2014 Q5 paddle wheel install on 2015 Q5?
winter599
Eastern Pennsylvania USA
C?ID=33972
I did a quick search and found no info on this particular swap. I've done a few steering wheel retrofits with good luck but this one confounds me a bit. The wheel was removed from a 2012 A4q and was installed successfully on a 2014 Q5. However I'm attempting to install it on my wifes 2015 Q5 and it's not agreeing. Everything works save for the shifters. I went into 'steering wheel' and made sure the tiptronic box was checked but it won't recognize the paddles. Forgive me for pulling the plug at that point without further diag but an oil change and winter tire swap took priority. I'm bringing it back in this evening and was hoping for a bit more direction. Thanks for any advice!
Please post an Auto-Scan so people can see how the vehicle is equipped and configured.
winter599
C?ID=33972
Monday,08,January,2018,10:20:09:56355
VCDS Version: 17.8.1.0 (x64)
VIN: WA1LFAFP1FA070223   License Plate: A5Q
Mileage: 82450km-51232mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 52 53 56 5F 62
          6C 6D 72
VIN: WA1LFAFP1FA070223   Mileage: 82450km-51232miles
Address 01: Engine (DET-CPMB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8R1 907 115 L    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---
   Coding: 6A2A0013242600062000
   Shop #: WSC 29643 002 1048576
   ASAM Dataset: EV_ECM20TFS0118R1907115L 001006
   ROD: EV_ECM20TFS0118R1907115L.rod
   VCID: 3E782116A1AB96B6A3-806A
Readiness: 0000 0100
   Part No SW: 8R0 927 158 AS    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H19 1002
   Revision: --H19---
   VCID: 0E18B1D6D18B463613-805A
   Part No SW: 8R0 907 379 BG    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0030
   Coding: 3A1D1801
   VCID: 060889F6B1FB0E76AB-8052
   Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
   Component: BCM2 2.0      H15 0711
   Coding: 0D854040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 081487CEBBEF1806D9-805C
   Serial number: 3214000130355010
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 186
                    Mileage: 61728 km
                    Date: 2017.01.07
                    Time: 11:17:40
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01011120140278
   Coding: 6481208000
   VCID: 77F6F432C61167FEA0-8022
   Revision: 08016001    Serial number: 00000936599302
   Coding: 26000091803CAFC00000480300003D0D0F1C4608A2090361000008004000030100000034000000
   Shop #: WSC 06335 123 12345
   VCID: 78F4F70ECB0F6886A9-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 141016  H12 0050
   Serial number: 90243014141011144119
   Coding: 01DD13
   Serial number: 23407031
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002810140071
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01CD3957
   Serial number: 7E788757000000000001
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED12T469
   Coding: 303634313432383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4C9C7BDEE71734263D-8018
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R140000LL5G
   Serial number: 6334MSME497C4720I
   Serial number: 6344MSME4A295600A
   Serial number: 6352QSME5D4A1850N
   Serial number: 6362QSME304A2C4ER
   Serial number: 63732SME444A0854
   Serial number: 63832SME444A0A4A3
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NK70009J
   Coding: 000017
   VCID: 489447CEFB6FD80619-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 981 N    HW: 8R0 920 981 N
   Component: KOMBIINSTR.   H35 0564
   Revision: 00300000    Serial number: ZD32353CF
   Coding: 8BB622000301D705020000
   VCID: 458A4EFACC7DC56EE2-8010
   Revision: 1Z120030    Serial number: 3041Z14A25033F
   Coding: 80C303FF00
   VCID: 4C9C7BDEEF1734263D-8018
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 5562494803
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000122733479
   Coding: 00581B00000000000000
   VCID: 428055E6DD53F256C7-8016
   Serial number: 0350867545
   Coding: 010211
   Shop #: WSC 06334 000 00000
   VCID: 3F865C12A6A19FBEA8-806A
   Component: SWA Slave  H05 0071
   Serial number: 0350607293
   Coding: 010211
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000123750259
   Coding: 011D13205E00440004
   VCID: 4FA66CD21E010F3E58-801A
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0018111498
   Coding: 100000000000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   Revision: 00002001    Serial number: 0350893647
   Coding: 0126023A20FA709584B0053200040000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000904288
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000123591559
   VCID: 4E9871D6190B063653-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000534706
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3A702D06BD83BA969F-806E
   Revision: AB001007    Serial number: 156K20E8090780
   Coding: 020007020100000001
   VCID: 244CF37E2707DC66D5-8070
   Part No SW: 8R1 035 746 G    HW: 8R1 035 746 G
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 523F/0F7543923
   Coding: 160200060005A1EF51028B5E00000403140000000000000000
   Shop #: WSC 49171 001 1048576
   VCID: 3B7E2802BAB9839E84-806E
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Component: DU7 High  H42 0104
   Serial number: A130K10E3177993
   Serial number: 00000002036713
   Component: CD-Database  5950
            000 -  -
                    Reset counter: 186
                    Mileage: 61727 km
                    Date: 2016.12.19
                    Time: 13:03:30
                    Text: KBD_FB8,KBD,M,0,0,5
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000124323368
   Coding: 010C13204000240004
   VCID: 468849F6F17BCE76EB-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J49A0UF
   Coding: 1020010
   VCID: 346C033E57E74CE645-8060
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D7A261AA4AD8DAEBA-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000124319189
End-------------------------(Elapsed Time: 03:56)--------------------------
winter599
C?ID=33972
Figured it out with a different computer. I had trouble clicking on the appropriate block in coding to see a drop down menu that alerted me to changing the wheel coding from '17' to '37'. Won't be using my HP tablet for the sensitive things any more.
