Sunday,14,January,2018,13:51:50:45450
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4409.4
VIN: WA1DGAFE6FD008394 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 34 36 3C 42 46 47 4C 4F
52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE6FD008394 Mileage: 60680km-37704miles
Address 01: Engine (CTW) Labels: None
Part No SW: 4L0 910 551 Q HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0928
Shop #: WSC 31414 790 00001
VCID: 3635DBE4644C6517B0D-8062
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 002 2443
Coding: 001378
Shop #: WSC 30586 001 1048576
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002.rod
VCID: 3A2DCFD45CD48177545-806E
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0103505
VCID: 3431E1EC723077078E9-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902162043
Coding: 0000135
VCID: 25170CA8C9EA1E8F097-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000000447079
Coding: 000CC026
VCID: 25170CA8C5EA1E8F097-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0115208822
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0115208818
Coding: 070000
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0133123
VCID: 6E8533845C9C1DD7B8D-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961425401612
Coding: 29011F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 3431E1EC7EB077078E9-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH45 0230
Revision: 09H45000 Serial number: 0038QD90ASU+
Coding: 0014131
VCID: 2B03FA90AF0E28FFDF3-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME79421A4EQ
Subsystem 3 - Serial number: 6342QSME1F431D4CT
Subsystem 4 - Serial number: 6352QSME43445458E
Subsystem 5 - Serial number: 6362QSME3D44327ES
Subsystem 6 - Serial number: 63734SME71424B54$
Subsystem 7 - Serial number: 63834SME0D454E605
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026142050193
Coding: 0012142
VCID: 2809059CBEF803E7321-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 S HW: 4L0 920 985 S
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2R52NJ9F
Coding: 8BD763040901CF05020205
VCID: 44D1B12C2E90C7873E9-8010
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M1490204F4
Coding: 00C303
VCID: 3FDBBEC04776A45F63B-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 41250510334121764484
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 49
Mileage: 60514 km
Date: 2017.12.19
Time: 23:41:00
Reset counter: 54
Mileage: 60514 km
Date: 2017.12.20
Time: 02:41:00
Bin. Bits: 00000
Voltage: 12.40 V
Count: 18
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---011 Serial number: 00000030351854
Coding: 0000006
VCID: 6889459C7E78C3E7F21-803C
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015520
Shop #: WSC 29409 001 1048576
VCID: 313FE8F88D22422FE5F-8064
01577 - Turn-Off due to Over-Temp
Fault Frequency: 8
Reset counter: 54
Mileage: 60295 km
Date: 2017.11.30
Time: 12:51:50
Error Code: 68
Reset counter: 54
Mileage: 60675 km
Date: 2018.01.09
Time: 12:32:41
Error Code: 13
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000114006321
Coding: 00581B00000011110000
VCID: 323DE7F4842479379C5-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E05F3849C1C5DD7F8D-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H03 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F28.08.1400H03000AMS14277ÿ
Subsystem 4 - Serial number: S14277ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000118410359
Coding: 011F57205E40440004
VCID: 48C9A51C12B8E3E7D21-801C
01705 - Selection Switch for Mirror-Adjust (E48)
Reset counter: 55
Mileage: 60319 km
Date: 2017.11.30
Time: 13:47:52
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82007937900000
Coding: 3570077
VCID: 3829D5DC6E589367A21-806C
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000060077
Coding: 030000
VCID: 290F0098A9F23AEF2DF-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191069910
Coding: 0694221
VCID: 231312B0C7DEE0BF673-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000196405
Coding: 0012001
VCID: 5EE56344AC3C8D5708D-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000118095476
VCID: 47CBA6201FA6EC9FDBB-8012
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000032
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Revision: AB001007 Serial number: 156I.0E8063162
Coding: 020007010000000000
VCID: 241111ACCED0E7871E9-8070
Part No SW: 4L2 035 746 F HW: 4L2 035 746 D
Component: H-BNT-NA H41 0812
Revision: -------- Serial number: 224IU0E7551041
Coding: 180200060104F1FF51002F456F632003140000000100000000
VCID: 313FE8F88122422FE5F-8064
Subsystem 1 - Part No: 8R0 060 884 CA
Component: NAR 2014 1002
Component: DU7 High H42 0104
Serial number: A130IY0E3128854
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002205827
Component: CD-Database 5950
Reset counter: 50
Mileage: 60608 km
Date: 2017.12.21
Time: 11:47:28
Bin. Bits: 00000000 00000010
Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000117954997
Coding: 010E57204040230004
VCID: 46D5AB2418ACF59720D-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00008200812238
Coding: 0200000000000000
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0171124
Coding: 020C000001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6E853384501C1DD7B8D-803A
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H58 0500
Revision: --H58001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81398C6A80EFC7969-8038
3ó
Subsystem 3 - Serial number: RD12.09.14--H58001002G0094ÿ
Subsystem 4 - Serial number: 2G0094ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0118255819----
Coding: 0003595
VCID: 26150BA4B4EC159700D-8072
Component: J_245_EE16_SKB10H15 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H15 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H15 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000117954996
End----(Elapsed Time: 02:29, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
