Loss of cruise control
Djaylulu
Pennsylvania USA
C?ID=319731
Hi,
I replaced my throttle body due to a fault, there was no cruise control before replacing it and there is no cruise control after replacing it!
How can I access the cruise control settings in VCDS and restore it to its correct functioning?
iichel
Netherlands, eastern part
C?ID=284912
let's start with an autoscan, see signature below
the car does have a cruise control system, i presume? if so, let's have a look at your autoscan and see where we go from there.
Djaylulu
Pennsylvania USA
C?ID=319731
Wednesday,10,January,2018,10:37:08:31315
VCDS Version: 17.8.0.1 (x64)
VIN: 3VWCC21C4YM482633   License Plate: HPP2160
Mileage: 164250km-102060mi   Repair Order: prethrottlechange
Chassis Type: 1C - VW New Beetle (1998 > 2010)
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
   Mileage: 164250km-102060miles
Address 01: Engine        Labels: 06A-906-018-AEG.lbl
   Part No: 06A 906 018 JN
   Component: 2.0l R4/2V  MOTR HS V01
   Coding: 00031
   Shop #: WSC 01029
   VCID: 77F3EF5655B717FEBB-4B18
17990 - Idle Adaptation Limit Reached
            P1582 - 35-10 -  - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 35-10 -  - Intermittent
16687 - Cylinder 3
            P0303 - 35-10 - Misfire Detected - Intermittent
17977 - Cruise Control Switch (E45)
            P1569 - 35-10 - Implausible Signal - Intermittent
17663 - Engine Coolant Temp Sensor (G62)
            P1255 - 35-10 - Short to Ground - Intermittent
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
            P1296 - 35-00 -
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 P
   Component: ABS     20 IE CAN  0001
   Coding: 03504
   Shop #: WSC 00066
   VCID: 3E7D3A723A0DE6B6B8-4B18
   Part No: 6Q0 909 605 A
   Component: 06 AIRBAG VW5       0004
   Coding: 12342
   Shop #: WSC 00066
   VCID: 356F255E0F3B25EE69-4B18
Address 17: Instruments        Labels: 1C0-920-xx0.lbl
   Part No: 1C0 920 901 C
   Component: KOMBI+WEGFAHRS. M73 V07
   Coding: 03202
   Shop #: WSC 00050
   VCID: 1C39D0FA8CD194A676-4B00
   Subsystem 1 - Part No: Ident
   Component: Nr. Wegfahrs.:VWZ5Z0Y2252038
   Ident.-Nr. Wegfahrs.:VWZ5Z0Y2252038
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V072
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70E1D44A30D940C67A-4B18
   Part No: 1J0 959 799 AJ
   Component: 5X Zentral-SG Komf. 0001
   Coding: 00256
   Shop #: WSC 00066
   VCID: 060D9292225D7E76B0-4B18
   Subsystem 1 - Part No: 1J2959802C
   Component: 5X Tırsteuerger. FS0002r
   Subsystem 2 - Part No: 1J2959801D
   Component: 5X Tırsteuerger. BF0002r
            54-00 - Incorrectly Equipped
00957 - Key 3
            09-10 - Adaptation Limit Surpassed - Intermittent
            35-00 -  -
            35-00 -  -
End-------------------------(Elapsed Time: 03:35)--------------------------
iichel
C?ID=284912
okay so you have a few DTCs in your system. In your ECU you can see the error from the CC:
You could see whether you can find the measurement value block and have a quick test of the set, reset, on, off and cancel button.
Furthermore, you can see whether the wiring is correct, verify with a multimeter according to the WD.
And last, but not least, if you checked the wiring and the fuse, and the MVBs are not conclusive, I'd replace the stalks.
Djaylulu
Pennsylvania USA
C?ID=319731
I don't know what blocks to access or where to find them. That is why I posted in here.
Djaylulu
Pennsylvania USA
C?ID=319731
OK, so I have run VCDS and find all my cruise control controls show as working in measuring block 66 but I still get :
P1569 - 35-00 - Implausible Signal
Readiness: 0110 1101
How do I correct this?
And please someone put the forum back the way it was, this is terrible and you cant code the text for the VCDS data either
We have not changed anything about the forum. What kind of device are you using for the forum?
Djaylulu
Pennsylvania USA
C?ID=319731
Apart from the layout, colors, software provider, shortcuts, links! I use a imac 27"
We've changed nothing! If I had to speculate, I'd say: Look for a "Full Site" link toward the bottom and click it?
Djaylulu
Pennsylvania USA
C?ID=319731
Who the heck would have thought of that?
What on earth is that for?
How do I get my cruise control to work?
Well, on the "Full Site" there's a Style Chooser down in the lower left. There are two choices; '--RT' and '-- Default Mobile Style'. Somehow, some way, it would seem you got the Mobile one. ;)
The fault code indicates there's something wonky with the cruise switch or the wiring to it. Usually it's relatively straightforward to confirm that by looking at the corresponding bits in the measuring values, but since you say they all changem I'm not sure what to tell you.
Djaylulu
Pennsylvania USA
C?ID=319731
It coincided with the throttle body failing - and on the wiki about throttle body alignment it says it may affect cruise control.
Djaylulu
Pennsylvania USA
C?ID=319731
What is the purpose of the mobile one? Is it part of an app? I didn't think that mobile devices could access just any part of the Internet or any old web page, just dedicated content or apps containing content access they download.
Yes, that's true, but the fault code you listed in post #7 quite specifically points at the CCS switches.
Cell phones have had web-browsers for well over a decade now. ;)
Djaylulu
Pennsylvania USA
C?ID=319731
But you cant get any webpage you choose on a cell, you have to download the app for that service or store or whatever and view the content in that app - not the same content that we see on the computer.
Is there a cruise control switch on the clutch?
Uhm, every phone I've had in the last 10 years has had a web browser that can access pretty much any website. Sure, some sites detect that you're on a mobile device and try to get you to use their proprietary app instead. Personally, I refuse to do that.
Have you checked a repair manual for your car?
Djaylulu
Pennsylvania USA
C?ID=319731
Not yet, but the clutch pedal changes the numbers in the measuring blocks
Yes, I'm sure it does. But I'm not sure whether there's a dedicated switch for that in your car or if that info comes from the brake-light switch.
Guitarman
C?ID=56603
Thanks Uwe, since a few weeks ago I've been getting the different colours and layout too. (W10/Opera) I just thought it was an 'improvement'. :D Back to the blue now..
