MK7 Golf Climate Windscreen Retrofit
JS3
C?ID=240511
Hi guys - has anybody retrofitted a climate windscreen to a MK7 golf? (Basically a heated windscreen) I would like to understand wiring and any associated controllers (plus coding of course). No Autoscan yet, will post later.
Thanks!
darkchina811
ITALY
C?ID=333184
I am looking into it as I have to replace the windscreen anyway to retrofit the Lane Assist camera.
the wiring is basic, one wire from the BCM goes to the engine fusebox to trigger a relay that will power the windscreen. there will be no actual button for the feature, you activate it through the radio on the Climatronic menu.
coding should be easy as well, I think the Long Coding talks about the option for both 08 and 09 modules.
MasterTommy
Amsterdam
C?ID=295586
I have one from the factory on my MQB tiguan. If your golf has a MIB 2.5 and a adaptations only/zero coding BCM i suspect it will be quite similar regarding coding/adaptations.
See here.
darkchina811
ITALY
C?ID=333184
thanks for the insight, it will be of some inspiration, but I have an old BCM with coding.
DV52
C?ID=194404
Thanks!
JS3: hi To add to the advice that has already been given- it doesn't look like rocket science from a WD perspective (see below), albeit I haven't done the retrofit personally.
As you can see - besides the wiring loom, you will also need to install a relay to control the comparatively large electrical current (the BCM can't do this directly). I reckon the first task in the project (before you spend bucks buying the various bits-and-pieces) is to check whether your current BCM has Pin #26, Socket A physically populated. This is a pretty-good indicator that your BCM can accommodate a heated windscreen function. Of course, if this pin is missing the task becomes more complex (including the dreaded job of clearing Component Protection errors)
kyle_h
Canada
C?ID=206710
Thanks!
So did you do it? 🤣
iichel
Netherlands, eastern part
C?ID=284912
I did but to a Passat with 5q0 bcm. Does that count?
Cuzoe
C?ID=279487
Interesting to see this pop up just as I'm looking at going through the firewall for the "last" time. My goal is to lay in wiring for anything I may want to retrofit later.
Anyway... found two part numbers for heated Golf glass with "facelift" style Driver Assist, so 3Q0 camera.
This one that is available in the states and elsewhere, seems to be an e-Golf part number, and parts.vw.com describes it as a rear windshield, haha.
Heated with Driver Assist (facelift, 3Q0 camera) - 5GE845011E NVB
Don't know how long this link will be alive but the glass is pictured.
This one that is not available in the states, looks like the same glass but not an e-Golf part number
Heated with Driver Assist (facelift, 3Q0 camera) - 5G0845011 AR
Again, don't know how long this link will be alive but the glass is pictured, you can see a connector at the bottom left of the pic (lower right of the windshield).
The wire routing is pretty straight forward, as is the coding. Now working on the part number for connectors and relay (not expecting trouble) and the relay "holder" section of the engine fuse box.
I'm not positive but I think this section of my fuse box is empty so I need the insert... and the repair wires (or terminals) for the wiring at the relay.
Cuzoe
C?ID=279487
My phone does something strange when I try to edit... but confirmed nothing in the second "row" (from the left) of my engine fuse box.
Perusing some Erwin drawings and some other diagrams for a 2019 Golf R one can get the nearly whole picture of what is required.
So I guess we can start with the electrical, which was partially pictured above but sort of needs more...
  • J47 is the Windshield Defogger Relay, which will need to be installed (position R11 engine fuse box), PN (Watch This Space :D)
    • Terminal 121 is 0.5mm (20 AWG) wire, tied to the output of Fuse SB17
      • This is a 7.5A fuse and will exist in your car, feeds several other things
      • It will not be replaced, as it just provides power to the relay J47 relay coil
    • Terminal 122 is 0.5mm (20 AWG) wire, goes into the cabin, BCM Plug B Pin 26
      • This is a ground for the relay coil, provided by the BCM (control via Infotainment screen)
      • Note the diagram in prior post shows BCM Plug A which is incorrect, BCM Plug B has 46 pins (Plug A and C have 73)
      • This is where your long coding will come in pre-facelift, or adaptation on facelift BCM
    • Terminal 123 is a 4mm (12 AWG) wire that is fed by Fuse SB14
      • SB 14 is a 40A fuse, which your car will not have so wiring needs to be added for the line and load side
        • This is "low profile maxi" type, although I suspect that's not the official name it'll get you what you want, haha.
