12 jetta 2.5l abs module coding (MK60EC1)
protekorl
C?ID=310356
Im new at forum and have a 12 jetta 2.5 where after replace the instrument cluster and send it to the dealer to relearn the inmobilizer, now i have a code on the abs module of no coding. I check the auto scan and the current codes and is 00000000000000000000 is any way i can find that coding for the abs module.
this is the auto scan. please help thanks...
Wednesday,14,June,2017,16:19:31:57792
VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4341.4
VIN: 3VWDP7AJ6CM129727   License Plate:
Mileage: 114860km-71370mi   Repair Order:
Chassis Type: AJ (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
VIN: 3VWDP7AJ6CM129727   Mileage: 114860km-71370miles
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 CJ    HW: 07K 907 309 B
   Component: 2,5l R5/4V      G01 3691
   Revision: T4H06---    Serial number:
   Coding: 0000075
   Shop #: WSC 00066 067 57207
   VCID: 78BC0DBB0B328B81D1-802C
001169 - Secondary Air Injection System: Bank 1
               P0491 - 000 - Insufficient Flow
                    Mileage: 114869 km
                    Date: 2017.06.08
                    Time: 18:28:04
                    RPM: 1357 /min
                    Load: 48.2 %
                    Temperature: 29.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.970 V
Readiness: 0010 1101
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           1914
   Revision: 00H90000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 004C655B53E2C341E9-8054
   Revision: 00H31001
   VCID: 7DB21CAFE410AEA982-8028
            000 -  -
                    Reset counter: 134
                    Mileage: 114869 km
                    Date: 2017.06.08
                    Time: 21:01:37
                    Count: 16391
                    Count: 12
                    Count: 24576
                    Count: 195
                    Count: 45824
                    Count: 256
                    Count: 9984
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000829944
   VCID: 6FAE36E77E7CCC3900-803A
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0251
   Revision: B2066001    Serial number: 04371069121166
   Coding: 7B994B1808AB0B0000382000240884C500C2502E60000000300000000000
   VCID: 2F2EF6E77EFC8C3940-807A
   Subsystem 1 - Part No SW: 6R0 959 801 AF    HW: 6R0 959 801 AF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Serial number: 14102584130731195057
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0088301
   Coding: 020000
   Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14102586130801204452
   Coding: 800000
00975 - Heated Rear Window (Z1)
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Fault Frequency: 8
                    Reset counter: 174
                    Mileage: 114869 km
                    Date: 2017.06.08
                    Time: 20:48:08
03591 - Control Circuit for Horn
                    Reset counter: 134
                    Mileage: 114869 km
                    Date: 2017.06.08
                    Time: 20:51:25
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   014 0808
   Serial number: 003GTM03J2BJ
   Coding: 00003936
   Shop #: WSC 05234 444 100159
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3424F98B9FDAAFE13D-8060
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y120000C9XD0.
   Coding: 303036
   Serial number: 3572MSME3C76056AZZZ%
   Serial number: 3582MSME3530107AZZZN
   Serial number: 3516KSME715F5717ZZZ.
   Serial number: 3526KSME2F5D5717ZZZ2
   Serial number: 3556LSME145B7714ZZZY
   Serial number: 3566LSME07227C15ZZZV
   Part No SW: 5C6 920 951 B    HW: 5C6 920 951 B
   Component: KOMBI         H04 0604
   Coding: 270201
   Shop #: WSC 19565 002 1048576
   VCID: 2A18E7F34D1EE91197-807E
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0251
   Revision: B2066001
   Coding: 102200
   VCID: 70AC359BA342D3C119-8024
01304 - Radio
                    Reset counter: 134
                    Mileage: 114869 km
                    Date: 2017.06.08
                    Time: 21:02:39
02078 - Media Player Position 3 (R120)
                    Reset counter: 134
                    Mileage: 114869 km
                    Date: 2017.06.08
                    Time: 21:02:39
   Component: IMMO          H04 0604
   VCID: 6A9827F38D9E291157-803E
Address 2E: Media Player 3
Address 56: Radio
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H12 2902
   Revision: 1B001001    Serial number: 00007661732039
   Coding: 0A10040000010110
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 271E1EC75E0CD47988-8072
          B104F 13 [009] - Short to GND
                    Reset counter: 133
                    Mileage: 114869 km
                    Date: 2017.06.08
                    Time: 18:59:52
          B104E 13 [009] - Short to GND
                    Reset counter: 133
                    Mileage: 114869 km
                    Date: 2017.06.08
                    Time: 18:59:52
0022 - Radio
          U1066 00 [009] - No Communication
                    Reset counter: 133
                    Mileage: 114869 km
                    Date: 2017.06.08
                    Time: 18:59:52
End----------(Elapsed Time: 02:07, VBatt start/end: 12.0V/11.9V)-----------
Address 03: DTCs cleared
Address 01: DTCs clearedding is 000000000000000000000 is any way you guys can help me to find the old code......
