Air Con Lost
Boy1925
C?ID=104764
Hi Chaps,
This was perhaps the warmest day here in England this year and my car chose today to cease breathing cool air for my comfort.
I'd like to attach an autoscan and a adaptation map and measurement block map each for channel 9. I could not see a security code to enable me to do the same for channel 8.
Unfortunately I seem not to be able to attach files. Is that because I'm not yet a heavy enough user?
In Channel 8 the fault code are 00457 and 00256 and 00256 also appears in Channel 9.
Is it just the temp sensor on top of the a/c rad or do you reckon there is something else wrong?
Thanks in anticipation of your help.
Westbury, UK
You don't attach them as files, you post them inline between CODE and /CODE (in square brackets) tags.
Boy1925
C?ID=104764
UWE, Many thanks for the pointer.
Here is my autoscan:
Monday,22,May,2017,21:25:39:60719
VCDS Version: 17.1.3.0 (x64)
VIN: WAUZZZ8K79A057310   License Plate: HD08LEU
Mileage: 338140km-210110mi   Repair Order: 22052017
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72
VIN: WAUZZZ8K79A057310   Mileage: 338140km-210110miles
Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 JM    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H01 3173
   Revision: 11H01---
   Coding: 0104002C18072118
   Shop #: WSC 06325 123 12345
   ASAM Dataset: EV_ECM20TDI03L906022JM A01005
   ROD: EV_ECM20TDI03L906022B.rod
   VCID: 79F2E125F8347D89AE-802C
5380 - Valve for Air Filter Bypass Flap (N275)
          P1016 00 [047] - Open Circuit
                    Mileage: 294350 km
                    Date: 2015.11.30
                    Time: 18:11:28
                    Engine speed: 869.50 /min
                    Normed load value: 54.5 %
                    Coolant temperature: 15 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 11.140 V
                    Crankshaft speed (RPM): 869.5 /min
                    Vehicle speed: 0.00 km/h
                    Accelerator position: 0.00 %
                    Ambient air pressure: 1006 hPa
                    Ambient temperature: 14.0 °C
                    Air mass: specified value: 532.4 mg/stroke
                    Intake air temperature: 14.0 °C
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AQ    HW: 8K0 907 379 AQ
   Component: ESP8 front    H03 0210
   Coding: 160500
   Shop #: WSC 06325 000 00000
   VCID: 081494E1BBDE1401A1-805C
   Part No SW: 8K0 907 064 BC    HW: 8K0 907 064 C
   Component: BCM2 1.1      H70 0252
   Coding: 031100
   VCID: 72E0D609AD420ED1EF-8026
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0508000027199019
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000026488004
   Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
   Component: KLIMA 3 ZONEN H06 0140
   Revision: D0000000    Serial number: 0116.06.080035
   Coding: 34040000
   VCID: 428046C9DD62FE51BF-8016
00457 - Control Module for Network (J519)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 218
                    Mileage: 338075 km
                    Date: 2017.05.22
                    Time: 14:43:13
                    Reset counter: 218
                    Mileage: 338075 km
                    Date: 2017.05.22
                    Time: 14:43:13
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Component: BCM1 1.0      H22 0253
   Revision: 04022001    Serial number: 00000000068449
   Coding: 2600D0914034AF000001000000001D0D001D030800010141000000
   VCID: 2F661F7D7EF0633940-807A
   Subsystem 1 - Part No SW: 8K2 955 119     HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 180608  H05 0060
   Serial number: SWFBIE 0000556
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10162674
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000002606080460
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 218
