2018 Audi A3 e-tron maps
Andy
Sector 7G
HC424490
Thursday,07,December,2017,14:36:25:29905
VCDS Version: 17.11.0.0 (x64)  HEX-NET CB: 0.4409.4
Data version: 20171026 DS285.1
VIN: WAUSPBFF8JA063478   License Plate: E-TRON-1
Mileage: 17km-10mi   Repair Order:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 29 2B 39 3C 42 44 47
          4B 51 52 5F 6C 75 8C A5 BB BC C0 C6 CF D6 D7
VIN: WAUSPBFF8JA063478   Mileage: 17km-10miles
Address 01: Engine (J623-CXUA)       Labels: None
   Part No SW: 04E 906 023 BL    HW: 04E 907 309 F
   Component: 1.4 TFSI hy   H22 5190
   Revision: X3H22---
   Coding: 021D0012636401083000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM14TFS01104E906023BL 008008
   ROD: EV_ECM14TFS01104E906023BL.rod
   VCID: 6B9944E782F1217203D-803E
Readiness: 1110 1101
   Part No SW: 0DD 300 046 G    HW: 0DD 927 770 C
   Component: GSG DQ400E    H32 1601
   Revision: 00032056    Serial number: TFK01710300270
   Shop #: WSC 00099 780 00200
   ROD: EV_TCMDQ400021.rod
   VCID: 2C1B87FB477FE64A4A7-8078
17 Faults Found:
32317 - Unknown Error Code
          U04B5 00 [002] - -
10893 - Implausible Data Received from Battery Energy Control Module 2
          U0413 00 [002] - -
60354 - ROD - Unknown Error Code
          - 00 [002]
60355 - ROD - Unknown Error Code
          - 00 [002]
60356 - ROD - Unknown Error Code
          - 00 [002]
60357 - ROD - Unknown Error Code
          - 00 [002]
60358 - ROD - Unknown Error Code
          - 00 [002]
60359 - ROD - Unknown Error Code
          - 00 [002]
60360 - ROD - Unknown Error Code
          - 00 [002]
60361 - ROD - Unknown Error Code
          - 00 [002]
60362 - ROD - Unknown Error Code
          - 00 [002]
60363 - ROD - Unknown Error Code
          - 00 [002]
60364 - ROD - Unknown Error Code
          - 00 [002]
60365 - ROD - Unknown Error Code
          - 00 [002]
60366 - ROD - Unknown Error Code
          - 00 [002]
60367 - ROD - Unknown Error Code
          - 00 [002]
60368 - ROD - Unknown Error Code
          - 00 [002]
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 63067000000687
   Coding: 12FF40923826226F897B0A07A1CB2948021C44915085947218A1505482A802
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003_AU37.rod
   VCID: 7CBB77BBF79FB6CA9A7-8028
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0459644688
   Coding: 030C0C
   VCID: 3C3BB7BBB71F76CADA7-8068
   Part No SW: 8V0 820 043 S    HW: 8V0 820 043 S
   Component: AC Automat    H03 0620
   Revision: 20002000    Serial number: 00000001381293
   Coding: 0300001001001000080000000000140001000000
   ASAM Dataset: EV_AirCondiFrontNARAU37X 001020
   ROD: EV_AirCondiFrontNARAU37X.rod
   VCID: 42C7C943D5FB003A90B-8016
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0009
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00104.4U.6C20340044
   Subsystem 3 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
   Serial number: 6CD015D800PAG0MUFU02
   Air Conditioning Compressor Sub:
   Subsystem 4 - Part No SW: 5QE 816 803 C    HW: 5QE 816 803 C
   Component: J842 eKK  H02 0006
   Serial number: IABB00000K0000000426
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001730300664
   ROD: EV_BCMBOSCH_018.rod
   VCID: 064F1553B953FC1AFC3-8052
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 171010  043 0580
   Serial number:         171018215533
   Coding: 0A47F7
   Serial number: 21039790X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 29 06 2017  00001475
   Serial number: 00000000000000002774
   Sun Roof:
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST001URT7M00000
   Coding: 101F00
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617300
   Coding: 0470155811
   VCID: 4BD9E467E2B1C17263D-801E
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: D50087C119FFC428949C8055000026
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   VCID: 3B39B4A7B21171F2D3D-806E
   Serial number: 003GCR09AB57
   Coding: 9DFCFCC0002000009000001AC24800000065
   VCID: 47D1D857FED92512475-8012
   Belt Pretensioner left:
   Serial number: 34230167A25101751432
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A02111750605
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001NM31Q
   Coding: 303334
   Subsystem 4 - Part No SW: -----------    HW: 480 000 211 17
   Serial number: 357000000006768C692S
   Subsystem 5 - Part No SW: -----------    HW: 480 000 211 17
   Serial number: 35800000000C63AC692X
   Subsystem 6 - Part No SW: -----------    HW: 480 400 611 17
   Serial number: 3510001C127FACA2E66L
   Subsystem 7 - Part No SW: -----------    HW: 480 400 611 17
   Serial number: 3520001AD275C8A14478
   Subsystem 8 - Part No SW: -----------    HW: 480 402 709 17
   Serial number: 3550002A1252D87021D-
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 402 709 17
   Serial number: 3560002A1252D872003Q
   Part No SW: 8V0 953 521 KF    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 01111704221174
   Coding: 6C18
   VCID: 08531B6BB347EA6A8EF-805C
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 894 A    HW: 8V0 920 894 A
   Component: FBenUSA       H16 0066
   Coding: 08440C516F88CF050283E8101B00000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3FC1C0B7A6096DD2FF5-806A
   Part No SW: 3Q0 907 530 M    HW: 3Q0 907 530 D
   Component: GW MQB EV     618 6322
   Serial number: 25101710801069
   Coding: 0201001726F200005B00101E581000000001010100010000000300000000
   ROD: EV_GatewNF_VW48.rod
   VCID: 3935AEAFB82D43E2C11-806C
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20171026205450 21683
   Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
   Serial number: 0264015604
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 G    HW: 5QE 909 059 B
   Component: EBKV          H14 0211
   Serial number:   085460013127
   Coding: 03720100331A00030002050500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
   ROD: EV_BrakeBoostBoschMQBOMG_004.rod
   VCID: 52E7F903059B90BA20B-8006
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0155
   Serial number: 05802861311017064918
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H06 0017
   Revision: 00000000    Serial number: 17000317723003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 342B9F9B9F4FBE8A127-8060
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
   Component: MRR1Rear      H21 0610
   Revision: --------
   Coding: 04C002
   Serial number: 191017EJJ05486
   Coding: 005D1F205C00048000000003
   VCID: 43C9CC47CAE109329BD-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: D106
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45CDD25FC4D53702B59-8010
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAH5F00ZPQ-
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 240B6FDB2FAF2E0A827-8070
   Serial number: 31101710800195
   Coding: 000000050100142A00112300040000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X.rod
   VCID: 72A75983A5DBF0BAC0B-8026
   Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
   Component: LE Gen 3.3H15 1032
   Revision: 00H15000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM08530115G0907080E 001008
   ROD: EV_DMCM08530115G0907080E.rod
   VCID: 29157EEF488DF362B11-807C
   Serial number: 221017EJL19794
   Coding: 005D17205E00048000000003
   Part No SW: 8V1 035 880 B    HW: 8V1 035 880
   Component: MU-P-LNS-US   054 1110
   Serial number: A702J0H2504957
   Coding: 017393020000000011220002041A00102F0029E5017001047E
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Component: DU High  H49 0014
   Serial number: AUZ8Z9H1Y071HF
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL113101700050389
   Compact Disc Database:
   Component: Gracenote2  --- 3012
   Coding: 0273100102002001400040
   Component: OCULowMQBUS   009 0570
   Coding: 017393011082BA0100F800000000
   ROD: EV_OCULowMQB.rod
   Part No SW: 5Q0 915 182 D    HW: 5Q0 915 182 C
   Component: BECM          H05 0921
   Serial number: V6130090
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006041
   ROD: EV_BECM09620115Q0915182.rod
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
   Component: BJB  H28 0240
   Cell Module Controller 1:
   Subsystem 2 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D1  H14 0481
   Serial number: V013C1762330573
   Cell Module Controller 2:
   Subsystem 3 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D2  H14 0481
   Serial number: V013C1762330568
   Cell Module Controller 3:
   Subsystem 4 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D3  H14 0481
   Serial number: V013C1762330572
   Cell Module Controller 4:
   Subsystem 5 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D4  H14 0481
   Serial number: V013C1762330571
   Cell Module Controller 5:
   Subsystem 6 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D5  H14 0481
   Serial number: V013C1772630045
   Cell Module Controller 6:
   Subsystem 7 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D6  H14 0481
   Serial number: V013C1772630046
   Cell Module Controller 7:
   Subsystem 8 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D7  H14 0481
   Serial number: V013C1762330586
   Cell Module Controller 8:
   Subsystem 9 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D8  H14 0481
   Serial number: V013C1762330585
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 27101711P11306
   Coding: 040307030000020101222346814E490080000E200120
   ROD: EV_MFKBoschMQBB_VW36.rod
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 091017EJ913756
   Coding: 000C17204000048000000002
   Serial number: 091017EJ913755
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 L    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H09 0212
   Serial number: EN172301820000
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 006013
   ROD: EV_ENoiseS1NNVW3707_006.rod
   VCID: 4AD7E163EDCBD87A58B-801E
   Part No SW: 5QE 915 682 AG    HW: 5QE 915 682 AG
   Component: OBC KOSTAL    H40 4013
   Revision: --------    Serial number: 0108170H10001Y
   Coding: 105168023000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
   ROD: EV_OBCSinglPhaseKLOMQB12P.rod
   VCID: 12673903C51B50BA60B-8046
   Part No SW: 3Q0 907 590 F    HW: 3Q0 907 590
   Revision: --------
   Coding: 04C002
   VCID: 3833ABAB83275AEA3EF-806C
   VCID: 17714817EEF97592175-8042
End----------(Elapsed Time: 02:15, VBatt start/end: 13.2V/13.2V)-----------
VCDS-Mobile scan:
Tue,Jan,09,2018,11:30:19
VCDS Mobile 0.4412.0.4
	 4B 52 5F 6C 75 A5 BB BC C0 C6 CF D6 D7
BB-Door Rear Drv Side -- Status: OK 0000
BC-Door Rear Pass Side -- Status: OK 0000
C0-Act. For Ext. Noise -- Status: OK 0000
Address 01: Engine  (CXUA J623)	Labels: 04-01.clb
	Revision: X3H22---
	ROD: N/A
	VCID: 6B9954AF0B1E788A12319D164E-803E
	No ASAM data for: "EV_ECM14TFS01104E906023BL"
No fault codes found.
Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
	Revision: 00032056
	VCID: 2C1B97B3CE90BFB25BBBE60203-8079
Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
	Revision: 00000000
	VCID: 7CBB67F37E70EF328BDB56C273-8029
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Revision: 00021000
	Coding: 030C0C
	ROD: EV_KessyHellaMQBAB.rod
	VCID: 3C3BA7F33EF02F32CB5B96C233-8069
Address 08: Auto HVAC  (E87)	Labels: 8V0-820-043.clb
	Revision: 20002000
	VCID: 42C7D90B5C1459C28197D80A61-8017
	Subsystem 1 - 	Part No SW: 3Q0-963-231-E
	Subsystem 2 -
	Subsystem 3 -
Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.clb
	ROD: EV_BCMMQB_018.rod
	VCID: 864F851BB0BC25E26D3FC45AED-80D3
	Subsystem 1 - 	Part No SW: 8V1-955-119-A	Labels: 5Qx-955-119-V1.clb
	Component:
G÷
	Subsystem 2 -
	Subsystem 3 -
	Subsystem 4 -
	Subsystem 5 - 	Component:
Address 10: Park/Steer Assist  (J446)	Labels: 5Q-10.lbl
	Coding: 0470155811
	VCID: 4BD9F42F6B5E988A72F13D96EE-801E
Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
	ROD: EV_ACCBOSCHVW416_001_AU37.rod
	VCID: 3B39A4EF3BFE280AC2518DD63E-806E
001538 - ROD - Unknown faultcode
001542 - ROD - Unknown faultcode
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	VCID: 47D1C81F77367CEA56C91146A2-8012
	Subsystem 1 - 	Part No SW: 5G0-980-945-B
	Component: 315
	Subsystem 2 - 	Component: 315
	Subsystem 3 - 	Component: 034
	Subsystem 4 - 	Component: ---
	Subsystem 5 - 	Component: ---
	Subsystem 6 - 	Component: ---
	Subsystem 7 - 	Component: ---
	Subsystem 8 - 	Component: ---
Address 16: Steering wheel  (J527)	Labels: 8V-16.lbl
	Revision: --------
	Coding: 6C18
	VCID: 88538B23BAA833921F53DA72D7-80DD
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	Coding: 004C0C516F88CF050283FE101B00001000000000
	VCID: 3FC1D0FF2FE6342AEE79B9E60A-806A
Address 19: CAN Gateway  (J533)	Labels: 3Q-19.clb
	ROD: EV_GatewNF_AU37.rod
	VCID: 3935BEE731C21A1AD03D77BED4-806C
	Subsystem 1 - 	Part No SW: 8W0-951-523-F
	Component: J453 MFL
	Subsystem 2 -
Address 23: Brake Booster  (J539)	Labels: None
	VCID: 52E7E94B8C74C942313788CA11-8007
	ROD: EV_LCMLeftCONTIAU426_AU37.rod
Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
	Revision: 00000000
	VCID: 342B8FD316A0E772030B3E629B-8061
	ROD: EV_LCMRightCONTIAU426_AU37.rod
Address 3C: Lane Change  (J769)	Labels: 3Q0-907-566.clb
	Revision: --------
	Coding: 04C002
Address 42: Door Elect, Driver  (J386)	Labels: 5Q-42.clb
	ROD: EV_DCUDriveSideEWMAXKLO.rod
	VCID: 43C9DC0F430E50CA8AA1E53656-8016
Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
	Coding: D106
	VCID: 45CDC2174D3A6EFAA4B5FB2EB8-8010
Address 47: Sound System  (J525)	Labels: 81A-035-466.clb
	Revision: 00000001
	VCID: 240B7F93A64077F2936B8EA2EB-8071
Address 4B: Multifunc. Module  (J745)	Labels: None
	VCID: F2A7C9CBAC3429425177684A71-80A7
Address 52: Door Elect, Pass.  (J387)	Labels: 5Q-52.clb
	ROD: EV_DCUPasseSideEWMAXKLO.rod
Address 5F: Information Electr.  (J794)	Labels: 8V-5f.clb
	Subsystem 1 - 	Part No SW: V03-959-801-PS
	Component: NAR 2018
	Subsystem 2 -
	Subsystem 3 -
	Subsystem 4 -
Address 6C: Back-up Cam.  (J772)	Labels: 5Q0-980-556.clb
	ROD: EV_CamSysRVRVCPANAMQBAB_006.rod
Address 75: Telematics  (J949)	Labels: 5QE-035-285.clb
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q-a5.clb
	ROD: EV_MFKBoschMQBB_AU37.rod
Address BB: Door Rear Drv Side  (J388)	Labels: None
	ROD: EV_DCURearDriveMINKLO.rod
Address BC: Door Rear Pass Side  (J389)	Labels: None
	ROD: EV_DCURearPasseMINKLO.rod
Address C0: Act. For Ext. Noise  (----)	Labels: 5QE-035-335.clb
	Coding: 04
	VCID: 4AD7F12B6424818249E7306AF9-801F
Address C6: Batt. Chrg.  (J1050)	Labels: None
	Revision: --------
	VCID: 9267A94BCCF48942F1B748CA51-80C7
Address CF: Lane Chge Asst 2  (J770)	Labels: 3Q-cf.clb
	Revision: --------
	Coding: 04C002
	VCID: 3833BBE30AC803122F336AB2E7-806D
	ROD: EV_LEDModLeftMELCOAU736_AU37.rod
	VCID: 9771D85FE716AC6A86E9810692-80C2
	ROD: N/A
	No ASAM data for: "EV_LEDModRightMELCOAU736"
I'm thinking VCDS should be taught to recognize those "E" trannies and not use aggressive mode when retrieving DTCs from them?
Eric
HC800000
Ha, I google searched for some of those gearbox DTCs and could only find the "E" trannies as results... is it your impression only those behave like this? If so, it's an easy workaround, indeed.
I think we start there and see what happens?
Andy
Sector 7G
HC424490
01-Engine maps
;SW:04E-906-023-BL   HW:04E-907-309-F ---  Engine
;Component:1.4 TFSI hy   H22 5190, Coding:021D0012636401083000
;EV_ECM14TFS01104E906023BL,008008,EV_ECM14TFS01104E906023BL.rod
;Friday,08,December,2017,16:05:24:29905
;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
;VCID: 6B9944E782F1217203D-803E
IDE01945-Engine run-in oil pressure,active ,1
IDE02248-Individually adjustable maximum speed limit,202.0 km/h,2
IDE05847-Hybrid drive customer service,not active ,1
IDE11520-Open tank shut-off valve to the gasoline pressure tank,0 s,1
Elapsed Time: 00:02
;Friday,08,December,2017,16:04:51:29905
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WAUSPBFF8JA063478,
IDE00019,Voltage terminal 30,13.340, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,14, °C
IDE00078,Time since engine start,0, s
IDE00083,Throttle valve position (absolute),17.3, %
IDE00084,Absolute load value,0, %
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,0.0, Nm
IDE00148,Median injection timing,0.000, ms
IDE00151,Oil fill level,73.768, mm
IDE00152,Oil warning threshold,36.000, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,4.4, °C
IDE00172,A/C compressor torque,0.0, Nm
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-24.344, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-25.000, °
IDE00178,Camshaft adjustment intake bank 1: specified value,22.789, °
IDE00179,Camshaft adjustment intake bank 1: actual value,22.000, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00187,Coolant temperature at engine start,14.3, °C
IDE00188,Fuel high pressure: actual value,3.3345, MPa
IDE00190,Charge air pressure specified value,359.84, hPa
IDE00191,Charge air pressure: actual value,1004.45, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,12.9, °C
IDE00194,Coolant temperature at radiator output: specified value,95.0, °C
IDE00196,Engine oil temperature,12.4, °C
IDE00201,High fuel pressure: specified value,14.1425, MPa
IDE00202,Low fuel pressure: specified value,538.8, kPa
IDE00304,Fuel level,41.00, l
IDE00348,Intake air temperature,15, °C
IDE00349,Throttle valve position: normed,7, %
IDE00350,Air mass: specified value,5.5, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_WAIT,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,1,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,0,
IDE00357,Fuel temperature,15.8, °C
IDE00358,Limitation: torque,400.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,1006.21, hPa
IDE00371,Fuel consumption,0.00, l/h
IDE00375,Generator: load signal,0.00, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,725.2, mV
IDE00393,Accelerator pedal: sensor voltage 2,366.2, mV
IDE00394,Camshaft position: start of phase window,111.86, °
IDE00406,Camshaft speed (RPM),0.0, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,0,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,Unknown,
IDE00474,Ambient air pressure,100, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,0.0, Nm
IDE00496-ENG57549,Activation of oil pressure switch valve-Bits 0-7,0,
IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,128,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,4, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.005 Lambda / -0.004 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.450, V
IDE00582,Equivalence ratio target value,1.999, Lambda
IDE00583,Throttle valve specified value,2, %
IDE00584,Distance driven since erasing DTC memory,66, km
IDE00587,Vapor pressure in tank ventilation system,-32206, Pa
IDE00588,Fuel tank fill level,98.0, %
IDE00592,Oxygen sensor control status,Engine off,
IDE00593,Ignition timing adjustment cylinder 1,0.0, Degrees
IDE00594,Absolute intake pressure,100, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,-0.8, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,6,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00657,Hybrid battery voltage,354.75, V
IDE00699,ESI: minimum oil level in service interval,32.000, mm
IDE00700,ESI: maximum oil level in service interval,-32.000, mm
IDE00752,Test of oxygen sensor control.,Syst. OK,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,228,
IDE00773,Terminal 15 status via CAN,1,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,4.5, °C
IDE01076,Time since ignition off,65535, s
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,1.0000,
IDE01260,Generator power,0, W
IDE01267,Height correction,0.99329,
IDE01378,High fuel pressure: control deviation,10.8075, MPa
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.455, V
IDE01650,Throttle valve position 2,17, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,blocked,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,104,
IDE01834,Battery voltage,13340, mV
IDE01869,Long-term fuel trim bank 1 at idle,-0.28, %
IDE01870,Oxygen sensor after catalytic converter: operating status,Test off,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,7.3696,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01876,Adaptation of loss torque,3.0, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,0,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,0.000, %
IDE01885,Shut off of oxygen sensor control,l-Reg.OFF,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,3,
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,3.999, %
IDE01900,Charge press. ctrl.: spec. value,0.0, %
IDE01901,Lost torque adaptation: idle,3.0, Nm
IDE01902,Lost torque adaptation A/C compressor,0.0, Nm
IDE01903,Lost torque adaptation driving mode,0.0, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,0.0, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.00000,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.13574,
IDE01911,Leakage air,3.4, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,15.9998,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,170,
IDE01922,Vehicle distance driven,78, km
IDE01923,Control module distance driven,78520, m
IDE01928,Close cam shaft angle at quantity control valve,54.0, °
IDE01929,Open cam shaft angle at quantity control valve,-8.0, °
IDE01930,High pressure regulation: adaptation value,0.2355, MPa
IDE01932,High pressure pump injection volume,327.67, mm³
IDE01975,Numb.of misfir.: cylinder 1,28,
IDE01976,Numb.of misfir.: cylinder 2,30,
IDE01977,Numb.of misfir.: cylinder 3,17,
IDE01978,Numb.of misfir.: cylinder 4,27,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,178,
IDE02116,Exhaust gas temperature before catalytic converter,4.49, °C
IDE02117,Relative load value,79.95, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,0.00, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03262,Adapt of angle sensor 1 f throttle valve,0.494, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.512, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.873, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.136, V
IDE03362,Requested transmission torque,1000.0, Nm
IDE03377,Coolant temp at radiator output: unconditioned voltage,3848.4, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,138,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,229,
IDE03709,Angle difference actual-specified camshaft adjuster,0.789, °
IDE03711,Mass flow through throttle valve,0.0, kg/h
IDE03767,Engine status,COENG_READY,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,1,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,0.000, %
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,0,
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,0,
IDE03814,Test of secondary air system: deviation mass air flow Bank 1,0.000,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,0.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,0.00, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,0.000, %
IDE03932,Charge pressure actuator: specified position,19.93, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3181.6, mV
IDE03935,Charge pressure actuator: adaptation for upper stop,90.0, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.99652,
IDE04002,Charge press. ctrl.,BP_A act:100, kPa
IDE04003,Charge air temperature sensor,B1S1:15 °C /  °C,
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:3230/--- kPa,
IDE04088,Turbocharger 1: temperature,Compr. in/out---/19 °C / Compr. in/out---/--- °C,
IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,0.000000, kJ
IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,0.000000, kJ
IDE04240,Counter start bef dew pt end f O2 sensor bef cat conv bank1,0,
IDE04244,Count start bef dew pt end f O2 sensor beh main cat conv bank1,0,
IDE04278,Bypass valve f high press turboch turbine inlet: target value,0.00, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,20.01, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,-0.27, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,0.27, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,0.00, %
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,2,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,16,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,702.6, mV
IDE04410,Intake manifold pressure: target value,342.73, hPa
IDE04420,Activation of secondary air system,Atmosphere/off,
IDE04604,Accelerator pedal travel,0.00, %
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04654-ENG57549,CAN status - engine control module-Bits 0-7,0,
IDE04670,Crankshaft signal evaluation: status,WAITSIG,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,2,
IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,15.9998,
IDE04685,Setpoint generation interior torque,0.0, Nm
IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-50000.0, Nm
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04872,Brake pedal value sensor: relative value filtered,-0.01, %
IDE04875,Brake pedal value sensor: learned zero point offset value,0.00, %
IDE04882,Operating mode control expanded electrical driving,Correct result,
IDE04882-ENG127289,Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE,1,
IDE04885,Hybrid batt charge cond act val standardized,45.05, %
IDE04887,Powertrain target torque,-364.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,-26.0, Nm
IDE04909-ENG57549,Operating mode of hybrid system-Bits 0-7,6,
IDE04913,Current speed of electric motor,0.0, /min
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,73904, s
IDE05140,Intake manifold pressure raw value,1007.66, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,Tank vent valve diagnosis pressure difference ratio,0.00,
IDE05217,Hybrid battery charge current actual value,1.75, A
IDE05219,E-machine current actual value,0.00, A
IDE05220,E-machine voltage actual value,355.00, V
IDE05221,E-machine torque actual value,-0.3, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05242,Phase angle adaptation request,False result,
IDE05242-ENG127289,Phase angle adaptation request-Test_Program_B TRUE UBYTE,0,
IDE05243,E-machine power consumption: actual value,0, W
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05436,Engine operating condition,Idling,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,4.5, °C
IDE05438,Rear cat conv temp main cat conv model value,4.49, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,16.99, %
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,131070, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00070,
IDE05464,Oxygen sensor 1 bank 1 fast offset adaptation counter,0,
IDE05466,Oxy sensor 1 bank 1 offset spec value,0.00000,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,-273.15, °C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05474,Main cat converter OSC age correction factor,1.070,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,0.0, kg/h
IDE05479,Misfire recognition reference moment,0.000, %
IDE05482,Tank venting adaptation factor,0.000,
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05508,Adaptation val cyl 1 with slow diagnosis,1.00000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,1.00000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,1.00000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,1.00000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,1.00000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,1.00000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,1.00000,
IDE05593,Secondary air injection sensor 1,1004.88, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05797,Throttle valve adapter: specified value,1.700, %
IDE06017,Camshaft position deviation from reference position,0.00, °
IDE06020,Intake air temperature in intake manifold bank raw value,15.0, °C
IDE06021,Intake air temperature before throttle valve: raw value,18.8, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,0.0, /min
IDE06040,High fuel pressure: regulator output value,16.3835, MPa
IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06056,Electric driving button status,Correct result,
IDE06056-ENG127289,Electric driving button status-Test_Program_B TRUE UBYTE,1,
IDE06098,Sensor control factor: output value,1.00000,
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,0,
IDE06386,Oil level: static measurement,73.768, mm
IDE06387,Oil level: last valid dynamic value,0.000, mm
IDE06388,Oil level: condition for static measurement fulfilled,1,
IDE06393,Oil level: dynamic average value,131.068, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06446-ENG57549,Status: incline angle-Bits 0-7,1,
IDE06607,Distance at last active oil overfill warning,0.0, km
IDE06608,Total distance with active oil overfill warnings,0.0, km
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,128,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,130,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,4,
IDE06706-ENG57549,ACC variants-Bits 0-7,2,
IDE06707-ENG57549,CCS Switch-Bits 0-7,2,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,0,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,255,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06758,Air mass since engine start,0.00, kg
IDE06759,Cam shaft adaptation inlet: counter,3,
IDE06760,Camshaft adaptation: exhaust: counter,3,
IDE06828,Coolant recirc. pump 2: spec. value,85.52, %
IDE06830,Coolant pump for charge-air cooling: spec. value,18.81, %
IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
IDE06947-ENG57549,E-machine operating mode: spec. state-Bits 0-7,0,
IDE06948-ENG57549,High-volt. battery mode: spec. value-Bits 0-7,4,
IDE06953,Radiator bypass change-over valve activation,0.00, %
IDE06957,Unfiltered clutch input rpm,0.0, /min
IDE06965,Coolant temp. before power electronics: act. value,25.2, °C
IDE06972,High-volt. battery: charge state: abs. value,48.79, %
IDE07048,Gasoline tank pressure sensor unconditioned voltage,1.655, V
IDE07049,Gasoline tank pressure sensor: offset corrected,-5.62, hPa
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07094,Correction factor injector cylinder 1,0.0000,
IDE07095,Correction factor injector cylinder 2,0.0000,
IDE07096,Correction factor injector cylinder 3,0.0000,
IDE07097,Correction factor injector cylinder 4,0.0000,
IDE07164,Number injections,0,
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,66,
IDE07234,Status bid for valid static oil level,1,
IDE07235,Status bid for dynamic oil level,0,
IDE07239-ENG57549,Operating state of electric drive-Bits 0-7,50,
IDE07254,Gasoline pressure tank refueling request button,0,
IDE07255-ENG57549,Number of refueling processes with time exceedance-Bits 0-7,1,
IDE07256-ENG57549,Number of refueling processes without time exceedance-Bits 0-7,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07573,Throttle valve adapter: actual value,9.50, %
IDE07796-ENG57549,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,6,
IDE08562,Basic correction factor: Injector cyl. 1: filtered,1.0000,
IDE08563,Basic correction factor: Injector cyl. 2: filtered,0.0000,
IDE08564,Basic correction factor: Injector cyl. 3: filtered,0.0000,
IDE08565,Basic correction factor: Injector cyl. 4: filtered,0.0000,
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09531,Total mass of gasoline and alcohol in oil,9.37, g
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,0.789, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,0.656, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,0.22, °
IDE09932,Intake camshaft bank1: adaption value sensor tolerance,0.20, °
IDE10040,Outlet camshaft bank 1 active operating mode,0,
IDE10041-ENG57549,Intake camshaft bank1 active operating mode-Bits 0-7,0,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10302,Time since engine start,0.0, s
IDE10303,Integrated air masse at first engine start,0.0000, kg
IDE10560-ENG57549,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,120.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.00, s
IDE11290,Heating circuit temp.: raw value,11.3, °C
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,0.000, l
IDE11522-ENG57549,Gasoline pressure tank fueling status-Bits 0-7,10,
IDE11523,State of shut-off valve to the gasoline pressure tank,false,
IDE11523-ENG127289,State of shut-off valve to the gasoline pressure tank-Test_Program_B TRUE UBYTE,0,
IDE11574,Status max. oil level dynamically exceeded,0,
IDE11575,Status max. oil level permanently exceeded,0,
IDE11576,Oil level: last valid dynamic value overfilling,0.000, mm
IDE11968-ENG57549,Meter for tank-empty operation-Bits 0-7,0,
IDE12000,Combustion: minimum number calculated of active crankshaft segments,0.0, %
IDE12001,Combustion: calculated crankshaft angle after TO,0.00, °
IDE12002,Combustion: average calculated crankshaft angle after TO,0.00, °
IDE12003,Combustion: minimum calculated crankshaft angle after TO,0.00, °
IDE12004,Combustion: number of calculated active crankshaft segments,0.0, %
IDE12005,Combustion: average value calculated of active crankshaft segments,0.0, %
IDE12355,ESI: consumption equivalent of the engine control module,0.00000000,
MAS15845,Fuel: tank fill level,41.3, l
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
ENG119898,Actual_section_of_standard_test,0,
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,0,
ENG101413,Calibration Identification,04E023BL5190BXAJ,
ENG99697,Calibration Verification Number,BC 81 A4 80,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG100634,In-use Per Tr: 16 or 20 cou*sec O2 Sens Mon Con Enc Cou B 1,00 03 00 46 00 01 00 03 00 00 00 00 00 00 00 03 00 00 00 00 00 08 00 02 00 04 00 02 00 00 00 01 00 00 00 03 00 00 00 00,
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
Elapsed Time: 00:32
Andy
Sector 7G
HC424490
02-Auto Trans maps
;SW:0DD-300-046-G   HW:0DD-927-770-C ---  Auto Trans
;Component:GSG DQ400E    H32 1601, Coding:0014
