A6 Oem towbar install.
What's the difference between the first bit that shows comms failure with instruments and the bit below that shows no faults?
This is is just what the Gateway thinks:
17-Instruments -- Status: Cannot be reached 0100
Whereas this is what the module itself has to say when VCDS talks to it.
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 985 L HW: 4G8 920 985 L
Component: TDieGb H08 0043
Revision: 04001037 Serial number: 658220415596032
Coding: 33A612000B412600010000
Shop #: WSC 63606 001 1048576
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 40897DDADBEC1145F5-8014
davebrannigan
C?ID=171908
So why would the changes made make the gateway "think" any different to what it has always reported thus far? For that matter, what is the "gateway" when it come to CAN? Where does it reside?
As background I am a bit of a systems type person. Electrionics / process/ networking but I confess I'm a virgin on CAN but willing to learn.
   #23
The gateway is like a router on a LAN. It connects and routes traffic between the various network segments inside the car to each other, as well as to the dedicated network segmet that goes to the outside world on your OBD-II connector.
I don't know why your gateway thought your instrument cluster was incommunicado at that particular moment.
davebrannigan
C?ID=171908
mmm well it wasn't just that particular moment. I did a few scans of individual modules and in total 3 auto scans and on each one it reports the same issue. Odd...
Sound like the gateway needs updating as to what nodes are out there?
   #25
Scratching head. That is strange.
davebrannigan
C?ID=171908
I think before I go any further I'm going to put all my coding back to as it was before and see what errors I get. Got to thinking that at the same time my Stop Start fault was fixed by Audi I changed the coding to automatically dip the passenger side mirror when engaging reverse. After these two events I got the message regarding my mobile phone antenna. Coincidence? Now, after adding the trailer module I got a GPS antenna error too. I'm struggling to see a link but stranger things have happened at sea - or so they say. I'm going to put it al back as was including the mirror and see what happens and we can go from there.
I'll let you know.
Oh and another thing. the instructions that come with Westfalia kits, the Wibutec harness and even the Audi instructions for retrofitting the swivel and removable bars all say that one of the five power wires should be connected to ST4 and they suggest this should be a switch live with ignition on. On my car ST4 is a permanent live as is ST1 where all the others go. Anyone have any inside knowledge or experience of this? I have put it in ST4 F5 for now as per Audi guide but there has to be some mistake here - maybe?
Cheers
Dave
davebrannigan
C?ID=171908
So...after putting all the coding back as was (including auto dipping passenger mirror) and disconnecting the Can connection of the trailer module I did a scan. I then cleared all dtc's and rescanned. The results are below. You'll note that the CAN gateway still has an issue reaching the instruments module yet later reads it fine with no fault code. Never had this before. The faults for the two antennas are still there too but the satnav seems to work perfectly despite the "short to ground" as does the telephone but I covered that right at the start so I wont go over that again. Weird.
One other oddity, when I look at my list of installed modules, for some reason 5F (the one with the antenna issues) appears twice in the list with only one of them ticked. All other modules appear only once. What's that all about? Really clutching at straws here:-)
Finally, I read somewhere that the switched +ve on ST4 may go 0V after the doors are closed but tried that and it doesn't even after 10 minutes so something awry with the Audi instructions there. Has anyone who's fitted this kit checked to see if ST4 stays live with ignition off? PF Jones (where I bought the interface) said today, ST4 should be fine. Just make sure you don't press the ignition button and it should stay dead. WRONG! Think I'll call them tomorrow.
Not sure how to proceed now. I'll park it until I hear from you guys.
