- Joined
- Jul 30, 2014
- Messages
- 1
- Reaction score
- 1
- VCDS Serial number
- C?ID=49004
I'm posting this thread to give positive feedback about changing coding in byte 18.
I was struggling with switching off my tail lights with DRL-s. Now thanks to Dana I've managed to do that.
So for me worked in byte 18 HEX 02 instead of original 29.
With that came one additional change: by switching on parking lights, my tail lights look like this, both tail light (lower) and brake light (upper) sections are illuminated with brake light section illuminated lower voltage, so that it looks like there is 5w bulb. While braking, the unit gives it 12 volts, so you can see clearly the difference. Originally there was only tail light section illuminated.
Here's the auto scan before:
Here's the auto scan after:
Monday,21,July,2014,09:36:43:53806
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWZZZ1KZAM654387 License Plate: 56OMND
Mileage: 110385 Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
Address 01: Engine (J623-CAYB) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 A HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 5862
Revision: -------- Serial number: 00000000000000
Coding: 00114014030400080000
Shop #: WSC 00066 000 00192
ASAM Dataset: EV_ECM16TDI02103L906023A 001005
ROD: EV_ECM16TDI02103L906023A.rod
VCID: 244D2DF92F09D13EDFF-8071
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
Component: MK70 M MASR 0104
Revision: 00H35001
Coding: 0017665
VCID: 7BFF36853A374EC6CE5-802E
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AB HW: 3C8 907 336 AB
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
Shop #: WSC 00066 000 00185
ROD: EV_ClimaBasis_SE36.rod
VCID: 6DDB08DDBC43D076401-8038
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 B HW: 5K0 937 084 B
Component: BCM PQ35 B 011 0028
Revision: BA011001
Coding: 00180E3A902DE3C040000080000000C407002988525D8160E4 8000000000
Shop #: WSC 00856 461 82526
VCID: 3163D4AD68FB7496249-8064
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 25011 21 0512
Coding: 009395
Component: Innenraumuebe 004 0611
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA1MWWX
Coding: 00003137
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B7FF685B2B78EC68E5-806E
Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME6240534CZZZT
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME6279104EZZZ.
Serial number: 3511HSME1F295D1EZZZ+
Serial number: 3521HSME1314451EZZZF
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000004
VCID: 830FCE65C2C7B606065-80D6
Part No SW: 5K0 920 860 J HW: 5K0 920 860 J
Component: KOMBI H04 0308
Coding: 170B00
Shop #: WSC 00066 000 00149
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 336FDEA59AE74686565-8066
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 091209F2002394
Coding: E9807F06000202002002
VCID: 69D37CCD40ABCC562C9-803C
Component: IMMO H04 0308
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EAD183C10DAD474EA53-80BF
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000282249
Coding: 0000B4
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 27573AF55E3F3A26FAD-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AG HW: 1K0 959 795 R Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004521354
Coding: 000090
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 3163D4ADA8FB7496249-8064
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000294024
Coding: 0000B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 285539C95321355EF37-807D
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AG HW: 1K0 959 794 R Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004526344
Coding: 000090
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 156 B HW: 1K0 035 156 B
Component: Radio H21 0057
Revision: R0000000 Serial number: VWZAZ1I8636700
Coding: 0000020002
VCID: 22412BE13D1DDF0EAD3-8077
End ---------------------------------------------------------------------
Revision: BA011001
Coding: 00180E3A902DE3C040000080000000C407000288525D8160E4 8000000000
Coding: 009395