;EV_TCMDQ400021,001001,EV_TCMDQ400021.rod
;Friday,08,December,2017,16:06:06:29905
;VCID: 2C1B87FB477FE64A4A7-8078
Elapsed Time: 00:01
;Friday,08,December,2017,16:05:30:29905
IDE00008,Softwareversion,1601,
IDE00018,Voltage terminal 15,12.8, V
IDE00019,Voltage terminal 30,12.6, V
IDE00021-ENG99543,Engine speed-Engine RPM,0, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,0, /min
IDE00023,Transmission output speed,0, /min
IDE00024,Transmission fluid temperature,23, °C
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0.00, km/h
IDE00086-ENG98363,Accelerator position-Accelerator pedal position,0.0, %
IDE00091-ENG101172,Status of starter lock-Status Engine Starter Lock,Activate,
IDE00094,Kick-down status,OFF,
IDE00095-ENG101643,Status of selector lever lock-Status Shift Lock,active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00101-ENG103259,Engine specified torque during transmission intervention-Calculated engine preset torque,1048.0, Nm
IDE00102-ENG102028,Control Module temperature-Control modul temperature,31, °C
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,0,
IDE00323-ENG09093,Security Access: Number of invalid keys-Counter Value,0,
IDE00450-ENG12321,Operating Instructions-Requested Action,--no display--,
IDE00451-ENG103018,Currently running routine-Current Test Routine,0,
IDE00872-ENG102188,Current of main pressure valve-Oil Pressure Actual Current,601.0, mA
IDE00970-ENG114816,Coolant fan activation: actual value-Radiator fan activation actual value,10.0, %
IDE00972,Idle speed increase,OFF,
IDE01588-ENG101855,Driving direction-M015 SvnNAbRichtung,not known,
IDE01716-ENG103234,Terminal 50 status-Status terminal 50,OFF,
IDE02211,Brake pressure,0.00, bar
IDE02221,Engine torque: qualification,valid,
IDE02713,Brake Light Switch,not activated,
IDE02714,Brake test switch,not activated,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,via CAN,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02719-ENG99606,Selector lever position made plausible-Shift Position Plausible,P,
IDE02720-ENG103810,Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1,0, /min
IDE02721-ENG100916,Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2,0, /min
IDE02722-ENG101964,Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1,0, /min
IDE02723-ENG100382,Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2,0, /min
IDE02724,Direction of rotation shaft 1,not known,
IDE02725,Direction of rotation shaft 2,not known,
IDE02726-ENG100799,Voltage supply E-pump-Voltage Supply Electric Motor,12.6, V
IDE02727-ENG99192,Selector lever lock SPECIFIED condition-Shift Lock Desired State,active,
IDE02728-ENG101668,Shift lock indicator lamp-Indicator Light Shift Lock,Indicator lamp off,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged,
IDE02738-ENG100412,Selector lever illumination-Display Shift Lighting,P,
IDE02740-ENG99750,Temperature of friction lining for clutch 1-Temperatur_Friction_Lining_Clutch_1,21, °C
IDE02741-ENG102724,Temperature of friction lining for clutch 2-Temperatur_Friction_Lining_Clutch_2,21, °C
IDE02742,Oil pressure actual value,0.00, bar
IDE02775-ENG101304,Status of basic setting data-State Of Basic Adjustmentdata,valid,
IDE02776-ENG102757,Pressure of partial transmission 1 specified value-Pressure Transmission Part 1 Commanded Value,1.50, bar
IDE02777-ENG101539,Pressure of partial transmission 1 actual value-Pressure Transmission Part 1 Actual Value,1.50, bar
IDE02779-ENG100646,Pressure of partial transmission 2 specified value-Pressure Transmission Part 2 Commanded Value,1.50, bar
IDE02780-ENG103741,Pressure of partial transmission 2 actual value-Pressure Transmission Part 2 Actual Value,1.50, bar
IDE02782-ENG103418,Current of valve for partial transmission 1 specified value-Current Valve Transmission Part 1 Commanded Value,245.7, mA
IDE02783-ENG99260,Current of valve for partial transmission 1 actual value-Current Valve Transmission Part 1 Actual Value,247.0, mA
IDE02785-ENG120854,Pulse duty factor of valve for partial transmission 1-Duty_Factor_Valve_Transmission_Part_1,0.0, %
IDE02786-ENG101222,Current of valve for partial transmission 2 specified value-Current Valve Transmission Part 2 Commanded Value,239.9, mA
IDE02787-ENG101614,Current of valve for partial transmission 2 actual value-Current Valve Transmission Part 2 Actual Value,241.0, mA
IDE02789-ENG120856,Pulse duty factor of valve for partial transmission 2-Duty_Factor_Valve_Transmission_Part_2,0.0, %
IDE02790-ENG104124,Specified torque clutch 1-Clutch 1 Commanded Torque,-100.00, Nm
IDE02791-ENG101742,Actual torque clutch 1-Clutch 1 Actual Torque,-100.00, Nm
IDE02792-ENG101464,Specified position clutch 1-Clutch 1 Commanded Position,0.00, bar
IDE02793-ENG102450,Actual position clutch 1-Clutch 1 Actual Position,0.04, bar
IDE02796-ENG103463,Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value,0.0, mA
IDE02797-ENG100730,Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value,0.0, mA
IDE02799-ENG120860,Duty cycle of valve for clutch 1-Duty_Factor_Valve_Clutch_1,0.0, %
IDE02800-ENG100171,Specified torque clutch 2-Clutch 2 Commanded Torque,-100.00, Nm
IDE02801-ENG120891,Specified position clutch 2-Clutch_2_Commanded_Position,0.00, bar
IDE02802-ENG102780,Actual position clutch 2-Clutch 2 Actual Position,0.10, bar
IDE02805-ENG99237,Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value,0.0, mA
IDE02806-ENG103118,Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value,0.0, mA
IDE02808-ENG120864,Duty cycle of valve for clutch 2-Duty_Factor_Valve_Clutch_2,0.0, %
IDE02820,Transmission mileage,78.9, km
IDE02821-ENG101653,Pressure supply specified pressure/threshold1-Pressure Supply Commanded Value Threshold 1,53.00, bar
IDE02823-ENG100173,Identification of selector lever-Identification Selector Lever,8V1713023AJ VL19,
IDE02824-ENG99279,Main status of abort code basic setting-Basic Settings Main Status,0,
IDE02825-ENG100313,Substatus of abort code basic setting-Basic Settings Sub Status,0,
IDE02827-ENG103491,Steering wheel paddle installation info-Application Info Steering Paddels,59,
IDE02828-ENG103640,Brake installation info-Application Info Breaksystem,59,
IDE02829-ENG103127,Steering wheel module installation info-Application Info Steering Modul,59,
IDE02830-ENG100103,Gateway installation info-Application Info Gateway,59,
IDE02858-ENG100590,Status of basic setting data: gear selector-State Of Basic Adjustmentdata Gearpositioner,Valid basic calibration,
IDE02859-ENG99797,Status of basic setting data for clutch-State Of Basic Adjustmentdata Clutch,Valid basic calibration,
IDE02864-ENG99505,Actual position of gear positioner A-Gearpositioner A Actual Position,7.87, mm
IDE02865-ENG104121,AD value 1 of actual position of gear positioner A-Gearpositioner A Actual Position AD Value 1,0,
IDE02867-ENG103746,Specified current of gear Solen.val. A-Gearpositioner A Valve Commanded Current,0.0, mA
IDE02868-ENG102455,Actual current of gear Solen.val. A-Gearpositioner A Valve Actual Current,1.0, mA
IDE02870-ENG120871,Duty cycle of gear Solen.val. A-Gearpositioner_A_Valve_Duty_Factor,0.0, %
IDE02872-ENG102218,Actual position of gear adjuster B-Gearpositioner B Actual Position,-0.06, mm
IDE02873-ENG101728,AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1,0,
IDE02875-ENG101174,Specified current of gear Solen.val. B-Gearpositioner B Valve Commanded Current,0.0, mA
IDE02876-ENG99266,Actual current of gear Solen.val. B-Gearpositioner B Valve Actual Current,2.0, mA
IDE02878-ENG120875,Pulse duty factor of gear Solen.val. B-Gearpositioner_B_Valve_Duty_Factor,0.0, %
IDE02880-ENG103036,Actual position of gear positioner C-Gearpositioner C Actual Position,-0.14, mm
IDE02881-ENG99453,AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1,0,
IDE02883-ENG103740,Specified current of gear Solen.val. C-Gearpositioner C Valve Commanded Current,0.0, mA
IDE02884-ENG99821,Actual current of gear Solen.val. C-Gearpositioner C Valve Actual Current,1.0, mA
IDE02886-ENG120879,Pulse duty factor of gear Solen.val. C-Gearpositioner_C_Valve_Duty_Factor,0.0, %
IDE02888-ENG103826,Actual position of gear positioner D-Gearpositioner D Actual Position,-7.71, mm
IDE02889-ENG100525,AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1,0,
IDE02891-ENG101968,Specified current of gear Solen.val. D-Gearpositioner D Valve Commanded Current,0.0, mA
IDE02892-ENG99541,Actual current of gear Solen.val. D-Gearpositioner D Valve Actual Current,1.0, mA
IDE02894-ENG120883,Duty cycle of gear Solen.val. D-Gearpositioner_D_Valve_Duty_Factor,0.0, %
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03107-ENG126246,Kilometers at last basic setting-Kilometer At Last Basic Adjustment,0, km
IDE03152-ENG104154,Neutral due to driver registr. proced. cond.: cause-Driver Registration Procedure Condition Cause,00 00,
IDE03153-ENG102498,Driver logon procedure: number of activations-Driver Registration Procedure Activation Counter,2,
IDE03155-ENG99516,GE clutch data: Status-GE Clutch Data Status,Data for basic calibration valid,
IDE03156-ENG102903,Last change to GE clutch data: odometer reading-Last Changing GE Clutch Data Km,0, km
IDE03160-ENG100046,Remaining clutch fast adaptations: kiss point-Remaining Clutch Fastadaption Kisspoint,2,
IDE03163-ENG103608,Protect. function temp. clutch 1 warn. level 1 number-Protective Function Temperature Clutch 1 Warning 1 Numbers,0,
IDE03164-ENG101576,Protect. function temp. clutch 1 warn. level 2 number-Protective Function Temperature Clutch 1 Warning 2 Numbers,0,
IDE03165-ENG102133,Protective function temp. clutch 1 protect. level 1 number-Protective Function Temperature Clutch 1 Protection 1 Numbers,0,
IDE03167-ENG102425,Protect. function temp. clutch 2 warn. level 1 number-Protective Function Temperature Clutch 2 Warning 1 Numbers,0,
IDE03168-ENG100182,Protect. function temp. clutch 2 warn. level 2 number-Protective Function Temperature Clutch 2 Warning 2 Numbers,0,
IDE03169-ENG104175,Protective function temp. clutch 2 protect. level 1 number-Protective Function Temperature Clutch 2 Protection 1 Numbers,0,
IDE03171-ENG102987,Driving strategy transmission mileage-Q002 Total Driving Time,83.5, km
IDE03172-ENG100789,Driving strategy driving portions in D or S w/ CCS-Q003 Driving Time Ecological,68, %
IDE03173-ENG103567,Driving strategy driving portions in S w/o CCS-Q004 Driving Time Sporty,9, %
IDE03174-ENG100415,Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual,23, %
IDE03180-ENG103176,Number of standard trips-General Denominator,3,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,33,
IDE04612-ENG101246,Clutch temperature air / splash oil-Centrifugal oil temperature,0, °C
IDE05303-ENG99893,Actual torque clutch 2-Clutch 2 Actual Torque,-100.00, Nm
IDE05987-ENG110524,Engine stop prohibitions-Basic setting,not active,
IDE05987-ENG28506,Engine stop prohibitions-Demontagestellung,not active,
IDE05987-ENG28505,Engine stop prohibitions-Drucksensorausfall,not active,
IDE05987-ENG28507,Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE05987-ENG110508,Engine stop prohibitions-km-Stand des letzten Stoppverbots,0.0, km
IDE05987-ENG28638,Engine stop prohibitions-Motorstoppverbote Anzahl Stoppverbote,0,
IDE05987-ENG110525,Engine stop prohibitions-Stop prohibition via application,not active,
IDE05987-ENG28504,Engine stop prohibitions-Temperaturbedingung,not active,
IDE05987-ENG122385,Engine stop prohibitions-unsortierte Gangsteller im Stand,not active,
IDE05988-ENG110505,Pressure of clutch 2: actual value-Clutch_2_actual_value,0.10, bar
IDE05989-ENG110503,Pressure of clutch 1: actual value-Clutch_1_actual_value,0.02, bar
IDE05990-ENG110506,Pressure of clutch 2: specified value-Clutch_2_commanded_value,0.00, bar
IDE05991-ENG110504,Pressure of clutch 1: specified value-Clutch_1_commanded_value,0.00, bar
IDE06241-ENG120892,Uneven road surface recognition: total driving portion-Drivingpart_of_roug_road_detection_total,655.3, %
IDE06243-ENG120894,Longest active distance with uneven road surface recognition-Longest_active_mileage_of_rough_road_detection,74, km
IDE06425,Roller test bench mode: functional,not activated,
IDE08133-ENG121991,Basic setting: cause for cancellation-Routine_abort_reason,Basic setting not active,
IDE10834-ENG127894,Identification data hybrid module-Anfang,#,
IDE10834-ENG98612,Identification data hybrid module-Date of manufacture,171107,
IDE10834-ENG98577,Identification data hybrid module-END,#,
IDE10834-ENG112382,Identification data hybrid module-Index,K ,
IDE10834-ENG120774,Identification data hybrid module-Lfd. Nr. pro Tag,0165,
IDE10834-ENG120775,Identification data hybrid module-Linienkennung,G04,
IDE10834-ENG124826,Identification data hybrid module-Measured value,Angle=275,7,
IDE10834-ENG126639,Identification data hybrid module-Messwert G1,G1=33,84,
IDE10834-ENG126640,Identification data hybrid module-Messwert G2,G2=29,38,
IDE10834-ENG126641,Identification data hybrid module-Messwert K1,K1=76,28,
IDE10834-ENG126634,Identification data hybrid module-Standort,K,
IDE10834-ENG126637,Identification data hybrid module-Trennzeichen 1,*&*,
IDE10834-ENG126638,Identification data hybrid module-Trennzeichen 2,*,
IDE10834-ENG126643,Identification data hybrid module-Trennzeichen 3,*,
IDE10834-ENG126642,Identification data hybrid module-Trennzeichen 4,*,
IDE10834-ENG126633,Identification data hybrid module-VW-Teilenummer,0DD901152,
IDE10835-IDE00009,Identification data: electric machine-Date of manufacture,171105,
IDE10835-MAS04970,Identification data: electric machine-Part Number,0EC901091,
IDE10835-ENG112382,Identification data: electric machine-Index,T_,
IDE10835-ENG126635,Identification data: electric machine-Kennbuchstabe,EAH_,
IDE10835-ENG126636,Identification data: electric machine-Laufnummer (über Alles),AI2941,
IDE10835-ENG120774,Identification data: electric machine-Lfd. Nr. pro Tag,0018,
IDE10835-ENG120775,Identification data: electric machine-Linienkennung,G06,
IDE10835-ENG126634,Identification data: electric machine-Standort,K,
IDE10889-ENG127918,Pulse duty ratio: clutch cooling valve-Duty Factor Valve Clutch Cooling,1.4, %
IDE10890-ENG127919,Pulse duty ratio: reservoir filling valve-Duty Factor Accumulator Pressure Valve,32.0, %
IDE10891-ENG127920,Pulse duty ratio: clutch valve K0-Duty Factor Valve Clutch 0,0.0, %
IDE11135-ENG127823,Capacity protection function: clutch 2 number-Protective_Function_Capacity_Clutch_2_Numbers,0,
IDE11136-ENG127822,Capacity protection function: clutch 1 number-Protective_Function_Capacity_Clutch_1_Numbers,0,
IDE11206-ENG98675,Mechatronic identification DQ400e-Construction version,B4,
IDE11206-ENG98612,Mechatronic identification DQ400e-Date of manufacture,171106,
IDE11206-ENG112382,Mechatronic identification DQ400e-Index,H-,
IDE11206-ENG120774,Mechatronic identification DQ400e-Lfd. Nr. pro Tag,0102,
IDE11206-ENG120775,Mechatronic identification DQ400e-Linienkennung,G05,
IDE11206-ENG126634,Mechatronic identification DQ400e-Standort,K,
IDE11206-ENG120776,Mechatronic identification DQ400e-Ventilkennung,A,
IDE11206-ENG126633,Mechatronic identification DQ400e-VW-Teilenummer,0DD325025,
IDE11241-ENG127896,Clutch 0 kiss point: successful adaptation counter-Clutch 0 adaption kisspoint positive case counter,5,
IDE11242-ENG127897,Clutch 0 upper point adaptation: success counter-Clutch 0 adaption upper point positive case counter,3,
IDE11243-ENG127898,Clutch 0 adaptation: reference start counter-Clutch 0 adaption counter for reference start counter,7,
IDE11244-ENG127899,Couple 0 adaptation: characteristic point 1 pressure-Clutch 0 adaption characteristic point 1 pressure,8.94, bar
IDE11245-ENG127900,Couple 0 adaptation: characteristic point 1 torque-Clutch 0 adaption characteristic point 1 torque,0.0, Nm
IDE11246-ENG127901,Couple 0 adaptation: characteristic point 2 pressure-Clutch 0 adaption characteristic point 2 pressure,9.94, bar
IDE11247-ENG127902,Couple 0 adaptation: characteristic point 2 torque-Clutch 0 adaption characteristic point 2 torque,10.0, Nm
IDE11248-ENG127903,Couple 0 adaptation: characteristic point 3 pressure-Clutch 0 adaption characteristic point 3 pressure,29.45, bar
IDE11249-ENG127904,Couple 0 adaptation: characteristic point 3 torque-Clutch 0 adaption characteristic point 3 torque,400.0, Nm
IDE11885-ENG09172,Error status of pump motor activation-Failure_status,0,
IDE11885-ENG09276,Error status of pump motor activation-Failure_status_cumulated,0,
IDE11921-ENG09197,Reason for cancelling emptying of oil pressure reservoir-Abort_reason_automatic_transmission_fluid_pressure_accumulator_discharge,Do not cancel,
IDE12712-ENG36173,Odometer reading on adopting the vehicle odometer reading-Mileage of setting resetting gearbox mileage,0.0, km
IDE12713-ENG36135,Transmission odometer reading-Gearbox mileage,78.9, km
IDE13947-ENG36805,Mileage since last activation: uneven road surface recognition-Kilometer_at_last_ activation_rough_road_detection,0, km
IDE80001-ENG100467,Analysis 1-Snapshot 1 Failure ID,0,
IDE80002-ENG102386,Analysis 2-Snapshot 1 Mileage,0, km
IDE80003-ENG101467,Analysis 3-Snapshot 1 Counter,0,
IDE80004-ENG110548,Analysis 4-Snapshot 1 Oil Pressure Actual Value,-10.0, bar
IDE80005-ENG103330,Analysis 5-Snapshot 1 Shift Position Plausible,P,
IDE80006-ENG99650,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Fahrzeugzustand,New,
IDE80006-ENG102000,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80007-ENG101090,Analysis 7-Snapshot 1  Commanded Gear,GANG N,
IDE80008-ENG100048,Analysis 8-Snapshot 1 Preselection Gear,GANG N,
IDE80009-ENG102100,Analysis 9-Snapshot 1 Transmission Input Speed,0, /min
IDE80010-ENG101565,Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1,0, /min
IDE80011-ENG100379,Analysis 11-Snapshot 1 Transmission Speed Shaft 1,0, /min
IDE80012-ENG103459,Analysis 12-Snapshot 1 Transmission Speed Shaft 2,0, /min
IDE80013-ENG99331,Analysis 13-Snapshot 1 Gearpositioner A Actual Value,-20.48, mm
IDE80014-ENG99512,Analysis 14-Snapshot 1 Gearpositioner B Actual Value,-20.48, mm
IDE80015-ENG100338,Analysis 15-Snapshot 1 Gearpositioner C Actual Value,-20.48, mm
IDE80016-ENG100656,Analysis 16-Snapshot 1 Gearpositioner D Actual Value,-20.48, mm
IDE80017-ENG99158,Analysis 17-Snapshot 1 Gearpositioner A Valve Actual Current,0, mA
IDE80018-ENG101917,Analysis 18-Snapshot 1 Gearpositioner B Valve Actual Current,0, mA
IDE80019-ENG102153,Analysis 19-Snapshot 1 Gearpositioner C Valve Actual Current,0, mA
IDE80020-ENG100002,Analysis 20-Snapshot 1 Gearpositioner D Valve Actual Current,0, mA
IDE80021-ENG102762,Analysis 21-Snapshot 1 Clutch 1 Actual Pressure,0.0, bar
IDE80022-ENG100347,Analysis 22-Snapshot 1 Clutch 2 Actual Pressure,0.0, bar
IDE80023-ENG99119,Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value,0, mA
IDE80024-ENG101123,Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value,0, mA
IDE80025-ENG103611,Analysis 25-Snapshot 1 Accelerator Pedal Position,0.0, %
IDE80026-ENG101503,Analysis 26-Snapshot 1 Engine torque,-50, Nm
IDE80027-ENG101521,Analysis 27-Snapshot 1 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80028-ENG103949,Analysis 28-Snapshot 1 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80029-ENG103070,Analysis 29-Snapshot 1 Voltage Terminal 15,0.0, V
IDE80030-ENG101050,Analysis 30-Snapshot 1 Voltage Supply Electric Motor,0.0, V
IDE80031-ENG102899,Analysis 31-Snapshot 1 Transmission Fluid Temperature,-60, °C
IDE80032-ENG99872,Analysis 32-Snapshot 1 Maximum Temperature Clutch 1 Clutch 2,-60, °C
IDE80033-ENG103098,Analysis 33-Snapshot 2 Failure ID,0,
IDE80034-ENG101047,Analysis 34-Snapshot 2 Mileage,0, km
IDE80035-ENG99915,Analysis 35-Snapshot 2 Counter,0,
IDE80036-ENG110549,Analysis 36-Snapshot 2 Oil Pressure Actual Value,-10.0, bar
IDE80037-ENG99369,Analysis 37-Snapshot 2 Shift Position Plausible,P,
IDE80038-ENG99350,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Fahrzeugzustand,New,
IDE80038-ENG102372,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80039-ENG101369,Analysis 39-Snapshot 2  Commanded Gear,GANG N,
IDE80040-ENG103638,Analysis 40-Snapshot 2 Preselection Gear,GANG N,
IDE80041-ENG103367,Analysis 41-Snapshot 2 Transmission Input Speed,0, /min
IDE80042-ENG102476,Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1,0, /min
IDE80043-ENG102699,Analysis 43-Snapshot 2 Transmission Speed Shaft 1,0, /min
IDE80044-ENG101900,Analysis 44-Snapshot 2 Transmission Speed Shaft 2,0, /min
IDE80045-ENG100935,Analysis 45-Snapshot 2 Gearpositioner A Actual Position,-20.48, mm
IDE80046-ENG102046,Analysis 46-Snapshot 2 Gearpositioner B Actual Position,-20.48, mm
IDE80047-ENG100712,Analysis 47-Snapshot 2 Gearpositioner C Actual Position,-20.48, mm
IDE80048-ENG101670,Analysis 48-Snapshot 2 Gearpositioner D Actual Position,-20.48, mm
IDE80049-ENG102288,Analysis 49-Snapshot 2 Gearpositioner A Valve Actual Current,0, mA
IDE80050-ENG103952,Analysis 50-Snapshot 2 Gearpositioner B Valve Actual Current,0, mA
IDE80051-ENG99664,Analysis 51-Snapshot 2 Gearpositioner C Valve Actual Current,0, mA
IDE80052-ENG100255,Analysis 52-Snapshot 2 Gearpositioner D Valve Actual Current,0, mA
IDE80053-ENG102973,Analysis 53-Snapshot 2 Clutch 1 Actual Pressure,0.0, bar
IDE80054-ENG100122,Analysis 54-Snapshot 2 Clutch 2 Actual Pressure,0.0, bar
IDE80055-ENG103189,Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value,0, mA
IDE80056-ENG103616,Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value,0, mA
IDE80057-ENG102447,Analysis 57-Snapshot 2 Accelerator Pedal Position,0.0, %
IDE80058-ENG103198,Analysis 58-Snapshot 2 Engine torque,-50, Nm
IDE80059-ENG100322,Analysis 59-Snapshot 2 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80060-ENG99335,Analysis 60-Snapshot 2 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80061-ENG101449,Analysis 61-Snapshot 2 Voltage Terminal 15,0.0, V
IDE80062-ENG99916,Analysis 62-Snapshot 2 Voltage Supply Electric Motor,0.0, V
IDE80063-ENG104157,Analysis 63-Snapshot 2 Transmission Fluid Temperature,-60, °C
IDE80064-ENG101948,Analysis 64-Snapshot 2 Maximum Temperature Clutch 1 Clutch 2,-60, °C
IDE80071-ENG127839,Analysis 71-FID event memory entry 1,FF FF,
IDE80071-ENG127848,Analysis 71-FID event memory entry 10,FF FF,
IDE80071-ENG127849,Analysis 71-FID event memory entry 11,FF FF,
IDE80071-ENG127850,Analysis 71-FID event memory entry 12,FF FF,
IDE80071-ENG127840,Analysis 71-FID event memory entry 2,FF FF,
IDE80071-ENG127841,Analysis 71-FID event memory entry 3,FF FF,
IDE80071-ENG127842,Analysis 71-FID event memory entry 4,FF FF,
IDE80071-ENG127843,Analysis 71-FID event memory entry 5,FF FF,
IDE80071-ENG127844,Analysis 71-FID event memory entry 6,FF FF,
IDE80071-ENG127845,Analysis 71-FID event memory entry 7,FF FF,
IDE80071-ENG127846,Analysis 71-FID event memory entry 8,FF FF,
IDE80071-ENG127847,Analysis 71-FID event memory entry 9,FF FF,
IDE80072-ENG127830,Analysis 72-Temperature hybrid time in range 0,0.0, s
IDE80073-ENG127869,Analysis 73-Temperature hybrid time in range 1,37699.1, s
IDE80074-ENG127870,Analysis 74-Temperature hybrid time in range 2,0.0, s
IDE80075-ENG127871,Analysis 75-Temperature hybrid time in range 3,0.0, s
IDE80076-ENG127872,Analysis 76-Temperature hybrid time in range 4,0.0, s
IDE80077-ENG127873,Analysis 77-Temperature hybrid time in range 5,0.0, s
IDE80080-ENG127878,Analysis 80-Temperature hybrid maximum,63, °C
IDE80081-ENG114824,Analysis 81-Clutch 1 temperature time in range 0,37671.4, s
IDE80082-ENG114820,Analysis 82-Clutch 1 temperature time in range 1,25.9, s
IDE80083-ENG114814,Analysis 83-Clutch 1 temperature time in range 2,2.2, s
IDE80084-ENG114813,Analysis 84-Clutch 1 temperature time in range 3,0.0, s
IDE80088-ENG111618,Analysis 88-Clutch 1 temperature maximum,140, °C
IDE80089-ENG114807,Analysis 89-Clutch 2 temperature time in range 0,37699.9, s
IDE80090-ENG114811,Analysis 90-Clutch 2 temperature time in range 1,0.0, s
IDE80091-ENG114805,Analysis 91-Clutch 2 temperature time in range 2,0.0, s
IDE80092-ENG114817,Analysis 92-Clutch 2 temperature time in range 3,0.0, s
IDE80096-ENG111619,Analysis 96-Clutch 2 temperature maximum,85, °C
IDE80097-ENG06584,Analysis 97-Snapshot 1 electric motor actual current,0, A
IDE80097-ENG06583,Analysis 97-Snapshot 1 electric motor actual speed,0, /min
IDE80097-ENG06585,Analysis 97-Snapshot 1 electric motor actual state,???,
IDE80097-ENG06582,Analysis 97-Snapshot 1 electric motor commanded speed,0, /min
IDE80098-ENG06588,Analysis 98-Snapshot 2 electric motor actual current,0, A
IDE80098-ENG06587,Analysis 98-Snapshot 2 electric motor actual speed,0, /min
IDE80098-ENG06589,Analysis 98-Snapshot 2 electric motor actual state,???,
IDE80098-ENG06586,Analysis 98-Snapshot 2 electric motor commanded speed,0, /min
IDE80101-ENG102219,Analysis 101-Betriebszeit Motor (Drehzahlbereich 1),1.8, H
IDE80101-ENG103682,Analysis 101-Betriebszeit Motor (Drehzahlbereich 2),0.3, H
IDE80101-ENG101200,Analysis 101-Betriebszeit Motor (Drehzahlbereich 3),0.0, H
IDE80101-ENG100226,Analysis 101-Betriebszeit Motor (Drehzahlbereich 4),0.0, H
IDE80101-ENG102223,Analysis 101-Betriebszeit Motor (Drehzahlbereich 5),0.0, H
IDE80102-ENG102381,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 1-Gang,125,
IDE80102-ENG99964,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 2-Gang,246,
IDE80102-ENG100231,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 3-Gang,240,
IDE80102-ENG104160,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 4-Gang,195,
IDE80102-ENG102663,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 5-Gang,162,
IDE80102-ENG99465,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 6-Gang,80,
IDE80102-ENG103205,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 7-Gang,0,
IDE80102-ENG103678,Analysis 102-Anzahl erfolgreiche Einlegevorgänge R-Gang,81,
IDE80103-ENG103574,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 1-Gang,2,
IDE80103-ENG103754,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 2-Gang,5,
IDE80103-ENG99560,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 3-Gang,2,
IDE80103-ENG101116,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 4-Gang,2,
IDE80103-ENG99083,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 5-Gang,3,
IDE80103-ENG99508,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 6-Gang,0,
IDE80103-ENG101966,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 7-Gang,0,
IDE80103-ENG103519,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge R-Gang,8,
IDE80104-ENG100464,Analysis 104-Anzahl Gangspringer 1-Gang,0,
IDE80104-ENG103518,Analysis 104-Anzahl Gangspringer 2-Gang,0,
IDE80104-ENG101484,Analysis 104-Anzahl Gangspringer 3-Gang,0,
IDE80104-ENG102434,Analysis 104-Anzahl Gangspringer 4-Gang,0,
IDE80104-ENG100828,Analysis 104-Anzahl Gangspringer 5-Gang,0,
IDE80104-ENG99747,Analysis 104-Anzahl Gangspringer 6-Gang,0,
IDE80104-ENG102967,Analysis 104-Anzahl Gangspringer 7-Gang,0,
IDE80104-ENG100893,Analysis 104-Anzahl Gangspringer R-Gang,0,
IDE80105-ENG100707,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 1),10.5, H
IDE80105-ENG101697,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 2),0.0, H
IDE80105-ENG100556,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 3),0.0, H
IDE80105-ENG100205,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 4),0.0, H
IDE80106-ENG103428,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 1),10.5, H
IDE80106-ENG101321,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 2),0.0, H
IDE80106-ENG100639,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 3),0.0, H
IDE80106-ENG103433,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 4),0.0, H
IDE80107-ENG101291,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 1),0.4, H
IDE80107-ENG104169,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 2),0.2, H
IDE80107-ENG100021,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 3),0.0, H
IDE80107-ENG101292,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 4),0.0, H
IDE80107-ENG99418,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 5),0.0, H
IDE80108-ENG99240,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 1),0.5, H
IDE80108-ENG99973,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 2),0.2, H
IDE80108-ENG103238,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 3),0.0, H
IDE80108-ENG101007,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 4),0.0, H
IDE80108-ENG101190,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 5),0.0, H
IDE80260-ENG127862,Pressure supply: act. press.-Pressure supply actual pressure,49.54, bar
IDE80261-ENG127834,Pressure supply: act. press.: AD value-Pressure supply actual pressure AD value,2767,
IDE80262-ENG127829,Pressure supply: spec. RPM-Pressure supply commanded speed,220, /min
IDE80263-ENG127885,Pressure supply: act. RPM-Pressure supply actual speed,221, /min
IDE80265-ENG127855,Pressure supply: act. current-Pressure supply actual current,160.0, mA
IDE80267-ENG127877,Pressure supply: act. condition-Pressure supply actual state,7,
IDE80269-ENG127893,Pressure supply: last error condition of driver-Pressure supply last driver state,0,
IDE80276-ENG127854,Current vehicle odometer reading-Current vehicle mileage,78, km
IDE80277-ENG127828,Neutral due to driver's workplace oper: veh odom.read.-Driver registration procedure condition vehicle mileage,0, km
IDE80278-ENG127882,Driver logon procedure: vehicle odometer reading-Driver registration procedure vehicle mileage,0, km
IDE80279-ENG127826,Driver logon procedure: cause-Driver registration procedure cause,32,
IDE80280-ENG127827,Driver logon procedure: wave-Driver registration procedure shaft,0,
IDE80282-ENG114823,Clutch 1 Adaption basic charac. point 0 moment-Clutch 1 adaption basic characteristic point 0 torque,0.0, Nm
IDE80283-ENG114819,Clutch 1 Adaption basic charac. point 1 moment-Clutch 1 adaption basic characteristic point 1 torque,100.0, Nm
IDE80284-ENG114822,Clutch 1 Adaption basic charac. point 2 moment-Clutch 1 adaption basic characteristic point 2 torque,400.0, Nm
IDE80285-ENG114815,Clutch 1 Adaption basic charac. point 3 moment-Clutch 1 adaption basic characteristic point 3 torque,500.0, Nm
IDE80287-ENG127832,Clutch 1 Friction value correction factor-Clutch 1 frictional correction factor,100.0, %
IDE80288-ENG114818,Clutch 1 Characteristic line shift-Clutch 1 characteristic shift,0.00, mm
IDE80289-ENG114806,Clutch 2 Adaption basic charac. point 0 moment-Clutch 2 adaption basic characteristic point 0 torque,0.0, Nm
IDE80290-ENG114810,Clutch 2 Adaption basic charac. point 1 moment-Clutch 2 adaption basic characteristic point 1 torque,100.0, Nm
IDE80291-ENG114821,Clutch 2 Adaption basic charac. point 2 moment-Clutch 2 adaption basic characteristic point 2 torque,400.0, Nm
IDE80292-ENG114809,Clutch 2 Adaption basic charac. point 3 moment-Clutch 2 adaption basic characteristic point 3 torque,500.0, Nm
IDE80294-ENG127876,Clutch 2 Friction value correction factor-Clutch 2 frictional correction factor,100.0, %
IDE80295-ENG114808,Clutch 2 Characteristic line shift-Clutch 2 characteristic shift,0.00, mm
IDE80296-ENG127853,Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter,8,
IDE80297-ENG127883,Clutch 1 Adaption kiss point part 1: vehicle odometer reading-Clutch 1 adaption part 1 vehicle mileage,70, km
IDE80298-ENG127880,Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter,10,
IDE80299-ENG127884,Clutch 2 Adaption kiss point part 1: vehicle odometer reading-Clutch 2 adaption part 1 vehicle mileage,70, km
IDE80303-ENG127833,Overall software description-Software full name,H16,
IDE80305-ENG125922,Parameter set description-Data set name,0DD300046G_1601_NJBE,
IDE80307-ENG127879,Clutch 1 Adaption kiss point part 1: remaining fast adaptations-Clutch 1 adaption part 1 remaining fastadaptions,2,
IDE80308-ENG127881,Clutch 2 Adaption kiss point part 1: remaining fast adaptations-Clutch 2 adaption part 1 remaining fastadaptions,0,
IDE80313-ENG127174,Transmission identification DQ400e-Baugruppennummer,006,
IDE80313-ENG98612,Transmission identification DQ400e-Date of manufacture,171107,
IDE80313-ENG112382,Transmission identification DQ400e-Index,  ,
IDE80313-ENG126635,Transmission identification DQ400e-Kennbuchstabe,TEB,
IDE80313-ENG120774,Transmission identification DQ400e-Lfd. Nr. pro Tag,0165,
IDE80313-ENG120775,Transmission identification DQ400e-Linienkennung,G01,
IDE80313-ENG126634,Transmission identification DQ400e-Standort,K,
IDE80313-ENG126633,Transmission identification DQ400e-VW-Teilenummer,0DD300046G,
IDE80314-ENG127917,Clutch 0 Adaption vehicle odometer reading-Clutch 0 adaption vehicle mileage,70, km
ENG98625-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,OK,
ENG100091,Ambient temperature,4, °C
ENG130270-ENG130289,Ausgabe der Abschalt- und Resetdaten 1-aktiver Fehler,0,
ENG130270-ENG130284,Ausgabe der Abschalt- und Resetdaten 1-Call-Stack-Element 0,00 00 00 00,
ENG130270-ENG130285,Ausgabe der Abschalt- und Resetdaten 1-Call-Stack-Element 1,00 00 00 00,
ENG130270-ENG130286,Ausgabe der Abschalt- und Resetdaten 1-Call-Stack-Element 2,00 00 00 00,
ENG130270-ENG130287,Ausgabe der Abschalt- und Resetdaten 1-Call-Stack-Element 3,00 00 00 00,
ENG130270-ENG130290,Ausgabe der Abschalt- und Resetdaten 1-erweiterte Informationen zum aktiven Fehler,0,
ENG130270-ENG130283,Ausgabe der Abschalt- und Resetdaten 1-Gesamt-Software-Version,,
ENG130270-ENG130292,Ausgabe der Abschalt- und Resetdaten 1-gewichteter Resetzähler,0,
ENG130270-ENG130295,Ausgabe der Abschalt- und Resetdaten 1-Klemme 15-Spannung,51.0, V
ENG130270-ENG130296,Ausgabe der Abschalt- und Resetdaten 1-Klemme 30-Spannung,51.0, V
ENG130270-ENG130288,Ausgabe der Abschalt- und Resetdaten 1-kumulierte Fehlermaske,00 00 00 00,
ENG130270-ENG130297,Ausgabe der Abschalt- und Resetdaten 1-Mechatroniktemperatur,215, °C