Cheers
Dave
davebrannigan
C?ID=171908
Whoops! Here:
Monday,29,January,2018,18:59:39:28626
VCDS Version: 18.1.0.2 (x64)
Data version: 20180122 DS285.1
VIN: WAUZZZ4G0FN094141   License Plate: S8DGB
Mileage: 51814km-32195mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F
          62 6D 72 A9 AC C0
VIN: WAUZZZ4G0FN094141   Mileage: 51814km-32195miles
Address 01: Engine (J623-CVUA)       Labels: None
   Part No SW: 4G0 907 589 D    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0002
   Revision: 54H23---
   Coding: 122A4032252603030000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30BTD0114G0907589D 001002
   ROD: EV_ECM30BTD0114G0907589D.rod
   VCID: 35671C0E942EA4ED56-8060
   Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1003
   Revision: --H19---
   VCID: 77FBD606CEA296FD84-8022
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 49A79E4192E579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 418F78DED0E6184DFA-8014
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01B9704E000000000000
   VCID: 7AFDCF32F5B08B95FB-802E
   Serial number: 3215000077200013
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 24041500041105
   Coding: 36221178210000
   VCID: 63C392566A3A6A5DC8-8036
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001057617501
   Coding: 0105001440349FE0410140C3000018000F9DC7082F08020100000894E100150200400024030000
   VCID: 71EFE81EA8C6C8CD4A-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 150319  H37 0080
   Serial number:         150326222926
   Coding: 0045F7
   Serial number: 23915170
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 17 04 2015  00000475
   Serial number: 002944A7000000000001
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1004DVPG
   Coding: 30333130313730323737554A305234473053
   VCID: 3B730A36B20A729DA0-806E
   Serial number: 3575HRB401A5312UGGH8
   Serial number: 3585HRB404T3761S6PM$
   Serial number: 3515JRB405P370PIIORC
   Serial number: 3525JRB400U54Q465P7G
   Serial number: 3554VRB400254Q46NGMQ
   Serial number: 3564VRB400254Q46M0MA
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862ODI000RH
   Coding: 000035
   VCID: 3B730A36BA0A729DA0-806E
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 04 04 2015  A0012114
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Revision: --------    Serial number: 00000001818093
   Coding: C0CD078118
   VCID: 75E7DC0ED4AEE4ED96-8020
   Serial number: 9703916203
   Voltage stabilizer:
   Serial number: 1502080000000000019F
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 67DB86469602067D14-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 28041500041962
   Coding: 22
   VCID: 3D77042EAC1E7CAD9E-8068
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720H16ZJ
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 336322169A5ABADD78-8066
   Component: TSG FA        H03 0507
   Coding: 011C16014001620002080002
   VCID: 479B66C6F6C2267D34-8012
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0013709395
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   VCID: 397F103EB836408DB2-806C
   Revision: 00002001    Serial number: 0367213645
   Coding: 013B0622A0B93000C320090400010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Component: TSG BF        H03 0507
   VCID: 46856BC2F1C83F75CF-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001443451
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D57346E7C7EEC2D2E-8078
   Coding: 04FE02102A630200
   VCID: 3461210A9F54BDE561-8060
   Coding: E01E00
   Coding: E01E00
   Part No SW: 4G1 035 021 H    HW: 4G1 035 021
   Component: MU-H-LND-EU   041 0924
   Serial number: A588D0F7511415
   Coding: 017502010000000013111102000A00132F0006E7F1700100DF
   VCID: 1F4BDEA606D20EBDAC-804A
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9FY801EKQ
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349ODM0007G
   Compact Disc Database:
   Component: Gracenote2  --- 1012
3083 - GSM antenna 2
          B1533 11 [009] - Short to Ground
                    Reset counter: 82
                    Mileage: 51814 km
                    Date: 2018.01.29
                    Time: 18:51:25
                    Voltage terminal 30: 12.2 V
3086 - Antenna for Telephone Mount
          B1564 01 [009] - Electrical Failure
                    Reset counter: 82
                    Mileage: 51814 km
                    Date: 2018.01.29
                    Time: 18:51:24
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 499F60FEE0D6D00D22-801C
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 102500545
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   VCID: 36651B028928AFF55F-8062
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 150408200359
   VCID: 2E5533627178973517-807A
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150980914
   ROD: EV_RDCMA00100_008.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0011
   Serial number: 150416200006
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 275BC6465E82C67DD4-8072
End-------------------------(Elapsed Time: 04:59)--------------------------
davebrannigan
C?ID=171908
Had an epiphany when I woke this morning. The new error is related to GSM antenna which is of course also related to the phone NOT GPS. Got my acronyms mixed up!
So as it is GSM I wonder if it is to do with the hexaganol antennas that are mounted behind the rear bumper on each corner. I believe these are to do with the phone. When I removed the bumper these were both covered in road grime so I hosed them off. They should be able to take a dousing, but you never know. I'll investigate that another time. Still curious as to wht the gateway has started playing up though.
really wish I'd done a scan just before I started so I could be sure it was related to this job and not pre existing. It was certainly not there a few weeks back, but that doesn't mean it didn't occur a few days or even the day before I did the bar. Probably too coincidental though.