                    Mileage: 338075 km
                    Date: 2017.05.22
                    Time: 14:43:00
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD16TMKZ
   Coding: 30363434363030303030554A3052384B3053
   VCID: 3C7C3831B78688A1F5-8068
   Serial number: 6334MSME3B0266258
   Serial number: 6344MSME3B02675FN
   Serial number: 6352QSME7D232123A
   Serial number: 6362QSME6E7A246F%
   Serial number: 63732SME6426176F3
   Serial number: 63832SME6B7A341BA
   Component: Lenks.Modul   H12 0013
   Revision: --------    Serial number: 90319HFN00077
   Coding: 000016
   VCID: 3D7A3535A49C81A9C2-8068
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 980 B    HW: 8K0 920 980 B
   Component: KOMBIINSTR.   H16 0221
   Revision: 00200000    Serial number: 995609Y68
   Coding: 2F17080002002600010000
   VCID: 3162190568C475C956-8064
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0091
   Revision: GB102039    Serial number: 3900G086108161
   Coding: 000303
   VCID: 46885AD9F14AC27193-8012
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 18026CE2080608
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 C    HW: 8K0 959 793 A
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007340773
   Coding: 011002204001410001
   VCID: 40844CC1D36EEC41A9-8014
   Revision: 00002001    Serial number: 0112438069
   Coding: 011B0622003904400020010000000000
   Shop #: WSC 00752 210 91076
03532 - Left Brake / Signal Light Lamp 2
                    Fault Status: 11101100
                    Reset counter: 219
                    Mileage: 338149 km
                    Date: 2017.05.22
                    Time: 21:19:36
03554 - Left Brake Light Lamp 3
                    Reset counter: 219
                    Mileage: 338149 km
                    Date: 2017.05.22
                    Time: 21:19:36
03389 - Data Set Implausible
            000 -  -
                    Reset counter: 219
                    Mileage: 338149 km
                    Date: 2017.05.22
                    Time: 21:19:36
03555 - Right Brake Light Lamp 3
                    Reset counter: 219
                    Mileage: 338149 km
                    Date: 2017.05.22
                    Time: 21:19:36
03533 - Right Brake / Signal Light Lamp 2
                    Reset counter: 219
                    Mileage: 338149 km
                    Date: 2017.05.22
                    Time: 21:19:36
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S1900000
   Coding: 0205010101
   VCID: 6ED8C279B97A2A310B-803A
   Part No SW: 8K0 959 792 C    HW: 8K0 959 792 A
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007374201
   VCID: 3F864F3DAE9093B9D0-806A
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 10000000051590
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 346C101157D640E13D-8060
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 Q    HW: 8T2 035 186 Q
   Component: Concert3 DAB  H07 0350
   Revision: 00000010    Serial number: AUZ5Z6K1551892
   Coding: 0302008201018D02037B050800
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
            000 -  -
                    Reset counter: 219
                    Mileage: 272072 km
                    Date: 2015.01.31
                    Time: 09:09:10
                    Bin. Bits: 00000000
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 219
                    Mileage: 272072 km
                    Date: 2015.01.31
                    Time: 09:09:10
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000100077028
   Coding: 010002204001210001
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Part No SW: 8K0 959 794 A    HW: 8K0 959 795 A
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000100087538
End-------------------------(Elapsed Time: 02:50)--------------------------
