Passenger window one touch
geforce007
C?ID=303008
Hi guys I have an a3 2007 5 door.
After fitting puddle lights and finding out the guide I was using was for the 2008 up and there was a wire change.
I found out my passenger window one touch will not work also the one touch on key a long with using the key in the door to open and close the windows.
I went back to my original auto scan still can't work it out.
Am new to this so forgive me for being stupid.
Posting the Auto Scan you have would be a good idea...
downtime
C?ID=280813
Have you done the basic setting for the window?
Procedure :
1. Make sure that the window is fully closed
2. Press and hold window down and keep pressing it for 5 secs after the window has been completely lowered
3. Press and hold window up and keep it pressed for 5 secs after the windows has been completely raised
Basic setting for the door control module teached and the one touch should work again.
geforce007
C?ID=303008
Hi I have done basic settings and will post auto scan soon.
geforce007
C?ID=303008
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 DN    HW: 03G 906 018 DN
   Component: R4 2.0l PPD1.2 G    4350
   Revision: --H42---    Serial number: AUX7Z0G7FN601A
   Coding: 0000078
   Shop #: WSC 66565 257 00032
   VCID: 74B2D5F2C2B0D0074F2-8020
000000 - SAE - Reserved by Document ISO 15031-6
               P0000 - 006 - 2005 - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 6
                    Reset counter: 40
                    Mileage: 193993 km
                    Date: 2017.08.09
                    Time: 22:23:54
                    RPM: 2016 /min
                    Torque: 144.0 Nm
                    Text: Kein Messwert verfuegbar
                    Raw, Form. N/A: 000 180 004
Readiness: N/A
   Part No SW: 02E 300 044 L    HW: 02E 927 770 AD
   Component: GSG DSG         082 1401
   Revision: 04808020    Serial number: 00000808301346
   Shop #: WSC 04940 001 00001
   VCID: 1E66D75A1CBC2A57496-804A
   Revision: 00H11001
   Coding: 0023170
   Shop #: WSC 06314 000 00000
   VCID: 73B0D6EEC7BED73F568-8026
   Part No SW: 8P0 820 043 AG    HW: 8P0 820 043 AG
   Component: KlimavollautomatH19 0420
   Revision: 172399      Serial number: 8P0820043AG
   VCID: 71BCDCE6BDA2E52FA44-8024
00532 - Supply Voltage B+
                    Reset counter: 194
                    Mileage: 194151 km
                    Date: 2017.08.14
                    Time: 19:54:41
                    Voltage: 10.60 V
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 K    HW: 8P0 907 279 K
   Component: Bordnetz-SG     H54 2501
   Revision: 00H54000    Serial number: 00000007472277
   Coding: 81881F01B0141000471600001600000000085E175C010000000000000000
   Shop #: WSC 06435 123 08192
   VCID: 45D45836D9AA198F28C-8010
   Subsystem 1 - Part No: 8P2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06435
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 L    HW: 8P0 959 655 L
   Component:    Airbag 9.41  H01 4210
   Revision: 91H01421    Serial number: 003CP000E4Y6
   Coding: 0071612
   VCID: 4BC06E0EFFCEEFFFFE8-801E
   Subsystem 1 - Serial number: 6332DRB405AC85A8+
   Subsystem 2 - Serial number: 6342DRB405AD9222R
   Subsystem 3 - Serial number: 63528RB402D1ED8B%
   Subsystem 4 - Serial number: 63628RB402D34EE6.