Cheers
Dave
BTW What was the edit for Code tags about? Not sure what to do with that?
   #31
davebrannigan
C?ID=171908
Ah Ok I got that. Sorry for not doing it before.
Little bit of good news today, I discovered that the issue with the switched live was down to ST4 fuse carrier being split into 2 parts. F1 through F5 are switched ignition lives where F6 through 12 are permanent. You'd never know looking at it briefly during installation. Just unfortunate that I popped my meter lead in an empty fuse slot around F9 position and assumed the rest of ST4 would be the same. I'll bet others never even bothered to check and assumed the instruction are correct - which they are! Hope this helps others in future though.
Loath as I am to pay someone to code this for me, there is a place near me that said they would do it for £50 using the Westfalia Autocode tool. They claim that after it, the swivelling hitch position is shown on the dash if not locked and the light on the release handle will work. Indeed when they code fixed or removeable bars they have to do something else to tell it that it isn't a swivelling bar - so they said. Haven't decided what to do yet but it's an option. If I do go for it I will post my coding afterwards so we can all see what differences are made to my code, and from that others may be able to work out all the changes that are necessary.
Of course there is also the Audi option but I'll bet that isn't cheap...
One way or t'other we'll get there.
Cheers
Dave
Thecherry0121
C?ID=302234
Not sure if you need it but this is a scan of my facelift 2015 equip with OE towbar if theres any coding on there that might help
Wednesday,10,January,2018,16:48:41:43233
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
VIN: WAUZZZ4G5FN077867   License Plate:
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 28 34 36 3B 42 44 46 52
          53 55 5F 62 69 6C 6D 72 85 A9 AC C0
VIN: WAUZZZ4G5FN077867   Mileage: 65516km-40709miles
   Revision: 54H23---
   Coding: 122A4032253603030000
   VCID: 3560ACE594E997EE72-8060
11897 - Turbocharger/Supercharger Inlet Pressure Sensor
          P012B 00 [032] - Implausible Signal
   Revision: --H19---
   VCID: 77FC66EDCE65A5FEA0-8022
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 49B7DE4192ED7B82BB00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3F8CCECDA6D55DBEA8-806A
154624 - Tire Pressure Warning
          C102D 00 [040] -  -
                    Mileage: 64742 km
                    Date: 2017.12.26
                    Time: 11:22:27
                    VzRef: 82
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    Uz: BA
                    Unlearning counter according OBD: 25
   VCID: 7AFA7FD9F577B896DF-802E
   Serial number: 3215000030265011
   Serial number: 10031500041607
   Coding: 362211B82D0000
   VCID: 63C422BD6AFD595EEC-8036
   Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG
   Revision: 14020001    Serial number: 00001019896102
   Coding: 0105001440349FE0690140C3A0001800CF9DE7082F08020100000894E100170200400010010000
   VCID: 70EE5DF1A30BF2C661-8024
   Component: WWS57X 150213  H37 0080
   Serial number:         150218212925
   Coding: 0045F7
   Serial number: 23795154
   Coding: 02006D
   Serial number: 03 03 2015  00001500
   Serial number: F8088897000000000001
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0070
   Revision: --------    Serial number: 56291505903880
   Coding: B91318
   ASAM Dataset: EV_EPHVA2CAU64X0000 001011
   ROD: EV_EPHVA2CAU64X0000.rod
   Revision: --------    Serial number: 003P1003NJMA
   Coding: 30333130313730323738554A305234473053
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 3B74BADDB2CD419E84-806E
   Serial number: 3575HRB400G52UCI4OO%
   Serial number: 3585HRB404T373K65H46
   Serial number: 3515JRB405T36K44K8SU
   Serial number: 3525JRB404V367OOPH57
   Serial number: 3554VRB405H33EQGB8T7
   Serial number: 3564VRB4010536FQQ1MO
   Revision: --------    Serial number: 90372OC600093
   Coding: 000035
   VCID: 377CA6ED86E565FE60-8062
   Component: E221 - MFL  H08 0009
   Serial number: 20 07 2011  11153056
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
   Revision: 04001037    Serial number: 658100315596041
   Coding: 33A612009B412600010000
   ROD: EV_RBD4K.rod
   VCID: 408ECD31DB2B2246D1-8014
   Revision: --------    Serial number: 00000001758281
   Coding: C0CD078118