ENG130270-ENG98689,Ausgabe der Abschalt- und Resetdaten 1-Odometer reading,655350, km
ENG130270-ENG130291,Ausgabe der Abschalt- und Resetdaten 1-Reset Quelle,0,
ENG130270-ENG112343,Ausgabe der Abschalt- und Resetdaten 1-Reset Status,0,
ENG130270-ENG130293,Ausgabe der Abschalt- und Resetdaten 1-Reset Typ,0,
ENG130270-ENG130294,Ausgabe der Abschalt- und Resetdaten 1-Status CHS-Abschaltung,0,
ENG130270-ENG130300,Ausgabe der Abschalt- und Resetdaten 1-Status des Eintrags,FF,
ENG130270-ENG130299,Ausgabe der Abschalt- und Resetdaten 1-Uds-Lesestatus des Eintrages,1,
ENG130270-ENG130298,Ausgabe der Abschalt- und Resetdaten 1-von Dksw uebergebene Fehlerdaten,255,
ENG130271-ENG130289,Ausgabe der Abschalt- und Resetdaten 2-aktiver Fehler,0,
ENG130271-ENG130284,Ausgabe der Abschalt- und Resetdaten 2-Call-Stack-Element 0,00 00 00 00,
ENG130271-ENG130285,Ausgabe der Abschalt- und Resetdaten 2-Call-Stack-Element 1,00 00 00 00,
ENG130271-ENG130286,Ausgabe der Abschalt- und Resetdaten 2-Call-Stack-Element 2,00 00 00 00,
ENG130271-ENG130287,Ausgabe der Abschalt- und Resetdaten 2-Call-Stack-Element 3,00 00 00 00,
ENG130271-ENG130290,Ausgabe der Abschalt- und Resetdaten 2-erweiterte Informationen zum aktiven Fehler,0,
ENG130271-ENG130283,Ausgabe der Abschalt- und Resetdaten 2-Gesamt-Software-Version,,
ENG130271-ENG130292,Ausgabe der Abschalt- und Resetdaten 2-gewichteter Resetzähler,0,
ENG130271-ENG130295,Ausgabe der Abschalt- und Resetdaten 2-Klemme 15-Spannung,51.0, V
ENG130271-ENG130296,Ausgabe der Abschalt- und Resetdaten 2-Klemme 30-Spannung,51.0, V
ENG130271-ENG130288,Ausgabe der Abschalt- und Resetdaten 2-kumulierte Fehlermaske,00 00 00 00,
ENG130271-ENG130297,Ausgabe der Abschalt- und Resetdaten 2-Mechatroniktemperatur,215, °C
ENG130271-ENG98689,Ausgabe der Abschalt- und Resetdaten 2-Odometer reading,655350, km
ENG130271-ENG130291,Ausgabe der Abschalt- und Resetdaten 2-Reset Quelle,0,
ENG130271-ENG112343,Ausgabe der Abschalt- und Resetdaten 2-Reset Status,0,
ENG130271-ENG130293,Ausgabe der Abschalt- und Resetdaten 2-Reset Typ,0,
ENG130271-ENG130294,Ausgabe der Abschalt- und Resetdaten 2-Status CHS-Abschaltung,0,
ENG130271-ENG130300,Ausgabe der Abschalt- und Resetdaten 2-Status des Eintrags,FF,
ENG130271-ENG130299,Ausgabe der Abschalt- und Resetdaten 2-Uds-Lesestatus des Eintrages,1,
ENG130271-ENG130298,Ausgabe der Abschalt- und Resetdaten 2-von Dksw uebergebene Fehlerdaten,255,
ENG130272-ENG130289,Ausgabe der Abschalt- und Resetdaten 3-aktiver Fehler,0,
ENG130272-ENG130284,Ausgabe der Abschalt- und Resetdaten 3-Call-Stack-Element 0,00 00 00 00,
ENG130272-ENG130285,Ausgabe der Abschalt- und Resetdaten 3-Call-Stack-Element 1,00 00 00 00,
ENG130272-ENG130286,Ausgabe der Abschalt- und Resetdaten 3-Call-Stack-Element 2,00 00 00 00,
ENG130272-ENG130287,Ausgabe der Abschalt- und Resetdaten 3-Call-Stack-Element 3,00 00 00 00,
ENG130272-ENG130290,Ausgabe der Abschalt- und Resetdaten 3-erweiterte Informationen zum aktiven Fehler,0,
ENG130272-ENG130283,Ausgabe der Abschalt- und Resetdaten 3-Gesamt-Software-Version,,
ENG130272-ENG130292,Ausgabe der Abschalt- und Resetdaten 3-gewichteter Resetzähler,0,
ENG130272-ENG130295,Ausgabe der Abschalt- und Resetdaten 3-Klemme 15-Spannung,51.0, V
ENG130272-ENG130296,Ausgabe der Abschalt- und Resetdaten 3-Klemme 30-Spannung,51.0, V
ENG130272-ENG130288,Ausgabe der Abschalt- und Resetdaten 3-kumulierte Fehlermaske,00 00 00 00,
ENG130272-ENG130297,Ausgabe der Abschalt- und Resetdaten 3-Mechatroniktemperatur,215, °C
ENG130272-ENG98689,Ausgabe der Abschalt- und Resetdaten 3-Odometer reading,655350, km
ENG130272-ENG130291,Ausgabe der Abschalt- und Resetdaten 3-Reset Quelle,0,
ENG130272-ENG112343,Ausgabe der Abschalt- und Resetdaten 3-Reset Status,0,
ENG130272-ENG130293,Ausgabe der Abschalt- und Resetdaten 3-Reset Typ,0,
ENG130272-ENG130294,Ausgabe der Abschalt- und Resetdaten 3-Status CHS-Abschaltung,0,
ENG130272-ENG130300,Ausgabe der Abschalt- und Resetdaten 3-Status des Eintrags,FF,
ENG130272-ENG130299,Ausgabe der Abschalt- und Resetdaten 3-Uds-Lesestatus des Eintrages,1,
ENG130272-ENG130298,Ausgabe der Abschalt- und Resetdaten 3-von Dksw uebergebene Fehlerdaten,255,
ENG130273-ENG130289,Ausgabe der Abschalt- und Resetdaten 4-aktiver Fehler,0,
ENG130273-ENG130284,Ausgabe der Abschalt- und Resetdaten 4-Call-Stack-Element 0,00 00 00 00,
ENG130273-ENG130285,Ausgabe der Abschalt- und Resetdaten 4-Call-Stack-Element 1,00 00 00 00,
ENG130273-ENG130286,Ausgabe der Abschalt- und Resetdaten 4-Call-Stack-Element 2,00 00 00 00,
ENG130273-ENG130287,Ausgabe der Abschalt- und Resetdaten 4-Call-Stack-Element 3,00 00 00 00,
ENG130273-ENG130290,Ausgabe der Abschalt- und Resetdaten 4-erweiterte Informationen zum aktiven Fehler,0,
ENG130273-ENG130283,Ausgabe der Abschalt- und Resetdaten 4-Gesamt-Software-Version,,
ENG130273-ENG130292,Ausgabe der Abschalt- und Resetdaten 4-gewichteter Resetzähler,0,
ENG130273-ENG130295,Ausgabe der Abschalt- und Resetdaten 4-Klemme 15-Spannung,51.0, V
ENG130273-ENG130296,Ausgabe der Abschalt- und Resetdaten 4-Klemme 30-Spannung,51.0, V
ENG130273-ENG130288,Ausgabe der Abschalt- und Resetdaten 4-kumulierte Fehlermaske,00 00 00 00,
ENG130273-ENG130297,Ausgabe der Abschalt- und Resetdaten 4-Mechatroniktemperatur,215, °C
ENG130273-ENG98689,Ausgabe der Abschalt- und Resetdaten 4-Odometer reading,655350, km
ENG130273-ENG130291,Ausgabe der Abschalt- und Resetdaten 4-Reset Quelle,0,
ENG130273-ENG112343,Ausgabe der Abschalt- und Resetdaten 4-Reset Status,0,
ENG130273-ENG130293,Ausgabe der Abschalt- und Resetdaten 4-Reset Typ,0,
ENG130273-ENG130294,Ausgabe der Abschalt- und Resetdaten 4-Status CHS-Abschaltung,0,
ENG130273-ENG130300,Ausgabe der Abschalt- und Resetdaten 4-Status des Eintrags,FF,
ENG130273-ENG130299,Ausgabe der Abschalt- und Resetdaten 4-Uds-Lesestatus des Eintrages,1,
ENG130273-ENG130298,Ausgabe der Abschalt- und Resetdaten 4-von Dksw uebergebene Fehlerdaten,255,
ENG130274-ENG130289,Ausgabe der Abschalt- und Resetdaten 5-aktiver Fehler,0,
ENG130274-ENG130284,Ausgabe der Abschalt- und Resetdaten 5-Call-Stack-Element 0,00 00 00 00,
ENG130274-ENG130285,Ausgabe der Abschalt- und Resetdaten 5-Call-Stack-Element 1,00 00 00 00,
ENG130274-ENG130286,Ausgabe der Abschalt- und Resetdaten 5-Call-Stack-Element 2,00 00 00 00,
ENG130274-ENG130287,Ausgabe der Abschalt- und Resetdaten 5-Call-Stack-Element 3,00 00 00 00,
ENG130274-ENG130290,Ausgabe der Abschalt- und Resetdaten 5-erweiterte Informationen zum aktiven Fehler,0,
ENG130274-ENG130283,Ausgabe der Abschalt- und Resetdaten 5-Gesamt-Software-Version,,
ENG130274-ENG130292,Ausgabe der Abschalt- und Resetdaten 5-gewichteter Resetzähler,0,
ENG130274-ENG130295,Ausgabe der Abschalt- und Resetdaten 5-Klemme 15-Spannung,51.0, V
ENG130274-ENG130296,Ausgabe der Abschalt- und Resetdaten 5-Klemme 30-Spannung,51.0, V
ENG130274-ENG130288,Ausgabe der Abschalt- und Resetdaten 5-kumulierte Fehlermaske,00 00 00 00,
ENG130274-ENG130297,Ausgabe der Abschalt- und Resetdaten 5-Mechatroniktemperatur,215, °C
ENG130274-ENG98689,Ausgabe der Abschalt- und Resetdaten 5-Odometer reading,655350, km
ENG130274-ENG130291,Ausgabe der Abschalt- und Resetdaten 5-Reset Quelle,0,
ENG130274-ENG112343,Ausgabe der Abschalt- und Resetdaten 5-Reset Status,0,
ENG130274-ENG130293,Ausgabe der Abschalt- und Resetdaten 5-Reset Typ,0,
ENG130274-ENG130294,Ausgabe der Abschalt- und Resetdaten 5-Status CHS-Abschaltung,0,
ENG130274-ENG130300,Ausgabe der Abschalt- und Resetdaten 5-Status des Eintrags,FF,
ENG130274-ENG130299,Ausgabe der Abschalt- und Resetdaten 5-Uds-Lesestatus des Eintrages,1,
ENG130274-ENG130298,Ausgabe der Abschalt- und Resetdaten 5-von Dksw uebergebene Fehlerdaten,255,
ENG99187,CAN version,0,
ENG98482-ENG99180,Checksum of flash-Calibration Checksumme,8A F6 39 A9,
ENG98482-ENG100495,Checksum of flash-Cboot Checksumme,CA 94 05 82,
ENG98482-ENG100117,Checksum of flash-Checksumme ECU + CAL,4D F2 03 55,
ENG98482-ENG102221,Checksum of flash-ECU Checksumme,3E 38 87 83,
ENG101012,Clutch 1 adaption basic characteristic point 0 position,6.84, bar
ENG102187,Clutch 1 adaption basic characteristic point 1 position,13.00, bar
ENG99501,Clutch 1 adaption basic characteristic point 2 position,30.64, bar
ENG99792,Clutch 1 adaption basic characteristic point 3 position,40.00, bar
ENG110529,Clutch 1 adaption kiss point part 1 fault cause,08 F8 10 00,
ENG110528,Clutch 1 adaption kiss point part 1 fault cause cumulative,08 F8 10 08,
ENG110530,Clutch 1 adaption kiss point part 1 fault counter,2,
ENG104250,Clutch 2 adaption basic characteristic point 0 position,7.42, bar
ENG100941,Clutch 2 adaption basic characteristic point 1 position,13.95, bar
ENG99957,Clutch 2 adaption basic characteristic point 2 position,31.72, bar
ENG99481,Clutch 2 adaption basic characteristic point 3 position,40.00, bar
ENG110535,Clutch 2 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110534,Clutch 2 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110536,Clutch 2 adaption kiss point part 1 fault counter,0,
ENG102882,Clutch adaptation kiss-point fast adaptation remaining km tr,0, km
ENG103186,Clutch center central plate temperature,21, °C
ENG99212,Common highside 1 specified condition,Common Highside soll eingeschaltet werden,
ENG99878,Common highside 2 specified condition,Common Highside soll eingeschaltet werden,
ENG103403,Converter Loss Torque,0.0, Nm
ENG100625,Coolant temperature,9, °C
ENG26438-ENG36192,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet,2.0, mJ
ENG26438-ENG36193,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet HR,461306.5, J
ENG26438-ENG36194,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet,2.0, mJ
ENG26438-ENG36195,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet HR,461306.5, J
ENG26438-ENG30210,Daten des Lebensdauermodells der K1-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG26439-ENG36192,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet,2.5, mJ
ENG26439-ENG36193,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet HR,110486.1, J
ENG26439-ENG36194,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet,2.5, mJ
ENG26439-ENG36195,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet HR,110486.1, J
ENG26439-ENG30210,Daten des Lebensdauermodells der K2-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG104016,Designation VWDQ-Lib,H15C02,
ENG98602,Driver request torque,-26.0, Nm
ENG100746,Driving strategy: sport factor,0.0, %
ENG122353-ENG122493,Einfachsynchronisationszählerstände Klasse 1-1-Gang,0,
ENG122353-ENG122494,Einfachsynchronisationszählerstände Klasse 1-2-Gang,0,
ENG122353-ENG122495,Einfachsynchronisationszählerstände Klasse 1-3-Gang,0,
ENG122353-ENG122496,Einfachsynchronisationszählerstände Klasse 1-4-Gang,0,
ENG122353-ENG122497,Einfachsynchronisationszählerstände Klasse 1-5-Gang,0,
ENG122353-ENG122498,Einfachsynchronisationszählerstände Klasse 1-6-Gang,0,
ENG122353-ENG122499,Einfachsynchronisationszählerstände Klasse 1-7-Gang,0,
ENG122353-ENG108465,Einfachsynchronisationszählerstände Klasse 1-R-Gang,0,
ENG122354-ENG122493,Einfachsynchronisationszählerstände Klasse 2-1-Gang,0,
ENG122354-ENG122494,Einfachsynchronisationszählerstände Klasse 2-2-Gang,0,
ENG122354-ENG122495,Einfachsynchronisationszählerstände Klasse 2-3-Gang,0,
ENG122354-ENG122496,Einfachsynchronisationszählerstände Klasse 2-4-Gang,0,
ENG122354-ENG122497,Einfachsynchronisationszählerstände Klasse 2-5-Gang,0,
ENG122354-ENG122498,Einfachsynchronisationszählerstände Klasse 2-6-Gang,0,
ENG122354-ENG122499,Einfachsynchronisationszählerstände Klasse 2-7-Gang,0,
ENG122354-ENG108465,Einfachsynchronisationszählerstände Klasse 2-R-Gang,0,
ENG122355-ENG122493,Einfachsynchronisationszählerstände Klasse 3-1-Gang,0,
ENG122355-ENG122494,Einfachsynchronisationszählerstände Klasse 3-2-Gang,0,
ENG122355-ENG122495,Einfachsynchronisationszählerstände Klasse 3-3-Gang,0,
ENG122355-ENG122496,Einfachsynchronisationszählerstände Klasse 3-4-Gang,0,
ENG122355-ENG122497,Einfachsynchronisationszählerstände Klasse 3-5-Gang,0,
ENG122355-ENG122498,Einfachsynchronisationszählerstände Klasse 3-6-Gang,0,
ENG122355-ENG122499,Einfachsynchronisationszählerstände Klasse 3-7-Gang,0,
ENG122355-ENG108465,Einfachsynchronisationszählerstände Klasse 3-R-Gang,0,
ENG127824-ENG127910,Electrical_oil_pump_teach_in_parameters-Cosinus Amplitude Korreturwert,554,
ENG127824-ENG127908,Electrical_oil_pump_teach_in_parameters-Cosinus Offset Korrekturwert,2029,
ENG127824-ENG127911,Electrical_oil_pump_teach_in_parameters-Cosinus Offset Korrekturwert 1,0,
ENG127824-ENG127912,Electrical_oil_pump_teach_in_parameters-Cosinus Offset Korrekturwert 2,0,
ENG127824-ENG127909,Electrical_oil_pump_teach_in_parameters-Sinus Amplitude Korrekturwert,552,
ENG127824-ENG127907,Electrical_oil_pump_teach_in_parameters-Sinus Offset Korrekturwert,2020,
ENG127824-ENG127913,Electrical_oil_pump_teach_in_parameters-Sinus Offset Korrekturwert 1,0,
ENG127824-ENG127914,Electrical_oil_pump_teach_in_parameters-Sinus Offset Korrekturwert 2,0,
ENG127824-ENG127905,Electrical_oil_pump_teach_in_parameters-Verhältnis Cosinus / Sinus Amplitude,1.00362,
ENG127824-ENG53351,Electrical_oil_pump_teach_in_parameters-Verhältnis Cosinus / Sinus Amplitude 1,0.00000,
ENG127824-ENG53232,Electrical_oil_pump_teach_in_parameters-Verhältnis Cosinus / Sinus Amplitude 2,0.00000,
ENG127824-ENG127906,Electrical_oil_pump_teach_in_parameters-Wert Winkelkorrektur,141.96417,
ENG127824-ENG53208,Electrical_oil_pump_teach_in_parameters-Wert Winkelkorrektur 1,0.00000,
ENG127824-ENG53345,Electrical_oil_pump_teach_in_parameters-Wert Winkelkorrektur 2,0.00000,
ENG101251,Empty,Empty,
ENG99932,Engine coding info,19,
ENG98756,Engine torque,27.0, Nm
ENG104230,Engine torque loss,27.0, Nm
ENG106287-ENG104036,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 1,140, °C
ENG106287-ENG103379,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 2,85, °C
ENG123019-ENG99024,Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission,0.0, km/h
ENG100414,Gangsteller A Adaption Neutralposition,-0.3, mm
ENG100089,Gangsteller B Adaption Neutralposition,0.1, mm
ENG103055,Gangsteller C Adaption Neutralposition,-0.4, mm
ENG101354,Gangsteller D Adaption Neutralposition,-0.1, mm
ENG110510,Gear actuator adaption engaged position G1,8.4, mm
ENG110511,Gear actuator adaption engaged position G2,-8.5, mm
ENG110512,Gear actuator adaption engaged position G3,-8.2, mm
ENG99484,Gear actuator adaption engaged position G4,8.1, mm
ENG110513,Gear actuator adaption engaged position G5,8.0, mm
ENG110514,Gear actuator adaption engaged position G6,8.5, mm
ENG110516,Gear actuator adaption engaged position GR,-8.2, mm
ENG110517,Gear actuator adaption synchro position G1,2.3, mm
ENG110518,Gear actuator adaption synchro position G2,-2.8, mm
ENG110519,Gear actuator adaption synchro position G3,-2.5, mm
ENG99198,Gear actuator adaption synchro position G4,2.2, mm
ENG110520,Gear actuator adaption synchro position G5,1.6, mm
ENG110521,Gear actuator adaption synchro position G6,3.1, mm
ENG110523,Gear actuator adaption synchro position GR,-2.4, mm
ENG99720,Height info,1003, mbar
ENG98604,Hill factor driving strategy,0.0, %
ENG99596,Indicated engine torque without external interventions,26.0, Nm
ENG99582,Intake air temperature,15, °C
ENG110556-ENG110541,Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung,0,
ENG110556-ENG110542,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß,0,
ENG110556-ENG110543,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein,0,
ENG110556-ENG120771,Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen,0,
ENG110557-ENG110545,Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung,0,
ENG110557-ENG110546,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß,0,
ENG110557-ENG110547,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein,0,
ENG110557-ENG110544,Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen,0,
ENG111613-ENG101555,Motordrehmoment Begrenzung-Engine torque limitation,0.0, Nm
ENG104079,Odometer state: last chng GE clutch mov press. char. curve,-1, km
ENG105329-ENG101124,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1),0.0, H
ENG105329-ENG100216,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2),10.5, H
ENG105329-ENG103067,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3),0.0, H
ENG105329-ENG101168,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4),0.0, H
ENG105329-ENG104150,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5),0.0, H
ENG105329-ENG100130,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6),0.0, H
ENG100188,Reached maximum temperature control module,63, °C
ENG123020-ENG102793,Rollwiderstand-Road Resistance,-0.7, %
ENG103000,Run time complete system,10.4777, H
ENG102748,Selector lever error flags,00 00,
ENG101057,Specified idle speed,0, /min
ENG100803,Speed: output,0, /min
ENG100141,Transmission coding info,23,
ENG103964,Veh. odometer state: last change of GE gear selector data,0, km
ENG101346,Version info driving strategy,FEJRMRBEB.039,
ENG109005,Voltage Common Highside 1,13.2, V
ENG99955,Voltage Common Highside 2,13.2, V
Elapsed Time: 00:36
Andy
Sector 7G
HC424490
03-ABS Brakes maps
;SW:5Q0-614-517-BL   HW:5Q0-614-517-AH ---  ABS Brakes
;Component:ESC           H62 0855, Coding:12FF40923826226F897B0A07A1CB2948021C44915085947218A1505482A802
;EV_Brake1UDSContiMK100OMG,003019,EV_Brake1UDSContiMK100OMG_003_AU37.rod
;Friday,08,December,2017,16:06:28:29905
;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
;VCID: 7CBB77BBF79FB6CA9A7-8028
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,not activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03493-Driver door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-Electromechanical parking brake,not activated ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire pressure monitoring display,2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05337-Starting vibration reduction-,normal ,1
IDE05337-MAS02653-Starting vibration reduction-Torque limitation,Deactivated ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,1 ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
IDE12030-Rough road optimization,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,activated ,1
ENG118148-Developer_Function_1,0 ,1
ENG130301-Developer_Function_121,not activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,6 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,8 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,12 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,6 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,6 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,8 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,12 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,80 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
Elapsed Time: 00:13
;Friday,08,December,2017,16:06:11:29905
Group,Description,Actual
IDE00019,Voltage terminal 30,13.037, V
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,14, °C
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator position,14.5, %
IDE00097-ENG101171,OBD - requirements for which this vehicle is designed-OBD requirements to which vehicle or engine is certified,USOBD,
IDE00601,Monitoring status since erasing DTC memory,00 04 00 00,
IDE00602,Monitoring status in current driving cycle,00 04 00 00,
IDE00609-MAS01155,Communication status of data bus 1-Control module,Engine Control Module 1,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,active,
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,ERROR,
IDE02270-IDE02713,CAN input signal(s) status-Brake Light Switch,not activated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,closed,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up light,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,FF63478,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency brake display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,-0.12500, m/s²
IDE02492,Start-stop function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,indicator lights-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,indicator lights-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,indicator lights--AUTO HOLD- Indicator Lamp,Not available due to specific system,
IDE02986-IDE04771,indicator lights-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,indicator lights-ABS indicator lamp,OFF,
IDE02986-MAS00556,indicator lights-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,indicator lights-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,indicator lights-Brake system indicator lamp,OFF,
IDE02986-MAS03234,indicator lights-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS04513,Stop process prevented-Brake control module pump operation,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-Brake control module pump operation,16,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,1,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,17,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2000,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,3,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,8,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,3,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,62,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,3,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,8,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,3,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,62,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Freescale,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,23,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.005, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,13.015, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-1, mbar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.10, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake Light Switch,not activated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,ERROR,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,65535, mm
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Front right wheel speed,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,65535, mm
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,65535, mm
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forwards,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,65535, mm
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forwards,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,ÿÿÿÿÿÿ,
IDE04442-IDE00010,Vacuum sensor-Serial number,FF FF FF FF FF,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,Available,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,0,
IDE04442,Vacuum sensor,-1, mbar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,0,
IDE04443-IDE02241,Traction control system sensor-Lateral acceleration sensor 1,-0.16677, m/s²
IDE04443-IDE02538,Traction control system sensor-Longitudinal acceleration sensor,-0.25506, m/s²
IDE04443-IDE04429,Traction control system sensor-Lateral acceleration sensor 1: offset,-0.09810, m/s²
IDE04443-IDE04430,Traction control system sensor-Longitudinal acceleration sensor: offset,-0.12500, m/s²
IDE04443-IDE04449,Traction control system sensor-Rotation rate sensor 1: Z-axis,0.017, °/s
IDE04443-IDE04460,Traction control system sensor-Steering angle sensor: offset straight line running,0.000, °
IDE04443-MAS00815,Traction control system sensor-Steering angle sensor,4.681, °
IDE04446-IDE01599,Hill descent control-Slope,0, %
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,not activated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not available due to specific system,
IDE04452-IDE03664,Brake system button-Button for driving program,not activated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,not activated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,not activated,
IDE04456-IDE02955,Brake disk drying-System status,Available,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,0, km
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MY3RAH00024,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,not completed successfully,
IDE04461-MAS01481,Internal measured values-Temperature in control module,13, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAB00008,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not recognized,
IDE04508-IDE02955,Hydraulic brake booster-System status,Available,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,ERROR,
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.10, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,0, mbar
IDE04508-MAS11246,Hydraulic brake booster-Duration of active control,0,
IDE04644-IDE02955,Roll-over protection-System status,Not available due to specific system,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,performed,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,Enabled,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,Enabled,
IDE04645-IDE02955,Electromechanical parking brake-System status,Available,
IDE04645-IDE03493,Electromechanical parking brake-Driver door status,Enabled,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,Enabled,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,Enabled,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,Enabled,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,Enabled,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04646-IDE02657,Electromechanical parking brake: parking brake motors-Cut-off current: left: reached,0.00, A
IDE04646-IDE02658,Electromechanical parking brake: parking brake motors-Cut-off current: right: reached,0.00, A
IDE04646-IDE04496,Electromechanical parking brake: parking brake motors-Left parking brake motor: status,closed,
IDE04646-IDE04497,Electromechanical parking brake: parking brake motors-Right parking brake motor: status,closed,
IDE04646-IDE04506,Electromechanical parking brake: parking brake motors-Calculated left rear brake temperature,5.0, °C
IDE04646-IDE04507,Electromechanical parking brake: parking brake motors-Calculated right rear brake temperature,5.0, °C
IDE04646-IDE04647,Electromechanical parking brake: parking brake motors-Left parking brake motor: current,0.00, A
IDE04646-IDE04648,Electromechanical parking brake: parking brake motors-Right parking brake motor: current,0.00, A
IDE04646-IDE05048,Electromechanical parking brake: parking brake motors-Left parking brake motor: actuation counter,34,
IDE04646-IDE05049,Electromechanical parking brake: parking brake motors-Right parking brake motor: actuation counter,34,
IDE04765-IDE02955,Counter steer support-System status,Available,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,21, km
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,On,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04871-IDE01599,Dynamic starting assist-Slope,-1, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Act.val.,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),0, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire pressure monitoring display-System status,Available,
IDE04939-IDE04248,Tire pressure monitoring display-Left front tire pressure diffusion indicator,254,
IDE04939-IDE04249,Tire pressure monitoring display-Right front tire pressure diffusion indicator,254,
IDE04939-IDE04250,Tire pressure monitoring display-Left rear tire pressure diffusion indicator,254,
IDE04939-IDE04251,Tire pressure monitoring display-Right rear tire pressure diffusion indicator,254,
IDE04939-IDE04432,Tire pressure monitoring display-Tire Pressure Monitoring Display Button,not activated,
IDE04939-IDE04946,Tire pressure monitoring display-Odometer reading at last adaptation,12, km
IDE04939-IDE04947,Tire pressure monitoring display-Odometer reading of last warning,0, km
IDE04939-MAS04538,Tire pressure monitoring display-Odometer reading two adaptations ago,3, km
IDE04939-MAS04539,Tire pressure monitoring display-Odometer reading three adaptations ago,3, km
IDE04939-MAS04540,Tire pressure monitoring display-Odometer reading four adaptations ago,0, km
IDE04939-MAS04541,Tire pressure monitoring display-Odometer reading of next-to-last warning,0, km
IDE04939-MAS04542,Tire pressure monitoring display-Odometer reading of third-to-last warning,0, km
IDE04939-MAS04543,Tire pressure monitoring display-Odometer reading of fourth-to-last warning,0, km
IDE04939-MAS04544,Tire pressure monitoring display-Left front flat tire indicator,255,
IDE04939-MAS04545,Tire pressure monitoring display-Right front flat tire indicator,249,
IDE04939-MAS04546,Tire pressure monitoring display-Left rear flat tire indicator,249,
IDE04939-MAS04547,Tire pressure monitoring display-Right rear flat tire indicator,249,
IDE05712-IDE02955,AUTO HOLD-System status,Not available due to specific system,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,valid,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,OFF,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,1933,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,49670,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,12,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,97,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2000,
IDE07280-MAS00107,Multiple collision brake-Month,3,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,12,
IDE07280-MAS00110,Multiple collision brake-Minutes,3,
IDE07280-MAS00111,Multiple collision brake-Seconds,63,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE09588-ENG103176,In use monitor performance ratio 1-General Denominator,6,
IDE09588-ENG102823,In use monitor performance ratio 1-Ignition Cycle Counter,73,
IDE09588-ENG100120,In use monitor performance ratio 1-Milage,70,
IDE09588-ENG102846,In use monitor performance ratio 1-Number of IUMPR Records,1,
IDE09589-ENG101817,In use monitor performance ratio 2-Denominator,3,
IDE09589-ENG103772,In use monitor performance ratio 2-DFCC Value,01 06,
IDE09589-ENG99150,In use monitor performance ratio 2-Numerator,4,
IDE09589-ENG101622,In use monitor performance ratio 2-Record Number,1,
IDE11490-MAS12826,Emergency brake request-current spec. press.,0,
IDE11490-MAS12827,Emergency brake request-Validity of emerg. brake request,invalid,
IDE11490-MAS12828,Emergency brake request-max. spec. pressure eBKV,0,
IDE80101,Analysis 101,A3 32 38 35 31 35 38 37 36 32 32 33 30 30 30 30 36 31 37 42 30 32 30 30 32 41 46 2F 02 36 1E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,99.9936, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,99.9936, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,98.0406, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,4,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,99.9936, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,3,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,100.384, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,2,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,101.165, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,4,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,Available,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,5.0, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,5.0, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,5.0, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,5.0, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake Light Switch,not activated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,Available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Available,
MAS00210-IDE80007,Parking Brake-Analysis 7,0, km
MAS00210-IDE80008,Parking Brake-Analysis 8,78, km
MAS00210-IDE80009,Parking Brake-Analysis 9,0, km
MAS00210-IDE80010,Parking Brake-Analysis 10,0, km
MAS00210-IDE80011,Parking Brake-Analysis 11,78, km
MAS00210-IDE80012,Parking Brake-Analysis 12,8F 0A 11 10 02 0C,
MAS00210-ENG36680,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG36681,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG36682,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG36683,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG36684,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG36685,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, %
MAS02138-IDE02955,Hill-start assistant-System status,Available,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,closed,
MAS02138-MAS03095,Hill-start assistant-Function status,not active,
MAS02426-MAS00580,Text display in instrument panel insert-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument panel insert-Text,0,
MAS02672-IDE02955,Start-stop-System status,Available,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,0,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,0,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,0,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,0,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,Available,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,Available,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG101413-ENG99697,Calibration Identification-Calibration Verification Number,5Q0517AH085524C,
ENG99697,Calibration Verification Number,01 B1 D7 8A B6,
ENG100152,ECUNAME,BSCM-BrakeSystem,
ENG109170,Sup PIDs ($01  - $20 )OBD - requ for which this veh is desig,98 18 00 01,
ENG103342-ENG109170,Sup PIDs ($21  - $40 )No. drv cyc since eras DTC mem-Sup PIDs ($01  - $20 )OBD - requ for which this veh is desig,00 00 00 01,
ENG100937-ENG109170,Sup PIDs ($41  - $60 ) time since eras DTC mem-Sup PIDs ($01  - $20 )OBD - requ for which this veh is desig,C0 80 00 00,
ENG109169-ENG109170,Supported INFOTYPEs ($01 - $20)-Sup PIDs ($01  - $20 )OBD - requ for which this veh is desig,14 40 00 00,
Elapsed Time: 00:16
Andy
Sector 7G
HC424490
05-Acc/Start Auth. maps
;SW:5Q0-959-435-C   HW:5Q0-959-435 ---  Acc/Start Auth.