        • Line side of this comes straight off the battery bus bar tied to (large, threaded) terminal 508 at the front of the box
        • Load side is a 4mm (12 AWG) wire which jumps right over Terminal 123 of the J47 - Windshield Defogger Relay
    • Terminal 125 is a 4mm (12 AWG) wire that is spliced (into two 4mm (12 AWG) wires) that go to connectors left/right windshield base
      • The diagram is sort of weird, and shows Z2 - Windshield Defogger, which I believe is the element of the windshield
      • So this Z2 has a connection on the left and right side (base) of the windshield
      • The schematic calls them A1 and B1 though it doesn't say which side is right/left (and it doesn't matter)
      • Not shown in my diagram for the Golf R but Tiguan drawing shows these, 1 wire connectors, both PN 071973851
      • Diagram shows "C1" which I suspect as the front windshield chassis ground
Now for the fuse panel, in my car there nothing in this second row, so an insert is required...
  • This will be position R11 of the engine fuse box (Fuse Panel B for you purists).
  • There are two inserts that can go in this spot, shown as item 6 and 9 of the picture.
  • You want item 9, PN 5Q0937507B which has a space for R11 (that we need)
    • Keen eyes may note that item 9 is for PR Code 4GW which is... heated insulating windshield!
    • This PR Code is shown in one place on the Golf drawing, but is all over the Tiguan drawings
  • You may find you already have this insert there, with position R8 used... circle gets the square!
    • Note, I am only talking Golfs here, Tiguan is a little different with the fuse layout.
Hopefully someone with more patience (and resources) than I will find the repair wire part numbers for these relays. In a shamefully delayed moment of insight I picked up a spare fuse panel.
All that means is I have plenty of wires with the the terminal types needed for fuses. Some repair wires can be $30-40 alone. I paid under $50 shipped for the spare fuse panel.
I don't know how XenForo decided which pictures to insert vs which ones to link, but you win some you lose some.
SiKa-FIN
C?ID=536536
Hi everyone!
I'm retrofitting windsreen heating to my Golf 7.
Windscreen with Kufatec wiring loom installed, some coding done but not able to get it working.
screen/radio is changed to aftermarket. (Zenec Z-E1010)
It shows HVAC screen when selecting "MENU" but windscreen heating activation isn´t possible.