   ROD: EV_GatewPkoUDS_001.rod
   VCID: 75E06CE5D469D7EEB2-8020
   Serial number: 6638126003
   Voltage stabilizer:
          U140B 00 [008] - -
                    Reset counter: 140
                    Mileage: 65384 km
                    Date: 2018.01.06
                    Time: 17:26:27
                    Voltage terminal 30: 11.5 V
                    Voltage terminal 15: 11.4 V
                    Control Module temperature: 8 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 002801150001042
   VCID: 285E7591535BFA06F9-807C
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Serial number: 11031500040345
   Coding: 22
   VCID: 3E72B3C9A1DF54B6A3-806A
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
                    Reset counter: 136
                    Mileage: 65264 km
                    Date: 2017.12.28
                    Time: 17:25:49
                    Outside air temperature: 2.5 °C
                    Left rear vent temperature: 41.2 °C
   Coding: 008001
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F6C9E8D76B5AD3E38-807A
          C10C8 00 [008] -  -
                    Reset counter: 110
   Revision: AA000000    Serial number: 00000138980418
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77FC66EDC665A5FEA0-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E01EMFO
   ROD: EV_SARA2.rod
   VCID: 377CA6ED8EE565FE60-8062
   Coding: 011F16015E01620002080002
   VCID: 479CD62DF605157E10-8012
   Revision: 00001000    Serial number: 0021539714
   Coding: 101100010001
   VCID: 3978A0D5B8F1738E96-806C
   Revision: 00002001    Serial number: 0362785969
   Coding: 013B0622A0B93094C320098420010F470000000000000000000000000000
   Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS20.403  H03 0004
   Serial number: 0000FST0006CCHB00000
   Coding: 901E00
   Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00011888356
   Subsystem 5 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS20.403  H03 0004
   Serial number: 0000FST0006CCNH00000
   Coding: 801E00
   VCID: 4682DB29F10F0C76EB-8012
   Revision: --------    Serial number: 00000001397238
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2D5084857CB9DF2E0A-8078
   Coding: 04FE02202A130200
   VCID: 346691E19F938EE645-8060
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 D    HW: 4G1 035 021
   Component: MU-H-LND-EU   041 0389
   Serial number: A588C0F7507254
   VCID: 1B345A5D120D219E64-804E
   Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
   Component: ECE 2017  --- 0157
   Serial number: AUZ8Z9EY800JEE
   Serial number: 90349OBK00061
                    Reset counter: 108
                    Mileage: 63711 km
                    Date: 2017.12.04
                    Time: 15:11:46
                    Voltage terminal 30: 14.5 V
   Coding: 010F14004001620002080002
   VCID: 4998D015E011E30E06-801C
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 140
                    Mileage: 65384 km
                    Date: 2018.01.05
                    Time: 13:20:51
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 7B001001    Serial number: 0363209295
   Coding: 0100000202000000
   VCID: 336492FD9A9D89DE5C-8066
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 027502010301000700
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 326A97F9658780D657-8066
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 059500647
   Coding: 093205C011
   VCID: 3662ABE989EF9CF67B-8062
Address 85: On Board Cam. (J852)       Labels:* None
   Component: DPC-SG        H27 0081
   Coding: E0140000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C56898147A3D6261D-8078
   Serial number: 150228200311
   VCID: 2E52838971BFA43633-807A
   Revision: 00000000    Serial number: 150131144
   Serial number: 150302201281
   ROD: EV_ActuaForExterNoiseUDS_VW12.rod
   VCID: 275C76AD5E45F57EF0-8072
End-------------------------(Elapsed Time: 06:01)--------------------------
davebrannigan
C?ID=171908
Interesting. Your trailer module is coded identically to mine, but as all the other modules look different dependant on what options are there I'd need others to see if there are other differences that are pertinent. The other thing that's of note is you have the same issue with the telephone antenna as I do. Common failure of error in the way vcds detects it I have no idea. I'll leave that for another thread.
Thanks for the post.