;Component:VWKESSYMQB    021 0803, Coding:030C0C
;EV_KessyHellaMQBAB,002020,EV_KessyHellaMQBAB_002.rod
;Friday,08,December,2017,16:06:57:29905
;VCID: 3C3BB7BBB71F76CADA7-8068
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105803-ENG120037-DeveloperCoding: Key Minder (Byte 1)-Cyclic interior scan during active warning message "Key not found",not activated ,1
ENG105803-ENG101923-DeveloperCoding: Key Minder (Byte 1)-Retry handling big car / expanded search,activated ,1
ENG105803-ENG100928-DeveloperCoding: Key Minder (Byte 1)-Seat Memory: scan after driver door opening,not activated ,1
ENG105803-ENG99649-DeveloperCoding: Key Minder (Byte 1)-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
ENG105803-ENG99417-DeveloperCoding: Key Minder (Byte 1)-Softtouch mounted,installed ,1
ENG105804-ENG99123-DeveloperCoding: Key Minder (Byte 2)-Inhibit ID-transmitter for passive go,activated ,1
ENG105804-ENG102581-DeveloperCoding: Key Minder (Byte 2)-Lock prevention tailgate,not activated ,1
ENG105804-ENG101018-DeveloperCoding: Key Minder (Byte 2)-No locking with ID-transmitter last used interior,activated ,1
ENG105804-ENG103451-DeveloperCoding: Key Minder (Byte 2)-Re-open after passive comfort closing,activated ,1
ENG105804-ENG99711-DeveloperCoding: Key Minder (Byte 2)-Re-open last handling,ZV entriegeln ,1
ENG105804-ENG103237-DeveloperCoding: Key Minder (Byte 2)-Re-open tailgate,activated ,1
ENG105804-ENG104103-DeveloperCoding: Key Minder (Byte 2)-Send numbers of ID-transmitters interior (ELV-Scan),not activated ,1
ENG153804-ENG154598-DeveloperCoding: Miscellaneous 2-exeption_drivers_doors_interior_scan,activated ,1
ENG153804-ENG154691-DeveloperCoding: Miscellaneous 2-interior_scan_clamp_15_new_concept,activated ,1
ENG153804-ENG154710-DeveloperCoding: Miscellaneous 2-open_cabrio_canopy_interior_scan,not activated ,1
ENG105807-ENG121989-DeveloperCoding: Passiv Entry Exit (Byte 1)-Impairment Entry / Exit key on low battery,not activated ,1
ENG105807-ENG125240-DeveloperCoding: Passiv Entry Exit (Byte 1)-lf_crc,not activated ,1
ENG105807-ENG99763-DeveloperCoding: Passiv Entry Exit (Byte 1)-Passive Exit: access door not open,activated ,1
ENG105807-ENG103722-DeveloperCoding: Passiv Entry Exit (Byte 1)-Passive Exit: all doors not open,not activated ,1
ENG105808-ENG155267-DeveloperCoding: Passiv Entry Exit (Byte 2)-lf_shutdown,activated ,1
ENG105808-ENG155268-DeveloperCoding: Passiv Entry Exit (Byte 2)-lf_shutdown_gotrigger,not activated ,1
ENG105808-ENG148905-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry at door locked/safed OR ZV safed,activated ,1
ENG105808-ENG123039-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit,activated ,1
ENG105808-ENG103289-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG105808-ENG103620-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit: retry with antennastep 1,not activated ,1
ENG105808-ENG103529-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry: second control concept,not activated ,1
ENG105809-ENG114300-DeveloperCoding: Passiv Go-Change Go antenna at every request,not activated ,1
ENG105809-ENG114299-DeveloperCoding: Passiv Go-Change Go antenna during retry challenge,activated ,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG148896-DeveloperCoding: Proximity Sensor-Easy Trunk,not activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,Fahrertürgriff wird nicht abgeschaltet ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",Fehlerspeichereintrag wird nicht unterdrueckt ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG148895-DeveloperCoding: Search lights-ZAT active during clamp 58xt on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG105810-ENG120039-DeveloperCoding: Sonstiges-Backdoor TSG,not installed ,1
ENG105810-ENG103075-DeveloperCoding: Sonstiges-Battery manager mounted,activated ,1
ENG105810-ENG102728-DeveloperCoding: Sonstiges-Diagnostic: service 86 - response on event,not activated ,1
ENG105810-ENG98656-DeveloperCoding: Sonstiges-internal,not activated ,1
ENG105810-ENG102591-DeveloperCoding: Sonstiges-Response extension for scan procedure,not activated ,1
ENG105810-ENG99430-DeveloperCoding: Sonstiges-Scan Procedure: Timeoutcontrol active,activated ,1
ENG105810-ENG104010-DeveloperCoding: Sonstiges-Use default antenna data,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,installed ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,left-hand drive ,1
ENG105825-Diagnostic: wait time after power on,3000 ms,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
ENG98656-internal,0 B,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG153886-lf_shutdown_timeout_2nd_operation,5 s,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,14 B,1
ENG107595-MCTX settling phase,10 B,1
ENG108165-Passive Entry Exit: control by pulling the door handle during active DSL (timeout),2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,210 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG108580-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error (Go),190 ms,1
ENG108581-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error (Kombi),700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1
ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1
ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1
ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
ENG153754-ZAT_motor_signal_timer_1,3000 ms,1
ENG153755-ZAT_motor_signal_timer_2,3000 ms,1
ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1
ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1
ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1
ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1
Elapsed Time: 00:24
;Friday,08,December,2017,16:06:44:29905
IDE00019,Voltage terminal 30,13.159, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00030,Status of actuator test,ended,
IDE02406,Key number of last identified ID sensor,ID sensor 1,
IDE02407,Status of vehicle locking,Vehicle unlocked,
IDE02408-MAS00218,Individual door locking: status-Driver door,closed,
IDE02408-MAS00219,Individual door locking: status-Front Passenger Door,closed,
IDE02408-MAS00220,Individual door locking: status-Left rear door,closed,
IDE02408-MAS00221,Individual door locking: status-Right rear door,closed,
IDE02409,ID sensor 1 authentication: status,No response,
IDE02410,ID sensor 2 authentication: status,No response,
IDE02411,ID sensor 3 authentication: status,No response,
IDE02412,ID sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear exterior door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear exterior door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear exterior door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear exterior door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear exterior door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear exterior door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear exterior door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear exterior door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear exterior door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear exterior door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,160,
IDE02419,Proximity sensor frt.pass. door: number of triggers,96,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardwareversion,FF,
IDE02422-MAS01483,Driver door handle: version information-Softwareversion,FF,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,FF,
IDE02423-MAS01482,ass. door handle: version information-Hardwareversion,FF,
IDE02423-MAS01483,ass. door handle: version information-Softwareversion,FF,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,FF,
IDE02424-MAS01482,Left rear door handle: version information-Hardwareversion,FF,
IDE02424-MAS01483,Left rear door handle: version information-Softwareversion,FF,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,FF,
IDE02425-MAS01482,Right rear door handle: version information-Hardwareversion,FF,
IDE02425-MAS01483,Right rear door handle: version information-Softwareversion,FF,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,FF,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,Yes,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,No,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,Yes,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,No,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,Yes,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,No,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,No,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,No,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,Yes,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,Yes,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72-hour signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02484,72-hr signaling counter left rear door,0,
IDE02485,72-hr signaling counter right rear door,0,
IDE02486,Data logger triggering,not activated,
IDE02495-MAS00976,Service key: number of activations-Counter,35,
IDE02496-MAS00976,Service key: number of timeouts-Counter,0,
IDE02497-MAS00976,Service key: number of incomplete messages-Counter,0,
IDE03008-MAS05971,Stop process prevented-Missing message from Engine Control Module,0,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,0,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,1,
IDE03008-MAS06119,Stop process prevented-CAN signal: operation reader coil is set,0,
IDE03010-MAS05971,Number of prevented stop processes-Missing message from Engine Control Module,1,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,2,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,4,
IDE03010-MAS06119,Number of prevented stop processes-CAN signal: operation reader coil is set,3,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,1,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,9,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,8,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,7,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,1,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,13,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,1,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,1,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,0,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,13,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,29,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,25,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,5,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,8,
IDE03127,Prevented stop processes (ring memory),2,
IDE03127,Prevented stop processes (ring memory),4,
IDE03127,Prevented stop processes (ring memory),3,
IDE03212,Start-stop conditions,Stop prohibition: no start request,
IDE03213,Start-stop enabling,All releases are present,
IDE04042-ENG20505,ID sensor history data-Scan 1 Origin,UID Monitoring,
IDE04042-ENG104152,ID sensor history data-Scan 1 Single Scan,Interior with trunk,
IDE04042-ENG20412,ID sensor history data-Scan 1 Trigger,UID search,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,A2,
IDE04042-ENG20435,ID sensor history data-Scan 2 Origin,UID Monitoring,
IDE04042-ENG99359,ID sensor history data-Scan 2 Single Scan,Interior with trunk,
IDE04042-ENG20402,ID sensor history data-Scan 2 Trigger,UID search,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,A2,
IDE04042-ENG20483,ID sensor history data-Scan 3 Origin,Passive Go,
IDE04042-ENG102354,ID sensor history data-Scan 3 Single Scan,Interior with trunk,
IDE04042-ENG20414,ID sensor history data-Scan 3 Trigger,Go authentication request,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,62,
IDE05204,Manufacturing dates for driver door handle,FF FF FF FF FF,
IDE05205,Manufacturing dates for frt.pass. door handle,FF FF FF FF FF,
IDE05206,Manufacturing dates for left rear door handle,00 00 00 00 00,
IDE05207,Manufacturing dates for right rear door handle,00 00 00 00 00,
IDE07359,Dimming of starter button lighting,61 12,
ENG26926-MAS00106,lf_shutdowns-Year,2063,
ENG26926-MAS00107,lf_shutdowns-Month,3,
ENG26926-MAS00108,lf_shutdowns-Day,31,
ENG26926-MAS00109,lf_shutdowns-Hours,15,
ENG26926-MAS00110,lf_shutdowns-Minutes,3,
ENG26926-MAS00111,lf_shutdowns-Seconds,63,
ENG26926-ENG32070,lf_shutdowns-Mileage_lf_shutdown_n,16777215, km
ENG26926-ENG32071,lf_shutdowns-Mileage_lf_shutdown_n-1,16777215, km
ENG26926-ENG32072,lf_shutdowns-Mileage_lf_shutdown_n-2,16777215, km
ENG26926-ENG32073,lf_shutdowns-Mileage_lf_shutdown_n-3,16777215, km
ENG120048,Overtemperaturecounter for ADRIMA,0,
ENG26348-ENG129140,Scan_cycle_data-Car_key_1,00000000 ,
ENG26348-ENG129141,Scan_cycle_data-Car_key_2,00000000 ,
ENG26348-ENG129142,Scan_cycle_data-Car_key_3,00000000 ,
ENG26348-ENG129143,Scan_cycle_data-Car_key_4,00000000 ,
ENG26348-ENG30036,Scan_cycle_data-Mileage_n,78, km
ENG26348-ENG30037,Scan_cycle_data-Mileage_n-1,43, km
ENG26348-ENG30038,Scan_cycle_data-Mileage_n-10,0, km
ENG26348-ENG30039,Scan_cycle_data-Mileage_n-11,0, km
ENG26348-ENG30040,Scan_cycle_data-Mileage_n-12,0, km
ENG26348-ENG30041,Scan_cycle_data-Mileage_n-13,0, km
ENG26348-ENG30042,Scan_cycle_data-Mileage_n-14,0, km
ENG26348-ENG30043,Scan_cycle_data-Mileage_n-15,0, km
ENG26348-ENG30044,Scan_cycle_data-Mileage_n-16,0, km
ENG26348-ENG30045,Scan_cycle_data-Mileage_n-17,0, km
ENG26348-ENG30046,Scan_cycle_data-Mileage_n-18,0, km
ENG26348-ENG30047,Scan_cycle_data-Mileage_n-19,0, km
ENG26348-ENG30048,Scan_cycle_data-Mileage_n-2,0, km
ENG26348-ENG30049,Scan_cycle_data-Mileage_n-3,0, km
ENG26348-ENG30050,Scan_cycle_data-Mileage_n-4,0, km
ENG26348-ENG30051,Scan_cycle_data-Mileage_n-5,0, km
ENG26348-ENG30052,Scan_cycle_data-Mileage_n-6,0, km
ENG26348-ENG30053,Scan_cycle_data-Mileage_n-7,0, km
ENG26348-ENG30054,Scan_cycle_data-Mileage_n-8,0, km
ENG26348-ENG30055,Scan_cycle_data-Mileage_n-9,0, km
ENG26348-ENG30076,Scan_cycle_data-Retry_count_n,6,
ENG26348-ENG30078,Scan_cycle_data-Retry_count_n-1,6,
ENG26348-ENG30079,Scan_cycle_data-Retry_count_n-10,0,
ENG26348-ENG30080,Scan_cycle_data-Retry_count_n-11,0,
ENG26348-ENG30081,Scan_cycle_data-Retry_count_n-12,0,
ENG26348-ENG30082,Scan_cycle_data-Retry_count_n-13,0,
ENG26348-ENG30083,Scan_cycle_data-Retry_count_n-14,0,
ENG26348-ENG30084,Scan_cycle_data-Retry_count_n-15,0,
ENG26348-ENG30085,Scan_cycle_data-Retry_count_n-16,0,
ENG26348-ENG30086,Scan_cycle_data-Retry_count_n-17,0,
ENG26348-ENG30087,Scan_cycle_data-Retry_count_n-18,0,
ENG26348-ENG30088,Scan_cycle_data-Retry_count_n-19,0,
ENG26348-ENG30089,Scan_cycle_data-Retry_count_n-2,0,
ENG26348-ENG30090,Scan_cycle_data-Retry_count_n-3,0,
ENG26348-ENG30091,Scan_cycle_data-Retry_count_n-4,0,
ENG26348-ENG30092,Scan_cycle_data-Retry_count_n-5,0,
ENG26348-ENG32465,Scan_cycle_data-Retry_count_n-6,0,
ENG26348-ENG30093,Scan_cycle_data-Retry_count_n-7,0,
ENG26348-ENG30094,Scan_cycle_data-Retry_count_n-8,0,
ENG26348-ENG30095,Scan_cycle_data-Retry_count_n-9,0,
ENG26348-ENG30114,Scan_cycle_data-Scan_reason_n,Driver_door,
ENG26348-ENG30115,Scan_cycle_data-Scan_reason_n-1,Driver_door,
ENG26348-ENG30116,Scan_cycle_data-Scan_reason_n-10,Driver_door,
ENG26348-ENG30117,Scan_cycle_data-Scan_reason_n-11,Driver_door,
ENG26348-ENG30118,Scan_cycle_data-Scan_reason_n-12,Driver_door,
ENG26348-ENG30119,Scan_cycle_data-Scan_reason_n-13,Driver_door,
ENG26348-ENG30120,Scan_cycle_data-Scan_reason_n-14,Driver_door,
ENG26348-ENG30121,Scan_cycle_data-Scan_reason_n-15,Driver_door,
ENG26348-ENG30122,Scan_cycle_data-Scan_reason_n-16,Driver_door,
ENG26348-ENG30123,Scan_cycle_data-Scan_reason_n-17,Driver_door,
ENG26348-ENG30124,Scan_cycle_data-Scan_reason_n-18,Driver_door,
ENG26348-ENG30125,Scan_cycle_data-Scan_reason_n-19,Driver_door,
ENG26348-ENG30126,Scan_cycle_data-Scan_reason_n-2,Driver_door,
ENG26348-ENG30127,Scan_cycle_data-Scan_reason_n-3,Driver_door,
ENG26348-ENG30128,Scan_cycle_data-Scan_reason_n-4,Driver_door,
ENG26348-ENG30129,Scan_cycle_data-Scan_reason_n-5,Driver_door,
ENG26348-ENG30130,Scan_cycle_data-Scan_reason_n-6,Driver_door,
ENG26348-ENG30131,Scan_cycle_data-Scan_reason_n-7,Driver_door,
ENG26348-ENG30132,Scan_cycle_data-Scan_reason_n-8,Driver_door,
ENG26348-ENG30133,Scan_cycle_data-Scan_reason_n-9,Driver_door,
ENG26348-ENG30134,Scan_cycle_data-Scan_trigger_n,Set_stop_car,
ENG26348-ENG30135,Scan_cycle_data-Scan_trigger_n-1,Set_stop_car,
ENG26348-ENG30136,Scan_cycle_data-Scan_trigger_n-10,Set_stop_car,
ENG26348-ENG30137,Scan_cycle_data-Scan_trigger_n-11,Set_stop_car,
ENG26348-ENG30138,Scan_cycle_data-Scan_trigger_n-12,Set_stop_car,
ENG26348-ENG30139,Scan_cycle_data-Scan_trigger_n-13,Set_stop_car,
ENG26348-ENG30140,Scan_cycle_data-Scan_trigger_n-14,Set_stop_car,
ENG26348-ENG30141,Scan_cycle_data-Scan_trigger_n-15,Set_stop_car,
ENG26348-ENG30142,Scan_cycle_data-Scan_trigger_n-16,Set_stop_car,
ENG26348-ENG30143,Scan_cycle_data-Scan_trigger_n-17,Set_stop_car,
ENG26348-ENG30144,Scan_cycle_data-Scan_trigger_n-18,Set_stop_car,
ENG26348-ENG30145,Scan_cycle_data-Scan_trigger_n-19,Set_stop_car,
ENG26348-ENG30146,Scan_cycle_data-Scan_trigger_n-2,Set_stop_car,
ENG26348-ENG30147,Scan_cycle_data-Scan_trigger_n-3,Set_stop_car,
ENG26348-ENG30148,Scan_cycle_data-Scan_trigger_n-4,Set_stop_car,
ENG26348-ENG30149,Scan_cycle_data-Scan_trigger_n-5,Set_stop_car,
ENG26348-ENG30150,Scan_cycle_data-Scan_trigger_n-6,Set_stop_car,
ENG26348-ENG30151,Scan_cycle_data-Scan_trigger_n-7,Set_stop_car,
ENG26348-ENG30152,Scan_cycle_data-Scan_trigger_n-8,Set_stop_car,
ENG26348-ENG30153,Scan_cycle_data-Scan_trigger_n-9,Set_stop_car,
Elapsed Time: 00:12
Andy
Sector 7G
HC424490
08 - Auto HVAC maps
;SW:8V0-820-043-S   HW:8V0-820-043-S ---  Auto HVAC
;Component:AC Automat    H03 0620, Coding:0300001001001000080000000000140001000000
;EV_AirCondiFrontNARAU37X,001020,EV_AirCondiFrontNARAU37X.rod
;Friday,08,December,2017,16:07:51:29905
;VCID: 42C7C943D5FB003A90B-8016
IDE00001-ENG128289-Production mode-Air_condition_compressor_deactivate,not active ,3
IDE00001-ENG128290-Production mode-Battery_cooling_and_heating_deactivate,not active ,3
IDE00001-ENG128291-Production mode-ClearResetEmissionRelated-DiagnosticInformation_Mode$04,not active ,3
IDE01476-Store recirculation air setting for terminal 15 off,Matching coding ,1
IDE01482-After-run of parking heater or parking ventilation,not activated ,1
IDE01483-Blower voltage for voice operation,activated ,1
IDE01490-Fresh air blower voltage offset,Default ,1
IDE01491-Temperature offset: summer operation,Default ,1
IDE01492-Temperature offset: winter operation,Default ,1
IDE01493-Air quality sensor sensitivity,Little ,1
IDE01495-After-run time of auxiliary heater with A/C off,120 s,1
IDE01500-Window condensation reduction at high humidity,Matching coding ,1
IDE01503-Runtime for compressor run-in basic setting,120 s,1
IDE01505-Tolerance range for basic setting of flap end stops,15 °,1
IDE01506-Tolerance range for flap end stops,10 °,1
IDE02371-Time until heated seat power withdrawal stage 3 to stage 2,10 min,1
IDE02372-Time until heated seat power withdrawal stage 2 to stage 1,0 min,1
IDE03176-Duration of compressor run in,20 s,1
IDE04074-Driving program,Matching coding ,1
IDE06326-Tolerance: compressor speed during compressor run-in,950 /min,1
IDE06545-Blower voltage for production routines,12 V,1
IDE06546-Interior target temperature for production routines,22 °C,1
IDE06547-Air distribution for production routines,Footwell air distribution ,1
IDE06593-Recirculation air for production routines,Recirculating air ,1
IDE07106-Application characteristic curves,Matching coding ,1
IDE07108-Climate modes,Matching coding ,1
IDE07398-Blower logic for manual adjustment,Matching coding ,1
IDE10278-Behavior of compressor during moderate outside temperatures,not active ,1
IDE80006-Analysis 6,not activated ,1
IDE80007-Analysis 7,00 00 ,2
IDE80008-Analysis 8,activated ,1
IDE80009-Analysis 9,not activated ,1
IDE80011-Analysis 11,not activated ,1
IDE80013-Analysis 13,4.0 s,1
Elapsed Time: 00:08
;Friday,08,December,2017,16:07:38:29905
;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
IDE00019,Voltage terminal 30,13.100, V
IDE00086,Accelerator position,15, %
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00198,Refrigerant pressure,4.4, bar
IDE00445-ENG126260,Unlearning counter according OBD-OBD Parameter,255,
IDE00556,Outside air temperature,5, °C
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00767-MAS05494,No. of unscheduled ECU resets-Cause 1,0,
IDE00767-MAS05495,No. of unscheduled ECU resets-Cause 2,5,
IDE00767-MAS05496,No. of unscheduled ECU resets-Cause 3,0,
IDE00767-MAS05497,No. of unscheduled ECU resets-Cause 4,0,
IDE00767-MAS05498,No. of unscheduled ECU resets-Cause 5,0,
IDE00767-MAS05499,No. of unscheduled ECU resets-Cause 6,0,
IDE00767-MAS05793,No. of unscheduled ECU resets-Cause 7,0,
IDE00767-MAS05794,No. of unscheduled ECU resets-Cause 8,0,
IDE00965,Compressor shut-off requirement,Electric compressor: not ready,
IDE00970,Coolant fan activation: actual value,10.0, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00973,Outside air temperature,5, °C
IDE00974,Outside air temperature internally calculated,5, °C
IDE00976,Left front vent temperature,12.5, °C
IDE00977,Right front vent temperature,14.5, °C
IDE00981,Footwell vent temperature,12.0, °C
IDE00982,Temperature after evaporator,11.8, °C
IDE00983,Interior temperature,12.8, °C
IDE00984,Sun intensity left,20, W/m²
IDE00985,Sun intensity right,20, W/m²
IDE00987,Blower voltage: specified value,0.0, V
IDE00989,Blower status,not active,
IDE00994,Actual value for fresh air/recirculation air flow flap,862,
IDE00994,Actual value for fresh air/recirculation air flow flap,100.0, %
IDE00995,Specified value for fresh air/recirc air flow flap,863,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,175,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,863,
IDE00998,Left temperature flap - actual value,100.0, %
IDE00998,Left temperature flap - actual value,911,
IDE00999,Left temperature flap - specified value,914,
IDE01040,Left temperature flap: cold stop,125,
IDE01041,Left temperature flap: warm stop,914,
IDE01042,Right temperature flap: actual value,99.5, %
IDE01042,Right temperature flap: actual value,910,
IDE01043,Right temperature flap: specified value,914,
IDE01044,Right temperature flap: cold stop,116,
IDE01045,Right temperature flap: warm stop,914,
IDE01050,Front air distribution flap: actual value,0.0, %
IDE01050,Front air distribution flap: actual value,928,
IDE01051,Front air distribution flap: specified value,930,
IDE01052,Front air distribution flap: air outlet stop,930,
IDE01053,Front air distribution flap: footwell air outlet stop,111,
IDE01054,Defroster flap: actual value,100.0, %
IDE01054,Defroster flap: actual value,934,
IDE01055,Defroster flap: specified value,937,
IDE01056,Defroster flap: stop open,937,
IDE01057,Defroster flap: stop closed,96,
IDE01063,Status of recirculation air,recirc. because A/C off,
IDE01076,Time since ignition off,128, min
IDE01217-MAS01447,Left heated seat stage-Act.val.,0,
IDE01217-MAS01448,Left heated seat stage-Specified value,0,
IDE01218-MAS01447,Right heated seat stage-Act.val.,0,
IDE01218-MAS01448,Right heated seat stage-Specified value,0,
IDE01226,Blower voltage: actual value,0.0, V
IDE01227,Blower current,0.00, A
IDE01232,Supply voltage for external components,5.0, V
IDE01287,Counter of compressor switch-offs,0,
IDE01419,Compressor shut-off condition: last,Invalid signals,
IDE01420,Compressor shut-off requirement: penultimate,Compressor activation: malfunction in activation path,
IDE01421,Compressor shut-off requirement: antepenultimate,No current contingent,
IDE01433,Air quality status,Clean air,
IDE01442-MAS01533,Pressing a button-Defrost,not activated,
IDE01442-MAS01534,Pressing a button-Recirculating air,not activated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,not activated,
IDE01442-MAS01550,Pressing a button-AC,not activated,
IDE01442-MAS01554,Pressing a button-Left heated seat,not activated,
IDE01442-MAS01556,Pressing a button-Right heated seat,not activated,
IDE01442-MAS01560,Pressing a button-OFF,not activated,
IDE01442-MAS02015,Pressing a button-AUTO,not activated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,not activated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,not activated,
IDE01442-MAS03832,Pressing a button-Air distribution up,not activated,
IDE01443,Left push-and-rotary knob counter,0,
IDE01444,Right push-and-rotary knob counter,0,
IDE01449-IDE01011,Personalization 1 for climate control-Data record,active,
IDE01449-MAS01533,Personalization 1 for climate control-Defrost,0,
IDE01449-MAS01534,Personalization 1 for climate control-Recirculating air,0,
IDE01449-MAS01550,Personalization 1 for climate control-AC,1,
IDE01449-MAS01552,Personalization 1 for climate control-Left specified temperature,21.0, °C
IDE01449-MAS01553,Personalization 1 for climate control-Right specified temperature,15.0, °C
IDE01449-MAS01554,Personalization 1 for climate control-Left heated seat,0,
IDE01449-MAS01555,Personalization 1 for climate control-Left seat ventilation,not installed,
IDE01449-MAS01556,Personalization 1 for climate control-Right heated seat,0,
IDE01449-MAS01557,Personalization 1 for climate control-Right seat ventilation,1,
IDE01449-MAS01560,Personalization 1 for climate control-OFF,1,
IDE01449-MAS01562,Personalization 1 for climate control-Air quality sensor,1,
IDE01449-MAS01563,Personalization 1 for climate control-Auxiliary Air Heater,not installed,
IDE01449-MAS01566,Personalization 1 for climate control-Style,not installed,
IDE01449-MAS01567,Personalization 1 for climate control-Synchronization,1,
IDE01449-MAS02015,Personalization 1 for climate control-AUTO,1,
IDE01449-MAS02804,Personalization 1 for climate control-Manual fan speed increase,11,
IDE01449-MAS03830,Personalization 1 for climate control-Footwell air distribution,0,
IDE01449-MAS03831,Personalization 1 for climate control-Upper body vent air distribution,0,
IDE01449-MAS03832,Personalization 1 for climate control-Air distribution up,0,
IDE01449-MAS04620,Personalization 1 for climate control-Fan setting: absolute,1,
IDE01449-MAS04621,Personalization 1 for climate control-Left cabin heater,not installed,
IDE01449-MAS04648,Personalization 1 for climate control-Right cabin heater,not installed,
IDE01449-MAS06077,Personalization 1 for climate control-Manual blower stage during defrost active,6,
IDE01449-MAS06366,Personalization 1 for climate control-Display blower levels,0,
IDE01449-ENG122610,Personalization 1 for climate control-Test_Program_Blower_Step_Absolut,1,
IDE01449-ENG122611,Personalization 1 for climate control-Test_Program_Manual fan speed increase,11,
IDE01450-IDE01011,Personalization 2 for climate control-Data record,not active,
IDE01450-MAS01533,Personalization 2 for climate control-Defrost,0,
IDE01450-MAS01534,Personalization 2 for climate control-Recirculating air,0,
IDE01450-MAS01550,Personalization 2 for climate control-AC,1,
IDE01450-MAS01552,Personalization 2 for climate control-Left specified temperature,28.5, °C
IDE01450-MAS01553,Personalization 2 for climate control-Right specified temperature,15.0, °C
IDE01450-MAS01554,Personalization 2 for climate control-Left heated seat,3,
IDE01450-MAS01555,Personalization 2 for climate control-Left seat ventilation,not installed,
IDE01450-MAS01556,Personalization 2 for climate control-Right heated seat,0,
IDE01450-MAS01557,Personalization 2 for climate control-Right seat ventilation,3,
IDE01450-MAS01560,Personalization 2 for climate control-OFF,0,
IDE01450-MAS01562,Personalization 2 for climate control-Air quality sensor,0,
IDE01450-MAS01563,Personalization 2 for climate control-Auxiliary Air Heater,not installed,
IDE01450-MAS01566,Personalization 2 for climate control-Style,not installed,
IDE01450-MAS01567,Personalization 2 for climate control-Synchronization,0,
IDE01450-MAS02015,Personalization 2 for climate control-AUTO,0,
IDE01450-MAS02804,Personalization 2 for climate control-Manual fan speed increase,11,
IDE01450-MAS03830,Personalization 2 for climate control-Footwell air distribution,0,
IDE01450-MAS03831,Personalization 2 for climate control-Upper body vent air distribution,0,
IDE01450-MAS03832,Personalization 2 for climate control-Air distribution up,0,
IDE01450-MAS04620,Personalization 2 for climate control-Fan setting: absolute,1,
IDE01450-MAS04621,Personalization 2 for climate control-Left cabin heater,not installed,
IDE01450-MAS04648,Personalization 2 for climate control-Right cabin heater,not installed,
IDE01450-MAS06077,Personalization 2 for climate control-Manual blower stage during defrost active,10,
IDE01450-MAS06366,Personalization 2 for climate control-Display blower levels,1,
IDE01450-ENG122610,Personalization 2 for climate control-Test_Program_Blower_Step_Absolut,1,
IDE01450-ENG122611,Personalization 2 for climate control-Test_Program_Manual fan speed increase,11,
IDE01451-IDE01011,Personalization 3 for climate control-Data record,not active,
IDE01451-MAS01533,Personalization 3 for climate control-Defrost,0,
IDE01451-MAS01534,Personalization 3 for climate control-Recirculating air,0,
IDE01451-MAS01550,Personalization 3 for climate control-AC,1,
IDE01451-MAS01552,Personalization 3 for climate control-Left specified temperature,22.0, °C
IDE01451-MAS01553,Personalization 3 for climate control-Right specified temperature,15.0, °C
IDE01451-MAS01554,Personalization 3 for climate control-Left heated seat,0,
IDE01451-MAS01555,Personalization 3 for climate control-Left seat ventilation,not installed,
IDE01451-MAS01556,Personalization 3 for climate control-Right heated seat,0,
IDE01451-MAS01557,Personalization 3 for climate control-Right seat ventilation,1,
IDE01451-MAS01560,Personalization 3 for climate control-OFF,0,
IDE01451-MAS01562,Personalization 3 for climate control-Air quality sensor,0,
IDE01451-MAS01563,Personalization 3 for climate control-Auxiliary Air Heater,not installed,
IDE01451-MAS01566,Personalization 3 for climate control-Style,not installed,
IDE01451-MAS01567,Personalization 3 for climate control-Synchronization,0,
IDE01451-MAS02015,Personalization 3 for climate control-AUTO,1,
IDE01451-MAS02804,Personalization 3 for climate control-Manual fan speed increase,11,
IDE01451-MAS03830,Personalization 3 for climate control-Footwell air distribution,0,
IDE01451-MAS03831,Personalization 3 for climate control-Upper body vent air distribution,0,
IDE01451-MAS03832,Personalization 3 for climate control-Air distribution up,0,
IDE01451-MAS04620,Personalization 3 for climate control-Fan setting: absolute,1,
IDE01451-MAS04621,Personalization 3 for climate control-Left cabin heater,not installed,
IDE01451-MAS04648,Personalization 3 for climate control-Right cabin heater,not installed,
IDE01451-MAS06077,Personalization 3 for climate control-Manual blower stage during defrost active,10,
IDE01451-MAS06366,Personalization 3 for climate control-Display blower levels,0,
IDE01451-ENG122610,Personalization 3 for climate control-Test_Program_Blower_Step_Absolut,1,
IDE01451-ENG122611,Personalization 3 for climate control-Test_Program_Manual fan speed increase,11,
IDE01452-IDE01011,Personalization 4 for climate control-Data record,not active,
IDE01452-MAS01533,Personalization 4 for climate control-Defrost,0,
IDE01452-MAS01534,Personalization 4 for climate control-Recirculating air,0,
IDE01452-MAS01550,Personalization 4 for climate control-AC,0,
IDE01452-MAS01552,Personalization 4 for climate control-Left specified temperature,22.0, °C
IDE01452-MAS01553,Personalization 4 for climate control-Right specified temperature,15.0, °C
IDE01452-MAS01554,Personalization 4 for climate control-Left heated seat,0,
IDE01452-MAS01555,Personalization 4 for climate control-Left seat ventilation,not installed,
IDE01452-MAS01556,Personalization 4 for climate control-Right heated seat,0,
IDE01452-MAS01557,Personalization 4 for climate control-Right seat ventilation,1,
IDE01452-MAS01560,Personalization 4 for climate control-OFF,0,
IDE01452-MAS01562,Personalization 4 for climate control-Air quality sensor,0,
IDE01452-MAS01563,Personalization 4 for climate control-Auxiliary Air Heater,not installed,
IDE01452-MAS01566,Personalization 4 for climate control-Style,not installed,
IDE01452-MAS01567,Personalization 4 for climate control-Synchronization,0,
IDE01452-MAS02015,Personalization 4 for climate control-AUTO,1,
IDE01452-MAS02804,Personalization 4 for climate control-Manual fan speed increase,11,
IDE01452-MAS03830,Personalization 4 for climate control-Footwell air distribution,0,
IDE01452-MAS03831,Personalization 4 for climate control-Upper body vent air distribution,0,
IDE01452-MAS03832,Personalization 4 for climate control-Air distribution up,0,
IDE01452-MAS04620,Personalization 4 for climate control-Fan setting: absolute,1,
IDE01452-MAS04621,Personalization 4 for climate control-Left cabin heater,not installed,
IDE01452-MAS04648,Personalization 4 for climate control-Right cabin heater,not installed,
IDE01452-MAS06077,Personalization 4 for climate control-Manual blower stage during defrost active,10,
IDE01452-MAS06366,Personalization 4 for climate control-Display blower levels,0,
IDE01452-ENG122610,Personalization 4 for climate control-Test_Program_Blower_Step_Absolut,1,
IDE01452-ENG122611,Personalization 4 for climate control-Test_Program_Manual fan speed increase,11,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01281,CAN input signal(s) status-Back-up light,OFF,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,0, s
IDE04312-MAS00084,System run time-Terminal 15 on,253, s
IDE04797,Center push-and-rotary knob counter,0,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE04805-MAS03559,Driving profile selection-System status 1,2,
IDE04805-MAS03917,Driving profile selection-Driver intention,0,
IDE04805-MAS05471,Driving profile selection-Efficiency,Efficiency mode not active,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,95,
IDE06091-MAS04647,Humidity sensor: internal-Dew point,97.1, °C
IDE06091,Humidity sensor: internal,-38.0, °C
IDE06091,Humidity sensor: internal,-0.5, %
IDE06091,Humidity sensor: internal,5.3, °C
IDE06091-ENG122608,Humidity sensor: internal-Test_Program_relative_humidity,-0.5, %
IDE06091-ENG122607,Humidity sensor: internal-Test_Program_sensor_temperature,-38.0, °C
IDE06091-ENG122606,Humidity sensor: internal-Test_Program_windshield_temperature,-13.5, °C
IDE06163-MAS04628,External humidity sensor-Air temperature,9.1, °C
IDE06163-MAS04629,External humidity sensor-Sensor temperature,14.9, °C
IDE06163-MAS04630,External humidity sensor-Relative humidity,0.0, %
IDE06163-MAS04647,External humidity sensor-Dew point,4399.6, °C
IDE06163-ENG122609,External humidity sensor-Test_Program_Air temperature,2.9, °C
IDE06163-ENG122608,External humidity sensor-Test_Program_relative_humidity,0.0, %
IDE06163-ENG122607,External humidity sensor-Test_Program_sensor_temperature,19.9, °C
IDE06545,Blower voltage for production routines,12, V
IDE06546,Interior target temperature for production routines,22, °C
IDE06547,Air distribution for production routines,Footwell air distribution,
IDE06593,Recirculation air for production routines,Recirculating air,
IDE06750-IDE01011,Last customer settings-Data record,active,
IDE06750-MAS01533,Last customer settings-Defrost,0,
IDE06750-MAS01534,Last customer settings-Recirculating air,0,
IDE06750-MAS01550,Last customer settings-AC,1,
IDE06750-MAS01552,Last customer settings-Left specified temperature,21.0, °C
IDE06750-MAS01553,Last customer settings-Right specified temperature,15.0, °C
IDE06750-MAS01554,Last customer settings-Left heated seat,0,
IDE06750-MAS01555,Last customer settings-Left seat ventilation,not installed,
IDE06750-MAS01556,Last customer settings-Right heated seat,0,
IDE06750-MAS01557,Last customer settings-Right seat ventilation,1,
IDE06750-MAS01560,Last customer settings-OFF,1,
IDE06750-MAS01562,Last customer settings-Air quality sensor,1,
IDE06750-MAS01563,Last customer settings-Auxiliary Air Heater,not installed,
IDE06750-MAS01566,Last customer settings-Style,not installed,
IDE06750-MAS01567,Last customer settings-Synchronization,1,
IDE06750-MAS02015,Last customer settings-AUTO,1,
IDE06750-MAS02804,Last customer settings-Manual fan speed increase,11,
IDE06750-MAS03830,Last customer settings-Footwell air distribution,0,
IDE06750-MAS03831,Last customer settings-Upper body vent air distribution,0,
IDE06750-MAS03832,Last customer settings-Air distribution up,0,
IDE06750-MAS04620,Last customer settings-Fan setting: absolute,1,
IDE06750-MAS04621,Last customer settings-Left cabin heater,not installed,
IDE06750-MAS04648,Last customer settings-Right cabin heater,not installed,
IDE06750-MAS06077,Last customer settings-Manual blower stage during defrost active,6,
IDE06750-MAS06366,Last customer settings-Display blower levels,0,
IDE06750-ENG122610,Last customer settings-Test_Program_Blower_Step_Absolut,1,
IDE06750-ENG122611,Last customer settings-Test_Program_Manual fan speed increase,11,
IDE06926-MAS00106,History memory: reset counter-Year,2000,
IDE06926-MAS00107,History memory: reset counter-Month,1,
IDE06926-MAS00108,History memory: reset counter-Day,18,
IDE06926-MAS00109,History memory: reset counter-Hours,10,
IDE06926-MAS00110,History memory: reset counter-Minutes,0,
IDE06926-MAS00111,History memory: reset counter-Seconds,1,
IDE06926,History memory: reset counter,Cause 2,
IDE09168-MAS01632,Refrigerant cut-off valve 1-Status,Open,
IDE09169-MAS01632,Refrigerant cut-off valve 2-Status,Open,
IDE09171-MAS01447,Coolant circulation pump 1-Act.val.,87,
IDE09171-MAS01448,Coolant circulation pump 1-Specified value,3,
IDE09172,Coolant change-over valve 1,not activated,
IDE09173-MAS01447,Coolant circulation pump 2-Act.val.,0,
IDE09173-MAS01448,Coolant circulation pump 2-Specified value,0,
IDE09174,Coolant change-over valve 2,operated,
IDE09179-MAS01632,Relay for standstill A/C: status-Status,operated,
IDE09186-MAS01447,Coolant circulation pump 3-Act.val.,0,
IDE09186-MAS01448,Coolant circulation pump 3-Specified value,100,
IDE09189-IDE09201,HV heater temperature-Intake temperature,11.0, °C
IDE09189-IDE09202,HV heater temperature-Exhaust Temperature,12.0, °C
IDE09190,Coolant change-over valve 3,not activated,
IDE09197,Temp sensor 5,26.0, °C
IDE09198-MAS01448,HV heater status: global-Specified value,0, %
IDE09198-MAS08432,HV heater status: global-Requirement,active,
IDE09199-IDE09201,HV heater status: internal-Intake temperature,11, °C
IDE09199-IDE09202,HV heater status: internal-Exhaust Temperature,12, °C
IDE09199-MAS01481,HV heater status: internal-Temperature in control module,20, °C
IDE09199-MAS01634,HV heater status: internal-Supply voltage,13.1, V
IDE09199-MAS02246,HV heater status: internal-Timeout,OK,
IDE09199-MAS03746,HV heater status: internal-Current: actual value,0.00, A
IDE09199-MAS07055,HV heater status: internal-Response error,OK,
IDE09199-MAS09468,HV heater status: internal-Vehicle high voltage system,OK,
IDE09199-MAS09469,HV heater status: internal-HV heater: status,OK,
IDE09199-ENG128274,HV heater status: internal-PTC_HV_Err_Heizkreis_1,OK,
IDE09199-ENG128275,HV heater status: internal-PTC_HV_Err_Heizkreis_2,OK,
IDE09199-ENG128276,HV heater status: internal-PTC_HV_Err_Heizkreis_3,OK,
IDE09199-ENG128280,HV heater status: internal-PTC_HV_Err_intern,OK,
IDE09199-ENG128277,HV heater status: internal-PTC_HV_Err_Leckagestrom,OK,
IDE09199-ENG128279,HV heater status: internal-PTC_HV_Err_Temperaturschutz,OK,
IDE09199-ENG128278,HV heater status: internal-PTC_HV_Err_Ueberstromabschaltung,OK,
IDE09199-ENG128267,HV heater status: internal-supply_voltage_status,OK,
IDE09203,HV heater shut-off condition,Charge manager,
IDE11382-IDE05237,Compressor status OBD: global-A/C compressor power consumption: actual value,0.00, kW
IDE11382-IDE05241,Compressor status OBD: global-A/C compressor release status,not transmitted,
IDE11382-IDE06336,Compressor status OBD: global-A/C compressor: target speed,0, /min
IDE11382-IDE06337,Compressor status OBD: global-A/C compressor: actual speed,0, /min
IDE11382-MAS04770,Compressor status OBD: global-A/C compressor: function status,Air conditioner compressor off,
IDE11382-MAS05974,Compressor status OBD: global-A/C compressor error indicator,not active,
IDE11382-MAS12658,Compressor status OBD: global-HV release,transmitted,
IDE11383-IDE01233,Compressor: system monitor-Compressor motor current,0.00, A
IDE11383-MAS05976,Compressor: system monitor-A/C compressor: inverter temperature,17, °C
IDE11383-MAS05978,Compressor: system monitor-High voltage supply voltage,354, V
IDE11383-MAS05979,Compressor: system monitor-A/C compressor: start-up monitor,OK,
IDE11383-MAS12656,Compressor: system monitor-A/C compressor: Inverter temperature status,OK,
IDE11455-MAS11114,Range consumption forecast-Time to transition from dynamic to steady-state operation,0, min
IDE11455-MAS11115,Range consumption forecast-Change in the prediction initiated by customer action,2,
IDE11455-MAS11116,Range consumption forecast-Dynamic power for heating/cooling,0, W
IDE11455-MAS11117,Range consumption forecast-Steady-state power for heating/cooling,0, W
IDE11455-MAS11118,Range consumption forecast-Consumption for heating and cooling of the components,0, Ws
IDE11455-MAS11119,Range consumption forecast-Overflow-bit component consumption,no overflow,
IDE11455-MAS11120,Range consumption forecast-Consumption for heating and cooling of the interior,0, Ws
IDE11455-MAS13274,Range consumption forecast-Overflow-bit interior consumption,no overflow,
IDE11836,Query of the supported PIDs (0x01 - 0x20),98 18 00 01,
IDE11837,Query of the supported PIDs (0x21 - 0x40),00 00 00 01,
IDE11838,Query of the supported PIDs (0x41 - 0x60),C4 80 00 00,
IDE11839,Query of the supported InfoTypes (0x01 - 0x20),14 40 00 00,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
MAS00464-MAS00107,Standard - ambient data 1-Month,0,
MAS00464-MAS00108,Standard - ambient data 1-Day,8,
MAS00464-MAS00109,Standard - ambient data 1-Hours,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,12,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,50,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,6,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,78, km
MAS11295,Refrigerant temperature,10.7, °C
ENG101413,Calibration Identification,8V0043S 062000U0,
ENG99697,Calibration Verification Number,8F 5A 2E 0E,
ENG100152-ENG104003,ECUNAME-ECU,HVAC,
ENG100152,ECUNAME,HVACCtrl,
Elapsed Time: 00:13
Andy
Sector 7G
HC424490
09 - Cent. Elect. maps
;SW:5Q0-937-085-BN   HW:5Q0-937-085-BF ---  Cent. Elect.
