RNS 510 retrofit radio malfunction codes
ctsailor55
C?ID=16043
Greetings all. I have a 2014 JSW (built 2/14). I replaced the OEM RCD 510 with a RNS 510 version N radio/GPS (built 9/14) that came out of a 2015 Passat .
After installation, I had some minor issues but cleared those up with VCDS, these forums, and removing the compass module.
I was finally able to clear the can gateway fault code.
I still have the fault codes for the #37 navigation mode for control module and microphone for radio.
I think the microphone issue needs a hard wire connection but what code should the #37 control module be using? I haven't found it yet.
I ran the full scan but only post the pertinent info here (no other fault codes reported).
Any input or feedback greatly appreciated.
Friday,16,June,2017,21:32:05:25028
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
VIN: 3VWML7AJ6EM620622   License Plate:
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
VIN: 3VWML7AJ6EM620622   Mileage: 86550km-53779miles
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 24041403000976
   Coding: 352002
   Shop #: WSC 00066 123 12345
   VCID: 79ACE413B9DF4E8F6A7-802C
   Part No SW: 3C0 035 684 N    HW: 3C0 035 684 N
   Component: RNS-MID       H26 5378
   Revision: AB001001    Serial number: VWZ6Z7P3269019
   Coding: 0400004201000010000B
   Shop #: WSC 09003 957 00200
   VCID: 2E06074F301159378F5-807A
   Subsystem 1 - Part No: 7L6 919 859
   Component: NAR V8  8112
            000 -  -
                    Fault Frequency: 8
                    Reset counter: 162
                    Mileage: 86544 km
01523 - Microphone for Telephone (R38)
                    Reset counter: 162
                    Mileage: 86550 km
                    Date: 2017.06.16
                    Time: 20:45:26
            000 -  -
                    Fault Frequency: 9
                    Reset counter: 162
                    Mileage: 86544 km
                    Reset counter: 162
                    Mileage: 86550 km
                    Date: 2017.06.16
                    Time: 20:45:26
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007665901500
   Coding: 0A10030080010110
   Shop #: WSC 01383 790 50316
   ROD: EV_UHVUMI.rod
   VCID: 2E06074F309159378F5-807A
End----------(Elapsed Time: 01:10, VBatt start/end: 12.3V/12.3V)-----------
kamold
Australia
C?ID=241363
If you post your complete autoscan it's going to be easier to determine what you've done wrong with your coding.
It will show what other modules you have installed like RVC, steering wheel type etc.
Basically you need to go through all the coding bytes for your RNS (they are all documented in the long coding helper) and make sure the settings match what is in your car.
The mic error is because your microphone is not correctly wired/connected. If you don't have or want a microphone then you need to remove the mic (byte 3 bit 1).
ctsailor55
C?ID=16043
Thanks for the reply. The CAN gateway fault is gone but I still have 2 left on the nav system. Everything seems to work except no voice commands for the navigation (voice ok for phone). I'm not sure what should be checked off in the long code helper. Any help is greatly appreciated.
Here's the full auto scan:
Tuesday,20,June,2017,21:21:45:25028
VIN: 3VWML7AJ6EM620622   Mileage: 87150km-54152miles
   Part No SW: 03L 906 019 JS    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000SG  8183
   Revision: 12H16---    Serial number:
   Coding: 0050072
   Shop #: WSC 58947 001 1048576
   VCID: 055498E3C9273A6F1EF-8050
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 114B600C492400FA881106E6921B0042A1000022
   Shop #: WSC 00066 000 00000
   VCID: 7EA6F70FA0F169B75F5-802A
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 7N0 907 426 CA    HW: 7N0 907 426 CA
   Component: AC Manuell    H20 0606
   Revision: 00001002
   Coding: 0010002002
   Shop #: WSC 00066 000 00119
   VCID: 75B4E82395472AEF0EF-8020
   Part No SW: 5K0 937 084 L    HW: 5K0 937 084 L
   Component: BCM PQ35 B    122 0173
   Revision: BG122001
   Coding: AF380E1A802F3EC4008800C17000004449000086535D0520648020200040
   VCID: 3B203E1BF363BC9F38B-806E
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 26041  26  0512
   Coding: 009795
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R02ZJN5
   Coding: 00004E42
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C223D07F6EDBBA7311-8068
   Subsystem 1 - Part No SW: 1KM 959 339 B    HW: 1KM 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--0000AG7H00
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME50160C45ZZZQ
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME7D593C42ZZZ6
   Serial number: 3511HSME4A312730ZZZB
   Serial number: 3521HSME35042730ZZZ6
   Serial number: 35527SME1C154630ZZZ8
   Serial number: 35627SME71743C30ZZZE
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440NC50002S
   Coding: 108A140000
   Shop #: WSC 00066 000 00013
   ROD: EV_SMLSNGKUDS_VW32.rod
   VCID: 72BED33FE4293DD72BD-8026
   Serial number: 0306784 FLE 20140313
   Coding: 820000
   Part No SW: 5K0 920 973 G    HW: 5K0 920 973 G
   Coding: 270F01
   VCID: 35342823D5C76AEFCEF-8060
   Coding: 352002
   VCID: 6A8ECB5FCCF9F51793D-803E
Address 2E: Media Player 3
                    Reset counter: 170
                    Mileage: 87150 km
                    Date: 2017.06.20
                    Time: 21:18:31
            000 -  -
                    Reset counter: 170
                    Mileage: 87144 km
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0008242391
   Coding: 0004B5
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 5BE09E9B13A39C9F18B-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1509
   Serial number: 00000008602362
   Coding: 000490
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 392C2413F55F8E8F2A7-806C
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0008185403
   Coding: 0004B4
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 5CE29D8716AD9BA7111-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1509
   Serial number: 00000008592697
   Coding: 000490
            000 -  -
                    Reset counter: 170
                    Mileage: 87144 km
                    Reset counter: 170
                    Mileage: 87150 km
                    Date: 2017.06.20
                    Time: 21:18:31
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:19, VBatt start/end: 12.7V/12.7V)-----------
kamold
Australia
C?ID=241363
The mic needs to go from the head liner to the mic in pins on the rns.
Then from the mic out pins on the rns to the Bluetooth module mic in.
You likely have the mic connected only to the BT module not via the RNS
downtime
Finland
C?ID=280813
I don't think there's any MIC pins going to BT module itself. BT module is CAN connected and the information is exchanged through CAN-BUS.
When I installed RCD510 and 9W7 BT module I only connected MIC pins to the green connector block in the radio Quadlock connector. BT module only has can h + l, +12v and gnd connections to the radio.
kamold
Australia
C?ID=241363
I'm only on my phone so can't give you links but just Google.
If you want voice control on the rns it needs to be piggybacked off the BT mic.
It doesn't happen over can.
downtime
Finland
C?ID=280813
Ah, yes, voice control needs that true. I don't have voice control enabled as RCD510 does not support that so it only needs mic + and - to radio quadlock.
Sorry, I missed the voice control part :)
ctsailor55
C?ID=16043
Thanks for the replies. I think I remember seeing something posted somewhere, where wires were jumped from one connection to another.
Any feedback for the Nav module controller and radio codes?
tolunay
C?ID=254125
Can you please test this coding for the navigation unit ?
0400004001000090000B
