2007 Passat with 2.5L 5-Cyl. Engine - ABS Coding?
kamold
Australia
C?ID=241363
If you change the ABS coding, it will require you to perform these again.
So no need to calibrate these sensors until you have a valid ABS coding string that results in no more 'control module incorrectly coded' error
   #22
Geoffzie
C?ID=309752
Forgive my stupid questions ... I've only had VCDS for about a week, this is all new to me!
So, when I'm changing the ABS coding, am I actually changing (rewriting) it in the ABS module itself? ... so it will communicate with the Jetta ECU? (through the CAN bus I assume).
   #23
kamold
Australia
C?ID=241363
I'm no expert no matter how fast and loose you want to play with the definition of the term, but have had to play with ABS coding quite a bit of late with an adaptive cruise retrofit.
Yes when you change the coding you are updating the EEPROM config in the ABS module itself.
ABS and ECU communicate with one another over the powertrain CANbus.
The ECU will log a fault in sympathy with the ABS to show that there is a DTC on the ABS. But once the ABS is clear of faults you can erase all other faults that may have resulted from the incorrectly coded ABS module.
Geoffzie
C?ID=309752
I'll have to get into this tomorrow.
Many moons ago I put a 1968 6-cyl. Porsche flat 6 into a VW based dune buggy. 4 bolts held it in ... some ignition wires, generator wires (or was it an alternator?), and an oil pressure wire ... voila, it was done!
Ah, for the good old days of VW engine swaps!
   #25
I feel the need to be pedantic here. VCDS asks the software it the module to update the EEPROM. The software in the module has a lot of plausibility checks in it, as evidenced by the fact that it rejects some values. In any case, that's not the same as updating the EEPROM config directly...
kamold
Australia
C?ID=241363
Thank you for the clarification :)
   #27
Geoffzie
C?ID=309752
Well, the VCDS is fine, I did three scans today. Don't know what the problem was yesterday.
I worked on the p2279 problem today. What's interesting is, if you disconnect the wire for the MAF/IAT ... the engine idles fine (probably in loop mode). I had another MAF/IAT sensor and switched them out ... no change. I also checked all the intake hoses, dip stick tube, and the air box ... didn't see any visible problems. I'll have to check the MAF/IAT fuse tomorrow, I forgot to do that.
With the MAF/IAT disconnected, I continued on my search for a working code for the ABS. I found that I don't actually have to start the engine to read the faults for the newly programmed ABS codes. But after going through about 100 codes ... I think I need to find better way, a more scientific approach ... this would take FOREVER!
I thought I read somewhere, that you can get VW codes direct from VW on-line ... is that true, or do I need to be a dealer?
What I don't understand is, before I got VCDS ... I had no faults or dash lights for the steering G85 ... now, after I've made some VCDS changes, I do have a dash light ... and no power assist?
At the end of the day today, I just disabled the ABS ... no more dash lights! I'll deal with the ABS later, after I get the engine issues resolved.
Here's my last VCDS scan of today (I had my interior light fuse out when I was doing my coding - I also have no idea why I'm now getting a clutch peddle code F36, I never had it before!) ...
Thursday,08,June,2017,14:06:56:23114
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
VIN: WVWBA71K78W315062   License Plate:
Chassis Type: 1K (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 6D
          72
VIN: WVWBA71K78W315062   Mileage: 219140km-136167miles
03-ABS Brakes -- Status: Not registered 0011
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 BJ    HW: 07K 906 032 Q
   Component: 2,5l R5/4V      G   1567
   Revision: 1NH01---    Serial number: VWX7Z0H33N97Z2
   Coding: 0000003
   Shop #: WSC 01279 785 00200
   VCID: 72BED2CB78AA85372BD-8026
050197 - Implausible Data Received from ABS Control Module
               U0415 - 008 -
                    Fault Status: 01101000
                    Mileage: 219137 km
                    Date: 2016.01.22
                    Time: 01:21:08
                    Load: 0.0 %
                    Temperature: 56.0°C
                    Temperature: -40.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 12.192 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 002 - Signal too High - MIL ON
                    Fault Status: 11100010
                    Mileage: 219137 km
                    Date: 2016.01.22
                    Time: 01:21:12
                    Load: 0.0 %
                    Temperature: 56.0°C
                    Voltage: 12.192 V
005171 - Secondary Air Pump Relay (J299)
               P1433 - 004 - Open Circuit - Intermittent
                    Mileage: 219137 km
                    Date: 2016.01.22
                    Time: 01:34:01
                    RPM: 273 /min
