VCDS® HEX-V2® Enthusiast capabilities?
redrooster
Canada
C?ID=307086
As I am new here, Hi everyone.
I am considering buying the Hex-V2 and want to know if I will be able to dis-able the warning chimes for the seat belts on my 2006 VW Jetta TDI?:thanks:
Yes, I'm pretty confident you should be able to do that.
redrooster
Canada
C?ID=307086
Well that's what I want to hear in order to justify the purchase.
I hope I will get some more confirmation on it just the same from other users?
Ademaxx
C?ID=146334
I disabled them on my 2008 Golf with the HEX-USB so there's no reason the V2 shouldn't do it also.
The one hesitancy I have is that 2006 NAR model Jettas used a somewhat unique/unusual instrument cluster that lacks some features that were standard in most other clusters. Unfortunately, I'm not able to find a scan from one off the cuff.. :(
Santos
It might be possible. Here's a coding screenshot from a very early mk5 cluster (i believe from 2006 jetta) without multifunction support.
                Address 17: Instruments       Labels: 1K0-920-xxx-17.lbl
Control Module Part Number: 1K0 920 953 CX
  Component and/or Version: KOMBIINSTRUMENT 3HL 4312
           Software Coding: 0000203
            Work Shop Code: WSC 00000 000 00000
                      VCID: 03464E4C42EA0459C6-8056
8 Faults Found:
00381 - Databus Instrument Cluster
00461 - Control Module for Seat Memory; Passenger (J521)
00771 - Fuel Level Sensor (G)
            010 - Open or Short to Plus
01316 - ABS Control Module
            013 - Check DTC Memory
redrooster
Canada
C?ID=307086
I think this is my cluster only mine is a US car.I don't know anything about the scan details that you are showing though?
8 Faults Found:
redrooster
Canada
C?ID=307086
That's what I want to hear/do