;Component:BCM MQBAB MNA H36 0253, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,018001,EV_BCMBOSCH_018.rod
;Friday,08,December,2017,16:08:57:29905
;VCID: 064F1553B953FC1AFC3-8052
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active ,3
IDE01550-Service position,133.197670 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,300 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,300 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,300 ms,10
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,16 s,8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,not active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,1000 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,16
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °,16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,32.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,OFF ,16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE03787-Activate left/right hand drive switch-over,No_Menue ,1
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,not active ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,11
IDE04928-MAS01577-Anti-theft device-Parking heater,not installed ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor,installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),Yes ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,1 Alarm ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 61 49 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 62 4A 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 1A 0B 00 7F 1E 00 7F 00 00 00 00 00 00 06 40 00 1B 0C 00 7F 1E 00 7F 00 00 00 00 00 00 06 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 06 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 5D 28 1E 7F 00 00 00 00 00 00 00 00 00 06 40 00 5E 28 1E 7F 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,28.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,27.50 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,28.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,27.50 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,40.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,40.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,63.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,62.50 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,63.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,62.50 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED not installed ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remotestart,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,21.197781 °,2
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,not active ,6
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,2 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.00 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,0 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,0 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,0 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,0 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,0 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,active ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,installed ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
IDE10298-Alternating park position 1,18.197784 °,2
IDE10299-Alternating park position 2,21.197781 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,1.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,100 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,100 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,active ,3
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
MAS05055-lower turn position,26.197776 °,2
MAS05056-upper turn position,166.197637 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,0.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,0.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,0.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,0.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,0.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,0.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,0.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,0.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,0.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,0.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,0.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,0.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,0.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,0.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,0.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,NOT-DEFINED ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,NOT-DEFINED ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,NOT-DEFINED ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,NOT-DEFINED ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,NOT-DEFINED ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,NOT-DEFINED ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,NOT-DEFINED ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,NOT-DEFINED ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,NOT-DEFINED ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,NOT-DEFINED ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,NOT-DEFINED ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,NOT-DEFINED ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,NOT-DEFINED ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,NOT-DEFINED ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,NOT-DEFINED ,30
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Sollspannungsanforderung 13.5 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,4 km/h,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,active ,9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,active ,9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,installed ,9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit,active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,60 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion,active ,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,installed ,18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht,bewusste Aktivierung Fahrer Dauerhaft ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x1 Stunden ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,6400 lx,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,separate ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),LIN ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,20 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,60 seconds ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,not active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,8 s,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Keine_Spannungsanforderung ,18
ENG122934-erase_error_table,55 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,500 ms,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,not active ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,2000 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG99457-ENG117394-Head area heater-blower_speed,0 ,2
ENG99457-ENG98971-Head area heater-Temperature,-3 ,2
ENG141645-ENG142026-HW_Verbau-Druckklappe,installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,installed ,8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,not active ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,active ,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-0.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-0.10 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-0.60 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-1.10 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-1.60 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-2.10 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-2.60 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-3.10 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-3.60 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-4.10 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,89.5 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,83.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,75.5 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,68.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,61.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,56.5 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,47.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,40.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,33.0 %,30
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,127 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,5D ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,36 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Coming Home oder Leaving Home aktiv ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,127 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,5E ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,40 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Coming Home oder Leaving Home aktiv ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,85 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,35 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,0A ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Coming Home oder Leaving Home aktiv ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,85 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,36 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,1A ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Coming Home oder Leaving Home aktiv ,16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,minimize ,16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,minimize ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,127 ,16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,3F ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Brake light ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,Blinken links aktiv (beide Phasen) ,16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,Blinken links Hellphase ,16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,Blinken links Dunkelphase ,16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,minimize ,16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,minimize ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,127 ,16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,40 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Brake light ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,Blinken rechts aktiv (beide Phasen) ,16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,Blinken rechts Hellphase ,16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,Blinken rechts Dunkelphase ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,04 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,46 - LED Kleinleistung ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Ambientelicht 2 ,16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,minimize ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,0 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,127 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,127 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,35 - kombinierte LED Blink-Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,not active ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Brake light ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Blinken links Hellphase ,16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,Blinken links Dunkelphase ,16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,minimize ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,0 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,127 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,127 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,35 - kombinierte LED Blink-Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,not active ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Brake light ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Blinken rechts Hellphase ,16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,Blinken rechts Dunkelphase ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,80 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,50 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,80 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,50 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Parking light right ,16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,127 ,16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,beidseitiges Dauerparklicht ,16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,minimize ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,37 - allgemeine LED bis 12W ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,Left high beam ,16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,37 - allgemeine LED bis 12W ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Right high beam ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,37 - allgemeine LED bis 12W ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,127 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,61 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,36 - LED Kleinleistung ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100 ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,127 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,62 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,36 - LED Kleinleistung ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,6 - LED Lichtmodul ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,6 - LED Lichtmodul ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 3F 18 00 7F 1A 06 80 02 00 7F 03 00 80 26 18 00 40 18 00 7F 1A 07 80 04 00 7F 05 00 80 23 13 00 3D 00 00 00 18 00 7F 02 00 7F 03 00 80 23 23 00 3E 00 00 00 18 00 7F 04 00 7F 05 00 80 2A 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 1E 50 09 00 32 00 00 00 00 00 00 2B 1A 00 2A 08 1E 50 0A 00 32 00 00 00 00 00 00 2B 28 00 30 08 1E 7F 3A 00 7F 00 00 00 00 00 00 25 0C 00 2E 1A 00 64 0D 00 80 00 00 00 00 00 00 25 1C 00 2F 1A 00 64 0E 00 80 00 00 00 00 00 00 25 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 25 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,2B 0A 00 35 08 1E 55 00 00 00 00 00 00 00 00 00 2B 1A 00 36 08 1E 55 00 00 00 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 64 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 64 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 64 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2650 mm,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,84.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,20.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-127.0 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,4.10 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,4.70 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,4.50 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.30 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.30 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,3.30 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_2 ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,70.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.10 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,Inverted ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,10 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,10 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,10 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,10 mm,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,5 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,10.00 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,not active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,60.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,5.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,20.0 %,62
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-0.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-0.55 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-1.10 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-2.40 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-2.80 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,0.30 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,0.20 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,0.80 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-4.60 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.20 ,20
ENG124714-ENG142261-OCU-Remote HuF Abbruch,0 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,0 Hz,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,0 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,0 ms,8
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,0 ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,not active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Audi ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,installed ,5
ENG122927-RLS_close_glazing,2.5 s,1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,100 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,200 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,8 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,1000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1200 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,1000 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,1000 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,1200 ms,10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Sollspannungsanforderung 13.5 ,10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,10.0 min,10
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,Potentiometer ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,5 ,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,50 %,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.248 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,1.0 %,21
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,6.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,6.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,16.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,30.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,60.0 %,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,not active ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,active ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,nur wenn freigegeben ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,not active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,not active ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,42 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,62 ,3
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,not active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,unidirectional ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,active ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Pulse control ,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5
Elapsed Time: 01:41
;SW:5Q0-937-085-BN   HW:5Q0-937-085-BF ---  Cent. Elect.
;Component:BCM MQBAB MNA H36 0253, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,018001,EV_BCMBOSCH_018.rod
;Friday,08,December,2017,16:08:05:29905
;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
;VCID: 064F1553B953FC1AFC3-8052
Group,Description,Actual
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,not coded/not installed,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,not coded/not installed,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not coded/not installed,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,not coded/not installed,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not coded/not installed,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not coded/not installed,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not coded/not installed,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not_defined,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,not coded/not installed,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,not coded/not installed,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,not coded/not installed,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,Measured value not available,
IDE00973,Outside air temperature,4.50, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,not activated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Windshield defogger-Activation,not coded/not installed,
IDE01943-MAS01737,Turn signal-Diagnosis,normal,
IDE01943-MAS02248,Turn signal-Signal state,not active,
IDE01943-MAS03873,Turn signal-Duty cycle,0.0, %
IDE01943-MAS04351,Turn signal-Connector terminal number,60,
IDE01943-MAS04352,Turn signal-Connector number,Plug A,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not activated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,closed,
IDE02092-MAS02447,Tailgate condition-Release,Enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,not activated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,closed,
IDE02488-MAS01632,DWA Interior monitoring-Status,not coded/not installed,
IDE02488-MAS04508,DWA Interior monitoring-Alarm detected,not coded/not installed,
IDE02515-MAS01737,Low beam-Diagnosis,normal,
IDE02515-MAS02248,Low beam-Signal state,not active,
IDE02515-MAS03873,Low beam-Duty cycle,0.0, %
IDE02515-MAS04351,Low beam-Connector terminal number,5,
IDE02515-MAS04352,Low beam-Connector number,Plug C,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not coded/not installed,
IDE02711,Rear Window Wiper,not active,
IDE02743-MAS01737,High Beam-Diagnosis,normal,
IDE02743-MAS02248,High Beam-Signal state,not active,
IDE02743-MAS03873,High Beam-Duty cycle,0.0, %
IDE02743-MAS04351,High Beam-Connector terminal number,72,
IDE02743-MAS04352,High Beam-Connector number,Plug A,
IDE02744-MAS01632,Steering wheel heater-Status,not coded/not installed,
IDE02744-MAS02311,Steering wheel heater-Steering wheel heating button,not coded/not installed,
IDE02744-MAS04136,Steering wheel heater-Current,0.00, A
IDE02744-MAS09758,Steering wheel heater-Temperature sensor,-35, °C
IDE02857-IDE03111,Activation current-Interior light,16, mA
IDE02857-IDE05533,Activation current-Spray nozzle heater,422, mA
IDE02857-IDE06012,Activation current-Search lights,0, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,no error,
IDE02857-ENG128455,Activation current-Cockpittaster_2,no error,
IDE02857-ENG128456,Activation current-Cockpittaster_3,no error,
IDE02857-ENG128457,Activation current-Cockpittaster_4,no error,
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,0, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957-MAS01737,Ambient lighting-Diagnosis,normal,
IDE02957-MAS02248,Ambient lighting-Signal state,not active,
IDE02957-MAS03873,Ambient lighting-Duty cycle,0.00, %
IDE02957-MAS04351,Ambient lighting-Connector terminal number,61,
IDE02957-MAS04352,Ambient lighting-Connector number,Plug C,
IDE02957-MAS06670,Ambient lighting-Channel,Chan. A,
IDE03111-MAS01737,Interior light-Diagnosis,not coded/not installed,
IDE03111-MAS02248,Interior light-Signal state,not active,
IDE03111-MAS03873,Interior light-Duty cycle,0.00, %
IDE03111-MAS04351,Interior light-Connector terminal number,0,
IDE03111-MAS04352,Interior light-Connector number,Plug A,
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,16.8, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,127.5,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,13.2, V
IDE03310-MAS01737,Brake light-Diagnosis,normal,
IDE03310-MAS02248,Brake light-Signal state,not active,
IDE03310-MAS03873,Brake light-Duty cycle,0.0, %
IDE03310-MAS04351,Brake light-Connector terminal number,60,
IDE03310-MAS04352,Brake light-Connector number,Plug A,
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,9.50, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,9.50, °C
IDE03504-IDE02022,Personalized settings-Comfort opening,not_defined,
IDE03504-IDE03679,Personalized settings-Adaptive light functions,not active,
IDE03504-IDE04036,Personalized settings-High beam assistant: status,active,
IDE03504-MAS01597,Personalized settings-Sunroof,active,
IDE03504-MAS04322,Personalized settings-Masked continuous high beam,not active,
IDE03504-MAS06456,Personalized settings-Autolock,active,
IDE03504-MAS06457,Personalized settings-autounlock,active,
IDE03504-MAS06911,Personalized settings-Status Coming Home,active,
IDE03504-MAS06912,Personalized settings-Status Leaving Home,active,
IDE03504-MAS07014,Personalized settings-Tourist light,not active,
IDE03504-MAS07967,Personalized settings-profile,1,
IDE03504-MAS07971,Personalized settings-Electrical rear lid,not active,
IDE03504-MAS07972,Personalized settings-Manual door unlock,all,
IDE03504-MAS07973,Personalized settings-Rain closure,not active,
IDE03504-MAS07978,Personalized settings-Mirror adjustment,INDIVIDUAL,
IDE03504-MAS07980,Personalized settings-Mirror lowering,active,
IDE03504-MAS07981,Personalized settings-Automatic mirror fold-in,not active,
IDE03504-MAS07982,Personalized settings-Activation sound: theft warning system,active,
IDE03504-MAS07983,Personalized settings-Virtual pedal,not active,
IDE03504-MAS07984,Personalized settings-Automatic rear window wiper,active,
IDE03504-MAS07985,Personalized settings-Coming Home set point,20, s
IDE03504-MAS07986,Personalized settings-Leaving Home set point,60, s
IDE03504-MAS07987,Personalized settings-Light intensity,normal,
IDE03504-MAS07990,Personalized settings-Comfort flasher,active,
IDE03504-MAS07991,Personalized settings-Comfort flasher set point,3,
IDE03504-MAS07992,Personalized settings-Sliding beam range,active,
IDE03504-MAS07993,Personalized settings-Rain light,active,
IDE03504-ENG29901,Personalized settings-Touristenlicht Einstellwert,not active,
IDE03638-MAS01737,static AFS light-Diagnosis,normal,
IDE03638-MAS02248,static AFS light-Signal state,not active,
IDE03638-MAS03873,static AFS light-Duty cycle,0.0, %
IDE03638-MAS04351,static AFS light-Connector terminal number,6,
IDE03638-MAS04352,static AFS light-Connector number,Plug B,
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator light for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00104,Expanded environmental conditions-DTC,08 0E 00,
IDE04347-IDE07836,Expanded environmental conditions-Log data,00 00 00 01 00 10 00 0C 63 00 00 03 63 00 00 00 00 00 00 00 00 00 00 00 00 02 00 03 00 05 F7 94 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 22 00 06 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 17 00 01 00 00 01 00 4F 64 07 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 00 81 04 4F 00 00 10 00 04 4C 07 87 00 20 00 00 40 C1 40 32 E9 0F 00 00 00 1C 05 68 00 3B 00 00 00 00 00 00 00 00 00 00 00 00 03 01 00 00 00 00 02 00 00 00 00 00 00 00 00 8F 03 01 01 00 00 00,
IDE04925-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
IDE04925-MAS02248,Daytime running lights-Signal state,not active,
IDE04925-MAS03873,Daytime running lights-Duty cycle,0.0, %
IDE04925-MAS04351,Daytime running lights-Connector terminal number,0,
IDE04925-MAS04352,Daytime running lights-Connector number,Plug A,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,32.00, %
IDE05045-IDE05183,Front windshield wiper module-Malfunction left,no error,
IDE05045-IDE05184,Front windshield wiper module-Malfunction right,no error,
IDE05045-MAS01632,Front windshield wiper module-Status,not active,
IDE05045-MAS02282,Front windshield wiper module-Position,park position,
IDE05045-MAS03638,Front windshield wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front windshield wiper module-Number of wiper cycles,0,
IDE05045-MAS05878,Front windshield wiper module-Stage,not coded/not installed,
IDE05323-MAS01737,Fog light-Diagnosis,not coded/not installed,
IDE05323-MAS02248,Fog light-Signal state,not active,
IDE05323-MAS03873,Fog light-Duty cycle,0.0, %
IDE05323-MAS04351,Fog light-Connector terminal number,0,
IDE05323-MAS04352,Fog light-Connector number,Plug A,
IDE05434-MAS01737,Rear entry light-Diagnosis,not coded/not installed,
IDE05434-MAS02248,Rear entry light-Signal state,not active,
IDE05434-MAS03873,Rear entry light-Duty cycle,0.00, %
IDE05434-MAS04150,Rear entry light-Side,not_defined,
IDE05434-MAS04351,Rear entry light-Connector terminal number,0,
IDE05434-MAS04352,Rear entry light-Connector number,Plug A,
IDE05533,Spray nozzle heater,active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,Not operated,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,Not operated,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE05730-MAS01737,Luggage compartment light-Diagnosis,not coded/not installed,
IDE05730-MAS02248,Luggage compartment light-Signal state,not active,
IDE05730-MAS03873,Luggage compartment light-Duty cycle,0.00, %
IDE05730-MAS04351,Luggage compartment light-Connector terminal number,0,
IDE05730-MAS04352,Luggage compartment light-Connector number,Plug A,
IDE05739-MAS01737,Footwell light-Diagnosis,normal,
IDE05739-MAS02248,Footwell light-Signal state,not active,
IDE05739-MAS03873,Footwell light-Duty cycle,0.0, %
IDE05739-MAS04351,Footwell light-Connector terminal number,72,
IDE05739-MAS04352,Footwell light-Connector number,Plug C,
IDE05742-IDE02515,Light switch position-Low beam,not activated,
IDE05742-IDE05323,Light switch position-Fog light,not activated,
IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
IDE05742-MAS00063,Light switch position-OFF,operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,not activated,
IDE05742-MAS03835,Light switch position-Parking light,not activated,
IDE05742-MAS03836,Light switch position-Rear fog light,not activated,
IDE05822-MAS01632,DWA Vehicle inclination sensor-Status,not coded/not installed,
IDE05822-MAS04508,DWA Vehicle inclination sensor-Alarm detected,not coded/not installed,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not active,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Alarm horn for anti-theft warning system,not coded/not installed,
IDE05828-MAS06608,DWA History data for alarm triggering-Cause for last alarm activation,Alarm trigger by DWA Master,
IDE05828-MAS06609,DWA History data for alarm triggering-Cause for second-to-last alarm activation,Alarm trigger by DWA Master,
IDE05828-MAS06610,DWA History data for alarm triggering-Cause for third-to-last alarm activation,No alarm,
IDE05828-MAS06611,DWA History data for alarm triggering-Cause for fourth-to-last alarm activation,No alarm,
IDE05828-MAS06613,DWA History data for alarm triggering-Number of alarm activations,2,
IDE05829-ENG28562,Rear spoiler history data-Spoiler_Activation_Trigger,NoEntry,
IDE05829-ENG28563,Rear spoiler history data-Spoiler_Activation_Trigger_Date,335544320,
IDE05829-ENG28565,Rear spoiler history data-Spoiler_Activation_Trigger_Milage,0, km
IDE05829-ENG28564,Rear spoiler history data-Spoiler_Activation_Trigger_Time,0,
IDE05830-MAS02282,Rear Spoiler-Position,not coded/not installed,
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05833-MAS00106,Anti-theft warning system: history data-Year,2000,
IDE05833-MAS00107,Anti-theft warning system: history data-Month,0,
IDE05833-MAS00108,Anti-theft warning system: history data-Day,0,
IDE05833-MAS00109,Anti-theft warning system: history data-Hours,0,
IDE05833-MAS00110,Anti-theft warning system: history data-Minutes,0,
IDE05833-MAS00111,Anti-theft warning system: history data-Seconds,0,
IDE05833-MAS00711,Anti-theft warning system: history data-Odometer reading,0, km
IDE05833-MAS04478,Anti-theft warning system: history data-Cause for alarm activation,No alarm,
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,not coded/not installed,
IDE05837,Activation for signal horn,not active,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,0, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,12, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE05839-MAS01737,Parking light-Diagnosis,normal,
IDE05839-MAS02248,Parking light-Signal state,active,
IDE05839-MAS03873,Parking light-Duty cycle,100.0, %
IDE05839-MAS04351,Parking light-Connector terminal number,2,
IDE05839-MAS04352,Parking light-Connector number,Plug B,
IDE05841-MAS06441,Central locking history data-Control-section / cause,Outside door handle sens.: frt. left,
IDE05841-MAS07519,Central locking history data-Command,Unlocking of entire vehicle,
IDE05841-MAS07942,Central locking history data-Additional information,KESSY ID sensor 1,
IDE05841-ENG29969,Central locking history data-command_direction_locking,No_locking,
IDE05841-ENG29970,Central locking history data-command_direction_unlocking,Door unlock,
IDE05842-MAS00218,Comfort function history data-Driver door,not active,
IDE05842-MAS00219,Comfort function history data-Front Passenger Door,not active,
IDE05842-MAS00220,Comfort function history data-Left rear door,not active,
IDE05842-MAS00221,Comfort function history data-Right rear door,not active,
IDE05842-MAS06441,Comfort function history data-Control-section / cause,lock zylinder drver door,
IDE05842-MAS07560,Comfort function history data-Top,not active,
IDE05842-MAS07561,Comfort function history data-Sun roof/tilt roof,not active,
IDE05842-MAS07941,Comfort function history data-Operating command,Open,
IDE06012-MAS01737,Search lights-Diagnosis,not coded/not installed,
IDE06012-MAS02248,Search lights-Signal state,not active,
IDE06012-MAS03873,Search lights-Duty cycle,0.0, %
IDE06012-MAS04351,Search lights-Connector terminal number,0,
IDE06012-MAS04352,Search lights-Connector number,Plug A,
IDE06012-MAS15156,Search lights-terminal,not_defined,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,-20.3, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,5.5, °C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,46.5, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,-30.9, °C
IDE06096-IDE03111,Interior lighting-Interior light,0, %
IDE06096-IDE05724,Interior lighting-Terminal 58xt dimmer,92.5, %
IDE06096-IDE05725,Interior lighting-Terminal 58xs dimmer,0.0, %
IDE06096-IDE05726,Interior lighting-Terminal 58xd dimmer,95.0, %
IDE06096-MAS01634,Interior lighting-Supply voltage,100.0, %
IDE06096-MAS04528,Interior lighting-Instrument panel and switch illumination dimmer switch,0, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not activated,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,Open,
IDE06470-MAS01737,Ambience lighting-Diagnosis,not coded/not installed,
IDE06470-MAS02248,Ambience lighting-Signal state,not active,
IDE06470-MAS03873,Ambience lighting-Duty cycle,0.0, %
IDE06470-MAS04351,Ambience lighting-Connector terminal number,0,
IDE06470-MAS04352,Ambience lighting-Connector number,Plug A,
IDE06507-MAS13127,Button in center console-Status of button 1,not activated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,On,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not activated,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,OFF,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lights,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Signal horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Parking light,not coded/not installed,
IDE06695-IDE01459,Energy management: last critical state-Energy management heat output control status,0,
IDE06695-MAS00107,Energy management: last critical state-Month,0,
IDE06695-MAS00108,Energy management: last critical state-Day,0,
IDE06695-MAS06555,Energy management: last critical state-Maximum switch-off priority while driving,0,
IDE06695-MAS06570,Energy management: last critical state-Number of critical operation cycles,0,
IDE06695-ENG28924,Energy management: last critical state-Anz_erreichte_Max_Freigaben,0,
IDE06695-ENG28921,Energy management: last critical state-Anz_krit_Betriebszyklen,0,
IDE06695-ENG28922,Energy management: last critical state-Bedingung_Tab_NQ,0,
IDE06695-ENG28920,Energy management: last critical state-min_prio_Tab_K,0,
IDE06695-ENG28919,Energy management: last critical state-min_prio_Tab_M,0,
IDE06695-ENG28923,Energy management: last critical state-min_prio_Tab_NQ,0,
IDE06695-ENG99063,Energy management: last critical state-Year,2000,
IDE06864-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
IDE06864-MAS02248,Daytime running lights-Signal state,not active,
IDE06864-MAS03873,Daytime running lights-Duty cycle,0.0, %
IDE06864-MAS04351,Daytime running lights-Connector terminal number,0,
IDE06864-MAS04352,Daytime running lights-Connector number,Plug A,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,42.80, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,801.9, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,5.000, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,126, %
IDE07344-MAS02447,Sunroof shade-Release,active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,not activated,
IDE07345,Sunroof front closed position switch,not activated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,closed,
IDE07346,Sunroof shade switches,not activated,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left cabin heater-PTC heater element: current consumption,not coded/not installed,
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right cabin heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08177-MAS06456,Central locking-Autolock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,closed,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Signal from door lock: released,
IDE08177-ENG09185,Central locking-Load_compartment_closing,not coded/not installed,
IDE08211-MAS00106,History data control module reset-Year,2017,
IDE08211-MAS00107,History data control module reset-Month,11,
IDE08211-MAS00108,History data control module reset-Day,9,
IDE08211-MAS00109,History data control module reset-Hours,0,
IDE08211-MAS00110,History data control module reset-Minutes,0,
IDE08211-MAS03129,History data control module reset-Reset counter,7,
IDE08211-MAS06734,History data control module reset-last cause of reset,Analysis 1,
IDE08343,Immobilizer Challenge,66 F0 F5 DC,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,1136, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,1248, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,32, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,32, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,13, mA
IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,20, mA
IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,20, mA
IDE08949-MAS07901,Operating current: light driver-Conn. pin 34,16, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,2,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,not coded/not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal,not installed / not active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,not installed / not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,not installed / not active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,not installed / not active,
IDE11134-IDE03310,Light sequence HU test result-Brake light,not installed / not active,
IDE11134-IDE03638,Light sequence HU test result-static AFS light,not installed / not active,
IDE11134-IDE05323,Light sequence HU test result-Fog light,not installed / not active,
IDE11134-IDE05839,Light sequence HU test result-Parking light,not installed / not active,
IDE11134-IDE06470,Light sequence HU test result-Ambience lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,not installed / not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,not installed / not active,
IDE11134-MAS03835,Light sequence HU test result-Parking light,not installed / not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog light,not installed / not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,327670, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,327670, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED not installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,Driving program,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11943-MAS01737,Signature light-Diagnosis,not coded/not installed,