and here is my adaptation map for channel 09;
Channel		Field 1	Field 2	Field 3	Field 4
1		ERROR:	Channel 01	Not	Available
2		ERROR:	Channel 02	Not	Available
3	9	- 	- 	100.00%	100.00%
4		ERROR:	Channel 04	Not	Available
5		ERROR:	Channel 05	Not	Available
6	1800	OFF	N/A	N/A	N/A
7	900	OFF	N/A	N/A	N/A
8		ERROR:	Channel 08	Not	Available
9		ERROR:	Channel 09	Not	Available
10		ERROR:	Channel 10	Not	Available
11		ERROR:	Channel 11	Not	Available
12	120	N/A	N/A	N/A	N/A
13	60	N/A	N/A	N/A	N/A
14		ERROR:	Channel 14	Not	Available
15		ERROR:	Channel 15	Not	Available
16	3	N/A	N/A	N/A	N/A
17		ERROR:	Channel 17	Not	Available
18	255	N/A	N/A	N/A	N/A
19	1	N/A	N/A	N/A	N/A
20		ERROR:	Channel 20	Not	Available
21	1	N/A	N/A	N/A	N/A
22	1	N/A	N/A	N/A	N/A
23	1	N/A	N/A	N/A	N/A
24	1	N/A	N/A	N/A	N/A
25	2000	N/A	N/A	N/A	N/A
26	5	N/A	N/A	N/A	N/A
27		ERROR:	Channel 27	Not	Available
28		ERROR:	Channel 28	Not	Available
29		ERROR:	Channel 29	Not	Available
30		ERROR:	Channel 30	Not	Available
31		ERROR:	Channel 31	Not	Available
32		ERROR:	Channel 32	Not	Available
33		ERROR:	Channel 33	Not	Available
34	0	N/A	N/A	N/A	N/A
35	0	N/A	N/A	N/A	N/A
36		ERROR:	Channel 36	Not	Available
37	3	N/A	N/A	N/A	N/A
38		ERROR:	Channel 38	Not	Available
39		ERROR:	Channel 39	Not	Available
40		ERROR:	Channel 40	Not	Available
41		ERROR:	Channel 41	Not	Available
42		ERROR:	Channel 42	Not	Available
43	10	N/A	N/A	N/A	N/A
44	1	N/A	N/A	N/A	N/A
45	0	N/A	N/A	N/A	N/A
46	0	N/A	N/A	N/A	N/A
47	0	N/A	N/A	N/A	N/A
48	120	N/A	N/A	N/A	N/A
49	120	N/A	N/A	N/A	N/A
50	120	N/A	N/A	N/A	N/A
51	120	N/A	N/A	N/A	N/A
52	120	N/A	N/A	N/A	N/A
53	0	N/A	N/A	N/A	N/A
54		ERROR:	Channel 54	Not	Available
55	1	N/A	N/A	N/A	N/A
56	1	N/A	N/A	N/A	N/A
57		ERROR:	Channel 57	Not	Available
58		ERROR:	Channel 58	Not	Available
59		ERROR:	Channel 59	Not	Available
60		ERROR:	Channel 60	Not	Available
61		ERROR:	Channel 61	Not	Available
62		ERROR:	Channel 62	Not	Available
63		ERROR:	Channel 63	Not	Available
64		ERROR:	Channel 64	Not	Available
65		ERROR:	Channel 65	Not	Available
66		ERROR:	Channel 66	Not	Available
67		ERROR:	Channel 67	Not	Available
68		ERROR:	Channel 68	Not	Available
69		ERROR:	Channel 69	Not	Available
70		ERROR:	Channel 70	Not	Available
71		ERROR:	Channel 71	Not	Available
72		ERROR:	Channel 72	Not	Available
73		ERROR:	Channel 73	Not	Available
74		ERROR:	Channel 74	Not	Available
75		ERROR:	Channel 75	Not	Available
76		ERROR:	Channel 76	Not	Available
77		ERROR:	Channel 77	Not	Available
78		ERROR:	Channel 78	Not	Available
79		ERROR:	Channel 79	Not	Available
80		ERROR:	Channel 80	Not	Available
81		ERROR:	Channel 81	Not	Available
82		ERROR:	Channel 82	Not	Available
83		ERROR:	Channel 83	Not	Available
84		ERROR:	Channel 84	Not	Available
85		ERROR:	Channel 85	Not	Available
86		ERROR:	Channel 86	Not	Available
87		ERROR:	Channel 87	Not	Available
88		ERROR:	Channel 88	Not	Available
89		ERROR:	Channel 89	Not	Available
90		ERROR:	Channel 90	Not	Available
91		ERROR:	Channel 91	Not	Available
92		ERROR:	Channel 92	Not	Available
93		ERROR:	Channel 93	Not	Available
94		ERROR:	Channel 94	Not	Available
95		ERROR:	Channel 95	Not	Available
96		ERROR:	Channel 96	Not	Available
97		ERROR:	Channel 97	Not	Available
98		ERROR:	Channel 98	Not	Available
99		ERROR:	Channel 99	Not	Available
100		ERROR:	Channel 100	Not	Available
101		ERROR:	Channel 101	Not	Available
102		ERROR:	Channel 102	Not	Available
103		ERROR:	Channel 103	Not	Available
104		ERROR:	Channel 104	Not	Available
105		ERROR:	Channel 105	Not	Available
106		ERROR:	Channel 106	Not	Available
107		ERROR:	Channel 107	Not	Available
108		ERROR:	Channel 108	Not	Available
109		ERROR:	Channel 109	Not	Available
110		ERROR:	Channel 110	Not	Available
111		ERROR:	Channel 111	Not	Available
112		ERROR:	Channel 112	Not	Available
113		ERROR:	Channel 113	Not	Available
114		ERROR:	Channel 114	Not	Available
