Hello guys.
First about LIGHT SENSOR
I remember I had a skoda mk2fl and the light sensor sensitivity adjusting was very easy.
Now in new 2018 Golf these settings are all in adaptations.
So I was trying to find anything light related in adaptations channel after i used the security code, and i found this:
There I found these options that I'm 100% sure will solve the problem (changing these values):
BUT then I try to change these values it says something about "request out of range/reach".
I saw a post in 2016 that somebody tried to change these values and got the same problem, I'm just interested has anybody actually succeeded in this?
Any opinions options advises?
Second about AID
I have seen few Golf that have AID panel that was coded to look like an R theme. I'ts almost the same as mine but does have speed number between 60 and 100.
Here is how mine looks:
Here is how Golf R AID looks, see, it has 60km, 80km 100km.
Am I in the right place in changing them if I try to change these values:
My normal setting is Variant 2, tried to change it to 1, turned off the power and then turned on, but didn't notice the difference, what am I doing wrong?
Here is my autoscan:
Second about AID
Sunday,28,January,2018,14:30:55:47449
VCDS Version: 18.1.0.2 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
VIN: WVWZZZAUZJW060359 License Plate: SMK-146
Mileage: 4314km-2680mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 29 2B 39 42 44 47 4B
52 5F A9 D6 D7
VIN: WVWZZZAUZJW060359 Mileage: 4314km-2680miles
Address 01: Engine (J623-CHHA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 C HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D001A4464050B3000
ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
ROD: EV_ECM20TFS0205G0906259C.rod
VCID: 2E05F034209CD0E7CA9-807A
Part No SW: 0D9 300 043 F HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5204
Revision: 06454104 Serial number: TFK01706290712
ROD: EV_TCMDQ250021.rod
VCID: 1D6727F85D3A5B7F633-8048
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 62067000002797
Coding: 01FA6BA13426216C477A0605C0CCA980D62C84E26003957738425078C209430000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_036.rod
VCID: 77AB15509F46D12F59F-8022
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0450687998
Coding: 032C1C
Shop #: WSC 12345 123 61029
VCID: 3C21CA7CE6E0327774D-8068
Part No SW: 5G0 907 044 CG HW: 5G0 907 044 CG
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0002001420411101100500400010102A
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 6E853034E01C90E78A9-803A
Air quality sensor:
Part No SW: 5Q0 937 084 CP HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H36 0253
Serial number: 01001722300524
ROD: EV_BCMBOSCH_018.rod
VCID: 084966ACE2B8AED7205-805C
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 170712 043 0551
Serial number: 170724041113
Component: RLHS 042 0105
Serial number: S4Y17M08D17H00M33S30
Coding: 00A8DD
Sun Roof:
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST001PYC7700000
Coding: 181801
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617222
Coding: 0471151811
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 4BC399A0B34E85CFCD7-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 3300678159FFC728949C810580400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
ROD: EV_ACCBOSCHVW416.rod
VCID: 3E25C074F0FC20675A9-806A
Part No SW: 5Q0 959 655 BH HW: 5Q0 959 655 BH
Component: AirbagVW21 005 0336
Serial number: 003VVR36VT7$
Coding: 98CCC000000000005C0000CF000800000065
VCID: 074B6590EFA6A1AF29F-8052
Subsystem 1 - Part No SW: ----------- HW: 480 001 008 17
Serial number: 35700000000C404D362G
Subsystem 2 - Part No SW: ----------- HW: 480 001 008 17
Serial number: 358000000006924CF62T
Subsystem 3 - Part No SW: ----------- HW: 480 400 208 17
Serial number: 3510001A726D7C0417F8
Subsystem 4 - Part No SW: ----------- HW: 480 400 308 17
Serial number: 3520001A726D7C0437FB
Subsystem 5 - Part No SW: ----------- HW: 480 400 308 17
Serial number: 3550001A12711E33977-
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 09081704221769
Coding: 0410
ROD: EV_SMLSKLOMQB_VW37.rod
Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
Component: KOMBI 407 3193
Coding: 03AD11182F80000801886B011401000000000000
VCID: 2A0DFC241C74BCC7161-807E
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 H HW: 5Q0 963 272 H
Component: STH-MQB 008 0075
Coding: 9309
VCID: 3B23C960E3EE354F7D7-806E
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000293101
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 01081710521651
Coding: 030100047F085900FB00027A1C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 3333E140CBBEFD0FA57-8066
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170001588160057315
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 5935334904
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
VCID: 47CBA590AF2661AFE9F-8012
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000199056008
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3431E25CCEB0FA37BCD-8060
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Component: TSG FS 020 0041
Serial number: 100717EG811399
Coding: 003F1320D000040000001000
VCID: 43D3B1809B1E4D8F357-8016
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000015840998
Coding: 110000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2DCC64ECD40C47661-806E
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1HMD00P059
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI.rod
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 02081710523497
Coding: 000000050100164A01100F01020000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X.rod
VCID: 72BD2444F424B4076E1-8026
Component: TSG BFS 020 0041
Serial number: 170617EFG60661
Coding: 003F1120DE00040000801000
VCID: 42DDB484840444873E1-8016
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000015854288
Coding: 090000
Part No SW: 3Q0 035 864 C HW: 3Q0 035 864 C
Component: MU-S-N-ER 851 0842
Coding: 02731001000000005111000200080A001F0503F401200000CF
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 313FEB4831A2CF1FD7B-8064
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHT2191632
Subsystem 2 - Part No SW: 3G0 919 866 BC HW: -----------
Component: ECE1 2017/18 --- 0820
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 170627200184
VCID: 6B833920D30E65CFAD7-803E
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 392FD368E9D2075F6FB-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----------(Elapsed Time: 01:54, VBatt start/end: 12.3V/12.2V)-----------