   Subsystem 5 - Serial number: 63747RB402C72EA2W
   Subsystem 6 - Serial number: 63847RB402C72F2F$
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0011142
   VCID: 41DC4C26CD8235AF144-8014
   Component: E0221           H01 0030
   Part No SW: 8P0 920 981 K    HW: 8P0 920 981 K
   Component: KOMBIINSTR. VDO H20 0640
   Revision: D0H20001    Serial number: 2247G001002748
   Coding: 0000408
   Shop #: WSC 12345 123 12345
   VCID: 40DA4922C6883CA71BA-8014
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K077190252
   Coding: ED807F0E1002022103
   Shop #: WSC 06314 123 12345
   VCID: 303A19E27628AC27EBA-8064
   Revision: D0H20001    Serial number: AUX7Z0G7FN601A
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0040
   Coding: 0000752
   VCID: 43D0462ED79E27BF068-8016
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.079 H08 1901
   Shop #: WSC 00999 444 64523
   VCID: 36362FFA944C8217B16-8062
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 J
   Component:    KSG          H10 0080
   Coding: 1980202002586D0085054C1FC677
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumueberw.H04 0020
   Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
   Component: AB2 SUBWOOFERBOXH06 0180
   Revision: 00005       Serial number: 30674703178581
   VCID: 353428F6894A890FB8C-8060
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0000752
   VCID: 44D24532D29020873F2-8010
Address 56: Radio        Labels: 8J0-035-1xx-56.clb
   Part No SW: 8P0 035 186 G    HW: 8P0 035 186 G
   Component: R Concert2+     H18 0270
   Revision: 00H18000    Serial number: AUZ1Z3G9101024
   Coding: 0110311
   Shop #: WSC 00565 210 80703
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000720
   Shop #: WSC 06314 000 1012551
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000720
   VCID: 42DE432AC8842EB70DE-8016
00099 - Rear Right Central Locking (Safe) Motor (V164)
Address 76: Park Assist        Labels: 8P0-919-283.lbl
   Part No SW: 8P0 919 283 D    HW: 8P0 919 283 D
   Component: Parkhilfe 4-Kan H09 0070
   Revision: 00H09000    Serial number: 00067824820721
   Coding: 0001113
   VCID: 3C223DD2AA605847472-8068
End----------(Elapsed Time: 01:26, VBatt start/end: 12.3V/12.3V)-----------
downtime
C?ID=280813
Looks like your rear door module is going bad. Does not affect the one touch function however.
Did you get that one sorted out by doing the basic setting?
geforce007
C?ID=303008
Hi done basic settings and no joy.
I went back to original coding and still no joy.
How ever I was trying wire the puddle lights into pin 1 and 2 on the grey plug when on my car it was pin 18 and 19.
hadez16
C?ID=289891
I have a slight different idea for the procedure:
Procedure :
2. Press and hold window down and keep pressing it for 5 secs after the window has been completely lowered. Release and press & hold down again for 5 secs. Release
3. Press and hold window up and keep it pressed for 5 secs after the windows has been completely raised. Release and press & hold up again for 5 secs. Release
downtime
C?ID=280813
Nope, that does not work. If you release the button too soon, basic setting is cancelled. At least on MK5 and MK6 platforms. MQB I've not had to do it so don't know if it's different there.
Even Ross-Tech agrees with me :
http://wiki.ross-tech.com/wiki/index.php/00932
downtime
C?ID=280813
Just for clarification. On which door was this? Passenger front door?
Are you sure pins 18 and 19 are correct? Did you already have something connected to pins 1 and 2? On drivers side pin2 should have brown earth wire connected to it.
Edit :
Seems that it could be either one :) Pin 1 & 2 or Pin 18 & 19.
http://www.myturbodiesel.com/wiki/puddle-light-retrofit-to-door-mirror-vw/
If you have multimeter you should be able to measure pin 18 after you've enabled puddle lights on the door control module using VCDS.
On the MQB platform you have to repeat the press & hold several times not just once.
geforce007
C?ID=303008
its the passenger front door and i no how to do basic settings on the one touch.
i had to do this for all 4 plenty of time's before.
its deffo pin 18 for the feed and 19 earth thats 110% then after 2007 they changed to pin 1 for feed and pin 2 for earth.
does anyone no what pin 1 and 2 are for ? on a 2007 audi a3 ?.
downtime
C?ID=280813
I'll check if I have Audio schematics on my ElsaWin.
geforce007
C?ID=303008
i got the window working.
i unplugged the passenger front module and reconnected.