Dave
   #35
davebrannigan
C?ID=171908
So today I took my car to a "Towbar specialist" who have a Westfalia Autocode tool with "The latest update in it"
AFter about 10 minutes the job was complete and they were going to send me on my way before I asked then to test it. Guess what...?
Yes, all the lights worked, but so did the revrsing sensors when they shouldn't and the trailer wasn't displayed on the MMI. They spent half an hour going through the process again and again and concluded there must be something wrong with the car! I explained that I already had all this working with the exception of the brakes as I was not able to code that module using NEtech's instructions due to the secure code not working. They are going to call Westfalia on Monday for advice.
In the mean time I took the car home and did a scan. All they appear to have done is to have added the trailer module and modify the trunk electrical module Byte 4 bit 0. Everything else is the exact same as it was before. No change to Engine, Central convenience Central electrical or brakes.
Clearly this is not a thorough job and I need to get back to them or revert to self coding but to do that I need to be able to do the ABS module and that takes me back to NEtech's suggestion of a Beta version of vcds off UWE to get access.
I would also really appreciate knowing what changing each of the the various modules per NEtech's instructions is meant to do.
Module 09 Byte 10 Bit 5
Module 46 12.5
Module 01 Byte 5 Bit 4
Module 03 Byte 8 bit 5
Module 6D Byte 4 Bit 0
Cheers
Dave
WHat are the chances guys?
   #36
Module 09, Byte 10 Bit 5: Not well documented; might have something to do with parking or back-up lights?
Module 46, Byte 12 Bit 5: Just tells this module that a Trailer module is installed.
Module 01 Byte 5 Bit 4: I've got nothing, sorry.
Module 03 Byte 8 bit 5: " " " "
Module 6D Byte 4 Bit 0: Just tells this module that a Trailer module is installed.
davebrannigan
C?ID=171908
OK. Maybe NETech will come good as he came up with the coding changes. He must have got the coding info from somewhere?
I'm pretty sure that when a board is connected the following is meant to happen:
The ESP program is modified to help stop trailer snaking
The reversing lights and fog light on the car are disabled
The rear parking sensors are disabled
The dashboard monitors the board lights for faults
And in the case of the EOM retractable bar, you get indication of the bar not being in the locked position whether that be in use or stored.
Is there any risk of a version of VCDS to allow me access to the ABS module? If I had that I think id just settle for doing it myself and be happy without the release LED working. NETech's guide worked much better then the Westfalia tool - in the hands of that company anyhow... Just the brakes that's all.
Cheers
Dave
   #38
He's the King of (certain) retrofits. This is due to the tax structure in Denmark where new cars have some absurd level of taxation, but "replacement parts" don't. Thus it's often advantageous to add features to a car after purchase rather than just ordering it with those features to begin with.
NEtech
Denmark
C?ID=56995
I don't know what you mean by this ?
If you mean what the purpose of the codings are, I did not answer before and also not now, about what the functions of each coding change is for.
We can come with different suggestions, what each coding function should mean, but in most cases not know for sure.
You would have to ask Audi engineers, who programmed controllers in your Model, for the correct answers.
I don't find it is crucial to know, to get a towbar installed, what is important, is to make the codings/corrections that are necessary.
I just try to suggest, what is done with the original test system for a original trailer bar retrofit.
Please just wait if you can, until next VCDS update or beta version.
Do you know if there is a short wire, on the connector for towbar controller, if so, what 2 pin numbers is it connected between ?
No..no, I am King of nothing (only my house) :thanks:
I just trying to keep up.
   #40
davebrannigan
C?ID=171908
I guess all I was saying is that if we knew what each change to the coding was meant to do we could tell if the installation and functionality was complete and working as designed. It was only the fact that a few who have tried this have had the same issue with the release lever indication led made me think it may not be everything that Audinwould do. Like I also said, if I can get the abs module sorted I'd consider it good enough and park it there.
It's looking like the only other option would be to ask an Audi garage to code it which would likely be an hour labour. I could ask them to do it during the cars last in warranty service in a few months which may work out cheaper. If they can't get that led working, nobody can! ( maybe)?
Don't want to sound in any way ungrateful for help offered to date. I'm just a bit of a perfectionist, which is why I bought the Oem bar rather than an aftermarket variant.
By the way there is no link between any two pins on the trailer module. It is as per elsawin drawings.
Thank you!
Dave
