Remove a key ?
Michael D. Frederiksen
C?ID=287897
My car has 3 keys adapted .. I was only handed 2 of them when I purchased the car.
I have no clue what key is missing, so I suppose I will need to clear all 3 keys
and re-addapt the two keys I do have ..
Is there a proper procedure to remove "the third" key, given my specific car model using VCDS ?
(You already have seen my autoscan plenty times in other threads here, so I wont repeat it again)
Generally, the only way to do that is to clear all the matching, then re-match the remaining keys.
Your car is a 4G-Chassis A6, right?
C?ID=287897
Well, just to be absolutely sure, I will let you be the judge of that.
I am quite sure you can tell every nut and bolt from the VIN.
Me, on the other hand would make assumptions based solely on
production year, and that may be a bit of a slugish diagnose :)
So, - VIN and all .. : :D
Friday,09,June,2017,16:47:18:39361
VCDS Version: 17.4.2.3 (x64)  HEX-NET CB: 0.4341.4
Data version: 20170505 DS270.4
VIN: WAUZZZ4G7DN016839   License Plate:
Mileage: 110978km-68958mi   Repair Order:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 3B 42 44 46 52 53 56
          5F 62 6D 72 8F 90
VIN: WAUZZZ4G7DN016839   Mileage: 110978km-68958miles
Address 01: Engine (J623-CHVA)       Labels: None
   Part No SW: 4G0 907 552 H    HW: 4G0 907 552 D
   Component: 2.8l V6 FSI   H07 0001
   Revision: --H07---
   Coding: 0A030034042401020000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM28FSI0214G0907552H 001001
   ROD: EV_ECM28FSI0214G0907552H.rod
   VCID: 2F2EDAD176848D3FA5-807A
Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
   Part No SW: 4G1 927 155 E    HW: 0AW 927 156 K
   Component: 0AW 28AVS RdW H04 0003
   Revision: --H04---    Serial number: 0000000175
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_TCMVL381 A02431
   ROD: EV_TCMVL381.rod
   VCID: 2E10C7D5718E8437AE-807A
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 02A187014085E180CB00
   VCID: 3620EFB589DEBCF7E6-8062
   Part No SW: 4H0 907 064 CH    HW: 4H0 907 064 CH
   Component: BCM2 2.0      H32 0421
   Coding: 01A83046000000000000
   VCID: 71AA1CA9A830DBCFF3-8024
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-4Z.clb
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0070
   Serial number: 01061200041357
   Coding: 4601007801
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 628863E575D670577A-8036
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 CB    HW: 4H0 907 063 B
   Revision: 13012002    Serial number: 00000001335007
   Coding: 6900C0108074A7E08105008300005F5FCF9CC2082E080201000008406001
   Shop #: WSC 46238 001 1048576
   VCID: 6A980BC585E62817B2-803E
   Component: WWS57X 120510  H35 0080
   Serial number:         120524040552
   Coding: 0045F7
   Serial number: 20327853
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
   Component: E1 - LDS  H07 0044
   Serial number: 30 05 2012  00000124
   Serial number: 9CE80136000000000001
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061215300196
   Coding: 88C305
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   ROD: EV_EPHVA18AU57X0000_003.rod
   VCID: 77BE22B1CE5485FF3D-8022
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Revision: --------    Serial number: 003JG008X834
   Coding: 30323436313330303333554A304C34473053
   Serial number: 3575HRB405L1D5MK4OVA
   Serial number: 3585HRB40531D5MK885+
   Serial number: 3515JRB401A4UI5CCPFZ
   Serial number: 3525JRB405518E5E81BJ
   Serial number: 3554VRB400A4UH26OGH1
   Serial number: 3564VRB400A4UH26EP6X
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: 00000000    Serial number: 20120612001418
   Coding: 000014
   VCID: 302CD9AD63BA92C7BC-8064
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0009
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 932 B    HW: 4G8 920 932 B
   Component: TBenRdw       H79 0515
   Revision: 28460207    Serial number: 658040612596038
   Coding: 13AE08000341000C010000
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K.rod
   Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000563319
   Coding: 00CD073000
   ASAM Dataset: EV_GatewPkoUDS 001013
   ROD: EV_GatewPkoUDS_001.rod
   VCID: 70AC19ADAB3AD2C7FC-8024
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790523990
   Voltage stabilizer:
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Revision: AA001002
   Coding: 01018264747464545425363E00
   VCID: 7CB43D9DFF72A6A750-8028
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
   Component: KLIMA FOND    H07 0070
   Serial number: 13061200040339
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0053
   Revision: --------    Serial number: EJ1BPA82003RMD
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   Component: TSG FA        H03 0506
   Coding: 011F16004000628002080002
   VCID: 47DE9271F634357F8D-8012
Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
   Part No SW: 4G0 909 144 AA    HW: 4G0 909 144 G
   Component: RCEPS         H35 0013
   Revision: 00001000    Serial number: 0011572879
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   VCID: 689C71CD93EA1A07A4-803C
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0176409948
   Coding: 0100062000B93000833008040801030F0000000000000000000000000000
   Component: TSG BF        H03 0506
   VCID: 46C09F75F13E2C7776-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000370676
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2B16CEC1429CF11F89-807E
   Part No SW: 4G0 035 056 E    HW: 4G0 035 056
   Component: Radio U STD   H60 0093
   Revision: AB001007    Serial number: 230EQ0C2542753
   Coding: 010003020100000001
   VCID: 230626E1224C395F31-8076
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
   Part No SW: 4G0 035 666 H    HW: 4G0 035 666 H
   Component: H-BN-EU       H49 0526
   Revision: --------    Serial number: 189F.0C7511281
   Coding: 050100000303E1ED07908F3E00000003E00001020000000000
   VCID: 2D12C0D97488FF2F97-8078
   Subsystem 1 - Part No: 8R0 060 884 ED
   Component: EUR 2017  2402
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC9401PJYK
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Serial number: 90349LF8000VD
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
   Component: TSG HL        H03 0506
   Coding: 010F14004000628002080002
   VCID: 49DA9449E020C30F9B-801C
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 4G5 959 107 A    HW: 4G5 959 107
   Component: HDSG-Modul    H01 0038
   Revision: 13001001    Serial number: 125201117
   Coding: 111104C000
   ASAM Dataset: EV_HDSGAu571 001001
   ROD: EV_HDSGAu571.rod
   VCID: 302CD9AD6BBA92C7BC-8064
   Component: TSG HR        H03 0506
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 312ADCA960B09BCFB3-8064
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 3228D3A565B6A0D7CA-8066
End-------------------------(Elapsed Time: 01:35)--------------------------
Yes... WAUZZZ4G7DN016839
'4G' in the 7th and 8th digit, and the 'D' in the 10th digit indicates it is a 2013 model (which may very well have been produced in 2012).
C?ID=287897
Thank you, - I learned something :-)
Does that allow you to infer a proper procedure for my purpose ?
Yes, proper procedure is take car to dealer and have them clear key matching and re-learn the two keys you have. Sorry, not something you can do with VCDS.
Dukedesmo
C?ID=288946
I had the same situation with my S4.
When I bought it I only got 2 keys - the 3rd plastic 'emergency' key was missing, likely broken? (although the holder to fit in the ignition is present). Initially I thought nothing of it as 2 keys is plenty but recently whilst looking through the settings I saw that 3 were activated and felt uncomfortable that there might be a working key out there which could fall into the wrong hands.
I had the car serviced a couple of weeks ago at the local Audi dealer and they recoded to just the 2 keys. Initially they quoted me a £60 recode fee but then did it FOC whilst in for service.
