2006 Jetta 2.5 Sedan Central Locking Problem Dtc 00928
Carfixr
C?ID=136362
Drivers door can not control any other power windows or locks,
All other doors can operate windows and locks.
Found and repaired 3 broken wires under boot.
Replaced drivers master switch, no change,
Removed panel found lkq window motor, see old motor on back seat,
Installed motor, now all windows can be operated from master switch,
Now just have 00928.
The drivers lock switch shows on and off on vcds and all ways shows
locked even though drivers door never locks, even with key fob.
I assuming the drivers lock module is the problem,
Is it possible to reuse second hand power window motor and door lock
module , or are they locked down to the donor car?
Thank You
Monday,05,March,2018,16:22:10:39461
VCDS Version: 17.8.0.1
VIN: 3VWSF71K26M654842   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72
VIN: 3VWSF71K26M654842   Mileage: 190410km-118315miles
42-Door Elect, Driver -- Status: Malfunction 1010
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 N    HW: Hardware No
   Component: 2.5l R5/4V      G   6698
   Revision: --------    Serial number: VWZ7Z0E2500996
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 346D13B257A14AE65E-8060
   Part No SW: 09G 927 750 EL    HW: 09G 927 750 EL
   Component: AQ 250 6F           0758
   Revision: 00H25000    Serial number:
   Coding: 0000072
   VCID: 7F070C9E2E6759BEF3-802A
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Revision: 00T12001
   Coding: 0021122
   VCID: 40854F621319E646CA-8014
            002 - Lower Limit Exceeded
   Part No: 1K0 820 047 DL
   Component: Climatic PQ35   090 0505
   VCID: 71E3DAA668333FCE75-8024
00532 - Supply Voltage B+
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000000122344
   Coding: 04058E234004180000140000001400000008730B5C
   VCID: 2A510DCA85650C16F4-807E
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 00066
                    Fault Status: 01100010
                    Reset counter: 206
                    Mileage: 190417 km
                    Voltage: 6.80 V
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7E2030390
   VCID: 2B5F08CE8A9F151E0F-807E
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 241
                    Mileage: 89571 km
                    Time: 02:12:05
                    Fault Frequency: 6
                    Reset counter: 231
                    Mileage: 190042 km
                    Time: 07:35:12
                    Voltage: 8.40 V
                    Fault Frequency: 7
                    Reset counter: 231
                    Mileage: 190042 km
                    Time: 07:35:12
                    Voltage: 8.40 V
02788 - Internal Communications Error
            000 -  -  - Intermittent
                    Reset counter: 246
                    Mileage: 89571 km
                    Time: 02:12:04
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
01304 - Radio
                    Reset counter: 246
                    Mileage: 190042 km
                    Time: 07:54:46
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD033CEW
   Coding: 0012627
   VCID: 2E5901DAB98D603628-807A
   Subsystem 1 - Component: BF-Gewichtsens.
   Subsystem 2 - Serial number: 6332MSME0A664707B
   Subsystem 3 - Serial number: 6342MSME0A671E0CM
   Subsystem 4 - Serial number: 6351HSME075A606DE
   Subsystem 5 - Serial number: 6361HSME0768084FG
   Subsystem 6 - Serial number: 63727SME073E1F1CD
   Subsystem 7 - Serial number: 63827SME072B1C622
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0010021
   VCID: 78F5E7820B496E86B2-802C
   Part No: 1K0 920 952 C
   Component: KOMBIINSTRUMENT 3HL 1212
   Coding: 0023203
   Revision:   H10       Serial number: 28001056108AD9
   Coding: 3F3F0360071002
                    Reset counter: 245
                    Mileage: 190061 km
                    Time: 00:10:25
                    Reset counter: 206
                    Mileage: 190417 km
                    Time: 00:01:01
   Component: IMMO            3HL 1212
   Shop #: WSC 41239 001 1048576
01176 - Key
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000531869219
   Coding: 0001205
   VCID: 3B7F388E7AFF859E9F-806E
7 Faults Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
                    Reset counter: 206
                    Mileage: 190417 km
                    Fault Status: 00100101
                    Reset counter: 245
                    Mileage: 190417 km
01552 - Motor for Central Locking; Drivers Door (V56); Lock
