this intermittent error on briskoda.net it would appear that a faulty selector switch is a common problem on the Octavia III.
