"No ROD file found"
pab567
C?ID=233680
Problem found, the fix was accidentally removed during a related change. Fixed permanently now, I'll make a revised version/update available next week.
When will you publish a new version? It's over 7 weeks since you wrote it and there is still no release. I am facing this problem every time with MIB STD2 PQ units 5L0035200 / 5L0035680 installed in Superb Mk2.
   #23
pab567
C?ID=233680
Beta doesn't work with previous generation interfaces... and I am not willing to spend another bucket of dollars replacing my interface
   #24
pab567
C?ID=233680
Any update? Another 7 weeks passed by and still no support for legacy interfaces.
   #26
Keithuk
Stoke on Trent, England
C?ID=122432
Download and install the following update for Release 18.2.1:
https://ross-tech.de/downloads/upd
That should take care of it.
I've just download 18.2.1 update but when I try to install it says VCDS found on your computer does NOT match Requirements. Update aborted (VCDS version found 18.2.1.2). Would I like to download the latest version, which I have.
These ROD - Unknown Error Code have been showing for years.
29-12-2017 Not finding a ROD file is not unusual when modules that don't belong in a particular car get retrofit. I'm confident we can make a work-around for this once we're back in the office next week.
   #27
No, apparently you don't. The current version on the download page is 18.2.1.5.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I'll make sure to offer opening the download page, when a lower version is found (next time I touch that updater...). ;)
   #29
Keithuk
C?ID=122432
Ok I had 18.2.1 but I didn't check the version number. I downloaded and installed the current online download and installed it. Then I ran Sebastian's update and it installed.
I think you should change the number shown to 18.2.1A, B, C with updates so its obvious which version your using.
   #30
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Since the subversion isn't changed that often and it's industry standard to use numbers (not necessarily letters), it's not really necessary to change anything here. That said, as I mentioned before - I'll make sure the error message is more clear with the next builds.
   #31
pab567
C?ID=233680
Unfortunately this does not help.
I was able to make controller channel list of 5F unit 5L0035680E but cannot edit adaptations - they are greyed out.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Please run a fresh Auto-Scan and post it here.
   #33
pab567
C?ID=233680
Here you are
Thursday,06,September,2018,23:43:00:12646
VCDS Version: 18.2.1.5
Data version: 20180904 DS287.4
Dealer/Shop Name: Paweł Brzeziński
Workshop Code: 048 00567 000001
VIN: TMBRC93T2C9033493   License Plate: PAB567
Mileage: 92160km-57265mi   Repair Order: 201809062342
Chassis Type: 3T-SK46 (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 25 2B 36 42 44 46 4C 52
          55 5F 62 69 6D 72
VIN: TMBRC93T2C9033493   Mileage: 92160km-57265miles
Address 01: Engine (0-32-CDVA)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 023 AE    HW: 03H 907 309 C
   Component: 3,6 FSI EU5   H04 1642
   Revision: MFH04---    Serial number:
   Coding: 001D0012242600000000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_ECM36FSI01103H906023AE 001002
   ROD: EV_ECM36FSI.rod
   VCID: 65C180BE6450A06CB7-8030
Readiness: 1110 0101
   Part No SW: 02E 300 013 R    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2704
   Revision: 05351113    Serial number: 00001110030996
   Shop #: WSC 33361 790 00051
   VCID: 204FD1AAF3F2854404-8074
   Revision: 00H31001
   Coding: 843D8016192580FD210F01ED981C0141370C00
   Shop #: WSC 00567 048 00001
   VCID: 7BF5C6C6FAD4069C71-802E
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 A
   Revision: 00085000    Serial number: 0156635623
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02014
   ROD: EV_KESSYPQ35G_A02_SK46.rod
   VCID: 34672DFA9F0A09E4F0-8060
   Part No SW: 3T0 907 044 BQ    HW: 3T0 907 044 BQ
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK46.rod
   VCID: 020BBB22953E775432-8056
   Part No SW: 1K0 937 087 AB    HW: 1K0 937 087 AB
   Component: BCM PQ35  H+  110 0651
   Revision: 00110 AC
   Coding: 46190AB8E849F1C040080080710089E4477900AE776D8FF05C814000A040
   Shop #: WSC 33361 790 00567
   VCID: 71E9E4EEA8987CCCDB-8024
   Subsystem 1 - Part No: 3T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 13101  26  0602
   Coding: 00D7B7
   Component: RLS 211011 05  54  0403
   Coding: 072BED
   Subsystem 3 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 3T0 919 475 C    HW: 3T0 919 475 C
   Component: PARKHILFE PLA H08 0005
   Revision: --------    Serial number: 13901127101192
   Coding: 118108
   VCID: 3D7108DEA440C8AC0F-8068
   Part No SW: 3T0 959 655 C    HW: 3T0 959 655 C
   Component: J234__LAK VW10 HI   1918
   Revision: 20014000    Serial number: 003K2PM8V29-
   Coding: 0016715
   VCID: 4189742E18B8AC4C6B-8014
   Subsystem 1 - Serial number: 6332MTS648082751
   Subsystem 2 - Serial number: 6342MTS648442751
   Subsystem 3 - Serial number: 6351HTS6IN83GAKR
   Subsystem 4 - Serial number: 6361HTS60EB9GAKJ
   Subsystem 5 - Serial number: 63727TS60SB8DAKR
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20111014200283
   Coding: 1012140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DF1C8DEECC008AC4F-8028
   Subsystem 1 - Part No SW: 5E0 919 719 G    HW: 5E0 919 719 G
   Component: E221__MFL-PR6  H05 0130
   Coding: 830000
Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5L0 920 840 S    HW: 5L0 920 840 S
   Component: KOMBI         H03 1028
   Coding: 110F190100
   VCID: 3B7506C6B254C69C31-806E
   Part No SW: 7N0 907 530 BA    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1663
   Revision:   H58       Serial number: 111114F1001375
   Coding: 462332
   VCID: 70EFE1EAA39275C4D4-8024
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 4581603E0C90806C57-8010
   Component: IMMO          H03 1028
   Coding: 000007
   Shop #: WSC 73430 790 00063
   VCID: 6ADBF3828D4E8F149A-803E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000231600001
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E533F927126233486-807A
   Part No SW: 3C8 959 760 C    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2901
   Revision: 00H05000
   Coding: 00003B
   Shop #: WSC 12336 024 394758
   VCID: 356110FE9C7010ECC7-8060
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
   Component: TSG FA        H09 0410
   Coding: 011D0220DE00001000
   VCID: 4FAD42161EEC4A3CED-801A
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 197    3201
   Revision: 00H20000
   VCID: 34672DFA570A09E4F0-8060
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
   Component: TSG BF        H09 0410
   VCID: 4E935F1219E64334E6-801A
   Coding: 1376839
   Coding: 00000021
   Coding: 00000021
   Part No SW: 5L0 035 680 E    HW: 5L0 035 680 E
   Component: MU-S-ND-ER    H30 0353
   Serial number: SKZAZ2S5063543
   Coding: 03130601FF00000051111205008802002F0100840120810046
   Shop #: WSC 00048 567 00001
   ROD: N/A
   VCID: 2C57359A473A5124A8-8078
   Subsystem 1 - Part No SW: 5L0 051 236 AH    HW: -----------
   Component: ECE1 2018/19  --- 1030
No ASAM data for: "EV_MUStd4CTSAT" (SK46)
6714 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 131
                    Mileage: 92163 km
                    Date: 2018.09.06
                    Time: 23:38:53
7178 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 131
                    Mileage: 92163 km
                    Date: 2018.09.06
                    Time: 23:41:34
   Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
   Component: TSG HL        H06 0409
   Coding: 010C00200000001000
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Revision: 3A001001    Serial number: 00000161130265
   Coding: 410D000100000000
   VCID: 306F21EA631235C494-8064
   Part No SW: 7N0 959 107 C    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0804
   Revision: 41011001    Serial number: 284100061
   Coding: 082301C003
   ASAM Dataset: EV_HDSGSk462 301133
   ROD: EV_HDSGSk462_SK46.rod
   VCID: 377D1AF68E7CE2FCD5-8062
   Component: TSG HR        H06 0409
End-------------------------(Elapsed Time: 03:58)--------------------------
   #35
pab567
C?ID=233680
Either I am dumb or cars is the same (SK46) , part number is the same (5L0 035 680 E), ASAM is the same (EV_MUStd4CTSAT) :)
I will check update tonight and let you know.
BTW: there is no label file for these units (5L0 035 680 x, I believe generally for all MIB STD2 PQ units it is missing but can check if you want as I have many of them, from each VW, Skoda and Seat, in my workshop), I use 3V0-035-MIB-STD2.clb which is pretty OK.
   #36
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The topic was started by IWMTom with WVWZZZAUZFW063529 and 3G0-000-021-D / EV_MUHig6C3Gen2HBAS, which was addressed on 19/May/2018. You jumped in without an Auto-Scan, so my assumption was you had the exact same unit - yes, I missed your post (#21) with the specific part number, yet that would have not been enough to address this case. In the end, key was the Auto-Scan - which you posted yesterday. So next time, start with that please.
Once you've installed the the last version of the updater, you should have both a label file and a proper matching ROD file. If you're running into any troubles, post a fresh scan please.
pab567
C?ID=233680
No worries, just misunderstanding :( Unfortunately no changes after re-installing VCDS and then installing update :(
Friday,07,September,2018,22:46:10:12646
Data version: 20180907 DS287.4
          55 5F 62 69 6D 72
Readiness: 1110 0001
   Revision: 00H31001
   Coding: 030C0C
   Revision: 00001007
   Coding: 0000000002
   Revision: 00110 AC
   Coding: 00D7B7
   Coding: 072BED
   Coding: 118108
   Coding: 0016715
   Coding: 1012140000
   Coding: 830000
   Coding: 110F190100
   Coding: 462332
   Coding: 0000005
   Coding: 000007
   Revision: 00H05000
   Coding: 00003B
   Revision: 00H20000
   Coding: 1376839
   Coding: 00000021
   Coding: 00000021
Address 5F: Information Electr. (J794)       Labels:. 3V0-035-MIB-STD2.clb
   ROD: N/A
1556 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 132
                    Mileage: 92165 km
                    Date: 2018.09.06
                    Time: 23:57:23
          - 00 [009]
                    Reset counter: 131
                    Mileage: 92163 km
                    Date: 2018.09.06
                    Time: 23:38:53
          - 00 [008]
                    Reset counter: 171
                    Mileage: 92163 km
                    Date: 2018.09.06
                    Time: 23:41:34
   Coding: 082301C003
End-------------------------(Elapsed Time: 03:47)--------------------------
   #38
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Well, you got a label file now but but the ASAM override was inserted in the wrong place. My bad, maybe I should have taken care of that after the morning tea and not before... ;)
For real this time. :D Have a nice Sunday!
   #39
pab567
C?ID=233680
Now it works OK, thx for your help!!!