IDE11943-MAS02248,Signature light-Signal state,not active,
IDE11943-MAS03873,Signature light-Duty cycle,0.0, %
IDE11943-MAS04351,Signature light-Connector terminal number,0,
IDE11943-MAS04352,Signature light-Connector number,Plug A,
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,Not Present,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,not coded/not installed,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,not coded/not installed,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear Window Wiper,not coded/not installed,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,not_defined,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,not_defined,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,not_defined,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,not coded/not installed,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,not coded/not installed,
IDE12940-MAS01288,Lever functions of the steering column electronics-Signal horn,not coded/not installed,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,not coded/not installed,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,not coded/not installed,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,not coded/not installed,
IDE12940,Lever functions of the steering column electronics,not coded/not installed,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Supply voltage: Terminal 30-Voltage terminal 30,13.15, V
MAS00043-IDE05835,Supply voltage: Terminal 30-Supply voltage for central locking,13.15, V
MAS00043-IDE05967,Supply voltage: Terminal 30-Voltage terminal 30 left,13.20, V
MAS00043-IDE05968,Supply voltage: Terminal 30-Voltage terminal 30 right,13.15, V
MAS00043-IDE08734,Supply voltage: Terminal 30-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Supply voltage: Terminal 30-Supply voltage for seat heater,13.15, V
MAS00043-MAS00362,Supply voltage: Terminal 30-Battery voltage,5.00, V
MAS00043-MAS07472,Supply voltage: Terminal 30-Battery voltage BEM,13.20, V
MAS00043-MAS07473,Supply voltage: Terminal 30-Test voltage rear window defogger,0.06, V
MAS00043-MAS07474,Supply voltage: Terminal 30-Test voltage windshield defogger,0.00, V
MAS00179-MAS04422,Brake Light Switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake Light Switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,8,
MAS00464-MAS00109,Standard - ambient data 1-Hours,1,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,42,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,6,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,78, km
MAS00829-MAS00244,Access and start authorization-Awakening wire,operated,
MAS00829-MAS01763,Access and start authorization-Signal Strength,-46,
MAS00829-MAS07866,Access and start authorization-Duration: last awakening wire actua.,0, ms
MAS01281-MAS01737,Back-up light-Diagnosis,normal,
MAS01281-MAS02248,Back-up light-Signal state,not active,
MAS01281-MAS03873,Back-up light-Duty cycle,0.0, %
MAS01281-MAS04351,Back-up light-Connector terminal number,11,
MAS01281-MAS04352,Back-up light-Connector number,Plug C,
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,not activated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge condition,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in detection area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heater,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,Enabling stage 3,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,Enabling stage 3,
MAS01490-MAS01564,Energy management-Windshield defogger,Enabled,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,31,
MAS01490-MAS05795,Energy management-Rear seat heater,Enabled,
MAS01490-MAS05796,Energy management-Emergency shut-down,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,Enabled,
MAS01490-MAS06552,Energy management-Seat heater front,Enabling stage 3,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,5,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance drive,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Adapted,
MAS01597-MAS02282,Sunroof-Position,0, %
MAS01597-MAS02447,Sunroof-Release,active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,normed,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835-MAS01737,Parking light-Diagnosis,normal,
MAS03835-MAS02248,Parking light-Signal state,active,
MAS03835-MAS03873,Parking light-Duty cycle,100.0, %
MAS03835-MAS04351,Parking light-Connector terminal number,39,
MAS03835-MAS04352,Parking light-Connector number,Plug B,
MAS03836-MAS01737,Rear fog light-Diagnosis,normal,
MAS03836-MAS02248,Rear fog light-Signal state,not active,
MAS03836-MAS03873,Rear fog light-Duty cycle,0.0, %
MAS03836-MAS04351,Rear fog light-Connector terminal number,60,
MAS03836-MAS04352,Rear fog light-Connector number,Plug A,
MAS07959-IDE00787,Remote start history data-Cause for cancellation,Vehicle movement recognized,
MAS07959-MAS00107,Remote start history data-Month,0,
MAS07959-MAS00108,Remote start history data-Day,0,
MAS07959-MAS00109,Remote start history data-Hours,0,
MAS07959-MAS00110,Remote start history data-Minutes,0,
MAS07959-MAS07960,Remote start history data-Stop or cancel cause,Remote start function active,
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,22860, lx
MAS08228-MAS04121,Light sensor-Voltage,25.4, V
MAS13141,Test voltage,0, V
ENG116910,Control unit internal measured value (supplier),00 00 00 01 1A 00 1A 00 64 00 00 0B 51 00 00 00 00 00 00 00 00 00 00 00 00 02 00 03 00 09 50 B6 00 00 0C 13 00 00 07 15 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 0A 00 06 00 00 00 00 00 00 07 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 05 00 01 00 00 00 00 4F 64 07 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 00 81 14 4F 00 00 10 00 04 4C 07 87 00 20 00 00 40 C1 40 32 E9 0F 00 00 00 25 72 6D 00 3B 00 00 00 00 00 00 00 00 00 00 00 00 09 01 00 00 00 00 02 00 00 00 00 00 00 00 00 8F 03 00 00 00 00 00,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,Pin C14 Kessy Weckleitung,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,0,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG116813-ENG28575,Entwicklermesswerte_CONTI-KurzSchlussZaehler,0,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,active,
ENG116909-ENG114948,LIN activity-LIN 3,active,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,not coded/not installed,
ENG116909-ENG114951,LIN activity-LIN 6,not coded/not installed,
ENG128380,Parametermonitor_0,84 14 64 64 AA 00 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 FA 64 05 C8 1E 00 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 3C 19 E1 32 0A 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 02 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 05 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 19 0A 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,C8 02 32 00 5A FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 5A 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 1E 0A 0B 0B 01 64 64 03 0A 05 01 0A 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 04 03 B4 00 0A 05 05 0A 4B 00 32 0A 00 00 1E 00 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 0A 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 51 32 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653-MAS00107,Personalized_Account_Key_History-Month,0,
ENG126653-MAS00108,Personalized_Account_Key_History-Day,0,
ENG126653-MAS00109,Personalized_Account_Key_History-Hours,0,
ENG126653-MAS00110,Personalized_Account_Key_History-Minutes,0,
ENG126653-MAS01551,Personalized_Account_Key_History-Key number,0,
ENG126653-ENG28771,Personalized_Account_Key_History-Account,0,
ENG126652-MAS03692,Personalized_key__Setting-Key 1,0,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,0,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654-MAS00107,Personalized_Signals-Month,0,
ENG126654-MAS00108,Personalized_Signals-Day,0,
ENG126654-MAS00109,Personalized_Signals-Hours,0,
ENG126654-MAS00110,Personalized_Signals-Minutes,0,
ENG126654-ENG30061,Personalized_Signals-Perso_Aktiv,0,
ENG126654-ENG28925,Personalized_Signals-Perso_Bedienstelle,0,
ENG126654-ENG28926,Personalized_Signals-Perso_Freigabe_Verstellung,0,
ENG126654-ENG28772,Personalized_Signals-Perso_Konto,0,
ENG126654-ENG28775,Personalized_Signals-Perso_Status,0,
ENG126654-ENG28773,Personalized_Signals-Perso_Steuerung,0,
ENG126654-ENG28774,Personalized_Signals-Perso_Steuerungs_parameter,0,
ENG116792-ENG115817,Power up history-Funktionsanforderung,19,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,0,
ENG116790-MAS00711,Supply voltage history-Odometer reading,11, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.0, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,13.1, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,13.1, V
ENG116791,Temperatures,4.50, °C
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,not activated,
ENG116907-IDE07956,Zusaetzliche Umgebungsdaten-redundant signal line,infinite,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside air temperature,4.5, °C
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,not activated,
ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Parking light,not activated,
ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,13.1, V
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,not activated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,not activated,
ENG116907-ENG124952,Zusaetzliche Umgebungsdaten-last_wakeup,Pin C14 Kessy Weckleitung,
ENG116907-ENG09169,Zusaetzliche Umgebungsdaten-LDS 0-Stellung,operated,
ENG116907-ENG115838,Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN),OFF,
ENG116907-ENG115837,Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW),OFF,
Elapsed Time: 00:52
Newer fresher map:
;SW:5Q0-937-085-BN   HW:5Q0-937-085-BF ---  Cent. Elect. --- SA: 31347
;Tuesday,05,June,2018,09:39:30:38124
;VCDS Version: Beta 18.5.2 (x64)  Data version: 20180518 DS291.0
;VCID: 06569C70C8AE63F7BC7-8052
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active ,3
IDE01550-Service position,133.197670 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,300 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,300 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,300 ms,10
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,16 s,8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,not active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,1000 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,16
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °,16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,32.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,OFF ,16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE03787-Activate left/right hand drive switch-over,No_Menue ,1
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,not active ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,11
IDE04928-MAS01577-Anti-theft device-Parking heater,not installed ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor,installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),Yes ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,1 Alarm ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 61 49 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 62 4A 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 1A 0B 00 7F 1E 00 7F 00 00 00 00 00 00 06 40 00 1B 0C 00 7F 1E 00 7F 00 00 00 00 00 00 06 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 06 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 5D 28 1E 7F 00 00 00 00 00 00 00 00 00 06 40 00 5E 28 1E 7F 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,28.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,27.50 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,28.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,27.50 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,40.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,40.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,63.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,62.50 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,63.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,62.50 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED not installed ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,21.197781 °,2
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,not active ,6
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,2 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.00 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,0 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,0 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,0 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,0 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,0 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,active ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,installed ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
IDE10298-Alternating park position 1,18.197784 °,2
IDE10299-Alternating park position 2,21.197781 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,1.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,100 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,100 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,active ,3
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
MAS05055-lower turn position,26.197776 °,2
MAS05056-upper turn position,166.197637 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,0.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,0.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,0.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,0.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,0.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,0.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,0.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,0.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,0.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,0.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,0.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,0.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,0.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,0.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,0.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,NOT-DEFINED ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,NOT-DEFINED ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,NOT-DEFINED ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,NOT-DEFINED ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,NOT-DEFINED ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,NOT-DEFINED ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,NOT-DEFINED ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,NOT-DEFINED ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,NOT-DEFINED ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,NOT-DEFINED ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,NOT-DEFINED ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,NOT-DEFINED ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,NOT-DEFINED ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,NOT-DEFINED ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,NOT-DEFINED ,30
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Sollspannungsanforderung 13.5 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,4 km/h,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,active ,9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,active ,9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,installed ,9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit,active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,60 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion,active ,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,installed ,18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht,bewusste Aktivierung Fahrer Dauerhaft ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x1 Stunden ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,6400 lx,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,separate ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),LIN ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,20 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,60 seconds ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,not active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,8 s,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Keine_Spannungsanforderung ,18
ENG122934-erase_error_table,55 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,500 ms,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,not active ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,2000 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG99457-ENG117394-Head area heater-blower_speed,0 ,2
ENG99457-ENG98971-Head area heater-Temperature,-3 ,2
ENG141645-ENG142026-HW_Verbau-Druckklappe,installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,installed ,8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,not active ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,active ,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-0.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-0.10 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-0.60 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-1.10 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-1.60 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-2.10 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-2.60 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-3.10 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-3.60 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-4.10 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,89.5 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,83.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,75.5 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,68.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,61.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,56.5 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,47.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,40.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,33.0 %,30
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,127 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,5D ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,36 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Coming Home oder Leaving Home aktiv ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,127 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,5E ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,40 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Coming Home oder Leaving Home aktiv ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,85 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,35 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,0A ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Coming Home oder Leaving Home aktiv ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,85 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,36 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,1A ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Coming Home oder Leaving Home aktiv ,16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,minimize ,16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,minimize ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,127 ,16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,3F ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Brake light ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,Blinken links aktiv (beide Phasen) ,16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,Blinken links Hellphase ,16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,Blinken links Dunkelphase ,16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,minimize ,16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,minimize ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,127 ,16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,40 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Brake light ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,Blinken rechts aktiv (beide Phasen) ,16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,Blinken rechts Hellphase ,16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,Blinken rechts Dunkelphase ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,04 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,46 - LED Kleinleistung ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Ambientelicht 2 ,16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,minimize ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,0 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,127 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,127 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,35 - kombinierte LED Blink-Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,not active ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Brake light ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Blinken links Hellphase ,16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,Blinken links Dunkelphase ,16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,minimize ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,0 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,127 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,127 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,35 - kombinierte LED Blink-Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,not active ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Brake light ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Blinken rechts Hellphase ,16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,Blinken rechts Dunkelphase ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,80 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,50 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,80 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,50 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Parking light right ,16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,127 ,16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,beidseitiges Dauerparklicht ,16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,minimize ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,37 - allgemeine LED bis 12W ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,Left high beam ,16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,37 - allgemeine LED bis 12W ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Right high beam ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,37 - allgemeine LED bis 12W ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,127 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,61 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,36 - LED Kleinleistung ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Unknown (73),16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100 ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,127 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,62 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,36 - LED Kleinleistung ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Unknown (74),16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,6 - LED Lichtmodul ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,6 - LED Lichtmodul ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 3F 18 00 7F 1A 06 80 02 00 7F 03 00 80 26 18 00 40 18 00 7F 1A 07 80 04 00 7F 05 00 80 23 13 00 3D 00 00 00 18 00 7F 02 00 7F 03 00 80 23 23 00 3E 00 00 00 18 00 7F 04 00 7F 05 00 80 2A 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 1E 50 09 00 32 00 00 00 00 00 00 2B 1A 00 2A 08 1E 50 0A 00 32 00 00 00 00 00 00 2B 28 00 30 08 1E 7F 3A 00 7F 00 00 00 00 00 00 25 0C 00 2E 1A 00 64 0D 00 80 00 00 00 00 00 00 25 1C 00 2F 1A 00 64 0E 00 80 00 00 00 00 00 00 25 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 25 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,2B 0A 00 35 08 1E 55 00 00 00 00 00 00 00 00 00 2B 1A 00 36 08 1E 55 00 00 00 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 64 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 64 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 64 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2650 mm,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,84.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,20.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-127.0 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,4.10 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,4.70 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,4.50 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.30 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.30 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,3.30 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_2 ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,70.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.10 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,Inverted ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,10 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,10 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,10 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,10 mm,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,5 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,10.00 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,not active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,60.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,5.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,20.0 %,62
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-0.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-0.55 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-1.10 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-2.40 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-2.80 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,0.30 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,0.20 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,0.80 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-4.60 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.20 ,20
ENG124714-ENG142261-OCU-Remote HuF Abbruch,0 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,0 Hz,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,0 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,0 ms,8
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,0 ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,not active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Audi ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,installed ,5
ENG122927-RLS_close_glazing,2.5 s,1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,100 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,200 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,8 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,1000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1200 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,1000 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,1000 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,1200 ms,10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Sollspannungsanforderung 13.5 ,10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,10.0 min,10
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,Potentiometer ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,5 ,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,50 %,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.248 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,1.0 %,21
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,6.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,6.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,16.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,30.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,60.0 %,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,not active ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,active ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,nur wenn freigegeben ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,not active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,not active ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,42 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,62 ,3
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,not active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,unidirectional ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,active ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Pulse control ,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5
Elapsed Time: 01:41
Andy
Sector 7G
HC424490
10 - Park/Steer Assist maps
;SW:5QA-919-294-B   HW:5QA-919-294 ---  Park/Steer Assist
;Component:PDC 8 KanalH07 0044, Coding:0470155811
;EV_EPHVA18AU3700000,009035,EV_EPHVA18AU3700000_009_AU37.rod
;Friday,08,December,2017,16:10:54:29905
;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
;VCID: 4BD9E467E2B1C17263D-801E
IDE00820-ENG118120-Activating and deactivating all development messages-Dev_Id_High_Nibble,not activated ,1
IDE00820-ENG118119-Activating and deactivating all development messages-Dev_Id_Low_Nibble,not activated ,1
IDE00845-Wheel circ.,1950 mm,2
IDE01167-Convertible offset for volume level 1,255 ,1
IDE01168-Increment for convertible volume levels,255 ,1
IDE01169-Audio reduction request,On ,1
IDE02328-Distance to curb,15 cm,1
IDE03782-Switch-off speed for parking assist,10 km/h,1
IDE05274-Acoustic warning for rear lid assistant,not active ,1
IDE11215-Automatic Activation,activated ,1
MAS01426-Speaker volume for rear park assist,Stage 6 ,1
MAS01427-Speaker frequency for rear park assist,Stage 4 ,1
MAS01428-Speaker volume for front park assist,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 6 ,1
MAS10106-MAS10103-ARA angle control parameter-Max. controllable corners,0.159 1/m,6
MAS10106-MAS10104-ARA angle control parameter-Max. selectable corners,1.308 1/m,6
MAS10106-MAS10105-ARA angle control parameter-Vehicle overhang,0.807 m,6
Elapsed Time: 00:09
;Friday,08,December,2017,16:10:41:29905
Group,Description,Actual
IDE00018,Voltage terminal 15,12.8, V
IDE00325,Diagnostic mode,VW - diagnostic mode,
IDE00957-MAS01632,Resulting distance of front sensors-Status,infinite,
IDE00958-MAS01632,Resulting distance of rear sensors-Status,infinite,
IDE00973,Outside air temperature,5.00, °
IDE00974,Outside air temperature internally calculated,5.00, °
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,not installed,
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,infinite,
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,infinite,
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,infinite,
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,infinite,
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,infinite,
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,ERROR,
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,ERROR,
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,ERROR,
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,ERROR,
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,ERROR,
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,ERROR,
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,ERROR,
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,ERROR,
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Speaker volume for rear park assist,Stage 4,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 6,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Speaker volume for front park assist,Stage 4,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 4,
IDE01163,Sound output for park assist in selector lever position P,OFF,
IDE01164,Park assist button,not activated,
IDE01165,Park assist activation tone,On,
IDE01166,Supply voltage for park assist sensor,12.8, V
IDE01167,Convertible offset for volume level 1,not installed,
IDE01168,Increment for convertible volume levels,not installed,
IDE01169,Audio reduction request,Yes,
IDE01171,Convertible factory setting offset for volume level 1,not installed,
IDE01172,Factory setting for increment for convertible volume levels,not installed,
IDE01173,Audio reduction factory setting,No,
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,activated,
IDE01411-MAS01426,Personalization 1 for park assist-Speaker volume for rear park assist,Stage 6,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01411-MAS01428,Personalization 1 for park assist-Speaker volume for front park assist,Stage 4,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,Parking aid active,
IDE01411-MAS12843,Personalization 1 for park assist-Maneuvering brake function,activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01412-MAS01428,Personalization 2 for park assist-Speaker volume for front park assist,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,not active,
IDE01412-MAS12843,Personalization 2 for park assist-Maneuvering brake function,not activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01413-MAS01428,Personalization 3 for park assist-Speaker volume for front park assist,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12843,Personalization 3 for park assist-Maneuvering brake function,not activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01414-MAS01428,Personalization 4 for park assist-Speaker volume for front park assist,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12843,Personalization 4 for park assist-Maneuvering brake function,not activated,
IDE01588,Driving direction,forwards,
IDE01632,System condition of park assist,not active,
IDE01633,Cause of park assist switching off,No shut-off requirement,
IDE01943,Turn signal,not activated,
IDE03782,Switch-off speed for parking assist,10, km/h
IDE03784,Temporary function limitation due to environmental influences,No,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,8,
MAS00464-MAS00109,Standard - ambient data 1-Hours,1,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,52,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,6,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,78, km
MAS01426,Speaker volume for rear park assist,Stage 6,
MAS01427,Speaker frequency for rear park assist,Stage 4,
MAS01428,Speaker volume for front park assist,Stage 4,
MAS01429,Speaker frequency for front park assist,Stage 6,
MAS10122,ARA operating condition,Initializing,
MAS10122-MAS11700,ARA operating condition-ARA function request door control module,no request,
ENG113995,Dimming_Signal_Terminal_58xd_pdc_pla,0, %
Elapsed Time: 00:13
Andy
Sector 7G
HC424490
13 - Auto Dist. Reg maps
;SW:5Q0-907-572-G   HW:5Q0-907-572-G ---  Auto Dist. Reg
;Component:ACC BOSCH MQB H10 0571, Coding:D50087C119FFC428949C8055000026
;EV_ACCBOSCHVW416,001005,EV_ACCBOSCHVW416_001_VW37.rod
;Friday,08,December,2017,16:11:20:29905
;VCID: 3B39B4A7B21171F2D3D-806E
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
IDE01795-Heated lens,On ,1
IDE01949-Distance basic setting option,OFF ,1
IDE05815-Sail function,Deactivating ,1
IDE08935-Expanded restart function,OFF ,1
IDE09564-Distance change via speed adjustment,OFF ,1
IDE09565-Prioritized target object display,OFF ,1
IDE10280-Constant delay after transfer request,Yes ,1
Elapsed Time: 00:05
;Friday,08,December,2017,16:11:07:29905
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,13.0, V
IDE00102,Control Module temperature,17, °C
IDE01788,Heated lens control signal,0.00, %
IDE01794,ACC operating lever signal,00000000 01001000 ,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,72 A5 7A 7B,
IDE03008-MAS12557,Stop process prevented-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,not active,
IDE03008-MAS12559,Stop process prevented-Driving ahead Vehicles start moving: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Driving ahead Vehicles are starting: ACC off,not active,
IDE03010-MAS12557,Number of prevented stop processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
IDE03010-MAS12559,Number of prevented stop processes-Driving ahead Vehicles start moving: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Driving ahead Vehicles are starting: ACC off,0,
IDE03011-MAS12557,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
IDE03011-MAS12558,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting possible,0,
IDE03011-MAS12559,Number of requested start processes-Driving ahead Vehicles start moving: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Driving ahead Vehicles are starting: ACC off,0,
IDE03203,Alignment instructions,Set mirror in posit 1 and start measurement,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 31 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,Yes,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition not met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C9 37 8A 27 80 D8 2C 8D 73 BC DC 20 E7 9C 7C D0 9F 3A 9E EE 13 AB 53 8E 4B E5 96 5C 6B C2 9E CC 51 13 00 E5 1A 81 6F 28 6B 3D 28 B8 9B D9 80 37 13 BB 54 73 69 96 5B 5F D2 C8 3A 8E F0 69 43 40 DE 8E B4 F4 B1 6A A1 C3 06 F3 BC F8 5E 8B D2 E1 04 7E 13 4A 72 CF 2C 3B 52 8E 85 73 72 45 4A 66 7A 01 9A D2 C6 E1 DD 6E BD C7 AF 95 04 BB BA C2 E5 47 D4 58 9C 8C 57 D9 99 B2 E2 AC B3 81 23 6F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,1,
IDE04805-MAS01448,Driving profile selection-Specified value,1,
IDE05814,Individualization characteristic,71 FC FC 7C DD,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08768,Mirror deviation: horizontal,0.089, °
IDE08769,Mirror deviation: vertical,-0.593, °
IDE08770-MAS01466,Adjustment of screw top left-Direction of rotation,none,
IDE08770-MAS02559,Adjustment of screw top left-Rotations,0.00,
IDE08771-MAS01466,Adjustment of screw top right-Direction of rotation,none,
IDE08771-MAS02559,Adjustment of screw top right-Rotations,0.00,
IDE08772-MAS01466,Adjustment of screw bottom left-Direction of rotation,none,
IDE08772-MAS02559,Adjustment of screw bottom left-Rotations,0.00,
IDE08773-MAS01466,Adjustment of screw bottom right-Direction of rotation,none,
IDE08773-MAS02559,Adjustment of screw bottom right-Rotations,0.00,
IDE08936,Misalignment angle: horiz,0.147, °
IDE08937,Misalignment angle: horiz: fast algorithm,0.287, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,-0.11, °
IDE09380-MAS00106,Performed adjustment-Year,17,
IDE09380-MAS00107,Performed adjustment-Month,11,
IDE09380-MAS00108,Performed adjustment-Day,10,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,0.08, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,2.10, °
IDE09906,Vertical deadjustment,2.068, °
ENG107409,Longitudinal_acceleration_vehicle_reference,0.00, m/s²
ENG107860,Number_of_ANB_partial_bracings,0,
ENG107861,Number_of_ANB_target_bracings,0,
ENG107862,Number_of_ANB-CM,0,
ENG00926,Number_of_boost_function_active,0,
ENG00927,Number_of_deactivation_ASR_active,0,
ENG00928,Number_of_deactivation_ESC_active,0,
ENG00913,Number_of_Emergency_steer_assist,0,
ENG00915,Number_of_fully_developed_deceleration_1,0,
ENG00916,Number_of_fully_developed_deceleration_2,0,
ENG06681,Number_of_mainwarnings,0,
ENG03998,number_of_prewarnings,0,
ENG00914,Number_of_Turn_off_assistant_intervention,0,
ENG107928,Operating_time_ACC,5, min
ENG00919,Operating_time_ACC_active_driving_programm_auto,0, min
ENG00918,Operating_time_ACC_active_driving_programm_comfort,5, min
ENG00917,Operating_time_ACC_active_driving_programm_dynamic,0, min