                    Load: 72.1 %
                    Temperature: 79.0°C
                    Voltage: 10.668 V
000258 - Mass Air Flow Sensor (G70)
               P0102 - 002 - Signal too Low - MIL ON
                    Mileage: 219137 km
                    Date: 2016.01.22
                    Time: 01:34:01
                    RPM: 283 /min
                    Load: 71.0 %
                    Temperature: 53.0°C
                    Voltage: 10.922 V
001393 - Brake Switch (F)
               P0571 - 008 - Implausible Signal
                    Mileage: 219140 km
                    Date: 2016.01.22
                    Time: 01:55:58
                    RPM: 761 /min
                    Load: 44.3 %
                    Speed: 8.0 km/h
                    Temperature: 72.0°C
                    Voltage: 14.224 V
Readiness: 0110 1101
   Part No SW: 09G 927 750 HJ    HW: 09G 927 750 CJ
   Component: AQ 250 6F           1068
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 08114 444 84076
   VCID: 005A88034606A7A72D9-8054
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0100005710
   Coding: 0013150
   Shop #: WSC 05311 000 00000
   VCID: 323E12CBB82AC537EBD-8066
            000 -  -
                    Reset counter: 49
                    Mileage: 219137 km
                    Date: 2016.01.22
                    Time: 01:49:47
            000 -  -
                    Reset counter: 49
                    Mileage: 219137 km
                    Date: 2016.01.22
                    Time: 01:49:47
                    Reset counter: 49
                    Mileage: 219137 km
                    Date: 2016.01.22
                    Time: 01:49:47
   Part No: 1K0 820 047 EB
   Component: Climatic PQ35   090 0505
   VCID: 688AB0A34E767FE7859-803C
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Revision: 00H46000    Serial number: 00000005468122
   Coding: 008C0F0340041A00470A00000F00000000285D435C0000
   Shop #: WSC 05311 123 12345
   VCID: 372823DF5348201FDC3-8062
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 05311
02399 - Control Circuit for Terminal 30 for Interior Illumination
            009 - Open or Short to Ground
                    Fault Status: 01111001
                    Reset counter: 50
                    Mileage: 219137 km
                    Date: 2016.01.21
                    Time: 00:13:00
                    Voltage: 12.80 V
00059 - Terminal 30 for Interior Lighting
                    Fault Status: 01101100
                    Reset counter: 50
                    Mileage: 219137 km
                    Date: 2016.01.21
                    Time: 00:00:00
                    Voltage: 12.75 V
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0N AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3P2W7PWA
   Coding: 0012366
   Shop #: WSC 05311 000 08193
   VCID: 2E0606BBAC12E1D78F5-807A
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 00000000032EPS
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0E716159Eÿ†63
   Subsystem 5 - Serial number: 16159Eÿ†6342MSME105B60746ÿ†63
   Subsystem 6 - Serial number: B60746ÿ†6351HTS64IKQTM627ÿ†63
   Subsystem 7 - Serial number: QTM627ÿ†6361HTS6TLLE15C3Uÿ†63
   Subsystem 8 - Serial number: E15C3Uÿ†63727TS63IK2T6C39ÿ†63
   Subsystem 9 - Serial number: 2T6C39ÿ†63827TS63IKEPNQ25ÿ
   Subsystem 10 - Serial number: EPNQ25ÿ
   Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C9953507R
   Coding: 0002014
   VCID: 313C1DC7BD2CFE2F927-8064
   Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: V0033000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 01119 067 57207
   VCID: 333017CF4730CC3FE0B-8066
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C0631304F6
   Coding: 3BFD0C0CD22002
   VCID: 211CED87EDCC4EAF027-8074
            000 -  -
                    Reset counter: 50
                    Mileage: 219137 km
                    Date: 2016.01.22
                    Time: 01:46:17
   Part No SW: 3C0 919 965 A    HW: 3C0 919 965 A
   Component: Kompass         001 0002
   Revision: 00001000    Serial number: 1339817TQ3XP02
   Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
   Component:    IMMO         041 0364
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 64713 001 1048576
   VCID: 2A0E0AAB90FA8DF753D-807E
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2801
   Coding: 0001205
   VCID: 36362EDB5442D917C75-8062
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
02546 - Steering Limit Stop
                    Mileage: 9080 km
                    Temperature: 27.0°C
                    Voltage: 14.60 V
                    Voltage: 14.30 V
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 RDK 041 0213
   Coding: 13900E88D1032E521804141FF00A0F0E081800
   Part No: 1K0 959 702 K
   Coding: 0001204
   Revision:   013
   Coding: 0000013
01316 - ABS Control Module
                    Fault Status: 00101101
                    Reset counter: 90