current BCM: 5Q0937084AJ H18 0137
Thursday,05,October,2023,18:32:38:54671
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 42 44 52 69 6C
VIN: WVWZZZAUZFWxxxxxx   Mileage: 247996km
69-Trailer -- Status: Not registered 0001
6C-Back-up Cam. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 8138
   Revision: 84H22---    CVN: AFF1A808
   Coding: 0125001A032415092000
   ASAM Dataset: EV_ECM16TDI01104L906021N 002013
   ROD: EV_ECM16TDI01104L906021M_002_VW37.rod
   VCID: 30391C328AAE0B7ABFB-8064
   VINID: 9E69EAAAA465A969C21412401001D63D1B
   Part No SW: 0CW 300 047 C    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5220
   Revision: 00043014    Serial number: CU501501165633 CVN: 0000BA34
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 3B233B1E53E8F8221A9-806E
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 60265000001349
   Coding: 01FA62A11425096D0780060041C72580462890E06082A4F300420078C202
   ROD: EV_Brake1UDSContiMK100IPB_034.rod
   VCID: 48C954D2123EA3BA87B-801C
4214 - Auto-Hold Switch
          C10CE 29 [008] - Signal Implausible
          [AVH switch was pressed longer than 10 s]
                    Reset counter: 215
                    Mileage: 247842 km
                    Date: 2023.10.03
                    Time: 15:51:01
   Part No SW: 5G0 907 044 BE    HW: 5G0 907 044 BE
   Revision: 00001K08
   Coding: 00020104204401011005000100101000
   Shop #: WSC 12345 123 64416
   VCID: 6B83CB5E6308A8A2CA9-803E
   Air quality sensor:
328964 - Motor for Front Air Distribution Flap
          B1091 71 [008] - Actuator Stuck
                    Reset counter: 222
                    Mileage: 247984 km
                    Date: 2023.10.05
                    Time: 17:56:23
                    Voltage terminal 30: 13.4 V
                    Outside temperature: 13.0 °C
                    Inside temperature: 23.9 °C
                    Front air distribution flap: actual value: 31
                    Front air distribution flap: actual value: 0.0 %
                    Air distribution door front - Specified value: 46
328965 - Motor for Front Air Distribution Flap
          B1091 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 182
                    Mileage: 247984 km
                    Date: 2023.10.05
                    Time: 17:24:19
                    Voltage terminal 30: 13.6 V
                    Outside temperature: 12.5 °C
                    Inside temperature: 25.0 °C
                    Air distribution door front - Specified value: 26
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011503000814 Dataset Number: 5G0063v____ 0001
   Coding: 000218E6C2C102F34BE44000001C07081408000000000000000000000000
   Shop #: WSC 12345 123 23456
   ROD: EV_BCMBOSCH_013.rod
   VCID: 00598CF27A8E5BFA0FB-8054
   Wiper motor control module:
   Component: WWS    150113  043 0551
   Serial number:         150120172435
   Component: RLHS  037 0059
   Serial number: S5Y15M02D03H01M43S49
   Coding: 06A8DD
197644 - Control Circuit for Fuel Tank Flap
          B1263 01 [008] - Electrical Failure
                    Fault Frequency: 7
                    Reset counter: 221
                    Time: 00:00:00
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): OFF
                    Status Bremslichtschalter (CAN): OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Automatic high beam assist: operated
                    Low beam: Not operated
                    Parking light left: Not operated
                    Parking light right: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 12.1 V
                    Outside temperature: 18.5 °C
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 170
                    Mileage: 247714 km
                    Date: 2023.10.01
                    Time: 05:41:13
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    last_wakeup: no cause for fault protection
                    Voltage: 12.6 V
                    Outside temperature: 12.0 °C
565764 - LED Light Bar
          B1664 31 [009] - No Signal
                    Reset counter: 158
                    Mileage: 247503 km
                    Date: 2023.09.25
                    Time: 13:04:32
                    Terminal 15 status: On
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.2 V
                    Outside temperature: 19.5 °C
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391502018330 Dataset Number: 5G0039v__A_ 0020
   Coding: 0031151211
   Shop #: WSC 00078 790 12345
   VCID: 3D2735064DFCF61224D-8068
   Component: AirbagVW20    014 0385
   Serial number: 003F6R0FN216 Dataset Number: 5G0003v____ 0096
   VCID: 41DF49F6310492F2405-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 401 15
   Serial number: 357670000004E11C921T
   Subsystem 2 - Part No SW: -----------    HW: 480 002 401 15