ENG00920,Operating_time_ACC_active_driving_programm_efficiency,0, min
ENG00921,Operating_time_ACC_active_timegap_1,4, min
ENG00922,Operating_time_ACC_active_timegap_2,0, min
ENG00923,Operating_time_ACC_active_timegap_3,0, min
ENG00924,Operating_time_ACC_active_timegap_4,0, min
ENG00925,Operating_time_ACC_active_timegap_5,0, min
ENG00929,Operating_time_ACC_active_v-delta_0,5, min
ENG00932,Operating_time_ACC_active_v-delta_large,0, min
ENG00931,Operating_time_ACC_active_v-delta_medium,0, min
ENG00930,Operating_time_ACC_active_v-delta_small,0, min
ENG00933,Operating_time_STA_active,0, min
ENG00934,Operating_time_STA_off_activation_possible,0, min
ENG00935,Status_ACC_System,ACC_Off_MainSwitch_Off,
ENG08760,Sw_version_supplier,1037603449;PF_R28.3.0_VW.MQB_A1_GPevo14.0571_I3.3;0;Compiled by BBT2BP on Thu Apr  7 17:50:31 2016$!,
ENG109878,Velocity_vehicle_reference,0.00, m/s
Elapsed Time: 00:13
Andy
Sector 7G
HC424490
15 - Airbags maps
;SW:5Q0-959-655-J   HW:5Q0-959-655-J ---  Airbags
;Component:AirbagVW20    010 0830, Coding:9DFCFCC0002000009000001AC24800000065
;EV_AirbaVW20SMEVW37X,002144,EV_AirbaVW20SMEVW37X_VW37.rod
;Friday,08,December,2017,16:11:44:29905
;VCID: 47D1D857FED92512475-8012
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 DF ,18
IDE06527-IDE06311-Adaptation pre-crash-Seat belt tensioner: left,activated ,4
IDE06527-IDE06312-Adaptation pre-crash-Seat belt tensioner: right,activated ,4
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,activated ,8
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated ,8
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,activated ,8
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated ,8
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,activated ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,activated ,8
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined ,8
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch not parameterized ,8
Elapsed Time: 00:02
;Friday,08,December,2017,16:11:33:29905
IDE00821,Safety belt switch 2nd row driver side,not installed,
IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
IDE00823,Safety belt switch 2nd row center,not installed,
IDE00824,Driver side 3rd row seat belt switch,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,3.0, Ohm
IDE00956,Occupation status: frt.passenger seat,Adult,
IDE01100,Passenger side airbag igniter ohm value,2.3, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,2.2, Ohm
IDE01102,Driver's side airbag igniter ohm value,2.5, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.5, Ohm
IDE01104,driver side rear airbag igniter ohm value,2.5, Ohm
IDE01105,Ft. pass.side rear airbag igniter ohm value,2.5, Ohm
IDE01106,Driver side head curtain airbag igniter ohm value,2.4, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.4, Ohm
IDE01108,Driver side knee airbag igniter ohm value,2.3, Ohm
IDE01109,Frt.pass. side knee airbag igniter ohm value,2.1, Ohm
IDE01110,Driver side belt tensioner igniter ohm value,2.4, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.4, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,2.3, Ohm
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,2.3, Ohm
IDE01114,Driver side belt force limiter igniter ohm value,2.4, Ohm
IDE01115,side belt force limiter igniter ohm value,2.3, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,2.4, Ohm
IDE01117,Passenger side rear belt tensioner igniter ohm value,2.4, Ohm
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,400.0, Ohm
IDE01194,Frt.pass. belt tensioner ohm value,too Low,
IDE01195,Sitzbelegungserkennung Beifahrerseite Ohm-Wert,no measured value present,
IDE01197,Key switch contact 1 ohm value,too High,
IDE01198,Key switch contact 2 ohm value,too High,
IDE01200,Driver seat position sensor current value,5.9, mA
IDE01201,Frt.pass. seat position sensor current value,5.6, mA
IDE01205,Safety belt switch 2nd row driver side ohm value,no measured value present,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,no measured value present,
IDE01207,Safety belt switch center 2nd row ohm value,no measured value present,
IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01555,Number of frontal crashes,0,
IDE02852,Igniter for battery interrupt: high voltage battery,correct,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,3.1, Ohm
IDE03870,Seat occupied recognition malfunction status,00,
IDE03870,Seat occupied recognition malfunction status,0,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,performed,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE06109,Right belt tensioner terminal 15,13.0, V
IDE06110,Right belt tensioner supply voltage,correct,
IDE06118,Right belt tensioner current consumption,no measured value present,
IDE06119,Left belt tensioner tensioning cycles charac. curve 1,0,
IDE06120,Left belt tensioner tensioning cycles charac. curve 2,0,
IDE06123,Right belt tensioner tensioning cycles charac. curve 1,0,
IDE06124,Right belt tensioner tensioning cycles charac. curve 2,0,
IDE06127,Left belt tensioner terminal 15,13.1, V
IDE06128,Left belt tensioner temperature,12.5, °C
IDE06129,Right belt tensioner temperature,11.5, °C
IDE06130,Left belt tensioner supply voltage,correct,
IDE06131,Left belt tensioner current consumption,no measured value present,
IDE06959,Seat occupant detection: diagnosis signal,1.0, %
IDE06960,Seat occupant detection: msmt. signal,14.5, %
IDE06961,Seat occupant detection: ref. signal,15.5, %
MAS00001,Driver airbag igniter,correct,
MAS00003,Passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,correct,
MAS00008,Passenger side rear thorax airbag igniter,correct,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,correct,
MAS00012,Front passenger knee airbag igniter,correct,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver seat belt tensioner igniter 2,correct,
MAS00016,Front passenger side seat belt tensioner igniter 2,correct,
MAS00017,Driver side belt force limiter igniter,correct,
MAS00018,Front passenger side belt force limiter igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,correct,
MAS00020,Passenger side rear safety belt tension igniter,correct,
MAS00022,Igniter for battery interrupt,not installed,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,assigned,
MAS00031,Airbag deactivation status,On,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,Rear,
MAS00036,Seat position sensor: front passenger side,Rear,
MAS00037,Calibration status,0,
MAS00044,Supply voltage: Terminal 15,13.1, V
MAS01634,Supply voltage,correct,
Elapsed Time: 00:11
Andy
Sector 7G
HC424490
16 - Steering wheel maps
;SW:8V0-953-521-KF   HW:5Q0-953-549-E ---  Steering wheel
;Component:Lenks. Modul  003 0140, Coding:6C18
;EV_SMLSKLOMQB,020002,EV_SMLSKLOMQB_020_AU37.rod
;Friday,08,December,2017,16:11:54:29905
;VCID: 08531B6BB347EA6A8EF-805C
ENG126411-p_k_i,0.040 %/s,1
ENG126415-p_k_i_offset,4 K,1
ENG126410-p_k_p,13.0 %,1
ENG126419-p_leistung_lrh,110 W,1
ENG126417-p_n_fehler_p_verriegelt,250 ,1
ENG120504-p_s_NWDF_spg,00000000  ,1
ENG102189-p_t_blinker_entprellen,40 ms,1
ENG102332-p_t_blinker_err_el_kurzschluss,200 ms,1
ENG104011-p_t_blinker_err_el_unterbrechung,1000 ms,1
ENG120503-p_t_blinker_err_fernlicht_haengt_aus,5000 ms,1
ENG120502-p_t_blinker_err_fernlicht_haengt_ein,300 s,1
ENG104185-p_t_blinker_err_gra_haengt_aus,5000 ms,1
ENG100988-p_t_blinker_err_gra_haengt_ein,300 s,1
ENG103202-p_t_blinker_err_lichthupe_haengt_aus,5000 ms,1
ENG100154-p_t_blinker_err_lichthupe_haengt_ein,300 s,1
ENG100923-p_t_blinker_err_unplausibel,200 ms,1
ENG103471-p_t_blinker_gra_entprellen,40 ms,1
ENG101294-p_t_blinker_sperrzeit,100 ms,1
ENG127114-p_t_entprellung_p_unplausibel,400 ms,1
ENG104033-p_t_entprellzeit_ueberspannung,90000 ms,1
ENG101392-p_t_entprellzeit_unterspannung,90000 ms,1
ENG102689-p_t_fas_entprellen,40 ms,1
ENG120505-p_t_gra_ea_error,200 ms,1
ENG101014-p_t_grahebel_entprellen,40 ms,1
ENG104117-p_t_grahebel_err_el_kurzschluss,200 ms,1
ENG102950-p_t_grahebel_err_el_unterbrechung,1000 ms,1
ENG103784-p_t_grahebel_err_gra_haengt_aus,5000 ms,1
ENG102546-p_t_grahebel_err_gra_haengt_ein,300 s,1
ENG103536-p_t_grahebel_err_unplausibel,200 ms,1
ENG126416-p_t_grenze_v,10 km/h,1
ENG99436-p_t_hupe_entprellen,40 ms,1
ENG102496-p_t_hupe_err_hinweis,2000 ms,1
ENG101071-p_t_hupe_err_hupe_haengt_aus,5000 ms,1
ENG101518-p_t_hupe_err_hupe_haengt_ein,60 s,1
ENG101702-p_t_hupe_indien_entprellen,500 ms,1
ENG126421-p_t_lrh_kurzschluss_entprellen,200 ms,1
ENG126422-p_t_lrh_unterbrechung_entprellen,1000 ms,1
ENG103999-p_t_p_verriegelt_entprellen,40 ms,1
ENG126412-p_t_soll_0,39 °C,1
ENG126413-p_t_soll_1,43 °C,1
ENG126414-p_t_soll_2,47 °C,1
ENG100796-p_t_spannung_obere_schwelle,16.7 V,1
ENG102338-p_t_spannung_untere_schwelle,8.5 V,1
ENG100559-p_t_wischer_entprellen,40 ms,1
ENG103039-p_t_wischer_err_el_kurzschluss,200 ms,1
ENG101343-p_t_wischer_err_el_unterbrechung,1000 ms,1
ENG108143-p_t_wischer_err_intervallpoti_haengt_aus,5000 ms,1
ENG102443-p_t_wischer_err_intervallpoti_haengt_ein,300 s,1
ENG101059-p_t_wischer_err_mfa_haengt_aus,5000 ms,1
ENG100346-p_t_wischer_err_mfa_haengt_ein,300 s,1
ENG103464-p_t_wischer_err_waschen_haengt_aus,5000 ms,1
ENG100423-p_t_wischer_err_waschen_haengt_ein,300 s,1
ENG99933-p_t_wischer_err_wischen_haengt_aus,5000 ms,1
ENG102586-p_t_wischer_err_wischen_haengt_ein,300 s,1
ENG101592-p_t_wischer_intervall_entprellen,40 ms,1
ENG103607-p_t_wischer_winterstellung,60 s,1
ENG126423-p_temp_lenkradheizung_aus,50 °C,1
ENG126420-p_zeit_temperatur_statisch_lrh,300 s,1
Elapsed Time: 00:26
;Friday,08,December,2017,16:11:51:29905
IDE00030-ENG99298,Status of actuator test-State,not active,
IDE00329-MAS00232,Buttons for multi-function display-MFI button UP,not coded/not installed,
IDE00329-MAS00233,Buttons for multi-function display-MFI button DOWN,not coded/not installed,
IDE00329-MAS00234,Buttons for multi-function display-MFI button RESET / OK,not coded/not installed,
IDE00329-MAS00236,Buttons for multi-function display-MFI buttons: number 3/4,not coded/not installed,
IDE00329-MAS00688,Buttons for multi-function display-Multifunction indicator,not coded/not installed,
IDE00333,Driver assistance systems button,not activated,
IDE00333-MAS00243,Driver assistance systems button-Buttons for driver assistance systems: status,No malfunction detected,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not activated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not activated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Accelerate tap,not activated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not activated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not activated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not activated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,Distance Regulation,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,not coded/not installed,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Delay tip level 2,not activated,
IDE00356-MAS04523,Cruise Control System (CCS): switch position-Accelerate tip level 2,not activated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,6 Position operating unit,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,On,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,not activated,
IDE02694-MAS01288,Signal horn activation-Signal horn,not activated,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,not activated,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 1,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,not activated,
IDE02696-IDE02711,Rear wiping: rear washing-Rear Window Wiper,not activated,
IDE02696-MAS02341,Rear wiping: rear washing-Rear window washer system,not activated,
IDE02743,High Beam,not activated,
IDE02744-MAS01632,Steering wheel heater-Status,OFF,
IDE02744-MAS04136,Steering wheel heater-Current,0.00, A
IDE02744-MAS09022,Steering wheel heater-PWM value,0, %
IDE02744-MAS09758,Steering wheel heater-Temperature sensor,-50, °C
IDE02745-IDE00096,Ignition key removal lock-Selector lever position,Current,
IDE02745-MAS08202,Ignition key removal lock-CAN p locked,Engaged and locked,
IDE02745-MAS08203,Ignition key removal lock-CAN p locked: qualified,Not qualified,
IDE02745-MAS08204,Ignition key removal lock-Hardware input: p_verriegelt,Open,
IDE02745-MAS08205,Ignition key removal lock-CAN ESP valid speed,Qualified,
IDE02745-MAS08206,Ignition key removal lock-CAN ESP speed,0, km/h
IDE02745-MAS08207,Ignition key removal lock-CAN GWB obsolete transmission,Current,
ENG120506-ENG100300,CCS_in_indic-lever-E: Blinkerhebel GRA Cancel,not activated,
ENG120506-ENG103377,CCS_in_indic-lever-E: Blinkerhebel GRA Fehler,No malfunction detected,
ENG120506-ENG103714,CCS_in_indic-lever-E: Blinkerhebel GRA OFF,not activated,
ENG120506-ENG102330,CCS_in_indic-lever-E: Blinkerhebel GRA ON,not activated,
ENG120506-ENG120475,CCS_in_indic-lever-E: Blinkerhebel GRA Speedlimiter,OFF,
ENG120506-ENG103991,CCS_in_indic-lever-E: Blinkerhebel GRA Tip Resume/Plus,not activated,
ENG120506-ENG100605,CCS_in_indic-lever-E: Blinkerhebel GRA Tip Set/Minus,not activated,
ENG120506-ENG120476,CCS_in_indic-lever-E: GRA_E_A,OFF,
ENG120507-ENG100163,CCS_in_third_lever-E: 3.ter Hebel ADR Fehler,No malfunction detected,
ENG120507-ENG99937,CCS_in_third_lever-E: 3.ter Hebel ADR Minus,not activated,
ENG120507-ENG101800,CCS_in_third_lever-E: 3.ter Hebel ADR Plus,not activated,
ENG120507-ENG101234,CCS_in_third_lever-E: 3.ter Hebel GRA Cancel,not activated,
ENG120507-ENG103820,CCS_in_third_lever-E: 3.ter Hebel GRA Fehler,No malfunction detected,
ENG120507-ENG99143,CCS_in_third_lever-E: 3.ter Hebel GRA OFF,operated,
ENG120507-ENG100333,CCS_in_third_lever-E: 3.ter Hebel GRA ON,not activated,
ENG120507-ENG101903,CCS_in_third_lever-E: 3.ter Hebel GRA Resume,not activated,
ENG120507-ENG101230,CCS_in_third_lever-E: 3.ter Hebel GRA Set,not activated,
ENG120507-ENG129309,CCS_in_third_lever-E: 3.ter Hebel GRA Speedlimiter,not activated,
ENG120507-ENG126425,CCS_in_third_lever-E: 3.ter Hebel GRA Tip 2 Beschleunigen,not activated,
ENG120507-ENG126426,CCS_in_third_lever-E: 3.ter Hebel GRA Tip 2 Verzögern,not activated,
ENG120507-ENG120477,CCS_in_third_lever-E: 3.ter Hebel GRA Tip Beschleunigen,not activated,
ENG120507-ENG120478,CCS_in_third_lever-E: 3.ter Hebel GRA Tip Verzögern,not activated,
ENG120507-ENG120476,CCS_in_third_lever-E: GRA_E_A,OFF,
ENG126424-ENG126428,LRH-LRH_current,0.00, A
ENG126424-ENG126430,LRH-LRH_level,low,
ENG126424-ENG126429,LRH-LRH_status,OFF,
ENG126424-ENG126427,LRH-LRH_temperature_NTC,204, °C
Elapsed Time: 00:02
Andy
Sector 7G
HC424490
17-Instruments and 23 - Brake Booster maps
Edit months later: Oops, looks like I forgot to post 17 maps at the time, so here they are:
17 maps:
;SW:8V0-920-894-A   HW:8V0-920-894-A ---  Instruments
;Component:FBenUSA       H16 0066, Coding:08440C516F88CF050283E8101B00000000000000
;EV_DashBoardFPKAU37X,001027,EV_DashBoardFPKAU37X.rod
;Friday,08,December,2017,16:02:41:29905
;VCID: 3FC1C0B7A6096DD2FF5-806A
IDE00301-Distance,78 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,US English ,1
IDE00500-Hour,16 H,1
IDE00501-Minute,2 min,1
IDE00502-Year,2017 yr,2
IDE00503-Month,12 mon,1
IDE00504-Day,8 d,1
IDE00510-ESI: distance driven from inspection,0 km,3
IDE00511-ESI: time from inspection,2 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,14500 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,14500 km,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00518-ESI: thermal load,0 km,2
IDE00819-Day counter,28 d,2
IDE01153-SIA: maximum value of distance to service,16000 km,2
IDE02489-Display depiction,Version 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.80 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.80 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.70 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.70 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.70 l,5
IDE03329-Driving profiled for range remaining,8.00 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,miles ,3
IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,°F ,3
IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3
IDE03346-MAS03032-Units adjusted-Volume,gallons (US) ,3
IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,32100 km,3
IDE03351-FIX: Distance covered since last mileage-dependent inspection,0 km,3
IDE03352-FIX: Time since last time-dependent inspection,2 d,2
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,OFF ,5
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,Driver door ,1
IDE07579-MAS05872-Driving profile for operating range consump.with electric drive-Operating range average voltage,0.00 A,8
IDE07579-MAS05875-Driving profile for operating range consump.with electric drive-Average consumption: electric drive,1 ,8
IDE07579-MAS05876-Driving profile for operating range consump.with electric drive-Average consumption: low voltage auxiliary consumer,0.00 ,8
IDE07579-MAS05877-Driving profile for operating range consump.with electric drive-Average consumption: high voltage auxiliary consumer,0.10 ,8
IDE07600-ENG114653-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_0,1.10 ,14
IDE07600-ENG114654-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_1,25.00 ,14
IDE07600-ENG114655-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_2,25.00 ,14
IDE07600-ENG114656-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_3,25.00 ,14
IDE07600-ENG114657-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_4,25.00 ,14
IDE07600-ENG114658-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_5,25.00 ,14
IDE07600-ENG114659-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_6,25.00 ,14
IDE08140-Driving profiled for range remaining CNG,0.00 kg/100 km,2
IDE08247-Driving profile for range remaining LPG,0.00 l/100km,2
IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,10.00 l/100km,14
IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1,10.00 l/100km,14
IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2,10.00 l/100km,14
IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3,10.00 l/100km,14
IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4,10.00 l/100km,14
IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5,10.00 l/100km,14
IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6,10.00 l/100km,14
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required,No display ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration_measurement,No display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag_indicator,No display ,4
IDE11472-MAS19086-Configuration of displayable contents-charge_symbol_colour,Standard ,4
IDE12050-Acoustic: drive position R,not active ,1
MAS03555-Lap counter,No display ,1
MAS03685-Digital speedometer,Display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,21
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,21
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,21
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,21
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,21
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,21
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,21
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,21
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,21
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,21
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,21
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,21
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,21
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,21
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,21
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,21
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,21
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,21
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,21
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,21
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,21
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,21
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,21
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,21
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,21
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,21
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,21
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,21
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,21
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,21
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,21
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,21
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,21
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,21
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,21
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,21
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,21
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,21
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,21
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,50ms ,21
ENG128731-MAS01129-designvariant_activation-Version 1,not active ,2
ENG128731-MAS01130-designvariant_activation-Version 2,not active ,2
ENG128731-MAS01131-designvariant_activation-Version 3,not active ,2
ENG128731-MAS03101-designvariant_activation-Version 4,not active ,2
ENG128731-MAS03102-designvariant_activation-Version 5,not active ,2
ENG128731-MAS03103-designvariant_activation-Version 6,not active ,2
ENG128731-MAS03104-designvariant_activation-Version 7,not active ,2
ENG128731-MAS03105-designvariant_activation-Version 8,not active ,2
ENG99320-Developers_menu,not active ,1
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,50 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,02 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,02 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,0E ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,1E ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,14 ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,1E ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,32 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,46 ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,64 ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,00 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,14 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,1E ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,32 ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,46 ,12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64 ,12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC ,12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,02 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,02 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,06 ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,0A ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,50 ,12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 96 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00 ,12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0A ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,50 ,12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64 ,12
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.00 ,16
ENG126283-parameter_hmi,41 43 56 03 05 FF 1E 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100
ENG135292-phev_stat_intervall-,5.00 ,3
ENG135292-phev_stat_intervall-,100 m,3
ENG135292-phev_stat_intervall-,0 min,3
ENG126281-ENG126398-SK2_Adjustment-max_number_of_writing_procedures,6 ,3
ENG126281-ENG126400-SK2_Adjustment-timeout_request_immediate,150 s,3
ENG126281-ENG126399-SK2_Adjustment-timeout_request_normal,300 s,3
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,1.40 ,4
ENG112418-ENG99298-total_range_gas-State,active ,4
Elapsed Time: 00:38
;Friday,08,December,2017,16:01:38:29905
IDE00019,Voltage terminal 30,13.10, V
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,12.75, °C
IDE00196,Engine oil temperature,12, °C
IDE00301,Distance,78, km
IDE00310,Outside air temperature,4.50, °C
IDE00316-IDE00500,Time-Hour,16, H
IDE00316-IDE00501,Time-Minute,1, min
IDE00316-MAS00111,Time-Seconds,40, s
IDE00317-IDE00502,Date-Year,2017, yr
IDE00317-IDE00503,Date-Month,12, mon
IDE00317-IDE00504,Date-Day,8, d
IDE00510,ESI: distance driven from inspection,0, km
IDE00511,ESI: time from inspection,2, d
IDE00512,ESI: minimum value km-driving distance/inspection,14500, km
IDE00513,ESI: maximum value km-driving distance/inspection,14500, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,0, km
IDE00520,Phototransistor,11,
IDE00695,ESI: service exceedance in km,Not available,
IDE00696,ESI: service exceedance in days,Not available,
IDE00697,ESI: remaining distance,15940, km
IDE00698,ESI: remaining running time,363, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,28, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,1937, mm
IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2005, mm
IDE00935,ESI: Theoretical service interval,15000, km
IDE01076,Time since ignition off,7778, s
IDE01153,SIA: maximum value of distance to service,16000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE01985-ENG101043,FAZIT identification test sum-Checksum,7A 9E 4C 36,
IDE01985-ENG99027,FAZIT identification test sum-Version,02,
IDE02642,Outside temp.: displayed value,4.50, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,65,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,5C,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,5C,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,9,
IDE03349,FIX: Max. distance until next mileage-related inspection,32100, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,0, km
IDE03352,FIX: Time since last time-dependent inspection,2, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-ENG126401,Vehicle configuration-intelligent_park_assist,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,9.40, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,42.00, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,43.00, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,9.40, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,0.80, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,13.50, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,13.50, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,0.80, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,0.00, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,0.00, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,0.00, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,0.00, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,0.00, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,0.00, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,0.00, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,0.00, l
IDE03472-MAS03822,Volume after refueling-Last error status,00,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
IDE03472-MAS06153,Volume after refueling-Last distance,10, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,0, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,0, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,0, km
IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,50, Ohm
IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,not_available,
IDE03473-IDE00732,Fuel tank sens-Fuel level sensor 1 soiling resistance,0, Ohm
IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,not_available,
IDE03473-IDE03494,Fuel tank sens-Fuel level sensor 3 including soiling resistance,not_available,
IDE03473-IDE03495,Fuel tank sens-Fuel level sensor 3 soiling resistance,not_available,
IDE03473-IDE03496,Fuel tank sens-Fuel level sensor 4 including soiling resistance,not_available,
IDE03473-IDE03497,Fuel tank sens-Fuel level sensor 4 soiling resistance,not_available,
IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,200,
IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,653,
IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,not_available,
IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,not_available,
IDE03473-MAS03802,Fuel tank sens-Raw value sensor 3 resistor 1,not_available,
IDE03473-MAS03803,Fuel tank sens-Raw value sensor 3 resistor 2,not_available,
IDE03473-MAS03804,Fuel tank sens-Raw value sensor 4 resistor 1,not_available,
IDE03473-MAS03805,Fuel tank sens-Raw value sensor 4 resistor 2,not_available,
IDE03474-IDE00304,Calculated volume-Fuel level,41.30, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,50, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,not_available,
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,not_available,
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,not_available,
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,43.00, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,not_available,
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,not_available,
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,not_available,
IDE03474-IDE00802,Calculated volume-Full volume,42.00, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,43.00, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,not_available,
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,not_available,
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,not_available,
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.00,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.00,
IDE03474-ENG102894,Calculated volume-averaged_volume,43.00, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,43.00, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,43.00, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,0.50,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,-0.13, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.13, m/s
IDE03474-ENG101623,Calculated volume-reference_volume,43.00, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.00,
IDE03474-ENG99683,Calculated volume-version_of_application,8,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0011377,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03475-MAS12387,Control button in instrument cluster-Button for daily distance driven,not active,
IDE03477-IDE00500,GPS time-Hour,16, H
IDE03477-IDE00501,GPS time-Minute,2, min
IDE03477-IDE00501,GPS time-Minute,1, min
IDE03477-IDE00502,GPS time-Year,2017, yr
IDE03477-IDE00503,GPS time-Month,12, mon
IDE03477-IDE00504,GPS time-Day,8, d
IDE03477-MAS00111,GPS time-Seconds,2, s
IDE03477-MAS00111,GPS time-Seconds,9, s
IDE03477-MAS03493,GPS time-last synchronization year,2017, yr
IDE03506,Distance: high resolution,00 01 33 9E,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,17,
IDE03880-MAS03425,MOST address-Physical address,04 01,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 1A,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 0C,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 0C,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 1A,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,FF FF FF FF,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,FF FF FF FF,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,FF FF FF FF,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04649-ENG128738,Activation for housing fan-PWM_FAN,0, %
IDE04649-ENG128737,Activation for housing fan-source_max_PWM_requested,none,
IDE04649-ENG98933,Activation for housing fan-Status,OFF,
IDE04649-ENG128733,Activation for housing fan-temperature_Boost,25, °C
IDE04649-ENG128734,Activation for housing fan-temperature_chipled,31, °C
IDE04649-ENG128736,Activation for housing fan-temperature_GPU,30, °C
IDE04649-ENG128735,Activation for housing fan-temperature_KI,25, °C
IDE06425-IDE06026,Roller test bench mode: functional-Adaptation of brake pedal path sensor,not activated,
IDE06924,Performance display,4093,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
IDE07578-MAS00138,Operating range consumption with electric drive-1,0.00,
IDE07578-MAS00139,Operating range consumption with electric drive-2,65533,
IDE07578-ENG04221,Operating range consumption with electric drive-ERW_Energieinhalt,0.00,
IDE07578-ENG114651,Operating range consumption with electric drive-s_erw_rw_batterie,65533, km
IDE07578-ENG114652,Operating range consumption with electric drive-s_erw_rw_batterie_anz,65534, km
IDE07578-ENG114648,Operating range consumption with electric drive-s_erw_rwds,0.00, A
IDE07578-ENG114640,Operating range consumption with electric drive-s_erw_rwds_high,0.00, A
IDE07578-ENG114644,Operating range consumption with electric drive-s_erw_rwds_low,10.00, A
IDE07578-ENG114637,Operating range consumption with electric drive-s_erw_rwdv_antrieb_high_unclass,0.10, kWh/100 km
IDE07578-ENG114641,Operating range consumption with electric drive-s_erw_rwdv_antrieb_low_unclass,25.00,
IDE07578-ENG114645,Operating range consumption with electric drive-s_erw_rwdv_antrieb_unclass,1.60,
IDE07578-ENG114638,Operating range consumption with electric drive-s_erw_rwdv_dcdc_high_unclass,0.00, kWh/100 km
IDE07578-ENG114642,Operating range consumption with electric drive-s_erw_rwdv_dcdc_low_unclass,0.20,
IDE07578-ENG114646,Operating range consumption with electric drive-s_erw_rwdv_dcdc_unclass,0.00,
IDE07578-ENG114639,Operating range consumption with electric drive-s_erw_rwdv_tme_high_unclass,0.10,
IDE07578-ENG114643,Operating range consumption with electric drive-s_erw_rwdv_tme_low_unclass,0.50,
IDE07578-ENG114647,Operating range consumption with electric drive-s_erw_rwdv_tme_unclass,0.10,
IDE07578-ENG114649,Operating range consumption with electric drive-s_erw_rwdv_unclass,1.80,
IDE07646-ENG114675,Consumption for road-specif. range with electric drive-s_erw_endsteigung,0.00, %
IDE07646-ENG114667,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_0,1.10, kWh/100 km
IDE07646-ENG114668,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_1,25.00, kWh/100 km
IDE07646-ENG114669,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_2,25.00, kWh/100 km
IDE07646-ENG114670,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_3,25.00, kWh/100 km
IDE07646-ENG114671,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_4,25.00, kWh/100 km
IDE07646-ENG114672,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_5,25.00, kWh/100 km
IDE07646-ENG114673,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_6,25.00, kWh/100 km
IDE07646-ENG114653,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_0,1.10, kWh/100 km
IDE07646-ENG114654,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_1,25.00, kWh/100 km
IDE07646-ENG114655,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_2,25.00, kWh/100 km
IDE07646-ENG114656,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_3,25.00, kWh/100 km
IDE07646-ENG114657,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_4,25.00, kWh/100 km
IDE07646-ENG114658,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_5,25.00, kWh/100 km
IDE07646-ENG114659,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_6,25.00, kWh/100 km
IDE07646-ENG04222,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_low_class,25.00, kWh/100 km
IDE07646-ENG114674,Consumption for road-specif. range with electric drive-s_erw_str_klasse,0,
IDE08235-ENG118223,Status of immobilizer participant-ELV_State,F8,
IDE08235-ENG118222,Status of immobilizer participant-GSG_State,F8,
IDE08235-ENG118217,Status of immobilizer participant-Immobilizer_State,00,
IDE08235-ENG118216,Status of immobilizer participant-key_state,1C,
IDE08235-ENG118218,Status of immobilizer participant-MSG_1_State,F8,
IDE08235-ENG118219,Status of immobilizer participant-MSG_2_State,00,
IDE08235-ENG118220,Status of immobilizer participant-MSG_3_State,00,
IDE08235-ENG118221,Status of immobilizer participant-MSG_4_State,F8,
IDE08236-ENG118224,Status locking periods immobilizer-blocking_time,00 00 00 00 00 00,
IDE08239,Transponder ID Key 1,09 D7 BF D6,
IDE08240,Transponder ID Key 2,09 D7 57 61,
IDE08252-ENG101043,Test sum of adapted transponder-Checksum,C3 A1 24 B2,
IDE08252-ENG99027,Test sum of adapted transponder-Version,01,
IDE08343,Immobilizer Challenge,40 E3 91 C5,
IDE08701-MAS07266,ESI: Status-Oil change: unit of dist. travelled,miles,
IDE08701-MAS07267,ESI: Status-Oil change: dist. travelled,6600,
IDE08701-MAS07268,ESI: Status-Oil change: stat. of dist. travelled,Service in,
IDE08701-MAS07269,ESI: Status-Oil change: stat. of time,Service in,
IDE08701-MAS07270,ESI: Status-Inspection: stat. of dist. travelled,Service in,
IDE08701-MAS07271,ESI: Status-Inspection: unit of dist. travelled,miles,
IDE08701-MAS07272,ESI: Status-Inspection: dist. travelled,20000,
IDE08701-MAS07273,ESI: Status-Inspection: time,728,
IDE08701-MAS07274,ESI: Status-Oil change warning,no warning,
IDE08701-MAS07277,ESI: Status-Inspections warning,no warning,
IDE08701-MAS07305,ESI: Status-Oil change: time,434,
IDE08701-MAS07308,ESI: Status-Inspection: status time,Service in,
IDE08701-MAS10768,ESI: Status-Daily mileage,100,
MAS00077-ENG99298,Immobilizer-State,02 01 03 5B 02 00 00 00 03 00,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG126262-ENG114675,Consumption_for_distance_on_map-s_erw_endsteigung,0.00, %
ENG126262-ENG114674,Consumption_for_distance_on_map-s_erw_str_klasse,0,
ENG126262-ENG128739,Consumption_for_distance_on_map-s_vkmrw_rwdv_antrieb_low_class,9.90, l/100km
ENG126262-ENG126309,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_0,10.00, l/100km
ENG126262-ENG126310,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_1,10.00, l/100km
ENG126262-ENG126311,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_2,10.00, l/100km
ENG126262-ENG126312,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_3,10.00, l/100km
ENG126262-ENG126313,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_4,10.00, l/100km
ENG126262-ENG126314,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_5,10.00, l/100km
ENG126262-ENG126315,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_6,10.00, l/100km
ENG126262-ENG126302,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_0,10.00, l/100km
ENG126262-ENG126303,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_1,10.00, l/100km
ENG126262-ENG126304,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_2,10.00, l/100km
ENG126262-ENG126305,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_3,10.00, l/100km
ENG126262-ENG126306,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_4,10.00, l/100km
ENG126262-ENG126307,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_5,10.00, l/100km
ENG126262-ENG126308,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_6,10.00, l/100km
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,92, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,28, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,10, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,10, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,10, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,100, km
ENG107920-ENG98868,onboard_computer-Range,474, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,8.00, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,0.00, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,0.00, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,0.00, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,8.00, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,9.90, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,0.00, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,0.00, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,0.00, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,65534, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,65534, km
ENG107920-ENG119791,onboard_computer-range_display_value,474, km
ENG107920-ENG126299,onboard_computer-range_lpg,65534, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,65534, km