                    Mileage: 219136 km
                    Date: 2016.01.22
                    Time: 01:51:33
                    Voltage: 14.18 V
                    Count: 236
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 50
                    Mileage: 219136 km
                    Date: 2016.01.22
                    Time: 01:32:30
                    Voltage: 12.21 V
                    Count: 172
00650 - Clutch Pedal Switch (F36)
                    Fault Status: 00101010
                    Fault Frequency: 16
                    Reset counter: 90
                    Mileage: 219120 km
                    Date: 2016.01.20
                    Time: 20:00:48
                    Voltage: 13.25 V
                    Count: 71
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 A    HW: 1K0 035 161 A
   Component: Radio DE2       012 0015
   Revision: 00012000    Serial number: VWZ4Z7F6117447
   Coding: 0040400
   VCID: 1D64D177D1B46A4F26F-8048
   Part No: 3C9 959 703 A
   Component: Tuer-SG         021 2507
   Coding: 0000144
   Component:    RDK              0391
   Coding: 0100101
                    Fault Status: 00110100
                    Reset counter: 90
                    Mileage: 219097 km
                    Date: 2016.01.19
                    Time: 11:43:11
00667 - Ambient Temperature Signal
                    Fault Status: 00111000
                    Reset counter: 90
                    Mileage: 219137 km
                    Date: 2016.01.21
                    Time: 00:00:50
   Part No SW: 3C9 827 383 B    HW: 3C9 827 383 C
   Component: J605  HECKDECKEL    0405
   Revision: 00H20001
   Shop #: WSC 23250 384 715754
   VCID: 303A18C3B626F7279D9-8064
   Subsystem 1 - Part No: 3C9 827 384 B
   Component: J756  HECKDECKEL    0405
   Subsystem 2 - Serial number: 0600H20001001C0055ÿ
00317 - Rear Lid Control Module (J605)
                    Reset counter: 90
                    Mileage: 218433 km
                    Date: 2015.06.28
                    Time: 00:01:23
                    Fault Frequency: 10
                    Reset counter: 65
                    Fault Frequency: 6
                    Reset counter: 90
                    Mileage: 218433 km
                    Date: 2015.11.13
                    Time: 00:00:02
   Part No: 3C9 959 704 A
   Coding: 0000144
End----------(Elapsed Time: 01:15, VBatt start/end: 14.4V/14.4V)-----------
kamold
Australia
C?ID=241363
To test a coding string for the ABS only takes 2 seconds, doesn't need an ignition cycle, and only needs terminal 15. You can blast through a lot of possibilities in a pretty short time...
Coding -> faults, new code -> faults, rinse repeat.
Geoffzie
C?ID=309752
Kamold, forgive my ignorance (I'm a VCDS child!) ... but what is terminal 15?
You're basically saying that I "change the code ... check for faults ... change the code ... check for faults"? I've been turning the ignition off each time! Plus, I've never seen an ABS code that's less than 0010000 ... can't I start there? One more question ... I've noticed some posted ABS codes have a different WSC ... should I only use ABS codes that match my existing WSC? ... or should I change that as well?
   #30
kamold
Australia
C?ID=241363
Sorry terminal 15 just means you have the ignition set to accessories so everything is powered.
WSC (workshop code) should normally just be a non-zero value eg 12345.
Sure start at 1000 (not 10000).
eg set coding to 1000, check fault codes (control module incorrectly coded) go straight back to coding and put in 1001 then check fault codes again just flip back and forward between coding and faults for ABS only.
This technique is not suitable for all scenarios, some modules require a power cycle, some need to wait a set time to power off or so a soft reset. But it works for ABS coding...
   #31
Geoffzie
C?ID=309752
Kamold, I've noticed in my scans that other modules (like CAN Gateway and the Parking Brake) have had their coding changed since my first scan (with the resulting "Control Module incorrectly coded).
I have never altered the coding for these modules. Are the coding changes to the ABS module affecting (changing) these modules as well? ... or is there something else going on? I HAVE disabled my DRL and TPMS ... don't know if that would affect coding for the above modules.
I'm just trying to wrap my head around how all this works.
   #32
kamold
Australia
C?ID=241363
Get a working coding string in your abs and then you will be able to sort out other modules which rely on it like epb.
Abs and ecu are critical modules. Unless they are happy everyone else is sad :(
   #33
Geoffzie
C?ID=309752
OK, today I spent most of the day and went through about 500 ABS codes ... nothing that works without faults though. I had started at about 0013000 the other day, I'm up to about 0013800 now. I'll go back and try the numbers from 0001031 on if I'm unsuccessful with my present "needle-in-a-haystack" search.