   Serial number: 358670000003AC6DA210
   Subsystem 3 - Part No SW: -----------    HW: 480 402 101 15
   Serial number: 3516502B9196FF4310EO
   Subsystem 4 - Part No SW: -----------    HW: 480 402 101 15
   Serial number: 3526502BD19121A233E7
   Subsystem 5 - Part No SW: -----------    HW: 480 402 101 15
   Serial number: 3556502B519121A1518
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150128500665
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDB4F0E47F0E402361-806A
   Part No SW: 5G1 920 741     HW: 5G1 920 741
   Component: KOMBI         204 4270
   Coding: 07A51A082380000801082A003400000100000000
   VCID: 6491A0628ED6E7DA8B3-8030
16776995 - Databus
          [ARA_01 keine Kommunikation]
                    Reset counter: 158
                    Mileage: 247503 km
                    Date: 2023.09.25
                    Time: 13:04:32
   Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
   Component: STH-MQB       006 0069
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   VCID: 36352A2A68CA254AE57-8062
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001049153
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 E
   Component: GW MQB Mid    127 1204
   Revision: --------    Serial number: 0003044929 Dataset Number: 5G0067v____ 2011
   Coding: 030100040F087300EF0002481C0F00010001050000000000000000000000
   GVL: 01543C0000000000400C00000006C00000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 71BFD93641244272F05-8024
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29150000107320085037
   Coding: 28FFFF
131689 - Rear View Camera System Control Module
          U104C 00 [009] - No communication
          [Timeout Knoten 0x69 / 6C - Steuergerät für Rückfahrkamerasystem]
                    Reset counter: 158
                    Mileage: 247503 km
                    Date: 2023.09.25
                    Time: 13:04:32
                    Terminal 30 power supply: 12.1 V
                    Terminal 15: On
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
          [Mehrverbau CAN]
                    Fault Frequency: 124
                    Reset counter: 182
                    Mileage: 247503 km
                    Date: 2023.09.25
                    Time: 13:04:32
                    Terminal 15: On
197175 - Control unit for battery monitoring
          U1050 00 [009] - No Communication
          [BDM (LIN#1) Timeout]
                    Reset counter: 158
                    Mileage: 247503 km
                    Date: 2023.09.25
                    Time: 13:04:32
                    Terminal 15: On
   Serial number: 190115BAI13715 Dataset Number: 5G0222v____ 0061
   Coding: 00350320D000040000001000
   VCID: 42DD46FA340289EA59F-8016
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000005112533
   Coding: 110000
   Component: EPS_MQB_ZFLS  126 1061
   Dataset Number: 5G0074v____ 0881
   Coding: 0102
   VCID: 43D343FE2B1880E2529-8016
   Serial number: 130115BAC07539 Dataset Number: 5G0157v____ 0057
   Coding: 00350120DE00040000801000
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000005095236
   Coding: 090000
   Part No SW: 5Q0 907 383 F    HW: 5Q0 907 383 C
   Component: Anhaenger     H14 0137
   Revision: 8B001001    Serial number: 0339739303
   Coding: 0101000202100000
   Shop #: WSC 01286 386 08256
   VCID: 3A2D3E1A5CD2C12A01F-806E
Address 6C: Back-up Cam.
End----------(Elapsed Time: 01:39, VBatt start/end: 12.4V/12.3V)-----------
downtime
C?ID=280813
Are you sure the aftermarket radio has that function? Try with your original radio if it allows to turn the heating on.
MasterTommy
Amsterdam
C?ID=295586
If you push the physical MAX defogging button (windshield icon with max below it) the blower goes on max and the electrical windshield heating turns on. If the electrical windshield heating works, you’ll be able to see that in measuring values of the BCM, and if it doesn’t, the BCM will probably throw a code. The windshield doesn’t get warm to the touch, so thats not a reliable indicator.
If the electrical windshield heating works with the above method, I’d say your issue is the aftermarket infotainment unit, since the button to turn on the electrical windshield heating manually is in de climate menu that displays on the infotainment screen. The setup sub-menu of the climate screen also contains a setting that turn automatic electrical windshield heating on and off.
The electrical heated windshield isnt a very common factory option, so I’m pretty sure it might very well be unsupported by your infotainment unit.
Edit: Heated windshield button is added in V3.6 according to these release notes.
MasterTommy
Amsterdam
C?ID=295586
And I have never heard of this system before, but 5 mins on google got me software release notes.