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,109,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,FA E2 00 23 C1 80 11 0C 08 0D 2A 2C 48 00 00 00 64 30 6B 11 C8 30 D8 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 FF FF 00 00 40 18,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,35,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,1,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Engine_off,
ENG126266-ENG119811,SK2_counter_per_day-Counter_Key_ID_1,0,
ENG126266-ENG119812,SK2_counter_per_day-Counter_Key_ID_2,0,
ENG126266-ENG119813,SK2_counter_per_day-Counter_Key_ID_3,0,
ENG126266-ENG119814,SK2_counter_per_day-Counter_Key_ID_4,0,
ENG126266-ENG119815,SK2_counter_per_day-Counter_Key_ID_5,0,
ENG126266-ENG119816,SK2_counter_per_day-Counter_Key_ID_6,0,
ENG126266-ENG119817,SK2_counter_per_day-Counter_Key_ID_7,0,
ENG126266-ENG119818,SK2_counter_per_day-Counter_Key_ID_8,0,
ENG126267-ENG126385,SK2_pointer_and_label-SK2_label,FF FF FF FF,
ENG126267-ENG126382,SK2_pointer_and_label-Write_Pointer_Pos_1,65535,
ENG126267-ENG126383,SK2_pointer_and_label-Write_Pointer_Pos_2,65535,
ENG126267-ENG126384,SK2_pointer_and_label-Write_Pointer_Pos_3,65535,
ENG126263-ENG126381,SK2_received_data_from_datalogger-SK2_data,12 23 9D 00 01 01 FF FF 00 00 4E 23 88 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG126268-ENG126392,SK2_state-difference_SK2_data_SK-master_key,Yes,
ENG126268-ENG126394,SK2_state-last_reveived_end_identification,no_end_identification_received,
ENG126268-ENG126391,SK2_state-limitation_normal_request,not active,
ENG126268-ENG126386,SK2_state-SK2_function,not active,
ENG126268-ENG126389,SK2_state-state_immediate_request,not active,
ENG126268-ENG126388,SK2_state-state_normal_request,not active,
ENG126268-ENG126390,SK2_state-state_waiting_for_retry,not active,
ENG126268-ENG126393,SK2_state-transfer_SK2_data_finished_within_timeout,Yes,
ENG126268-ENG126387,SK2_state-trigger_normal_request,no_trigger,
ENG109340-ENG104056,tank_validation-s_vali_abs_active,not active,
ENG109340-ENG102652,tank_validation-s_vali_abs_display_0,not active,
ENG109340-ENG102994,tank_validation-s_vali_abs_distance/mileage,not active,
ENG109340-ENG101149,tank_validation-s_vali_abs_rough,not active,
ENG109340-ENG101740,tank_validation-s_vali_active,not active,
ENG109340-ENG101355,tank_validation-s_vali_consumption_deq,3276.80, l
ENG109340-ENG100596,tank_validation-s_vali_consumption_deq_abs,3276.80, l
ENG109340-ENG102770,tank_validation-s_vali_display_0,not active,
ENG109340-ENG99133,tank_validation-s_vali_needle_vol_ref,not active,
ENG109340-ENG99562,tank_validation-s_vali_rough,not active,
ENG109340-ENG100160,tank_validation-s_vali_status,2, l
ENG109340-ENG103691,tank_validation-s_vali_vol_delta_gef,3276.50, l
ENG109340-ENG100615,tank_validation-s_vali_vol_delta_roh,3278.30, l
ENG109340-ENG99506,tank_validation-s_vali_vol_g1_vg,3319.80, l
ENG109340-ENG103928,tank_validation-s_vali_vol_g2_vg,3276.80, l
ENG109340-ENG101476,tank_validation-s_vali_vol_g3_vg,3276.80, l
ENG109340-ENG101237,tank_validation-s_vali_vol_g4_vg,3276.80, l
ENG109340-ENG101103,tank_validation-s_vali_vol_ref_gew,3318.30, l
ENG109340-ENG100543,tank_validation-s_vali_vol_ref_vg,3318.30, l
ENG109340-ENG100079,tank_validation-s_vali_vol_total_vg,3319.80, l
Elapsed Time: 01:02
23 Maps
;SW:5QE-909-059-G   HW:5QE-909-059-B ---  Brake Booster
;Component:EBKV          H14 0211, Coding:03720100331A00030002050500
;EV_BrakeBoostBoschMQBOMG,004003,EV_BrakeBoostBoschMQBOMG_004.rod
;Friday,08,December,2017,16:12:27:29905
;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
;VCID: 52E7F903059B90BA20B-8006
IDE08581-Recuperation,active ,1
IDE11447-electro-mechanical brake booster,active ,1
IDE11985-Expected OBD requirements,US OBD ,1
IDE80011-MAS05513-Analysis 11-Bit 0,OFF ,1
IDE80011-MAS05514-Analysis 11-Bit 1,OFF ,1
IDE80011-MAS05515-Analysis 11-Bit 2,OFF ,1
IDE80011-MAS05516-Analysis 11-Bit 3,OFF ,1
IDE80011-MAS05517-Analysis 11-Bit 4,OFF ,1
IDE80011-MAS05518-Analysis 11-Bit 5,OFF ,1
IDE80011-MAS05519-Analysis 11-Bit 6,OFF ,1
IDE80011-MAS05520-Analysis 11-Bit 7,OFF ,1
IDE80012-MAS05513-Analysis 12-Bit 0,OFF ,1
IDE80012-MAS05514-Analysis 12-Bit 1,OFF ,1
IDE80012-MAS05515-Analysis 12-Bit 2,OFF ,1
IDE80012-MAS05516-Analysis 12-Bit 3,OFF ,1
IDE80012-MAS05517-Analysis 12-Bit 4,OFF ,1
IDE80012-MAS05518-Analysis 12-Bit 5,OFF ,1
IDE80012-MAS05519-Analysis 12-Bit 6,OFF ,1
IDE80012-MAS05520-Analysis 12-Bit 7,OFF ,1
IDE80013-Analysis 13,00 00 00 ,3
IDE80015-Analysis 15,On ,1
IDE80016-Analysis 16,On ,1
IDE80017-Analysis 17,On ,1
IDE80018-Analysis 18,OFF ,1
IDE80019-Analysis 19,00 00 00 00 ,4
IDE80020-Analysis 20,00 00 00 00 ,4
Elapsed Time: 00:03
;Friday,08,December,2017,16:12:23:29905
Group,Description,Actual
IDE00019,Voltage terminal 30,33,
IDE00021,Engine speed,00,
IDE00025,Coolant temperature,36,
IDE00075,Vehicle speed,00,
IDE00085,Normed load value,00,
IDE00086,Accelerator position,25,
IDE00097,OBD - requirements for which this vehicle is designed,02,
IDE00102,Control Module temperature,12.825, °C
IDE00601-ENG30035,Monitoring status since erasing DTC memory-MIL_Status,OFF,
IDE00601-ENG30057,Monitoring status since erasing DTC memory-Number_of_errors_Mode$03,0,
IDE00601-ENG30070,Monitoring status since erasing DTC memory-Readiness_State,00,
IDE00601-ENG30155,Monitoring status since erasing DTC memory-Supported_Info,00,
IDE00601-ENG30156,Monitoring status since erasing DTC memory-Supported_Info_Readiness,04,
IDE00602,Monitoring status in current driving cycle,00,
IDE03680-IDE00019,Supply voltages-Voltage terminal 30,13.1, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,13.1, V
IDE03680-MAS06928,Supply voltages-Supply voltage pedal travel sensor,5.0, V
IDE05793-IDE06045,Brake activation-Output DTM status,No activation,
IDE05793-MAS11301,Brake activation-Timer,0, s
IDE05816-IDE00075,Input signals from data bus-Vehicle speed,0.0, km/h
IDE05816-IDE00086,Input signals from data bus-Accelerator position,0.0, %
IDE05816-IDE00643,Input signals from data bus-Minimum torque of electric machine,0.0,
IDE05816-IDE00773,Input signals from data bus-Terminal 15 status via CAN,Terminal 15 on,
IDE05816-IDE02211,Input signals from data bus-Brake pressure,0.0, bar
IDE05816-IDE03660,Input signals from data bus-Longitudinal acceleration,-0.0, m/s²
IDE05816-IDE05221,Input signals from data bus-E-machine torque actual value,0.0,
IDE05816-IDE07152,Input signals from data bus-Fall-back level,not active,
IDE05816-IDE07667,Input signals from data bus-Desired torque of regeneration,0.0,
IDE05816-IDE09126,Input signals from data bus-Vehicle switch-off time,136.0,
IDE05816-IDE09127,Input signals from data bus-Status: switch-off time,calculated,
IDE05816-MAS01078,Input signals from data bus-Vehicle type,Hybrid vehicle,
IDE05816-MAS05179,Input signals from data bus-ABS intervention,not active,
IDE05816-MAS05187,Input signals from data bus-MSR intervention,not active,
IDE05816-MAS06150,Input signals from data bus-Terminal 50,not active,
IDE05816-MAS08112,Input signals from data bus-Drive readiness,Not ready,
IDE05816-MAS08788,Input signals from data bus-Driving Cycle,not recognized,
IDE05816-MAS12319,Input signals from data bus-Alternator failure,no error,
IDE05816-MAS13659,Input signals from data bus-Warm air cycle,not recognized,
IDE05816-MAS14468,Input signals from data bus-OBD type,Type 2,
IDE05816-MAS14473,Input signals from data bus-OBD Normed Trip,Unknown,
IDE05816-MAS14474,Input signals from data bus-OBD Minimum Trip,not fulfilled,
IDE06422-ENG103176,IUMPR_1-General Denominator,3,
IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,69,
IDE06422-ENG100120,IUMPR_1-Milage,70, km
IDE06422-ENG101622,IUMPR_1-Record Number,1,
IDE06423-ENG101817,IUMPR_2-Denominator,3,
IDE06423-ENG103772,IUMPR_2-DFCC Value,03 69,
IDE06423-ENG99150,IUMPR_2-Numerator,11,
IDE06423-ENG101622,IUMPR_2-Record Number,1,
IDE08586-IDE00805,Status: electromechanical power brake-Dead volume,-255.0, mm³
IDE08586-IDE02955,Status: electromechanical power brake-System status,ready for operation,
IDE08586-IDE06673,Status: electromechanical power brake-Initialization status,completed successfully,
IDE08586-IDE11447,Status: electromechanical power brake-electro-mechanical brake booster,active,
IDE08586-IDE11985,Status: electromechanical power brake-Expected OBD requirements,US OBD,
IDE08586-MAS08092,Status: electromechanical power brake-Basic setting: electromechanical power brake,performed,
IDE08586-MAS10343,Status: electromechanical power brake-Correction factor_1,0.0000,
IDE08586-MAS10344,Status: electromechanical power brake-Correction factor_2,0.0000,
IDE08587-MAS02925,Power brake displays-Brake system indicator lamp,--no display--,
IDE08587-MAS08097,Power brake displays-Status: OBD lamp,OFF,
IDE08587-MAS08098,Power brake displays-Note - text message,--no display--,
IDE08587-MAS08100,Power brake displays-Warnings - text message,--no display--,
IDE08588-IDE06373,Sensor signals for electromechanical power brake-Rotor position of drive motor for electric drive,-0.39, °
IDE08588-MAS08107,Sensor signals for electromechanical power brake-Brake pedal position sensor pulse width,16.4, %
IDE08588-MAS08108,Sensor signals for electromechanical power brake-Brake pedal sensor 2 pulse width,84.0, %
IDE08588-MAS08109,Sensor signals for electromechanical power brake-Input rod path sensor: plausibilized,0.0, mm
IDE08588-MAS08110,Sensor signals for electromechanical power brake-Brake pedal actuation,OFF,
IDE08588-MAS10345,Sensor signals for electromechanical power brake-Position of booster,-0.066, mm
IDE08588-MAS10346,Sensor signals for electromechanical power brake-Engine torque,0.0000, Nm
IDE08588-MAS11260,Sensor signals for electromechanical power brake-Brake pedal position sensor distance,-0.078, mm
IDE08588-MAS11261,Sensor signals for electromechanical power brake-Brake pedal position sensor 2 distance,0.012, mm
IDE08589-IDE06673,Status of brake press. accum.-Initialization status,Wait for reference run permission,
IDE08589-IDE08581,Status of brake press. accum.-Recuperation,active,
IDE08589-MAS08113,Status of brake press. accum.-Brake pressure accum. basic setting,performed,
IDE08590-IDE00019,Supply voltages for brake press. accum.-Voltage terminal 30,13.4, V
IDE08591,Control module temp. brake press. accum.,15, °C
IDE08597-IDE06045,Activation brake press. accum.-Output DTM status,No activation,
IDE08597-MAS11301,Activation brake press. accum.-Timer,0, s
IDE11836,Query of the supported PIDs (0x01 - 0x20),98,
IDE11837,Query of the supported PIDs (0x21 - 0x40),00,
IDE11838,Query of the supported PIDs (0x41 - 0x60),C0,
IDE11839,Query of the supported InfoTypes (0x01 - 0x20),14,
IDE80001-IDE80011,Analysis 1-Analysis 11,00,
IDE80001-IDE80012,Analysis 1-Analysis 12,00,
IDE80001-IDE80013,Analysis 1-Analysis 13,00 00 00,
IDE80001-IDE80015,Analysis 1-Analysis 15,0.0078, mm
IDE80002,Analysis 2,00 00,
IDE80002,Analysis 2,00,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,8,
MAS00464-MAS00109,Standard - ambient data 1-Hours,1,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,26,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,6,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,78, km
MAS10353-IDE00634,Brake press. accum. current-Vehicle electrical system current,0.0, A
MAS10353-MAS10347,Brake press. accum. current-max. veh. elec. sys. current during last pressurization,0.3, A
MAS10354-MAS10348,Sensor signals for break press. accum.-Act. volume,0.00, mm³
MAS10354-MAS10349,Sensor signals for break press. accum.-System volume,4656.4, mm³
MAS10354-MAS10350,Sensor signals for break press. accum.-Target volume,469.6, mm³
MAS10354-MAS10351,Sensor signals for break press. accum.-Maximum volume,0.00, mm³
MAS10354-MAS10352,Sensor signals for break press. accum.-Resting volume,0.00, mm³
ENG101413,Calibration Identification,5QEB 0211@P(#((S,
ENG101413,Calibration Identification,2,
ENG101413,Calibration Identification,5QE057A 0155xxxx,
ENG99697,Calibration Verification Number,02 DC 15 8A,
ENG100152,ECUNAME,EBBC-ElecBrkBstCtrl,
ENG100152,ECUNAME,1,
Elapsed Time: 00:04
Andy
Sector 7G
HC424490
29 - Left Light maps
;SW:8S0-907-397-D   HW:8S0-907-397-D ---  Left Light
;Component:LCM_MQB       H06 0017, Coding:
;EV_LCMLeftCONTIAU426,001009,EV_LCMLeftCONTIAU426_VW41.rod
;Friday,08,December,2017,16:12:37:29905
;VCID: 42C7C943D5FB003A90B-8016
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not activated ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not activated ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not activated ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not activated ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not activated ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not activated ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not activated ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not activated ,1
IDE01550-Service position,not active ,1
Elapsed Time: 00:01
;Friday,08,December,2017,16:12:33:29905
IDE00767-MAS01478,No. of unscheduled ECU resets-Insuff. voltage,56,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,2,
IDE03680-MAS01468,Supply voltages-Terminal 15,Not available,
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,13.00, V
IDE06876-MAS01482,Signature light bulb-Hardwareversion,3,
IDE06876-MAS01483,Signature light bulb-Softwareversion,2,
IDE06876-MAS12381,Signature light bulb-Software subversion,04,
IDE06876-ENG14244,Signature light bulb-Software_sub_version_Textual,numerical value: no text,
IDE06926-IDE02068,History memory: reset counter-Time stamp,FA FE 10 47 00,
IDE06926-MAS09176,History memory: reset counter-Reset reason,Watchdog Reset,
IDE08742-MAS01155,Operating time-Control module,7.88, H
IDE08742-MAS03835,Operating time-Parking light,3.12, H
IDE08742-MAS09325,Operating time-Daytime running lights,0.00, H
IDE08742-MAS09330,Operating time-Cover for low beam headlight,0.00, H
IDE08742-MAS09332,Operating time-Turn signal,0.19, H
IDE08742-MAS09333,Operating time-Side-marker light,3.11, H
IDE08742-MAS09334,Operating time-Parking light,0.00, H
IDE09492-MAS01155,Temperatures-Control module,26.00, °C
IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,27.00, °C
IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,29.00, °C
IDE09768-MAS04121,LED channel 1-Voltage,0.00, V
IDE09768-MAS04136,LED channel 1-Current,0, mA
IDE09768-MAS09022,LED channel 1-PWM value,0.00, %
IDE09768-MAS09327,LED channel 1-LED brightness class,2,
IDE09768-MAS09328,LED channel 1-Primary function,no function,
IDE09768-MAS09329,LED channel 1-Secondary function,no function,
IDE09769-MAS04121,LED channel 2-Voltage,0.00, V
IDE09769-MAS04136,LED channel 2-Current,0, mA
IDE09769-MAS09022,LED channel 2-PWM value,0.00, %
IDE09769-MAS09327,LED channel 2-LED brightness class,3,
IDE09769-MAS09328,LED channel 2-Primary function,Turn signal,
IDE09769-MAS09329,LED channel 2-Secondary function,Turn signal,
IDE09770-MAS04136,High side channel 1-Current,1060, mA
IDE09770-MAS09022,High side channel 1-PWM value,100.00, %
IDE09770-MAS09326,High side channel 1-Function,Supply for power output stage for headlamp aux. functions,
IDE09771-MAS04136,High side channel 2-Current,0, mA
IDE09771-MAS09022,High side channel 2-PWM value,0.00, %
IDE09771-MAS09326,High side channel 2-Function,no function,
IDE09772-MAS04136,High side channel 3-Current,0, mA
IDE09772-MAS09022,High side channel 3-PWM value,0.00, %
IDE09772-MAS09326,High side channel 3-Function,Side-marker light,
IDE09774-MAS03835,Number of activations-Parking light,53,
IDE09774-MAS09325,Number of activations-Daytime running lights,0,
IDE09774-MAS09330,Number of activations-Cover for low beam headlight,0,
IDE09774-MAS09332,Number of activations-Turn signal,1693,
IDE09774-MAS09333,Number of activations-Side-marker light,52,
IDE09774-MAS09334,Number of activations-Parking light,0,
IDE09775-MAS09336,High temperature operating times for control unit-°C,0.00, H
IDE09775-MAS09337,High temperature operating times for control unit-between 105°C and 115°C,0.00, H
IDE09775-MAS09338,High temperature operating times for control unit-over 115°C,0.00, H
IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,36.24, %
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,0.00, %
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-over 60%,0.00, %
IDE09828-MAS00890,Head lamp variant-via CAN,E0 44,
IDE09828-MAS01155,Head lamp variant-Control module,E0 44,
IDE09916-MAS09563,Data set names-Number of data set names,01,
IDE09916-MAS09564,Data set names-Data set ID,28929,
IDE09916-MAS09565,Data set names-Data set name,A3PALEDetron,
IDE10175,Capturing statistic data: status,active,
IDE10301-MAS01155,Number of excess temp. protection activations-Control module,0,
IDE10301-MAS03835,Number of excess temp. protection activations-Parking light,0,
IDE10301-MAS09325,Number of excess temp. protection activations-Daytime running lights,0,
IDE10301-MAS09332,Number of excess temp. protection activations-Turn signal,0,
IDE11124-MAS12195,Headlight beam adjusting motor-Reference run status,performed,
IDE11124-MAS12196,Headlight beam adjusting motor-Fault position,not approached,
IDE11124-MAS12199,Headlight beam adjusting motor-Adjustment speed,normal,
IDE11124-MAS12206,Headlight beam adjusting motor-Motor position (percent of max. adjustment stroke),36.80, %
IDE11124-MAS12207,Headlight beam adjusting motor-Low beam inclination,-449.50, mm
IDE11125-MAS12195,Dynamic cornering light adjusting motor-Reference run status,not performed,
IDE11125-MAS12196,Dynamic cornering light adjusting motor-Fault position,not approached,
IDE11125-MAS12199,Dynamic cornering light adjusting motor-Adjustment speed,normal,
IDE11125-MAS12206,Dynamic cornering light adjusting motor-Motor position (percent of max. adjustment stroke),0.00, %
IDE11125-MAS12209,Dynamic cornering light adjusting motor-Swivel angle,Unknown,
IDE11276-MAS01482,Power output stage for headlamp aux. functions-Hardwareversion,Not available,
IDE11276-MAS01483,Power output stage for headlamp aux. functions-Softwareversion,Not available,
IDE11276-MAS12381,Power output stage for headlamp aux. functions-Software subversion,0F,
IDE11276-ENG14244,Power output stage for headlamp aux. functions-Software_sub_version_Textual,Not available,
IDE11347-MAS12195,Variable headlamp positioning motor-Reference run status,not performed,
IDE11347-MAS12196,Variable headlamp positioning motor-Fault position,not approached,
IDE11347-MAS12199,Variable headlamp positioning motor-Adjustment speed,normal,
IDE11347-MAS12212,Variable headlamp positioning motor-Calibrated light index setting,Unknown,
Elapsed Time: 00:03
Andy
Sector 7G
HC424490
2B - Steer. Col. Lockmaps
;SW:5Q0-905-861-A   HW:5Q0-905-861-A ---  Steer. Col. Lock
;Component:ELV-MQBA      H01 0120, Coding:5D00000000000000
;EV_ELVMarquMQB,004111,EV_ELVMarquMQB.rod
;Friday,08,December,2017,16:12:49:29905
;VCID: 342B9F9B9F4FBE8A127-8060
Elapsed Time: 00:01
;Friday,08,December,2017,16:12:40:29905
IDE00019,Voltage terminal 30,13.100, V
IDE00021,Engine speed,0.00, /min
IDE00021-MAS02248,Engine speed-Signal state,valid,
IDE00075-MAS02248,Vehicle speed-Signal state,valid,
IDE01766-MAS03714,Distance impulses-Left front wheel,1,
IDE01766-MAS03715,Distance impulses-Right front wheel,0,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS05509,Distance impulses-Left front wheel signal state,valid,
IDE01766-MAS05510,Distance impulses-Right front wheel signal state,valid,
IDE01766-MAS05511,Distance impulses-Left rear wheel signal state,valid,
IDE01766-MAS05512,Distance impulses-Right rear wheel signal state,valid,
IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
IDE02571-MAS05507,Terminal 50: line status-Actual value engine control module,OFF,
IDE02572-MAS02350,Starter button: status-Switch contact 1,not activated,
IDE02572-MAS02351,Starter button: status-Switch contact 2,not activated,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,not activated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02578,Play protection status,not activated,
IDE02579,Park selector lever position,Engaged and locked,
IDE02580,Number of unlocks,77,
IDE02581-MAS02312,Drive train uncoupling-Powertrain (engine),decoupled,
IDE02582-MAS00179,Brake activation: switch status-Brake Light Switch,OFF,
IDE02582-MAS02248,Brake activation: switch status-Signal state,valid,
IDE02582-MAS02253,Brake activation: switch status-Brake test switch,OFF,
IDE02586-MAS02398,ID sensor authenticated in vehicle-ID sensor 1,No,
IDE02586-MAS02399,ID sensor authenticated in vehicle-ID sensor 2,No,
IDE02586-MAS02400,ID sensor authenticated in vehicle-ID sensor 3,No,
IDE02586-MAS02401,ID sensor authenticated in vehicle-ID sensor 4,No,
IDE02587,ID sensor search: status,not active,
IDE02589-MAS02255,Rotary latch status-Status of rotary latch in driver door,closed,
IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02682-MAS02250,Disengage starter-Disengage request,No,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
IDE03527-IDE00660,CAN signals-Drive readiness,not active,
IDE03527-IDE03410,CAN signals-Yellow warning lamp,not active,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine speed,Condition met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02578,Locking requirements-Play protection status,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-IDE07029,Locking requirements-Terminal status via CAN,Condition not met,
IDE06746-MAS02349,Locking requirements-Learn mode,Condition met,
IDE07028,Time until shut-off terminal S,4.14e+006, ms
IDE08440,Recommendation energy management,no restriction,
IDE09068-IDE00020,Status: automatic terminal shut-off-Terminal 15 status,Condition met,
IDE09068-IDE00021,Status: automatic terminal shut-off-Engine speed,Condition met,
IDE09068-IDE00325,Status: automatic terminal shut-off-Diagnostic mode,Condition not met,
IDE09068-IDE02579,Status: automatic terminal shut-off-Park selector lever position,Not coded,
IDE09068-IDE06983,Status: automatic terminal shut-off-Diesel emissions re-treatment: status,Condition met,
IDE09068-IDE08099,Status: automatic terminal shut-off-Status engine speed,Condition met,
IDE09068-IDE08440,Status: automatic terminal shut-off-Recommendation energy management,Condition not met,
IDE09068-MAS06473,Status: automatic terminal shut-off-Status vehicle standstill,Condition met,
IDE09068-MAS08076,Status: automatic terminal shut-off-Exiting the vehicle,Condition not met,
IDE09068-MAS08788,Status: automatic terminal shut-off-Driving Cycle,Condition not met,
IDE09068-MAS08789,Status: automatic terminal shut-off-Valid distance impulses,Condition met,
IDE09068-MAS08790,Status: automatic terminal shut-off-Driver absence,Condition met,
MAS00025,Driver seat belt switch,not connected,
MAS01493,Engine running,not active,
MAS03129,Reset counter,2,
MAS03607,Engine stop in start-stop mode active,not active,
MAS05104,Driver request: start engine,not active,
MAS09771,Driver information comfort switching,No switch-off,
ENG111213-ENG111202,Activated_Fault_Reactions-CoCo permanent reset,No,
ENG111213-ENG111201,Activated_Fault_Reactions-KL50 disabled,No,
ENG111213-ENG111200,Activated_Fault_Reactions-Locking disabled / Clamp change up disabled,No,
ENG125217,Active_requirement_light_lag,not activated,
ENG120012-ENG100326,CAN Message CLS_02-Can State,active,
ENG120012-ENG119946,CAN Message CLS_02-Time to Timeout ZV_02,1940, ms
ENG120012-ENG119966,CAN Message CLS_02-ZV_gesafet_extern_soll,0,
ENG120012-ENG119965,CAN Message CLS_02-ZV_verriegelt_extern_soll,0,
ENG120020-ENG119995,CAN Message ESCL_01-ELV_Anf_Klemme_15,1,
ENG120020-ENG119996,CAN Message ESCL_01-ELV_Anf_Klemme_50,0,
ENG120020-ENG119994,CAN Message ESCL_01-ELV_Anf_Klemme_S,1,
ENG120020-ENG120001,CAN Message ESCL_01-ELV_Anlernmodus,0,
ENG120020-ENG119998,CAN Message ESCL_01-ELV_Entriegelt,1,
ENG120020-ENG120000,CAN Message ESCL_01-ELV_Lebenszustand,1,
ENG120020-ENG120003,CAN Message ESCL_01-ELV_LED_Gelb,0,
ENG120020-ENG120002,CAN Message ESCL_01-ELV_LED_Rot,0,
ENG120020-ENG120009,CAN Message ESCL_01-ELV_P_verriegelt,0,
ENG120020-ENG120007,CAN Message ESCL_01-ELV_Txt_Defekt,0,
ENG120020-ENG120005,CAN Message ESCL_01-ELV_Txt_Lkg_Bewegen,0,
ENG120020-ENG120008,CAN Message ESCL_01-ELV_Txt_P_Gang,0,
ENG120020-ENG120004,CAN Message ESCL_01-ELV_Txt_Panikabschaltung,0,
ENG120020-ENG120006,CAN Message ESCL_01-ELV_Txt_Werkstatt,0,
ENG120020-ENG119997,CAN Message ESCL_01-ELV_Verriegelt,0,
ENG120020-ENG119999,CAN Message ESCL_01-ELV_ZAT_betaetigt,0,
ENG120016-ENG100326,CAN Message ESP_10-Can State,active,
ENG120016-ENG119984,CAN Message ESP_10-ESP_10_BZ,3,
ENG120016-ENG119985,CAN Message ESP_10-ESP_10_CRC,186,
ENG120016-ENG119993,CAN Message ESP_10-ESP_QBit_Wegimpuls_HL,0,
ENG120016-ENG119992,CAN Message ESP_10-ESP_QBit_Wegimpuls_HR,0,
ENG120016-ENG119990,CAN Message ESP_10-ESP_QBit_Wegimpuls_VL,0,
ENG120016-ENG119991,CAN Message ESP_10-ESP_QBit_Wegimpuls_VR,0,
ENG120016-ENG119989,CAN Message ESP_10-ESP_Wegimpuls_HL,0,
ENG120016-ENG119988,CAN Message ESP_10-ESP_Wegimpuls_HR,0,
ENG120016-ENG119986,CAN Message ESP_10-ESP_Wegimpuls_VL,1,
ENG120016-ENG119987,CAN Message ESP_10-ESP_Wegimpuls_VR,0,
ENG120016-ENG119951,CAN Message ESP_10-Time to Timeout ESP_10,1880, ms
ENG120014-ENG100326,CAN Message Gateway_71-Can State,active,
ENG120014-ENG119687,CAN Message Gateway_71-ESP_21_alt,0,
ENG120014-ENG119968,CAN Message Gateway_71-ESP_QBit_v_Signal,0,
ENG120014-ENG119967,CAN Message Gateway_71-ESP_v_Signal,0.00, km/h
ENG120014-ENG119947,CAN Message Gateway_71-Time to Timeout Gateway_71,920, ms
ENG120019-ENG100326,CAN Message Gateway_73-Can State,active,
ENG120019-ENG119976,CAN Message Gateway_73-MO_Drehzahl_01,0.00, /min
ENG120019-ENG119977,CAN Message Gateway_73-MO_QBit_Drehzahl_01,0,
ENG120019-ENG119684,CAN Message Gateway_73-Motor_12_alt,0,
ENG120019-ENG119948,CAN Message Gateway_73-Time to Timeout Gateway_73,500, ms
ENG120015-ENG100326,CAN Message Kessy_04-Can State,active,
ENG120015-ENG119978,CAN Message Kessy_04-KY_ID_Geber 1_im_Fzg,0,
ENG120015-ENG119979,CAN Message Kessy_04-KY_ID_Geber 2_im_Fzg,0,
ENG120015-ENG119980,CAN Message Kessy_04-KY_ID_Geber 3_im_Fzg,0,
ENG120015-ENG119981,CAN Message Kessy_04-KY_ID_Geber 4_im_Fzg,0,
ENG120015-ENG119982,CAN Message Kessy_04-KY_ID_Geber_Suche,0,
ENG120015-ENG119950,CAN Message Kessy_04-Time to Timeout Kessy_04,1880, ms
ENG120013-ENG100326,CAN Message Motor_14-Can State,active,
ENG120013-ENG119969,CAN Message Motor_14-MO_Aussp_Anlass,0,
ENG120013-ENG119970,CAN Message Motor_14-MO_BLS,0,
ENG120013-ENG119971,CAN Message Motor_14-MO_Fahrer_bremst,0,
ENG120013-ENG119975,CAN Message Motor_14-MO_HYB_Fahrbereitschaft,0,
ENG120013-ENG119973,CAN Message Motor_14-MO_Interlock,1,
ENG120013-ENG119681,CAN Message Motor_14-MO_Kl_50,0,
ENG120013-ENG119972,CAN Message Motor_14-MO_Qbit_Fahrer_bremst,0,
ENG120013-ENG119974,CAN Message Motor_14-MO_StartStopp_Motorstopp,0,
ENG120013-ENG119949,CAN Message Motor_14-Time to Timeout Motor_14,940, ms
ENG120010-ENG100326,CAN Message term._Status_01-Can State,active,
ENG120010-ENG119944,CAN Message term._Status_01-Time to Timeout Klemmen_Status_01,960, ms
ENG120010-ENG119680,CAN Message term._Status_01-ZAS_Kl_15,1,
ENG120010-ENG119679,CAN Message term._Status_01-ZAS_Kl_S,1,
ENG120011-ENG100326,CAN Message TSG_FT_01-Can State,active,
ENG120011-ENG119964,CAN Message TSG_FT_01-FT_Tuer_geoeffnet,0,
ENG120011-ENG119945,CAN Message TSG_FT_01-Time to Timeout TSG_FT_01,920, ms
ENG120018-ENG100326,CAN Message WFS_01-Can State,active,
ENG120018-ENG119952,CAN Message WFS_01-Time to Timeout WFS_01,1940, ms
ENG120018-ENG119983,CAN Message WFS_01-WFS_Schluessel_Ist,2,
ENG111214-ENG119959,CAN Request-Clamp generation,active,
ENG111214-ENG119958,CAN Request-Diagnostic connection,active,
ENG111214-ENG119961,CAN Request-Immobilizer authentication,not active,
ENG111214-ENG119960,CAN Request-Move,not active,
ENG111215-ENG119959,CAN Request-Clamp generation,active,
ENG111215-ENG119958,CAN Request-Diagnostic connection,active,
ENG111215-ENG119961,CAN Request-Immobilizer authentication,not active,
ENG111215-ENG119960,CAN Request-Move,not active,
ENG111211-ENG111203,Endposition_Button_Blocked_Contact-Button Blocked Contact 1,not activated,
ENG111211-ENG111204,Endposition_Button_Blocked_Contact-Button Blocked Contact 2,operated,
ENG111217-ENG111209,Endposition_Button_Unlocked_Contact-Button Unlocked Contact 1,operated,
ENG111217-ENG111210,Endposition_Button_Unlocked_Contact-Button Unlocked Contact 2,not activated,
ENG111212-ENG111184,Errorcounter-AD-Converter corrupt,0,
ENG111212-ENG111176,Errorcounter-CoCo RAM-Check,0,
ENG111212-ENG111177,Errorcounter-CoCo ROM-Check,0,
ENG111212-ENG111194,Errorcounter-CPU-Test CoCo,0,
ENG111212-ENG111192,Errorcounter-CPU-Test HaCo,0,
ENG111212-ENG111186,Errorcounter-Enable CoCo incorrect active KL15,0,
ENG111212-ENG111187,Errorcounter-Enable CoCo incorrect active locking,0,
ENG111212-ENG111178,Errorcounter-Endposition locked not reached,0,
ENG111212-ENG111181,Errorcounter-Endposition switches implausible,0,
ENG111212-ENG119957,Errorcounter-Error clamp15: - Steeringlock isn't unlock,0,
ENG111212-ENG111185,Errorcounter-HaCo CoCo communication disturbed,0,
ENG111212-ENG111175,Errorcounter-HaCo EEPROM-Check,0,
ENG111212-ENG111173,Errorcounter-HaCo RAM-Check,0,
ENG111212-ENG111174,Errorcounter-HaCo ROM-Check,0,
ENG111212-ENG111196,Errorcounter-KL15 ELV locked,0,
ENG111212-ENG111188,Errorcounter-No CoCo enable KL15,0,
ENG111212-ENG111189,Errorcounter-No CoCo enable locking,0,
ENG111212-ENG111182,Errorcounter-Particle,0,
ENG111212-ENG111195,Errorcounter-Program sequence CoCo,0,
ENG111212-ENG111193,Errorcounter-Program sequence HaCo,0,
ENG111212-ENG111190,Errorcounter-Reset HaCo CoCo failed,0,
ENG111212-ENG111191,Errorcounter-Reset SBC HaCo failed,0,
ENG111212-ENG119956,Errorcounter-Return address,00 00 00 00,
ENG111212-ENG111183,Errorcounter-SBC-Error,0,
ENG111212-ENG111197,Errorcounter-SDA-Error,0,
ENG111212-ENG111179,Errorcounter-Shortcut motor driver highside,0,
ENG111212-ENG111180,Errorcounter-Shortcut motor driver lowside,0,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2000,
ENG125220-MAS00107,History last automatic terminal switch off-Month,1,
ENG125220-MAS00108,History last automatic terminal switch off-Day,6,
ENG125220-MAS00108,History last automatic terminal switch off-Day,7,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,0,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,2,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,0,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,33,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,28,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,44,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,6,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,21,
ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,17, km
ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,17, km
ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,17, km
ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,13, km
ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,12, km
ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Leaving the car,
ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Leaving the car,
ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
ENG111218-ENG98599,Last reset reason-external,WAKEUP_SST1,
ENG111218-ENG98656,Last reset reason-internal,NOT_INTERNAL,
ENG125219-ENG125224,Status_Selective_catalytic_reduction-Count_engine_start,OK,
ENG125219-ENG125223,Status_Selective_catalytic_reduction-Selective_catalytic_reduction_install,not installed,
ENG125218,Suppression_ignition_message,not activated,
ENG120017-ENG100326,Timeout CAN Messages-Can State,active,
ENG120017-ENG119953,Timeout CAN Messages-Time to Timeout Diagnose_01,4560, ms
ENG120017-ENG119951,Timeout CAN Messages-Time to Timeout ESP_10,1820, ms
ENG120017-ENG119947,Timeout CAN Messages-Time to Timeout Gateway_71,900, ms
ENG120017-ENG119948,Timeout CAN Messages-Time to Timeout Gateway_73,480, ms
ENG120017-ENG119950,Timeout CAN Messages-Time to Timeout Kessy_04,1840, ms
ENG120017-ENG119944,Timeout CAN Messages-Time to Timeout Klemmen_Status_01,1000, ms
ENG120017-ENG119949,Timeout CAN Messages-Time to Timeout Motor_14,1000, ms
ENG120017-ENG119954,Timeout CAN Messages-Time to Timeout Systeminfo_01,4560, ms
ENG120017-ENG119945,Timeout CAN Messages-Time to Timeout TSG_FT_01,980, ms
ENG120017-ENG119952,Timeout CAN Messages-Time to Timeout WFS_01,2000, ms
ENG120017-ENG119946,Timeout CAN Messages-Time to Timeout ZV_02,1860, ms
Elapsed Time: 00:08
Andy
Sector 7G
HC424490
39 - Right Light maps
;SW:8S0-907-397-D   HW:8S0-907-397-D ---  Right Light
;EV_LCMRightCONTIAU426,001009,EV_LCMLeftCONTIAU426_VW41.rod
;Friday,08,December,2017,16:12:56:29905
Elapsed Time: 00:01
;Friday,08,December,2017,16:12:52:29905
IDE08742-MAS01155,Operating time-Control module,7.29, H
IDE08742-MAS03835,Operating time-Parking light,3.11, H
IDE08742-MAS09332,Operating time-Turn signal,0.18, H
IDE09492-MAS01155,Temperatures-Control module,27.00, °C
IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,28.00, °C
IDE09769-MAS09327,LED channel 2-LED brightness class,4,
IDE09770-MAS04136,High side channel 1-Current,1080, mA
IDE09774-MAS03835,Number of activations-Parking light,52,
IDE09774-MAS09332,Number of activations-Turn signal,1602,
IDE09774-MAS09333,Number of activations-Side-marker light,51,
IDE09775-MAS09336,High temperature operating times for control unit-°C,0.01, H
IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,36.26, %
Elapsed Time: 00:03
Andy
Sector 7G
HC424490
3C - Lane Change maps
;SW:3Q0-907-566-F   HW:3Q0-907-566 ---  Lane Change
;Component:MRR1Rear      H21 0610, Coding:04C002
;EV_RearRadarS1BoschVW48X,001007,EV_RearRadarS1BoschVW48X.rod
;Friday,08,December,2017,16:13:05:29905
;VCID: 3B39B4A7B21171F2D3D-806E
IDE00001-MAS15623-Production mode-Deactivation of lane change assistance and exit warning,not active ,3
IDE00001-MAS15624-Production mode-Deactivation of Cross traffic assistant rear and pre sense rear,not active ,3
IDE00820-Activating and deactivating all development messages,not activated ,1
IDE05394-Brightness characteristic of warning display,normal ,1
Elapsed Time: 00:03
;Friday,08,December,2017,16:13:00:29905
IDE00018,Voltage terminal 15,12.90, V
IDE00019,Voltage terminal 30,Measured value not available,
IDE00020,Terminal 15 status,Measured value not available,
IDE00102,Control Module temperature,21, °C
IDE00925,Yaw rate,-127, °/s
IDE01352,Temperature unit,°C,
IDE01441,Back-up light,OFF,
IDE01763,Dimming,3,
IDE02049,Trailer detected,Unknown,
IDE02389,Ambient brightness,0, %
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,253,
IDE03197-MAS02477,Rain/Light Recognition Sensor-Front brightness,0,
IDE03197-ENG09275,Rain/Light Recognition Sensor-Brightness_forwards_Textual,numerical value: no text,
IDE03504-MAS03692,Personalized settings-Key 1,0,
IDE03504-MAS03693,Personalized settings-Key 2,0,
IDE03504-MAS03694,Personalized settings-Key 3,0,
IDE03504-MAS03695,Personalized settings-Key 4,0,
IDE03505-MAS03692,Personalized settings dimming-Key 1,4,
IDE03505-MAS03693,Personalized settings dimming-Key 2,3,
IDE03505-MAS03694,Personalized settings dimming-Key 3,3,
IDE03505-MAS03695,Personalized settings dimming-Key 4,3,
IDE05068,Driver side warning light flashing cycle,Unknown,
IDE05069,Frt.pass. side warning light flashing cycle,Unknown,
IDE05070,Curve radius,4093, m
IDE05071,Lane change assistance button,not activated,
IDE05075,Status of driver side warning light,OFF,
IDE05076,Status of frt.pass. side warning light,OFF,
IDE05089,Dynamic calibration: distance traveled,0, km
IDE05090,Measured receiving power lane change assist. 1,1, %
IDE05091,Measured receiving power lane change assist. 2,54, %
IDE05092,Measured angle lane change assist. 1,-38.80, °
IDE05093,Measured angle lane change assist. 2,40.30, °
IDE05094,Static angle offset lane change assist. 1,-1.18, °
IDE05095,Static angle offset lane change assist. 2,-0.39, °
IDE05393,Currently used key,Key 2,
IDE09232,Vehicle speed from radar measurement,0.00, km/h
IDE09387,Dynamic angle offset lane change assist.,-0.65, °
IDE09388,Rear cross traffic assistant: warning levels,Stage 0,
IDE09780,System condition ctrl. mod.,Terminal 15 on,
IDE09781,Syst. condition lane change assistance,Available,
IDE09782,System condition rear cross traffic assistant,Available,
IDE09783,System condition pre sense rear,Temporary malfunction,
IDE09784,Functional status of lane change assist.,passive,
IDE09785,Function condition rear cross traffic assistant,OFF,
IDE09786,Function condition pre sense rear,passive,
ENG112308,ECU_Serial_Number,31 35 2E 31 30 2E 31 37 37 37 31 31 32 31 35 33,
Elapsed Time: 00:04
Andy
Sector 7G
HC424490
42 - Door Elect, Driver maps
;SW:5Q0-959-593-E   HW:5Q0-959-593-B ---  Door Elect, Driver
;Component:TSG FS        020 0041, Coding:005D1F205C00048000000003
;EV_DCUDriveSideEWMAXKLO,006003,EV_DCUDriveSideEWMAXCONT.rod
;Friday,08,December,2017,16:13:53:29905
;VCID: 43C9CC47CAE109329BD-8016
IDE00001-Production mode,00000000 00000000 00000000  ,3
IDE02332-Deactivate production mode,00000000 00000000 00000000  ,3
Elapsed Time: 00:12
;Friday,08,December,2017,16:13:11:29905
IDE00310,Outside air temperature,5.0, °C
IDE01766-MAS02248,Distance impulses-Signal state,OK,
IDE02262,synchronous mirror adjustment,not installed,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,13.1, V
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Right,
IDE04216-MAS01458,Mirror heater-Operating condition,not_active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,not activated,
IDE04217,Fuel filler door release button,not activated,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,not activated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,not activated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,not activated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,not activated,
IDE04220,Driver power window button,not activated,
IDE04411,Child Safety Lock Switch,not activated,
IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
IDE04539-MAS02228,Mirror memory-X coordinate,255, %
IDE04539-MAS02229,Mirror memory-Y coordinate,255, %
IDE04539-MAS02476,Mirror memory-install,not installed,
IDE04540,Mirror adjustment (X/Y-direction),Position center,
IDE04580,Dimming of inside door handle lighting,92, %
IDE04581,Dimming for interior ambient lighting,255, %
IDE04586,Mirror fold-in activation,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,not activated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,not activated,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,15, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not activated,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.0, %
IDE06206-MAS02098,Front window regulator status: driver side-Power window control standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,0, %
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.5, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.5, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.5, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.5, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.5, %
IDE07110-MAS01632,Recognition of motor variant for window regul.-Status,not recognized,
IDE07110-MAS04606,Recognition of motor variant for window regul.-Parameter set,15,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,4, °C
IDE07543,Vehicle speed,0.0, km/h
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,0.0, A
IDE09798,Play protection: mirror fold-in,not active,
MAS00464-MAS00106,Standard - ambient data 1-Year,2017,
MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,4,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,1248, km
MAS01872,Rear lid remote release button,not activated,
MAS02101,Child safety,active,
MAS06010,Ambient light,255, %
Elapsed Time: 00:41
