Hi I have a Passat (well someone I know) I did a diagnosis on it today...........car has no ignition coming on at all, so what I did is put a wire in the fuse box and connected it to another fuse resulting in ignition coming on and car starting and drivng with no lights coming on on the dash...........but soon as the wires disconnected the car go's off............so now I know that its not getting ignition what can be the problem.?
I have 2 scans one is before faults cleared and one after
this one below is one taken before the faults were cleared.
Monday,19,June,2017,12:51:24:07086
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x86
VCDS Version: 17.1.3.0
VIN: License Plate: 60-PASSAT
Mileage: 206760km-128474mi Repair Order:
Gateway Installation List: 3C0 907 530 Q
Monday,19,June,2017,12:50:19:07086
VIN: WVWZZZ3CZAP064007 License Plate: 60 PLATE PASSAT
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 77
VIN: WVWZZZ3CZAP064007 Mileage: 206760km-128474miles
04-Steering Angle -- Status: Sporadic communication error 1000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 997 025 P HW: 03L 907 309
Component: R4 2,0 EDC G000SG 0485
Revision: 13H08--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 50890 001 1048576
VCID: 3F8750B26E6612B9D0-806A
000144 - Valve for Fuel Metering (N290)
P0090 - 000 - Open Circuit - Intermittent
Mileage: 206763 km
Date: 2011.11.10
Time: 14:48:31
RPM: 552 /min
Voltage: 13.30 V
Pressure: 0.0 bar
Inj. Quantity: 23.9 mg/str
Lambda: 44.2 %
Lambda: 34.7 %
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 000 - Open Circuit - Intermittent
Mileage: 206763 km
Date: 2011.11.10
Time: 14:48:31
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --026--- Serial number: 00000706009469
Coding: 0003347
Shop #: WSC 00028 790 00007
VCID: 62C1B9C6BD541F519F-8036
00576 - Terminal 15
Reset counter: 148
Mileage: 206763 km
Date: 2011.11.10
Time: 14:32:47
Hex Value: 0x0000
Voltage: 13.25 V
Bin. Bits: 00111110
Count: 123
Hex Value: 0x0000
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AC HW: 3C8 907 336 AC
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
Shop #: WSC 00028 028 00020
ROD: EV_ClimaBasis_VW36.rod
VCID: 6ED9DDF6B18CAB310B-803A
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 188
Mileage: 206763 km
Date: 2017.06.19
Time: 14:32:56
13701392 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 188
Mileage: 206763 km
Date: 2017.06.19
Time: 14:32:56
9481748 - High Pressure Sensor
B10AE 14 [009] - Open or Short to Ground
Reset counter: 148
Mileage: 206763 km
Date: 2017.06.19
Time: 14:33:01
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000006103215
Coding: 00808F0700041A00470A00000F000000000859435C000120000000000000
Shop #: WSC 00028 028 00001
VCID: 32610986AD34CFD12F-8066
Subsystem 1 - Part No: 3C2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 140710 022 0612
Coding: 00046997
Shop #: WSC 00028
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 148
Mileage: 206763 km
Voltage: 13.65 V
02403 - Terminal 15 for Interior
Reset counter: 148
Mileage: 206763 km
Fault Status: 00100110
Reset counter: 188
Mileage: 206763 km
Voltage: 12.75 V
Reset counter: 188
Mileage: 206763 km
Reset counter: 188
Mileage: 206763 km
Voltage: 12.95 V
Reset counter: 188
Mileage: 206763 km
Part No SW: 5N0 959 655 N HW: 5N0 959 655 N
Component: J234__006 VW10 HI 1916
Revision: 21014000 Serial number: 003GHPENQK2H
Coding: 0012342
VCID: 48954B6E3BA8550161-801C
Subsystem 1 - Serial number: 6332MTS650301740
Subsystem 2 - Serial number: 6342MTS671211740
Subsystem 3 - Serial number: 6351HTS66ME1D6KR
Subsystem 4 - Serial number: 6361HTS6EA84D6KR
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
Component: LENKS.MODUL 009 0135
Revision: FF010037 Serial number: 20100726300650
Coding: 0182270002
VCID: 72E1C986A5B48FD1EF-8026
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C0 920 972 J HW: 3C0 920 972 J
Component: KOMBI H03 0305
Coding: 460F00
VCID: 2D5B1AFA7C0A902972-8078
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P10727000E
Coding: F9807F06400602001003
VCID: 2F6700F2BE06E23940-807A
Reset counter: 188
Mileage: 206763 km
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 7AF1E1A635C4F791A7-802E
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
02828 - Enabling Steering Column Lock from Diagnostic Interface
Reset counter: 188
Mileage: 206763 km
Date: 2011.11.10
Time: 14:32:47
Address 37: Navigation
Part No SW: 3C0 959 701 HW: 3C0 959 793
Component: TUER-SG FT 002 0306
Revision: 13101005 Serial number: 0001202801
Coding: 0002B5
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 65CBA2DA647A68697A-8030
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0402
Serial number: 00000001593334
Coding: 000290
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 147
Mileage: 206763 km
Date: 2017.06.19
Time: 14:25:01
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Reset counter: 148
Mileage: 206763 km
Date: 2017.06.19
Time: 14:57:06
68107 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 188
Mileage: 206763 km
Date: 2017.06.19
Time: 14:32:44
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 195 3001
Revision: 00H17000
VCID: 3163068AA832F4C956-8064
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 043 0612
Coding: 01910A0001860E763004941570085FCE107C01
Subsystem 1 - Part No: 1K8 951 605 A
Component: LIN BACKUP HORN H11 9004
Component: Neigungssensor 004 0611
Reset counter: 188
Mileage: 206763 km
Date: 2011.11.10
Time: 14:32:45
00625 - Vehicle Speed Signal
Reset counter: 188
Mileage: 206763 km
Date: 2011.11.10
Time: 14:32:45
Part No SW: 3C0 959 702 HW: 3C0 959 792
Component: TUER-SG BT 002 0306
Revision: 15101005 Serial number: 0001201168
Coding: 0002B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 66C9A5D6997C637173-8032
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0402
Serial number: 00000001594241
Coding: 000290
U1111 00 [008] - -
Reset counter: 188
Mileage: 206763 km
Date: 2017.06.19
Time: 14:32:44
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 011 Serial number: 00000000349812
Coding: 0000057
VCID: 2C5D17FE8F10992165-8078
00576 - Terminal 15
Fault Frequency: 9
Reset counter: 188
Mileage: 206763 km
Date: 2011.11.10
Time: 14:32:44
Voltage: 13.60 V
Count: 54
Hex Value: 0x1161
Hex Value: 0x0001
Hex Value: 0x1010
Address 56: Radio
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000A07951336
Coding: 012120
VCID: 2A5111E645E4871197-807E
End-------------------------(Elapsed Time: 02:24)--------------------------