I DID fix the engine miss ... it was the PCV Valve diaphragm that was torn (a common 2.5 problem). I just purchased the Dorman repair kit (PN 917-064) instead of the whole valve cover ($33 at Advance Auto). I cleared all the codes and it seems to be OK now.
Something else strange ... I did a VCDS scan at the end of the day, and the only steering fault was the "Steering Limit Stop Adaptation" ... the "Sensor For Steering Angle G85" is gone! Since the steering stop adjustment doesn't even require VCDS, just some steering turns, I did it ... and the steering is fine now.
I realize that if I ever get the ABS module coded ... I'll have to go through all the steering adjustments again.
   #34
Ashraf6119
C?ID=174194
What is your ABS Software Coding reading at the moment.............? Is it 0000000 or, any numbers.............? If its 0000000 than all your fault code for the Steering Angle Sensors will come back after ignition recycle..........
   #35
kamold
Australia
C?ID=241363
Just bear in mind that its possible that there isn't a valid coding string for the ABS module paired with that engine ECU...
The Passat ABS is a different type to the Golf/Jetta (supports EPB etc) - was that 2.5L engine available in a Passat in any market?
   #36
Yes, it was available in the NAR "NMS" Passat from 2012 through about 2014.
Geoffzie
C?ID=309752
Ashraf6119, the present ABS coding is 0014020 ... that's where I stopped for today. Although I just disabled the ABS in the CANbus ... got tired of looking at the light! I found that when I re-enable it ... my last coding entry is still there. From my last scan (below) it looks like it's ABS coding from an all-wheel-drive Passat ... and yes, it looks like my Steering Angle Sensor error came back ... but there's no dash light!?
The coding may be for a manual transmission also ... because I'm getting a clutch peddle error.
Yes kamold, that's what I'm faced with ... I've searched and searched, and can fine no VW's with the 2.5L engine, that were paired with the ABS unit in my car. I would REALLY like to get the ABS/ESP working in this car.
As Uwe said, VW did put the 2.5L in the Passat in 2012 ... but I've checked on eBay, and the used ABS units for those cars is NOT the same as mine. From the photos, they actually resemble a 2008 Jetta ABS unit. But unlike the Jetta unit, the 2012 Passat ABS unit should be compatible with the EPB ... but it's probably not compatible with my 2008 Jetta/Rabbit/Golf ECU!
In the beginning of this project, I actually bought a used ECU from a 2012 Passat 2.5L. But I couldn't find anyone who could disable the immobilizer in the ME17.5.6 ECU. Apparently, it's a lot more complex!
Any other ideas how I could get around this? I REALLY like the car ... it drives great with the 2.5L, although it may have a little less HP than the 2.0t ... it's a smooth running engine ... AND no more HPFP problems to worry about! The advantage of the 2.5L over the 2.0t or VR6 is ... COST. I paid $600 for the car in boxes ... I've got about $1000 in the 2.5L engine, ECU, Fuel pump, and various conversions pieces ... but I sold the old blown 2.0t engine parts for $700 on Craigslist and eBay!
Here's the last scan from about an hour ago (in Central Electric, I think I left my battery charger on it too long!) ...