Jef
HQ
Did you run an Auto-Scan prior to removing the original instrument cluster? VCDS automatically saves a "hidden" copy of Auto-Scans in the \Ross-Tech\VCDS\Scans folder. Take a look in there.
If you didn't run Auto-Scan prior to removing the instrument cluster... now you know why you should. :p If no one captured the ABS coding prior, reply back and we'll see what we can do.
Ashraf6119
C?ID=174194
Try this coding and let us know..........
a13b800d09240003851201e690200002200000
Gone But Not Forgotten
I would like to know why if the dealer installed a cluster or relearned the immobilizer why did they not recode the ABS because it is in fact part of the work procedure?
Coding: 0000075
Coding: 0000840
Revision: 00H31001
B14B400C492408038D1202E692201061A71000 JEF
A13B800D09240003851201D690200002200000 ASH
0000000009240003001200E690200000000000 VIN Stripped LHD
B14B440C492608008D1322E6921E1061A70000 From donor
B14B440C492408038D1202E692201061A70000 Try this...........
Donor abstract matched config
VIN: 3VWDP7AJ6CM346825
Component: 2,5l R5/4V G01 1156
Coding: 0000075
Address 02: Auto Trans Labels: 09G-927-750.lbl
Component: AQ 250 6F 2041
Revision: 00H97000 Serial number:
Coding: 0000840
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: B14B440C492608008D1322E6921E1061A70000
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Exactly same question, Coding ABS is part of the job.
Or VIN in cluster and car do not match , then online ABS coding can not be done.
You gained another star Marin.....
Very good point in follow up but vw will change the identity of every other controller in car to donor identity.
So OP now the question is does the Vin number match the actual chassis?
protekorl
C?ID=310356
Jef and Jack thanks for reply the cluster was replace with a use one the customer swap the clusters before send it to the dealer after that he have this coding code on abs module i tell him to tell the dealer to code that module at the same time they work with the inst cluster but they didn't. Now im stuck with the problem and thats why i dont have the auto scan eather.
protekorl
C?ID=310356
I try the coding but is giving me error12 sub function not supported or invalid format
I can help fix this through the mail with a complete documentation trail to prove ownership.
The dual identity will be combined in all eeproms to verify the path.
protekorl
C?ID=310356
And if the gymg dont want to.do it they need to take it back to the dealer to tbem to fix that right?
I would see if dealer would correct it free first but most likely wont take responsibility from what I have witnessed.
protekorl
C?ID=310356
Ok I witnessed that too. Just let me know what is next step thanks..
Go to contact form in my signature & start a written record request for immobilizer at website.
Yup correct module is the VIN the same in 0x25 advanced ID and 0x01-08-081 or advanced ID?
Vehicle Identification No.3VWDP7AJ6CM129727
ModelJetta
JEM
Date of production20.03.2012
Year2012
Sales type162WS3
Engine CodeCBUA
Transmission CodeMAN
Axle drive6A
Equipment NT
Roof colorA1
Exterior color / Paint CodeA1 / 041
protekorl
C?ID=310356
Im sorry guys has been a crazy day at the shop. I will check asap and sorry again
protekorl
C?ID=310356
Friday,16,June,2017,13:27:11:57792
VCDS Version: Release 17.1.3 (x64)
Address 01: Engine
Control Module Part Number: 07K 906 055 CJ
Component and/or Version: 2,5l R5/4V G01 3691
Software Coding: 0000075
Work Shop Code: WSC 00066
Advanced Identification
Identification: ZSC-864
Revision: T4H06---
Date: 11.03.12
Test stand number: 7825
Manufacturer number: 0160
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00000 000 00000
Flash Date: 00.00.00
Software
P0101
M14VA0
Misc.
Hardware number: 07K 907 309 B
Immo Challenge: A5 5F 15 21
Car Info
Chassis Number: 3VWDP7AJ6CM129727
Engine code: CBU
VCDS Info:
Readiness: 06A-906-032-BGP.crd
Friday,16,June,2017,13:31:09:57792
Control Module Part Number: 5K0 953 234
Component and/or Version: IMMO H04 0604
Software Coding: 000000
Work Shop Code: WSC 00000
Advanced Identification/FAZIT
Identification: ZYS-000
Date: 03.10.11
Manufacturer number: 4131
Test stand number: 1042
Flash Status
Software
OSEK-OS: 03.14.00
HiSpd Net: 01.12.01
Misc.
Hardware number: 5K0 953 234
Workshop System Name: J334
Equipment/PR Code: 2D2D2D2D2D2D2D2D
Dataset Number: -----------
Dataset Version: ----
End of Line Equipment Level: ------------------
ASAM Dataset Revision: A03009
Car Info
Immobilizer
Transponder ID (Current val.): F09B5499
Transponder ID 1: F09B5499
VCDS Info:
