Various Databus Messages
drennie599
Northern Ireland
C?ID=109519
Have had these various databus messages for sometime, would like to eradicate most if possible, any guidance welcomed!
Friday,16,June,2017,18:37:11:49196
VCDS Version: 17.1.3.0 (x64)
Workshop Code: 874 00874 000874
VIN: WVWZZZ3CZGxxxxxxx   License Plate: DATABUS
Mileage: 19036km-11828mi   Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
          6C BB BC
VIN: WVWZZZ3CZGxxxxxxx   Mileage: 19036km-11828miles
Address 01: Engine (J623-CUAA)       Labels: 03N-906-026-CUA.clb
   Part No SW: 03N 906 026 E    HW: 03N 907 309
   Component: R4 2,0L EDC   H23 1754
   Revision: A1H23---
   Coding: 01250012036705083000
   Shop #: WSC 05311 115 00300
   ASAM Dataset: EV_ECM20BTD01103N906026E 001002
   ROD: EV_ECM20BTD01103N906026E.rod
   VCID: 2D55717A7CD1122972-8078
17156 - Databus
                    Mileage: 17619 km
                    Date: 2017.05.31
                    Time: 17:19:34
                    Coolant temperature: 51 °C
                    Intake air temperature: 46 °C
                    Voltage terminal 30: 12.040 V
                    Unlearning counter according OBD: 6
                    Drivetrain coordinator: ACC fault status-Bit 0: 0
                    Drivetrain coordinator: ACC fault status-Bit 8: 0
                    Drivetrain coordinator: brake fault status-Bit 0: 1
                    Drivetrain coordinator: brake function status-Bit 0: 0
                    Drivetrain coordinator: brake function status-Bit 8: 24
                    Acceleration: 0.000 m/s²
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0DL 300 011 H    HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5201
   Revision: 00H10V01
   ROD: EV_TCMDQ500021_VW41.rod
   Revision: 00000000    Serial number: 62615000001225
   Coding: 0EEC938F54280B6E077E070841C46970C92AD0E0E08296F5186250F8C209
   Shop #: WSC 12345 111 12345
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 7AFF8A26FD1F7591A7-802E
8277 - Databus
                    Reset counter: 201
                    Date: 2017.05.19
                    Time: 17:39:25
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0710
   Revision: 00026000    Serial number: 0380968757
   Coding: 000F0F0703
   VCID: 397D552AB899BE89EE-806C
   Part No SW: 5G2 907 044     HW: 5G2 907 044
   Revision: 00001K10
   Coding: 11120104202100011015504C0010180A
   Shop #: WSC 00015 115 00001
   ROD: EV_ACClimaBHBVW37X_004_VW48.rod
   VCID: 66C7CE5699A7E17173-8032
   Air quality sensor:
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
                    Reset counter: 28
                    Mileage: 18373 km
                    Date: 2017.06.10
                    Time: 20:17:38
                    Voltage terminal 30: 14.2 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.value: 1
                    Auxiliary heater: in stages-Specified value for control: 3
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86580309150065
   Coding: 03011C46C2C102FF07804094B11807281880000000000000000000000000
   Shop #: WSC 00874 874 00874
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 0301F7C28AD53459F4-8056
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150727  043 0607
   Serial number:         150820165011
   Coding: 0E4DFD
   Component: RLHS  037 0059
   Serial number: S2Y15M09D23H21M17S56
   Coding: 90A8DD
   Serial number: 11 06 2015  10001099
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY152170WU6
   Serial number: 00000000000063683899
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391526001331
   Coding: 0071151811
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 448334DECF5BF3618D-8010
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0192
   Coding: 3200678251FFC428949C804D
   Shop #: WSC 05311 115 00090
   ASAM Dataset: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3463641E9FFB43E13D-8060
2102 - Databus
                    Reset counter: 8
                    Mileage: 17619 km
                    Date: 2017.05.31
                    Time: 17:19:33
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 12.0 V
0836 - Databus
                    Reset counter: 43
                    Mileage: 16542 km
                    Date: 2017.05.19
                    Time: 17:39:24
                    Control Module temperature: 47 °C
                    Voltage terminal 15: 14.1 V
0928 - Databus
                    Reset counter: 8
                    Mileage: 17619 km
                    Date: 2017.05.31
                    Time: 17:19:33
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 19091541350191
   ROD: EV_DRCONTITEMIC.rod
   VCID: 377953128E8DA8F918-8062
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSPJF5JS+
   Coding: 98FCC0C0008000005C5400CC008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EF78636E13759B19B-802A
   Belt Pretensioner left:
   Serial number: 3G2857705E0261P00127
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 3G2857706E0260P01251
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 000 609 15
   Serial number: 3576U0000001C969661F
   Subsystem 4 - Part No SW: -----------    HW: 454 000 609 15
   Serial number: 3586U0000006D969661M
   Subsystem 5 - Part No SW: -----------    HW: 454 800 609 15
   Serial number: 3516R78332908000000$
   Subsystem 6 - Part No SW: -----------    HW: 454 800 909 15
   Serial number: 3526R5E0B61080000002
   Subsystem 7 - Part No SW: -----------    HW: 454 803 108 15
   Serial number: 3556V386625080000002
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 AL    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0185
   Revision: FF033033    Serial number: 20140801500212
   Coding: 8010
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
   ROD: EV_SMLSVALEOMQBLRH.rod
   Part No SW: 3G0 920 791 A    HW: 3G0 920 791 A
   Component: KOMBI         411 1340
   Coding: 27A50018BF80AE0001867F011000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009048
   VCID: 275983525E2D387988-8072
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 16091510800242
   Coding: 030300045F017300FB00025E9C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75E5991AD4011AE9CA-8020
   Serial number: 29160000688370046133
   Coding: 2FFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 6808707503
   Analog clock:
   Component: Analoguhr  111 1004
   Serial number: 0308201500010237
   Serial number: HA1-00028.07.15
   Coding: 0301
   Shop #: WSC 00015 115 08193
   VCID: 4A9F1AE6ED7F251177-801E
   Serial number: 15000073687012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71EDAD0AA06936C916-8024
   Serial number: 140915BIC20916
   Coding: 001F0A20D001028000001000
   VCID: 438137C2CA55F459B4-8016
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 0002
   Shop #: WSC 00015 115 00300
   ROD: EV_SteerAssisMQB_VW31.rod
   Serial number: 100915BIA01933
   Coding: 001F0020D001028000001000
   VCID: 428F32C6D54FFD51BF-8016
   Coding: 03A602000F200200
   Shop #: WSC 05311 000 08193
   VCID: 3F893B32A6BD90B9D0-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Coding: E02400
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    820 0627
   Coding: 02840101FF00000051111101008808001F0100D601200100CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 306B680E6BE37FC159-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9R2580238
   Subsystem 2 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-980-556.clb
   Part No SW: 5Q0 980 568     HW: 5Q0 980 568
   Component: RVC Compact+  H03 0100
   Coding: 01000101E2002017000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
   ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW48.rod
13705497 - Databus
                    Reset counter: 201
                    Mileage: 16542 km
                    Date: 2017.05.19
                    Time: 17:39:24
                    ARA_error_bits: 0
                    ARA_function_operating_time: 0.0000 s
                    Poor_image_quality_reason: Environmental conditions
                    Poor_image_quality_reason: 0.0000
                    Camera_System_Operating_Condition: passive
13705498 - Databus
                    Reset counter: 201
                    Mileage: 16542 km
                    Date: 2017.05.19
                    Time: 17:39:24
                    ARA_error_bits: 0
Address BB: Door Rear Drv (J388)       Labels: None
   Serial number: 270815BHR05229
   Coding: 000E00200101028000001000
   VCID: 458529DAC461CA699A-8010
Address BC: Door Rear Pass (J389)       Labels: None
   Serial number: 270815BHR0522B
End-------------------------(Elapsed Time: 05:35)--------------------------
Have you made any changes to this car's factory configuration?
drennie599
Northern Ireland
C?ID=109519
Only the rear view camera and added the Virtual Cockpit dashboard however everything apart from the DTCs in 6C were present before both were installed.
Spurious databus message faults seem to be a fact of life in the current generation of cars. Although they can certainly be brought on by tweaks retrofits, if they were there when the car was in factory stock configuration, I'm afraid I have no advice.