                    Fault Status: 00111100
                    Fault Frequency: 6
                    Reset counter: 246
                    Mileage: 190417 km
                    Fault Status: 01111000
                    Reset counter: 206
                    Mileage: 190417 km
01706 - Switch for Mirror-Adjust (E43)
                    Reset counter: 206
                    Mileage: 190417 km
01030 - Central Locking Key Switch; Driver Side; Lock
                    Fault Status: 00111000
                    Fault Frequency: 8
                    Reset counter: 246
                    Mileage: 190417 km
00109 - Left Mirror Turn Signal Lamp (L131)
                    Reset counter: 246
                    Mileage: 190417 km
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 326115AAADB544D64C-8066
            002 - Lower Limit Exceeded - MIL ON
                    Mileage: 400 km
                    Temperature: 12.0°C
                    Voltage: 4.60 V
                    Voltage: 5.40 V
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AF
   Coding: 137803281B09050F880F048051A0
   VCID: 74EDD3B217210AE69E-8020
No Faults Found
   Part No: 1K0 959 702 K
   Component: Tuer-SG         024 2377
   Coding: 0001269
   Shop #: WSC 08305 993 56004
   VCID: 377724BE46D7A1FE7B-8062
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
   Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
   Component: Radio DE2       011 0014
   Revision: 00011000    Serial number: VWZ4Z7E2034023
   Coding: 0040400
   VCID: 2045EFE2F359C646AA-8074
Address 62: Door, Rear Left        Labels: None
   Part No: 1K0
   VCID: 2C5D0BD28F91122606-FFFE
No Faults Found
   Part No: 1K0 959 704 D
   Component: Tuer-SG         021 2434
   Coding: 0000144
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End-------------------------(Elapsed Time: 02:22)--------------------------
Lotta faults still present in 42: Door Elect, Driver. Have you cleared them yet? Do they come back? The one I would focus on first is: "1811 - Supply Voltage for Door Controller; Drivers Side (J386) - Lower Limit Exceeded".
However, it also bothers me that 46: Central Conv. is showing:
"No Faults Found
What happens if you go directly to 46 and check it for faults?
Carfixr
C?ID=136362
2005 Jetta
I disconnected the battery for 30 minutes, 00928 seems to have cleared, all doors except passenger right
lock-unlock with key fob, passenger right rear door button not lighting up.
Drivers door lock-unlock key icon shows dim then goes out, doesn't lock or unlock,
but does sound like it is try to actuate.
Saturday,10,March,2018,11:39:10:39461
   Coding: 0000003
   Coding: 0000072
   Revision: 00T12001
   Coding: 0021122
   Coding: 00065493
   Shop #: WSC 00066
                    Fault Status: 01101100
                    Reset counter: 208
                    Mileage: 190417 km
                    Voltage: 14.15 V
                    Reset counter: 208
                    Mileage: 190417 km
                    Voltage: 14.05 V
            014 - Defective
                    Reset counter: 241
                    Mileage: 89571 km
                    Time: 02:12:05
            000 -  -
                    Reset counter: 208
                    Mileage: 190417 km
                    Time: 18:12:15
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
   Coding: 0012627
   Subsystem 1 - Part No: 1K0 959 339 B
   Component: BF-Gewichtsens. 006 0003
   Coding: 0010021
   Coding: 0023203
   Part No: 1K0 959 701 K
   Coding: 0001269
   VCID: 366929BA41DD58F660-8062
   Coding: 0001269
   Coding: 0040400
   Part No: 1K0 959 703 D
   Coding: 0000144
   VCID: 31631AA6A8B37FCE35-8064
   Coding: 0000144
End-------------------------(Elapsed Time: 02:10)--------------------------
Carfixr
C?ID=136362
Can a used driver door lock module with same part number be used, or is it locked to donor vehicle?
Thanks
On a 2005 Jetta, I would not expect any problem swapping door control modules, provided of course you get the correct one.
Carfixr
C?ID=136362
This is a 2006 Jetta Sedan 2.5, still o.k.?
Thanks
Thanks
Sorry, typo. Let me re-phrase:
On an Mk.5 Jetta, I would not expect any problem swapping door control modules, provided of course you get the correct one.
The harness should be toned out, and to be able to carry current, because it doesn't only fail at boot location.
In addition other faults on shared bus for the other doors will need to be corrected.