115		ERROR:	Channel 115	Not	Available
116		ERROR:	Channel 116	Not	Available
117		ERROR:	Channel 117	Not	Available
118		ERROR:	Channel 118	Not	Available
119		ERROR:	Channel 119	Not	Available
120		ERROR:	Channel 120	Not	Available
121		ERROR:	Channel 121	Not	Available
122		ERROR:	Channel 122	Not	Available
123		ERROR:	Channel 123	Not	Available
124		ERROR:	Channel 124	Not	Available
125		ERROR:	Channel 125	Not	Available
126		ERROR:	Channel 126	Not	Available
127		ERROR:	Channel 127	Not	Available
128		ERROR:	Channel 128	Not	Available
129		ERROR:	Channel 129	Not	Available
130		ERROR:	Channel 130	Not	Available
131		ERROR:	Channel 131	Not	Available
132		ERROR:	Channel 132	Not	Available
133		ERROR:	Channel 133	Not	Available
134		ERROR:	Channel 134	Not	Available
135		ERROR:	Channel 135	Not	Available
136		ERROR:	Channel 136	Not	Available
137		ERROR:	Channel 137	Not	Available
138		ERROR:	Channel 138	Not	Available
139		ERROR:	Channel 139	Not	Available
140		ERROR:	Channel 140	Not	Available
141		ERROR:	Channel 141	Not	Available
142		ERROR:	Channel 142	Not	Available
143		ERROR:	Channel 143	Not	Available
144		ERROR:	Channel 144	Not	Available
145		ERROR:	Channel 145	Not	Available
146		ERROR:	Channel 146	Not	Available
147		ERROR:	Channel 147	Not	Available
148		ERROR:	Channel 148	Not	Available
149		ERROR:	Channel 149	Not	Available
150		ERROR:	Channel 150	Not	Available
151		ERROR:	Channel 151	Not	Available
152		ERROR:	Channel 152	Not	Available
153		ERROR:	Channel 153	Not	Available
154		ERROR:	Channel 154	Not	Available
155		ERROR:	Channel 155	Not	Available
156		ERROR:	Channel 156	Not	Available
157		ERROR:	Channel 157	Not	Available
158		ERROR:	Channel 158	Not	Available
159		ERROR:	Channel 159	Not	Available
160		ERROR:	Channel 160	Not	Available
161		ERROR:	Channel 161	Not	Available
162		ERROR:	Channel 162	Not	Available
163		ERROR:	Channel 163	Not	Available
164		ERROR:	Channel 164	Not	Available
165		ERROR:	Channel 165	Not	Available
166		ERROR:	Channel 166	Not	Available
167		ERROR:	Channel 167	Not	Available
168		ERROR:	Channel 168	Not	Available
169		ERROR:	Channel 169	Not	Available
170		ERROR:	Channel 170	Not	Available
171		ERROR:	Channel 171	Not	Available
172		ERROR:	Channel 172	Not	Available
173		ERROR:	Channel 173	Not	Available
174		ERROR:	Channel 174	Not	Available
175		ERROR:	Channel 175	Not	Available
176		ERROR:	Channel 176	Not	Available
177		ERROR:	Channel 177	Not	Available
178		ERROR:	Channel 178	Not	Available
179		ERROR:	Channel 179	Not	Available
180		ERROR:	Channel 180	Not	Available
181		ERROR:	Channel 181	Not	Available
182		ERROR:	Channel 182	Not	Available
183		ERROR:	Channel 183	Not	Available
184		ERROR:	Channel 184	Not	Available
185		ERROR:	Channel 185	Not	Available
186		ERROR:	Channel 186	Not	Available
187		ERROR:	Channel 187	Not	Available
188		ERROR:	Channel 188	Not	Available
189		ERROR:	Channel 189	Not	Available
190		ERROR:	Channel 190	Not	Available
191		ERROR:	Channel 191	Not	Available
192		ERROR:	Channel 192	Not	Available
193		ERROR:	Channel 193	Not	Available
194		ERROR:	Channel 194	Not	Available
195		ERROR:	Channel 195	Not	Available
196		ERROR:	Channel 196	Not	Available
197		ERROR:	Channel 197	Not	Available
198		ERROR:	Channel 198	Not	Available
199		ERROR:	Channel 199	Not	Available
200		ERROR:	Channel 200	Not	Available
201		ERROR:	Channel 201	Not	Available
202		ERROR:	Channel 202	Not	Available
203		ERROR:	Channel 203	Not	Available
204		ERROR:	Channel 204	Not	Available
205		ERROR:	Channel 205	Not	Available
206		ERROR:	Channel 206	Not	Available
207		ERROR:	Channel 207	Not	Available
208		ERROR:	Channel 208	Not	Available
209		ERROR:	Channel 209	Not	Available
210		ERROR:	Channel 210	Not	Available
211		ERROR:	Channel 211	Not	Available
212		ERROR:	Channel 212	Not	Available
213		ERROR:	Channel 213	Not	Available
214		ERROR:	Channel 214	Not	Available