          72
VIN: WVWBA71K78W315062   Mileage: 219160km-136179miles
65-Tire Pressure -- Status: Not registered 0001
   Coding: 0000003
               U0415 - 008 -
                    Mileage: 219152 km
                    Date: 2017.06.09
                    Time: 15:18:29
                    Load: 0.0 %
                    Temperature: 78.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 12.446 V
005173 - Secondary Air Pump Relay (J299)
               P1435 - 002 - Short to Ground - Intermittent
                    Mileage: 219152 km
                    RPM: 283 /min
                    Load: 73.7 %
                    Temperature: 47.0°C
                    Temperature: 45.0°C
                    Voltage: 10.922 V
                    Mileage: 219156 km
                    Date: 2017.06.09
                    Time: 15:46:44
                    RPM: 1230 /min
                    Load: 16.1 %
                    Speed: 61.0 km/h
                    Temperature: 74.0°C
                    Temperature: 47.0°C
                    Voltage: 14.224 V
Readiness: 0000 1100
   Coding: 0000072
   Coding: 0014020
            000 -  -
                    Reset counter: 49
                    Mileage: 219161 km
                    Date: 2017.06.09
                    Time: 19:33:48
01324 - Control Module for All Wheel Drive (J492)
            000 -  -
                    Reset counter: 49
                    Mileage: 219161 km
                    Date: 2017.06.09
                    Time: 19:33:48
            000 -  -
                    Reset counter: 49
                    Mileage: 219161 km
                    Date: 2017.06.09
                    Time: 19:33:48
            000 -  -
                    Reset counter: 49
                    Mileage: 219161 km
                    Date: 2017.06.09
                    Time: 19:33:48
                    Reset counter: 49
                    Mileage: 219161 km
                    Date: 2017.06.09
                    Time: 19:33:48
   Coding: 00063445
   Shop #: WSC 05311
                    Fault Status: 00111001
                    Reset counter: 90
                    Mileage: 219140 km
                    Date: 2017.06.09
                    Time: 14:19:00
                    Voltage: 12.90 V
00532 - Supply Voltage B+
                    Fault Status: 00100001
                    Reset counter: 90
                    Mileage: 219140 km
                    Date: 2017.06.09
                    Time: 14:00:00
                    Voltage: 15.75 V
                    Fault Status: 00101100
                    Reset counter: 90
                    Mileage: 219140 km
                    Date: 2017.06.09
                    Time: 13:56:00
                    Voltage: 14.15 V
                    Reset counter: 90
                    Mileage: 219140 km
                    Date: 2017.06.09
                    Time: 14:00:00
                    Voltage: 15.55 V
   Coding: 0012366
   Coding: 0002014
   Coding: 0007205
            000 -  -
                    Reset counter: 50
                    Mileage: 219140 km
                    Date: 2017.06.09
                    Time: 13:56:12
   Coding: 0001205
                    Reset counter: 90
   Coding: 0001204
   Revision:   013
   Coding: 0000012
                    Fault Frequency: 21
                    Reset counter: 90
                    Mileage: 219120 km
                    Date: 2016.01.20
                    Time: 20:00:48
                    Voltage: 13.25 V
                    Count: 71
   Coding: 0040400
   Coding: 0000144
   Component:    RDK              0391
   Coding: 0100101
   Revision: 00H20001
                    Reset counter: 90
                    Mileage: 218433 km
                    Date: 2015.06.28
                    Time: 00:01:23
                    Fault Frequency: 10
                    Reset counter: 65
                    Fault Frequency: 6
                    Reset counter: 90
                    Mileage: 218433 km
                    Date: 2015.11.13
                    Time: 00:00:02
   Coding: 0000144
End----------(Elapsed Time: 01:16, VBatt start/end: 14.0V/13.7V)-----------
kamold
Australia
C?ID=241363
What sort of ABS module would the factory 2.5L Passat have?
Is it expecting a 3C0 614 109 or a 3AA 614 109?
   #39
Geoffzie
C?ID=309752
Kamold, eBay has an ABS unit listed for 2012 Passat with 2.5L engine PN: 1K0 907 379 BK (that unit says "Steuergeraet ESP" on it, not sure what that means). I believe that's the part number of the ABS control unit, not the pump itself. That part number also corresponds to a genuine VW parts website called www.realoem.me
eBay also has an ABS unit listed for a 2006-09 Jetta (same as my ECU) and it's PN: 1CO 907 379 M (it also says "Steuergeraet ESP" on it). eBay also has other units listed for the same year Jetta, but the "M" suffix is different.
Physically, they both look the same ... although both are different than my present ABS unit PN: 3CO 614 095 S ... and they're different than the ABS unit I took off a 2008 Passat wagon 2.0t ... PN: 3CO 614 109 (don't remember the suffix) ... which is similar to the part number you listed.
So, if I purchased an ABS unit from a 2012 Passat with 2.5 engine ... it might work fine with the rest of the Passat system (I'd have to modify the mounting and line routing), but I'm not sure I could get it to work with the 2008 Jetta/Golf/Rabbit ECU. And if I purchased a 2006-09 Jetta ABS unit ... it would probably work with my ECU, but it would have no provision for EPB.
From the beginning of this project I had two goals ... I wanted the installation to "look factory" ... and I wanted everything to work properly (including the ABS/ESP). I guess I'll have to do some more research, there's got to be a way to do this.
kamold
Australia
C?ID=241363
Not sure the 3AA ABS module will support the CBT/CBUA engine, as it's not listed in Golfi-Vend's label file here:
http://forums.ross-tech.com/showthr...ofit-in-progress&p=87403&viewfull=1#post87403
If the NMS uses a MK60 ABS my (very limited) understanding is that these don't support an EPB.
I checked some reference scans of NMS and they don't have an EPB at address 53.
So if you install a 1K0 907 379 BK ABS then you'd need a manual handbrake perhaps...? But at least the ECU and ABS would be known to work together...