215		ERROR:	Channel 215	Not	Available
216		ERROR:	Channel 216	Not	Available
217		ERROR:	Channel 217	Not	Available
218		ERROR:	Channel 218	Not	Available
219		ERROR:	Channel 219	Not	Available
220		ERROR:	Channel 220	Not	Available
221		ERROR:	Channel 221	Not	Available
222		ERROR:	Channel 222	Not	Available
223		ERROR:	Channel 223	Not	Available
224		ERROR:	Channel 224	Not	Available
225		ERROR:	Channel 225	Not	Available
226		ERROR:	Channel 226	Not	Available
227		ERROR:	Channel 227	Not	Available
228		ERROR:	Channel 228	Not	Available
229		ERROR:	Channel 229	Not	Available
230		ERROR:	Channel 230	Not	Available
231		ERROR:	Channel 231	Not	Available
232		ERROR:	Channel 232	Not	Available
233		ERROR:	Channel 233	Not	Available
234		ERROR:	Channel 234	Not	Available
235		ERROR:	Channel 235	Not	Available
236		ERROR:	Channel 236	Not	Available
237		ERROR:	Channel 237	Not	Available
238		ERROR:	Channel 238	Not	Available
239		ERROR:	Channel 239	Not	Available
240		ERROR:	Channel 240	Not	Available
241		ERROR:	Channel 241	Not	Available
242		ERROR:	Channel 242	Not	Available
243		ERROR:	Channel 243	Not	Available
244		ERROR:	Channel 244	Not	Available
245		ERROR:	Channel 245	Not	Available
246		ERROR:	Channel 246	Not	Available
247		ERROR:	Channel 247	Not	Available
248		ERROR:	Channel 248	Not	Available
249		ERROR:	Channel 249	Not	Available
250		ERROR:	Channel 250	Not	Available
251		ERROR:	Channel 251	Not	Available
252		ERROR:	Channel 252	Not	Available
253		ERROR:	Channel 253	Not	Available
254		ERROR:	Security	access	required
255		ERROR:	Security	access	required
I hope that is helpful.
DrPeter
16.4905° S, 151.7375° W
- Thanks for posting the Auto-Scan, the G395 sensor can be a common cause of 'no AC' failure on these vehicles.
If you look at the A/C condenser, the G395 should be on the outlet side line. I would suggest to disconnect the electrical connection and see if there is any evidence of refrigerant oil leaking, a common side effect when these fail.
We suggest to consult with the Official Factory Repair Information for component locations and proper repair procedures.
- You can use VCDS to view the G395 pressure in the Measuring Value Block group 1, field (4). This sensor should read about 1-bar of atmospheric pressure at sea level when NOT connected to the refrigerant line, so if there was no refrigerant in the system, you should at least see a reading of 1-bar. With a properly charged AC system, static system pressure could be 4 to 8 bar depending on temperature and the amount of charge in the system.
If you end up replacing a defective G395, be sure to clear all the fault codes.
ref: 00256 - A/C Pressure/Temperature Sensor (G395)
Also have a look at this Ross-Tech forum post we have: Tis’ the HVAC Season
Hope this helps and be careful!!! AC systems and refrigerant dangerous if not properly understood and worked on with safety in mind!
drpeter
Boy1925
C?ID=104764
Thanks Dr P.
I have replaced one of these on my old B6 A4 and it was pretty simple, but I appreciate the warning and your guidance on the pressure readings I should expect.
HamR
New Zealand
C?ID=287514
Thank you to those who contributed to this thread. I have the same symptoms. When I attempt to look at the Measuring Value Block group 1, field (4) I get data in the first two fields, nothing in the third and "ERROR" in the fourth.
Since the AC failure has been sudden, I'm going to assume it's a sensor issue and not a leak.
ak77
Singapore
C?ID=232348
Hi guys,
My experience in last 3 cars in Australia was control solenoid valve.
Even dough the codes were pointing elsewhere. Mostly they fail..
Al
HamR
New Zealand
C?ID=287514
Thanks Al,
In my case it was a sensor in my Q5. But I've had the solenoid fail in my Passat too. When the solenoid failed, the a/c would still work for the first five minutes, then stop.
